V12 has a V bottom. According to plans first are stitched side panels and after that bottom panels are attached to them .
In internet I've seen more common in V bottom dinghies is first stich v bottom panels and then attached side panels.
Why do you recommend this order ?
Regards
Mario
V12 panels stitching order
Re: V12 panels stitching order
It's a bit more complicated than just stitching the sides, then the bottom. You stitch the bow loose, attach transom, set in the forward, mid and aft frames. Then you attach the bottoms.
Doing it this way, it is super easy to get the share right as you can very easily get the frame positions correct with the sides making a VERY stable surface. If you build in the traditions "right side up "bottom first" you have to have a cradle to support the bottom that matches the not-yet-developed shape of the V and curve to the bow. The BBC method is apparently fool proof as even I managed to be a nice boat
Having built the V12 (sail version) I could not imagine attempting to build it "bottom to top" as you suggest.
Thank you Janysen for your answer. I've asked because I've noticed lots of people have struggled with stitching V bottom bow section in the end .
That’s problem is the same no matter witch method you would use. You are putting a compound curve in the sheet at that point. It would be impossible to do right without a the frames with would make it even harder to do bottom to top.
The trick for the bow is to keep things loose at the start, use edge spacers, use pvc tie spacers and work things tight slowly. Then remember that the ply is a CORE not the boat so we can fill gaps with not problem. I think I filled about 1” of gap with some ply scrap, thickened epoxy and glass. Mine gets a regular beating every time she’s out and the one spot I know will never be a problem is the gap in the bow.
Thanks Jaysen, I have nothing to add except to say that you explained it well.
Thank you very much for the answers.
