knottyBuoyz III The TW28 Project
- icelikkilinc
Re: knottyBuoyz III The TW28 Project
Will you glue all that support structure, especiallly the middle beams which is directly over the engine?
- icelikkilinc
This to give my view
Steps moved for front access to belts etc
Support is not over the engine to allow lift
- Attachments
- E9FB8618-BE51-4DE7-AA4A-1C92153AA7D4.jpeg (142.1 KiB) Viewed 8885 times
- Knottybuoyz
I think I'll drop mine in the water week after nest. I win!fallguy1000 wrote: ↑Sat May 30, 2020 10:39 am Are you gonna launch this season or next?
Want to race to finish?
I am planning May 1, 2021.
All the best. Looks good to see the deck members.
Yours Aye! Rick
- Knottybuoyz
Actually all structure will be glued except those running down the centerline. They'll be removable for full access. It'll get clearer as I go along.icelikkilinc wrote: ↑Sat May 30, 2020 9:31 pm Will you glue all that support structure, especiallly the middle beams which is directly over the engine?
Yours Aye! Rick
- Knottybuoyz
I think on my model engine I can access all the belts, pulleys, alternator etc. from the sides of the engine. I'd like to keep that bulkhead in tact so I can put in sound insulation there.icelikkilinc wrote: ↑Sat May 30, 2020 9:33 pm This to give my view
Yours Aye! Rick
- icelikkilinc
My stairs and bulkhead piece had sound insulation at the back
When I pushed back in place, there are tightning bolts to secure and support insulation
Front access is really important imho
- Knottybuoyz
Yours Aye! Rick
Hey Rick...another great video. A well thought out deck/tank plan I'd say.
I only have a couple of critiques/advice for you.
1. The blackwater tank service hoses have service lives of 3-7 years. Once that time elapses; they will start to stink like hell. You must plan for them to be replaced. Perhaps you know; I did not until I ordered my shitter.
2. Fuel lines and battery compartments are a no-no. Running a fuel line anywhere near batteries is a bad idea and against abyc and probably Canadian laws. You may consider bulkheading the battery compartment or anything that has a remote chance of sparking or grounding. I would be a bit nervous about fuel smells in the living spaces and personally would also bulkhead the fuel tanks, the electrical, and the blackwater tanks for odors, and any spark. That is me. You could use a cheaper plywood; no glass, relatively easy to do. I am surprised fuel tanks are in the living area, I could be wrong. The main thing to remember is no fuel system can traverse above a battery compartment. I have a start battery in my boat and I think I can get away with running the fuel line below the terminal heights.
3. see private message
If you need more hardwoods for the build, pm me.
Nice Rick!!! Jeff
- Knottybuoyz
The sanitary hoses will all be openly accessible and easy to change out. Made sure of that right from the start.fallguy1000 wrote: ↑Mon Jun 01, 2020 9:55 am Hey Rick...another great video. A well thought out deck/tank plan I'd say.
The black & grey water tanks will have 'drop in' bulkheads separating those tanks from the main engine space. The batteries will be in proper boxes. As for the fuel tanks being under the main living space there will be plenty of ventilation of the space (forced by elec fans) and I'm 99% sure I'm going to open the main cabin in a 'picnic style' so there will also be plenty of air exchange in that area as well.fallguy1000 wrote: ↑Mon Jun 01, 2020 9:55 am 2. Fuel lines and battery compartments are a no-no. Running a fuel line anywhere near batteries is a bad idea and against abyc and probably Canadian laws. You may consider bulkheading the battery compartment or anything that has a remote chance of sparking or grounding. I would be a bit nervous about fuel smells in the living spaces and personally would also bulkhead the fuel tanks, the electrical, and the blackwater tanks for odors, and any spark. That is me. You could use a cheaper plywood; no glass, relatively easy to do. I am surprised fuel tanks are in the living area, I could be wrong. The main thing to remember is no fuel system can traverse above a battery compartment. I have a start battery in my boat and I think I can get away with running the fuel line below the terminal heights.
All the electrics will be set up on the stbd side space I've laid out. All cables and wires will be shielded in cable supports and will be nowhere near the fuel system lines. All of the fuel lines go forward and across the main bulkhead to get to the fuel pump as far away from any electrics as possible. The only exception is the 1/4" fuel feed line to the diesel heater which will get shielded and I'm not exactly sure where I'll locate that heat just yet.
Canadian Small Vessel Construction Standards (Transport Canada) are virtually identical to ABYC standards for all these pieces of equipment. I have both sets of standards.
Acknowledged. Thanks.fallguy1000 wrote: ↑Mon Jun 01, 2020 9:55 am 3. see private message
Yours Aye! Rick
