After using the boat, I realized that a rub rail is a must. I saw Joel's at the builders meet and decided to try and put one of those on in black. I drilled then overdrilled and now I've filled....... Here is what I got so far.
I also got a tiller extension to try out and a tiny tach to see what rpm's I'm running with the current prop....
FS14 build saga continues......
Re: FS14 build saga continues......
Very neat work Derrick You'll be glad you installed the rubrail.
You're garage is still a mess though And I think you need another fishing rod
CL,
I should have the rub rail on by the end of this weekend.
I do need to organize the garage before I start the next build. Was that an offer to come over and help?
A man can never have too many rods. As you can see, they are well organized and up off the ground.
that looks great, I did mine the same way - "drill and fill"
That rubrail lays out straight and it comes pre-drilled. It was so easy compared to the "kits" I have used in the past. Never again. I liked that material enough I found the manufacturer and ordered a pallet of the rubrail and insert (in black and white)
I like the snoopy rods between the standup 30'sshine wrote:that looks great, I did mine the same way - "drill and fill"
Joel,
That is the best rod rack I have ever seen. You do have to alternate small and big rods so they fit... The snoopy rods catch the biggest fish
By the way, I picked up another spear gun this week.. I think you would like it. I'm going to start to increase my spear fishing. I'm thinking of close in with the FS14 and free dive.
Does that mean your going to be selling the rubrail in the store!shine wrote:shine wrote:that looks great, I did mine the same way - "drill and fill"
C17ccx, Mirror Dinghy
Who makes that rubrail?shine wrote:yes, we have an order for a pallet
You like it better than the "flexible" ones you stretch as you put on? I have put those on before (TACO brand) , but cant remember if they are pre-drilled? I know that they are a pain to pull off and line your holes back up!
yes, its pre-drilled every 6", and because its rigid you can very easily line the rail back up so the holes match the "drilled and filled" epoxy plugs
