If you use screws make sure to take them out before the epoxy cures, or their in there for good.
At first my motorwell sides didn't exactly line up, took about 3 tries measuring & tweeking my jig till all was straight and linned up, I was also off just a little in my measurements
hope this helps,
Daniel
New Pictures
Hey. thanks very much guys.
I am using forms for every thing except for the transom and the clamping boards, which I already cut and dry fit. I would like to add that the keel line up almost perfectly from the mid section to the transom.
I measured a new motor well side again today, gained 1/8", still short by 1/8"
Question; on the side where the clamping board hangs, where does the 10 7/8" measurement begins? Does it start at the very top most right corner, or is there an off set by a perpendicular line to compensate for the 1 1/4" cut out.
If I use the off set measurement, I will drop an 1/8" on line up of the keel as mentioned above.
Does this matter?
maybe Jacques or Shine can add something to this.
Thanks again guys for all the encouragement.
Bushmaster
Does this matter?
Bushmaster
OK guys
physic myself up and summed up the courage to mix up my first batch of epoxy ever. Well I poured 4 ounces(2 of Jacques pump) of resin and 2 ounce of hardener. stirred well for over 2 minutes ,closer to 3.
It was a hot morning (80 degrees FH) but had both garage doors open, I had more than enough to do the transom side and three sides of clamping board, I am only using one clamping board at this time. Tomorrow I will do the other two sides of clamping boards.
I mixed 6 ounce of epoxy, add one handful of wood flour...my hand is very small.. stirred well was like ketchup, add another handful came out like peanut butter.
Lay it on the transom part, did not even cover 33%. build another 9 ounces this time.. all the time my heart is racing hoping it would not harfde on me, i had no idea what I was doing.
This batch came out lovely. completed the transome part and 1/4" of one
side of the clamping board..like I said this is my limit..I am taking Steve's advice. Again hurried up and mixed up another batch of 9 ounces again no problem. Enough to finish the camping board side.
Before that I drilled 4 3/8" hole to insert the softwood dowel I bought.
Attached the clamping board to the transom aligned with the dowels. works great so far. Put some weight on it, half a cement block, 2 10lbs barbells, 4 container of resin.
An hour later I forgot to clean up around the transom, I used a plastic spreader to clean up the excess mayo and a rag soaked a bit with acetone. Did a wonderful job.
Now I have to wait until tomorrow to really check if I deserve kudos.
Question, should I sand the clamping boards that I had already covered with the left over epoxy and put a thin coat maybe or should i just lay the mayo on top of the already coated surface?
Please advice.
Pictures coming soon.
Thanks for all the advice and help guys.
Please advice.
Well done your away .If the epoxy coat you put on has been on for more than 24 hrs, sand it to provide a key for the next layer.the pre coat of epoxy is there to seal the wood & help prevent the wood out gassing so you dont need to go wild, just use some 80 grit to scuff it up good.watch out for the dust tho',use a mask.
Steve
Steve
Steve
After sanding (scuffing up) should I add a light coat of epoxy or just layer the mayo?
Thanks Steve
http://forums.bateau2.comthumbnails.php?album=751
Thanks Steve
When wood is already sealed from a previous cured coat, there will be little benefit from another epoxy coat before the mayo. If you were laying mayo on bare wood, depending on the thirst of the wood, you would want a *soak* coat first, so the epoxy would not be wicked out of the mayo filler blend at the substrate bond surface, but this is not the case with you if there is already a cured seal layer on there. The mayo blend should have plenty excess epoxy in it to get into and bite into the sanding scuff marks, imho. As long as we're talking mayo and not stiff peanut butter. Peanut butter will not flow and fill well during the lamination, but neither should it be extremely runny. As you mix and spread, you'll know if it needs thinning or thickening. Be sure to use enough so that you get some ooze, but not so much pressure that it all gets oozed out. Mix thoroughly, but watch the clock too! Hold your breath. Don't forget to breathe. Hurry up and wait. All those fun things!
Hi Berndl and ks8
I am building the standard console model of the FS 17 and I am thinking of hanging the Honda 50 hp, weighs about 205 lbs same for the 40 hp. price is about 200-300 dollars difference.
I don't know how much difference this makes in weight ratio to the over all design. I plan mostly to go to the Florida Everglades...shallow water.. and to the Byscane Bay just off from Homestead.
Flamingo is not very far away from Homestead.
Thanks KS8 for the advice.
Bushmaster
Bushmaster
Users browsing this forum: Google [Bot] and 11 guests
