Supplies substituted for a D15
llargent86
New Poster
New Poster
Post by llargent86 »
Jacques
I contacted Reid and he pointed me to you. Some how I ordered the plywood to build the Indian River Skiff, and I ended up with the following:
2 pc. 1/4" plywood
3Pc 3/8" Plywood
2Pc 3/4" plywood
No 1/2" plywood
Can I use the 3/4" in place of the 1/2"
Is there any way to substituter the 3/8" for the 1/2"
Or any Ideas?
Lee
jacquesmm
Re: Supplies substituted for a D15
Post by jacquesmm »
Yes, you can use 3/4" instead of 1/2". Those panels are flat or almost. Close to the tip of the bow, you may have to kerf if the 3/4" does not bend.
A couple of transversal slits halfway deep should take care of that.
Looking at the nesting drawing:
1/4" for the hull sides = 2 sheets
1/4" for the benches sides = 1 sheet
3/8 for the decks = 2 sheets
3/4 for the bottom and transom instead of 1/2" = 2 sheets.
My total is not the same than yours. Do you use 3/8 for the bench sides? That will be fine.
Another possibility is to replace the 1/2" with 3/8. That is enough for the bottom but not for the transom. You could ad a clamping board at the transom or double the 3/8 at the top of the transom. There is enough leftover to do that.
llargent86
New Poster
New Poster
More questions
Thanks a bunch for the advice, I will use the 3/4" for the bottom and the transom
A few other questions.
You said I can make some scarf cuts across the 3/4' about 1/2 way through to help get it to bend. Do I make them on the top or under the board.
Also, we are making this boat in a high school summer school class, My students would like the standard 3 bench version and we see it calls for a Kelson when using benches. What is used for it and can use tell me why it is needed for benches. (Good information for students - and instructor) . Thanks again for all your help.
Working class
Lake Roosevelt High School
Mr. L
jacquesmm
Re: More questions
Post by jacquesmm »
llargent86 wrote: Thu Jul 08, 2021 3:07 pm Thanks a bunch for the advice, I will use the 3/4" for the bottom and the transom
We call them kerfs. Those are slits in the plywood, about half depth, on the convex side (outside). Where ever you have kerfs, you must cover with fiberglass.
Working class
Mr. L
The idea is to have longitudinal stiffness. The hull sides give you some but the long bench sides are also a stiffener. If you build the thwarts (seats across) and no benches, you lose that stiffener. I recommend to add either one keelson or a pair of runners on the bottom to compensate. This is particularly important on a flat bottom planing hull.
