Slow progress this week,due to the rugby world cup, but some never the less,
I have mounted the frames on the jig & also the transom.
I am going to have to re-cut frame D due to what is best described as a momentary loss of brain function in that I marked it with a measurement that is not on any of the drawings, anywhere. I was always taught to think thrice , measure twice & cut once.One day I will take that advice & save myself time in the process. Nevermind.I can use the ply later on something else. I am gong to recut the frame from OSB later today.
I made some screwed adjusting brackets for the transom mounting as it was to big & heavy to hold & adjust on my own.
here are some pics-
overall view of transom
& one of the adjusting gizmo-
& last another view of the molds on the strongback
You might be able to see that the stringer is proud of frame D. the measurement I got wrong was the baseline to chine. Should have been 89, marked & cut at 59. 59 appears nowhere on the frames drawing,so what I was thinking I don't know.
Steve
A British FS17
It will be interesting to see a standard boat on it's jig to see just how bigger 8 extra inches of side panel makes it appear. I will agree with Jerry tho, it looks bigger than I envisioned.Lower wrote:
Jerry...just an FYI...he is building the raised sheer version. Makes those pieces look bigger than the standard build.
Lower, you can only go as fast as life lets you............I am so keen to get on that I am trying to find time where none exists,thats how the stupid small mistakes are creeping in. Rushing.
since last time I updated this thread I have recut frame "c" from OSB (horrible stuff to work with btw) & mounted it on the jig.
I had two evenings last week where I had a couple of hours at a time to work & here is the result
As you can see both bottom panels are on & stitched, this went easy with hardly any stiches pulled tight on the straight part of the keel.The keel & planing surfaces seem really good with no hook or rocker that I can see or measure with the 1800mm staight edge I have. I realise this may change as the sides are hung.
It is also sitting nicely on the frames & stringers. The bow I did have to open up the gap between the panels with a jigsaw as the stitching pulled it into shape.
this is the view along the keel from the transom-
& one down the centre from the front-
finally, the tip of the bow panel came out right on the money at the bow mold,which I was dead chuffed about
I will post a pic later of that, with a hopefully fully assembled stitched hull.
I can tell you it looks a lot bigger than I thought,a bit daunting thinking about sanding
I realise I might be a trifle ahead of myself here, but am now looking for suggestions on the best way to tape the hull, i.e do the transom then the keel,then chines or?????. which way produces the neatest overlaps?. I don't think I will be able to fillet & tape in one session, my plan is this;
-fillet all the seams in one session & let cure
-radius all the edges & sand,precut all the tapes at my leisure
-coat seams with epoxy & tape all in one go
-unless someone has a better one
any suggestions/tips would be appreciated please.
Steve
Steve
Awesome Steve! That's what I've been waiting for. Hull looks nice...and like you say BIG! I'm slowly moving along as well. Just finished cutting everything out and put my epoxy order in. Time to start glueing things together. Thanks again for posting the pics. I'm enjoying watching it come together.
Users browsing this forum: Yandex [Bot] and 8 guests
