Cracker Larry's OD 18
- chicagoross
Larry...just as a tip from someone who put gunwhales on and has used the boat quite a bit now:
Make sure that where the individual gunwhale sections meet, you splice them together, like you did with the hull panels using biaxial tape. You can do this after they are installed, rather than installing one long section.
What happened to mine, as I didn't do this when I put them on my OD16, is that the flexing of the hull when it pounds on the seas, causes cracks to appear where the different sections meet. Not a major problem..just a blemish that could've been avoided!
...it's one of those repairs that I still need to get to (one in several..hehehe) ...but it hasn't stopped me from fishing yet..hehehe!
All the best! Love your boat...looking really great.
Tom, I'm thinking the rectangle may look better also
Thank you CR
Craig, no need to re-invent the wheel. My pleasure
No GK, I'm not that good of a builder, or just not that industrious. I've got the transitions worked out now, I'll show you tomorrow what we decided.Maybe you need to steam-bend something for the transition at the rear.
1" X 1" yellow pine. I ripped them on the table saw from a larger board. Yeah, this boat is going to be tough for certain. You can't buy a boat like this at Bass ProWhat size batten/cleat are you using??
You just don't know how much beer and pondering it took to figure this stuff out. And how much wood I've wasted. I told you I made 30 frames to get 10. My only real attribute is that I'm real stubborn.Just when I think I got it figured out you show me a better way.
Daddy
Just a small hand saw. A backsaw actually.Cl what did you use to cut the notches ?
You don't have to have a router, but for some applictions it is the fastest and most accurate. I'm not a wizard with them, but the basics we can handle.I can see that i am going to have to buy a
router and try to learn to use it.
Exactly. That will probably save more time than it took to recess the cleats.A flush cutting bit can save a lot of time. You now have your inner and outter edge, rout away.
Thank you CR
Larry, sure hope you don't get mad when you see all these unique additions on my boat!
Thanks Dr. Bones. I was planning on butt blocks underneath for splicing, where they will be hidden by the coaming. Do you think that would be best?Make sure that where the individual gunwhale sections meet, you splice them together, like you did with the hull panels using biaxial tape. You can do this after they are installed, rather than installing one long section.
As I go grey, I find that the only real attribute. This new little section is such a gem. Big thanks on this, it's gonna help me big time on my gunnel time. BTW, you gotta a killer CD here and maybe, with a little push, a neat little builder's book goin' on.My only real attribute is that I'm real stubborn.
Says good on you Dougster
Your gunwale installation is similar to mine.
- You used larger cleats at the frames so that after you cut the notch you still have some cleat supporting the rail. I just have the frame supporting the rail.
You notched the fore frame and motor well to support the rail. I just used some large radius fillets there. I may run some stainless steel deck screws through the rail and into the end of my cleats. I really don't want that joint giving way with me standing on top.
I like your system much better
-david
-david
See my blog: http://buildingtx18.blogspot.com/view or drop "view" from the end for the old interface
And, if you have, say, two butt block splices and they fall halfway between the frames you could then fit in a short half frame under each one...just an idea if you plan on walking on the gunwals or stepping on them when getting in or out of the boat.
Looking good.
Frank
P.S. Did Jacques ever post up his impressions of the CR builders meet, or did I miss it ?
Looking good.
Frank
Craftsmanship means no wrinkles in your duct tape.
Users browsing this forum: No registered users and 24 guests
