Fostner bit and drill press?VT_Jeff wrote: ↑Fri Feb 12, 2021 12:58 pmThat would def simplify things. I fear that 1-5/16 may not be an easy-to-find mortise bit size.Jaysen wrote: ↑Fri Feb 12, 2021 12:30 pm A little secret...
If you have the proper radius bit, you don’t need to radius the template. Just make the corner straight extension of the edges. The bit will make the rounded corner for you.
So figure out the diameter of the hinge corner radius and make it simple by buying a bit to match.
For some reason I thought these were square with rounded corners. I’m no help at this poin
