DAYTRIPs Bertram 28 Strech
Re: DAYTRIPs Bertram 28 Strech
As always - amazing! Great to see an update. Thanks.
Did you add a step to the hull bottom that I missed? Maybe it's a screed that you use to fair the hull bottom, in the last boat pic?
Thanks guys.
That is the bracket Rick. No step for me.
Of course it is It makes sense now.
Sprayed the bottom with interlux vc performance epoxy. Marked the water line with with a lazer. Currently wet sanding to 600. Want to spray with paint but the alexseal rep strong encouraged me not to as there is a chance for blistering and the vc should be less friction. Current boat has it and it has be just fine. The wet sanding sucks and the luster is......lack luster
1200 grit ..not happening! Looks great though
So, do any of these come back and blister on you after all the work?
My little 69 Whaler was skinned with 6 oz and that damn thing blistered on me now...would you cut them all out? I have not topcoated; just primer.
I have not had that happen fortunately. I ground all gelcoat off then did two skins on this hull as well as the 28 and my 17 mako. No issues. Is it the glass or the paint system?
Nice DayTrip!!! Jeff
Users browsing this forum: Google [Bot] and 14 guests
