Ken:
Thanks for the reply. I have read lots of posts but seem to have missed something somewhere. The advice would have made a difference i am sure.
To resolve the voids I have drilled 1/8 inch holes in the voids and have used a hypodermic syringe to inject epoxy into the voids between the fiberglass and the plywood. It will take some time but the first attempt has done pretty good. I have a couple of weeks before the help arrives to put the cloth on. In hind sight It would have been way better to followed you directions if I had them to begin with.
Thanks.
Bill
PH18 - Getting Started in LA
- Muddler
Well the injection process has worked with marginal success. I was not totally happy and the process was taking to long, squirt, wait to cure, squirt some more, wait to cure. After two evenings of this, I got up This morning and got out the belt sander I took off the tape at the transom, and from forward of bulkhead "C" back to the transom. I then followed the "Stickystuff" advice. "Thanks Ken"
I wetted the ply, put on the putty, laid on the tape, epoxied and squeegeed things out to a smooth finish. It looks a whole lot better and I will sleep good tonight knowing there are no voids behind the tape.
Bill
Bill
Is it a Boat yet?
Mudder,
Get some of these roolers they can be had at most any
boat store but they will help you push out any air under
your glass. Glad to hear you ground out the old glass
This was the only picture I could find with a quick google
http://www.tapplastics.com/shop/product.php?pid=188&
- Muddler
Thanks for all of the replies, I have the roller, The issue was the angle at the chine. The fiberglass tape will not make the bend around anything close to 90 deg. After grinding off the first attempt, I rounded the chine and laid in the putty, used a spatula to smooth out any air bubbles. I used the spatula the first time and got the air bubbles out and things looked pretty good at first. I covered the tape with plastic to make things a little smoother (that part worked very well) but when the plastic was removed the tape had pulled off the plywood just on either side of the chine in some long sections.
I used a hypodermic syringe to inject epoxy through small holes into the voids and that seemed to work OK in some spots but in the end it just seemed best to get out the belt sander and do it right.
Bill
Bill
Is it a Boat yet?
- robbiro
Muddler,
She's looking great!! Enjoy the process, I have learned much not only about building, but about me and how I cope with life also, WHOA!!!! That was too deep for a Saturday Morning. Keep after it and before long you will have a thing of true beauty sitting in your garage and then on your favorite body of water.
Robbie
(I see that we use similar barbers)
Robbie
32.20.0983N
89.48.0787W
GF-16 FIRST LIGHT finished; D-5 Crusader '08 finished, PY 12 plans in hand
89.48.0787W
- Muddler
The hull fiberglass is on!!!!!
We finished the hull fiberglass late Friday night. It is supposed to get to 25 tonight so we'll leave the heaters on to help things to cure!
Bill
Bill
