I used bolts 2" long 6-32 stainless with large fender washers and wing nuts to hold the rails and taped the edges.
Took the rails back off, mixed wood flour with epoxy and applied it liberally to the rails after I roughed them up with 60 grit. put them back on and tightened everything up until the glue started oozing out. Pushed the glue back into any gaps with my finger, and then cleaned the outside of the rails with a rag and vinegar.
Tomorrow I will pull the bolts and patch the holes with epoxy.
Was easier than I thought...
Cape Man's Dory
Re: Cape Man's Dory
Re: Cape Man's Dory
Re: Cape Man's Dory
Was having more trouble posting pics than putting the rails on!
Re: Cape Man's Dory
Might give them a light coat of polyurethane before I pull the tape. Okay....I will.
Re: Cape Man's Dory
Hi,
Posting so many detailed pictures is invaluable for us because they stick in our mind and should we ever be in the spray rail mounting position we know clearly how to do it namely perfect your way. Wish you and your wife a Happy New year.
Greetings from Karl
Greetings from Karl
- glossieblack
Re: Cape Man's Dory
Very nice.
What are the cross sectional dimensions of the rails?
Re: Cape Man's Dory
Thanks guys. Remarks like that make posting worth it.
The rails are 1.5" x 3/4". I didn't want to leave the bolts in so glued the wide edge down. We launch Wed. Won't be able to post until I get back which looks like the 7th. AT&T has good cell coverage at Cape Sable, so I switched to Verizon
Re: Cape Man's Dory
The good news is we have 6 days of light winds and warm temperatures so the fishing should be hot this year. The bad news is the bugs might be atrocious! Going grocery shopping and packing today.
Happy 2019!
Happy 2019!
Re: Cape Man's Dory
Those look good Craig. You sure did a good job of taping things up to protect the rest of the boat.
Take lots of pictures on your trip. You can sort through them to edit out the innocent
Re: Cape Man's Dory
Are you feeding the Yankees peas, collards and hog jowls tonight? I got mine on...
The AT&T vs Verizon thing is kind of funny, it’s all about location.
I had to buy a Verizon hot spot in order to have phone service at my hunting camp in Lake City.
My AT&T phone works great in Cape Sable.
Richard
viewtopic.php?f=12&t=62146
