I guess I'll amend my previous statement about cause and quantity of blisters.
Each of these brownish colored spots just forward of the transom is a small void under the gelcoat. They appear to have resin starved tips of glass strands in them.
After grinding them out and filling, I moved on to the area just ahead of that. It had a few of the telltale cracks and brown spots, but the defects were much more extensive. This bubbly area is about 4x6 inches!
It was surrounded by dozens of other, smaller voids. Here's a wider shot after the first round of QF.
Didn't realize that I was sailing with all of that additional water ballast in these blisters.
O'Day 20 Rebuild and Refit
- gk108
Re: O'Day 20 Rebuild and Refit
CC, D15, V10
- gk108
Whew
That only took a few months.
Every time I thought I had all of the blisters fixed, another one (or three) would make itself obvious.
Here's the area where the previous pictures were taken.
I used a whole gallon of S3 primer. The bottom had suffered from some aggressive sanding to remove anti-fouling paint before I got it and the surface was in rough shape from that. The first coat of primer was mostly sanded away but it filled all of the gouges and swirls.
After sanding the first coat, three more were applied at 12 hour intervals. Now the boat has a smoother entry.
I'm hoping the tape edge from the primer at the waterline will show through enough to mark the line when it's time to paint a bootstripe. Time to order some bottom paint.
CC, D15, V10
Like new, but better.
Fantastic!!
- gk108
The bottom is painted.
There's a few bugs and such that a little light wet-sanding with 2000 grit will take care of.
CC, D15, V10
- topwater
Big difference gk Looks like you will pick up some hull speed there.
Novi 23 finally launched !
Nice work Gary
- gk108
I could have posted this with a few changes http://forums.bateau2.com/viewtopic.php ... 44#p339035
Interlux VC Performance Epoxy has been added to my list of the most horrible smelling things, ever. Opening the can of base was a shock to the senses that literally made me step back.
After a week, it seems like good stuff. Really hard finish, similar to the epoxy graphite on the keel. I'm going to try and get some of the wet sanding done this weekend, but Jr. turned 33 and I have to deliver her birthday card today.
CC, D15, V10
- gk108
Next up is the transom. Big changes here. The kicker bracket was on the starboard side. With a right-hand prop, like all of them except the Seagull have, this boat had two directions of travel under power...Forward and -105 deg. to Port. I haven't seen a better demonstration of prop walking.
I'm going move the kicker bracket to the other side and see if that makes it easier to back out of a slip.
Transom has a reverse rake with a bit of camber, so the bracket needs some wedges under it. The new wedges are a bit taller to trim the motor better.
Some contouring with a belt sander and the will fit the little bit of camber. Too bad the cool looking side will be against the hull.
CC, D15, V10
