My FL 14
My FL 14
I got the plans a few weeks back and started building my FL 14.I just gave the bottom of the hull a coat of epoxy .Do i have to sand it before putting the fibreglass sheet over the hull? i, not building a skeg ,just some rails to help protect the bottom of the hull. What size( if possible in metric) should the rails ( don't know if rails is the correct word for it) be and how many should there be? Are the going the whole length of the bottom?
Re: My FL 14
I found in the plans the size for the rails . I did already a lot on the boat put some pictures in an album. Have a lot of sanding to do
Re: My FL 14
I call them runners but the name does not matter.
Exact size does not matter either: about 25 mm square.
You need either a skeg or runners for tracking: you can't row straight in string winds without them.
Re: My FL 14
If all goes correct i have it n the water by end of Jan or beginning Feb. Still working on a name
Re: My FL 14
Nice WHP!!! Is this the first pictures of your build?? Jeff
Re: My FL 14
Jeff there are some more pictures in the Gallery . Peter
Re: My FL 14
Ok and thanks WHP!! Jeff
Re: My FL 14
Gunwale on both sides is done sanded it . Set a smal board in to the bow to store the ancker, chain and rope. Next I drill holes for cleats and rod holders so I can seal the holes .
I,m brushing the whole boat with epoxy , do I still need a paint primer( undercoat ).
http://forums.bateau2.com/app.php/gallery/image/333
http://forums.bateau2.com/app.php/gallery/image/334
Re: My FL 14
Looks real good. Congratulations and keep it up.
Re: My FL 14
WHP, looking really nice!! Very good gallery!! Jeff
Users browsing this forum: Bing [Bot] and 15 guests
