Fitz 21 CC Transom Stringer Sole R&R
NOTHING ELSE MATTERS
Re: Fitz 21 CC Transom Stringer Sole R&R
Post by NOTHING ELSE MATTERS »
Fitz, that is a great motor, as good as the 200 HPDI, bullet proof.
tech_support
Post by tech_support »
I hope it is as good as everyone says...I am pretty psyched to be at this point
I know of one that is 15+ years old, has been mistreated, left in saltwater, sunk at least once, and still runs :!: :)
Not as fuel efficient as the later HPDI's, but its a turn the key and go machine
FitzFisher
Post by FitzFisher »
I finished off the primer in the interior. Have a little bit of touch up fairing to do, but should be ready to roll on some top coat and Kiwi Grip Soon. In this shot you can see the studs that will secure the leaning post (the only bolts in this entire boat)
A shot from the rear
and A shot from the bow
Should get a lot done this weekend. I wish my paint order had come in today....plenty of other stuff to do though
You are what you is! And I is Done!
wildbill
Post by wildbill »
Looking Sweet!!!
Shooting for some winter time tarpon season in the inlet this year ? 8)
FitzFisher
Absolutely...Grouper...Tarpon...snook....all fish beware....If I had a good crew to help knock this out I could be on the water in a couple of weeks.
FitzFisher
So I keep going around and around and around with the filler and the primer, BUt I think I am ready to do a final sand on the top gunnels and roll on some paint. :doh: :help: What grit sandpaper should I do for the last step before rolling on the Sterling Topcoat? I am using the transportation white over the S3 Highbuild yacht primer. I am going to do Kiwi over most of it as well, so I am wondering if I really need to do more than just skuff it with some 120 or 180....I will be using the roll and tip method for application. Words of wisdom??? :help: :doh:
Thanks
I used 180 grit and came out great. The only problem i have is I went over and over with the filler too and after i painted the sides of the inside hull and a little around the floor i discovered that the my efforts on the filler was not good enough. So go over and over and over with a fine comb.
Other than that you doing great.
FitzFisher
Here's a few updated pix. Still going around the boat fairing sanding and priming, but I am just about done with all that I hope. I added a couple of new 1 1/2" scuppers on the transom just above the the sole level
Mocked up some of the bolt on items so I could seal up all of the penetrations...
primed and test mounted the console
worked on a custom aluminum gauge panel
and did a bunch of other little things to get closer to the splash day....
NOt enough hours in a week....
Cracker Larry
Post by Cracker Larry »
You have come a long ways, looks great 8)
Walkers Run
Post by Walkers Run »
I just saw your post about the Yamaha. I had a pair of those on a Pursuit. Could not kill them. I tried. I used Yamaha ring free, and Yamalub. I sold the boat with almost 2,000 hours. They are still going strong for the current owner.
"Do. Or do not. There is no try" - Yoda
https://youtu.be/nzWO9FVJODo
