Are you dead set on an epoxy just for durability? What kind of service do you expect?
https://slipdoctors.com/collections/non ... 5EEALw_wcB
This stuff specifically mentions use on boats.
If you wanted to go more cost effective, you could neat-coat with epoxy and then use one of the one part epoxy garage floor coverings from the local home improvement store.
I am testing out the durability of some valspar porch and floor paint on my boat, so far so good. I have their non-skid on the sole. It is a little tough to clean, but the nonskid has a nice texture and is gentle on bare feet.
Spray epoxy
Re: Spray epoxy
Unfortunately most people don't understand what happens when you rebuild the transom o a fiberglass boat, as far as moving the low point of the boat away, forward, from it's intended place.
Here is a link to where I explain the thought of the PVC pipe
http://classicaquasport.com/smf/index.p ... #msg133124
Here is a link to where I show what is actual problem
http://classicaquasport.com/smf/index.p ... #msg133556
Here is a link to a rebuild that shows the PVC pipe installation to keep a drain at the new low point of the boat
http://classicaquasport.com/smf/index.p ... #msg134262
I didn't figure this out until after I rebuilt my Aquasport 170. I now usually have about 3/4" - 1" of water after I pull the garboard plug, even with the front jacked up.
Re: Spray epoxy
One of the best marine epoxy coatings I've ever used is PC-11. It's particularly useful if you want to make emergency boat repairs while you're still on the water. Can stick to and bond to a variety of surfaces and materials.
Re: Spray epoxy
Great point Rick.
Even on my new build, I was struggling a bit to ensure that the self-bailing transom drains would remain the low point after drilling/fairing/painting etc, and I really won't know how they work until the boat is further along and I get it I the water. They will definitely let out a lot of water, quickly, which is their first priority, but only time will tell how well they get rid of that last little bit.
