This has probably been covered ad-naseum but here goes:
Is there a good reason that un-faired, 4oz glass weave won't work well as a non-skid surface on the deck? I was thinking it feels weird that I'm going to fair the weave first, and then apply a non-skid coating, when all I really need to do is nothing and I get about the same result.
As always, any/all opinions welcome.
Jeff
Glass Weave for non-skid
Re: Glass Weave for non-skid
I would worry that after painting the non skid ability might be lost. If so you can always add non skid to another layer of paint.
Not the same but I once laid 1708, roven up and with dye add, on the deck of my commercial salmon boat. I had to boat for 6-7 years after and it both held up and worked very well the whole time.
That is definitely possible, it's pretty tight already without paint.
That's good to hear. At least I know I'm not crazy for considering it.
Considering that you are using Fuzz as the source of not crazy means you are almost certainly crazy.
Great point! Grading crazy on a curve in this case I guess!
I once did some non-skid that went like this: I put down the weave, then went a little heavy with epoxy, then tossed a few handfuls of garage floor coating grit that said it was epoxy compatible over it as it was drying. I bought the grit from Home Depot for around six bucks.
That boat got used really heavily, was always coated in sand from me climbing in and out at the beach, got walked on probably 5 times a week, and three years later the deck would still take the skin off your knees if you let it. It was about the grippiest deck I've ever had.
Just weave, I'm not sure. But weave with a bit of cheap silica grit, wow, that is some hard-wearing, hard-gripping floor. I don't really recommend it for bare feet, though.
I like that idea a lot but the wife's barefeet and the dogs feet may not.cracked_ribs wrote: ↑Mon Mar 08, 2021 3:56 pm Just weave, I'm not sure. But weave with a bit of cheap silica grit, wow, that is some hard-wearing, hard-gripping floor. I don't really recommend it for bare feet, though.
I think I'm going to go with Mike Seaslugs method using the BBC grit and forget the effortless/glass weave idea.
I have to remember most of you guys use your boats a little different than how I do. There is no such thing as too much deck grit for me. The next time I am bare footed on a boat will also be the first time.
The advice I received on a different boatbuilding forum was that using just the glass weave for non-skid works BUT it's a one-time application. If you ever need to refinish the deck, if you just look at it with a sander you'll sand into the glass and destroy whatever structural qualities the glass was intended to bring to the party in the first place. You'll need to re-glass the whole deck. Better to fill the weave and top the paint with non-skid, because when that wears out you can fix it.
I've never worn out a deck enough to test that theory but it seemed to make sense ...
Great point!Chenier wrote: ↑Mon Mar 08, 2021 8:37 pm The advice I received on a different boatbuilding forum was that using just the glass weave for non-skid works BUT it's a one-time application. If you ever need to refinish the deck, if you just look at it with a sander you'll sand into the glass and destroy whatever structural qualities the glass was intended to bring to the party in the first place. You'll need to re-glass the whole deck. Better to fill the weave and top the paint with non-skid, because when that wears out you can fix it.
Users browsing this forum: Bing [Bot] and 11 guests
