Curacao CS 25
Posted: Sun Jun 08, 2008 7:41 pm
by peter-curacao
Edited by admin: this is the detailed story of the building of a CS25 by Peter H. Long but worth reading.
Well there go's nothing
after a lot of studying the plans I decided to start today before the plans fall apart from the studying
So what did I do? not much if you ask me I measured and cut the transom (3X), frame A and both inside stingers (2x) made some pics that I will post later with some more interesting pics.
Laterzzzz
Peter
Posted: Mon Jun 09, 2008 4:06 am
by steve292
Peter,
Nice to see you start,post plenty pictures.I like the CS boats,but you don't see that many construction photos.
Good luck,
steve
Posted: Mon Jun 09, 2008 6:53 am
by TomW
Peter you got your foot wet. That transom is biggggggg. So good start. Glad you made the first not so small step.
Posted: Mon Jun 09, 2008 7:48 am
by jgroves
Lookin' forward to seeing your boat come together. Tom is right... the transom is huge so good work!
folow up
Posted: Mon Jun 09, 2008 8:36 pm
by peter-curacao
Today (afternoon!) I started with the outside stingers, that is until my tube gave some problems broadcasting the match
what to do???? not so difficult wait for some signal on my dish? didn't think so! what I did is left everything in a hurry and went to the pub to see the rest of the match!! And I think that was a good thing to do! we won from Italy with 3 to nothing Cheerio!!! OK there's always Manana
boating time
Sorry for this no to nothing update
Posted: Tue Jun 10, 2008 7:52 pm
by peter-curacao
Today I finished the outside stingers, measured and cut stations F - G - H and epoxy glued the transom pieces together now that was fun
Al the above with a little hangover from the victory party yesterday
Tomorrow I will try to finish stations B,C,D and E, wanna try start with the Jig this Saturday.(also try to post some pics then to)
I don't understand one thing though, don't know were I read it but I remember reading that all the stations should be able to cut out of standard plywood 244 x 122, but how do I do that with station B -254x 141,7 , station c - 259 x 155 and station D - 254,2 x 145,7 ? anybody can help me out with that or have some tips?
Ciao
Peter
Posted: Tue Jun 10, 2008 8:13 pm
by TomW
Peter don't forget to look at the nesting diagram. Jacque will have shown there what he feels is the best way to get the best way to use the least amount of wood.
I know on my C17 frame C is cut on two different peices of wood because of it's heigth.
Posted: Tue Jun 10, 2008 8:24 pm
by peter-curacao
TomW wrote:Peter don't forget to look at the nesting diagram. Jacque will have shown there what he feels is the best way to get the best way to use the least amount of wood.
Thank's Tom but on my nesting diagram there are no stations only frame's, in a earlier question I made to Jacque he recommended me to use stations with a build like this instead of the frames, as you can see here (
http://forums.bateau2.com/viewtopic.php ... ht=#135483 )
Peter
Posted: Wed Jun 11, 2008 12:25 am
by TomW
Peter frames and stations are the same. The frame/bulkhead is the peice of wood and the station is where the wood goes, usually. Sometimes we use the terms interchangeably to keep us confused.
So the frames on the nesting page should correspond to the stations. Just crossout frame and put in Stat. A-I for your build. The nesting diagram is just a page Jacque put together to help us use the wood most effeciently. It is just a guide but normally a helpful one.
I also forgot to ask are you using cheap wood or your good wood for the stations. If cheap wood then you can just splice it together where you need to for the stations for the frame. If good wood this is something all together different and why I said to look at the nesting diagram. There will be an indication on where to cut each station from and also other parts in or around the station once it is used for the outside build and you take them out to fiberglass the inside and start putting them back in cut down to size.
Oh, congrats on Curacao's win the other day. I imagine there was one big party
Posted: Wed Jun 11, 2008 12:06 pm
by peter-curacao
Tom thanks for you reply but I still don't understand it, the frames on the nesting page don't exactly correspond to the stations.
I try to explain it again with some pics, this is what jacques told me to do.
jacquesmm wrote:The dimensions for the molds are on the stations drawings. That is what you use for molds, no need to put small pieces together.
So I did, only problem is stations/molds B-C-D are to big to cut out a standard piece of plywood or mdf etc
I hope i was more clear now
Ciao
Peter
Btw it was the Netherlands who won from Italy
Curaçao is a Dutch Island
Posted: Wed Jun 11, 2008 12:47 pm
by tech_support
The molds are full size, and can either be cut from throw-away mold material OR they can can be made from all the small pieces of the frames.
The frames are the actual pieces that go in the boat - the molds in the same location and are the same shape as the frame, so can use the same measurements.
Note: because the frames are interrupted (cut into smaller pieces) by the intersection of the stringers and sole, you will have to take into account the thickness of those pieces
Posted: Wed Jun 11, 2008 12:53 pm
1. Peter, if you have a question, please post in "Power Boats" not in "Builder's Power Boats". The "power Boats" forum is for technical questions, this forum is for builders to document their building story.
I do not always check this forum.
2. The frames and bulkheads, except for 1 or 2, fit on standard plywood sheets because they are made of small pieces but not the molds.
The molds (located at the stations) can be made of several pieces. See pictures of molds in the gallery.
For one or two frames, I cheat by leaving a small gap (less than 10 mm) just at the top on each side.
Posted: Wed Jun 11, 2008 1:01 pm
by TomW
Peter sorry for the Netherlands slip I watched part of it. It was and unbelievable match by them. Italy looked shell shocked and looked like they didn't belong in the game. The Netherlands sure looked good in there orange.
The reason I said look at the nesting diagram is just what you discovered. It will be cheaper for you to use cheap plywood or OSB for the molds/stations on the build. Then once you get to putting her together after glassing the inside cut your good plywood according to the nesting plans.
Just my .02.
Posted: Wed Jun 11, 2008 1:45 pm
by peter-curacao
Thank's everybody for the answers, so if I understand correctly I have to make those 3 molds out of several pieces.
Sorry for the wrong posting
next time I will put questions in the correct forum.
@ Tom, that Netherlands slip no problem at all man
Posted: Wed Jun 11, 2008 2:55 pm
by TomW
You are correct Peter a few peices. Try to work it so you use as few as possible to keep your cost down. They are only temporary after all.
Posted: Wed Jun 11, 2008 4:34 pm
by peter-curacao
Ok Tom and the rest, I think it has to be something like this
Ciao
Peter
Posted: Wed Jun 11, 2008 7:00 pm
by TomW
That works fine.
Posted: Wed Jun 11, 2008 7:52 pm
by peter-curacao
Ok glad that's out of the way, I really thought I did something wrong because of what I have read before.
This afternoon I measured and cut stations B and E, a little bit more work now, because of the expanding of the wood sheets but still funn
So two more stations to go, so putting up the jig this Saturday and Sunday must be possible I think/hope so.
Also epoxy glued the inside stingers together, hope to glue the outside stingers tomorrow afternoon and also measure and cut the last two stations, so I can take a short break Friday to see the match against France.
Question to the readers of this topic NOT building related
if I place the pics of the progress should I post them only in my album, or in my album and also here?
Posted: Thu Jun 12, 2008 12:24 am
by chicagoross
Post at least a representation of your progress here so that we can follow the build easily! Haven't seen one of these built yet, lokoking forward to it!
Posted: Thu Jun 12, 2008 8:03 am
by TomW
I'd post 2-4 of the most important ones here and provide a link to your gallery.
PS What time is the match on Friday.
Posted: Fri Jun 13, 2008 10:17 am
by peter-curacao
Yesterday cut the last two molds and glued the outside stingers.
Today's soccergame Netherlands vs France starts at 14:45 hour in Forumtime I belive that's would be 13:45.
Peter
Posted: Mon Jun 23, 2008 8:04 pm
by peter-curacao
First of all sorry for the late update
one week to late
good news is I can put on some pics with this posting
Well that jig did go up Saturday before last saturday.
Only last week I made some modifications on it, along the way, because it was a little bit to long, or the stations where on to low depence how you look at it
So I put on the stations and try to line them out think this tolerance (see pics) is acceptable???
After that the next logical step was ( I think
) cutting and glueing the long panels the bottem panels I already did
I think my dog Sammy is thinking NO WAY I'm going on on the sea in that thing
Here you can see the bottom panels on the jig
And here the upper and lower side panels.
This was yesterday started to glue a little bit used way to much today my belt from the sander said to me do it your self
So that was the update so far, I try to do it more frequently but can't promise anything.
Saludos , from a at the moment very hot Curaçao 35 degrees Celcius that's about 95 degrees Fahrenheit if I'm correct, Humidity is about 80 %
Laterz Peter
PS: please let me know if you (anybody) see's mistakes I might have made, thank's in advance.
Posted: Mon Jun 23, 2008 11:39 pm
by Daniel Huckleberry
She looks great! I am so excited to see this go together. I would love to do one of these myself. Maybe you will be my inspiration!
Huck
Posted: Tue Jun 24, 2008 12:21 am
by TomW
Very well done Peter. That is a big boat.
Posted: Tue Jun 24, 2008 7:15 pm
by peter-curacao
Thank's for the compliments, and Huck I hope I can indeed be some inspiration for you!
Ciao
Peter
Posted: Wed Jun 25, 2008 11:03 am
by jgroves
The boat is coming together great! I like your pics. This is a very nice area to build boats
My wife would be watching my ever move with epoxy if I built on such a nice floor!
Posted: Wed Jun 25, 2008 11:56 am
by peter-curacao
jgroves wrote:The boat is coming together great! I like your pics. This is a very nice area to build boats
Thank you and belief me she is she is, my wife that is
Posted: Sat Jun 28, 2008 1:16 pm
by peter-curacao
I think she is ready for glass
Just have to wait just a little before the glass is here
Thanks Joel (Shine) for a excellent and very fast service and a special thank's for the present (cabin plan)
Posted: Sat Jun 28, 2008 2:46 pm
by topwater
Nice work peter and real fast.
Wait to you turn that bad girl over...she's going
to get real big....
Posted: Sat Jun 28, 2008 5:44 pm
by chicagoross
Build some steps for it - when you turn it over you'll find that a boat builder climbs in and out of the boat maybe a thousand times more than a boat owner ever does; and that's a big, big boat!
Posted: Sun Jun 29, 2008 6:32 pm
by peter-curacao
Thank's for the compliments feels good
, those steps are a good idea to make while waiting for the glass.
Posted: Mon Jul 07, 2008 3:22 pm
by peter-curacao
Since I have to wait for the glass I started to fool around with some old hardwood (Surinam) what in earlier days had a pool deck function.
Inspiration was this pic I saw a couple of weeks ago on this forum
I really like the looks of that boat (shearlineboatworks) and decided to try and make a rod holder similar to the one in the pic above.
First I did cut out some marlins from 10 mm marine plywood that was a little mistake as you can see at the end because when sanding it changed color.
Then I cut in some details and fill it up with epoxy and sand dust from the hardwood
After that I glued 3 pieces of hardwood together cut out the form and again the marlins
Than I sanded the plate and put the plywood marlins in, and a lot of epoxy again with the sanddust
than sanded the hole piece again and varnished it sanded again and varnished it etc etc and than put the rod holders in.
although the plywood chanced color I still think I like it and will use it on my CS 25.
I'm really curious what you guys think of it
Peter
Posted: Mon Jul 07, 2008 3:39 pm
What do I think? Phenominal
, fantastic
, beautiful
, I've got to learn how to do that
How did you make the cut outs (inlets) for the marlins?
by RR
Peter, it's really beautiful
Posted: Mon Jul 07, 2008 4:37 pm
by TomW
Peter that is fantastic.
I have done strait in-laying but nothing like that. My hat is off to you! They are beautiful. Did you make the marlins thicker than needed and then sand them down to base. I also assume you used a sharp craft knife to mark there position and carefuly cut out the design.
It is amazing the detail you got.
Posted: Mon Jul 07, 2008 4:44 pm
by colonialc19
Cool, Darn Cool!! Thats art!!
Very Creative
Daniel
by tech_support
Wow. That is good stuff
Posted: Mon Jul 07, 2008 4:52 pm
by jgroves
Flippin' amazing! That's a touch of class to any boat!
Posted: Mon Jul 07, 2008 5:08 pm
by topwater
You guys do stuff like this in youre spare time.......?
I am doomed....
Posted: Mon Jul 07, 2008 5:40 pm
by chicagoross
Beautiful! I'm still hoping for just a simple coat of paint on mine...
Posted: Mon Jul 07, 2008 7:10 pm
by peter-curacao
Wow thank you all for the overwhelming comments real nice.
Cracker Larry if you mean cut outs for the details on the marlins I did that with a dremmel cutting wheel but since I did not had the dremmel tool (sold out) I did it with a small drill what wasn't easy because I could only hold the drill at its housing to control the wheel, consequence was a very very hot machine because my hands where closing of the ventilation vents (big hands small machine
) but no blisters
Tom Yes I did sand the marlins down to base. I just used a pencil to mark them of on the hardwood It's not that precise
as you are thinking that's why I used sanddust from the same hardwood to cover that up
thank's again
Peter
Posted: Thu Jul 10, 2008 5:07 pm
by TomW
Peter you are asking question about your boat in other peoples threads thus a HIJACK. If you have a question on your boat ask about it here that is what this section is set up for. It is common courtesy not to ask about what is going on with your boat on someone elses thread, although you will probably get answered do to everyone wanting to help each other.
If you need an answer from Jacque post it in the Boat Builders Section at the head of the column.
I hope this helps you in understanding and getting the best answers to your questions and answers not just from me. There are many people interested in your build but they can't follow what your doing if you keep posting questions in other peoples Threads.
Posted: Thu Jul 10, 2008 5:30 pm
by peter-curacao
TomW wrote:Peter you are asking question about your boat in other peoples threads thus a HIJACK. If you have a question on your boat ask about it here that is what this section is set up for. It is common courtesy not to ask about what is going on with your boat on someone elses thread, although you will probably get answered do to everyone wanting to help each other.
PS
Tom and everybody else sorry for that I really wasn't aware of that, it's just when reading other treats sometimes questions come up regarding my build it wasn't my intension to be impolite, maybe I'm just a little to enthousiastic?
Next time when a question come up while reading a other thread I will make a quote of it and place it here with the question I have, I hope that's the right Forum etiquette.
PS What I did here
http://forums.bateau2.com/viewtopic.php ... 3&start=15 Is that a HIJACK to ?
Posted: Thu Jul 10, 2008 7:53 pm
by TomW
nope just honest discussion. Questions on an other site not good discussion on another sight okay. We learn from each other, through the discussions. And by answering the questions you pose on your site. If they are not on your site we can't help you as well as they are hidden somewhere else. Hope this makes sense to you.
Posted: Thu Jul 10, 2008 8:10 pm
by peter-curacao
I think I understand alltough it's a little vague for me Tom, but you did make your point.
Question I hope I can post it here, I have a spray paint compressor 1.5 HP with a small tank, way to small to spray a 25 hull.
I was thinking to connect a big old propane tank to it, will that give me a longer time to spray at a good pressure for a long time?
Or when I do that is that just killing my motor on the compressor?
Posted: Thu Jul 10, 2008 9:33 pm
by bushmaster
Hi Peter
Nice boat. Huge. Sorry I missed the pictures. Keep them coming.
Nice craftsmanship. Did you use a jig saw to cut the marlins from plywood?
Great job, keep it up
Bushmaster
Posted: Fri Jul 11, 2008 12:40 am
by TomW
A 1.5 HP compressor is pretty small you can try but you may just burn it up. Check to see if it has a over heat cutout if it does then you may be okay. You won't be able to maintain pressure I don't think maybe one of the other guys can answer that. Peter you can also ask questions like this in the Paint section or the Power Boat section.
I hope I didn't offend you just trying to get your questions out to the maximum amout of people by you asking them under your own posts, instead of someone else's.
Posted: Fri Jul 11, 2008 12:09 pm
Peter, not to worry, it took me a while to figure it out too
Let me try to help clarify what Tom is saying about how the site is set up.
This particular section we are on, titled Builders Power Boats, is for power boat builders to share their build with other builders, show off their skills or lack there of, and to generally shoot the breeze about building your boat. If you ask a technical question here, it may not get read or answered by an expert in a timely manner, maybe never.
If you have a technical question about building, you should start a thread in the Plans and Building section at the top. The boat masters like 1 topic/ 1 builder questions so as not to confuse. For instance if some one asks a question, and Jacques answers it, then someone else asks another question in the same thread, Jacques will probably never read it because he assumes he's already answered. Does that makes sense?
If your question is about painting, you should post it in the Resins, Fiberglass, Paint section. If it's about plywood or foam, then ask it in the Core Materials heading. Sticking to the 1 builder/ one boat question rule.
Those are the sections the experts will look for questions in, and you will get a timely answer.
Hope that helps you some.
Posted: Sat Jul 12, 2008 6:11 pm
by peter-curacao
bushmaster thank you, yes I did use a jigsawfor the Marlins.
Tom don't worry you didn't offend me at all, it's always nice to know how something works.
Larry It's all clear to me thank you except for this
I don't want to offend Jacques, but I did that once here
http://forums.bateau2.com/viewtopic.php?t=16965&start=0
Strange thing is I never did get answer from Jacques, Capt H repeated the question in that same topic, there never came an answer from Jacques.
Well maybe Jacques missed it, but there came a lot of helpful answers from other builders
Posted: Sat Jul 12, 2008 9:09 pm
Well, that happens sometimes, but it is still more likely to get answered there. I'm sure it was unintentional. That question/thread only lasted about 3 days, spanning a weekend. Even J needs a weekend off sometimes:lol:
If you really need his answer, just call him on the phone
Posted: Fri Jul 18, 2008 8:16 pm
by peter-curacao
Santa came early this year
This morning the Silvertip epoxy arrived so I couldn't wait and directly started this afternoon, put on the tape on the chines keel and bow.
This is gone be a loooong weekend
Posted: Sat Jul 19, 2008 6:30 pm
by peter-curacao
Posted: Sat Jul 19, 2008 7:40 pm
by chicagoross
Posted: Sat Jul 19, 2008 7:54 pm
by TomW
Peter, nice looking job. You're doing a good job. As far as the cloth you are probably going to have to do it in four peices overlapped at the keel and then at the chine, but don't know for sure. I think you should wait for Shine or Jacque on this one it is pretty critical.
Posted: Sat Jul 19, 2008 8:02 pm
by peter-curacao
Sssst don't tell anybody
I had to demolish 2 column's and my garden wall, fill and take "temporary
"some goverment land to create some work space
The flip I think I figured that out the jig is on casters and i will yank that out on the street with my car, luckely the company I work for owns a old telescope crane I will use that for the flip.
Not sure it will work but I jump off that bridge when I'm there
Posted: Sat Jul 19, 2008 8:16 pm
by peter-curacao
TomW wrote:Peter, nice looking job. You're doing a good job. As far as the cloth you are probably going to have to do it in four peices overlapped at the keel and then at the chine, but don't know for sure. I think you should wait for Shine or Jacque on this one it is pretty critical.
Thank you Tom , I also thought it was critical that's why I pushed my pause button better safe than sorry!, and that roll of fabric stands ok in that corner.
Tomorrow I will find a way to be busy on my free Sunday if I dont have an answer.
maybe I´m going to make a fighting chair what match the rocket launchers I made
Something like this
Ciao Peter
Posted: Tue Jul 22, 2008 9:47 pm
by peter-curacao
I might have failed today
went home early today to lay some glass, I did cut everything at the right size then I did wet out the hull after that I put on my first 7.5 meters wide fabric and then .......................... all hell broke loose over here a lot off wind, thank god no rain but it made everything very difficult for me.
so I still had 22,5 meters to go at that point I already gave op hope of doing the side panels, but I had to finish the bottom.
As I said that was very difficult I'm building alone and the wind kept blowing the glass of, I hope god is a little deaf because I never cursed so much as today
Because everything went so difficult I was finished in the dark, the last part I had to do with artificial light (I hate that
), But the 4 layers are on now, but I'm almost sure when I rip off the foil tomorrow I will discover a lot off air bubbles, Lets hope that he did not heard my cursing and that I'm wrong about the bubbles
Good night
Peter
Posted: Tue Jul 22, 2008 9:54 pm
In my experience some things will only behave properly with a good cussing. He isn't deaf, but I don't think he offends easily either and he certainly has a sense of humor.
Others experiences may vary
Posted: Tue Jul 22, 2008 10:31 pm
by peter-curacao
Posted: Wed Jul 23, 2008 4:21 pm
by peter-curacao
Yep as I thought air bubbles
thankfully not as much as I thought and as far I could see only in places that need a final coat of glass.
At the bow you can see the mess I made yesterday, when I told the epoxy was blown out of my cup I wasn't kidding, for sure I have to replace a lot of clinkers in my carport when finished with this build
Most of them at the chines
and a lot left of the transom thats the part I had to do in the dark, today I tried to fix that, and gave up the illusion I could do everything alone wet on wet.
Tomorrow I will do one upper side and will sand out the air bubbles and connecting parts of that side, I think that should work also?
All this makes me wonder how much damage a air bubble could make if left under the glass and paint?
"fixed" transom , with last glass coat and under poor mans peel
Greetings from a very itchy Peter That sanded glass is everywhere
Posted: Thu Jul 24, 2008 12:26 am
by Fred in Wisc
I'v had good luck filling small air pokets like that with epoxy in a glue syringe. It's way faster than sanding off the whole thing and reglassing.
Just mix up some resin and slow or medium hardener, a little wood flour (just a little, it should be just going from transparent to translucent), brill some little holes (about 3/16" at one end, 1/16 at the other) inject glue into the big hole, watch as it fills the bubble. You may need a cuple extra injection holes o long thin bubbles. When it's all full, seal the holes with packing tape or whatever. Let it set and you are good to go.
This is great for smallish bubbles, I would not recommend it for anything real big without the designer's ok.
Fred in Wisc
Posted: Thu Jul 24, 2008 10:11 am
by peter-curacao
Thank you Fred for the suggestion,maybe I will try that
Peter
Posted: Thu Jul 24, 2008 10:32 am
I don't think that's humor man he was blowing the epoxy out of my mixing cups
Peter, I've never been to Curacao, would love to some day, but I've been to your sister islands Bonaire and Aruba. They are the windiest places I've ever been, north of Tierra del Fuego
In Aruba last year, when I walked out of the airport door I instantly lost my hat, my cigarettes, my plane tickets and my beer
That wind blows the beer right out of a can, it will blow your hamburger 100 yards if you turn it loose. You couldn't put anything down unsecured. Must have lost a dozen pina coladas that way. And it never quit, the entire week. No need to sweep the condo, just open the front and back doors and everything blew out, including the laundry, the loose cash and the plane tickets. Damdest thing I've ever seen
I don't know how you could lay glass in a place like that
Posted: Thu Jul 24, 2008 1:35 pm
by peter-curacao
Cracker Larry wrote:I don't think that's humor man he was blowing the epoxy out of my mixing cups
Larry you just made me laugh so hard I'm almost crying
I saw the whole picture in my head
I lived 1 year on Bonaire after that I moved to Curaçao little bit more action here, although Bonaire is a beautiful island after one year it was to quiet for me.
And indeed the wind is strong but the day I was laying glass, imagine those winds and then 3 to 4 times as strong, man it drove me crazy
Hope to welcome you sometime over here, if my boat is finished we could go out and pop some beers and do some fishing
Posted: Thu Jul 24, 2008 2:12 pm
I have been known to accept fishing invitations on the spur of the moment
I might just take you up on that, thanks
Posted: Thu Jul 24, 2008 6:35 pm
by peter-curacao
One side to go, today I glassed one side I think it went well sanded the bubbles out and lay glass, after that the plastic over it, that didn't went so well as the transom yesterday, not strange I think because of the curve's well I think it's always better than nothing?
Transom without the plastic
Cheers
Peter
Larry you may take me up on the fishing no problem at all
Posted: Fri Jul 25, 2008 4:15 pm
She is looking great! This boat is really inspiring me to bigger and better things!
Thanks for all the pics, Peter. You are doing great work on a very large project on your own. My hat's off to you.
Huck
Posted: Fri Jul 25, 2008 9:07 pm
by wegcagle
Peter, the boat looks INCREDIBLE. You make me drool and daydream over bigger and tougher boats. Are you going to do the cabin version or open model?? I've enjoyed and look forward to more pictures of your build. I can't believe you are doing it all by yourself. You're a braver man than most.
Will
Posted: Thu Jul 31, 2008 8:39 pm
by peter-curacao
Sorry for the late response my radio (wireless internet) died on me and it took a while before they came over to replace it, but both thank's for the compliments !
Posted: Fri Aug 01, 2008 6:50 pm
by peter-curacao
Weird weird Island life
today I was in a copy shop were they also selling computers,printers, office supply's etc while waiting on my order my eye fell on a 3M sign in the corner, so I walked over there to have a look and guess what I find there?...........................exactly! 3M marine fairing boards now isn't that something? Next time when I'm at Nappa's or the marina I have to ask if they also make copy's or selling computers
O yeah also put half the hull in the easy fair, don't think I'm going to make it with my 1.5 gallon, I have about half of it left.
Btw I still can't place the smell of that stuff especially the hardener strange smell
Also went to the carpenters shop to buy the strakes, chine fender and rubrail all in hardwood as jaquess recommended.
And wegcagle sorry I overread your question I'm still not sure with version to go with, but my interest goes mostly to the open version short deck, simply because it's giving you the most fishing (read fun
) space, it also give's me the chance to accommodate more people
Tommorow fairing time jipiiiiiiii
Posted: Fri Aug 01, 2008 9:02 pm
by chicagoross
Sounds like you're still having fun, Peter! You're the right person to be building that big a boat with that much fairing, for sure! Definitely beyond my skills, patience, and endurance!
This is going to be a beautiful boat when you're done, and IMHO your progress is excellent!
Posted: Fri Aug 01, 2008 9:50 pm
by colonialc19
Peter, the boat is really comming along great,
you mentioned the smell of the quickfair, I think its ammonia with a slight vinegar???? smell, certainly different.
Looks Great
Daniel
Posted: Sat Aug 02, 2008 12:47 am
by TomW
Looks good Peter, you are definately moving right along.
Posted: Sat Aug 02, 2008 3:59 am
by ks8
Now there's a man who knows a good use for the space on the side of the house. Wow! Will she roll over there or will you have to haul her out first, roll, and drag her back in?
Looking forward to the finish and how you fit her out. Enjoy!
Posted: Sun Aug 03, 2008 5:48 pm
by peter-curacao
Thanks all for the reply's, here my weekend update,
I did not do much beside sanding,sanding and sanding
since I actual not knowing what I am doing concerning the fairing I put my transom in the epoxy primer to get an idea what I'm doing and how I'm doing it, for me it's much easier to see when it's in primer, the marked spots needs some more attention with quikfair, could be worse I think
O yeah also glued on the rubrail and chine fender, the strakes i have to sit on some longer before I glue those on
Also went over to my neighbour to get a good side shot!
to get some perspective the car on the right is a medium SUV (Kia Sportage) probable in the US this is a small SUV
And now time to take a cold one cheers!!
Peter
Ps ks8 yes I roll her out flip her on the street and back in she goes.
colonialc19 I was more thinking the smell of a public swimming pool or am I wrong, haven't been there in age's
Posted: Sun Aug 03, 2008 5:55 pm
by steve292
Looking good!!!
That is some boat to build single handed, you have my total respect.
Steve
Posted: Sun Aug 03, 2008 7:40 pm
by cape man
A public swimming pool
You're right and I am rolling with laughter!
Posted: Mon Aug 04, 2008 3:29 am
by Jaap
Hi Peter,
Your well on the way!! Looks good and inspiring, so back to the shop.
jaap
Posted: Mon Aug 11, 2008 7:18 pm
by peter-curacao
Boy o boy after I've got my answers in strakes2 I've made it very difficult for my self (I think), I once read in this forum boat building is like sculpting, sorry I don't remember who wrote that but if you are still on the forum I now know what you mean
Those things were by far the most difficult things I did so far on the build, or maybe the rest went very well that is a possibility to
So I glued the strakes on with the gellmagic man that stuff really glues
probably with some spoons of that stuff you can glue an elephant permanently to the roof, if the roof holds it
Yesterday I saw they were not as straight as I thought so I pulled out the easy filled, right easy to lay! hard harder very hard to sand
but I think I've managed it, I'm not saying it is a suburb job but I can live with it anyway its close to how I want it
Here some pics,,sculpted the outside strake, the inside I still have to start with, that one isn't as bad as the outside one was anyway.
Ciao
Peter
Posted: Mon Aug 11, 2008 7:30 pm
by TomW
Peter, they look great, even with the keel all the way to the bow, nicely smoothed down as they approach the bow.
Posted: Tue Aug 12, 2008 1:34 am
by chicagoross
Looks like the carport is shrinking!
Posted: Tue Aug 12, 2008 12:01 pm
by cape man
Sculpted like Michael DaVincci
Looking great Peter.
Posted: Tue Aug 12, 2008 2:59 pm
by peter-curacao
Posted: Tue Aug 12, 2008 6:18 pm
by gk108
Good find
At least you didn't have to dispose of a rotten boat in order to get the trailer.
Posted: Sun Aug 24, 2008 11:38 am
by peter-curacao
Well yesterday I put on the first coat of primer (one side) only and as I thought it showed a whole lot of big and small imperfections
Although you can't see them that well on the pic's believe me they are there
So a lot of fairing and sanding ahead, I don't understand how you guys can see those imperfections before a coat of primer
Ah well it keeps me from the street
Ciao peter
Posted: Sun Aug 24, 2008 4:33 pm
Looking very nice, Peter
You're coming along quickly.
It was I.
You can't. It's the primer that lets you know just how much more fairing and sanding that you need to do.
Posted: Sun Aug 24, 2008 5:03 pm
by chicagoross
That hull looks fantastic to me, Peter. You're the one that decides how close to a mirror finish you need for your boat.
Oh yeah, you're the guy that's doing carved wood inlays on a 25' boat...
Posted: Sun Aug 24, 2008 7:44 pm
by cape man
Peter,
Looking great man! I too was shocked with how many places showed up when the primer went on. I could have sworn it was smooth and fair! I'm getting ready to put another layer of primer on the fairing I di, and think I am going to live with what I get this time.
Posted: Mon Aug 25, 2008 2:53 am
by Jaap
Looks good Peter and you're going fast! Don't come closer then 3 ft for spotting imperfections and try one pass with some filler putty and the ro sander if you did a good job with the fairing board and the filler before. Most imperfections will dissapear then when you do a second coat with primer. Did you see production boats on boatshows, some look really half finished and you can outperform them with a little elbow grease.
jaap
Posted: Tue Aug 26, 2008 5:27 pm
by TomW
Peter, my computer broke Thursday so just got back. Looking good. Yea that first coat of primer or finish always shows the inperfections. Get out the QF and fill them in and go on. Have a good rum and take a deep breath first as you contemplate how to attack her.
You are moving along very quickly and should be proud of your progress.
Posted: Tue Aug 26, 2008 7:48 pm
by peter-curacao
Thank you all for the moral support, always nice to have some ears listening or in this case some eyes reading
Already fill most of the imperfections, now I'm for sure I ain't gonna make it with the 1.5 gallon Quick Fair so have to order more I love that stuff, sands a lot nicer than the Easy Fillet, it does make me wonder if the Bateau shop shouldn't look in to this because I'm not the first one who doesn't make it with his QF in his epoxy kit I think 1.5 gallon is really not enough for a 25 foot boat
Cracker Larry wrote:I once read in this forum boat building is like sculpting, sorry I don't remember who wrote that
It was I.
Than I have to say you are absolutely right
chicagoross wrote:Oh yeah, you're the guy that's doing carved wood inlays on a 25' boat...
Yep that's me, why? shouldn't I do that??
TomW wrote:Peter, my computer broke Thursday so just got back.
Tom good to have you back, I thought so something was wrong, "luckily" it was only your PC.
Ciao Peter
Posted: Tue Aug 26, 2008 8:44 pm
by Bart-Curacao
hi peter,
Im also building a boat on Curacao. You can buy fairing fillers in budget marine this way you dont have to wait for the quick fair to arrive.
I also saw that trailer laying around at piscadera baai. how did you get it home? looked pretty heavy.
Posted: Tue Aug 26, 2008 9:00 pm
by peter-curacao
Bart-Curacao wrote:hi peter,
Jeez what a small world!
your going for the Panga right? can I ask what stage you are in and were you are located ?
Thank's for the tip on budget marine but I think I stick with the QF
The trailer afterwards I had to pay for It was real heavy some friend's helped me.
Peter
Posted: Wed Aug 27, 2008 6:48 am
by chicagoross
Peter, you should! I'm just in awe of your level of detail on a project this big. Don't know how you do it - I know what it's like building solo on a tropical island - small epoxy batches and lots of fun finding supplies and bits and pieces. Just glad my project was only 18'. And is getting closer to the water!
Posted: Wed Aug 27, 2008 9:03 am
by Bart-Curacao
I just uploaded some photo's of my boat. Im building the boat in Julianadorp. Where are you building it?
Posted: Wed Aug 27, 2008 11:09 am
by peter-curacao
Bart-Curacao wrote:I just uploaded some photo's of my boat. Im building the boat in Julianadorp. Where are you building it?
Looking good are you going in open sea with it? I like the model it looks a little like the Go fasts the coast guard catches here.
I'm located at Jan Thiel
Posted: Wed Aug 27, 2008 11:22 am
by tech_support
Netherlands Antilles builders meet anyone
Posted: Wed Aug 27, 2008 11:50 am
by Bart-Curacao
yes thats the plan. i put two layers of biaxial fabric on the outside so should be strong enough i think... but the sea can be pretty rough around here with all the wind chop so hopefully the boat stays in one piece
Posted: Wed Aug 27, 2008 11:56 am
by peter-curacao
shine wrote:Netherlands Antilles builders meet anyone
Sign me up Joel
are you coming by boat or plane or both
Posted: Sat Aug 30, 2008 9:15 am
by colonialc19
I'd love to see the islands, and your CS25, but don't think my fs17 is up for that trip, Flying in maybe a possibility though
I always need an excuse to travel to a tropical island
Daniel
Posted: Sat Aug 30, 2008 3:01 pm
by AD16 The Opportunist
Daniel
Since BBV is some kind of sickness
, what's about "a medical convention" in the Dutch Antillas?
Posted: Sat Aug 30, 2008 6:30 pm
I'm in
Don't need much of an excuse to visit a tropical island. And I do like the swimwear in the Netherland Antilles.
Something about the US is just wrong in that respect.
Posted: Mon Nov 17, 2008 11:10 pm
by Leotis
Why no new posts here have you stopped building?
Posted: Mon Nov 17, 2008 11:44 pm
by TomW
Also hope all is well Peter and that the hurricanes did not do any harm this fall to your lovely island.
Posted: Tue Nov 18, 2008 9:42 am
I was just wondering what happened to Peter also
Hope he is OK. I'm going to try his email..
Posted: Mon Nov 24, 2008 7:50 am
by cape man
Larry,
Richard and I were talking about Peter yesterday while fishing. Any luck with contacting him? His email is disabled on this site.
Posted: Mon Nov 24, 2008 10:03 am
No luck contacting him. Anyone know his last name?
Posted: Tue Nov 25, 2008 6:59 am
by cape man
Curacao?
Posted: Sun Feb 01, 2009 1:45 pm
by peter-curacao
First off all to everybody and specially those who were concerned about me , I’m really sorry and embarrassed
of my self that I didn’t let hear anything about my self and my build. For a long period of time about three months there was no wind here and it was very uncomfortable to do anything because it was to hot .After the holidays I started with my build again
, and because I didn’t want to come back with a posting with no news at all I waited after de flip and that stressful day
was yesterday here some pictures. Once again sorry about the radio silence.
Waiting to get flipped
Flipping site left across the street on a empty lot
Her journey to the site
Getting ready for the flip
There she's go
Above view
Converting the jig
Getting her on there
She's on
Getting her home
She's home again
Posted: Sun Feb 01, 2009 2:12 pm
by hwsiii
Absolutely BEAUTIFUL Peter, that is a boat to be proud of.
HWS
Posted: Sun Feb 01, 2009 2:32 pm
by TomW
Super Peter. It looks like you graphited the bottom. Is that primer on the sides or your final paint. In some of the pictures it looks shiny in others like primer.
She is one fine looking lady. Can't wait to follow the inside build.
Posted: Sun Feb 01, 2009 2:53 pm
by Aripeka Angler
Peter, you are indeed OK. Nice job and pictures of your flip. Good luck and keep in touch. We missed your humor while you were away
Richard
Posted: Sun Feb 01, 2009 4:26 pm
by Fonda@kauai
Looks beautiful and congrats on the flip! Au'ryte
Posted: Sun Feb 01, 2009 5:57 pm
by BassMunn
GeeWiz that's a big boat
The boat looks awesome! Congrats on the flip.
Looking forward to seeing this one complete
Posted: Sun Feb 01, 2009 6:07 pm
by topwater
good to see eveything is all right and its great to see
pictures of youre filp
Posted: Sun Feb 01, 2009 6:55 pm
by chicagoross
Glad you're OK and the build is progressing again, Peter! Congrats on the flip. What a monster - it looks even larger in the street! Upside down, it sure looks like that hull's nose would make a great snow-plow for our northern friends!
Posted: Sun Feb 01, 2009 7:58 pm
by colonialc19
Good to hear from you again, the boat is incredible, too cool
Keep us posted, even if your not making progress, a few of us thought you were blown away
by the storms this season.
Daniel
Posted: Sun Feb 01, 2009 8:20 pm
by bushmaster
Marvelous work Peter.
Boat is looking great. Keep posting. Do you own that crane?
Bushmaster
Posted: Mon Feb 02, 2009 5:23 am
by steve292
Nice hull....I am in awe of the guys who take on the big builds,knowing how much work goes into it. I am also glad to have heard from you again.
Steve
Posted: Mon Feb 02, 2009 11:33 am
Hello Peter, glad you're safe and back with us
Your boat looks fabulous
Posted: Mon Feb 02, 2009 4:38 pm
by peter-curacao
Thank you all for the nice compliments, its good to be back.
TomW wrote:Super Peter. It looks like you graphited the bottom. Is that primer on the sides or your final paint. In some of the pictures it looks shiny in others like primer.
Tom the bottom is
seahawk Island 44 antifouling and the sides are spray painted with Uni marine from the local paint factory here, but not the final layer I have to sand once more with about 400 grid and then I put the last layer on.
chicagoross wrote: Upside down, it sure looks like that hull's nose would make a great snow-plow for our northern friends!
Something like this?
bushmaster wrote: Do you own that crane?
Bushmaster
No I do not it’s from the company I work for.
Now that the boat is flipped the side panels in the front are hanging down for about 3 inch, I was wondering if I should take action on that before laminating the inside?
Posted: Mon Feb 02, 2009 5:56 pm
by TomW
Peter yea the panels do sometimes hang down. Best way is get some straps that go around the boat and pull them back in place or some some strap clamps that you can some how hook to the sides that will do the same thing.
Like that bottom paint really looks sharp. The sides also looks very nice and good.
Posted: Mon Feb 02, 2009 6:31 pm
by peter-curacao
TomW wrote:Peter yea the panels do sometimes hang down. Best way is get some straps that go around the boat and pull them back in place or some some strap clamps that you can some how hook to the sides that will do the same thing.
Ok Tom thank's I'm glad i didn't take al the stations out yet
Posted: Mon Feb 02, 2009 6:39 pm
by JohnC
Peter,
I'm having trouble copying the link, but look in Builder galleries, search for "C17" and look at page 18. You'll see what Tim (Wobblylegs) did on his C17, might give you some ideas.
John
Posted: Mon Feb 02, 2009 6:41 pm
by tech_support
Hi Peter
Tom is correct, when you flip her the sides having no support will pull out. You need to use spacers (2x4 or such) at the sheer to pull her back to the proper shape. You need to do this before putting in the stringers.
you can use straps to pull the sides back to the molds, then attach the spacers. I will look for a good picture of spacers from my fs17 build
Posted: Mon Feb 02, 2009 6:46 pm
by tech_support
Here you see a couple straps and one spacer towards the bow, thats all I needed on this small boat, you will need more on the CS25. You can see also that my spacer is pulling the sides in, so I did not have to screw anything into the hull, just a block of wood on the underside of each end to hold the sides in.
Posted: Mon Feb 02, 2009 6:54 pm
by peter-curacao
Tom, Joel and John thank's its very clear for me now I have to strap her in before laminating further
Posted: Tue Feb 03, 2009 6:58 pm
by peter-curacao
Today I braced her some more in the front
And I made and attach the spacers, also took al the stations out heavy F#!*#@!
Tomorrow its time to fish so we are going to Bonaire and back to Curaçao
Posted: Tue Feb 03, 2009 8:53 pm
by peter-curacao
shine wrote:droopy bow is a result of not tightening the side panels down enough to the bow mold. Use a very rigid bow mold and keep the top of the side panel (bow point) secured firmly before tightening anything else.
If I understand correctly I have created a droopy bow to??
Posted: Wed Feb 04, 2009 12:11 am
by TomW
It sure looks like it.
Posted: Wed Feb 04, 2009 1:58 am
by Spokaloo
I say we call it Powderhorn in the sheer and get on with it!
E
Posted: Wed Feb 04, 2009 6:49 pm
by peter-curacao
Nah I don't mind I like it beter this way! when I had it tight to the mold it didn't seem right for me so I cut them loose
Posted: Wed Feb 04, 2009 6:55 pm
by peter-curacao
After fishing we went home at relatively high speed over some respectable waves, although it’s not so clear in the short movie the wave’s were not small and the speed was high, while bracing my self and trying to film this clip I was wondering how a Bateau especially my CS 25 should hold at this kind of “abuseâ€
Posted: Wed Feb 04, 2009 7:15 pm
by TomW
Peter a 32' boat is always going to do better than a 25' boat.
But you'll be pleased.
Posted: Wed Feb 04, 2009 7:21 pm
by peter-curacao
TomW wrote:Peter a 32' boat is always going to do better than a 25' boat.
That I of course understand
I was more talking about the constant banging on the waves at a speed of about 35 miles PH will she hold up?
Posted: Thu Feb 05, 2009 5:54 am
by cape man
Peter,
I'm a little late, but welcome back to the site. You've been busy! Lookin' good man.
Posted: Thu Feb 05, 2009 6:57 am
by TomW
Oh yea she'll hold up! Remember Jacque used to design for Cigarette Boats at 100 mph. So he always has a safety factor built in.
But if your like me after a while that pounding at 35mph gets old like we do and we slow down.
Posted: Thu Feb 05, 2009 8:11 am
by colonialc19
Most of my offshore trips rarely break the low 20's speed wise, not because we couldn't, just more comfortable
nobody likes to spill their drink
Posted: Fri Feb 06, 2009 11:30 am
by peter-curacao
TomW wrote:Oh yea she'll hold up! Remember Jacque used to design for Cigarette Boats at 100 mph. So he always has a safety factor built in.
I don't like it to much either, but once in a while It's possible I stay to long fishing so than I have to hurry to go home that's why I was asking, and colonialc maybe use this for those rides
Posted: Sun Feb 08, 2009 2:11 pm
by peter-curacao
Posted: Sun Feb 08, 2009 2:18 pm
by hwsiii
Peter, you are doing a wonderful job on the boat.
H
Posted: Sun Feb 08, 2009 2:26 pm
by TomW
Peter, nice neat job as always, you'd think this was your profession.
Posted: Sun Feb 08, 2009 3:48 pm
by peter-curacao
This is a graphic I had in my mind to put on her in metallic bleu also the rubrails,chine fenders and transom I would like to do in that same color, just wondering what you guys think of it
Posted: Sun Feb 08, 2009 8:07 pm
by tobolamr
That graphic looks great! I can't wait to see it in the blue!
Posted: Sun Feb 08, 2009 9:58 pm
by hwsiii
That is excellent looking Peter.
H
Posted: Sun Feb 08, 2009 11:10 pm
by TomW
Peter clarification question. Do you mean you want to paint your whole transom the metallic blue? I like the graphics and think it would be fine for everything else.
Posted: Mon Feb 09, 2009 5:57 am
by cape man
I like. White hull?
Posted: Mon Feb 09, 2009 8:32 am
by peter-curacao
TomW wrote:Peter clarification question. Do you mean you want to paint your whole transom the metallic blue? I like the graphics and think it would be fine for everything else.
Yes I mean the whole transom, funny thing you ask that's the only thing I'm in doubt with
cape man wrote:I like. White hull?
Yep white hull with a sun burning between 30 and 37 degrees Celsius 365 days a year it seems the wisest to do I think
Posted: Mon Feb 09, 2009 8:39 am
by gk108
I'm not too sure about a blue transom, but the stripes are a perfect complement to the lines of the boat.
Posted: Mon Feb 09, 2009 12:06 pm
by TomW
Peter with all your sun and temperatures I would highly recommend not doing the transom dark keep it white. Put your port on the back if you want. Or the name of the boat.
The main problem with dark colors and epoxy is that it will over time telegraph the fiberglass through the finish. This is less a problem if you used Silvertip but can still occur.
Posted: Mon Feb 09, 2009 6:45 pm
by peter-curacao
OK I will think it over, I wasn't to sure anyway that it would look nice.
Well I just finished laying glass on one side, that sure wasn’t as easy as I thought it would be, especially at the bow very uncomfortable to sit/stand/lay etc
I also think I used way more resin than on the outside not sure tough, I used +/- ¾ gallon of resin (without the hardener) on 7.35 meter (24F) fabric biaxial 45/45 12 oz 125 cm (50â€
Posted: Mon Feb 09, 2009 7:32 pm
by TomW
That's fine Peter your a little heavy on the resin. 24' of fabric is 8yds or 6lbs of 12oz. A gallon of mixed resin weighs 9.5 to 10lbs.
Posted: Mon Feb 09, 2009 8:08 pm
by peter-curacao
Ok Tom as always thanks for the quick answer
Posted: Tue Feb 10, 2009 10:00 pm
by ixplorer
Looks awesome... I am investigating building this same boat now down here in Sunny New Zealand [its pissing down right now]... is this your first boat Peter ?
Anyone ... what are the steps next after the glass is all laid out on the inside ?
Guy
Posted: Wed Feb 11, 2009 9:03 am
by peter-curacao
ixplorer wrote:Looks awesome... I am investigating building this same boat now down here in Sunny New Zealand [its pissing down right now]... is this your first boat Peter ?
Guy
Yes it is, next step is taping in de stingers and frames, but he if you order the plans all (most) is very clear and if it isn't you always have this wonderful forum for your questions, it helped me lots of time as you can see when you read back in my thread. I would say go for it you can do it! good luck!
Posted: Wed Feb 11, 2009 12:39 pm
by wegcagle
She's looking awesome Peter
I really like the graphics. I'm with Tom, I think you should keep the transom white, go for it with the graphics on the sides (they really finish nicely), and maybe match the T-top (if you're going with the center console version) to the same color as the graphics.
Just a thought (sometimes I can't control the artsy side of me)
Will
Posted: Wed Feb 11, 2009 2:20 pm
by ixplorer
With this boat there are three deck layouts and three transom layouts does anyone have images of all of the combinations ? I can only find two of each... ide just like to kno what others there are and which deck are you doing Peter ?
g
Posted: Wed Feb 11, 2009 3:04 pm
by peter-curacao
First layer of wide fabric is in hope to have the second layer in before the weekend. I was wondering can I wait with covering the upper panels and first put the stingers and the frames in? And after that put some planks over those so it’s easer working the side panels.
Posted: Wed Feb 11, 2009 3:08 pm
by peter-curacao
wegcagle wrote:She's looking awesome Peter
Will
Thanks and yes that’s a great idea I think I'm going for that and make either the hardtop or the console metallic bleu
Posted: Wed Feb 11, 2009 3:14 pm
by peter-curacao
ixplorer wrote:With this boat there are three deck layouts and three transom layouts does anyone have images of all of the combinations ? I can only find two of each... ide just like to kno what others there are and which deck are you doing Peter ?
g
Over her you can find them all
versions just combine them yourself.Still don't know either the Open version, short deck or the Jump cabin version with bracket
Posted: Wed Feb 11, 2009 4:02 pm
by ixplorer
I think ill be doing a soft top version with runners... so it can go forward or back ... the sun here is killer.
It would be awesome to see your hull in the water right now though... with no contents just to see where it sits on the water now and give it some scale.
g
Posted: Wed Feb 11, 2009 4:09 pm
by peter-curacao
ixplorer wrote:the sun here is killer.
Same here
ixplorer wrote:It would be awesome to see your hull in the water right now though... with no contents just to see where it sits on the water now and give it some scale.
g
Isn’t going to happen
Posted: Wed Feb 11, 2009 4:14 pm
by ixplorer
Where exactly are you ? Geographically ?
That huge metal jig, is that going to be the base of your trailer ? That will weigh about a ton alone... thats untowable with your boat on the back of it !
Posted: Wed Feb 11, 2009 4:20 pm
by peter-curacao
ixplorer wrote:Where exactly are you ? Geographically ?
North of Venezuela East of Aruba
ixplorer wrote:That huge metal jig, is that going to be the base of your trailer ? That will weigh about a ton alone... thats untowable with your boat on the back of it !
It isn't a jig it's a trailer so when I put wheels under it, it should be tow able, after al it's a boat trailer
Posted: Wed Feb 11, 2009 4:22 pm
by ixplorer
OMG... what a place to be... petrol is like $0.10ltr... ? here its USD$0.80ltr !!
Yikes... its a total beast !
What engine have you got planned ?
Posted: Wed Feb 11, 2009 4:27 pm
by ixplorer
Also what grade of Ply did you use ? Gaboon ?
Posted: Wed Feb 11, 2009 4:28 pm
by peter-curacao
ixplorer wrote:OMG... what a place to be... petrol is like $0.10ltr... ? here its USD$0.80ltr !!
I wish it's about US$ 1,35 a liter I'm not
in Venezuela
ixplorer wrote:What engine have you got planned ?
Not sure yet thinking of ETech 280 or 2 times 150
ixplorer wrote:Also what grade of Ply did you use ? Gaboon ?
Gaboon?? never heard of that I used marine grade Okume
Posted: Wed Feb 11, 2009 4:41 pm
by ixplorer
Only thing with two engines... double the petrol consumption and therefore half the range !... or not far off... I would think.
Gaboon is what they call the marine version here in NZ. Its stronger and more flexible I understand... but dont quote me. I know its damn expensive at $160 a sheet of the 12mm. Thats USD$80. Do you recall your cost of ply sheets ?
I am thinking ill have the top deck in Khaikatea a white pine that is stunning. The transom in the same or Jarrah I think a red hardwood from Australia. Same with all the stringers.
g
Posted: Wed Feb 11, 2009 4:55 pm
by peter-curacao
ixplorer wrote:Only thing with two engines... double the petrol consumption and therefore half the range !... or not far off... I would think
I only use one when trolling
ixplorer wrote:I am thinking ill have the top deck in Khaikatea a white pine that is stunning. The transom in the same or Jarrah I think a red hardwood from Australia. Same with all the stringers.
g
Stop thinking just start! way more fun!
Posted: Thu Feb 12, 2009 5:20 pm
by peter-curacao
peter-curacao wrote: I was wondering can I wait with covering the upper panels and first put the stingers and the frames in? And after that put some planks over those so it’s easer working the side panels.
Anyone?
Posted: Thu Feb 12, 2009 7:17 pm
by TomW
yes as long as you have an overlap of the bottom glass.
Posted: Sat Feb 14, 2009 5:18 am
by sideslippa
Hi Peter I have been checking out your build project...I am very impressed with the boat and your workmanship. I will enjoy keeping track of your progress.
Steve.
Posted: Sat Feb 14, 2009 10:33 am
by peter-curacao
sideslippa wrote:Hi Peter I have been checking out your build project...I am very impressed with the boat and your workmanship. I will enjoy keeping track of your progress.
Steve.
Thanks, my pleasure
Posted: Sat Feb 14, 2009 2:26 pm
by ixplorer
FYI ... Veneers available down here... this is a good resource for you if you are looking for colours etc...
http://www.gvpnz.com/veneers.htm
Wet on wet biaxial tape method you may be interested in Peter...
http://www.youtube.com/watch?v=x6BIr0Kq0Bs
Posted: Sat Feb 14, 2009 4:50 pm
by peter-curacao
Today I’m certain that I’m going to hell
, I didn’t count the curses I made but there were a lot! Thing is last week I did all the layers on the inside bottom but since the fabric isn’t wide enough to do the two layers in four times I have to put a small piece in the middle.
So I did that today jeez what a B@#%ch was that, I thought to be smart since it is the bilge area I wanted to put some foil over it to get a smooth surface that didn’t go as well as the outside because of the keel there was air trapped under the foil I couldn’t get out took the foil off two times with the for me necessary curses. At the end I cut the foil in two pieces and that did the job duh I’m an idiot
should have done that directly .I hope it will come out good tomorrow I will post pic’s tomorrow.
Btw Explorer I did al my tapes and filets wet on wet, did see those clips but thanks anyway.
Posted: Sat Feb 14, 2009 7:05 pm
by chicagoross
On the bright side, Peter, you're going to be the glassing expert here. Most of us would have to build 3 or more boats to get the amount of experience you're getting building that monster!
Hang in there! Other than that have you been enjoying looking at the inside of the boat for a change?
Posted: Sun Feb 15, 2009 11:20 am
by peter-curacao
As I thought so a world-class fiasco! Man
this is gone give me a lot of sanding to do there is air trapped on a lot of places. I knew it yesterday it just took me to long to get it right this is the result!
chicago o yes I did that, it's nice to sit in there doing nothing but just looking around and fantasizing
Posted: Sun Feb 15, 2009 7:50 pm
by Spokaloo
Peter, you gotta get in there with a roller man, seriously...
http://boatbuildercentral.com/proddetai ... M_lam_roll
E
Posted: Sun Feb 15, 2009 7:57 pm
by peter-curacao
Spokaloo wrote:Peter, you gotta get in there with a roller man, seriously...
E
How do you mean that?
Posted: Sun Feb 15, 2009 7:58 pm
by Spokaloo
Excellent, you are on and I am on.
Did you roll that glass down against the wood? With as tight as your layups looked before, it seems like it'd be odd that those areas lifted and got bubbles that size.
E
Posted: Sun Feb 15, 2009 8:02 pm
by peter-curacao
Spokaloo wrote:Excellent, you are on and I am on.
E
Yes I did but I had a bad day Saturday see my earlier posting
Posted: Sun Feb 15, 2009 8:03 pm
by Spokaloo
Hey, guess what happens when you use a work computer that doesn't cache your read/unread threads....
Doh, sorry, sounds like it was a fun saturday!
E
Posted: Sun Feb 15, 2009 8:07 pm
by peter-curacao
Spokaloo wrote:Hey, guess what happens when you use a work computer that doesn't cache your read/unread threads....
E
It was fun until that foil worked against me
Posted: Sun Feb 15, 2009 11:00 pm
by Murry
Sorry your last layer went that way for you Peter.
No worries, as you know, it can fixed. You've probably already fixed it
Posted: Mon Feb 16, 2009 4:12 pm
by peter-curacao
Well here’s the damage
first pic is at the transom second towards the bow
Black lines is where the second layer of wide fabric ends so the last piece of glass that went in (the piece that went wrong) is only to cover the area between those black lines. The bleu spots are the area’s I sanded away because of the air trapped under the glass, what do you guys think I should do?:doh:
Posted: Mon Feb 16, 2009 6:55 pm
by Spokaloo
Peter, whats next in the laminating schedule? Sheathing the interior coming up soon?
E
Posted: Mon Feb 16, 2009 7:00 pm
by peter-curacao
Spokaloo wrote:Peter, whats next in the laminating schedule? Sheathing the interior coming up soon?
E
Hi Erik first I have to clean up the mess above after that stingers and frames, but you did know that didn’t you?
Concerning the interior I still didn’t make up my mind between a cuddy or a open short deck difficult decision
High spots or bubbles?
Posted: Mon Feb 16, 2009 7:04 pm
by Bluefish2
Peter,
If those are high spots just grind them flat and move on.
If they are air bubbles try cutting around them and filling underneath.
Yu can cut out bubbles and and fill with paste of glass and wood floor.
They are going to be unseen by all eyes but yours.
BF
Posted: Mon Feb 16, 2009 7:05 pm
by Spokaloo
Woah big fellah...
On my LB I taped first then laid sheathing over the tape. I backtracked and saw you already laid your wide sheets.
So then that leaves us with our good friend the grinder.
If it were me (in my absolute infancy of boatbuilding compared to you), Id be in there grinding that sucker out flat and relaying glass, but im betting you have a better, lower effort solution.
E
Posted: Mon Feb 16, 2009 7:48 pm
by peter-curacao
Erik once in a while I’m having a little trouble to understand your postings sorry for that.
In this crapy drawing I made I try to explain what I did
Bleu lines is first layer over tape red second and green is the last small piece
The green piece I already sanded so that all air bubbles are out , If I understand you correctly you are telling me to grind that whole green piece out and start over?
Posted: Mon Feb 16, 2009 7:50 pm
by Spokaloo
Again, if it were me (and Im not one to be listened to)...
I would grind back the layer that has all the problems only as far as necessary to get past the bubbles.
Then I would feather the edge and lay in another piece.
E
Posted: Mon Feb 16, 2009 7:56 pm
by peter-curacao
Spokaloo wrote:Again, if it were me (and Im not one to be listened to)...
E
Okay great that's what I did maybe it's not so clear on the last pics but in those pics I did grind/sand that piece down that's why its white, only have to lay new glass yet
Btw why shouldn't I listen to you? you build more boats than I did
Posted: Mon Feb 16, 2009 8:24 pm
by Spokaloo
Did you see how many times I screwed mine up?!?
Im a horrible role model.
E
Posted: Mon Feb 16, 2009 8:31 pm
by peter-curacao
Spokaloo wrote:Did you see how many times I screwed mine up?!?
E
ahh don't be so hard on yourself
Posted: Mon Feb 16, 2009 8:41 pm
Peter
What do you think you should do, in the keel of an offshore fishing boat
Your offshore fishing boat.
So would I, E
Posted: Mon Feb 16, 2009 8:44 pm
by peter-curacao
Cracker Larry wrote:Peter
What do you think you should do in, Your offshore fishing boat.
Euuh put two of those in
Posted: Mon Feb 16, 2009 8:50 pm
And hope the keel don't split
Posted: Mon Feb 16, 2009 10:36 pm
by Murry
Maybe three
I'm picturing that video you posted of your friends 29 a couple of weeks.
Posted: Tue Feb 17, 2009 5:29 pm
by peter-curacao
Posted: Tue Feb 17, 2009 6:03 pm
by Fonda@kauai
Fat a$$ transom indeed! That baby's got some junk in the trunk.
Posted: Wed Feb 18, 2009 6:38 pm
by peter-curacao
Posted: Wed Feb 18, 2009 8:18 pm
by dustin1
Peter, those extra layers in the transom will come in handy when/if Mr. pissed off blue marlin makes violent contact with your baby!
Posted: Thu Feb 19, 2009 4:14 pm
I moved the discussion about monster turtles to "Anything else".
Posted: Thu Feb 19, 2009 4:16 pm
by peter-curacao
jacquesmm wrote:I moved the discussion about monster turtles to "Anything else".
Again no worry's no problem
Posted: Fri Feb 20, 2009 7:03 pm
by DrBones
That's going to be one 'show boat' once you get done with her. Congrats! Happy to see that now there is a 'bateau' community in Curacao!
Btw..I have a good friend living over there...moved from Florida to Curacao and always wanted to build a boat. He's a top chef with his wife that does the pastries. If you come across him...tell him 'DrBones' says hello and to start building!
Posted: Tue Feb 24, 2009 5:11 pm
by peter-curacao
DrBones wrote:Btw..I have a good friend living over there...moved from Florida to Curacao and always wanted to build a boat. He's a top chef with his wife that does the pastries. If you come across him...tell him 'DrBones' says hello and to start building!
If you tell me his name I will certainly do that.
Posted: Tue Feb 24, 2009 5:21 pm
by peter-curacao
Transom taped and glassed again and “motorwellâ€
Posted: Tue Feb 24, 2009 5:59 pm
by Murry
I like it Peter!
Where will your fish box/boxes be located?
Will there be enough room to have a fish box in the center with a live well on one side or the other. I thought you were running a bracket, if so, you should have the entire length of the transom for storage,baitwell, and fish boxes and such. Right
Looking great,
Daniel
Posted: Tue Feb 24, 2009 6:05 pm
by peter-curacao
Murry wrote:I thought you were running a bracket, if so, you should have the entire length of the transom for storage,baitwell, and fish boxes and such. Right
Looking great,
Daniel
Correct but I'm gone loose some space for the fish/swim door, there is also space beneath the casting deck
Posted: Tue Feb 24, 2009 7:39 pm
by Dog Fish
Peter
I had my bait well in the transom of my Hatteras and had the drain in the bottom like yours but none at the top on the side like your set up shows. I used a plastic 2 1/4 through hull and put a removable pvc stand pipe with a cap on the top and drilled about 20 small holes just below the cap and just stuck it in the through hull. I had 3 different length pipes so I could change the water height. At the end of the day when done I just pull out the pipe and it drained out fast and all the scales and crap with it. I do all my bait tanks that way, it makes for fast easy clean out. works for me.
Posted: Tue Feb 24, 2009 7:59 pm
by peter-curacao
Dog Fish wrote:Peter
I know that system, a friend of my has it in his Dusky and indeed it works good, but the thing is I don't like the loose parts that's why I went for a valve.
Posted: Tue Feb 24, 2009 8:13 pm
by Dog Fish
I got ya
Posted: Tue Feb 24, 2009 8:40 pm
by Murry
Sounds like you're thinking of all the details Peter.
Isn't fun getting to plan the layout of your own boat?
As much fun as I've had planning my gf, I can only imagine how much more fun it would be to plan the layout of that huge thing.
I bet you just sit inside the hull pondering of this and that......I could sit in that bare hull and waste days at a time day dreaming about ideas and wondering what it'll look like on the water.
Have fun Peter.
Posted: Wed Feb 25, 2009 6:01 am
by cape man
I concur with the overflow being a separate hole up top. You lose the ability to control the water level that stand pipes give you, but you also lose the hassles of a stand pipe...an obstruction in the middle of the tank, and stopping after a long run to discover the tank is empty and the bait dead because the pipe vibrated out while running. Boat is looking really nice Peter.
You mention a swim/fish door...I assume you are cutting that in the transom on one side. Would it have been easier to cut that before the transom was glued and taped in?
Posted: Wed Feb 25, 2009 11:28 am
by Dog Fish
I could see the stand pipe getting in the way if you were foolish enough to put it in the middle . As far as water height, its controlled by whatever length pipe you use like your are saying. My stand pipes were all snug fits and never had one come out in 26 years in the charter boat business. Just saying
I also had a T on my through hull pick up with two bait pumps so if one went down I was back going quickly. I did lose all my bait many times to red tide and once to a soap fish that I keep for bait. Peters system he drew up is a great way to do it.
Posted: Wed Feb 25, 2009 12:16 pm
by peter-curacao
Thanks you al for the input and compliments I really appreciate it.
cape man wrote:You mention a swim/fish door...I assume you are cutting that in the transom on one side. Would it have been easier to cut that before the transom was glued and taped in?
Yes I will and yes it would be way easier if I have done it on forehand but I always thought it wasn’t possible until here
fish/swimdoor discussion
Dog Fish wrote:As far as water height, its controlled by whatever length pipe you use like your are saying.
Maybe a stupid question but why would you have different water levels? We always pump the tank full and most of the time keep on pumping “freshâ€
Posted: Wed Feb 25, 2009 1:08 pm
by Dog Fish
My tank was extra large, so I could haul a lot of bait. In tarpon season we would go 4 or 5 miles offshore and catch 25-30 + dozen squirrel fish ( sand perch ) that are 6 to 9 inches long. Needed the extra volume for all that bait. On a charter I would use a shorter pipe so I wasn't hauling all that extra water around. I even had a separate through hull with a large capacity pump to increase the water flow just for squirrel fishing. Had to baby those things $$$.
If you are missing something, look around I think its somewhere.
Just kidding ya
Peter, keep up the good work your build is looking really good. I would like to ride in it some day. That hull design is one of my favorite plans.
Posted: Sun Mar 01, 2009 9:23 am
by cape man
The only boats I ever run that used stand pipes did exactly that...right in the middle of the tank!
..and they were "unsnug" fit. Your wells sound fine, and a pipe inserted into a deep fitting is often a bear to get out. Still like a fixed overflow in the side and a seperate drain, but have no good reason for it
Posted: Sun Mar 01, 2009 10:41 am
by AmbitiousRookie
Every boat I've ever been in with a stand pipe came out at one time or another. Since we make everything here why not have the stand pipe be a screw in NPT .
Posted: Sun Mar 01, 2009 4:31 pm
by OllieK
Hey Peter,
Was just wondering, as I am about to buy my first lot of epoxy, how much did you use on the bottom? Just a rough idea would be great. need to get it ordered soon.
Cheers
Ollie
Posted: Sun Mar 01, 2009 8:11 pm
by tampa_panga
T H Marine sells a screw in overflow drain pipe that is threaded. I've never used one but it appears to solve the frustrating issue of the "push in" standpipe drains.
http://www.thmarine.com/product.cfm?PRID=67
Ultimate standpipe
Posted: Mon Mar 02, 2009 12:32 am
by Leotis
All you need is a male adaptor a quick fix coupling and a short piece of pipe to make the best stand pipe for your livewell. The quick fix coupling is adjustable so once you connect it to the male adaptor and screw it in to the drain you can adjust it just by pushing or pulling it, if you do desire different water levels. You can get all of these at any plumbing supply house.
tampa_panga wrote:T H Marine sells a screw in overflow drain pipe that is threaded. I've never used one but it appears to solve the frustrating issue of the "push in" standpipe drains.
Posted: Tue Mar 03, 2009 5:39 pm
by peter-curacao
OllieK wrote:Hey Peter,
Cheers
Ollie
Not sure but I think with about 7 gallons you will be ok
Posted: Tue Mar 03, 2009 7:08 pm
by peter-curacao
Not sure but I think with about 7 gallons you will be ok[/quote]I'm talking resin only here
Posted: Sat Mar 07, 2009 6:34 pm
by peter-curacao
Posted: Sat Mar 07, 2009 7:26 pm
by steve292
That's impressive,very neat nice work
Steve
Posted: Sat Mar 07, 2009 7:30 pm
by Dog Fish
I would say that was a lot of work, great progress Peter. Yea that's great and it gives ya something to look at now, good job.
Posted: Sun Mar 08, 2009 6:47 am
by chicagoross
Very nice, Peter! Now you've got about a mile of cleats to cut into little bitty pieces and glue to the tops of all those frames and stringers; that should keep you busy for another day or two!
Posted: Sun Mar 08, 2009 9:48 am
by gk108
It looks strong enough to support a 400 lb. grouper.
Posted: Sun Mar 08, 2009 10:07 am
by Dougster
Well that's about 3 months work for me and you run through it in a week. I'm finishing the cleats for the LB22's cockpit now and boy, like Chicago says, you got a mile's worth. Probably take you most of an hour
How come you glassed all the stringers? I just taped mine. Wish my work looked as clean as yours.
Gettin' coffee'd up on a Sunday morning Dougster
Posted: Sun Mar 08, 2009 2:28 pm
by Murry
Looks great Peter.
I enjoyed picturing that.
Posted: Mon Mar 09, 2009 9:42 am
About the stringers pictures: on the plans, the notches are much shallower. We show the notches only 3" deep, 3" below the sole.
This has a few advantages: the stringers stay straight during the assembly and if there is a defect in the fiberglass work like a gap, we can count on the stiffness of the wood core.
In this case, Peter did a good fiberglass job and the boat will be just as strong. And we have good safety margin built-in but I would prefer to see the stringer notches cut as on the plans.
Posted: Mon Mar 09, 2009 1:01 pm
by peter-curacao
Ok I’m glad I’m safe there, about the plans:
The plan says
[quote]“Stringers and molds (frames) have assembly notches. The exact depth of the notches is unimportant and left to the builder's preference but 3" (75 mm) is a good standard value.
See our HowTo file titled "Notches for jig and structure assembly" for an explanation of the notches system.
The location of the notches is clear. On the molds, the notches are always located at the same distance from the centerline, equal to the stringers spacing.
On the stringers, the notches are located at each frame or bulkhead: see the Stations drawing.â€
Posted: Mon Mar 09, 2009 1:21 pm
The exact depth is not important but I prefer to have them 3" deep or less for the reasons stated in my post.
As long as the builder does a good job of aligning the stringers and a good fiberglass job, it doesn't matter but shallow notches give you more stiffness during the assembly. This help obtain a straight bottom but it is not 100% required.
We show 3" notches (76 mm) in our HowTo files:
http://bateau2.com/content/view/98/28/
http://bateau2.com/content/view/77/28/
I will add the words "ideally notch depth in the stringers is 3" or less" to the building notes but I repeat, it is not an absolute requirement. A careful builder can get the same results with deeper notches.
Posted: Mon Mar 09, 2009 1:34 pm
by peter-curacao
jacquesmm wrote:I will add the words "ideally notch depth in the stringers is 3" or less" to the building notes but I repeat, it is not an absolute requirement. A careful builder can get the same results with deeper notches.
Thanks for that and your quick response
Posted: Wed Mar 11, 2009 8:43 pm
by peter-curacao
Still busy with taping and glassing the frames not my favorite part of this build, but what has to be done has to been done, so no cleats gluing for me … yet.
It’s because of all the little pieces of tape and fabric this also brings a lot of loose threads all over the build, it looks like a mess!
thankfully when dry it cleans up pretty easy
Posted: Wed Mar 11, 2009 9:02 pm
by Doc_Dyer
Peter,
we can't get our fix in if you dont post pics
Bradley
Re: Curacao CS 25
Posted: Wed Mar 25, 2009 11:25 am
by D2Maine
ttt
Re: Curacao CS 25
Posted: Wed Mar 25, 2009 1:02 pm
by Doc_Dyer
Peter,
we neeeeed some boat porn...please post new pics
Re: Curacao CS 25
Posted: Thu Mar 26, 2009 10:04 am
by peter-curacao
I’m sorry I don’t have much news to show I did tape and cover some frame’s but nothing mayor
I’m a little busy with setting up a new project at work and I really want to have this done as soon as possible, so hopefully I can make it to the boat builders meeting in April and if really lucky go to Boca Grande too.
But I will see if I can post some pic’s tonight when I’m at home.
Re: Curacao CS 25
Posted: Thu Mar 26, 2009 6:32 pm
by Dog Fish
I hope ya can because were going to have a good time
Geter done.
Re: Curacao CS 25
Posted: Thu Mar 26, 2009 8:04 pm
by TomW
Ya Peter get that nasty work done then you can spend almost a week forgettin' about it.
Re: Curacao CS 25
Posted: Wed Apr 01, 2009 6:32 pm
by peter-curacao
Getting there! today I took off early from work and started with those frames again Only frame H left and full frame I but I still have to cut that last one, so almost time to make hatches (in I ) still not sure if I make them or just put some stock one’s in and off course the life bait and coolers
But first things first and that is frame H jeezzz it’s not that I hate detailed work but this is just plain stupid all those friking little pieces between the stringers and that three times staggered.
As soon as possible in the new forum I will put up some more pic’s
Ciao Peter
Re: Curacao CS 25
Posted: Wed Apr 01, 2009 7:55 pm
by Dog Fish
We will be looking forward to the pics Peter. No complaining, remember your the one that wanted to build that big boat. Just messing with ya, keep plugin away. Just think when you get all that under sole stuff done, you can start the fun stuff that you see all the time. Your getting there dude
Re: Curacao CS 25
Posted: Thu Apr 02, 2009 2:23 am
by chicagoross
Hang in there, Peter, when you finish all those
of tape, I'll bet you you got 2 or 3 times as many
of cleats to do...
Then you lay the soles, build the gunnels, and THEN you can really start doing the
detailed work
The funniest part is, about a week after you say "boy I'm glad that's done, I didn't think it would ever end", pop the champagne, and catch your first fish off your beautiful new boat, you're going to notice how weird your (former patio) empty boat shop looks and start thinking about what you need to build next. Or maybe it will actually take up to a month after building a boat that big; but it will happen!
Re: Curacao CS 25
Posted: Fri Apr 10, 2009 4:16 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Apr 11, 2009 2:50 am
by ks8
I still think you'll be done before me.
Re: Curacao CS 25
Posted: Sat Apr 11, 2009 6:36 pm
by chicagoross
Nice looking hatches! I think that qualifies as detail work!
Re: Curacao CS 25
Posted: Sat Apr 11, 2009 7:16 pm
Nice work Peter
Re: Curacao CS 25
Posted: Sat Apr 11, 2009 8:15 pm
by TomW
You do very nice work Peter.
Re: Curacao CS 25
Posted: Sat Apr 11, 2009 8:38 pm
by wegcagle
I agree. Those hatches look AWESOME
Makes me consider doing the extra work
Re: Curacao CS 25
Posted: Sun Apr 12, 2009 11:25 pm
by cape man
Like the hatches. Have cussed myself several times fighting with mine but now that they are close to done I'm real glad I spent the time. Really sets the boat off. Plastic hatches are great, probably cheaper in the long run, but that stainless hardware on a flush hatch is nice. You'll be happy when they are done.
Re: Curacao CS 25
Posted: Mon Apr 13, 2009 1:30 pm
by peter-curacao
Everybody thanks for al the compliments, really appreciate them.
I dry fitted the bulkhead today and after I was done with that there was directly a question rising, this can’t be right is it?
Re: Curacao CS 25
Posted: Mon Apr 13, 2009 1:35 pm
by Spokaloo
I don't have plans, but I personally would trim it.
E
Re: Curacao CS 25
Posted: Mon Apr 13, 2009 3:58 pm
by Murry
Looks like a preference decision to me. Trim it.
Not without hearing form Jacques ofcourse.
I missed you hatches from earlier Peter. They look fantastic.
Re: Curacao CS 25
Posted: Mon Apr 13, 2009 4:00 pm
by Spokaloo
Peter, post the question in Power Boats. Jacques doesn't fish down here often.
E
Re: Curacao CS 25
Posted: Mon Apr 13, 2009 4:01 pm
by peter-curacao
Spokaloo wrote:Peter, post the question in Power Boats. Jacques doesn't fish down here often.
E
I just did
thanks both of you
Re: Curacao CS 25
Posted: Mon Apr 13, 2009 9:54 pm
by wegcagle
We'll see what Jacques says about it, but at least the bulkhead is bigger than the transom. Much easier to trim wood than to add it
Also the angle would drain water out of the boat instead of into it. Either way, again the hatches look great, and WE NEED PICTURES MORE OFTEN
Just the addict in me
Will
Re: Curacao CS 25
Posted: Fri Apr 17, 2009 4:17 am
by cape man
Peter,
Don't have plans and am interested in Jacques' response. Your work is VERY clean compared to mine.
Re: Curacao CS 25
Posted: Fri Apr 17, 2009 7:44 pm
by peter-curacao
wegcagle wrote:We'll see what Jacques says about it,
cape man wrote: and am interested in Jacques' response.
Me to but I think in one way or the other I did ,do, wrote or said something wrong
because he is not answering. All thanks for the response and compliments, Monday if not possible tomorrow I will see if I can still get a plane ticket for the BB meeting, boy I really would like to meet you guys, unfortunately work didn’t make it easy for me to make the decision ahead of time
Re: Curacao CS 25
Posted: Fri Apr 17, 2009 11:06 pm
Peter, he'll be there and you can ask him in person
He's been quiet this week, must be busy somewhere.
Re: Curacao CS 25
Posted: Wed May 27, 2009 6:56 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed May 27, 2009 7:44 pm
by Dog Fish
Hey Peter, Lookin good dude
I know where your coming from with the bad back, Its a real bummer when it happens, it takes your breath away sometimes. Can't hardly find a position to sit, stand or even lay down without getting that sharp dagger pain. Puts tears in your eyes.Glad to hear your on the mend, it takes a while. I hope you continue to get better, don't over do it.
Looks like the hull has got some good strength now with your last run of glassing. Later.
Brian
Re: Curacao CS 25
Posted: Wed May 27, 2009 9:22 pm
Makes my back hurt to think about glassing and sanding all that
That's a big boat. Very nice looking work Peter
Re: Curacao CS 25
Posted: Wed May 27, 2009 9:27 pm
by Fonda@kauai
Looks good. I bet it really stiffens up when you glass those frames in huh?
Re: Curacao CS 25
Posted: Thu May 28, 2009 9:26 am
by Doc_Dyer
thanks for the Porn Peter
awesome job where does your water tank go?
Bradley
Re: Curacao CS 25
Posted: Thu May 28, 2009 9:36 am
by peter-curacao
Doc_Dyer wrote:thanks for the Porn Peter
Bradley
Thank's, the tank go's all the way at the bow behind the first frame (B) you see on the first pic, and is about 100 liters about 26/27 US gallons have to test it when finished for exact numbers. Still have to put some wave barriers?? in (don't know the exact name)
Re: Curacao CS 25
Posted: Thu May 28, 2009 9:44 am
by Doc_Dyer
here?
Re: Curacao CS 25
Posted: Thu May 28, 2009 10:11 am
by peter-curacao
Doc_Dyer wrote:here?
Yep I took the advice from what you guys gave me
In this topic
Re: Curacao CS 25
Posted: Thu May 28, 2009 11:13 am
by gk108
I guess you would call them baffles. You won't need much for a tank that size and shape. Probably just two pieces crossing near the middle of the tank. I would place them off of the bottom of the tank, so there's no need to worry about getting all of the water out of the tank through limber holes in the bottoms of the baffles.
Re: Curacao CS 25
Posted: Thu May 28, 2009 11:28 am
by peter-curacao
gk108 wrote:Still have to put some wave barriers?? in (don't know the exact name)
Thank's baffels it is than
Exactly what I was thinking thank's for that conformation, one thing I'm not sure of shall I paint the inside or leave it like this?
Re: Curacao CS 25
Posted: Thu May 28, 2009 11:36 am
No paint for potable water tanks
Re: Curacao CS 25
Posted: Thu May 28, 2009 11:43 am
by peter-curacao
Cracker Larry wrote:No paint for potable water tanks
Your smiley confuses me, Now I don't understand what you mean
paint or no paint?
Re: Curacao CS 25
Posted: Thu May 28, 2009 11:53 am
No paint
Re: Curacao CS 25
Posted: Thu May 28, 2009 12:05 pm
by peter-curacao
Oke thank's Larry
Re: Curacao CS 25
Posted: Thu May 28, 2009 12:18 pm
by Murry
That looks amazing Peter!
Seeing that picture of the stringers and frames really gets me excited. I can only imagine how strong they are.
I want to build a big boat.
Re: Curacao CS 25
Posted: Thu May 28, 2009 12:26 pm
by Jaap
Hi Peter, looks good! Why did you make a sperarate tank instead of using the space between the stringers? I used a epoxy coating which is approved for use with food. Bought it here in the netherlands at polyservice in amsterdam. The hardener smells different, no ammonia, more like araldite glue.
Take care of your back, you have only one!
jaap
Re: Curacao CS 25
Posted: Thu May 28, 2009 1:10 pm
by peter-curacao
Jaap wrote:Hi Peter, looks good! Why did you make a sperarate tank instead of using the space between the stringers? I used a epoxy coating which is approved for use with food. Bought it here in the netherlands at polyservice in amsterdam. The hardener smells different, no ammonia, more like araldite glue.
jaap
Jaap to be honest I did think of that, and I can't give you a specific reason why I went with the separate tank, It was just a feeling of me that that was the way to, go don't know why
I did use just regular west system epoxy hope that's oke too after a lot off flushing.
Re: Curacao CS 25
Posted: Thu May 28, 2009 4:37 pm
by Jaap
This is an interesting link, maybe you already read it
http://www.epoxyworks.com/18/tanks.html.
jaap
Re: Curacao CS 25
Posted: Thu May 28, 2009 6:15 pm
by fishin'
lookin good! How exactly do you go about putting the lid on the water tank? Will you document this for us please? Thanks.
Re: Curacao CS 25
Posted: Fri May 29, 2009 8:03 pm
by blindmullet
peter-curacao wrote:Cracker Larry wrote:No paint for potable water tanks
paint or no paint?
They sell an epoxy thats used inside water tanks--FGCI has it.
Re: Curacao CS 25
Posted: Fri May 29, 2009 8:36 pm
by peter-curacao
fishin' wrote:lookin good! How exactly do you go about putting the lid on the water tank? Will you document this for us please? Thanks.
Sure no problem, I was planning to glue it on and later tape the outside with biax 45/45, I will show with pic's
Re: Curacao CS 25
Posted: Fri May 29, 2009 8:43 pm
by peter-curacao
blindmullet wrote:peter-curacao wrote:Cracker Larry wrote:No paint for potable water tanks
paint or no paint?
I did read Jaap's link (btw thanks for that one Jaap) and I didn't see anything that I couldn't use regular epoxy, only needed to ad a little less hardener, please correct me if I'm wrong!
Note: this freshwater tank is only for showering, cleaning etc.
not drinking water (although it could happen in emergency's)
Re: Curacao CS 25
Posted: Sat May 30, 2009 9:19 am
Regular epoxy will be fine Peter.
Re: Curacao CS 25
Posted: Sat May 30, 2009 10:13 am
by peter-curacao
Thanks Larry
Re: Curacao CS 25
Posted: Sat May 30, 2009 3:59 pm
by Daddy
I like the idea of a little less hardener in a fresh water tank as it is the hardener that is most worrisome and the idea of uncured hardener leaching out into the water might be unpleasant. Probably just a bit less would not compromise the mix.
Just my 2 cents/\.
Daddy
Re: Curacao CS 25
Posted: Sat May 30, 2009 4:35 pm
by peter-curacao
The mix ratio when working with the mini pumps according the west system PDF file is:
Epoxy Combination---------------------Pumps Resin--Pumps Hardener
105 Resin +205 or 206 Hardener-------------6----------------5
105 Resin +207 or 209 Hardener-------------7----------------6
Re: Curacao CS 25
Posted: Sat May 30, 2009 6:51 pm
by peter-curacao
Some of the cleats went in today
Re: Curacao CS 25
Posted: Sun May 31, 2009 6:32 pm
by peter-curacao
I didn't bought enough material to finish the cleats this weekend, somewhere during measuring something went
wrong I think
so have to buy more next week. I did had the ply for the sole dough, so I couldn't resist
Re: Curacao CS 25
Posted: Sun May 31, 2009 7:38 pm
by wegcagle
See's looking GREAT Peter. You gotta be getting excited now
Clean work
Will
Re: Curacao CS 25
Posted: Sun May 31, 2009 11:04 pm
by peter-curacao
wegcagle wrote:See's looking GREAT Peter. You gotta be getting excited now
Clean work
Will
Thanks, sure I'm exited its a major milestone (for me it is) to get the sole in, but it's a little bit of a double feeling happy to reach that point
, less happy to see all that work disappear under just 5 sheets of plywood.
Re: Curacao CS 25
Posted: Mon Jun 01, 2009 1:55 am
by chicagoross
Don't worry yet, Peter, you've still got lot's of details left after you get that sole glued down (which by the way is going to take a LOT of glue to cover all those cleats and run filets all around - hope your epoxy stash is holdng out!). The real upside is that you are really going to enjoy the next phase of working in the boat on a solid, level sole instead of sloped hull sides and stepping over frames!
You back, ankles, and knees are all going to appreciate the change the sole makes!
But first, tanks and chases?
Re: Curacao CS 25
Posted: Mon Jun 15, 2009 10:19 am
by Doc_Dyer
Peter,
2 weeks since your last post !!!!!
what have you done lately, any pics ????
Bradley
Re: Curacao CS 25
Posted: Tue Jun 16, 2009 8:57 pm
by bushmaster
Very good work Peter
Is the sole towards the bow supposed to touch the side panels or is there some filling along the sides?
I have to do some filling on my FS17 because I raised the stringers a bit.
Keep up the good work and keep on posting
Bushmaster
Re: Curacao CS 25
Posted: Sun Jun 28, 2009 11:11 pm
by Dog Fish
Peter, are ya out there
Hope every thing is ok.
Brian
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 1:04 pm
by peter-curacao
I'm still here but I was busy with some other things (o.a. work) almost all the cleats are in for now, the rest I will put in when my tank's have arrived and placed, I ordered them a little late just before vacation time over here, so I have to wait a little more.
Also I was a lot in the thinking chair what again raised some questions see power boat section, little scary because once the sole is glued in I can't get under it anymore so a little more thinking won't hurt I think
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 2:09 pm
by Daddy
Looks really good right now, great prep work for the sole. Good to think ahead about the chair or anything else that you might need to anchor down. Pondering. That's half the build.
Daddy
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 3:43 pm
by peter-curacao
Just try to bend my 3 '" trace piping for steering and push/pull cables, that was much more difficult as I did once with a 2 " pipe.
I took a piece of pvc pipe,put a cap on one end and filled it with sand than capped the other side and heated the pipe and bended it, its fairly smooth on the outside curve but the inside is like a bumpy roller coaster! What do you guys think can I use it?
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 5:52 pm
by TomW
Yep the inside is probably smooth as a baby's bottom. Don't worry about it you have a 3" tube to drage your cables through and they won't catch on those small ridges. Have fun. It's good to see you back on the forum
Toom
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 7:10 pm
by peter-curacao
Ok Tom Thanks, I will put them in tomorrow, I was wondering can I fit everything for the OB in one 3" pipe? ( with exception for the fuel) throttle steering electrical ? and what diameter pipe should I use for the fuel line ?
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 8:57 pm
by BWhalen
I used 3" PVC with fittings as suppose to bending the pipe....fit everything less fuel through it. That includes the big mechanical steering cable
Brian
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 9:07 pm
I don't see any problem with that. The rigid ends on the steering and control cables will follow the outside of the bends. I used 2" for my steering and shift/throttle cables with no troubles.
I used 1" and it was borderline too small, using factory made sweep 90s. Next time I'll use 1 1/2".
Brian, Peter is in Curacao and can't buy the fittings there.
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 9:17 pm
by peter-curacao
Cracker Larry wrote:I don't see any problem with that. The rigid ends on the steering and control cables will follow the outside of the bends. I used 2" for my steering and shift/throttle cables with no troubles.
Oke thank's Larry (good to "speak" with you again) I bought 32 mm for the fuel so I think that might do, still a little tight but if I understood correctly it will work?
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 9:19 pm
by peter-curacao
That's why I didn't understand sh..t of that posting, thougt it was the rum
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 9:21 pm
Good to speak with you also Peter
, my non-metric mind makes 32mm to be about 1.25 inches, which will be fine if you don't have more than 1 or 2 - 90 degree bends in the pipe.
Re: Curacao CS 25
Posted: Wed Jul 08, 2009 9:27 pm
by peter-curacao
Cracker Larry wrote:Good to speak with you also Peter
No I will use my super duper sand filling heat bending technique, loooooong curves
Re: Curacao CS 25
Posted: Fri Jul 10, 2009 12:25 pm
by peter-curacao
Another trace pipe question, what size do I use for the fuel fill and fuel vent
Re: Curacao CS 25
Posted: Fri Jul 10, 2009 6:51 pm
by stickystuff
fuel fill if I remember correctly is 1 1/4" The vent I think is 1/2" ID.
Re: Curacao CS 25
Posted: Fri Jul 10, 2009 7:03 pm
by peter-curacao
stickystuff wrote:fuel fill if I remember correctly is 1 1/4" The vent I think is 1/2" ID.
Thank's Ken is this trace pipe or the size of the filling tube itself ?
Re: Curacao CS 25
Posted: Fri Jul 10, 2009 8:42 pm
by TomW
Peter I was looking at fuel fils and vents yesterday and the regs. Fill recommendations are 1 1/2" and vent is 5/8" I believe that is what just about everyone uses. That is the inside hose diameters. Fittings are easy to find for this size hose also. For hose to the motors you will want 3/8 or even 1/2" for those big engines.
For the 1 1/2 you'll need 2 1/2" and for 5/8 I'd use 1 1/2" . I'm not sure you even need pipe for these hoses as they need to be inspected occasionally and you have to be able to push the hose on the fittings and clamp them. For the hose to the motors yes put them in tubes again it will be easier if you use 1 1/2" pipe.
Re: Curacao CS 25
Posted: Fri Jul 10, 2009 10:41 pm
Yes, those are the standard sizes for both, ID. The OD is much larger. There is no need for either to be in a conduit.
Re: Curacao CS 25
Posted: Fri Jul 10, 2009 11:17 pm
by Dougster
Bateau sells the 5/8", but I don't see where they sell the 1 1/2". Those do seem like standards. I've looked at lots of hoses and tanks on line tryin' for one to fit Nina. You can figure on a 4" to 5" radius bend on all of 'em that are CSGC approved, and forget about angled adapters. It seems to be a liability thing. I need to order some hose now, and will use Bateau as possible. I wonder why they don't seem to carry the fill hose (1 1/2")?
Messing with this fuel thing Dougster
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 10:10 am
by peter-curacao
Cracker Larry wrote:Peter I was looking at fuel fils and vents yesterday and the regs. Fill recommendations are 1 1/2" and vent is 5/8"
Oke that's clear, but maybe a stupid question doesn't the pour foam damage the hoses ?
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 12:52 pm
by TomW
According to the Coast Guard they have to be able to be pulled out and examined or replaced so you cannot cover them with foam. Guess that makes sense.
PS Dougster found this site for 1 1/2" Type A
http://www.rivermarinesupply.com/xcart/ ... t=0&page=1 , best price I could find.
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 6:19 pm
by peter-curacao
TomW wrote:According to the Coast Guard they have to be able to be pulled out and examined or replaced
How is that possible to do if you don't place them in a conduit ?
Cracker Larry wrote:There is no need for either to be in a conduit.
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 6:25 pm
by Daddy
I guess you gotta do the conduit at least where it is going to be encased in foam. Can't speak for Larry but I don't think he was thinking the hose would be encased in foam. Makes sense that you should be able to examine/replace the hose as necessary.
Daddy
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 7:32 pm
by Aripeka Angler
Peter, you do not want to bury either hose in foam. I would also want an inspection plate or hatch to check the hose connections every so often. It is not a bad idea to have to have one in the deck just above the tank and one in the gunnel at the fill. If you have to pour foam around the hoses, I would put them in a chase. You want to be able to get them out without taking a chainsaw to your boat if ethanol fuel makes a hose fail:help: Could you leave a space in the foam for a chase for your hoses
That would be easier than a bunch of chase pipes
Just an opinion....
Richard
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 8:12 pm
by peter-curacao
Aripeka Angler wrote: Could you leave a space in the foam for a chase for your hoses
Just an opinion....
Richard
That's a good idea I think tomorrow I will buy a piece of plastic rain gutter (I think the fill hose the vent hose and the ground wire will fit in there) and put that in before foaming, the sole will than function as a lid on the gutter, I think that will work ?
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 8:32 pm
by Aripeka Angler
peter-curacao wrote:Aripeka Angler wrote: Could you leave a space in the foam for a chase for your hoses
Just an opinion....
Richard
I think that would work great Peter. Your boat is looking very nice. Good luck with the foam....
Richard
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 8:37 pm
by peter-curacao
Richard
Thank you Angler, I hope tomorrow will be the day! of all the story's I have read here it has to be loads of fun
Re: Curacao CS 25
Posted: Sat Jul 11, 2009 9:19 pm
No, don't bury them in foam
One day you'll need to replace them. Fuel fill and vent usually leave the top of the tank and head up to the gunwale somewhere. The fill especially needs to be as straight a run as possible, so it's usually in an area that would not be foamed anyway.
Re: Curacao CS 25
Posted: Sun Jul 12, 2009 2:24 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun Jul 12, 2009 7:43 pm
by stickystuff
Looks like the elbow in the starboard bow section is going to give you a hell of a time fishing anything through it. To sharp an angle. You really need a sweep el.
Re: Curacao CS 25
Posted: Sun Jul 12, 2009 11:36 pm
by peter-curacao
stickystuff wrote:Looks like the elbow in the starboard bow section is going to give you a hell of a time fishing anything through it. To sharp an angle. You really need a sweep el.
Re: Curacao CS 25
Posted: Mon Jul 13, 2009 4:45 am
by stickystuff
What I was reffering to is the PVC Elbow in the forward pipe on starboard front of bow. Looks to be 30 deg. angle.If you run any type of hose in it you may have a stopping block. If its for wireing then vaccuum a string line through it to pull wires. Just an observance. Looks great.
Re: Curacao CS 25
Posted: Mon Jul 13, 2009 4:51 am
by stickystuff
Was reffering to PVC elbow in Forward section on Starboard side. Might have problems fishing any hoses through it due to angle. Wireing ok if you use a fish tape or string line to pull wires through. Just an observance. Looks great NIce job.If I posted this twice sorry. Couldn't remember if I sent first message.
Re: Curacao CS 25
Posted: Mon Jul 13, 2009 9:39 am
by Doc_Dyer
here
Re: Curacao CS 25
Posted: Mon Jul 13, 2009 12:15 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon Jul 13, 2009 12:43 pm
by peter-curacao
As to my experience now with putting in the trace pipes, I would recommend everybody to do it before putting in the cleats, especially when using 2"x2" cleats , it gives you more workable space and its easier to cut the cleats around the pipe before gluing them in as to drill a 3" hole through 4,5" material without special drill, just mu honest opinion
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 5:06 pm
Peter, I just posted this in another chase tube thread, wanted to make sure you see it so I'm just going to copy it here.
TomW wrote:
Also always put the cutout in the center of the wood this leaves the strongest beam.
The building notes say to cut the chase holes as high up the frames & stringers as possible.This ensures that the maximum amount of wood is against the the hull,where you want it to be. on the panga the frames are quite deep, so it may be more academic, but on the fs17 I am building the frames/stringers are shallow, so it becomes more important.
Steve
I agree with Tom. From an engineering standpoint any I Beam or joist carries the load on it's top and bottom surfaces only. One side is in compression, the other side in tension. The center of the beam has no load. If you read any building codes concerning drilling holes for conduits in floor or ceiling joists, or I Beam timbers, it says that all holes must be drilled in the center 1/3 of the beam and not exceed 1/3 the height of the joist. And building floor joists don't get the flexing that a boat stringer does!
Photos like this really worry me, Peter
Not only is the load bearing portion of the stringers cut away, but there are several cuts right across from each other
This boat will hinge/ flex at that midships point and suffer very early hull failure.
Peter, you really need to pull out those chases and rebuild the stringers. I'm serious
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 5:13 pm
by steve292
Boot the subject upstairs & ask the man.
I am not disagreeing with anyone here, but the building notes do say to go through the tops of the frames ect.
It would be good to get JM's take on this.
Steve
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 5:26 pm
by peter-curacao
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 5:53 pm
by peter-curacao
This is what my building notes says, I believe I did everything according what it says.
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 6:00 pm
by Aripeka Angler
Peter, I suggested to leave out some foam for a chase, not cut through the stringers. At the time of the suggestion, the subject of cutting into the stringers did not come up. It would appear that you did exactly what the building notes said to do though.
That is a beefy stringer, and the deck will help a bunch. It will be interesting to see Jacques says. I hope all is ok, but Larry does bring up an interesting point.
Richard
Added...The scary key word in the building notes may be (hole).
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 6:15 pm
Kick it where you want, do what you like. Please do ask Jacques. But as an almost certified marine surveyor, I'd flunk it. All 4 of those stringers are weakened in an athwartship plane. The boat will break in the middle over time. Stringers should never have a notch in the top of them, or any kind of step or change of level. Nothing but a straight line across the top, bow to stern. Sorry, please don't shoot the messenger
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 6:25 pm
by peter-curacao
Cracker Larry wrote:Kick it where you want, do what you like. Please do ask Jacques. But as an almost certified marine surveyor, I'd flunk it. All 4 of those stringers are weakened in an athwartship plane. The boat will break in the middle over time. Stringers should never have a notch in the top of them, or any kind of step or change of level. Nothing but a straight line across the top, bow to stern. Sorry, please don't shoot the messenger
I'm not blaming you anything, its just that according to the building notes in my opinion I did what it says
I cut the holes as close as possible to the sole, I will sent Jaques an email and ask him to look here. thank's for you concern
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 6:47 pm
Foam is already in
I'm sorry I didn't see this earlier, Peter. It will still be easier to cut it out now than later.
The building notes can be a little vague, but I don't think that's what he had in mind. If so, then I'm really worried
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 7:09 pm
by peter-curacao
Larry not that I will kick it my way or question your expertise or somthing , just so I will understand better, I saw this in boat repairs and those stringers are way lower than mine
http://forums.bateau2.com/viewtopic.php ... 50#p177515
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 7:50 pm
by TomW
I'm coming on this late again. I have to agree with Larry. Peter if you had made holes you would have been in pretty good shape, but you didn't. You notched your stringers and frames and this is where you went wrong. Even your Construction Notes specify holes, not notches. Some of the areas appear to have less than 3" required by the Construction Notes below the pipe and nothing above them.
I hope everything will workout okay but please check with Jacque.
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 8:19 pm
by peter-curacao
TomW wrote:I'm coming on this late again. I have to agree with Larry. Peter if you had made holes you would have been in pretty good shape, but you didn't. You notched your stringers and frames and this is where you went wrong. Even your Construction Notes specify holes, not notches. Some of the areas appear to have less than 3" required by the Construction Notes below the pipe and nothing above them.
Again I'm blaming no one for my stupidity's,but then again my notes also says
cut the openings, I respected at all places the 3" above the bottom norm, I told Jacques also it was either this or disrespecting the 3" especially at the bow outside stringer, inside stringer I could go lower but then how would that 2,5 " fill hose come in a straight line above my fuel tank?
I hope Jacques will let me get away with it (probably not) one thing is for sure to get a good sleep tonight, I need some
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 9:21 pm
Peter, again not to argue with you, but to keep you safe and help protect your investments
Just because you saw it done by a manufacturer or anybody else doesn't make it right. Many manufacturers have produced stringers with steps, as in your example here..
I won't mention brands, but time has proven that almost all of these will result in some type of hull failure, at the point of the step. Some very well known brands are very well known for it. There are a lot of bad boats out there. We're building great boats here, right
Some boat building companies don't hire engineers.
Don't sacrifice the integrity of the hull just to make it easy to run a chase tube. Re-engineer the tubes. The stringers are more important.
I'm done
Re: Curacao CS 25
Posted: Tue Jul 14, 2009 9:53 pm
by Daddy
I have to agree with Larry, the strength and usefulness of your stringers have been seriously compromised. When you glue the deck down you will gain a fraction back but not enough. Take the time to replace all of those cuts, beef up the stringers where they have been cut, sister some additional ply along the sides and bore new holes closer to the center of the stringers as small a you can get away with. A real PITA but better than the option. A beautiful boat with a serious weak point unless you correct it now. Nobody enjoys passing on this kind of news, sorry.
Daddy
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 10:40 am
Peter, I feel bad about this, I really do. If I were closer I'd come help you fix it
I've done a little research to defend my position and thoughts on this. David Pascoe is one of the most respected marine surveyors in the world. Here is one of his exerpts on stringers...
The principles of good stringer design are simple. They must run uninterrupted from one end of the hull to the other. They must be of adequate height to width ratio, i.e., structural modulus, to resist impact loading on the hull skin, be of sufficient strength to carry the engine load, be stabilized against lateral movement if high profile, and be securely attached to the hull so that they don't break loose. The profile, or top of the stringer, should run in a straight line. If there are any changes in the profile, then special design reinforcements must be added.
Dog leg in stringer which was cut down to make the engine fit.
The stringer proved to be so weak that the engine bounced every time the hull hit a wave, ultimately bending the shaft and wrecking the transmission. Also notice the hard spots created by the fuel tank mounting pads at top of photo that caused stress cracks in the hull.
These principles are often compromised by designs that utilized dog-legs, step downs, step ups (meaning an inconsistent profile along their length), perforations with large and ill-placed holes, inadequate section modulus and numerous other faults. In nearly all the cases that I have seen, there is no compelling reason why these faults should have occurred. What these design faults unfortunately suggests is that the designers really don't understand the basic engineering principles. Yet in most cases of failure that I have seen, the builder could have had his cake and eat it too by giving a little more thought to the problem. What is compromised in one way can always be built up in another. There's always an alternative solution. The builder just didn't take the time to consider it.
Reference
http://www.marinesurvey.com/surveyguide ... lPart1.htm
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 3:54 pm
I missed that.
Cracker Larry is correct: those cuts seriously weaken the stringers.
The chase tubes should go, as much as possible, through the middle of the stringer height.
You need 3", minimum 2 at the bottom and 1 or 2" plus the whole thickness of the cleats at the top.
I know that some production boats have that type of cuts in the top of the stringers but it is wrong.
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 4:13 pm
by peter-curacao
jacquesmm wrote:You need 3", minimum 2 at the bottom and 1 or 2" plus the whole thickness of the cleats at the top.
Ok but how do I got on the top of the tanks than ? with my 2,5" filling hose?
I ordered my tanks like this , and this shows only the height of the 2" cleat as available space
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 5:02 pm
by peter-curacao
Anybody some idea's how to remove the buoyancy foam as easy as possible ?
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 5:19 pm
by TomW
Peter an easy way to cut it is with an eletric carving knife. You can cut close to the wood pretty easily with one. Keep your shop vac hose right behind it as you go and you'll keep down the dust. Get under it and it will break away you will have to probably do it in layers. But at least the cutting will be easy. Once you get most of it out I have found acetone disolves most foams and as I recall got Larry out of his foam mittens.
Feel for you guy and wish I was close so I could help. Good luck
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 5:43 pm
by BassMunn
Peter sorry to hear about your mistep, I think we all have had or are going to have those, but atleast it's just a few extra days work and you're good to go. Luckily CL picked it up now rather than you finding out later.
That foam is pretty easy stuff to cut up, as TomW says an electric carving knife will sort it out. A loose hacksaw blade also cuts it up pretty easily.
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 6:00 pm
by cape man
I would NOT put acetone to it!!! Don't think it will dissolve it, but if it does, it will be very hard to control how much you dissolve, and then how in the hell would you clean off the residue? Take your time and cut it out with a blade. I used a sharp machete to even the tops of mine and it cuts easily.
I know this was not in your plans, but since you have already ordered your tanks based on a 2.5" clearance that will be hard to accomplish, what about having the fills on the console? Looking at the position of the tanks, you should be able to bring the fills up through the console?
Have seen many a boat with the fill inside the gunwales, and while it can be messy it works. Just a thought...
Feel your pain man, but it sure is easier now than later....
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 6:25 pm
Yeah, acetone will disolve it almost instantly, but obviously destroys it. It cuts easily with a handsaw though and you'll be better able to re-use it. Later you can stuff the blocks back in and pour around them.
I hesitate to reply. I've already licked all the red off your candy
and now you're asking me to pull the legs off your spiders too
Uh, have you followed Dougsters thread and his hose clearance problems?
The tank is too tall for what you have in mind. One option maybe, not a good one, but often done for the same reason as yours, is to put the fill and vent fittings on the center console itself. The downside is that splash backs and fumes end up in the cockpit, and it's against USCG and ABYC rules. But it is still often done even on production boats. They can't run the hose under the sole either on a small boat
Those rules are probably not an issue to you, but the intent of them may give you something to think about.
I'll go ahead and pull that last spider leg off now. The tank should not sit directly on the hull surface, it should have a cradle that supports it with ventillation space underneath. For many reasons, corrosion, chafing. Not sure by your drawing but it looks like it's sitting directly on the hull? If so, that's not good.
I really hate tanks below the sole for all these reasons. They are almost impossible to plumb, they are almost impossible to ventillate and they are almost impossible to keep moisture out of the compartment. They have to be shallow by nature of the space and will often fuel starve the engine. Consider a shallow tank half full and the boat is running down sea just below the crest. The fuel runs to the front of the tank and the pick up is in the rear. Add to that the lifting distance the fuel pump has to overcome. The only upside to the location is CG.
Many things to ponder. I know only a little of your islands, but I know that on a calm day the wind usually blows 30 knots and the seas are 6-8
. It's no place for a wimpy boat in any respect.
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 6:27 pm
I see Craig and I are thinking alike on the console fill
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 7:07 pm
by TomW
Peter agree with Larry on your tanks they should not be placed directly on the hull. Joel sells 4" wide 1/4" thick neopreme just for this purpose. Also check with Jacque in one of the boats he had the guy add an extra layer of fiberglass to the tank compartment 6" up all sides. Don't know if you need it with all the Fg you have though.
Larry I think your argument where the tank is, isn't quite right . The pick-up is always at the bottom of the tank and the lift is always the same whether the tank is below deck or above deck and is in fact more for an above deck tank as it has to make up for the extra heighth of the suction. The angle of fuel is going to be the same for each as long as the tank is the same size. Your right on this if the below deck tank is unusually short say 6" vs 10" deep whick is often the case in small boats.
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 7:20 pm
by peter-curacao
Cracker Larry wrote:Yeah, acetone will disolve it almost instantly, but obviously destroys it. It cuts easily with a handsaw though and you'll be better able to re-use it. Later you can stuff the blocks back in and pour around them.
I did a little test, acetone doesn't dissolve it, it doesn't do much at all
Cracker Larry wrote:Uh, have you followed Dougsters thread and his hose clearance problems?
No I didn't see that
Cracker Larry wrote:The tank is too tall for what you have in mind. One option maybe, not a good one, but often done for the same reason as yours, is to put the fill and vent fittings on the center console itself. The downside is that splash backs and fumes end up in the cockpit, and it's against USCG and ABYC rules. But it is still often done even on production boats. They can't run the hose under the sole either on a small boat
Not an option don't wane stand in those fumes, for a short time no problem but every time? no thanks! than I would probably hate my self every time I smell it and wondering WHY not did it the right way!
Cracker Larry wrote:I'll go ahead and pull that last spider leg off now. The tank should not sit directly on the hull surface, it should have a cradle that supports it with ventillation space underneath. For many reasons, corrosion, chafing. Not sure by your drawing but it looks like it's sitting directly on the hull? If so, that's not good.
It is not my drawing it came with the plans, the order I placed is for two tanks, hanging freely between the stringers completely ventilated
Cracker Larry wrote:I really hate tanks below the sole for all these reasons. They are almost impossible to plumb, they are almost impossible to ventillate and they are almost impossible to keep moisture out of the compartment. They have to be shallow by nature of the space and will often fuel starve the engine. Consider a shallow tank half full and the boat is running down sea just below the crest. The fuel runs to the front of the tank and the pick up is in the rear. Add to that the lifting distance the fuel pump has to overcome. The only upside to the location is CG.
Unfortunately I don't have much of a choice two tank's on top of the T top also looks crazy ,but I have good hope my tanks still aren't in production, called the welder and received a sms that he is still on holiday, so as soon he is back I ask hem to do some modifications
Cracker Larry wrote:Many things to ponder. I know only a little of your islands, but I know that on a calm day the wind usually blows 30 knots and the seas are 6-8
Your absolutely right about that
I really appreciate all the help and support all your guys are giving me, although sometimes it confuses me , for example"
Cracker Larry wrote:No, don't bury them in foam
jacquesmm wrote:Either with a hoe between the two tanks or in front or behind the tank, down, through the stringers then up.
I have to open the plans but I believe we show the console right over the tank fill.
In that case, you go up through the sole, over the stringer then down under the sole and through the outside stringer.
Any ideas on the tanks are more than welcome
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 7:22 pm
by peter-curacao
TomW wrote:Peter agree with Larry on your tanks they should not be placed directly on the hull. Joel sells 4" wide 1/4" thick neopreme just for this purpose. Also check with Jacque in one of the boats he had the guy add an extra layer of fiberglass to the tank compartment 6" up all sides. Don't know if you need it with all the Fg you have though.
Sorry Tom I had an internet problem didn't see your posting until I posted mine
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 7:41 pm
by peter-curacao
jacquesmm wrote:They are 2x2 but they are oversized.
1x1 would work but I like the 2x2, it makes stringer T beam and gives good glue contact area for the sole.
Make then smaller if you want, it is not very important.
jacquesmm wrote:....and 1 or 2" plus the whole thickness of the cleats at the top.
Does this mean I can cut a HOLE
directly under my cleats
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 8:06 pm
by gk108
I think that means if you have 2x2 cleats, the edge of the hole should be 1" below the bottom of the cleat.
One day, I should try building a boat with stringers and soles and gas tanks, just to see what all of the fuss is about.
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 8:12 pm
by peter-curacao
gk108 wrote:I think that means if you have 2x2 cleats, the edge of the hole should be 1" below the bottom of the cleat.
No fuss
but 1 " cleats were ok too ! so a 1" cleat plus the one inch minimum Jacques recommended, makes 2" that's the height of my cleats
that's why I put in the question
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 8:16 pm
by TomW
Peter here's the formula measure the height of the stinger or frame where you want to drill a hole. Then try to put the hole as close to the center as possible with the fudge factor leaving more to the bottom and a minimum of 2" on top and 3" on the bottom, this means you may need to move some of your conduits. You can get by with the 2" because of the I beam strength and from the strength the glued sole will also add. Make sure when you glue the sole down you add glue to the stringers and frames and not just the cleats.
Peter it is probably a little late for this but here is an article for installing aluminum tanks by the same Davd Pascoe the Larry quoted earlier for the striingers:
http://www.yachtsurvey.com/fueltank.htm
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 8:24 pm
by peter-curacao
TomW wrote:Peter it is probably a little late for this but here is an article for installing aluminum tanks by the same Davd Pascoe the Larry quoted earlier for the striingers:
No Tom it's not to late I think? but as I already told my tanks will be hanging between the stringers, and the only point they making contact with the hull is at there hanging points, six if I understood correctly
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 9:23 pm
by Aripeka Angler
Peter, I am sorry for your misfortune. If any comments that I made about not covering hoses with foam led you to cut your stringers, then my apologies. No more boat building advice will be coming from me. Signing off now...
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 10:08 pm
Excellent. I didn't realize that
Perfect.
Well, of course the pick up is always at the bottom
But in a shallow tank less than half full, all the fuel can run forward of the pick up tube. A problem in flat tanks. The angle may be the same but the portion of the tank that the fuel covers won't be.
Liquids seek their own level. That's what makes a water level work. A tank in the sole is well below the level of the outboard head, resulting in a higher lift. The closer the tank is to the level of the engine, the less fuel lift. If the tank is higher, it will gravity feed to the engine.
Re: Curacao CS 25
Posted: Wed Jul 15, 2009 11:30 pm
by TomW
Agree with you Larry had just come in from the shop and didn't take time to think it all the way through. On the small shallow tanks agreed with you to start with. I never get a tank less than 9" deep and that is marginal and I'll order dual pick-ups if I can.
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 1:03 am
by cape man
I was not suggesting the vent be in the console (or inside the boat anywhere). That line is 5/8"? Should be easy to clear the cleats and stringers, stay below the sole and then out to the sides below the gunwales. If the fill gives you any fumes inside the boat, find the missing cap and close it
. Wish I had a pic of my friend's boat. His fill is up on the foredeck and the vent is out the port side just below the sheer line.
Peter, I know you will figure this out (you probably already have!
). Your boat is going to be gorgeous and built like a tank!
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 10:50 am
by peter-curacao
Aripeka Angler wrote:Peter, I am sorry for your misfortune. If any comments that I made about not covering hoses with foam led you to cut your stringers, then my apologies. No more boat building advice will be coming from me. Signing off now...
Don't worry I ain't blaming you or anyone else,but please keep on cumming with ideas and advice it's highly appreciated
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 10:57 am
by peter-curacao
TomW wrote:You can get by with the 2" because of the I beam strength and from the strength the glued sole will also add. Make sure when you glue the sole down you add glue to the stringers and frames and not just the cleats.
So everybody agrees ? I can drill/cut the holes directly under the 2" cleat?
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 11:19 am
by TomW
Peter always do more if you can.
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 7:09 pm
by Leotis
Peter, what did your transom angle end up being?
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 7:11 pm
by peter-curacao
Figured out a way to drill those two holes in one straight line, because there is simply not enough space between the outside and inside stringers too get in with a drill I bought a cheap (didn't want to ruin my Gedore set) Socket extension and a socket 11 mm that fit the drill,I cut of the part that goes on the ratchet so it did fit in my machine.
You guys probably already figured that out, but wanted to share it anyway.
Did some repairing also, WARNING not such a pretty sight
, hope I did it right! tomorrow I will sand it further and cover it with 12 oz biax after that new cleats.
Decided if still possible to make my tanks +/-3 " shorter so I can connect the fill on the backsides the hose will still have a little lift at the end +/- the 2" from the cleats, but I think that's ok?
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 7:25 pm
by peter-curacao
Leotis wrote:Peter, what did your transom angle end up being?
Don't know
why?
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 8:22 pm
by Daddy
good job Peter, I bet you will sleep better after all this
Daddy
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 11:16 pm
by Doc_Dyer
looks good Peter,
keep the pics comming
Bradley
Re: Curacao CS 25
Posted: Thu Jul 16, 2009 11:33 pm
by Leotis
peter-curacao wrote:Leotis wrote:Peter, what did your transom angle end up being?
Don't know
why?
I mounted the transom today and it looked a little steep and I remember you were trying to figure yours out so you could have a bracket made. I just wanted a number to compare to?
Re: Curacao CS 25
Posted: Fri Jul 17, 2009 12:22 am
I'll sleep better too
. Good job, getting right at it. It shouldn't set you back more than a few days
That's a slick hole saw extension.
Transom angle should be about 15 degrees.
Quote from CL
if you go from beer to rum, and then rum to moonshine, things tend to get crooked up
Now that's an original quote
Re: Curacao CS 25
Posted: Fri Jul 17, 2009 6:42 am
by cape man
My skeg shoe is perfect!!!! And has a great story behind its installment...(sorry for the hijack but had to post this
Peter,
Very impressed! Good decision making and quick response. I like it better than my suggestion to go to the console (which was the easy way out). As Larry said you have only lost a few days...but have learned a ton from the experience. How much fuel capacity do you lose per inch of height you go down on the tanks (231 cu in/gallon)?
Looks real pretty to me!
Re: Curacao CS 25
Posted: Fri Jul 17, 2009 2:19 pm
by peter-curacao
cape man wrote:My skeg shoe is perfect!!!! And has a great story behind its installment...(sorry for the hijack but had to post this
Don't worry about any hijack's, love to hear that story
cape man wrote:Peter,
I did seriously think about it, to do it like that, but since I had a layout as in the pics in mind (don't even know if it's even possible) I let it go, because I can't let the lady's go to the toilet with a lot of fuel hoses between their legs
Don't know exactly how much fuel capacity I'm losing but since I'm making them shorter instead of lower I don't think its that much.
cape man wrote:WARNING not such a pretty sight
Maybe messy was a better word instead of pretty
Re: Curacao CS 25
Posted: Fri Jul 17, 2009 2:36 pm
by peter-curacao
Leotis wrote:peter-curacao wrote:Leotis wrote:Peter, what did your transom angle end up being?
Don't know
why?
Larry is correct I measured it today (yesterday was to late/dark) and it's exactly 15 degrees
Btw did you post pic's here on the forum from your build?
Re: Curacao CS 25
Posted: Fri Jul 17, 2009 5:04 pm
by stickystuff
WOW! I can't believe I overlooked that. The elbow thing hit me right off the top. saw the cuts on the stringer tops but didn't hit me.You could double up and epoxy a butt splice on each side of the stringers. Make each splice approx. 24" long and you should be ok. I wouldn't tear the whole thing out. Just my opinion. It should be OK doing this.
Re: Curacao CS 25
Posted: Fri Jul 17, 2009 6:48 pm
by cape man
Take Larry and me fishing and you can hear it from both sides...
Actually was one of the most memorable nights I have spent in years. Nothing like some ethanol to get the tongues wagging...
Re: Curacao CS 25
Posted: Fri Jul 17, 2009 6:58 pm
by peter-curacao
cape man wrote:Take Larry and me fishing and you can hear it from both sides...
You've got yourself a deal, but I ain't gonna pick you guys up, that would only give me more tank troubles
1189 miles jeez that's a lot of gas to store.
Re: Curacao CS 25
Posted: Sat Jul 18, 2009 8:40 pm
by peter-curacao
Such a coool CC !!!
especially the T Top supports just my opinion, what do you guys think?
Re: Curacao CS 25
Posted: Sun Jul 19, 2009 11:02 am
by TomW
Where's the turbo boost and the wings.
Re: Curacao CS 25
Posted: Sun Jul 19, 2009 5:58 pm
by Jaap
The T top support looks functional, so for me, ok. The console is very much overdesigned, an awfull crappy mistake.... that is, again, for me. Luckily we have a lot of different tastes and opinions, and thus with some good wine, beer and fish on the grill a lot to talk about
jaap
Re: Curacao CS 25
Posted: Sun Jul 19, 2009 6:38 pm
by JIM M
Looks cool,
My first thought was cap'n Kirk saying ''Scotty I need more power''
Jim
Re: Curacao CS 25
Posted: Sun Jul 19, 2009 7:09 pm
by peter-curacao
Jaap wrote: The console is very much overdesigned, an awfull crappy mistake.... that is, again, for me.
Hey it's a cigarette what did you expect, some basic stuff?
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 3:21 am
by Jaap
Oh oh Peter, we're talking about boats here, not strip comic space ships.
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 11:11 am
by peter-curacao
Jaap wrote:Oh oh Peter, we're talking about boats here, not strip comic space ships.
We do have caves here !
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 12:24 pm
by tech_support
I went on that cigarette center console at the Miami boat show last year. Completely impracticable for real fishing, but I dont think the boat was really intended for serious fishermen. One shaking gaffed dolphin and there would be $10k of ruined upholstery and leather.
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 12:31 pm
by peter-curacao
What I like is the 3 support posts for the T Top and only two in front of you, not a lot of tube's in front of you something different.
Joel do you think when you can afford a boat like that , you will care about some ruined upholstery?
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 12:47 pm
by tech_support
I would have one boat for fishing and one boat for chasing tail. (If I had the money and were single)
I like the top also, if I build a larger center console I will do something similar from Carbon fiber.
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 4:09 pm
by peter-curacao
Not that it matter anymore, but now I'm completely confused.
shine wrote:thats how the stringer sin the PH15 work. Use 2 layers of 3/8" plywood epoxied together.Your stringers will just be the height of the casting decks, then a lower cut out where the sole is located. The casting decks and sole will be epoxied down to the tops of the stringer. Its very strong this way.
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 4:46 pm
So am I Peter.
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 4:52 pm
by peter-curacao
here an other quote
shine wrote:stringer would look like a frame, not level on the top.
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 4:55 pm
by D2Maine
nm
Re: Curacao CS 25
Posted: Mon Jul 20, 2009 5:48 pm
by Leotis
quote="Leotis"]Peter, what did your transom angle end up being?[/quote]Don't know
why?[/quote]
I mounted the transom today and it looked a little steep and I remember you were trying to figure yours out so you could have a bracket made. I just wanted a number to compare to?[/quote]Larry is correct I measured it today (yesterday was to late/dark) and it's exactly 15 degrees
Btw did you post pic's here on the forum from your build?[/quote]
Peter thanks and no pics yet, i've got this Camera problem, I can't find my cord to unload them on to my computer and it seems to be an odd size.
Re: Curacao CS 25
Posted: Sun Aug 09, 2009 7:06 am
by cape man
Peter,
Where you at? Need pictures of that boat you're building for my Curacao vacation! Want to make sure it's seaworthy.
Re: Curacao CS 25
Posted: Mon Aug 10, 2009 5:09 pm
by peter-curacao
pompomtiedom
for my fueltanks.
Re: Curacao CS 25
Posted: Mon Aug 10, 2009 7:46 pm
by cape man
Good. Don't want to have a fuel problem while I'm reeling in that wahoo.
Re: Curacao CS 25
Posted: Mon Aug 10, 2009 9:24 pm
by peter-curacao
cape man wrote:Good. Don't want to have a fuel problem while I'm reeling in that wahoo.
Are you really going to visit "my" Island?
Re: Curacao CS 25
Posted: Tue Aug 18, 2009 10:05 pm
by peter-curacao
Trying to build you a chair for reeling that Wahoo in
Re: Curacao CS 25
Posted: Tue Aug 18, 2009 10:24 pm
by Bowmovement
peter-curacao wrote:cape man wrote:Good. Don't want to have a fuel problem while I'm reeling in that wahoo.
Cape, sounds like your going to be finishing in style
Your own chair and everything. Nice
Re: Curacao CS 25
Posted: Tue Aug 18, 2009 10:43 pm
by cape man
Cape, sounds like your going to be finishing in style Your own chair and everything. Nice
Finishing or fishing? I'm not ready to be finishing yet, but always ready to fish!
Peter, the ABC's have been on my list for many many years (my roomate in college and best man was Dutch and he had been there a couple times. He talked about them with a lot of fond memories.)."Your" Island seems the most appealing of the three. Don't know if I'll ever make it, but if so I will definetely look you up and sit in the chair. On a recent trip to the UK I made a very nice detour and had a wonderful evening drinking a few cold ones while leaning up against the sides of an FS17 being built there. If Steve had been nicer he would have finshed that boat before I came over and taken me fishing...
Re: Curacao CS 25
Posted: Wed Aug 19, 2009 7:18 am
by steve292
You come again & I'll take you fishing boat or no boat.........................
Steve
Re: Curacao CS 25
Posted: Thu Aug 20, 2009 9:12 am
by Doc_Dyer
Peter............
Pics please..
Bradley
Re: Curacao CS 25
Posted: Thu Aug 20, 2009 1:58 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Aug 20, 2009 2:42 pm
by ks8
I don't feel like I'm so bad with getting caught up in details after all.
Nice...
Can we see them in position in the boat too?
Re: Curacao CS 25
Posted: Thu Aug 20, 2009 2:49 pm
by flatpicker
WoW! That looks really good!
Re: Curacao CS 25
Posted: Thu Aug 20, 2009 4:45 pm
by TomW
Geourgeous Peter. Now how about the rest of the boat.
Re: Curacao CS 25
Posted: Thu Aug 20, 2009 6:13 pm
by cape man
Can I adjust that up and down while fighting the wahoo? Very nice!
Re: Curacao CS 25
Posted: Sat Aug 22, 2009 8:12 pm
by peter-curacao
Thank's for the compliment's
@ KS8 When finishes I will take a pic in position in the boat
@ Tom This is the rest of the boat
@ Cape Man You can adjust it but if you can do it while fighting Wahoo, I don't think so
Today I got a step closer and now I'm actually thinking this is gonna work out, still not 100% sure but a lot more confident when started this side project while waiting for my fuel tanks.
One thing I'm sure of is that the oval profile looks a lot better as the square profile, a lot less static,also bended them a little for comfort (verticals) and to flow nice with the rocket launcher (horizontals)
Here some more pic's
Re: Curacao CS 25
Posted: Sat Aug 22, 2009 8:58 pm
by cape man
I like!!! Don't want to sit in no ugly chair! That will be beautiful. Are you putting a backing plate below the sole for that?
Re: Curacao CS 25
Posted: Sat Aug 22, 2009 10:42 pm
Re: Curacao CS 25
Posted: Sun Aug 23, 2009 4:38 pm
by BassMunn
Peter that's a wicked looking chair. If you carry on at this rate we might all have to come over to test it out
Re: Curacao CS 25
Posted: Sun Aug 23, 2009 6:25 pm
by a_Adel
Great work Peter
I've come across your thread a lil late "of course I had the pleasure to go thru 40+ pages of progress at once
Like your progress, level of details "specially on those twin marlins
", very nice looking fighting chair, can not wait to see it finished, along with the rest of the interior design/detail, I bet we would expect something different
I was interested on your intention about making a swim/fish door, read its thread too, have you decided what you gonna do about it? also about the fuel tanks? have not you considered making them? I see you did a good job with the water tank? or is there a huge difference in the making of the two types of tanks?"excuse me if it was too noob of a question
Re: Curacao CS 25
Posted: Mon Aug 24, 2009 5:15 pm
by Murry
Wow!! Peter.
Very nice.
Re: Curacao CS 25
Posted: Mon Aug 24, 2009 6:13 pm
by AD16 The Opportunist
Re: Curacao CS 25
Posted: Mon Aug 24, 2009 9:12 pm
by peter-curacao
Thanks you all
@BassMunn: You and others are more than welcome to come over and test it out.
@a_Adel : Glad I could provide you with some reading pleasure
, Indeed I try to do something different but if it's gonna work out I'll have to see , its a matter of trial and error I think
For the side swimdoor I have one last idea (it involves a aluminum or stainless frame between the gunwales) :idea:I have to ask Jacques before I glue the sole in, but I'm a little reserved about that, because I don't wanna drive him crazy with an other question and my obsession of a swim door
I did consider making the (aluminum)fuel tanks myself but once in a while you have to know your limits, those things are to important if not dangerous to screw up, that's why I decided to leave those to the professionals, the watertank on the other hand is a different story that's just a wooden box with some glass and resin, thank's for reminding me still have to close that thing up
Re: Curacao CS 25
Posted: Wed Aug 26, 2009 6:16 am
by a_Adel
Wise decision i guess regarding the fuel tank,
Good luck with the swim door, can not wait to see ur final decision and how u gonna execute it, I am planning to build the cx25 "hopefully soon", just when i feel i absorbed enough experience"and ideas", from such a great forum, full of knowledgeable builders, and the swim/fish door is one thing i would REALLY love to see in my future boat, i would be real upset losing "THAT" fish, just cuz i couldn't get it in
waiting for ur updates and pics
Re: Curacao CS 25
Posted: Sat Sep 05, 2009 7:21 pm
by peter-curacao
Well last week they came and dry fitted my tanks, decided were the fill etc. needed to come so hopefully they are finished next week. Today I finished my chair it's in Technicolor now
I know some of you will like it maybe even love it, but I also know there will be some who doesn't or maybe even hate the result, especially that I make the rocket launcher partially white (no wood color) just thought it went better like this with the blue, also the Penn decals won't be appreciated by everybody, I also had to give those things long thought's but finally decided to do it and I'm happy with the result, I know it's not a Pompanette or a Penn chair so lets call it a Peternette
Here it is!
Everything ready to bolt on
backrest supports still needs aluminum tops to close the pipe (I did order them, also a white cushion with hook and loop straps )
Side still need gimbels so I can put rods in the armrests
Center under gimbel
Re: Curacao CS 25
Posted: Sat Sep 05, 2009 7:45 pm
by topwater
Peter the chair looks awsome...
Now all you have to do is build the boat around the chair.
Re: Curacao CS 25
Posted: Sat Sep 05, 2009 9:27 pm
Beautiful job Peter
I love it
International fighting chairs are built here in Savannah. They start about 3K US, but the average price is about $15K-20K per chair
. They ain't got nothing on you
That's some fine work!
Re: Curacao CS 25
Posted: Sat Sep 05, 2009 9:33 pm
by ks8
Cup holders....
Beautiful!
Re: Curacao CS 25
Posted: Sat Sep 05, 2009 11:14 pm
by cape man
Thanks. That will be comfortable.
And I will look good in it!
Very sweet, and a nice custom touch.
Re: Curacao CS 25
Posted: Sun Sep 06, 2009 12:20 am
by Spokaloo
That turned out gorgeous.
NOW GET THE BOAT DONE!
E
Re: Curacao CS 25
Posted: Sun Sep 06, 2009 1:20 am
by Fonda@kauai
I love it
Re: Curacao CS 25
Posted: Sun Sep 06, 2009 7:06 am
by a_Adel
i know i said is before
i just love ur attention to details!,. specially the rocket launcher's board,. great combination, paint & Wood
i can't think of myself coming close to half of that neat, sharp looking masking, is not that masking?
Re: Curacao CS 25
Posted: Mon Sep 07, 2009 10:10 pm
by peter-curacao
Doc_Dyer wrote:Peter............Pics please..
TomW wrote:Geourgeous Peter. Now how about the rest of the boat.
topwater wrote:Now all you have to do is build the boat around the chair.
Spokaloo wrote:NOW GET THE BOAT DONE!
Guys please I really want to continue, I just have to have some more patience!
Re: Curacao CS 25
Posted: Mon Sep 07, 2009 10:31 pm
by ks8
Hugh Laurie is not always so
thoughtful while *
waiting*....
Re: Curacao CS 25
Posted: Tue Sep 08, 2009 5:34 pm
by peter-curacao
Re: Curacao CS 25
Posted: Tue Sep 08, 2009 6:12 pm
by cape man
Get rid of the two chair idea and install a nice leaning post/bench seat instead. Will save all the room you need. DO NOT get rid of the fighting chair!!!! Make the console smaller than you first thought, scrap even a leaning post and stand up while driving, make your guest lie on the deck. DO NOT get rid of the fighting chair!!!!! Install tiller steering and drive from the fighting chair. DO NOT get rid of the fighting chair.!!!!!!
On the other side of things you can build two bucket seats that will have a lot smaller horizontal space consumption than the chairs you have there.
Re: Curacao CS 25
Posted: Tue Sep 08, 2009 8:00 pm
by gk108
I've seen a thing that looks sort of like a leaning post/compact seat that might work, too.Height was adjustable, so you could lean on it, or lower it a bit and sit down. The backrest wasn't really much, more like a little cushion to keep you from sliding off, but no support.
Search Todd part# 2200-35 for an idea of what I'm talking about. 37 1/2''W x 11''H x 15 3/4''D (with adjustable pedestals, 16''-32''H), much smaller footprint than the lawn chairs.
Re: Curacao CS 25
Posted: Tue Sep 08, 2009 9:33 pm
by daydrmr999
I have a better idea, stick with the two seats, and send me the fighting chair, I don't have much room on my Trojan rebuild, but I can live without captain and co pilot chairs, LOL
Mike
Re: Curacao CS 25
Posted: Wed Sep 09, 2009 10:03 am
by tech_support
I did not think of this until now, but how do you fight a fish from the chair with outboards
unless there is a trick I dont know (very likely) your going to have to get out of the chair and fight stand up when the fish gets close in. With an inboard, the chair position is design so it can be moved around and the rod tip always clears the sides so the line does not touch the boat. With outboards on a bracket Im not sure how thats going to work.
I have seen fighting chairs on the bows of big center console boats with outboards. The rod tip clears the sides up there.
Re: Curacao CS 25
Posted: Wed Sep 09, 2009 11:29 am
by Dog Fish
Maybe "stand-up" for fishing and chair for "haircuts".
Good work Peter
Brian
Re: Curacao CS 25
Posted: Wed Sep 09, 2009 4:02 pm
by ddbiiz
Peter,
I love your work!!!! If you switched to the CX model that would be alot more deck space, nothing worse than a cramped cockpit area. Not the same but. I added fish boxes,cooler, & baitwell in the back of my OD18, by the time I was done with console & seats IT'S TIGHT. I've never been happy with the layout just my 2cents
Don
Re: Curacao CS 25
Posted: Thu Sep 10, 2009 5:10 pm
by Leotis
Peter, I have seen boats where the fighting chair serves as the captains chair and fighting chair, it looks really cool and keeps the cockpit open. I will try and find the picture.
Re: Curacao CS 25
Posted: Sat Sep 12, 2009 7:45 pm
The helmsman maneuvers the boat to always keep the fish positioned off a stern quarter or side. No matter how the fish runs, you spin the boat to keep it where you want it. I like to turn a slow circle, keeping the fish inside of the turn and about a 45 degree angle off the side.
That would make it very difficult for the Capt. to maneuver the boat while the rod man fights a marlin
Re: Curacao CS 25
Posted: Sat Sep 12, 2009 11:16 pm
by Leotis
Cracker Larry wrote:I did not think of this until now, but how do you fight a fish from the chair with outboards
Well the Chair sits on a gooseneck so when it swivels back(towards the stern) it swivels away from the HELM!!
This allows room for someone to drive (standing) which they should be if there is a fish on.
The foot pedastals and rod holder on the chair are removable and on the one I saw the rod holders on the back where peter has his awesome woodwork was more of a box and it flipped up two serve as a leaning post. (if there was not a fish on). When you grow up on the water fighting fish larger than you most of your life you tend to see alot of things, things that only people with creative minds can think of.
This is a boat building website so anything is achievable...
Re: Curacao CS 25
Posted: Sun Sep 13, 2009 10:30 am
Even if not necessarily practical
If I was the Capt., and it was my boat, we ain't going to be re-arranging my seat, and I got to stand up, every time we hook a fish
If that's OK with you on your boat, it's OK with me, but it's not happening on my boat
Re: Curacao CS 25
Posted: Sun Sep 13, 2009 7:57 pm
by Dog Fish
Happy Birthday Peter
Re: Curacao CS 25
Posted: Sun Sep 13, 2009 8:08 pm
by Bowmovement
Re: Curacao CS 25
Posted: Wed Sep 16, 2009 10:23 pm
by ThistleDewDayDreamin
Happy B-Lated Birthday Peter. That Chair
What do you charge to import them to the US
I bet you could find a market. It's been a few days since the lawn chair / water tank / fighting chair mock up pictures. Have you found a solution? I like the idea of building your own buckets ( smaller versions of the ones in your cigarette boat top photo ?) I bet your clever enough to pull off the upholstry too aren't you. I could see embroidered twin Marlins. Just wondering what you decided, I watch your build closely, It's inspirational.
- ThistleDew ( Please note the limited, well limited for me, use of smilies
Re: Curacao CS 25
Posted: Wed Sep 16, 2009 10:58 pm
by peter-curacao
ThistleDewDayDreamin wrote:Happy B-Lated Birthday Peter. That Chair
Once in a while a man has to think think and think but also , drink and drink! did I mention drink? (especially on its birthday) Ahhh it's good please give me some time I promise you and everybody soon an update with my decisions ! can I ask you this Whistle ? are you FBI? CIA? maybe Scotland yard :doh:Seems like you know all my next movements
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 8:51 am
can I ask you this Whistle ? (
You mean Thistle ) are you FBI? CIA? maybe Scotland yard :doh:Seems like you know all my next movements
No Law Enforcement Ties WHAT-SO-EVER
( Pirate ! ). Just,. I think,.like minded, and Curious, and Nosey
I admire your talent that's all.
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 12:05 pm
Peter, You On Line? 12:05 PM Sept 17, 2009 ?
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 12:07 pm
Please Send me an email address. To edited out for privacy
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 12:14 pm
by peter-curacao
ThistleDewDayDreamin wrote:Please Send me an email address. To" edited out for piracy
Just sent you a mail
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 12:23 pm
Thanks, just sent you one back. Please edit out my personal email address from your reply post. Don't need the whole world to have it.
Thanks.
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 6:19 pm
by peter-curacao
I know this will probably the most stupid question I ever asked here (don't worry more to come
) , but I'm gonna do it anyway! hold tide to your chair here it come's: is it possible to power my CS under sail? (emergency only)
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 6:26 pm
No It's not a stupid question. Just put a really, really, really big hard top on it
Sooner or later it'll blow hard enough to make it into a sail and push you toward land somewhere ! See my thread on hard tops for the FS17, there's all kinds of advice there
Just kidding, that is a really good question. You certainly can't paddle a CS25 ! But maybe Better to invest in good radios ( 2 ) or a satellite phone? It'll be interesting to see what the gang has to say.
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 6:37 pm
by TomW
Ferget it Peter it maybe possible but with the 17 degree angle at the transom and the higher angle at the cutwater you will need a lot of sail to do anything other than go straight down wind. What the heck you trying to do guy your building a fishing a boat not a sailing boat.
If you want to add sails build a displacement hull.
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 6:48 pm
by peter-curacao
TomW wrote:Ferget it Peter it maybe possible but with the 17 degree angle at the transom and the higher angle at the cutwater you will need a lot of sail to do anything other than go straight down wind. What the heck you trying to do guy your building a fishing a boat not a sailing boat.
I know I know! told you it was my most stupid question ever
just was browsing trough my fishing trip pics and saw those local boats again ( You remember that threat I put up?) they all have sails as backup but then again they are all displacement hulls indeed. Also remembered me about the sailing trips with my granddad, it was always a magic moment when that engine shuts off and the boat went further under sail ! almost a peaceful moment if I can describe
it like that?
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 7:08 pm
by TomW
Re: Curacao CS 25
Posted: Thu Sep 17, 2009 7:10 pm
You ain't likely to go to windward, but you could rig up something that would put you in Venezuela in about 2 days.
If you end up over there, see if you can find my hat
Love the green rum Peter. I think your sanding bits are going to last longer though. Mrs. Cracker says thanks too. It's weird to drink blue and taste orange
Re: Curacao CS 25
Posted: Fri Sep 18, 2009 11:10 am
by peter-curacao
Cracker Larry wrote:Love the green rum Peter. I think your sanding bits are going to last longer though. Mrs. Cracker says thanks too. It's weird to drink blue and taste orange
Glad you and the Mrs like it, maybe she can mix it with orange juice or try some of the following ?
My signature never made more sense as under this posting
Arcturian Sunrise recipe
1/3 oz Blue Curacao liqueur
1/3 oz blackberry liqueur
1/6 oz grenadine syrup
5 oz sparkling white wine
Pour blue curacao, blackberry liqueur and grenadine into a highball glass filled with ice cubes. Add sparkling white wine, stir well, and serve.
13% (26 proof)
Serve in: Highball Glass
Bitter Hitter recipe
2 oz Cointreau® orange liqueur
4 oz ice cold water
1 large orange
1 large grapefruit
1 tamarillo
Place all the fruits in a blender and puree, add blue curacao and Cointreau then pulse until combined. Add water and ice and pulse until combined. Serve in tall glass with rim dipped in sugar and lemon juice and a slice of orange on side.
Serve in: Collins Glass
Bloody Smurf Jizz recipe
3/4 oz Blue Curacao liqueur
3/4 oz grenadine syrup
1 tsp Bailey's® Irish cream
Sprite® soda to taste
Chill the grenadine. Pour the blue curacao into a champagne flute. Add the sprite to taste. Slowly pour the grenadine into the glass in order for it to sink. Add the Bailey's irish cream with a teaspoon slowly in the glass to allow it to float, and serve.
Serve in: Champagne Flute
Blue Bay recipe
1 part Blue Curacao liqueur
2 parts bitter lemon soda
ice cubes
Mix in a highball glass. Stir. Garnish with a slice of lemon.
9% (18 proof)
Blue Sapphire recipe
1 oz Blue Curacao liqueur
5 - 7 oz cranberry juice
Pour both ingredients into a collins glass filled with ice cubes. Stir and serve.
4% (8 proof)
Blue Sky recipe
6 oz milk
Pour both ingredients into a cocktail shaker half-filled with ice cubes. Shake well, strain into a highball glass almost filled with ice cubes, and serve.
4% (8 proof)
Bluetail Fly recipe
1 1/2 oz Blue Curacao liqueur
1 tbsp white creme de cacao
1 tbsp light cream
Pour the blue curacao, white creme de cacao and cream into a cocktail shaker half-filled with cracked ice. Shake well, strain into a chilled cocktail glass, and serve.
22% (44 proof)
Serve in: Cocktail Glass
Brian Fabulous recipe
1 part pineapple juice
1 part Midori® melon liqueur
Mix ingredients and serve over ice.
Serve in: Old-Fashioned Glass
Chameleon recipe
1/2 glass orange juice
fill with 7-Up® soda
Combine all ingredients over ice.
Cyclone Attack recipe
2 oz lemon juice
Layer both ingredients in a cocktail glass, and serve.
15% (30 proof)
Dark Lagoon recipe
1 oz grenadine syrup
pineapple wine
Pour the blue curacao and grenadine into a highball glass. Fill with pineapple-flavored wine, to taste, and stir. Garnish with a slice of pineapple.
Dolphin's Foam recipe
50 ml pina colada mix
50 ml Blue Curacao liqueur
Shake vigorously in a shaker with lots of ice. Strain into a glass, garnish with a red cherry, and serve.
15% (30 proof)
Erin's Sweater recipe
3 parts Blue Curacao liqueur
2 parts white chocolate liqueur
Shake and serve over ice cubes in a champagne saucer.
Serve in: Champagne Saucer
Fruit Loop recipe
fill with milk
ice cubes
Fill highball glass with ice. Pour curacao over ice then fill with milk.
7% (14 proof)
Fruit Tingle recipe
30 ml Blue Curacao liqueur
30 ml raspberry cordial
lemonade
ice
Pour curacao over ice in a tumbler. Add raspberry cordial and lemonade at the same time so that the combined effect mixes the drink. Tastes like the lollies called Fruit Tingles.
Ginger Swing recipe
1 1/2 oz Bols® Blue Curacao liqueur
fill with ginger ale
Pour curacao over ice in a highball glass, then fill the rest of the way up with ginger ale.
4% (8 proof)
Green Widow recipe
2 parts Blue Curacao liqueur
3 parts orange juice
Pour blue curacao into a cocktail glass. Pour the orange juice over it. Stir and serve cold.
12% (24 proof)
Irish Griep recipe
2 1/2 oz sweet and sour mix
cola
ice
Fill an old-fashioned glass with ice. Add blue curacao and sour mix. Top off with cola. Stir until a greenish/blue mixture is obtained.
Jedi Cocktail recipe
1/3 oz creme de cacao
2 1/2 oz milk
Pour the milk over a single ice cube in a cocktail glass. Add blue curacao and creme de cacao simultaneously. Stir briefly, and serve.
9% (18 proof)
Kristi GreenEye recipe
1/2 oz Midori® melon liqueur
1/2 oz Cointreau® orange liqueur
2 oz pineapple juice
ice cubes
Place all ingredients in a shaker and shake well. Pour over ice in an old-fashioned glass.
13% (26 proof)
Midnight Liaison recipe
1 oz Parfait Amour® orange liqueur
4 oz lemonade
1 dash grenadine syrup
Pour the blue curacao, parfait amour and lastly the lemonade into a highball glass filled with ice cubes. Drop in the grenadine at the side of the glass so that it sinks to the bottom, and serve.
9% (18 proof)
Nickel Fever recipe
2/3 oz Southern Comfort® peach liqueur
2/3 oz Galliano® herbal liqueur
1 1/3 oz cream
1 1/3 oz orange juice
Pour the blue curacao, Southern Comfort, galliano, cream and orange juice into a mixing glass half-filled with cracked ice. Stir well. Strain into a champagne saucer. Garnish with ice chips and 8-10 drops of blue curacao, and serve.
13% (26 proof)
Purple VW recipe
1 part grenadine syrup
Fill two-thirds of a shot glass with blue curacao. Fill completely with grenadine, stir, and serve. Drink slowly.
19% (38 proof)
Serve in: Shot Glass
Sex in the Shower recipe
1 oz triple sec
1 oz butterscotch schnapps
2 oz orange juice
fill with ice
Shake with ice and strain into Champagne Flute.
15% (30 proof)
Stars and Stripes recipe
2/3 oz grenadine syrup
2/3 oz double cream
2/3 oz Blue Curacao liqueur
Make pousse-cafe (layered) in a cordial or liqueur glass, and serve.
9% (18 proof)
Serve in: Cordial Glass
Re: Curacao CS 25
Posted: Fri Sep 18, 2009 11:20 am
I think we're going to need another shipment
Re: Curacao CS 25
Posted: Fri Sep 18, 2009 1:56 pm
by cape man
Me too, me too.
Re: Curacao CS 25
Posted: Fri Sep 18, 2009 8:16 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Sep 19, 2009 1:38 pm
Yep, that's an ugly dog
But the tanks sure look nice
Re: Curacao CS 25
Posted: Sat Sep 19, 2009 2:47 pm
by Bowmovement
Tanks look good!
I love English Bulldogs!! It will be my next dog. Been doing alot of research on them. Found some breeders overseas that have excellent bloodlines. They also guarantee the health problems that are common with the breed. They are damn proud of thier pups for sure. $$$$$$$$ Hopefully I wont need to be looking for a new pup for quite a while. Got a good dog now.
Thats Dixie
Matt
Re: Curacao CS 25
Posted: Sat Sep 19, 2009 2:48 pm
by Bowmovement
Oh, and I kinda like Rambo as his name. Rough and Tough.
Matt
Re: Curacao CS 25
Posted: Sat Sep 19, 2009 8:35 pm
by cape man
what Larry said. Nice tanks.
Re: Curacao CS 25
Posted: Sun Sep 20, 2009 6:47 am
Oh, jeeze, darn it all, the tanks arrived.
Now we'll have to wait to see those custom bucket seats with the embroidered, hand crafted "curacao-ian" ( how would you correctly say that?, "Curacian?, Curacan?
) leather being put together.
The tanks do look good though, can't wait to see/hear how they go in. Have fun, I know you've been waiting a while for these.
Re: Curacao CS 25
Posted: Sun Sep 20, 2009 8:36 am
by Murry
I'm excited for you Peter.
Looking forward to seeing them permanently mounted in that boat.
Daniel
Re: Curacao CS 25
Posted: Mon Sep 21, 2009 9:41 am
by tech_support
I have an English bulldog. Very sweet dog, but she is very expensive. She has an allergic skin condition that requires special food and medication or she would die - its severe. She did not develop it unit 6 years old. here is "Belle". Not the smartest dog, but she is great with our 1 year old daughter
Re: Curacao CS 25
Posted: Mon Sep 21, 2009 4:57 pm
by peter-curacao
@ Bowmovement and Shine
Indeed they are very nice dogs but as Shine said not the easiest breed to choose, I had two English bull brothers before and they died way to young that was a pretty devastating experience,and they came from overseas, this one comes from the States (for me also overseas
) I believe the US also have excellent breeders and that all is also a matter of some luck.
Here a fun movie of the English Bull if you guys doesn't already seen it
http://www.youtube.com/watch?v=CQzUsTFqtW0&NR=1
Re: Curacao CS 25
Posted: Mon Sep 21, 2009 10:03 pm
by Bowmovement
peter-curacao wrote:@ Bowmovement and Shine
I have seen that video. That dog was actually on a reality TV show with his owner. Dont remember the name. The show had different people and thier dogs. They had to train the dogs to do different tricks or what not each week.
Matt
Re: Curacao CS 25
Posted: Mon Sep 21, 2009 10:11 pm
by peter-curacao
Matt
I'm gonna train mine boatbuilding first! after that fishing on that same boat, after that cooking the fish catched on that boat, after that serve it to me
and I don't even want a place in that show
but first let me train him where to shit and where not!
Re: Curacao CS 25
Posted: Mon Sep 21, 2009 10:46 pm
You should have got a Golden if you wanted all that out of a dog
Re: Curacao CS 25
Posted: Tue Sep 22, 2009 9:40 am
by Bowmovement
Matt
That would be very impressive. Especially with out thumbs.
Re: Curacao CS 25
Posted: Sat Sep 26, 2009 5:56 pm
Hey Peter, Any progress on mounting those fuel tanks
We need pictures
Hope all is well with you.
Re: Curacao CS 25
Posted: Sun Sep 27, 2009 2:30 pm
by Spokaloo
Sounds like Joel's dog has epoxy hardener sensitivity!
E
Re: Curacao CS 25
Posted: Mon Sep 28, 2009 3:31 pm
OK Peter, Which is it this time, Blue Rum or Football games? I'm waiting to see more pics
Did you finish installing those tanks? How about the customer leather upholstered marlin embroidered bucket seats, got those ready to install yet?
You and CL seem to have gone missing from the forum at the same time
You guys aren't off at some secret fishin hole are ya.
Re: Curacao CS 25
Posted: Tue Sep 29, 2009 4:06 pm
by peter-curacao
ThistleDewDayDreamin wrote:OK Peter, Which is it this time, Blue Rum or Football games? I'm waiting to see more pics
I wish that was true about the fishing
, unfortunately the tanks are still in the front lawn
this because I didn't do anything on the boat, while playing with the dogs I sprained my ankle on a hole in the lawn and when that happen it also shoot in my back again
(I know shoot in my back???
don't know the medical term )Hope to provide you with some boatporn again soon
Re: Curacao CS 25
Posted: Tue Sep 29, 2009 4:15 pm
Sorry to hear about the accident with the dogs
I think we all know what you mean by "shoot in the back" bad pain, sore for days or weeks, but ahh there's medicine in that rum bottle. That, a lot of hot baths and ice packs. I hope you are feeling better soon. Until then, I recommend Rum & TV.
Re: Curacao CS 25
Posted: Mon Oct 05, 2009 8:54 am
Peter, how is the recovery coming? Hope that hole in the yard didn't seriously damage you
Any progress on the tanks
Re: Curacao CS 25
Posted: Mon Oct 05, 2009 11:47 am
by TomW
Peter hope the back recovers soon. I have had back problems before and it can take a while sometimes.
Re: Curacao CS 25
Posted: Sun Oct 11, 2009 9:39 pm
Gee Whiz Peter, how bad did the dogs and that hole in the yard mess you up man? See you've been posting here and there lately, but no progress on the CS 25? Let us know OK? Hope all is well.
Re: Curacao CS 25
Posted: Mon Oct 12, 2009 7:48 am
by peter-curacao
Thanks for the concern's, as Tom says it sometimes can take a while and I think that's the case this time, because it isn't the first time I have this problem, earlier in my build I tried to remove the bulkhead with the 3 hatches (it was stuck),got it bad that time and took to less time to recover, but it's going a bit better already. again thanks
Re: Curacao CS 25
Posted: Mon Oct 12, 2009 9:25 am
by a_Adel
I really hope you are getting better soon Peter
There are lots of of wonderful builds around here, the one I am interested in/following the most is yours, for so many reasons
please keep us updated on how r u doing
regards, A.Adel
Re: Curacao CS 25
Posted: Mon Oct 12, 2009 4:23 pm
Ditto, feel better soon, but don't go back at it sooner than you should. Hope to see you up and back at it as soon as it's safe for your back. Best regards ThistleDew.
Re: Curacao CS 25
Posted: Tue Oct 13, 2009 6:23 pm
by peter-curacao
Again thanks for the concerns, ThistleDew am I correct or didn't I see anymore update's from your boatbuildingbuilding?
Is it finished, did you already make a boat model choice if so did you started? or did I missed something?
Re: Curacao CS 25
Posted: Tue Oct 13, 2009 8:26 pm
by cape man
Re: Curacao CS 25
Posted: Tue Oct 13, 2009 8:38 pm
by peter-curacao
cape man wrote:OUCH!!!
Burn.
Now i see you're reaction yes you are right! but I didn't mean it that way sorry
Re: Curacao CS 25
Posted: Wed Oct 14, 2009 9:10 pm
Well, guys, ya see it's like this
Taxes
Son's Spring Semester tuition ( Wake Forest )
Insurances all due
Son's Birthday ( 21st ) ( hopefully no bail required )
Short Beach Trip, a little time away to Myrtle with the wife ( her company paid most of that bill )
looked at some production boats, just cause they were there. more on that later.
It's been awefull rainy and cold here.
So mostly I've been spending money on taxes and tuition,
I do work some, have to pay for this stuff somehow, but it's been so miserable outside,...
We do a lot of this.
I have been building the boat building building, but building is slow. A lot of little unexciting pieces going into the framing for soffit and facia. Getting ready for the big $$ roofing project soon. I'll update that thread this evening unless the fire makes me too sleepy. It's a hard life,.
if I could spend as much money as I wanted as soon as I wanted, I'd be building that Abaco 23 by now. But, I can't, so I don't and I'll wait, and it'll all get done, when it's time. Freezer is full, wood is in, the rest is just gravy.
Geeze I'm sleepy.
Re: Curacao CS 25
Posted: Wed Oct 14, 2009 9:33 pm
by peter-curacao
Hey congrats with your son's 21 birthday! let him try this
walk over water to get alcohol if you're 21
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 10:01 am
by peter-curacao
Not that I'm questioning Tom's Idea's that I post this
Link here, just hoping for some more suggestions so I can pick the best one out since I think this is a mayor part in the build.
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 10:33 am
by gk108
I'd go for transverse supports cut to form a cradle on the bottom of the tanks. With the way your tanks are made, the angled bottoms give you some longitudinal strength compared to a flat bottomed tank of rectangular cross-section. You could put 4 transverse supports under each tank and maybe a plywood beam let into them down the middle to keep the flat bottom from sagging. Those transverse supports will tie into the stringers and spread the fuel load to the entire bottom. More of the egg crate type thing, you know.
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 11:59 am
by Murry
gk108 wrote:I'd go for transverse supports cut to form a cradle on the bottom of the tanks. With the way your tanks are made, the angled bottoms give you some longitudinal strength compared to a flat bottomed tank of rectangular cross-section. You could put 4 transverse supports under each tank and maybe a plywood beam let into them down the middle to keep the flat bottom from sagging. Those transverse supports will tie into the stringers and spread the fuel load to the entire bottom. More of the egg crate type thing, you know.
That's what came to my mind when I reviewed the pic's from the other thread Peter and I think Tom's idea is basically the same but with the supports being on the bottom of the tank only. Keep in mind I've only built an unfinished Gf 16.
If you go with method, don't forget to leave enough room for the padding between the cradles and tanks.
Don't you have a drain tube running down the middle under those tanks?
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 12:06 pm
by peter-curacao
Murry wrote:Don't you have a drain tube running down the middle under those tanks?
Yes I have why is that?
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 12:13 pm
by Murry
Thanks for posting that picture.
Everytime I see that one, I want to start my CS23.
No reason other than bringing that into the discussion. What ever is built, frames, ect. , drainage will need to be considered.
Daniel
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 12:20 pm
by peter-curacao
Murry wrote:Thanks for posting that picture.
Daniel
That's why I had the idea to use two mini stringers under the tank as supports instead of mini- bulkheads, no need for drainage holes.
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 12:45 pm
by Murry
peter-curacao wrote:Murry wrote:Thanks for posting that picture.
Daniel
I hear you loud and clear Peter.
With a tank compartment there will most likely always be a way for water to get to that compartment through the fill hose routeing area. So even in the case of the two mini stringers they would need to drain where they tied into the aft frame, I would think. Perhaps some others will chime in.
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 12:55 pm
by peter-curacao
Now I'm a bit confused (even more) why did I glue that pipe in then?
Re: Curacao CS 25
Posted: Fri Oct 16, 2009 2:04 pm
by Murry
Peter,
Don't let me confuse you. That's that last thing I want to do. Someone with more experience may need to chime in here. I don't want to lead you down the wrong the path or give incorrect advice/information.
All I was trying to say is, that if there is an open compartment anywhere with the possibilty of water entry there needs to be a way for that water to get out. When
I build my cs23 I will also have a center pipe drain like you, but in compartments that will be open under the sole, I'll have holes in that center pipe to allow water in or a seperate way to drain those compartments.
Please don't cut holes in your center pipe because of that last statement (not that you would), I don't want to lead you down the
wrong path.
Hopefully someone more qualified than me will step in here and clear the mess I've made up.
Re: Curacao CS 25
Posted: Sun Oct 25, 2009 11:26 pm
by Murry
Peter have you been able to get any more information on what to do with the tank compartment?
I'd sure like to know what you decide or what you've found out.
I'm taking notes.
Re: Curacao CS 25
Posted: Mon Oct 26, 2009 10:47 am
by peter-curacao
Murry sorry should have answered you earlier, I forgot about your last posting until your reminder. I decided to sent my tanks back to the welder and let him change them so I still can place them as I intended in the first place, with the only difference that they won't hang freely between the stringer but they will hang freely on top of the stringers and cleats. To avoid water in the tank compartments I will make a conduit half way up the side panels around the the hoses coming true the sole and foam these of on top, to cover those conduits I'm planning to extent the frame's what are located on those place's around those conduits so those can also function as speaker housing. Difficult for me to explain in words, hope the following drawing will help (sorry for my paint ability)
Re: Curacao CS 25
Posted: Mon Oct 26, 2009 11:22 pm
by Murry
Got it Peter, thanks, and I'm looking forward to seeing those tanks installed.
I think I understand what you're doing with those too. I guess I'll find out
when you get them back.
Daniel
Re: Curacao CS 25
Posted: Tue Oct 27, 2009 6:37 am
by cape man
Only if you let it. My vent and fill lines come out of the locker and there's NO way water is seeping around them. I'm going to have to cut and grind them out if I ever replace them, but no water is getting past them. The place water can get in mine is the access hatch, but that can be fixed by installing a water tight circular access port instead of a hatch. If mine were below the sole that's what I would have done. Good bead of 5200 around the edges and make sure to grease the O ring before screwing it shut. I don't think you need the conduit other than to protect the outside of the hoses if you think they need it. You can get a very tight seal of epoxy around the hoses as easily as around the conduit.
Re: Curacao CS 25
Posted: Tue Oct 27, 2009 10:21 am
by Murry
cape man wrote:With a tank compartment there will most likely always be a way for water to get to that compartment through the fill hose routeing area.
There are alot of
good ways to skin a cat for sure. It sound like yours won't leak for sure and I may not even be able to accomplish the task on the cs23 I'm planning to build, but in the case where I have an open compartment under the sole. I hope to have it either sealed up and full foam or design a way for water to exit to the bilge incase of entry. Just make sense to me.
But I'm the guy that built his strakes to short and weak.
Re: Curacao CS 25
Posted: Tue Oct 27, 2009 1:36 pm
by cape man
That's the key. While you need to access the compartment to replace hoses, sender unit, etc., the comparment is otherwise sealed and water tight using something like this.
Re: Curacao CS 25
Posted: Tue Oct 27, 2009 2:08 pm
by Murry
cape man wrote: but in the case where I have an open compartment under the sole.
I hear you loud and clear and I understood exactly what you were describing in your earlier post, but thanks for the further explanation incase I didn't.
For me personally I wouldn't want to only trust a water tight hatch or deck plate. IF water ever got in, How would you get it out? If it can be opened up, I personally would want a way for any water that could ever get in to have a way to drain to the bilge for pumping or drainable when the plug is removed. Haveing said that, this isn't my build and I'm cluttering Peter's page up with my personal opinions concerning a subject that he has already made a good decision on.
Come to thank of it, He didn't even ask for my opinion to begin with.
Thanks for helping to clarify Craig.
Daniel
Re: Curacao CS 25
Posted: Tue Oct 27, 2009 6:12 pm
by peter-curacao
Murry wrote:Haveing said that, this isn't my build and I'm cluttering Peter's page up with my personal opinions concerning a subject that he has already made a good decision on.Danie
Daniel I really don't mind that,from listening or in this case reading other ones discussions you can learn a lot
O yeah tanks came back today I think I really have tackle it now, tomorrow I will route out the lips where they are hanging on in the hope the are hanging completely free from the hull and stringers, pics will follow o yeah back and ankle are not completely healed but are going a lot better,for those interested
Re: Curacao CS 25
Posted: Tue Oct 27, 2009 6:53 pm
by TomW
Peter glad to hear that you are healing well. Only time will heal those types injuries. Backs are especially nasty, I know I spent 2 sessions when I was in the Navy. Kept me from going on as a career.
Re: Curacao CS 25
Posted: Tue Oct 27, 2009 10:14 pm
by Murry
peter-curacao wrote:O yeah tanks came back today I think I really have tackle it now, tomorrow I will route out the lips where they are hanging on in the hope the are hanging completely free from the hull and stringers, pics will follow o yeah back and ankle are not completely healed but are going a lot better,for those interested
I'm happy about the tanks and the injuries healing up. To be honest, I'm a bit more excited about those tanks.
Re: Curacao CS 25
Posted: Wed Oct 28, 2009 2:40 pm
by cape man
Good to hear you are on the mend. We are Jonesing for new pics of the boat!
Re: Curacao CS 25
Posted: Thu Oct 29, 2009 11:13 pm
by Bowmovement
cape man wrote:Good to hear you are on the mend. We are Jonesing for new pics of the boat!
^^^What He Said^^^
Re: Curacao CS 25
Posted: Tue Nov 03, 2009 7:24 pm
by peter-curacao
Just to get the idea, still will put on neoprene on the side lips(between stringers and aluminum flat bars) with what do I glue neoprene to the aluminum, thickend epoxy, bison kit, gorilla glue?
Re: Curacao CS 25
Posted: Tue Nov 03, 2009 7:41 pm
by Fonda@kauai
I would think 5200.
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 2:24 am
by TomW
Agree 5200
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 7:11 am
by peter-curacao
Isn't that a little over the top not to mention expensive to use 5200 for an application like this? it's not that I gonna go true the hull with those things
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 7:40 am
by cape man
Peter, If I understand right (I often don't
) all you want to do is insert some small squares of neoprene to pad the tabs that will attach the tanks to the lip/cleat. I assume you will also screw them down, in which case all you need is a little dab of 5200 to assure the neoprene will not slide. Put several screws per tab and that shouldn't be an issue anyway.
LOVE the tanks! Those are very sweet! Want plenty of gas so we can go a long ways while I sit in the fighting chair and drink green rum!
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 7:55 am
by peter-curacao
cape man wrote:Peter, If I understand right (I often don't
No those small horizontal strips, I planed to screw those down in a bed of tickend epoxy, for the neoprene I'm talking about the vertical strips, this to prevent the tanks slamming against the stringers, I know as it looks now (tanks are very stiff) it's almost impossible, but just as a precaution
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 8:02 am
by cape man
I see...good idea. I'm with Tom and Fonda still...5200. You won't need much to keep the neoprene attached, and you really want it to stay there forever.
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 8:03 am
Yep, 5200. Tanks are beautiful Peter
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 8:21 am
by gk108
52oo for sure. I'm not sure if there is another adhesive that I would trust to glue rubber to aluminum.
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 9:11 am
by Murry
The tanks look very strong Peter.
Great design to keep the weight off the floor by supporting them on the stringers.
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 9:40 am
by tech_support
5200 is what I use. Its flexible enough, plus it bonds well.
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 3:57 pm
by peter-curacao
Oke I'm convinced 5200 it is!
Re: Curacao CS 25
Posted: Wed Nov 04, 2009 6:05 pm
by BassMunn
Those tanks look good and you've fitted them in there really nicely. Looking good
Re: Curacao CS 25
Posted: Thu Nov 05, 2009 7:05 am
by Murry
What's their capacity Peter? Just wondering.
Re: Curacao CS 25
Posted: Thu Nov 05, 2009 7:08 am
by cape man
That looks really nice Peter. Your welder did a great job, and the neoprene will give you that extra feeling of confidence.
Re: Curacao CS 25
Posted: Thu Nov 05, 2009 7:23 am
by peter-curacao
Murry wrote:What's their capacity Peter? Just wondering.
They are 225 liters each (if my calculations are right) that's about 60 gallon each I think
Re: Curacao CS 25
Posted: Fri Nov 06, 2009 7:35 am
by cape man
59.53 gallons
Hey Peter...been thinking about the earlier concerns with water getting down in the bottom of those fuel compartments and how to get it out. Maybe a bad idea, but one I have been considering for mine....
My fuel compartment is above the sole and has a drain to the sole. However, where I park the boat is not level ground and the boat leans to starboard just enough to keep all the water from draining out. I cleaned the whole boat last week including washing down the top of the tank where I could get to it as there was dust and debris from the build. Afterwards I stuck a small piece of 1" flex hose in along the sides of the tank into the corner where the water pooled and sucked it out with a shop vac. Didn't get much out, but felt better afterwards. The hatch seals pretty good, but not water tight (remember I built them myself
), so I will keep the vac and hose handy for clean up after each trip. What if you permanently installed a hose that terminated at the lower point of those compartents and was accessable when you opened your access hatch(es)? Like I said, maybe a bad idea, and you have come up with something better. A good sealing access hatch shouldn't leak, but this may give you that much more comfort.
Re: Curacao CS 25
Posted: Fri Nov 06, 2009 10:19 am
by peter-curacao
I don't think that's a bad idea at all but do I need it? My idea is since I don't have to be in there often not to make any hatches in my tank compartments, what I will make is rectangular inspection plates above the hose connection and fuel senders, those I will make my self just a hole in the sole with a lid screwed on it with either 4200 or silicone between it, I jump from that bridge when I'm there
To make it more clear an illustration.
Re: Curacao CS 25
Posted: Fri Nov 06, 2009 10:30 am
by cape man
You probably don't need it. If you seal the plate with 4200 or silicone you should be fine. I assume your fuel cutoff valve will be somewhere else.
Is that a question or a statement? I have no way to illustrate right now, and understand what you want to do.
Re: Curacao CS 25
Posted: Fri Nov 06, 2009 10:56 am
by peter-curacao
cape man wrote:I don't think that's a bad idea at all but do I need it? My idea is since I don't have to be in there often not to make any hatches in my tank compartments, what I will make is rectangular inspection plates above the hose connection and fuel senders, those I will make my self just a hole in the sole with a lid screwed on it with either 4200 or silicone between it, I jump from that bridge when I'm there
You probably don't need it. If you seal the plate with 4200 or silicone you should be fine. I assume your fuel cutoff valve will be somewhere else. .
Yes they are but very close by
cape man wrote:Is that a question or a statement? I have no way to illustrate right now, and understand what you want to do.
Sorry didn't worked the first time, now it's there
Re: Curacao CS 25
Posted: Fri Nov 06, 2009 11:05 am
by cape man
Nice drawing. That'll work.
Re: Curacao CS 25
Posted: Sun Nov 08, 2009 9:54 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun Nov 08, 2009 10:47 pm
by cape man
You are too much!!! Nice pictures of the build...and animated !
Re: Curacao CS 25
Posted: Tue Nov 10, 2009 6:11 pm
by peter-curacao
Post from Tom's thread
Cracker Larry wrote:Come on Tom, bring us up to date. Peter just showed us his gas tank install
Actually I'd "installed" the second gas tank today (used Tef Gel between the screws and aluminum lips )still have to do the hoses and ground though reason is I had to do other small things also, like coating the holes GOOD where the hoses go to the sides through the stringers, also I did cut 3 frames from between the stringers and had to replace those with 2 others, in between those two new frames there will be a floor which have to have drainage because I'm planning to put in a marine head which has to be able to clean with a hose, made that to and connected that to the main drain under the tanks (see pic), could not find a stainless steel strainer for that, so I made one from aluminum I had left over from the fighting chair, so a lot off small things I didn't thought of until I was getting there but they have to be done and they take time also especially the drying of the resin, hopefully I put in the last cleats above the tanks tomorrow after that more pics after cleaning up
Re: Curacao CS 25
Posted: Wed Nov 11, 2009 7:22 am
by Murry
Thanks for the update Peter.
I'm looking forward to seeing and gaining a better understanding of your drain ideas after clean up with those additional pictures.
Re: Curacao CS 25
Posted: Wed Nov 11, 2009 7:19 pm
by peter-curacao
Murry wrote:Thanks for the update Peter.
Sorry Murry I know I promised some pics today, but the cleats above the tanks are curing as we speak also the floor is in etc etc don't wanna disturb that or even ruing that work for some pics , for sure tomorrow all is dry so also safe to clean and take pics
Re: Curacao CS 25
Posted: Thu Nov 12, 2009 4:54 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Nov 12, 2009 5:10 pm
Very nice work Peter. Before you glue down the sole, run through the chase tubes and wiring one more time in your head. Once it's glued down there is no changing anything. I'd go ahead and run those fuel lines too.
Re: Curacao CS 25
Posted: Thu Nov 12, 2009 6:48 pm
by TomW
Looking good Peter it is really looking like a boat. Like Larry make sure you run through one last time that you have everything accounted for before you put down the sole. That is a big boat your building and no use making any errors now.
Re: Curacao CS 25
Posted: Thu Nov 12, 2009 8:55 pm
by Bowmovement
Looks good Peter
I think I would label the end of the chase tubes also. You may not need to but I am just OCD and suffer from CRS
Matt
Re: Curacao CS 25
Posted: Thu Nov 12, 2009 10:46 pm
by Dog Fish
Sweet Peter, everything looks really good, tanks look great. Nice work
Re: Curacao CS 25
Posted: Fri Nov 13, 2009 12:01 pm
by cape man
Very Nice Work! Love your filets (never though I'd say that to a man
Re: Curacao CS 25
Posted: Sat Nov 14, 2009 4:43 pm
by BassMunn
Peter you've done some really neat work in that boat, looks very good
Looking forward to seeing this one finished.
Question - what is that hatch between the fuel tanks going to be used for? Just curious
Re: Curacao CS 25
Posted: Sat Nov 14, 2009 7:48 pm
by peter-curacao
BassMunn wrote:Question - what is that hatch between the fuel tanks going to be used for? Just curious
Thanks, but I'm not sure I understand your question correctly ?
Re: Curacao CS 25
Posted: Sat Nov 14, 2009 10:12 pm
by Daddy
I think he means the one with the drain?
Daddy
Re: Curacao CS 25
Posted: Sun Nov 15, 2009 9:35 am
by peter-curacao
Daddy wrote:I think he means the one with the drain?
Daddy
Ooh in that case that's not a hatch that's an euuhh
how the hell to I describe it? Eeh a hole in the sole? with a lower little piece of sole to mount a marine head under the CC, still don't know if it's possible if not it will be storage, if it is, it won't be the most comfortable place
but hey if you got to go you got to go, also it's nice to have it in case of female passengers, you've got to treat the lady's good
Re: Curacao CS 25
Posted: Sun Nov 15, 2009 5:28 pm
by OllieK
Hey Peter, that boat is coming along just fine.
I have so much to do to get to where you are. Keep at it, you are my inspiration to get this thing built! Back on the build for the next 6 months, i'll see where I can get to before work picks up again. All the best
Ollie
Re: Curacao CS 25
Posted: Tue Nov 17, 2009 10:32 am
by Murry
Thanks for all the great detail with those pictures Peter!
I like the drain you made there, looks like you paid good money for that finished project.
Nice work!
When/if I get the opportunity to build my dream boat (CS23), I want to do something similar to have a removable head
stored in the center console, not to mention it's a great place for storage.
Peter, next time you're in the boat with your tape measure, could measure that area. (please don't go out of your way) It might have to be smaller on the 23 though. I read where you had to remove/rearrange some of the frames to make it work. I'm glad that's allowed. I think it's a great improvement.
Daniel
Re: Curacao CS 25
Posted: Tue Nov 17, 2009 11:42 am
by peter-curacao
Daniel as I said earlier it's not a very big area so not the place to do your royal morning thing
, but handy to have it there
Anyway: it measures 23" by 29" it could be a little bigger though, if you are willing to sacrifice some fuel capacity the longer site could be longer as 29"
Murry wrote:I read where you had to remove/rearrange some of the frames to make it work. I'm glad that's allowed.
Yep the big boss
himself gave the thumps up for that
Re: Curacao CS 25
Posted: Tue Nov 17, 2009 3:56 pm
by Murry
Thanks Peter.
That's enough room for a porapoty and your feet. Besides it's for an emergency anyway.
It does make me consider the jump cabin,
but I'm afraid I'd miss that casting deck room way to much.
Thanks again Peter!
Re: Curacao CS 25
Posted: Tue Nov 17, 2009 4:57 pm
by peter-curacao
Murry wrote:Thanks Peter.
Thanks again Peter!
Your welcome, I ain't gonna make either of those
Re: Curacao CS 25
Posted: Tue Nov 17, 2009 5:03 pm
by Murry
I see!
Looking forward to seeing your layout in the coming months Peter.
Re: Curacao CS 25
Posted: Tue Nov 17, 2009 5:26 pm
by peter-curacao
Murry wrote:I see!
It's because over here we almost always fish
from the stern I think I don't really need a casting deck, a cabin I thought about for a long time in case of tournaments on other (is)lands for example Venezuela,Aruba or Bonaire, I let that go because of the weather here! or I put on a hammock
on the boat and sleep under the stars , which shouldn't be a problem with all the beer
on those tournaments, or I book a comfy hotel. So I'm trying to accomplish sort of the same layout as the SeaVee on page
38 of my build thread
Re: Curacao CS 25
Posted: Tue Nov 17, 2009 5:58 pm
by Murry
I remember that console layout, but I had forgotten about the extra seating up front. That's really nice. You'll solve the main problem with center console's in my opinion with that layout, the lack of seating.
That'll be nice Peter.
Re: Curacao CS 25
Posted: Tue Nov 17, 2009 6:03 pm
by BassMunn
OK it's for those emergencies, cool thanks.
I love your smilies
Re: Curacao CS 25
Posted: Fri Nov 27, 2009 2:54 pm
by peter-curacao
WOW!!!
first sole panel is in I used around 2,5 to 3 liters of mixed thickened epoxy to glue that one in,I know it would take a lot epoxy but never could imagine it would take that much
Re: Curacao CS 25
Posted: Thu Dec 03, 2009 2:10 am
by sideslippa
Hi Peter...I wouldn't like your epoxy bill ...Wow. I think I have used much more than suggested with my build. Oh well, it has to be done.
Many thanks for the Birthday wishes. Very pleasant suprise. Cheers.
Re: Curacao CS 25
Posted: Sat Dec 05, 2009 9:53 pm
by cape man
delete
Re: Curacao CS 25
by cape man
Just put whatever epoxy it takes. I was over 3X on mine and no regrets. I knew I was in trouble when I glassed the stringers down instead of just glueing them. It takes what it takes.
It will feel good the first big wave you slap into.
Re: Curacao CS 25
Posted: Sat Jan 09, 2010 11:17 am
by peter-curacao
Okay we are back in Curaçao and had a great vacation what we are certainly going to repeat to other places in the US, the ODO told us we drove around 4500 miles when we returned the car yesterday, but it sure didn't feel like that, very relaxing driving in the US, at first I had a hard time respecting the maximum speed limit, but after a while I found if you are going with the flow you still driving close to 90 mh.Yesterday evening we past customs without any troubles Gloria's suitcase had to be opened then they saw a frame and asked what it was so I showed them the gold and platinum Elvis singles with a lot of talking and blablabla while pushing my suitcase forward with my food, believe it or not but that worked so no import taxes for this guy
Here's what I brought home
Two Si-TEX GPS/fischfinder/rader units one with and one without WAAS, hmmm since I ripped the boxes ofnow I have to find out which is the one with WAAS
One VHF Radio Standard Horizon
One Sony FM/AM CD radio, amps and speakers I will buy here that's really to heavy to carry with me.
Transducer and SI-TEX transducer box
SI-TEX GPS WAAS Antenna
Ritchie Compass
The right size scuppers, navigation LED lights,three color courtesy LED cockpit light
And a lot of matching cables, Dremmel flapperwheels,mounting hardware etc. not really picture material.
Re: Curacao CS 25
Posted: Sat Jan 09, 2010 11:22 am
Glad you made it home safe and had a good trip in the US. Dori and I sure enjoyed your visit!
Re: Curacao CS 25
Posted: Sat Jan 09, 2010 11:54 am
by gk108
Nice stuff. I've been looking at that same VHF radio for the O'Day renovation. Your picture shows it a lot better than any catalog. Looks like it will work for me.
4500 miles is a pretty good road trip. You could do that once a year for the rest of your life in different regions of the US and still miss half of the interesting places.
Now it's about time to mix up some epoxy or something, isn't it?
Re: Curacao CS 25
Posted: Sat Jan 09, 2010 9:32 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Jan 09, 2010 9:56 pm
by chicagoross
We're impressed
and jealous
. Now for some pics of your wifes shopping spree?
Re: Curacao CS 25
Posted: Sun Jan 10, 2010 9:39 am
by Bobg
Oh yeah, I know I'm impressed.. You might decide what's what using serial numbers
Re: Curacao CS 25
Posted: Sun Jan 10, 2010 11:17 am
by peter-curacao
chicagoross wrote:We're impressed
and jealous
No need to be jealous
My hard drive and probably also Bateau's server is to small for your request.
You know the saying don't you?
"A man is willing to pay 20 US$ for an US$ 10,- item he really needs, a women will pay US$ 10,- for an US$ 20,- item she don't need at all"
Re: Curacao CS 25
Posted: Sun Jan 10, 2010 12:49 pm
by TomW
Nice stuff Peter, you sure made the best of your trip. Glad you and Gloria enjoyed yourselves.
The cold up here is causing some of these old electrical stuff to freeze and crack so I have been without power twice yesterday and today. Some of the power lines and equipment on our road is 80 years old.
Re: Curacao CS 25
Posted: Sun Jan 10, 2010 2:48 pm
Those Sitex units are really nice
That will be sweet, having them networked to a laptop
And Standard has been making great VHF radios for a long time. I've had 3 or 4 of them, never a problem. My son would like the stereo
Re: Curacao CS 25
Posted: Mon Jan 11, 2010 4:49 pm
by cape man
Well that's a huge ! response on my shopping spree !?!?!!
Put them on the boat if you want to impress me!
Re: Curacao CS 25
Posted: Mon Jan 11, 2010 4:58 pm
by peter-curacao
No need to be impressed, just sharing my happiness.
Btw pic's where taken
on the boat
Re: Curacao CS 25
Posted: Mon Jan 11, 2010 8:35 pm
by cape man
Perfect response!
My jealousy got the best of me. Just want to see more pics of your boat coming together!
Re: Curacao CS 25
Posted: Wed Jan 13, 2010 4:10 pm
by peter-curacao
Cool it works!!
this is as far I can see now a real No Nonsense unit, perfect for me not a lot of bells and whistles although there is perspective view on it there's no 3D, overall display look, looks in my opinion more like a commercial unit as a pleasure craft unit which I like.
Here a pic so you guys can make your own judgment, as always all honest opinions are highly appreciated.
I played with it for a few moments and everything is real simple to operate and understand, although there's one thing (till now) I don't know what to do with or what it does and that is the raster grid's in the next pic, anybody could be some help here?
Re: Curacao CS 25
Posted: Wed Jan 13, 2010 4:30 pm
That looks great Peter
I think the grids denote areas that have a larger scale chart available. Have you tried clicking on them?
Re: Curacao CS 25
Posted: Wed Jan 13, 2010 4:59 pm
by peter-curacao
Cracker Larry wrote: I think the grids denote areas that have a larger scale chart available. Have you tried clicking on them?
That's what I thought,but with clicking nothing happened
Re: Curacao CS 25
Posted: Wed Jan 13, 2010 5:13 pm
I'm sure that's what they are, just different charts for the harbors, it shows more detail than the large area charts. When you zoom in on those places, the different charts may be integrated already in the software. Or it may just be a copy of the small scale paper chart, showing areas that better harbor detail is available on additional charts. What kind of software are you using?
I bet each of those areas are are covered by one of these...
Chart # Title
24400 East Coast of Trinidad including Tobago
24402 Tobago (West Indies), Plans: A. Charlotteville, B. Scarborough
24404 Gulf of Paria
24405 Gulf of Paria (Trinidad & Tobago-Venezuela)
24406 Port of Spain (Trinidad-West Coast)
24408 Plans in Trinidad; A. Pointe-a-Pierre & Adj. Ports, B. Point Fortin, C. Approaches to Brighton
24410 Serpents Mouth, Panels: A. Serpents Mouth, B. Eastern Approach to Serpents Mouth, Plan: Galeota Point
24414 Puerto de Hierro
24423 Islands off the Coast of Venezuela: Plan A. Islas Los Testigos. Plan B. La Blanquilla & Los Hermanos
24430 Cabo Codera to Cabo Tres Puntas including Isla La Tortuga to Islas Los Testigos
24431 Canal de Margarita & Golfo de Cariaco ( Venezuela) Plans: A. Cumana, B. Bahia Guamache
24433 Cumana to Picuda Grande (Venezuela)
24434 Approaches to Bahia de Pozuelos & Golfo de Cariaco
24435 Approaches to Bahia Bergantin, Bahia Guanta & Bahia de Pertigalete
24441 Isla La Tortuga & Isla Las Aves
24444 Islas Los Roques
24450 Punta San Juan to Cabo Cadera incl. Offshore Islands (Omega)
24452 La Guaira and Approaches, Plans: A. Catia la Mar, B. La Guaira
24453 Approaches to Puerto Cabello, Plan: El Palito & Moron
24454 Puerto Cabello (Venezuela)
24455 Plans on the Coast of Venezuela: A. Bahia de Chichiriviche, B. Puerto Tucacas & Approaches
24460 Cabo de La Vela to Punta San Juan including Aruba, Curacao & Bonaire
24461 Bonaire - Plans: A. Kralendijk Roadstead; B. Goto Oil Terminal; C.Salt Pier; D. Kralendijk Pier
24462 Curacao, Plan: Bullenbaai
24463 Aruba, Plans: A. Commandeurs Baa; B. Sint Nicolaas Baai; C. Paarden Baai
24464 Caracas Bay
24465 Sint Anna Baai & Schottegat (Netherlands Antilles-Curacao)
24470 Golfo de Venezuela (Colombia-Venezuela)
24471 Punta Salinas to Punta Cardon,Plan: Bahia Boca de Las Piedras
24481 Lago de Maracaibo, Plans: A. Bachaquero, B. San Lorenzo
24482 Maracaibo Channel, Panels: A. La Salina to Maracaibo, B. Punta Viga to Punta Piedras
24483 Entrance to Bahia de Tablazo
24484 Plans in Maracaibo Channel, A. Maracaibo, B. Puerto Miranda, C. La Salina
25400 Trinidad to St. Vincent
402 Caribbean Sea (Omega)
Re: Curacao CS 25
Posted: Wed Jan 13, 2010 5:24 pm
by peter-curacao
I have the C-MAP software from jeppesen.com/lightmarine
C-MAP MAX MEGA WIDE C-CHARD
SA-M503 S AMERI GULF CARIBBEAN
Also standard there is a limited world map in it
Re: Curacao CS 25
Posted: Mon Jan 18, 2010 4:47 pm
by Doc_Dyer
hey,
does that zoom in any closer?
is that a regular VGA monitor? if so that is sweet
I need some CS-25 Boat PORN please..have you got the sole in yet?
Bradley
Re: Curacao CS 25
Posted: Mon Jan 18, 2010 5:40 pm
Yeah Doc, it zooms
Peter, the digital charts are exact digital images of the corresponding paper charts. Paper charts always denote areas that are covered by another smaller scale/ larger view paper chart. They are of no particular use on the digital chart since the software automatically switches charts to the one with most detail when you enter those areas.
Re: Curacao CS 25
Posted: Mon Jan 18, 2010 7:16 pm
by Murry
All this talk abouit Si-Tex just made me spend 15 minutes searching about them on-line, about 16 minutes ago I hadn't a clue what I was looking at in your photo's Peter.
They look sweet! Where do you plan on mounting your monitor Peter?
Re: Curacao CS 25
Posted: Thu Jan 21, 2010 3:48 pm
by peter-curacao
Sorry for the late reply, I had a high fever.
Doc_Dyer wrote:hey,
Bradley
Doc yes it's a regular pc screen and yes it zoom's but still I have to figure out how to zoom to the separate charts (chart's in the chart's) but for now I packed it and stored it safely until later use.
Sole is partially in but I have a delay because I ruined my freshwater tank, what happened? well while testing if it was watertight I forgot to open the vent hose and walked away while filling with water, after a while a BIG BANG
airpressure in the top blew up the tank
So now I'm thinking of just using the hull as an freshwater tank like someone suggested earlier in my thread, sorry forgot who it was
Cracker Larry wrote:Yeah Doc, it zooms
Thanks Larry, maybe on a rainy Sunday I will do a test again before installation, btw on our boat trip in Savannah we where discussing the sea depts in my area did you saw those in my gps pics?
Murry wrote:All this talk abouit Si-Tex just made me spend 15 minutes searching about them on-line, about 16 minutes ago I hadn't a clue what I was looking at in your photo's Peter.
Murry, I'm planning to mount 3 separate 12" or 15" waterproof monitors 1 for gps 1 as fishfinder and 1 for a camera in top of my T Top sort of a remote tuna tower (don't know if this is gonna work)
also maybe this one will have a radar in the future.Al those has to come in the center console under the compass.
Re: Curacao CS 25
Posted: Thu Jan 21, 2010 4:39 pm
by Murry
Looking forward to seeing that setup Peter.
Re: Curacao CS 25
Yes! Looks like fantastic bill fish and wahoo waters
That's going to be a nice electronics set up to find them too! You got to finish that boat so I can come down and catch a marlin with you
Re: Curacao CS 25
Posted: Thu Jan 21, 2010 5:27 pm
by cape man
Don't let Larry sit in my chair!!!
Re: Curacao CS 25
Posted: Thu Jan 21, 2010 8:29 pm
by Spokaloo
Peter, what size was that water tank? I might have a tank that will work perfectly for you (found a way to repair my fuel tank, but it would be better suited to water than to fuel). 40 gals of water would be sweet and I can box her up and ship it this week.
E
Re: Curacao CS 25
Posted: Thu Jan 21, 2010 9:22 pm
by peter-curacao
Spokaloo wrote:Peter, what size was that water tank? I might have a tank that will work perfectly for you (found a way to repair my fuel tank, but it would be better suited to water than to fuel). 40 gals of water would be sweet and I can box her up and ship it this week.
E
Wow Erik that's a mighty fine offer
but as much as I wish your tank would work for me I don't think that's gonna be the case, to be honest I don't know the capacity of the tank because I custom made it myself, and I didn't get the chance to poor the water out in a controlled kind of way to measure it, it was more like a water balloon kind of way
Here some construction pics
Re: Curacao CS 25
Posted: Fri Jan 22, 2010 3:52 am
by Spokaloo
Nice work Peter!
E
Re: Curacao CS 25
Posted: Fri Jan 22, 2010 6:03 am
by cape man
Perhaps if you could describe the sound it made, how far away you were when you heard it, and what were the weather conditions at the time, we could calculate the volume based upon the dopler effect. Of course we would also need to know the pressure of the water supply, the length and diameter of the hose used to fill it, and what you were doing at the time (Voodoo and Green Rum? Playing with the new pooch? Building a 5 gallon bucket stool for CL to Marlin fish from?).
Re: Curacao CS 25
Posted: Fri Jan 22, 2010 8:26 am
You'd better price shipping to Curacao before you make that offer
I shipped Peter some Dremel bits, and I think it would have been cheaper to buy myself a round trip ticket and carried the bits in my pocket
That's harsh!
Re: Curacao CS 25
Posted: Fri Jan 22, 2010 11:12 am
by wegcagle
I'd take a 5 gallon bucket seat if it meant catching a big marlin.
Not too proud over here
Will
Re: Curacao CS 25
Posted: Fri Jan 22, 2010 12:49 pm
by ks8
I was looking into making a water tank myself, and after some research, I see there is a type of epoxy formulated to be safe for a potable water tank. Curious which brand you used. And did you use cleats to bond the top on? Do you have a largish inspection hatch incorporated into the top?
Re: Curacao CS 25
Posted: Fri Jan 22, 2010 1:03 pm
by Larry B
Peter, you do some very clean work
Re: Curacao CS 25
by peter-curacao
ks8 wrote:KS I was looking into making a water tank myself, and after some research, I see there is a type of epoxy formulated to be safe for a potable water tank. Curious which brand you used.
I believe we had this discussion before here earlier in this thread,
I used regular West Epoxy just with a little less hardener maybe you found this an interesting link for your tank build?
http://www.epoxyworks.com/18/pdf/tanks.pdf
ks8 wrote:And did you use cleats to bond the top on? Do you have a largish inspection hatch incorporated into the top?
No I didn't use cleats just a beat of thickened epoxy and after that some 45/45 biax on the outside, I wish I had a inspection hatch in there! properly that would have popped out then instead of that BIGBANG!!
Re: Curacao CS 25
Posted: Fri Jan 22, 2010 2:38 pm
by ks8
Thanks for that link Peter. I hadn't recalled the discussion earlier in the thread...
and I echo the previous post. Nice to watch the clean work you do.
Re: Curacao CS 25
Posted: Fri Jan 22, 2010 11:11 pm
by peter-curacao
I have something better, video!
Re: Curacao CS 25
Posted: Sat Jan 23, 2010 4:06 pm
by cape man
Based on that I would say it was right at 22.765 gallons.
Re: Curacao CS 25
Posted: Sat Jan 23, 2010 4:39 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun Jan 24, 2010 7:40 am
I never cease to be amazed
You tried to blow up your own boat?,.. With a water hose?!?!?
I feel much better about myself after reading this. First time in a while I can go to church with a smile on my face. That'll have 'em all wondering. Keep up the good work Peter you truly are an inspiration.
Re: Curacao CS 25
Posted: Sun Jan 24, 2010 9:21 am
by peter-curacao
Thank you very much and your very welcome, good to see you posting here again
Re: Curacao CS 25
Posted: Mon Jan 25, 2010 8:17 pm
by peter-curacao
Cool
three puppies like this are on their way to complete the Sitex stuff!
Don't ask me what the cost because I don't know, I'm getting them as a gift from a client of my.
http://www.nanovdisplay.com/presentatio ... 50wppp.pdf
Re: Curacao CS 25
Posted: Mon Jan 25, 2010 8:23 pm
Waterproof? What kind? Should I bring my own rods or do you have enough?
Re: Curacao CS 25
Posted: Mon Jan 25, 2010 8:54 pm
by peter-curacao
Cracker Larry wrote:Waterproof? What kind? Should I bring my own rods or do you have enough?
I included a link with product information hope you like it, till this point I don't have enough rods but that will change in the future
Re: Curacao CS 25
Posted: Mon Jan 25, 2010 8:57 pm
I missed the link, sorry
Those are very nice
I'll bring the rods
Re: Curacao CS 25
Posted: Thu Jan 28, 2010 6:00 pm
by peter-curacao
Second attempt of the fresh water tank
As I told earlier I let the idea of a separate tank between the stringers go and used the boat hull to build me a tank.
First a lot of epoxy coats, I lost count but I believe its somewhere around 12 coats, that's including the glass.
The lid (inside) is 3 coats 1 rolled and 2 poured.
I set the timer on my camera, put it in the tank and closed the lid to position the suction pipe.
I made 90 degree corner profile from biax and woven, epoxy glued those to the sides of the box,those aren't structural they are just there to hold the lid in place while gluing, next day I put a beat of thickened epoxy on top and pushed in the lid.
The top sides of the lid I planed somewhere around 45 degrees, after it was in place I filled those corners with thickened epoxy and give it a filled.
Hope this works better
Re: Curacao CS 25
Posted: Thu Jan 28, 2010 7:30 pm
Nice work Peter. You got the fiberglass figured out
I maybe would have made a baffle in the tank to reduce slosh, but it's a little late for that
I'm sure it will work fine.
What is the clear plastic tubing on the side.
Re: Curacao CS 25
Posted: Fri Jan 29, 2010 7:53 am
by Larry B
Peter, Hope you didn't forget and leave the camera inside
Hey that was a pretty neat idea with the camera
Takes all the guess work out of it.
You do some very nice work Peter
Re: Curacao CS 25
Posted: Fri Jan 29, 2010 9:26 am
by tech_support
good use of space! Just a not to others considering this, if you add just a little pigment tot he epoxy when you doing these heavy coats, you will be able to easily see where you are building up thickness. But with 12 coats Peter's tank is definately sealed up
Re: Curacao CS 25
Posted: Fri Jan 29, 2010 5:54 pm
by gk108
Let us know when to take cover... I mean let us know when you are going to pressure test it.
Re: Curacao CS 25
Posted: Sat Jan 30, 2010 11:14 am
by peter-curacao
gk108 wrote:Let us know when to take cover... I mean let us know when you are going to pressure test it.
FIRE IN THE HOLE !!!!!
Re: Curacao CS 25
Posted: Sat Jan 30, 2010 8:01 pm
by peter-curacao
Dear webmaster please close and delete this thread! but before you do please sent it to my email thanks and have a nice day!
Peter
Re: Curacao CS 25
Posted: Sat Jan 30, 2010 8:06 pm
by BassMunn
Huh????
Re: Curacao CS 25
Posted: Sat Jan 30, 2010 8:08 pm
by TJS Redchaser
BassMunn wrote:Huh????
Yea, do you want to delete the whole thread peter? It's one of the ones I always look for an update on. Such a cool "BIG" boat and you do such nice work.
Re: Curacao CS 25
Posted: Sun Jan 31, 2010 1:24 am
by TomW
Peter????
Please don't leave us, we'll miss your humor!
Re: Curacao CS 25
Posted: Sun Jan 31, 2010 10:49 am
Peter
Dear webmaster, please ignore this request until Peter comes to his senses.
Re: Curacao CS 25
Posted: Sun Jan 31, 2010 11:22 am
by pkar
Hello Peter - greetings from Greece.
Please don't do that
You do a very nice work and your thread is like a "Handbook" for us - I look every day for an update.
pkar
Re: Curacao CS 25
Posted: Sun Jan 31, 2010 12:59 pm
by fishin'
Don't do it Peter!!!
Peter
Re: Curacao CS 25
Posted: Sun Jan 31, 2010 8:13 pm
by ThistleDewDayDreamin
Was it something we said
Please tell us that was rum talking
Ditto on your thread being a builders manual for the rest of us.
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 1:33 am
The Green Rhum will make you talk in tongues. Not your own
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 6:27 am
by Joe H
Peter, we really appreciate your humor, advice and you build thread, please don't go??
Joe H
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 7:08 am
by cape man
Peter,
You have met some good friends here, with more to come (as soon as I can figure how to get down so I can sit in that chair). Take a break if you need it but don't take away one of our favorite builds.
I'm hoping everything is alright with you and yours. Email me separately if there's anything I can do.
Craig
"cawatson at ufl dot edu"
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 9:59 am
by OllieK
I would guess that Peter has had his account hacked. He only replied to a post in one of my threads the other day. I think J or J should look into this.
Peter, if by chance I am wrong dont get rid of the thread, there is so much useful info in these 60 odd pages. Its just to good to trash.
Hope you are OK
Ollie
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 10:37 am
by tech_support
I cant see anything wrong with the account, very strange. I will lock the thread for now. Hopefully we hear back from him in the near future......
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 5:36 pm
by peter-curacao
Joel would you please be so kind and post the following in my thread and reopen it again, sorry for the trouble I’ve caused.
Thanks Peter
To all,
After my request I’ve received a couple of emails this was my response on those and is also my response to all of you what took the time to post a response on my request, after sending those mails, those people again took the time to mail me and talked some sense back into me, after that I’ve asked Joel to reopen my thread again,
Sorry for that inconvenience and selfish request I made!
Hi ……,
Just received your Email, first of all sorry for that jackass request I made; I knew some were following my thread but I had no idea it were that quite a number. Let me try to explain the why, as far that's possible. When I first joined this forum it was a very nice and friendly forum, people were nice and were also clowning around with each other and that’s cool, but the last couple of weeks in my opinion (maybe/hopefully I'm seeing it wrong) that clowning around took a whole different path! in other words not so nice and friendly anymore, and although it wasn't against me I wasn't sure I wanted have anything to do with that, and yes I know I also did a lot of teasing on my side, but never with the intention to deliberate offend anybody. Maybe or probably I was seeing it to dark at the time I made that request, and maybe the fatigue from work and yes the green rum
also took over my ability to think clearly. I really appreciate you took the time of Emailing me regarding this matter, and I will be back when the sole is in, Okay??
Best regards
Peter
PS this is NOT a reprimand. to you!
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 5:42 pm
by wegcagle
Really Glad you're back Peter. This place wouldn't be the same with out you.
I don't disagree with your thoughts or what you did. I thought about doing the same thing 2 days ago. I'm glad all of this has finally come to a head and we can get back to the fun part of all of this. When we all joined the group it was a bunch of fun loving people out to help guide each other through the tough and fun maze of boat building. Some people are funny (tried to find a picture of an avatar pointing at you
) and some are salty. We are all connected by the love of boats, boat building, and eventually actually fishing from these things
Now that that's said........Post some #@!#$%^ pictures. You're killing me here
Will
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 6:06 pm
by Fonda@kauai
Whew, scared me there Peter
I know what you mean too, I go away for a few weeks and suddenly threads are getting locked
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 7:45 pm
by Daddy
Glad you are back Peter, maybe it was all just something in the water, good to be on track again.
Daddy
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 8:41 pm
by cape man
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 8:52 pm
by TJS Redchaser
Good news
That CS is gonna be awesome.
Not to belabor the point but I've stopped posting on two other fishing forums for the same reasons. They turned into a small group of people acting like high school guys arguing over whose truck was better. Or constant jabs about stealing fishing holes.
It seems that some will post things on the internet that they probably would never say to someones face. That's the rule of thumb I try to go by. Don't type anything you wouldn't say in person. You never know what someones experience or knowledge really is. So for things that are structurally important or must be technically accurate go with the designer. With that being said I doubt anybody intentionally gives out bad advice, so there's no reason to call anybody out.
Sometimes I don't really want to post updates. I barely have time to build the boat, never mind take, upload and post pictures. But one of the main reason I do is I have learned so much from others builds. Especially the pictures, they are worth 1,000 words ya know. Anyway if someone learns something or gets an idea from something I've done I figure I've helped back.
So if you can't say something nice don't say anything at all.
Build Away
Sorry Peter Hijack Over.
Re: Curacao CS 25
Posted: Mon Feb 01, 2010 8:58 pm
by Kestelle
Hi Peter,
Glad to hear that you are not closing your account!!!
I brought my plans for the CS25 closed Transom some months ago, after being inspired your thread.
After I get married in March, I will be starting to work on this daunting project, and I know I will be using your thread as my guide.
Cheers
Mike
Sydney Australia
Re: Curacao CS 25
Posted: Tue Feb 02, 2010 5:45 am
by OllieK
Thanks for jumping back onboard. I am back on track and right behind you!
Ollie
Re: Curacao CS 25
Posted: Tue Feb 02, 2010 6:22 am
Wheww, That was close,... I was surprised at how really uncomfortable the thought of you not being here was to me. It didn't just bother me a little, I was seriously contemplating trying to get your phone number from someone and calling you up. I've said it before, you truly are an inspiration to me.
I think the teasing can get out of hand. For me being cooped up in the house can get my sarcastic side acting up,... and if I offended anyone, well I'm sorry.
I can't tell you how many times I've gone back to the beginning of your thread and re-read from the start. I KNOW I've learned from some of your goofs, and I have been continuously inspired. Besides I will never get enough of your sense of humor and all those crazy smilies you use.
Glad to have you back man. -- porn please
Re: Curacao CS 25
Posted: Tue Feb 02, 2010 7:11 am
by Murry
Me too Peter. As you know I inspire to build a 23/25 one day and I've been following your entire build and will continue.
I must have missed the rude behavior, but noboby needs that. It takes a lot of timeo tpost pictures and expain them and
I appriecate everyone that takes the time to post their progress very much. Without it, my boat wouldn't be the same.
Daniel
Re: Curacao CS 25
Posted: Tue Feb 02, 2010 9:22 am
I've got his phone number
Re: Curacao CS 25
Posted: Tue Feb 02, 2010 10:44 am
by pkar
Hello Peter,
glad you are back.
pkar
Re: Curacao CS 25
Posted: Wed Feb 03, 2010 7:38 pm
Yup, CL,... you were the guy I was gonna email for his phone number. I figured you would help coerce him back. Ya know, a little friendly arm twisting.
Re: Curacao CS 25
Posted: Fri Feb 05, 2010 4:06 pm
by macs
I'm glad your back too Peter. I've certainly learned a lot from you and your build. We're all in this together!!!!!!!
Thanks for hanging in there!
Macs
Re: Curacao CS 25
Posted: Sun Feb 07, 2010 3:19 pm
by peter-curacao
First of all everybody thanks for the nice reply's and Emails,since the sole is in as promised some more boat porn
Still have to sand away the epoxy remains, didn't wanna let you guys wait for that
First two sheets of ply at the bow section I recut because I wasn't happy with the first fit, seams were to big.
Fill and vent hoses fresh water tank, pipe still have to receive a fillet will do that when I glass the sole.
Inspection plate fresh water tank
Re: Curacao CS 25
Posted: Sun Feb 07, 2010 3:29 pm
by chicagoross
Peter, those pics are deceptive! How bout one of somone standing in the boat at one end for perspective so we can see how huge this oat is?
Re: Curacao CS 25
Posted: Sun Feb 07, 2010 7:55 pm
by tobolamr
And also how big that boat is!
Re: Curacao CS 25
Posted: Sun Feb 07, 2010 8:06 pm
And we would prefer to see Gloria, not you
Re: Curacao CS 25
Posted: Sun Feb 07, 2010 8:54 pm
by cape man
Lookin' good Peter! Major step!
Re: Curacao CS 25
by chicagoross
Re: Curacao CS 25
Posted: Sun Feb 07, 2010 8:55 pm
by wegcagle
Ooooooo Baby. God bless some good boat porn
Looks good Peter.
Will
Re: Curacao CS 25
Posted: Sun Feb 07, 2010 9:00 pm
by chicagoross
Major milestone for sure! It's so nice to get to the point where you can walk around inside without stepping on cleats and stringers, or tripping over them. I'm still in awe at the scale, though - that's 5 sheets of ply there, half of that did my boat!
Re: Curacao CS 25
Posted: Mon Feb 08, 2010 1:21 am
by TomW
Looking good Peter
Bet your glad that's done! No more crawling around or exploding tanks.
Re: Curacao CS 25
Posted: Mon Feb 08, 2010 7:48 am
by Larry B
Looking good Peter, nice clean work
This is a tough crowd to please but your doing a good job of it
Re: Curacao CS 25
Posted: Thu Feb 11, 2010 1:16 pm
by TomW
Hey Peter, Evinrude just announced a HO 15HP motor. Be perfect for you as a trolling motor. Lots of amps to keep the battery charged also. Only problem is it weighs 177 pounds vs 135 for the heaviest of the other 15HP motors.
I think thats 81KG vs 61 KG.
Thought I'd give you a heads up.
Re: Curacao CS 25
Posted: Thu Feb 11, 2010 3:21 pm
by ks8
Nice!
Yep... we need a good lookin' live (modestly clothed
) body in there for scale (no Photoshop allowed).
Did you epoxy down that access plate for the potable water?
Re: Curacao CS 25
Posted: Thu Feb 11, 2010 7:46 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Feb 11, 2010 7:53 pm
Looks great Peter. I know you are glad that's over with
The sole is a milestone for certain. Yep. she'll be solid as a rock
Re: Curacao CS 25
Posted: Thu Feb 11, 2010 11:42 pm
by TomW
Peter it's on Evinrude's site. It was on the home page when I went to there site today, down in the lower left. If it's not there it's in the High Output section of the engines.
Re: Curacao CS 25
Posted: Fri Feb 12, 2010 7:16 am
by icelikkilinc
Grinded down a putty knife to create a somewhat beefier fillet as normal not to make it stronger but just because I think at sole level it looks nicer, normal I use the black mixing sticks
Same line of thinking Peter, that is what I used in my TW28.. in most areas where I felt more comfortable at fillets with it...
Re: Curacao CS 25
Posted: Fri Feb 12, 2010 7:19 am
by macs
Good job Peter. I know It's a great feeling to have the sole in place.
Macs
Re: Curacao CS 25
Posted: Fri Feb 12, 2010 5:29 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri Feb 12, 2010 5:31 pm
A bold move indeed
Re: Curacao CS 25
Posted: Fri Feb 12, 2010 5:49 pm
by peter-curacao
I copy paste this over here because didn't wanna blemish Larry B his thread
Cracker Larry wrote: I know a lot of people put PFDs on dogs, but I've never met a dog than can't swim better than I do, and I swim pretty good.
Is that so? compare here Larry
Remember Bulldogs are probably the worst swimming dogs! I think
Rambo the sea Lion
Re: Curacao CS 25
Posted: Fri Feb 12, 2010 6:03 pm
by Larry B
Peter, thats a nice looking hole in your hull
I'll bet that took guts to start drilling that one
Re: Curacao CS 25
Posted: Fri Feb 12, 2010 6:05 pm
by Larry B
peter-curacao wrote:I copy paste this over here because didn't wanna blemish Larry B his thread
No problem, blemish away
I think I blemish alot of threads and they haven't kicked me off the forum "yet"
Re: Curacao CS 25
Posted: Fri Feb 12, 2010 9:45 pm
Peter, Mrs. Cracker and I are sitting here watching it snow and thinking of you, down there where it's warm. I'm calling Delta tomorrow and we're going someplace south
This pic is for you and Gloria, bien vida...
Re: Curacao CS 25
Posted: Sat Feb 13, 2010 2:03 am
by chicagoross
Those Georgia winters are brutal!
Re: Curacao CS 25
Posted: Sat Feb 13, 2010 2:46 am
by icelikkilinc
something seems wrong there...
Re: Curacao CS 25
Posted: Sat Feb 13, 2010 9:15 am
by peter-curacao
icelikkilinc wrote:something seems wrong there...
Serious?
Re: Curacao CS 25
Posted: Sat Feb 13, 2010 10:57 am
by Bluefish2
I think Georgia has had more snow than Boston !!8O
Re: Curacao CS 25
Posted: Sat Feb 13, 2010 10:58 am
by Bluefish2
Re: Curacao CS 25
Posted: Sat Feb 13, 2010 3:39 pm
by peter-curacao
Cracker Larry wrote:This pic is for you and Gloria, bien vida...
Thanks Larry, Cheers
Re: Curacao CS 25
Posted: Sat Feb 13, 2010 3:46 pm
The bottle is almost empty
Not to worry, we have another
Re: Curacao CS 25
Posted: Sat Feb 13, 2010 3:59 pm
by peter-curacao
Cracker Larry wrote:something seems wrong there...
GOOD!!
But serious I hope icelikkilinc is just joking about that big hole
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 4:13 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 4:22 pm
Beautiful job Peter. First class scuppers there
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 4:51 pm
by ks8
Nice.
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 5:25 pm
by TomW
Beautiful Peter I was hoping you would do something like that. First class all the way!
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 6:04 pm
by Fonda@kauai
Hey! you stole my idea
I better post some pics of mine on my thread so people wont think I'm copying you
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 7:43 pm
by TJS Redchaser
Very Nice Peter,
All those little details that add man hours also make it look like an expensive custom built yacht. First Class
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 8:59 pm
by cape man
Man do I like that! Beautiful and way to think it through.
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 9:13 pm
by majorgator
I agree Peter, excellent work on the scuppers
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 9:17 pm
by chicagoross
Great Job, Peter! Now I'm embarrassed thinking back to when I thought fitting the boat out was time-consuming.
Re: Curacao CS 25
Posted: Mon Feb 15, 2010 9:57 pm
by colonialc19
Great Job!
Re: Curacao CS 25
Posted: Tue Feb 16, 2010 10:20 am
by wegcagle
WOW!!! You planning on driving through the Perfect Storm
I guess if you do it'll be with dry feet. Great job
Will
Re: Curacao CS 25
Posted: Tue Feb 16, 2010 6:11 pm
by Fabio
Great job Peter! Those scuppers recalls me the scuppers of my beloved (and sold) Mader built Flying Dutchman!
You did a neat and fine work!
Fabio
Re: Curacao CS 25
Posted: Tue Feb 16, 2010 9:24 pm
by Dougster
I gotta join in here, what a nice, thought out job. I love seeing how creative folks can be with a little glue, glass, and wood. Man, and I was fooling around splitting a piece of 4" PVC yesterday to see if it would work channeling water. Hats off to that job.
Knows it when he sees it Dougster
Re: Curacao CS 25
Posted: Wed Feb 17, 2010 2:31 am
by BassMunn
Hey Peter your boats coming along really nicely.
Those are the nicest scuppers I've seen, sort of like "Free Flow" scuppers.
Re: Curacao CS 25
Posted: Sat Feb 20, 2010 3:46 am
by fallguy1000
Greetings from snow covered Minnesota Peter. I spent a few hours reading your entire build tonight and was totally captivated until 2 am! I'm going to build the LB26 which is foam sandwich and not ply, but I really learned a lot and wanted to thank you for posting your successes and failures.
I bought plans and am planning to start in December of this year and am just doing research right now.
I thought about your chair space issues and you might consider after discussion with JM modifying the heights of the helm chairs (with a stepup as well) which would mean the bottom (smallest part) of the helm chairs would be higher. This might also give the captain better visibility over the bow and waves. We don't use fighting chairs here for Great Lakes fishing (fish too small), but I've seen pilothouses designed where the captains seats are raised up to allow for seating behind the captain (lower) on smaller boats. With a step up and a high seat for the captain, it allows for the top of the back of the other seat (your rodholders for example) to be at the bottom of the back of the other seat, saving a few precious inches or more if the captains seats are pedestal mounts. That said, I think the lawnchairs are probably a bit bigger than the seats you'd build.
And on the romantic and crazy notion about sailing with a powerboat. It isn't entirely impossible. Check out kiteship.com for a little fun.
Thanks again for sharing your build. It really helps give me more confidence and helps me see things I need to consider.
Dan Fall
Re: Curacao CS 25
Posted: Sat Feb 20, 2010 10:19 am
by peter-curacao
Tanks everybody for the nice reply's, really a morality booster
fallguy1000 wrote:Greetings from snow covered Minnesota Peter. I spent a few hours reading your entire build tonight and was totally captivated until 2 am! I'm going to build the LB26 which is foam sandwich and not ply, but I really learned a lot and wanted to thank you for posting your successes and failures.
You are very welcome it's a pleasure
fallguy1000 wrote:I thought about your chair space issues and you might consider after discussion with JM modifying the heights of the helm chairs (with a stepup as well) which would mean the bottom (smallest part) of the helm chairs would be higher. This might also give the captain better visibility over the bow and waves. We don't use fighting chairs here for Great Lakes fishing (fish too small), but I've seen pilothouses designed where the captains seats are raised up to allow for seating behind the captain (lower) on smaller boats. With a step up and a high seat for the captain, it allows for the top of the back of the other seat (your rodholders for example) to be at the bottom of the back of the other seat, saving a few precious inches or more if the captains seats are pedestal mounts. That said, I think the lawnchairs are probably a bit bigger than the seats you'd build.
Thanks for that, you know the helm seats are rarely if not never used here at least not when in plane simply because you will probably break your back or something if you do so, they are used when going at a very moderate speed and when troling so when not in plane at that point there is no problem looking over the bow.What I'm thinking of doing now (still not sure) is make something like in the racing boats, something like 2 horse shoes next to each other where you can lean in when in plane and when not in plane something like a seat in there that can flip up or down or something
fallguy1000 wrote:And on the romantic and crazy notion about sailing with a powerboat. It isn't entirely impossible. Check out kiteship.com for a little fun.
That's a cool site
yeah I brought it up because the local professional fisherman here al use sailing power as a backup on there motors so I thougt why can't I ?
why because completely different boats!
Here you have a few
Re: Curacao CS 25
Posted: Sat Feb 20, 2010 10:24 am
by icelikkilinc
Hej Peter
It looks much better now.. at the first pic, it seemed a bit low but with the scuppers on it looks neat..
I didnt want to upset you, I carefully follow your build as you are doing a very nice job...
Re: Curacao CS 25
Posted: Sat Feb 20, 2010 10:32 am
by peter-curacao
icelikkilinc wrote:Hej Peter
O no you didn't upset me, but I thought you saw something I was missing at that point, well they are level with the sole,thanks for thinking with me
RE: The wind there.
Posted: Sat Feb 20, 2010 11:05 am
by fallguy1000
I suppose with the wind there, if your motors conked out, you'd be blown away fast. Considering that, I'd try to build some redundancy into my plans, like 2 batteries or a kicker motor with a small tank of its own. I recall an Egyptian airliner crash where 13 or so were killed when a fuel gauge failed(actually it was the wrong gauge there). I don't know if you use kickers there, but if you single on the ob, then I wouldn't want to go out without a kicker that could get me home slow at least in a big blow.
What all is going in your 3" pvc tube..just the fuel line(s)? I'm asking because I didn't think you could run electrics and fuel lines in the same chase and pass USCG, but I'm a rookie, not an expert, and I might have missed it late last nite, and was curious.
Re: RE: The wind there.
Posted: Sat Feb 20, 2010 11:14 am
by peter-curacao
fallguy1000 wrote:I suppose with the wind there, if your motors conked out, you'd be blown away fast. Considering that, I'd try to build some redundancy into my plans, like 2 batteries or a kicker motor with a small tank of its own. I recall an Egyptian airliner crash where 13 or so were killed when a fuel gauge failed(actually it was the wrong gauge there). I don't know if you use kickers there, but if you single on the ob, then I wouldn't want to go out without a kicker that could get me home slow at least in a big blow.
Yep a kicker is the plan! although I don't really like the looks of it, the pro's here convinced me to go for that, so that's what I'm doing, the 3" pipe is for steering hoses and gas cables, you are right
for fuel I have a different trace pipe, thank god boats can't fall down
seating and traces
Posted: Sat Feb 20, 2010 11:21 am
by fallguy1000
ahh, the steering hydraulics, now I get the sizing...thanks I'll need to do the same/similar
the boats you compare to for the helm seating, are those mostly charters? I ask because the charter captain probably doesn't get much time for a comfy sit, but I think you and friends and family might enjoy better seating at the helm than just a lean post and if you and the Mrs. go out fishing together and she is running the boat sometime, she'd probably get weary fast of just the standing... my wife is a super tomboy but she wouldn't like to stand the whole while... just my thoughts
We have hydraulic seating in our small boats here so the chairs can be lowered for running fast and raised when fishing, etc.
Re: seating and traces
Posted: Sat Feb 20, 2010 11:04 pm
by peter-curacao
fallguy1000 wrote:if you and the Mrs. go out fishing together and she is running the boat sometime, she'd probably get weary fast of just the standing... my wife is a super tomboy but she wouldn't like to stand the whole while... just my thoughts.
Come on over and you will understand much better and faster for sure I think
Re: Curacao CS 25
Posted: Sun Feb 21, 2010 8:13 pm
by fallguy1000
sorry if I spoke out of place, no disrespect intended..
Re: Curacao CS 25
Posted: Sun Feb 21, 2010 8:54 pm
by peter-curacao
fallguy1000 wrote:sorry if I spoke out of place, no disrespect intended..
Jeeeez blabber all you wanna
Re: Curacao CS 25
Posted: Sun Feb 21, 2010 9:19 pm
It's very hard to sit in a seat, and very easy to get hurt trying, in 12 foot seas
Probably about average conditions in Curacao.
Strabagante luna, si Peter
Re: Curacao CS 25
Posted: Mon Feb 22, 2010 9:27 am
by Murry
Wow Peter,
I hope you don't mind if I copy your scuppers one day.
What did you use for the mold? I couldn't make it out in the photo.
I'm with you on the larger radius fillets, that's going to look very nice.
Great job
Daniel
Re: Curacao CS 25
Posted: Mon Feb 22, 2010 10:16 am
by peter-curacao
Murry wrote:Wow Peter,
Daniel
I be honored if you do, the mold for the pipe you mean? if so I used a 2x4 and a 2x2 taped those together with masking tape, not to much just on the ends because later the tape must be able to break, then I took a 2' pipe and cut that in half, tape those around the wood with packaging tape(the tape doesn't touch the wood) after the glass cured put only the 2x4 in the vice and hammer out the 2x2 after the wood is removed you can twist out the two pipe half's and packaging tape fairly easy.
Re: Curacao CS 25
Posted: Mon Feb 22, 2010 10:21 am
by peter-curacao
Cracker Larry wrote:It's very hard to sit in a seat, and very easy to get hurt trying, in 12 foot seas
Claro!! but I don't mind fallguy trying to talk me into it, so no harm done there fallguy don't worry
Hey now I think I understand! Fallguy wasn't that a series in the 80's about a stuntman ?
Re: Curacao CS 25
Posted: Mon Feb 22, 2010 10:55 am
by fallguy1000
Yes, fallguy was from the series with Lee Majors, and it easily became my nickname because my last name is Fall.
On this thread, understanding now what I didn't then, hope I don't get called foolguy.
Its hard for me to fathom the idea of 12' seas typical, even 6 footers. We were on George's Strait in 2007 in my 16 foot Lund Predator (a decent boat), and no way could we fish in about 5 footers. Of course, that was tiller steering and wasn't ready to kill my new wife on our honeymoon for a couple seal chased salmon. We went into the fjords (inlets) and caught some rockcod.
What drives the waves to get that big there? It must be winds coming down off mountains or something, cuz I thought Curacao was kind of protected by Venezuela when I looked on the map last, but what do I know.
What's next on the build Peter?
Re: Curacao CS 25
Posted: Mon Feb 22, 2010 11:08 am
FG, the winds in Curacao are coming all the way from Africa, howling towards Venezuela, all the time. Every tree on the island points towards South America
Re: Curacao CS 25
Posted: Mon Feb 22, 2010 11:13 am
by peter-curacao
We are below the hurricane belt but we are located in the middle of the trade winds, what is I think the main reason.Those winds are north/east so Venezuela doesn't do much for us.
about the build I'm in the middle of framing waiting for a thumps up from Jacques concerning frame B
Re: Curacao CS 25
Posted: Mon Feb 22, 2010 5:48 pm
by Murry
peter-curacao wrote:Murry wrote:Wow Peter,
Daniel
Yes, that's the one.
Thanks Peter.
Re: Curacao CS 25
Posted: Tue Feb 23, 2010 10:43 am
by peter-curacao
Re: Curacao CS 25
Posted: Tue Feb 23, 2010 10:52 am
by Larry B
Peter, those frames look nice.
Question, do you have a air conditioner for every room in the house????? And you must be one skinny fellow to get between the boat and the house
And I see the Pondering Chair
Re: Curacao CS 25
Posted: Tue Feb 23, 2010 11:45 am
by TomW
Looking good Peter did you decide to cut them back to 8" or keep them the original width.
Re: Curacao CS 25
Posted: Tue Feb 23, 2010 4:30 pm
I've had the pleasure of meeting him, and I can tell ya he ain't gonna fit through that crack
Frames look good Peter, much better
Re: Curacao CS 25
Posted: Tue Feb 23, 2010 5:34 pm
by gstanfield
Very nice, I too await the splash of this boat. If I had the money to build any boat the JM makes this boat would be on the top three for me to decide from. You're doing an awsome job so far and I'm sure the finished results will be nothing less than stellar.
George
Re: Curacao CS 25
Posted: Tue Feb 23, 2010 5:59 pm
by macs
Looking good Peter. Looks like your going to need a Leroy Jethrow Gibbs solution to get that thing out
Macs
"Rule # 9 - Never go anywhere without a knife"
Re: Curacao CS 25
Posted: Fri Feb 26, 2010 6:42 am
OK Admittedly, I'm pretty tough to impress, and I've made ya blush by sayin it before, but you are an inspiration to be sure. I've been a little busy here lately and haven't been to your thread since before you started the scuppers. So Imagine my delight when I stopped in for a little boat porn
I tell ya what, you may be the cause of a lot of guys not wanting to post pictures of their builds
You're a tough act to follow
As usual, nice work, imaginative methods and some of the trademark attention to detail. I'm telling you, between you and CL I'm gonna have to work very hard, keep the shop nice & neat, avoid gluing the Shit-Tzu to the boat, and really be on my craftsmanship game before I'm showing anyone any pictures of the build. As always, thanks and keep the pics comming. TD3 ( Brett )
Re: Curacao CS 25
Posted: Fri Feb 26, 2010 8:05 am
by Dog Fish
Hay Peter
I haven't been on here in a while either. I went back some pages and wow, great job. Not only have you done really good work, but you have come up with some great ideas. Must be that green Rum ( or something else
) that helps you come up with this stuff. The boat sure is starting to take shape, keep up the good work.
Brian
Re: Curacao CS 25
Posted: Tue Mar 02, 2010 5:53 pm
by peter-curacao
Click here for ->
Tuna tubes
Re: Curacao CS 25
Posted: Thu Mar 18, 2010 7:16 am
by cape man
Peter,
What's going on down there?
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 6:58 pm
by peter-curacao
Hey Cape thanks for asking I appreciate your concern I'm almost afraid to tell,but yeah I'm having health problems again and that's the third time in about two/three years? (the time I'm on this forum) and I hate to tell because I see myself as a strong person, maybe I'm getting old? nahhh anyway I'm almost every week in surgery because of a ciste (if it isn't the same I don't know the English name}I have on my lower jaw, so I have a wound in my mouth that has to stay open to release pressure from that ciste it's very irritating and yes it hurts ones in a while so that keeps me from boatbuilding and when I'm in better days and like to do some building Gloria prohibit me from it because she is worried that that wound will infect from the dust etc. maybe she is right but I'm not a happy camper at the moment!
Again thanks for your concerns
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 7:02 pm
by Larry B
Get Well Peter, we miss your comments around here.
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 7:05 pm
by TomW
Peter sorry to hear about the ciste that has to be painful and irritating. Follow Gloria's good sense and let it heal before you get into the dust again. Better to slow down and keep your health than try to get the boat done and maybe have more problems.
Take care and get well my thoughts are with you!
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 7:23 pm
by Spokaloo
Peter, thats starting to drift into my family's line of work. Let me know if you need any referrals.
Get better!
E
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 7:42 pm
by Dog Fish
Bummer dude, Very sorry to hear of your troubles. I have been wondering where you got off to, sounds like not such a good place, that really sucks. Take care of yourself
and get well soon Peter.
Brian
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 9:10 pm
by peter-curacao
Spokaloo wrote:Peter, thats starting to drift into my family's line of work. Let me know if you need any referrals.
Get better!
E
Too be honest I'm thinking I'm getting a medieval treatment! we have if I'm informed the right way two jaw cutters here! that does say enough don't it?
thanks
peter
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 9:53 pm
Sorry Peter, sure hope you recover fast
Fast enough to meet us at Boca Grande
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 10:13 pm
by Dougster
Sorry to hear it. It sounds miserable too, pain up in your mouth is too close to home, hard to get away from it. I'm thinkin' a little work could be tonic but not so much if dust makes it worse. Maybe, there's something needs doing that won't make dust? I dunno but I'm pulling for you. Anyway, I'm lucky like you in having someone to fuss over me. Can't beat that.
Knows what matters Dougster
Re: Curacao CS 25
Posted: Fri Mar 19, 2010 10:32 pm
by Aripeka Angler
Peter, hope you get well soon so you can get back to boat building and posting funny stuff. It's no fun to suffer and not be able to do what makes you happy.
Wishing you a speedy recovery....
Richard
Re: Curacao CS 25
Posted: Sat Mar 20, 2010 7:10 am
by cape man
Sorry and glad I asked. Get better dude! I need that boat finished when I come down there!
Re: Curacao CS 25
Posted: Sat Mar 20, 2010 9:19 pm
Your in my thoughts too Peter, rest, get well. Wish there was more I could do. For now, take it easy and listen to the "better half" I've found mine to be much more realistic, and sensible than I am when it comes to the health related stuff.
Take care TDDD (Brett)
Re: Curacao CS 25
Posted: Sat Mar 20, 2010 9:31 pm
by johnymarlin
rest up and get well soon peter youve got a great thread and boat happening cant wait to see and read more
john
Re: Curacao CS 25
Posted: Sun Mar 21, 2010 3:30 am
by pkar
Hello Peter, I'm sorry to hear it, but don't worry, strong men recover fast !!
panos
Re: Curacao CS 25
Posted: Mon Mar 22, 2010 7:40 am
by Murry
I second all those responses Peter.
Get Well Soon,
Daniel
Re: Curacao CS 25
Posted: Wed Mar 24, 2010 11:09 am
by Mad Dog
Missed seeing your posts Peter could help but wonder what was going on. Hey, we all sick and hurt from time to time. The wise man pursues good health not worrying about what other men might think. You do what you need to get well as soon as possible. When you start feeling the blues just pop back on the forum and let us help cheer you up.
That's part of the community you belong to here.
Praying for your healing... MD
Re: Curacao CS 25
Posted: Thu Mar 25, 2010 10:09 pm
by peter-curacao
Thanks everybody I really miss you guys I really do !!! I thought if I don't look I can't miss it! tonight I couldn't resist! damn me! so I took a peak here again and saw all those nice messages thanks for those! trying to get back on it as fast as possible!
As it for now click my signature on the bottom and enjoy! if you saw it already for lets say a hundred times! just shout and I change it to a new one
Re: Curacao CS 25
Posted: Fri Apr 09, 2010 8:20 am
Hey Peter! Been a couple of weeks since we've heard anything from you here. Hope you are well, no big problems.
Looking forward to hearing from you,.. pretty concerned about you. I'm not alone hoping you get back in action soon, can't wait for you to get back to building, but not till you're ready. I need the inspiration. Let us know how you're doing OK?
Re: Curacao CS 25
Posted: Sat May 22, 2010 7:59 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat May 22, 2010 8:14 pm
by BassMunn
He Lives
Nice to see you back Peter!
That's a pretty impressive livewell system you got going there, very nice
Re: Curacao CS 25
Posted: Sat May 22, 2010 8:28 pm
by Larry B
very nice work there Peter, beautiful
Re: Curacao CS 25
Posted: Sat May 22, 2010 11:36 pm
by wegcagle
WOW
Now that's ALOT of work for a livewell system. Totally worth it when you're dragging those billfish over the sides.
Damn impressive,
Will
Re: Curacao CS 25
Posted: Sun May 23, 2010 2:16 am
by TomW
Great work Peter! It looks wonderful and you should get a lot of use out of it.
Re: Curacao CS 25
Posted: Sun May 23, 2010 7:59 am
Re: Curacao CS 25
Posted: Sun May 23, 2010 9:53 am
Nice job Peter
Great design, well executed and you even named them after us
Re: Curacao CS 25
Posted: Sun May 23, 2010 12:37 pm
by cape man
That is awesome!!! I REALLY like that versus the ones on the back of the transom. You should sign and date the original drawings. Lot's of witnesses here of the originality of the design.
Re: Curacao CS 25
Posted: Sun May 23, 2010 5:08 pm
by macs
Sweet
Macs
Re: Curacao CS 25
Posted: Sun May 23, 2010 8:53 pm
made ice boxes from P3 ducting material and finished those with Formica,
Did I understand you to say that the cooler boxes pictured here, are finished in formica? If so, how may I ask did you get the radius corners? I can't see an epoxy seem ? You are crafty, or I am lost, or maybe both. Can you elaborate on how you built and finished those cooler boxes? Please
Re: Curacao CS 25
Posted: Sun May 23, 2010 8:57 pm
by topwater
Thistle to me it looks like he built the box with square corners and then filleted a radius and painted.
knowing peter i am probably wrong.
Re: Curacao CS 25
Posted: Sun May 23, 2010 9:31 pm
by peter-curacao
topwater wrote:Thistle to me it looks like he built the box with square corners and then filleted a radius and painted.
No I think, not sure you are right! not sure about the question either! Everything is done with epoxy! gluing the Formica to the duct material, the fillets are epoxy too, tinted with a white pigment and thickened with a West 406 silica filler, hope this helps?
Re: Curacao CS 25
Posted: Sun May 23, 2010 10:02 pm
Yes Peter it Does! I didn't realize epoxy would make a reliable bond to formica. I guess I never really thought about it though. I know it is stuck all over the formica top on my workbench.
With no hope of ever getting it off. Well that opens up a whole new material for me to explore. Now that I'm actually building stuff ( even if it's not the hull yet ) the questions seem to come a lot more often than when I was sitting in the wings just watching all you other guys build stuff. Thanks for the great pictures, and all the advice. Glad to see you posting again.
Re: Curacao CS 25
Posted: Sun May 23, 2010 10:23 pm
by wegcagle
Thistle,
Epoxy binds to all sorts of stuff, fiberglass, wood, formica, concrete, graphite, metal. hair, skin, fingernails, and new clothes
Somehow I know all of this from experience
.....and all in the last year
Will
Re: Curacao CS 25
Posted: Sun May 23, 2010 10:56 pm
by peter-curacao
not completely
Re: Curacao CS 25
Posted: Sun May 23, 2010 11:22 pm
Epoxy will glue 100 pound dogs to concrete
Formica is no obstacle
Re: Curacao CS 25
Posted: Mon May 24, 2010 8:36 am
by peter-curacao
I did rough up the corners with the Dremmel and a pointy sand bit, just to be sure.
Re: Curacao CS 25
Posted: Mon May 24, 2010 8:59 am
by gk108
I recently decided to re-cone some of my concert sound system speakers myself, instead of letting UPS bust them during shipment. The kits come with all parts that must be glued together on the magnet frame to get proper alignment. The voice coils are wound on a core made of a material very much like formica. There is one glue joint that joins the voice coil, cloth suspension and paper cone with a bead of epoxy. There's a bunch of different ways those big speakers can fail, but I've never had one come apart at that glue joint.
Re: Curacao CS 25
Posted: Mon May 24, 2010 10:26 am
by peter-curacao
cape man wrote:You should sign and date the original drawings. Lot's of witnesses here of the originality of the design.
I don't have drawings
I made it free handed as it comes to mind (Or how do I say that?
Re: Curacao CS 25
Posted: Mon May 24, 2010 11:13 am
by peter-curacao
Re: Curacao CS 25
Posted: Mon May 24, 2010 11:48 am
by Aripeka Angler
Man your boat is looking sweet
I like the lines of the hull, that is going to be a really pretty boat
Good to see you are back at it. Continued good luck on your boat
Richard
Re: Curacao CS 25
Posted: Mon May 24, 2010 2:04 pm
by TomW
All right Peter looking great that is going to be a very super boat for you.
Re: Curacao CS 25
Posted: Tue May 25, 2010 7:09 am
by Joe H
I also like the line's, if I had the patients that the boat I would be building next!
Very nice.
Joe
Re: Curacao CS 25
Posted: Tue May 25, 2010 10:27 am
by cape man
Man you do good work! Nice.
Re: Curacao CS 25
Posted: Tue May 25, 2010 6:03 pm
by TJS Redchaser
Seriously Peter, that is going to be one pretty lady when shes all done. Keep on Keepin on!
Re: Curacao CS 25
Posted: Sun May 30, 2010 3:07 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun May 30, 2010 3:16 pm
Looking good Peter
Really nice router work on the hatches! Not sure that you need lids for the tubes, when in use the tails of the bait will stick out of the tubes anyway.
Re: Curacao CS 25
Posted: Sun May 30, 2010 4:19 pm
by wegcagle
Beautiful work Peter. I gotta get better at my router. You guys are putting out some amazing builds with that tool
I agree with Larry on the tuna tubes. I've never seen one with a lid, but I'd be a liar if I said I grew up with tuna tubes
I think I would cut a circular trim piece around the tuna tube opening, and leave it wood finished. Maybe use some teak??
What can I say I'm a sucker for wood grain finishes.
Will
Re: Curacao CS 25
Posted: Sun May 30, 2010 4:47 pm
by BassMunn
Peter as usual, awesome attention to detail.
Love the clear baitwell lid
Re: Curacao CS 25
Posted: Sun May 30, 2010 5:28 pm
by Jaap
Very nice Peter! A lot of work on a fishing detail I never heard of
I does more and more look like a boat, and more and more details need attention!!
jaap
Re: Curacao CS 25
Posted: Sun May 30, 2010 6:34 pm
by cape man
Fantastic Peter. Very accessible and perfect position. Did you router out a recess for the hinges in the clear lid?
Re: Curacao CS 25
Posted: Sun May 30, 2010 7:44 pm
by ks8
You've done it again Peter... gotten me to walk away from this life draining computer and back out to the garage. Beautiful work as usual.
Re: Curacao CS 25
Posted: Mon May 31, 2010 7:08 pm
by peter-curacao
Thank you all for the compliments, always nice to hear your work is appreciated!
today started with the second half of the rubrail and did a test setup with the gas springs on my cooler,and guess what! they push the hatch open but they also push the hatch closed, that makes me very happy
no need for locks or things like that just a pop up pull ring! nice and clean
As for the questions
wegcagle wrote:I agree with Larry on the tuna tubes. I've never seen one with a lid,
Will
I agree but those doesn't have a function of filling the live bait tank also, so when the tubes are not in use I like to be able to close them so the water won't spill out of the tubes but into the baitwell
cape man wrote:Did you router out a recess for the hinges in the clear lid?
Yes I did, it was a bit tricky certainly not the same as routing wood.
Jaap wrote:A lot of work on a fishing detail I never heard of
jaap
Maybe you can take a peek here if you are interested in it, and wanna know more about it
http://forums.bateau2.com/viewtopic.php?f=6&t=22697
Re: Curacao CS 25
Posted: Mon May 31, 2010 8:37 pm
by cape man
Certainly not. Just drilling a hole is a bitch.
Re: Curacao CS 25
Posted: Tue Jun 01, 2010 11:14 pm
by peter-curacao
Re: Curacao CS 25
Posted: Tue Jun 01, 2010 11:20 pm
by TJS Redchaser
Peter, beautiful as usual. The hatches are really nice. I like the gas tubes.
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 10:51 am
by peter-curacao
Ideas wanted!
Is there a other more decent way to do this? I really don't like it this way
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 11:01 am
What are you referring to Peter? The cut out area for the hinge bolts?
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 11:03 am
by peter-curacao
Cracker Larry wrote:What are you referring to Peter? The cut out area for the hinge bolts?
Yes I do.
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 11:08 am
OK, instead of the long bolts with acorn nuts, how about flush mounting T-Nuts. Then nothing will protrude
or barrel bolts
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 11:19 am
by peter-curacao
I tried to find those barrel nuts in stainless, but as you guess without any success, so I think those flush mounting T-Nuts are certainly out of the question.I was very surprised I found those gas springs and there brackets over here, had to rebuild them a bit and make the clips out of those
though
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 12:03 pm
I forget you have a supply problem. I'd be glad to send you some, but we already know it will take a month and cost $100 in shipping. No problem if you want me to do that.
How about we just use epoxy and cast the threads directly into the hatch? Drill the holes slightly over size, dam the bottom with tape and fill with thickened epoxy. Use a sacrificial bolt, coat the threads with a release agent and set them in the wet epoxy. When the epoxy cures, remove the sacrificial bolt and it will leave you with a strong threaded hole all the way through.
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 12:16 pm
by peter-curacao
Cracker Larry wrote:I forget you have a supply problem. I'd be glad to send you some, but we already know it will take a month and cost $100 in shipping. No problem if you want me to do that.
Great Idea Larry this could work for the cooler doors if they where thick enough, since they are only nine mm I think minus the recess for the hinges I simply don't have enough "flesh" to make a strong glue connection
. as for the glass door this idea won't work, no I think we have to find a cleaner solution for the cut out area
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 12:29 pm
You are a hard man to satisfy
I think you have plenty of thickness in the plywood for it to work, epoxy is some strong stuff.
Not sure what to suggest about the glass door
Find the hardware you want and I'll get it and mail it to you. Is it possible to tap threads into lexan
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 12:43 pm
by Jaap
You can use a 4 mm strip of aluminium or ss and use that as an insert under the hatches. 4 mm is enough for m5 or m6 thread and if you use one large strip for both the hinges you have just enough thickness in the ply for a recess for the hinges as well as the insert.
Another option is to glue the hinges with epoxy or polymere kit to the hatches and use small srews to fasten the hinges as well.
Grind away the overlenght of the screws, I thing that would be strong enough. There is a special primer for glueing stainless steel with epoxy.
Now I understand your tuna tube! Thanks, would it suit zoute haring as well? Next week Haring Party!!
jaap
Re: Curacao CS 25
Posted: Wed Jun 02, 2010 10:04 pm
by Murry
Your boat is loking fantastic Peter.
I get more and more excited about building a CS evertime you post your progress.
Thanks for shareing it with us,
Daniel
Re: Curacao CS 25
Posted: Thu Jun 03, 2010 2:37 am
by TomW
Peter I can get these in SS for you
Let me know if you want them.
Re: Curacao CS 25
Posted: Thu Jun 03, 2010 12:02 pm
by cape man
Peter,
My hatches are the same thickness as yours. For the hinges I drilled the holes oversize, filled with epoxy and wood flour, and then drilled a hole for a tight fit with a short SS screw smeared with 5200. 8 months later I have not seen any of these show any sign of weakening or wallowing out, and I don't have the additional support of the gas shocks that you do. I think you are over thinking this and worrying about something you don't need to. Get rid of the bolts and nuts that are bothering you and screw those babies in.
Re: Curacao CS 25
Posted: Thu Jun 03, 2010 2:12 pm
by Knottybuoyz
Air brakes? I thought trim tabs went on the bottom of the boat!
Sorry Peter, couldn't resist.
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 5:34 pm
by peter-curacao
Thank you all for the advice and sending stuff offers, but I decided to take a bit of a shortcut as you can see in the pics, still not crazy about it but a lot more decent as the gap before I think
, well I think I can live with it especially when everything is in white later, also mounted the pull rings.
Reason I kept the bolt and nut, is because of the gas springs those hinges are always under pressure when the hatches are closed, I just chickened out and didn't dare to go with such short screws
Knottybuoyz wrote:Air brakes? I thought trim tabs went on the bottom of the boat!
That's the reason I talked about the F1 season also, no problem I can appreciate a good joke
Use a ball grinding bit in the dremmel
on this flange it was more burning instead of grinding
but it did work
The pullrings
The airbrakes
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 5:53 pm
I can't get over what a nice job you did on that bait tank
Just wondering, why did you decide on a clear lid?
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 6:03 pm
by peter-curacao
Cracker Larry wrote:I can't get over what a nice job you did on that bait tank
Thank you Larry, well I went with a clear lid because one (Cooper) told me that was the way to go, his story made kind of sense to me
http://forums.bateau2.com/viewtopic.php ... 70#p202266
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 6:12 pm
OK, thanks, I've never seen many clear ones, but it may be better
I don't know, can't hurt, looks cool
I like livewells with a clear lid. I think it's better for the baits. When an opaque lid is closed, the baits chill out and hang by the bottom. Then they freak when you open the lid. I think repeating that all day is more stress than just having a clear lid where they can see daylight. 1/2" plexi is perfect for a lid.
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 6:31 pm
by gk108
I recently read an article about the interior color of your bait tank making a difference. The author was of the opinion that white and light color interiors caused the bait to act differently and even lighten their own color. Colors between battleship gray and pea soup green apparently didn't cause such reactions.
I dunno. I thought my bait was supposed to act different and attract attention. Although the predators might just go after bait acting wounded, not bait acting crazy.
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 6:38 pm
by peter-curacao
gk108 wrote:I recently read an article about the interior color of your bait tank making a difference. The author was of the opinion that white and light color interiors caused the bait to act differently and even lighten their own color. Colors between battleship gray and pea soup green apparently didn't cause such reactions.
I don't know either I just followed the advice cause it made kind of sense, on the other hand maybe it's best to have a bait well in the color of the baits natural surroundings, in my case the blue would be okay then, but in lakes and rivers in the US I can imagine that battleship gray and pea soup green are better, again I have no clue I'm just guessing!
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 6:44 pm
by Spokaloo
Reminds me of the bait tanks on Blackfin boats with the clear lid and the clear window on the bow side of the tank. Light is right!
E
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 6:47 pm
by gstanfield
If we're going with paint the color of their "natural" water then I'd have to go with a dark brown here
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 6:49 pm
by TomW
Light is good Peter and turn on a light at night if your still fighing that late or keeping bait overnight.
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 6:57 pm
by peter-curacao
Spokaloo wrote:Reminds me of the bait tanks on Blackfin boats with the clear lid and the clear window on the bow side of the tank. Light is right!
E
Good glad to hear that!! thanks for clearing that up
Just looked them up I kind of like them(Blackfin boats)
gstanfield wrote:If we're going with paint the color of their "natural" water then I'd have to go with a dark brown here
TomW wrote:Light is good Peter and turn on a light at night if your still fighing that late or keeping bait overnight.
Thanks Tom I thought about that
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 7:32 pm
by gk108
All I have is a 5 gal. bucket and a bubbler.
If I ever use it again, I guess I'll keep on using the white bucket. Maybe paint the outside blue.
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 8:04 pm
by peter-curacao
gk108 wrote:All I have is a 5 gal. bucket and a bubbler.
Am In overdoing it? you mean?
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 8:08 pm
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 8:10 pm
by gstanfield
You guys sure are going through a lot of trouble to take live fish with you. If I had a bucket of fish to start with I would just stay home
It's like taking a couple bunny rabits deer hunting with you isn't it
OK, maybe not
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 8:16 pm
by peter-curacao
gstanfield wrote: It's like taking a couple bunny rabits deer hunting with you isn't it
Deer eat rabbits nowadays?
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 8:23 pm
by gstanfield
OK, maybe that was a bad example
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 9:28 pm
by peter-curacao
gstanfield wrote:OK, maybe that was a bad example
But funny it was!
Re: Curacao CS 25
Posted: Fri Jun 04, 2010 10:14 pm
by gk108
Not at all. Call it sufficient overkill, which is a better than good rating by my system.
All I have to do is keep a dozen shrimp alive long enough to feed the redfish and speckled trout. Last year I used some Gulp fake shrimp and never got around to buying live ones.
Re: Curacao CS 25
Posted: Sat Jun 05, 2010 1:49 am
Ya reckon those bait have a night light in their natural environment? Fish ain't scared of the dark, they're in the dark every night
Re: Curacao CS 25
Posted: Sat Jun 05, 2010 1:56 am
No, it's like taking bunny rabbits on a mountain lion hunt. Yes, we do go to a lot of trouble with our bait
We stay up all night catching it, or spend $200 buying it, and we'll take 200 or more live fish, and 50 pounds of dead bait with us when we leave the dock, and plan on spending another $300 in fuel and ice getting to the fishing grounds offshore and back, so yes, we take our bait very serious.
No live bait, no big fish
Any one of which hopefully won't fit in a bucket
Re: Curacao CS 25
Posted: Sat Jun 05, 2010 9:08 am
by cape man
For baits that like to jump out (mullet, ballyhoo, flying fish) the clear tops help a lot. They may try and jump out but eventually stop when they keep hitting the lid. With a solid lid, they start jumping everytime the top comes open. I didn't use one as I fish primarily with herring and/or pinfish, and wanted to use the lid as a place to stand. You can stand on 1/2" plexiglass, but it's pretty slick! The light helps you find the fish at night, but does nothing to help them stay alive. They actually last longer in the dark as they calm down.
Re: Curacao CS 25
Posted: Sat Jun 05, 2010 2:22 pm
by TomW
For non-schooling fish/shrimp that aren't constantly swimming totally agree. For schooling fish swimming all the time here is what the experts say and I agree with it and would rather have the light.
There are mixed reviews on the importance of using a bait light in your tank at night. Some anglers feel it's a must while others have been successful without any lights. The theory is, in a dark tank, the bait will injure themselves since they can't see the sides of the tank. Positioning a light over the tank will work.
So choose your way there are theories in both ways. Do it however you want. Craig sure has the experience from his fish farms. I've always used a light on the Great Lakes and Mississippi. You don't keep some of the smaller tender live bait we use without one, they'll be dead by morning from hitting the walls.
Re: Curacao CS 25
Posted: Sun Jun 13, 2010 10:37 pm
by peter-curacao
I put up a new entertainment center last week for the WC Soccer!
Sideslippa what the hell was that today against Germany??
Re: Curacao CS 25
Posted: Sun Jun 13, 2010 11:03 pm
Tom, no offense, but I think that the Director of Aquaculture for the University of Florida might have just a little experience keeping fish alive in a tank
Craig is an expert, the expert, one of the top in the entire world, more so than anyone else you or I have ever met, and anyone you are likely to ever meet
You telling Craig what experts say about keeping fish in a tank is like me telling the Lone Ranger how tight to wear his mask, what to feed Silver and how much powder to put in those bullets
There is a reason Craig travels the globe, advising governments and nations on how to raise fish to feed their populations wink: I'm sure your experience is vast in this field, but there comes a time to listen and ask questions, not answer them
Re: Curacao CS 25
Posted: Sun Jun 13, 2010 11:05 pm
by Doc_Dyer
Re: Curacao CS 25
Posted: Sun Jun 13, 2010 11:07 pm
Bradley, sorry, my BS tolerance is especially low tonight
Re: Curacao CS 25
Posted: Sun Jun 13, 2010 11:08 pm
by peter-curacao
Cracker Larry wrote:For non-schooling fish/shrimp that aren't constantly swimming totally agree. For schooling fish swimming all the time here is what the experts say and I agree with it and would rather have the light.
Tom, no offense, but I think that the Director of Aquaculture for the University of Florida might have just a little more experience keeping fish alive than you do
Craig is an expert, more so than anyone else you or I ever met, and anyone you are likely to ever to meet
You telling Craig what experts say about fish is like telling the Lone Ranger how to wear his mask and what to feed Silver
There is a reason he travels the world, advising nations on how to raise fish
I'm sure your experience is vast, but there comes a time to shut up, listen and ask questions, not answer them
You Americans didn't played so well either!
Re: Curacao CS 25
Posted: Sun Jun 13, 2010 11:11 pm
by Doc_Dyer
Have an extra tall tottie tonight
It will make it better
Hi Peter nice Tv
Re: Curacao CS 25
Posted: Sun Jun 13, 2010 11:15 pm
Our goalie isn't being benched though
We tied those Brits yesterday, and I only know that because my soccer playing niece was over and watched the game at our house
I don't know squat about soccer myself.
And Peter, that is a very nice setup
I know something about electronics, probably not as much as Craig knows about fish, but that's real nice
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 9:27 pm
by peter-curacao
Doc_Dyer wrote:Hi Peter nice Tv
Cracker Larry wrote:And Peter, that is a very nice setup
Thank you both I'm still waiting for my glasses to enjoy it fully
but I have to say and I didn't think of that when posting the pic, that this stuff is a lot cheaper here as in the US or Europe don't ask me why but it is, if I had to pay the same as in Europe for a TV like this I would never do it, or at least wait until affordable.What I want to say is I didn't want to be a showoff (when I wrote back it looked a bit like that to me sorry about that
)I just was happy with my new toys and the setup work (+/-2 days) I did.
And yeah today we won 2 to 0 but we played so badly it's a shame
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 9:52 pm
How many runs did they score
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 9:53 pm
by peter-curacao
Cracker Larry wrote:How many runs did they score
what's a run?
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 10:03 pm
by Doc_Dyer
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 10:07 pm
I told yall I don't know squat about soccer
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 10:08 pm
by peter-curacao
Doc_Dyer wrote:
Man that must a been one tall toddy
What the hell is a toddy? and when did you sneak that signature in, in that previous post? hilarious
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 10:14 pm
by peter-curacao
Cracker Larry wrote:I told yall I don't know squat about soccer
Just from knowing you in person for 2 days?I think if you understand it, I think you will like it, it's a no nonsense game IMHO
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 10:24 pm
I've been forced to learn more about it lately because my niece, my brothers daughter, is a junior high soccer star
Get's her name in the paper every week and colleges are already trying to sign her up. She's only 15, but about 6'1 and nothing but hard body
You didn't tell me how many touchdowns they made?
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 10:29 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 10:43 pm
by Aripeka Angler
You spilled the beans. I have been enjoying that for two weeks
BTW, what is up with that humming racket on the WC games
It sounds like a swarm of bees..
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 10:51 pm
Yep
I'm surprised it took this long.
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:04 pm
by peter-curacao
Aripeka Angler wrote: when did you sneak that signature in
Yeah I'm with you on that ! it's a replica of an African instrument it drives me nuts also! especially with that new setup of ours! it goes around the room like a fly looking for shit
I think not sure this is a original
And this one commercially drained until the last cent
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:05 pm
by Aripeka Angler
Kind of deserves a response like" that is what she said"
Sorry Peter for the hijack
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:06 pm
by peter-curacao
Yep
I did! where?
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:09 pm
by peter-curacao
Aripeka Angler wrote:I'm surprised it took this long.
I don't care! hijack all that you want! as long you guys have fun it's okay by me ! use/abuse my thread as often and much as you like! but please keep it nice
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:13 pm
by Aripeka Angler
My son is a sports nut. We have been watching alot of the games. The dang buzzing was so bad during the US vs UK game that I was wondering if I needed some medical help
I didnt know it was a musical device
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:18 pm
by peter-curacao
Aripeka Angler wrote:Yeah I'm with you on that ! it's a replica of an African instrument it drives me nuts also! especially with that new setup of ours! it goes around the room like a fly looking for shit
ROFLMAO
same here! this was me!!!!!! WHAT THE F................!!!!!!!!!!!!!!!
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:21 pm
by Aripeka Angler
No problem. You have a great build that I follow regularly. I enjoy reading your posts as well....
Richard
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:24 pm
That game should have stayed in Africa, or wherever it came from. Along with golf
Do you know what you call people who can't fish? Golfers
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:35 pm
by peter-curacao
Cracker Larry wrote:That game should have stayed in Africa, or wherever it came from. Along with golf
That's why I STINK at golf!!
Well that proves it! you don't have to be a golf-player to stay at a golf court hotel,that Westin in Savannah was great Larry
Re: Curacao CS 25
Posted: Mon Jun 14, 2010 11:45 pm
Yeah, that is a nice place, I just don't look toward the golf course
A waste of waterfront property IMO
Re: Curacao CS 25
Posted: Tue Jun 15, 2010 8:45 pm
by peter-curacao
indeed and that fellow bringing me over the river in his Popeye boat is a mighty nice fellow!
Re: Curacao CS 25
Posted: Wed Jun 16, 2010 9:50 pm
by peter-curacao
WHY!!!
IMHO its just plain stupid those discussions
Re: Curacao CS 25
Posted: Wed Jun 16, 2010 11:03 pm
by cape man
Re: Curacao CS 25
Posted: Wed Jun 16, 2010 11:42 pm
WHY!!!
I lost ya somewhere too, Peter. No comprende. ¿Qué debate es estúpido?
Edit: No te preocupes, yo entiendo. Sí, ki diskushon tábata ridíkulo.
Re: Curacao CS 25
Posted: Thu Jun 17, 2010 8:40 am
by peter-curacao
Didn't want to blemish Bassmunn's thread any further,but tell me if there was a failure to communicate or it had to do with a language barrier, why is it you understood me perfectly?
Cracker Larry wrote:Peter is saying that cheap boats do that to hide the cheap, and blood and squid guts is real hard to wash out of carpet. That's all.
Re: Curacao CS 25
Posted: Thu Jun 17, 2010 12:45 pm
I don't know, more practice maybe
I was just trying to defuse the situation. George must have had a bad shift
Re: Curacao CS 25
Posted: Thu Jun 17, 2010 12:50 pm
by peter-curacao
Cracker Larry wrote:I don't know
Can be, maybe I was also to pushy about the carpet, but I still don't understand why a beautiful boat like that need carpet. Anyhow I changed my postings in Bassmunn's thread
Btw you language beside English isn't that bad at all
Re: Curacao CS 25
Posted: Thu Jun 17, 2010 12:54 pm
It ain't that good either
I have to remind myself of this often
Re: Curacao CS 25
Posted: Wed Jun 23, 2010 8:08 pm
by ThistleDewDayDreamin
Thought better of it so,.. Deleted
Re: Curacao CS 25
Posted: Wed Jun 23, 2010 8:18 pm
by peter-curacao
ThistleDewDayDreamin wrote:It is better not to wrestle ? in the mud?
I missed a lot in two weeks?!?!
BTW, How'd the Americans play today ? ( FIFA ), (World Cup)
Can we talk about rum please??? or is that for the bilge section also?
Re: Curacao CS 25
Posted: Wed Jun 23, 2010 9:41 pm
It's confusing to switch language mid sentence, makes it harder to google, doesn't it
Back to that Rum, Peter I'm still holding on to 1 bottle of green
Re: Curacao CS 25
Posted: Wed Jun 23, 2010 10:18 pm
[ The statement that was here was off Topic,.. so I made it "gone"] Sorry Peter
I do have a boat building question for you, If I may impose on Peter's thread?
Some time ago when you guys were trying to explain drain vs. overflow as they are plumbed in bait-wells. Someone stated that the overflow tube exited the boat above the water line,.. and not to worry if it dipped below the water line in route from the top of the tank to the point where it discharged overboard. Something about water finding it's own level. That bothered me then, and as I'm doodling on my drawings, it keeps coming back to bother me. If the discharge tube is allowed to dip below the waterline in route, will it not hold water like the trap in a drain as soon as water stops going into the overflow? ie. someone shuts off the pump or drains the tank. That just sounds like a bad idea to me, so,.. either I misunderstood that part of the conversation, or I'm worrying about something that I shouldn't, or the drain tube should be routed overboard such that it doesn't hold water after the tank is drained? Please straighten this out for me, I can't see from the top shots Peter posted here, how he's got his plumbed.
Thanks, TDDD
Re: Curacao CS 25
Posted: Thu Jun 24, 2010 12:36 am
What was that anyway? Pig gaelic, yiddish, portuguese, latin?
The universal language of the islands. Call it what you will, a mix of Creole, Gullah. Creolah
but you got very close, I'm impressed
We'll get to that bait tank question.
Listen to this while you ponder it
http://www.youtube.com/watch?v=e_Rl7BXQpng
Re: Curacao CS 25
Posted: Thu Jun 24, 2010 8:08 am
by topwater
Thistle when i was explaining how the overflow worked on my bass boat
i stated that both my pickups and overflow were below the water line.
the overflow hose was a straight run, no bend up to exit.
Re: Curacao CS 25
Posted: Thu Jun 24, 2010 8:46 am
Below the waterline
So the water in the overflow tube will only rise to the level of the water outside the boat?,.. And drain out whatever water is in the tube above that level? As in when the pump is on and there is water overflowing into the tube, right. And,. then when the boat is taken out of the water ALL the water from the overflow and the pick up(s) will just drain out onto the ground. Am I getting this? Finally ?!
Re: Curacao CS 25
Posted: Thu Jun 24, 2010 9:14 am
by topwater
I am not saying thats how i would do it but if you look at most production bass boats
thats how they do it, at least on my triton.
Re: Curacao CS 25
Posted: Thu Jun 24, 2010 9:43 am
Hey Topwater, ( and anyone else watching ) let's take this back to my tread to keep from hijacking Peter too badly. I'm going to ThistleDew's Abaco 23. Thanks - TDDD (Brett)
Re: Curacao CS 25
Posted: Thu Jun 24, 2010 9:19 pm
by peter-curacao
ThistleDewDayDreamin wrote:Hey Topwater, ( and anyone else watching ) let's take this back to my tread to keep from hijacking Peter too badly. I'm going to ThistleDew's Abaco 23. Thanks - TDDD (Brett)
Go ahead! hijjack all you want I don't care!!! my drain works very well above the waterline !! so please discuss further maybe I can learn also
My drain works very well above the waterline
Re: Curacao CS 25
Posted: Tue Jul 13, 2010 8:51 am
by Bart-Curacao
hi peter,
you know somebody that has a trailer for sale for a 22 ft boat??
Re: Curacao CS 25
Posted: Tue Jul 13, 2010 9:08 am
by DAVE LUDICK
I picked up somewhere a chirp about that instrument that was used at the World Cup, it is called a "vuvuzela"and originates from a "kudu" horn, a kudu being a antelope. It is the worst thing to come out of this world cup, the infernal noise 24/7 is enough to drive anyone mad.
I also picked up something about golfers can't fish, well the author of that statement should set up a match on the river/sea and the golf course and let's see if it is true. I love both pusuits, tee off Sat mornings at 7.30 am or launch the boat 7.30 and enjoy the wonderful outdoors before the rest of the world wakes up.
We in South Africa are looking for a permanent home for the "vuvuzela's and their blowers, any takers.
Dave
Re: Curacao CS 25
Posted: Wed Jul 21, 2010 9:06 pm
Hello Peter !! Wondering if you've made any of your "Very Understated" "baby steps" lately? Got any new pics. Always get inspired when you post. Hope all is well. -- Brett
Re: Curacao CS 25
Posted: Wed Aug 18, 2010 9:09 pm
by chlli willie
Things have a little stale around here, where is Peter?
Re: Curacao CS 25
Posted: Wed Aug 18, 2010 9:12 pm
by chlli willie
I stuttered in my post. I meant to say things have gotten a lttle stale with out Peter. Must have been that last pint o Guiness!
Re: Curacao CS 25
Posted: Fri Sep 03, 2010 9:14 pm
by cape man
Peter,
What's up? Miss you man!
Craig
Re: Curacao CS 25
Posted: Mon Sep 13, 2010 1:47 pm
If he doesn't show up soon, I say we start an email barrage until he decides to let us know he's alive and well. !!
What-da-ya say guys? TDDD.
Re: Curacao CS 25
Posted: Mon Sep 13, 2010 1:48 pm
This'll get him,....
HEY PETER? !?! IS YOUR BOAT FOR SALE?
Re: Curacao CS 25
Posted: Mon Sep 13, 2010 3:08 pm
I haven't heard from him lately either
Hope he's OK. I just sent him a personal email, I'll let yall know if he replies.
Re: Curacao CS 25
Posted: Thu Sep 16, 2010 12:14 pm
by tobolamr
You just wait... He'll show up at the next builder's meet with a boat full of Rum, babes, seafood, and a HUGE grin!
Re: Curacao CS 25
Posted: Sun Sep 19, 2010 7:23 am
I've been in touch with Peter and Gloria. Unfortunately his health has not been good, and has him bummed out
He asked me to pass on his regards to everyone. I'll do a copy and paste .....
Larry and Dori,
First of all sorry for the late response from our site! but as you both know, Gloria isn't the greatest in computer skills and I, I am not always the fastest in reply's for curtain reasons, sorry for that!
Let me tell you Gloria is great but I am a little less great! that mouth thing did get worse and in November I have to go in surgery again! in that surgery I'm gone lose 2 or 3 perfect good tooth or moles you call them? those in the back of your mouth? and that really makes me nervous and depresses me! Anyway I'm sad about that! but If I have to believe my "expert" that's the thing I have to do!
I really wish there was a way to live in the States at moments like that! so I had more choices to make if you know what I mean, but it is what it is!
Larry please bring my regards over to the rest of the guys and tell them I'm really sorry not posting any progress! there isn't any progress on my build at this time just a little "struggling in life"
We love both of you guys give Dori a big hug and kiss from me! and you just received them from Gloria!
OXOXOXOX
Gloria & Peter
PS tell those boys from Carolina to get some imagination! they can not steal and use all my ideas and then expose them as if they invented them!LOL
Re: Curacao CS 25
Posted: Sun Sep 19, 2010 7:30 am
by majorgator
I like that line. Leave it to Peter to throw in a shot. From the looks of though, they will be done a good bit quicker.
Here's to hoping you get better soon Peter...in time for the Boca meet in June??
seth
Re: Curacao CS 25
Posted: Fri Oct 01, 2010 10:02 pm
by peter-curacao
Is that so? pardon me !!!!! bye bye
Re: Curacao CS 25
Posted: Sat Oct 02, 2010 6:39 am
by majorgator
Hey Peter, I'm gonna give one attempt to clear that up. It was meant as a compliment. Nothing negative implied
But again, here's hoping you get better soon.
seth
Re: Curacao CS 25
Posted: Sun Oct 10, 2010 9:27 pm
by macs
Hey Peter. How's it going?
Re: Curacao CS 25
Posted: Mon Oct 11, 2010 6:49 am
by cape man
Yeah Peter...show us a picture...you can post a pic of the dog if you haven't worked on the boat.
Re: Curacao CS 25
Posted: Mon Oct 11, 2010 10:26 am
by TomW
Peter hope your surgery goes well and you have a quick recovery, want to see pics of that boat of yours that you have spent so many hard hours on. Just take your time and do what you can. I really miss your wit and responses on the forum.
Re: Curacao CS 25
Posted: Wed Oct 13, 2010 7:23 pm
by peter-curacao
cape man wrote:Yeah Peter...show us a picture...you can post a pic of the dog if you haven't worked on the boat.
Okay you asked for it, so here it is! couple months ago, enjoy!
Find the dog
Re: Curacao CS 25
Posted: Wed Oct 13, 2010 7:45 pm
by Larry B
Cool
Thanks for the picture, made my day
Re: Curacao CS 25
Posted: Wed Oct 13, 2010 8:18 pm
by ks8
Re: Curacao CS 25
Posted: Thu Oct 14, 2010 6:14 pm
by peter-curacao
Larry B wrote:Cool
It's a sweet hard isn't he?
Re: Curacao CS 25
Posted: Thu Oct 14, 2010 6:16 pm
by macs
Looks like he's had a little of that green rum
Re: Curacao CS 25
Posted: Thu Oct 14, 2010 7:01 pm
I think (hope) that was supposed to be "sweet heart"
Re: Curacao CS 25
Posted: Thu Oct 14, 2010 7:04 pm
by peter-curacao
macs wrote:Looks like he's had a little of that green rum
After green rum he' s even nicer! just like me!
I can't even describe the love I have for this guy and get from this guy ! so I won't even start! BELIEVE ME PLEASE! HE'S THE BEST!!!
Re: Curacao CS 25
Posted: Thu Oct 14, 2010 7:05 pm
by TomW
He is a cutey Peter!
Re: Curacao CS 25
Posted: Thu Oct 14, 2010 7:17 pm
Yep, I'm sure it was sweet heart
Love ya Peter, welcome back
Re: Curacao CS 25
Posted: Fri Oct 15, 2010 10:18 am
by cape man
Okay...now boat pictures...
Re: Curacao CS 25
Posted: Sat Oct 16, 2010 6:52 pm
by sideslippa
cape man wrote:Okay...now boat pictures...
I agree lets look at boat building progress, I might want to build one of these things!!!!!
Slippa.
Re: Curacao CS 25
Posted: Sat Oct 16, 2010 11:55 pm
by col555
I just read thru the whole thread
You do great work peter, love to see more pics
C
Re: Curacao CS 25
Posted: Sun Oct 17, 2010 12:30 am
by TomW
He will when his health improves. If he feels like it.
See CL's post of 9/19 he hasn't done much of anything on his boat this year. He and I have had a couple of e'mails back and forth about his upcoming surgery and he is concerned about it so, hope everyone will give him a good luck and get well quick and not worry about pics of his boat, it's the last thing on his mind.
Re: Curacao CS 25
Posted: Sun Oct 17, 2010 1:11 am
by gstanfield
...that mouth thing did get worse and in November I have to go in surgery again! in that surgery I'm gone lose 2 or 3 perfect good tooth or moles you call them? those in the back of your mouth? and that really makes me nervous and depresses me!
Sorry to hear about that Peter. I just went through similar myself and lost two good teeth on both sides due to some crazy infection thing. I'm doing OK now, but I often whistle when I talk and kinda miss eating steak.
I'll keep you in my prayers for a speedy recovery,
George
Re: Curacao CS 25
Posted: Sun Oct 17, 2010 9:57 am
by wegcagle
Good luck Peter. Hope the surgery is a great success, and you have a fast and complete recovery. We'll be thinking about you. If my boat can wait 3 years for me to come home; I don't think you should sweat taking a year off or so for your health and family
Will
Great picture of you and your dog. Your place looks like a little slice of paradise.
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 6:55 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 6:58 pm
by peter-curacao
TomW wrote:He will when.......... the last thing on his mind,
.thank you Tom!
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:00 pm
by cape man
HEY PETER!!!!
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:17 pm
by peter-curacao
shine wrote:I deleted several posts this morning from this thread. Starting with the post that was a troll, then the reactions to the troll. Just trying to clean up the thread a little.
Unbelievable!!! after all the requests I made to take my,this thread off of this message board!! Shine/Joel we share the same interest's I think? BB,bbq, fishing and English Bulldogs!! why don't you just honer my request's? then the troll you referring to was gone long time ago and saved you a lot of moderation time won't it?
god speed!
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:23 pm
by peter-curacao
cape man wrote:HEY PETER!!!!
hello 8)coral guy!
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:33 pm
by peter-curacao
TomW wrote: he hasn't done much of anything on his boat this year.
At least I did annoy some people didn't I Tom?
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:35 pm
by sitandfish
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:36 pm
by peter-curacao
Nice pic how do I make the scuppers?
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:38 pm
by sitandfish
ROFL
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:42 pm
by sitandfish
peter-curacao wrote:Well...Laterzzzz
Peter
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 7:51 pm
by peter-curacao
COOL
Re:
Posted: Sat Nov 13, 2010 7:55 pm
by sitandfish
jacquesmm wrote:.... but I would prefer to see the stringer notches cut as on the plans.
Re: Re:
Posted: Sat Nov 13, 2010 8:01 pm
by peter-curacao
sitandfish wrote:jacquesmm wrote:.... but I would prefer to see the stringer notches cut as on the plans.
AAhhhh the French are so stubborn!
Re: Curacao CS 25
Posted: Sat Nov 13, 2010 8:16 pm
by sitandfish
Thanks, for the update.
Re: Curacao CS 25
Posted: Sun Nov 14, 2010 9:04 am
Great book! Should be required reading for anyone wanting to do business in the Caribbean
Happy holidays Peter, if you come to the States this year let us know and we'll party again
Re: Curacao CS 25
Posted: Sun Nov 14, 2010 10:00 am
by Dog Fish
Re: Curacao CS 25
Posted: Sun May 29, 2011 6:00 pm
by peter-curacao
Dog Fish wrote:.
Dry fitted the deck today
Re: Curacao CS 25
Posted: Sun May 29, 2011 6:20 pm
by gstanfield
Good to see you back to work on her
Re: Curacao CS 25
Posted: Sun May 29, 2011 8:49 pm
by wej
YAY!! Peter is back!!!! (crowd cheering in the back ground)
Re: Curacao CS 25
Posted: Mon May 30, 2011 7:47 am
by cape man
Peter,
Looking great!
Glad you're back on it!
Re: Curacao CS 25
Posted: Mon May 30, 2011 7:49 am
Welcome back, Peter
Re: Curacao CS 25
Posted: Mon May 30, 2011 8:01 am
by macs
Yes, welcome back Peter. Good to hear from you.
Re: Curacao CS 25
Posted: Mon May 30, 2011 12:29 pm
by peter-curacao
I don't like the curve I originally made
So which one is better? I think the last one but not sure,:doh: or are there other maybe better ideas?
Re: Curacao CS 25
Posted: Mon May 30, 2011 12:31 pm
by gstanfield
I like the last, smaller radius best.
Re: Curacao CS 25
Posted: Mon May 30, 2011 12:38 pm
by wegcagle
Good to see you back at it Peter. I'm with George, I like the smaller radius one better. That being said it's your boat pick the one you like the best
Will
Re: Curacao CS 25
Posted: Mon May 30, 2011 12:42 pm
by peter-curacao
Thanks guys I was thinking the same, here are some better angled overall pics.
Re: Curacao CS 25
Posted: Mon May 30, 2011 1:02 pm
by macs
I agree, I like the smaller radius too.
Re: Curacao CS 25
Posted: Mon May 30, 2011 1:14 pm
Yep, second pic looks the best, to me.
Re: Curacao CS 25 - cx25 in Greece
Posted: Mon May 30, 2011 2:08 pm
by pkar
Hello Peter,
welcome back.
How exactly have you made the rub rail?
pkar
Posted: Mon May 30, 2011 3:08 pm
by peter-curacao
pkar wrote:Hello Peter,
welcome back.
pkar
3 layers of ply with exception of the rear straight part, that's hard wood. I'm not sure if it had to do with the droopy nose I created (I do think so,to many bends in different directions) but I had a hard time bending the rail in the bow section, therefore I made cut's in that part and filled it with epoxy woodflour mix, see beneath pics.
Re: Curacao CS 25
Posted: Wed Jun 01, 2011 6:04 am
by cape man
Nice detail, but we expect nothing less.
Re: Curacao CS 25
Posted: Wed Jun 01, 2011 12:34 pm
by tobolamr
Peter, Glad to see you back up and at 'em! Keep up the great work! I also like the smaller radius.
Re: Curacao CS 25
Posted: Thu Jun 02, 2011 1:51 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Jun 02, 2011 2:21 pm
by gstanfield
Looks good to me
Re: Curacao CS 25
Posted: Thu Jun 02, 2011 3:22 pm
by ks8
Sure does
Re: Curacao CS 25
Posted: Thu Jun 02, 2011 4:46 pm
by tobolamr
Nice! And yes, that explanation works for me, too!
Re: Curacao CS 25
Posted: Thu Jun 02, 2011 6:36 pm
by Daddy
nice job Peter, glad it went so well
Re: Curacao CS 25
Posted: Fri Jun 03, 2011 6:53 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri Jun 03, 2011 7:02 pm
by macs
Cool Peter that looks great. Sanding sucks, sanding upside down sucks big time
Looking good
Re: Curacao CS 25
Posted: Sun Jun 05, 2011 8:33 pm
by flyfishingmonk
Peter,
I can't believe I haven't seen this. What an amazing boat you have there.
Casey
Re: Curacao CS 25
Posted: Sun Jun 05, 2011 8:59 pm
by peter-curacao
flyfishingmonk wrote:Peter,
Casey
Well thank you very much, still a long way to go though
Re: Curacao CS 25
Posted: Mon Jun 06, 2011 6:21 am
by cape man
Man it is good to see you working on her again. Love the coaming.
Re: Curacao CS 25
Posted: Wed Jun 08, 2011 10:32 am
by Jaap
Good to see you working on the boat again!! It is a big thing, but you already added so many nice details, so keep going.
jaap
Re: Curacao CS 25
Posted: Wed Jun 08, 2011 7:55 pm
by peter-curacao
Thanks guys, Jaap sorry to hear you have to stop your build but good to hear she will be finished by good friends, how is Bangkok treating you? Did you decide if and what boat you are gonna build over there? Don't know why but for some reason I think a Panga fits good there
Re: Curacao CS 25
Posted: Sun Jun 12, 2011 5:35 pm
by ixplorer
Hey Peter,
Great to see the progress after so long since I last saw it... have you kept a log of hours taken ?
Cheers
g
Re: Curacao CS 25
Posted: Sun Jun 12, 2011 5:39 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun Jun 12, 2011 5:40 pm
by peter-curacao
ixplorer wrote:Hey Peter,
Cheers
g
Thanks, no I didn't, also didn't kept a log on the $$$
Re: Curacao CS 25
Posted: Sun Jun 12, 2011 5:42 pm
by gstanfield
Some things are better of not known
Re: Curacao CS 25
Posted: Sun Jun 12, 2011 8:10 pm
by peter-curacao
Several hours
and Cuba libre's later in the thinking chair, I think this brings me back to the sliding door option, flows nicer with the front seats also.
Re: Curacao CS 25
Posted: Sun Jun 12, 2011 8:45 pm
by wej
If I'm looking at it correctly I LOVE IT!!!!
Re: Curacao CS 25
Posted: Sun Jun 12, 2011 8:53 pm
by peter-curacao
wej wrote:If I'm looking at it correctly I LOVE IT!!!!
To help you look at it, something like this I'm trying to create.
5
Re: Curacao CS 25
Posted: Sun Jun 12, 2011 8:58 pm
by wej
OK yes quite sure I love it now!!
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 1:53 am
by chicagoross
Cool!
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 2:12 pm
by tobolamr
VERY cool!
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 6:29 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 6:49 pm
by gstanfield
Hmmm, I'm not sure.
I don't expecially like it, but I don't dislike it either. I think it's a good idea that just needs a little more work to be perfect. I like the large radius on the one piece, but maybe a small radius is needed on the other corners to make things flow better.
Whatever you come up with I'm sure it will be nice
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 6:55 pm
by peter-curacao
gstanfield wrote:but maybe a small radius is needed on the other corners to make things flow better.
That I was going to do when I'm glassing it, this is a dry fit I think it's to bulky.
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 6:58 pm
by gstanfield
I agree it's a bit too bulky. How deep did you make the seats? They seem awful big to me
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 7:51 pm
by peter-curacao
gstanfield wrote: How deep did you make the seats? They seem awful big to me
I think that's the angle maybe this pic helps the seat is 40 cm from the corner to the coaming off course it is deeper but I cant sit under the coaming the height is 50 cm I took those measurements from the CC drawing
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 8:08 pm
by gstanfield
OK, it's not as bad as I thought. You have them at 16" deep and I would have guessed 18-20" from the picture. Maybe they will look better once you get the seat backs in place.
Someone is going to jump in here with a great idea I'm sure of it...it's just not me
Re: Curacao CS 25
Posted: Mon Jun 13, 2011 10:06 pm
by peter-curacao
I think I'm letting the idea of connecting the seats with the CC go and make the other side the same with the rounded off seat
Also gonna lower the CC a bit I think
Re: Curacao CS 25
Posted: Tue Jun 14, 2011 7:35 am
Peter, the seat height of 19.5" may be a little high. Standard (furniture) chair heights are 15-17". At 19.5, Gloria's feet won't reach the deck.
Your work as always looks great
Re: Curacao CS 25
Posted: Tue Jun 14, 2011 2:39 pm
by Matt Gent
And consider the foam cushion is ~3" thick. The seat for my c/c is ~17.5" from floor to the base (not including foam), and I just spaced it up to 19" to fit a cooler underneath. I think you are in the ballpark, if not on on the high side.
I like this type of layout for a larger CC. The CS has a lot of style and flair to its shape, so the seats would want to be consistent. Check out some of the higher-end pontoon boats, they have this type of seating and you may be able to borrow design elements. One that I like a lot is a lounger, for your boat it would be an angled back on the starboard side bench where the plywood currently spans to the gunnel.
Re: Curacao CS 25
Posted: Wed Jun 15, 2011 4:11 pm
by Tiwaz
Great to see progress once again.
Re: Curacao CS 25
Posted: Wed Jun 15, 2011 5:57 pm
by TomD
Peter - I love your build I think its going great. My girlfriend loves your seat lay out - but frankly (and much to her disgust) I don't like it! To me it defies the purpose of a center console if you can only walk around it one way. If you round off both sides you will only loose a tiny bit of seating and "sunbathing" area and have a much nicer "symmetrical" look - in my humble opinion!
Re: Curacao CS 25
Posted: Wed Jun 15, 2011 6:36 pm
by peter-curacao
TomD wrote:Peter - I love your build I think its going great. My girlfriend loves your seat lay out - but frankly (and much to her disgust) I don't like it! To me it defies the purpose of a center console if you can only walk around it one way. If you round off both sides you will only loose a tiny bit of seating and "sunbathing" area and have a much nicer "symmetrical" look - in my humble opinion!
Easy easy
it's already changed as I stated in my last post
center console lowered and port will be the same as starboard, still thinking about lowering those seat's,I put my girlfriend on it and she thinks it's okay, I think indeed it's i bit high. But don't forget first use for this boat is fishing not beach anchoring, she first has to work
Pics soon to follow
Re: Curacao CS 25
Posted: Wed Jun 15, 2011 7:53 pm
Amen, mi amigu
Allow for the cushion height too, as Matt suggested
Nobody is comfortable very long if they can plant their feet on the floor to take some of the beating off their @ss. Running offshore, nobody is likely to be sitting anyway, or should not be sitting, except for the calmest of days. I once had a girl break her hip on my charter boat, because she was sitting with her feet not on the deck. A wave lifted us and then left us, the boat fell, and she fell about 3 seconds behind it. Even though she landed on a cushion, it broke her hip because her legs weren't under her. That cost me about 25K.
Re: Curacao CS 25
Posted: Wed Jun 15, 2011 9:52 pm
by TomD
Easy easy
I know .... that's why I braved my opinion without offending anyone else other than my girlfriend!
Re: Curacao CS 25
Posted: Wed Jun 15, 2011 10:33 pm
by whosmatt
Yikes. That's a boat or two for most of us.
Great job so far, Peter. Looking forward to seeing more. I'm glad this thread popped back up to the top; it's good to see someone at a similar point in the build, even if it's three times the boat I'm working on.
-Matt
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 2:39 pm
by peter-curacao
Thanks guys
Camera is fixed problem was a dead battery, strange because the camera said empty battery, but when I put a voltage meter on it it seem to be okay, anyway bought a new battery and now it's working again, so here's a sneak peak
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 2:42 pm
I'm trying to figure out whatinhell it's a peek of
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 4:34 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 4:36 pm
by chicagoross
Covering for the tank hoses?
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 4:55 pm
by peter-curacao
chicagoross wrote:Covering for the tank hoses?
Nope
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 5:26 pm
by tobolamr
The under-side of the motorwell? In other words, you built this section upside-down and will flip it over and install it?
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 5:54 pm
by peter-curacao
tobolamr wrote:The under-side of the motorwell? In other words, you built this section upside-down and will flip it over and install it?
Good guess but no, I'm building a bracket version so that would be excessive
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 6:32 pm
by Doc_Dyer
step rest for your feet below console ?
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 6:55 pm
by timmydafool
bottom side view of recessed head in console?
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 7:10 pm
by majorgator
Its mounted on the console...
Side mount/flush mount rod-holders. Picture is taken looking down at an angle.
similar to this...
seth
Re: Curacao CS 25
Posted: Thu Jun 16, 2011 9:54 pm
by wej
Larry took the words right out of my mouth.
Re: Curacao CS 25
Posted: Fri Jun 17, 2011 8:45 am
by peter-curacao
majorgator wrote:Its mounted on the console...
seth
Ding ding ding ladies and gentleman we have a winner!!!
And what have you won? absolutely nothing!
But I think it's very clever that you could make it up out of a pic like that
Re: Curacao CS 25
Posted: Fri Jun 17, 2011 7:50 pm
by peter-curacao
LOOK! A DOG!!
Re: Curacao CS 25
Posted: Fri Jun 17, 2011 7:57 pm
by sds
Best console dog I've seen today.
Re: Curacao CS 25
Posted: Fri Jun 17, 2011 8:31 pm
by chicagoross
Re: Curacao CS 25
Posted: Sat Jun 18, 2011 8:46 am
by cape man
As we would say here in Florida....You just aint right in the head. Fun stuff here Peter.
Re: Curacao CS 25
Posted: Sat Jun 18, 2011 3:38 pm
by stickystuff
Now thats Doggone funny. doggonnit anyhow.
Re: Curacao CS 25
Posted: Sat Jun 18, 2011 4:07 pm
by wegcagle
Nice work Peter, I'm sure she'll be a man's best friend.
Will
Re: Curacao CS 25
Posted: Sat Jun 18, 2011 10:36 pm
by peter-curacao
LOOK! a desktop computer
Re: Curacao CS 25
Posted: Sun Jun 19, 2011 9:58 am
by wej
Re: Curacao CS 25
Posted: Tue Jun 21, 2011 8:24 pm
by peter-curacao
Re: Curacao CS 25
Posted: Tue Jun 21, 2011 10:02 pm
by gstanfield
Nice
Re: Curacao CS 25
Posted: Wed Jun 22, 2011 7:38 am
by macs
That's preety cool Peter, good job! Where did the vents come from?
Re: Curacao CS 25
Posted: Wed Jun 22, 2011 2:53 pm
by peter-curacao
macs wrote:Where did the vents come from?
Read back a little and you will find out
Re: Curacao CS 25
Posted: Wed Jun 22, 2011 4:05 pm
by Matt Gent
I'm guessing this is 1/4" ply. A few questions:
-What bend radius?
-Kerfs appear to be about every 1/4" - how deep?
-How did you make them?
-Did the inner skin kink at the slits?
Re: Curacao CS 25
Posted: Wed Jun 22, 2011 4:13 pm
by peter-curacao
Matt Gent wrote:
I'm guessing this is 1/4" ply. correct
-What bend radius? about 14 "
-Kerfs appear to be about every 1/4" - how deep? about 1/8"
-How did you make them? circular saw
-Did the inner skin kink at the slits? no
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 9:44 am
by Doc_Dyer
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 6:44 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 6:48 pm
by Steven
That configuration looks much better. If you're going to use it for fishing and family fun, you could have a lip on the inner edged of the seat that you could support a drop in "deck" Put a great big cushion on wthe hole thing and have a huge sun pad for the girlies.
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 6:52 pm
by peter-curacao
Steven wrote:That configuration looks much better. If you're going to use it for fishing and family fun, you could have a lip on the inner edged of the seat that you could support a drop in "deck" Put a great big cushion on wthe hole thing and have a huge sun pad for the girlies.
I was thinking about that for tournaments on other islands,in one way or the other put some canvas over it and there is my rainfree crib.
For my girl I don't have to do it, she's avoiding the sun as much as possible, as everybody here btw
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 7:16 pm
by ks8
The cleat for the deck insert is also a very handy handhold. I find myself using these things often for a quick grip. They are positioned all along the bench seat edges.
Testing the theory during the install...
I have not been disappointed. They are positioned all along the bench seat edges. Haven't met anyone yet with a negative comment about them, but I admit that some may not like the looks of them.
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 7:20 pm
by peter-curacao
KS8 your work keeps amazing me every time I see it, way above my league.That paint it looks like gelcoat and I mean that in a good way
what kind of paint is that and how did you apply it if I may ask?
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 8:02 pm
by gstanfield
Peter, the new seating arrangement looks really nice. I personally like it much better than the first setup although the first setup was a good idea, it just didn't really fit that boat
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 8:56 pm
Oh yeah
That's a lot better. Very nice, and more practical
Yes they are. I have them around the entire inside perimeter in mine. They aren't quite as large as those, but they still do the job. Just something to get a fingertip or 2 on helps keep you stabilized.
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 9:50 pm
by wej
Awesome Peter, can't wait to see some blood on this baby!!! (that's fish blood not one of your knuckles)
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 10:01 pm
by Larry B
wej wrote:Awesome Peter, can't wait to see some blood on this baby!!! (that's fish blood not one of your knuckles)
I'd bet there is already knuckle blood in his boat
I think most boats have some knuckle blood in them, I know mine does
btw, Peter boat is looking great.
Re: Curacao CS 25
Posted: Thu Jun 23, 2011 10:30 pm
by Steven
Larry B wrote:wej wrote:Awesome Peter, can't wait to see some blood on this baby!!! (that's fish blood not one of your knuckles)
They're like blood altars.
I caught my toe on a one strand of 12oz. that was sharp as a hypodermic needle and just as effective at relieving me of copious amounts of blood.
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 1:43 am
by ks8
peter-curacao wrote:KS8 your work keeps amazing me every time I see it, way above my league.That paint it looks like gelcoat and I mean that in a good way
The white in that picture is S3 primer (it behaves pretty well when sprayed). The other color, for which I haven't yet decided on a name, was applied with... Photoshop.
But that is the intended trim color scheme (or close to it) for the interior. The floor may also be that color... well... ok... its not technically a *floor* in boat building *speak*, and its not a *sole*. What does one call the bottom panels of the hull, from the perspective of the interior, when there is no raised *sole*?
Though I sprayed this with System Three LPU (the LPU is rascally to spray)... (and brushed on the waterline after masking it off)...
6761
... I'm considering roll and tip for the remainder of the interior. I started spraying some sections. Spraying these patterns is a lot of setup time, masking, guarding against overspray, cleanup, etc. I'm even considering Sterling on the interior after experiencing some of the problem with S3 LPU in the southern sun (Using less x-linker helps it behave better though not as tough a film), but about 1/3 of the interior has already got some S3 on it
. First I've got to finish the utility mast and paint some lockers. Thank you for the kind words. I'm looking forward to how you paint and trim the interior of that beauty Peter. You are putting a fighting chair in there, right?
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 7:29 am
by macs
Looking good Peter. I agree, I like that layout better also. Looks like your going to have plenty of room to get around the console. I have a friend with a 25' Baja Sportfish CC and it's a little tight getting around that big console in that boat.
KS8 - that's some mighty fine looking work there.
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 8:15 am
by peter-curacao
How about the bilge?
I really like the white paint,but don't think it will work here after reading your comment on the sun , if I'm putting the chair in there depends a little on how it would look like in total.
Thanks for your answer
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 9:23 am
by Matt Gent
The layout does look good. Are the seats high enough, with cushions, to see out over the deck? That hull has such a high bow.
Its also a great place to hinge the seat bases for extra storage.
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 12:45 pm
by ks8
Well that would mean that here I am sitting down in the bilge...
8120
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 4:15 pm
We usually call that by the very nautical term of "bottom"
The bilge is the free space above the bottom, but below the sole.
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 4:16 pm
by tobolamr
Peter - another vote of confidence for you on your bow seating. That looks outstanding!
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 4:28 pm
by peter-curacao
Cracker Larry wrote: The bilge is the free space above the bottom, but below the sole.
Correct and since he hasn't have a sole in his boat
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 4:29 pm
by peter-curacao
tobolamr wrote:Peter - another vote of confidence for you on your bow seating. That looks outstanding!
Thanks!
To all Btw
Matt Gent wrote:Are the seats high enough, with cushions, to see out over the deck? That hull has such a high bow.
I just lowered the seats but they are still high enough, I will route out out the hatches one's everything is glued in place.
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 5:03 pm
by Joe H
I like the seats too Peter, and ks8's rubbers.
Joe H
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 5:30 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 5:52 pm
by tobolamr
I'm not touching THAT one with a 10 foot pole!!!!
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 6:53 pm
Language barrier alert
See those feet? Yanks call them rubbers
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 6:56 pm
by peter-curacao
Cracker Larry wrote:Language barrier alert
Larry Larry I knew that! just joking with the guy
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 7:49 pm
by ks8
Humble sea boots...
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 8:11 pm
by Joe H
how the hell do you know KS8 his rubbers? And why are you liking them? are they ribbed?
I have tears in my eye's!!! I didn't expect any less............
[img]Language%20barrier%20alert%20%20See%20those%20feet?%20Yanks%20call%20them%20rubbers[/img]
HOLY SH%&T, I guess I am a yank!
Joe H
Re: Curacao CS 25
Posted: Fri Jun 24, 2011 9:16 pm
by cape man
Always worth a look see here. Love the new seat pattern.
Re: Curacao CS 25
Posted: Sat Jun 25, 2011 9:11 am
by peter-curacao
cape man wrote:Always worth a look see here. Love the new seat pattern.
Thanks Craig
Re: Curacao CS 25
Posted: Sat Jun 25, 2011 5:29 pm
by steve292
The lines flow nice on this. I like that layout a lot.
Steve
Re: Curacao CS 25
Posted: Sat Jun 25, 2011 9:13 pm
by Bluefish2
That is going to be beautiful when done Peter! Have you started thinking of a name? Southern Climes, Blue Skies?
BF2
Re: Curacao CS 25
Posted: Sat Jun 25, 2011 9:18 pm
Joe H
Yeah, I'm sure you are, compared to me
You are one of my favorite Yanks though
Re: Curacao CS 25
Posted: Sun Jun 26, 2011 10:46 pm
by wej
Peter do you think the other seating arrangement would have worked with a side console?? I like that arrangement just wondering if that would make it more feasible??
Re: Curacao CS 25
Posted: Sun Jun 26, 2011 10:57 pm
by peter-curacao
wej wrote:Peter do you think the other seating arrangement would have worked with a side console?? I like that arrangement just wondering if that would make it more feasible??
I think that would have worked out perfectly, well at least much better, still it would have a hump above the coaming if you want a respectable size side Console. But my personal taste doesn't include a side console for this type of boat.
Re: Curacao CS 25
Posted: Sun Jun 26, 2011 11:10 pm
by wej
Just wondering what it would take, that design would be awesome for a lake boat for the family is kinda why I was wondering.
Re: Curacao CS 25
Posted: Fri Jul 01, 2011 2:07 am
by ixplorer
Only reason i wondered on your time log ... was i was told this boat took 400 hours... COF COF ... no friggin way !! I would guess its more like 800 already.
Looks stunning by the way... couldn't have it that open here in NZ as the wind would tear your hair off.
g
Re: Curacao CS 25
Posted: Fri Jul 01, 2011 2:08 am
by ixplorer
Is the plan to have an outboard on your boat ?
g
Re: Curacao CS 25
Posted: Fri Jul 01, 2011 8:10 am
Peter left this morning on a trip to the states, so I'll answer for him
He plans on a 300 HP Etec outboard.
I've never been to New Zealand but I've been to the Netherland Antilles. I think it is the windiest location that I've ever seen
When I stepped off the plane I immediately lost my passport, airline tickets, hat and cigarettes, dang. You can't even set a full beer down without it getting blown away. My first hamburger got blown 100 yards down the beach. And every tree on the ABC islands grows in the same direction, down wind
Re: Curacao CS 25
Posted: Fri Jul 01, 2011 9:00 am
by peter-curacao
Larry thanks for answering xplorerer, I'm on the airport now having a 3 hour delay so I was bored and opened up my laptop, after reading your story the whole airport looked at me if I was some kind of nutjob, every time you tell that story I have to laugh so hard
You forgot about cleaning the apartment though, yep pretty windy place over here,try to laminate a hull in that wind, nice pics btw.
Xplorer although I didn't keep a log of anything what so ever I think you see it to dark, I'm not building at that boat every spare minute I have, just when I feel like it, hey it's a hobby not a job you know
4 Oclock in the morning to found out later we leave at 11:30
Re: Curacao CS 25
Posted: Fri Jul 01, 2011 9:48 am
I hate airports
Didn't have to do any cleaning, just open the front and back doors, and your airline tickets, passports and money will all get blown clear to South America
I had the hardest time hanging on to my stuff down there. Had to learn a whole new technique for drinking beer without it blowing up my nose
Not sure how you get any glass work done
Just a bit
See you in a few days, hope the trip delays improve.
CX 25 in Greece
Posted: Fri Jul 15, 2011 4:10 pm
by pkar
Hello Peter,
I build the cx25 in Greece.
Can you please tell me how many layers of glass tape have put in these points (A-F)?
http://gallery.bateau2.com/displayimage.php?pos=-38367
pkar
Re: CX 25 in Greece
Posted: Sun Jul 24, 2011 2:47 pm
by peter-curacao
Sorry for the late response we came back home from the States yesterday evening.
A - 2 layers tape inside, same for the outside
F - just 1 layer inside and out, but woven tape not biax, they are just splices, if you don't want a hump on the outside for easy fairing, plane down your wood a little (wideness and dept of the tape)
Ps If not clear, it,s in your lamination schedule and building notes
Edit: if I may give you another hint? make more slits at the bow, it will give you a much nicer flare, I didn't do it because I didn't know at the time, if I could do it over I would make two more slits at each side
Re: Curacao CS 25
Posted: Wed Jul 27, 2011 2:26 pm
by pkar
Thank you Peter ...also for the hint.
Another question ...how many layers at B & D?
I' ll try to setup a builder thread on the forum to show fotos of my work.
pkar
Re: Curacao CS 25
Posted: Thu Jul 28, 2011 12:19 am
by peter-curacao
pkar wrote:Thank you Peter ...also for the hint.
pkar
B is the same as A.
As for D none or if you want, some woven tape, but just a bead of thickened epoxy is sufficient until wide fabric
Re: Curacao CS 25
Posted: Thu Jul 28, 2011 12:48 am
by peter-curacao
pkar
Btw no problem at all! if you need help and don't find an answer, just post your question also in my thread and I will try to help you if I can. Not claiming that I am an expert , just walked some stages in the "same" build you still have to tackle
Re: Curacao CS 25
Posted: Sun Aug 28, 2011 9:42 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun Aug 28, 2011 10:01 pm
by wej
Looks great!
Re: Curacao CS 25
Posted: Sun Aug 28, 2011 10:21 pm
by gstanfield
Nice Christmas tree
Re: Curacao CS 25
Posted: Sun Aug 28, 2011 10:26 pm
by peter-curacao
gstanfield wrote:Nice Christmas tree
LOL
little dull not? need more bells and whistles
Re: Curacao CS 25
Posted: Sun Aug 28, 2011 10:44 pm
by gstanfield
I'm just a simple country boy. I don't mind fancy stuff to look at, but if it's mine I want it to work and that's about all it has to do
Re: Curacao CS 25
Posted: Sun Aug 28, 2011 10:55 pm
by peter-curacao
gstanfield wrote:I'm just a
Si Tex!
O yeah and it is affordable. well at least for me it is
Re: Curacao CS 25
Posted: Sun Aug 28, 2011 11:15 pm
by gstanfield
Re: Curacao CS 25
Posted: Mon Aug 29, 2011 2:58 am
by chicagoross
I'd add a tach, fuel gauge, voltmeter, VHF, and a steering wheel...too many doo-dads?
Re: Curacao CS 25
Posted: Wed Aug 31, 2011 11:04 am
by ks8
I like the idea of a steering wheel...
Re: Curacao CS 25
Posted: Wed Aug 31, 2011 11:19 am
by gstanfield
No need for a steering wheel if you have dual throttle controls
Re: Curacao CS 25
Posted: Wed Aug 31, 2011 2:43 pm
by tobolamr
LOL
gstanfield wrote:No need for a steering wheel if you have dual throttle controls
This reminds me of a tractor a neighbor had when I was growing up...
Re: Curacao CS 25
Posted: Wed Aug 31, 2011 3:59 pm
by Uncle D
Bet if you can "steer" a plane, you could steer that tractor.
Re: Curacao CS 25
Posted: Wed Aug 31, 2011 10:04 pm
by peter-curacao
So in other words my console sucks and is fugly?
ah well I like it!
Re: Curacao CS 25
Posted: Wed Aug 31, 2011 11:28 pm
by gstanfield
Not at all Peter, I think everyone is just having fun
Re: Curacao CS 25
Posted: Thu Sep 01, 2011 3:12 am
by chicagoross
Proportional and functional. It's got some nice curves to it, the extra work on large-radius rounding all corners means you're not going to be hurting yourself on it when you get bounced around. Should work nicely, Peter!
Windshield? Grabrails? T-top or bimini?
Re: Curacao CS 25
Posted: Thu Sep 01, 2011 2:44 pm
by tobolamr
Peter - I can't wait to see how it looks when you FINISH the console!
Re: Curacao CS 25
Posted: Thu Sep 01, 2011 6:02 pm
by gk108
I like it, too. It reminds me of some of the new aircraft instrument panels. None of those rows of visually fatiguing round dials. I also think a steering wheel would be a nice addition, along with joystick steering.
Re: Curacao CS 25
Posted: Thu Sep 01, 2011 8:46 pm
by peter-curacao
Ahh okay my bad sorry
, thought because of the tractor comparison it looked like a piece of sh.t
Well as for the request for the steering wheel here it is
In the photo (pic 1) you see the standard configuration which I (after long looking at it) didn't like, so I decided to make a box (pic will follow) and lower it into the console without having the need of a external hydraulic oil fill plug, this gave me a big gap which I made a aluminum cover for and polished that (pic2)
Re: Curacao CS 25
Posted: Thu Sep 01, 2011 8:53 pm
by wegcagle
Looks great from here Peter. Where did you find the rod holders to fit your console? I know you were having a hard time a while back. Good to see you working on the beast
Will
Re: Curacao CS 25
Posted: Thu Sep 01, 2011 9:52 pm
by gstanfield
Looking good Peter, I love that banjo steering wheel
Re: Curacao CS 25
Posted: Fri Sep 02, 2011 5:39 pm
by tobolamr
Peter,
Please let me explain the tractor comparison: I grew up on a dairy farm in Wisconsin. Sometimes, when conditions were right, the front steering on the tractor was irrelevant. So you would steer by using the brakes. So the idea of 2 engines with no steering wheel made me think of steering the tractor with brakes. No offense intended - just sharing a laughable and positive experience from growing up on the farm. Thanks for letting me ramble!
Re: Curacao CS 25
Posted: Fri Sep 02, 2011 6:37 pm
That's the way twin engine boats are maneuvered in close quarters and slow speed. With a twin inboard boat I just center the helm and leave it there, and steer with prop torque, one engine pushing and one pulling. A lot like a tracked vehicle, you can turn it around in it's length. Twin outboards are very similar but the helm has more effect, so you use a combination of the 2. You can most certainly steer a twin engine outboard with throttles alone while running.
And Peter, I like your console
Re: Curacao CS 25
Posted: Sat Sep 03, 2011 7:05 pm
by cape man
I really like your console!
Re: Curacao CS 25
Posted: Tue Sep 06, 2011 12:14 pm
by ks8
I like the lock down of the equipment along with splash protection.
I don't think anyone likes the *need* for lock down, but you made it look nice!
Re: Curacao CS 25
Posted: Fri Oct 14, 2011 9:38 pm
by gstanfield
Re: Curacao CS 25
Posted: Fri Oct 14, 2011 11:09 pm
by wej
Great to see you are still at it Peter.
Re: Curacao CS 25
Posted: Sat Oct 15, 2011 12:08 am
by ks8
What a difference a detail makes.
Re: Curacao CS 25
Posted: Sat Oct 15, 2011 6:33 pm
by steve292
Nice work Peter
Re: Curacao CS 25
Posted: Sat Oct 15, 2011 7:08 pm
by chicagoross
Perfect timing, Peter - I'm thinking about how to wrap the rubrail around some serious curves in my round transom right now! Now I see how to wrap a rail with two different curve directions.
Re: Curacao CS 25
Posted: Sat Oct 15, 2011 9:52 pm
That looks great, Peter
You've accomplished a huge amount of work, is Gloria helping you
I can't believe how tight it fits under your porch. Not sure how you are working around it, must be tough
I'm ready for that fishing trip, build on
Re: Curacao CS 25
Posted: Sat Oct 15, 2011 11:41 pm
by TRC886
tobolamr wrote:LOL
That's not the old John Deere I saw advertised is it...the one with no seat or steering wheel? It was advertised as being perfect for the farmer who had lost his a$$ and didn't know which way to turn
Peter, your boat looks great. I like everything you've done to it
trc
Re: Curacao CS 25
Posted: Mon Oct 17, 2011 5:45 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon Oct 17, 2011 8:05 pm
by peter-curacao
Potential boat name or not?
Re: Curacao CS 25
Posted: Tue Oct 18, 2011 8:48 pm
by peter-curacao
Cracker Larry wrote:That looks great, Peter
Hi Larry,
Gloria wants to help but she's getting itchy just by walking by when I'm sanding, so no no help in that area on the other hand I like to think I can do anything,in reality that's far from true for instance I can't organize and cleaning up is a complete disaster when I'm doing it! at least that's what Gloria tells me, (and I'm sure she's right) so that's were she's coming in , and I have to admit she's doing a far better job at is as I do, so yes she is a huge help and still the love of my life
As far as the fit maybe this pic will help get a perspective?
I think chicagoross has less space with his new build
Re: Curacao CS 25
Posted: Tue Oct 18, 2011 10:09 pm
Ugh. That's a lot of fairing. I don't envy you there my friend, but you'll get it.
I bet! If you get tired of her just send her to me
How many air conditioners do you have on that house
Re: Curacao CS 25
Posted: Tue Oct 18, 2011 10:18 pm
by peter-curacao
Cracker Larry wrote:Ugh. That's a lot of fairing. I don't envy you there my friend, but you'll get it.
LOL
I will, hope you have lot's of waiting time, was home late from work today, still did a lot of fairing before dark.
Cracker Larry wrote:How many air conditioners do you have on that house
4, one for every bedroom, we don't cool the rest of the areas in the house
Re: Curacao CS 25
Posted: Wed Oct 19, 2011 6:29 am
by wegcagle
Nice work Peter
that big ole boat sure is coming together beautifully.
Will
Re: Curacao CS 25
Posted: Wed Oct 19, 2011 4:22 pm
by chicagoross
Yeah, but you have the same feeling! Really a pain trying to fair on the side where you can't bend over...
Like you, I can't take a picture of the boat until it comes out of hiding...
Looks like you'll be on the water pretty soon! Where are you going to paint the traditional Curacao orange top?
Re: Curacao CS 25
Posted: Wed Oct 19, 2011 6:23 pm
by peter-curacao
chicagoross wrote: Really a pain trying to fair on the side where you can't bend over...
Spray painting even a bigger b..ch in such small spaces
chicagoross wrote: Where are you going to paint the traditional Curacao orange top?
LOL
That's as far as I know only obligatory to professional fisherman, and I'm far, far, faaaar from that!
good memory by the way
Re: Curacao CS 25
Posted: Wed Oct 19, 2011 6:53 pm
by chopperman
Your fairing work is looking real nice, Peter
Re: Curacao CS 25
Posted: Wed Oct 19, 2011 6:57 pm
by peter-curacao
chopperman wrote:Your fairing work is looking real nice, Peter
Well thank you! I really like the boats you build/building really nice detail in it
Re: Curacao CS 25
Posted: Thu Oct 20, 2011 9:05 pm
by peter-curacao
Sanded the sole today just to clean it up for 8 oz cloth, hopefully this weekend. Then everything is in glass and resin, so finally I just can use a water hose once in a while to clean up
Re: Curacao CS 25
Posted: Fri Oct 21, 2011 5:40 pm
by peter-curacao
Lot of sanding done, still more to come, tomorrow it's time to cover the sole
Acapulco deck
gunwale's
On the scupper tubes you can see how much dirt came from the sole
Detail still to be finished
Sole cleaned up,sanded and ready for 8 oz woven I think
Re: Curacao CS 25
Posted: Sat Oct 22, 2011 6:04 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Oct 22, 2011 6:16 pm
by peter-curacao
Did I mention
came early this year
Re: Curacao CS 25
Posted: Sat Oct 22, 2011 6:35 pm
by gstanfield
The boat is looking good Peter, congrats on getting everything glassed. That motor should be very nice on this boat too
Re: Curacao CS 25
Posted: Sat Oct 22, 2011 7:58 pm
by wej
Looking forward to seeing performance numbers when that Etec gets mounted and fired up!
Re: Curacao CS 25
Posted: Sun Oct 23, 2011 4:39 pm
by peter-curacao
Thanks George
wej wrote:Looking forward to seeing performance numbers when that Etec gets mounted and fired up!
Me to! I have no idea what to expect, they advised me this Cyclone prop, so not knowing much in that area I went with that advice, only thing brought in myself is that I wanted it stainless steel.
Re: Curacao CS 25
Posted: Mon Oct 24, 2011 5:56 pm
by peter-curacao
As suggested by Daddy inside locker benches in fairing compound for easier cleaning
Re: Curacao CS 25
Posted: Mon Oct 24, 2011 7:13 pm
by Aripeka Angler
Peter, your boat is looking very nice
The finish work looks great! Santa was sure nice to send an early present
Re: Curacao CS 25
Posted: Tue Oct 25, 2011 1:36 pm
by Jtrees
Your boat looks great! Nice work! Im an Evinrude fan too, so im curious to see the perfornace of your 300.
Happy Boat Building,
Jtrees
Re: Curacao CS 25
Posted: Tue Oct 25, 2011 2:41 pm
by tobolamr
Peter - looking great! Congratulations on the outboard! I really look forward to your feedback on it, and long-term use reports on it, too. Keep up the great build!
Re: Curacao CS 25
Posted: Thu Oct 27, 2011 1:43 pm
by peter-curacao
Just to be sure, can I hinge a hatch with an outline like this?
Thanks for the compliments btw
Re: Curacao CS 25
Posted: Thu Oct 27, 2011 3:27 pm
by dbcrx
You should be able to. I have seen some unusual shape hatches on some boats.
You might need to place the hinges slightly nearer the middle than normal or trim the hatch a little smaller so there's a bit more space for it to close without rubbing, but it should be doable without looking bad.
Re: Curacao CS 25
Posted: Thu Oct 27, 2011 3:32 pm
by peter-curacao
dbcrx wrote:You should be able to. I have seen some unusual shape hatches on some boats.
Okay Thanks I will directly give it a try
Re: Curacao CS 25
Posted: Thu Oct 27, 2011 5:16 pm
Yeah, just have to use the right hinge. Even a round hatch can hinge. A piano hinge won't work
Re: Curacao CS 25
Posted: Thu Oct 27, 2011 6:28 pm
by ks8
Send another picture showing where you hope to place hinges, and what sort of hinges. You may have a problem if you had planned to have the lower surface of the hatches resting on a cleat surface in the opening all the way around on the inside of the opening.
With interior bungee hinges, you can do most anything with most any shape because you are not bein restricted by unforgiving stiff metal hardware in the geometry ... but bungee hinge points are not as secure and *tight* ...
Re: Curacao CS 25
Posted: Thu Oct 27, 2011 6:48 pm
by peter-curacao
Cracker Larry wrote: A piano hinge won't work
LOL
ks8 wrote:Send another picture showing where you hope to place hinges, and what sort of hinges. You may have a problem if you had planned to have the lower surface of the hatches resting on a cleat surface in the opening all the way around on the inside of the opening.
Sorry ks 8 already made the cuts and it seems to work I think, also I used your tip for the grab rails outside just under the seat, as always pictures will follow .
Re: Curacao CS 25
Posted: Fri Oct 28, 2011 12:16 pm
by ks8
cool.
I really like those hand grabs. When it comes to painting and re-painting, they may be something that in the future I will have bolted on and removeable, but on my current boat, I like them super strong for supporting the removeable deck boards, and they are crazy strong with those dowels even before any epoxy was used.
waiting for the pictures...
Re: Curacao CS 25
Posted: Sat Oct 29, 2011 7:58 am
by cape man
Peter, Haven't been around in a while. Great progress, and that is one very nice Christmas present!
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 10:47 am
by peter-curacao
Thanks Craig
Intentionally I wanted to paint my hull white but now I'm hanging more to a navy blue sort of color which remembered me at this post, how true is this?
TomW wrote:Peter with all your sun and temperatures I would highly recommend not doing the transom dark keep it white. Put your port on the back if you want. Or the name of the boat.
The main problem with dark colors and epoxy is that it will over time telegraph the fiberglass through the finish. This is less a problem if you used Silvertip but can still occur.
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 12:02 pm
by Daddy
Light colors work best especially in hot climates with lots of sun. Dark colors on horizontal surfaces suffer the most, not as much on vertical surfaces
Somewhere I read that, "There are only two colors to paint a boat, white or black and who wants a black boat?"
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 1:42 pm
by ks8
Another version....
*You can paint a boat any color at all... as long as its white.*
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 3:34 pm
The quote is from Nathaniel Herreshoff
"There are only two colors to paint a boat, black and white. And, only a damn fool would paint a boat black."
Peter, I would avoid dark colors in your sun, yall live real close to the sun down there
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 6:31 pm
by peter-curacao
Okay thanks guys, I stick with white then
bit boring but better as paint what fails after time.
Daddy hard to imagine but there are people who wants black
boats
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 6:37 pm
by icelikkilinc
http://www.bateau.com/boats/CS23/index.html
White imho is boring.. why not choose a light color like this?
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 6:41 pm
by peter-curacao
Yeah I know that one, I don't like that color, I like the color of your TW 28 a lot,a real classy look
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 9:58 pm
by Mad Dog
peter-curacao wrote:Yeah I know that one, I don't like that color, I like the color of your TW 28 a lot,a real classy look
Peter, White: pro - better in the sun. con - it's boring and you don't like it.
Navy: con - not so durable in the sun. PRO - you really like it!!
It's your boat... make it yours.
Have you thought about "Rum Green"?
MD
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 10:26 pm
Perfect, not too dark, looks real good against white, well, as good as anything looks against this white I guess, but it's a good color for drinking
Re: Curacao CS 25
Posted: Mon Oct 31, 2011 10:36 pm
by Prarie Dog
Peter
How about white with a rum green stripe down the side. If you could find someone good with an airbrush they could probably put glasses in the stripe. That would look real cool.
My son want's to paint his GF lime green.
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 8:12 am
by icelikkilinc
if I was to built this boat, I would really plan on a graphic setup..
really love the flare to the bow and I think it needs some kind of flowing paint job..
light base color to finish with dark navy graphics with reddish stripes..
I think I want to build another one...
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 8:23 am
by peter-curacao
icelikkilinc wrote:if I was to built this boat, I would really plan on a graphic setup..
I did had some kind of plan like that, not really navy graphics but also cool I think :doh:
http://forums.bateau2.com/viewtopic.php ... &start=140
What exactly do you mean with navy graphics?
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 8:40 am
by icelikkilinc
fast typing...
I tried to mean graphics in a navy based color...
I have seen that graphic but for me the character of this boat lies to the bow.. Try to inject some kind of graphic there.. following the raise to he bow..
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 2:58 pm
by tobolamr
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 3:16 pm
by Steven
Funny. My kids keep telling me to paint shark teeth on the bow of the OB. Might just have to do it.
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 8:48 pm
by peter-curacao
Note to myself
ELFISH in this letter type
edit: also nice?
edit 2 A better one leave the charter out
Cool Rumnings does that mean something?
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 9:35 pm
by Spokaloo
E
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 9:39 pm
by Daddy
Hmmm, that would really jazz BUNKY up. I would have to change her name tho....
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 9:59 pm
by peter-curacao
Spokaloo wrote:
E
That's real cool
but the guys told me not to use dark colors, also that theme doesn't work here I think, because the overall background here looks like this
boring I know but it is what it is
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 10:00 pm
by Spokaloo
Peter, you are a cruel, cruel man. Our forecast is for snow all this week, and temps from -6C to +4C
E
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 10:03 pm
by peter-curacao
Spokaloo wrote:Peter, you are a cruel, cruel man. Our forecast is for snow all this week, and temps from -6C to +4C
E
I'm sorry
you know you are more than welcome here just buy a darn ticket
(and sandpaper)
Re: Curacao CS 25
Posted: Tue Nov 01, 2011 10:54 pm
by gstanfield
Sounds like a good idea Peter. We've had almost a foot of snow today here, still coming down too
Re: Curacao CS 25
Posted: Wed Nov 02, 2011 10:21 am
by peter-curacao
Re: Curacao CS 25
Posted: Wed Nov 02, 2011 12:06 pm
by gstanfield
Sounds like a great idea to me, only I'm about $1473 short
Re: Curacao CS 25
Posted: Wed Nov 02, 2011 4:22 pm
by ks8
Peter... have someone airbrush this on each side... put the shoreline about 4 inches above the waterline...
George... have you been surfing the calendars and posters over at despair.com?
Re: Curacao CS 25
Posted: Wed Nov 02, 2011 4:30 pm
by gstanfield
Never heard of despair.com, but they do have some neat stuff over there
Re: Curacao CS 25
Posted: Wed Nov 02, 2011 11:06 pm
by TRC886
gstanfield wrote:Sounds like a good idea Peter. We've had almost a foot of snow today here, still coming down too
Don't forget the sandpaper
trc
Re: Curacao CS 25
Posted: Wed Nov 02, 2011 11:10 pm
That pic ain't from Curacao, The trees are standing upright
Everything in the ABC Islands points downwind. Everything
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 1:06 am
by ks8
Easily adapted... lean all the trees toward the stern...
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 8:29 am
by peter-curacao
Cracker Larry wrote:Peter... have someone airbrush this on each side...
You are right it's a pic from klein Curaçao (little Curaçao) a small deserted island south east from Curaçao, popular for day trips and fishing.
You are also right about the trees, strange thing is the palm trees grows as straight as an arrow.
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 2:26 pm
by tobolamr
I liked your graphic at the stern, Peter - very cool!
But you gotta do something to match on the bow!
I still suggest "nose art" of some sort... That was a great suggestion, whomever made it!
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 4:21 pm
by peter-curacao
Benches are back in, everything glued and glassed, hatches are cut with cleats underneath, insides are sanded and ready for primer, outsides still need fairing compound and sanding.
Grab rail, suggestion of KS8, thanks
Hatch
Inside corners
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 4:22 pm
by peter-curacao
I really don't know about that
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 4:31 pm
by gstanfield
I'd keep it simple if it were me, no nose art.
The benches look great Peter, this boat is going to be wonderful when it's finished. I might just have to buy a flight down there so I can come and see it in person
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 4:34 pm
by wegcagle
Nice work on the benches Peter. They look awesome. Great job on those rounded edges, you made that looks easier than it should have.
Will
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 5:15 pm
Beautiful work Peter, you are really getting good at this
I love the radius on the seats, that will sure save some shin bones. The hatches are great too
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 6:26 pm
by chicagoross
The rounded corners on the benches look great - I'm sure someone's shins will appreciate that during "rock-and-roll" days!
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 6:37 pm
by tobolamr
Peter - it's YOUR boat! And she is already a beauty! I'm sure that however you finish her off, she'll make you proud! I really like your bow seats.
Re: Curacao CS 25
Posted: Thu Nov 03, 2011 9:13 pm
by ks8
I think your guests are going to appreciate those hand grabs. Only down side I've experienced is trying to prep and spray them, but even rolling over the wakes of other boats, they are handy!
btw, I ended up brushing their undersides and their *shadow on the vertical* with paint, and then sprayed around them. Got a run now and then. I'd be interested to know how you paint them and around them.
Really looking good Peter!
Re: Curacao CS 25
Posted: Sun Nov 06, 2011 4:39 pm
by peter-curacao
Thanks guys, KS 8 I'm not quite sure I understand your question, everything gets white paint so I don't go around them, just spray all at once
Itchy itchy
Sanding the bow section
Re: Curacao CS 25
Posted: Sun Nov 06, 2011 4:54 pm
by gstanfield
Looking good itchy guy
Re: Curacao CS 25
Posted: Sun Nov 06, 2011 8:33 pm
by ks8
Depending on the gun you use, it might be difficult to get the spray up under the handholds. I could not. So I painted under them by brush and then sprayed overall.
Re: Curacao CS 25
Posted: Mon Nov 07, 2011 6:31 am
by wegcagle
Looks great Peter. The bow seating has turned out really nice
I find that the itchies go away just in time for the next round of itchies
Will
Re: Curacao CS 25
Posted: Mon Nov 07, 2011 9:37 am
by peter-curacao
Well it's not a Rockwell and I didn't try it yet so can't tel you how it works, but I'm glad I found one it has six variable speeds from 11000 to 22000 RPM, it was Nafl 235,- that's a US$ 130,- let you guys know later how it works
Edit: little noisy but sands like crazy, didn't try to cut something yet, can somebody tell me where all the blades are for? there are also 2 blades in there with no teeth (the silver ones) I really wonder were those are for
Re: Curacao CS 25
Posted: Mon Nov 07, 2011 6:03 pm
Hope it works good for you. The silver blades are for scraping, like scraping paint or epoxy runs. The bronze colored one is for ceramics, glass, tile, grout. The rectangular are for flush cutting and stopped depth cutting. The round one will cut about anything, it's the blade I use the most for fiberglass and wood.
Re: Curacao CS 25
Posted: Mon Nov 07, 2011 6:13 pm
by peter-curacao
Cracker Larry wrote:Hope it works good for you. The silver blades are for scraping, like scraping paint or epoxy runs.
That's cool I certainly can use that
thanks for explaining which is which
Re: Curacao CS 25
Posted: Mon Nov 07, 2011 6:46 pm
The scraping blades have the least spectacular performance of the bunch. They are OK, but not great.
Re: Curacao CS 25
Posted: Sun Nov 13, 2011 6:04 am
by TomD
Peter great work on the benches - considering doing something similar on my C19 but slightly worried I don't have enough room. What are the dimensions of the benches? How much space have you got between the front of the console and the edge of the bench?
Re: Curacao CS 25
Posted: Sun Nov 13, 2011 9:02 am
by peter-curacao
TomD wrote:Peter great work on the benches - considering doing something similar on my C19 but slightly worried I don't have enough room. What are the dimensions of the benches? How much space have you got between the front of the console and the edge of the bench?
Tom I'm not sure which measurements you are looking for so I took a bunch for you (roughly), I think the benches are plenty big, I can lay on them very comfortable I'm not a big guy but also not the smallest( around 1,85 m) even without a fill in piece between them. (sorry don't know the name of that)
Also I can walk very comfortable around the CC and enter the bow area as you can hopefully see here.
Hope it's clear
Re: Curacao CS 25
Posted: Sun Nov 13, 2011 10:58 am
by TomD
Peter thanks very much for taking the time to do that - it looks great.
Re: Curacao CS 25
Posted: Sun Nov 13, 2011 11:59 am
by peter-curacao
TomD wrote:Peter thanks very much for taking the time to do that - it looks great.
Your very welcome, no problem at all
Re: Curacao CS 25
Posted: Sun Nov 13, 2011 4:39 pm
by BassMunn
Peter your boat is looking incredible, I can't wait to see your launch pics
And I'm very jealous of that white Monster you have in that crate
One just 1/3 of that size would do me just fine
Re: Curacao CS 25
Posted: Sun Nov 13, 2011 5:17 pm
by peter-curacao
BassMunn wrote:Peter your boat is looking incredible, I can't wait to see your launch pics
Well thank you I can't wait either, you don't have to be jealous I saved a long time for it
glad you like it though.
Re: Curacao CS 25
Posted: Mon Nov 14, 2011 4:38 pm
by Pat4
great looking bowseat. Table down and a sunbed for 2!!
Re: Curacao CS 25
Posted: Mon Nov 14, 2011 5:46 pm
by peter-curacao
Pat4 wrote:great looking bowseat. Table down and a sunbed for 2!!
thanks, I looked up your boat (the one in your signature)
she is amazing
missed that launch completely.
Re: Curacao CS 25
Posted: Tue Nov 15, 2011 4:37 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Nov 17, 2011 2:33 pm
by peter-curacao
Today I bought some hardware also two fuel vents like this
When I arrived home I saw the mesh screen was exactly on the other side as in the above pic so after installation the mesh will be facing upward, will this be a problem? (the knob is not turnable)
edit:If not a problem what is the appropriate height to put those trough the hull? my first guess is as high as possible but then maybe the fumes come into the boat, I have no clue
Re: Curacao CS 25
Posted: Thu Nov 17, 2011 2:58 pm
Yes. It will catch rain and sea water and funnel it into your tank! The hose barb should be mounted up, the screen down, and you make a circular loop in the vent hose to keep water from getting in the tank.
Mount it as high as possible, but leave room for a hose loop above it.
Re: Curacao CS 25
Posted: Thu Nov 17, 2011 5:20 pm
by peter-curacao
Aha thanks Larry I didn't know that, so because of the circular loop I still can use those? should that loop be a full circle or just go up with the hose then bend it down and connect it to the vent?
An other small step hull stiffeners glued and glassed in , I think I have to drill a small hole in them so I can put some foam in there, because now when I smash the side panels I hear the smaller pipes inside rattle, for sure it's going to annoy me at sea.
Could I do that with ordinary construction foam in a can?
Re: Curacao CS 25
Posted: Thu Nov 17, 2011 5:58 pm
Yes, you can still use them. Just point the screen opening down and angled slightly back so they don't catch spray. About 30 degrees back . A full circle loop in the hose is best, forming a trap, but it will work OK just looping the hose above the fitting and back down to it. The object is to drain any water that comes in back out, and to trap any water that makes it over the hump.
Re: Curacao CS 25
Posted: Thu Nov 17, 2011 6:26 pm
by Daddy
Foam in a can should be fine for that purpose.
Re: Curacao CS 25
Posted: Thu Nov 17, 2011 6:30 pm
by peter-curacao
Daddy wrote:Foam in a can should be fine for that purpose.
thanks Daddy
Re: Curacao CS 25
Posted: Thu Nov 17, 2011 6:31 pm
by peter-curacao
Cracker Larry wrote:so because of the circular loop I still can use those? should that loop be a full circle or just go up with the hose then bend it down and connect it to the vent?
Thanks Larry I try to do a full loop, pictures will follow
Re: Curacao CS 25
Posted: Fri Nov 18, 2011 1:40 pm
by peter-curacao
Should I do the deckfills and gas vents also drill fill drill or is just a epoxy coat and 3M 5200 sufficient enough?
Re: Curacao CS 25
Posted: Fri Nov 18, 2011 2:02 pm
by Mad Dog
peter-curacao wrote:Should I do the deckfills and gas vents also drill fill drill or is just a epoxy coat and 3M 5200 sufficient enough?
FWIW. On my rebuild, since the deckfill needed such a large hole, I cut it slightly larger then coated the exposed ply with a couple coats of epoxy (added a little filler the the second coat). The fastener holes were drilled and filled because they need a snug fit and might wear through the epoxy coating. My deckfill came with a neoprene gasket and is well above the waterline so I did not use 5200. The vent was built into the deckfill so I didn't face the need for a separate vent.
MD
Re: Curacao CS 25
Posted: Fri Nov 18, 2011 4:50 pm
My answer is the same as MD's, except that I use 5200 on everything
On holes that large I just coat the edges with 2 or 3 coats of epoxy.
Re: Curacao CS 25
Posted: Fri Nov 18, 2011 4:52 pm
by peter-curacao
Okay thank you both
so same for the venting just coat with epoxy?
Re: Curacao CS 25
Posted: Fri Nov 18, 2011 4:58 pm
Either way on that, it's a much smaller hole so easier to fill and re-drill, but a few coats of epoxy will seal the wood edges just fine too.
Re: Curacao CS 25
Posted: Fri Nov 18, 2011 5:20 pm
by peter-curacao
Cracker Larry wrote:Either way on that, it's a much smaller hole so easier to fill and re-drill, but a few coats of epoxy will seal the wood edges just fine too.
Okay thanks Larry I'm a bit confused now
so when do we drill fill drill? only below the waterline and screw holes above the waterline?
Re: Curacao CS 25
Posted: Fri Nov 18, 2011 8:40 pm
by Mad Dog
peter-curacao wrote:Okay thanks Larry I'm a bit confused now
The way I made those decisions was based on what was going through the hole. When the hole is for a fastener (bolt or screw) I drill and fill. I want as much protection where there is lots of stress. For big holes like deckfills and hawes pipes I just coat the exposed wood.
MD
Re: Curacao CS 25
Posted: Sat Nov 19, 2011 11:45 am
by peter-curacao
Thanks Mad dog
Okay this should do it, I think
Re: Curacao CS 25
Posted: Sat Nov 19, 2011 12:41 pm
by TRC886
That looks good, Peter
trc
Re: Curacao CS 25
Posted: Sat Nov 19, 2011 5:31 pm
by peter-curacao
Thanks trc 886
Covers to cover those hoses, tomorrow I will pull them of the mold and trim them to fit.
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 7:58 am
by topwater
Dont want to start a war here, but shouldnt the loop be higher than the inlet
Water will seek its own level, with the inlet higher wouldnt it keep filling the loop ?
I know that it would have to be under water to do it . just woundering
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 8:08 am
by peter-curacao
topwater wrote:Dont want to start a war here, but shouldnt the loop be higher than the inlet
Every comment/thought is welcome here topwater, I don't know but I thought the purpose of the loop is being filled by water in case some come in.
If it has to be higher I'm open for that if more guys think so
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 8:20 am
by topwater
Peter i always thought that the loop had to be higher than the inlet. That way any water that got in
would run back out. That high on the side of the boat you mite not have any problems, if you bury the
the rail long enough to fill the tank you mite be busy with other things than water in the tank
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 9:07 am
by peter-curacao
topwater wrote:Peter i always thought that the loop had to be higher than the inlet. That way any water that got in
I don't think it matters after all even if the loop is higher how can water run back out of a loop? LOL indeed if the water level is that high there's not much more to do as swim swim swim
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 9:32 am
by TRC886
I thought the same thing but didn't think he had enough room over the vent. Now that I have re-examined the pic, I believe that he does have room and should move it up. I also looked back a couple of pages and reread what Cracker Larry wrote:
Thank you for questioning it TW
trc
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 10:28 am
by peter-curacao
I don't think it matters he calls this one
http://forums.bateau2.com/viewtopic.php ... 00#p262383 perfect and that loop is also under the vent, I had to do port side that way otherwise the holes in the vent were facing upward, otherwise I had done the same as at starboard.
Looked in all 4 stores over here couldn't find the same vent as in starboard, I had one that I had to change because it was a sharp 90 degree bent and didn't fit trough the hole, maybe I have to look out for the same starboard vent
Edit: yeah that's what I gonna do I think wait till I find a better vent what has a connection facing upward, I'm almost certain the starboard site is okay like it is now
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 11:09 am
by dbcrx
I would have thought it was better to just have a goose neck (as big as possible). With a loop like that, if water gets in it will block off the vent.
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 11:25 am
It won't block it
The escaping air will bubble right through it. Think of putting a drinking straw in a glass of water and blowing through the straw. It takes almost no force to blow bubbles. Another good analogy is an air trap on a fermentation vessel for wine or beer making. It uses a water trap to keep outside, yeast laden air out, while letting fermentation gases escape through the water. Blub, blub, blub...
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 11:53 am
I don't think it matters he calls this one viewtopic.php?f=12&t=19940&start=300#p262383 perfect and that loop is also under the vent,
Notice on that one, the hose runs uphill from the vent fitting before it goes into the loop. This slight uphill run will keep spray, or water from a buried bow out. The loop itself doesn't have to be higher, but the initial run from the fitting should rise. As said, if the bow is buried long enough to get water in there, you've got worse problems than that
Peter, I would cut those zip ties and roll your loop as high as possible and re-tie them, the one in this pic will be fine, just roll the loop higher..
The one is this pic, I don't like it so much. That one needs work
No uphill run from the fitting..
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 1:03 pm
by peter-curacao
Cracker Larry wrote:The one is this pic, I don't like it so much. That one needs work
Thanks Larry for confirming that, It was dumb of me being impatient should have left that vent at the store and wait till they have a correct one.
Topwater thanks to bring this to my attention.
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 11:06 pm
by Jtrees
Your progress looks great peter, keep up the good work
Re: Curacao CS 25
Posted: Sun Nov 20, 2011 11:19 pm
by chopperman
Peter, my vent has a straight stem. Here's the one I ordered. I'm not sure if it would work in your aplication, but due to the angle of my hull side, it gave the stem a nice upward direction to start with.
Here's the one I ordered:
http://www.gandermountain.com/modperl/p ... rchID=4005
Re: Curacao CS 25
Posted: Mon Nov 21, 2011 8:57 am
by topwater
No problem Peter, i am building my first boat also and i am learning as i go. Just didnt look right to me.
If i could just figure out how to do quotes the right way
Re: Curacao CS 25
Posted: Mon Nov 21, 2011 9:55 am
by peter-curacao
chopperman wrote:Peter, my vent has a straight stem. Here's the one I ordered. I'm not sure if it would work in your aplication, but due to the angle of my hull side, it gave the stem a nice upward direction to start with.
Thanks chopperman, they sell those also over here, but I'm afraid I don't have enough room to use those. If I can't find the correct one I'm gonna give one like that a try.
Btw I'm gonna use the wrong one at my fresh water tank lot's more space in the bow, or maybe I vent that inside.
Re: Curacao CS 25
Posted: Mon Nov 21, 2011 1:02 pm
by Cooper
There's also something like this:
http://www.attwoodmarine.com/store/prod ... mount-vent (the 90 degree option). It's not directional.
Re: Curacao CS 25
Posted: Mon Nov 21, 2011 2:06 pm
by Steven
Maybe put in an elbow to change hose direction.
Re: Curacao CS 25
Posted: Mon Nov 21, 2011 9:43 pm
If the fitting is stainless or aluminum and you know a good welder, just cut off the stem, turn it 180 degrees and weld it back together
Re: Curacao CS 25
Posted: Tue Nov 22, 2011 8:42 pm
by peter-curacao
Reinforcing the drilled through frame, triple frame, hope that's okay!
just to keep it mirrored.
Re: Curacao CS 25
Posted: Tue Nov 22, 2011 9:07 pm
by TRC886
Re: Curacao CS 25
Posted: Tue Nov 22, 2011 9:38 pm
by peter-curacao
Yeah doesn't fit at all
Re: Curacao CS 25
Posted: Sun Nov 27, 2011 3:48 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun Nov 27, 2011 4:07 pm
by gstanfield
A little bit massive and maybe not the most elegant way to hide the hoses...
I disagree, that is a very nice way to hide the hoses. That rounded cover looks very professional and top of the line!
Re: Curacao CS 25
Posted: Sun Nov 27, 2011 4:10 pm
by Daddy
Looks good, I agree with George. What holds them in place?
Re: Curacao CS 25
Posted: Sun Nov 27, 2011 5:58 pm
by ks8
ditto
Re: Curacao CS 25
Posted: Sun Nov 27, 2011 7:30 pm
by TRC886
Ditto x 2
trc
Re: Curacao CS 25
Posted: Mon Nov 28, 2011 12:02 am
by chicagoross
The hose covers look great, Peter!
Re: Curacao CS 25
Posted: Mon Nov 28, 2011 5:33 am
by wegcagle
Looks good from here. I thought that he was going to fiberglass them in, and put access plates on the front. Maybe I'm wrong?
Will
Re: Curacao CS 25
Posted: Mon Nov 28, 2011 8:33 am
No comment
Re: Curacao CS 25
Posted: Wed Nov 30, 2011 1:23 pm
by peter-curacao
Thanks guys appreciate it
Daddy wrote:Looks good, I agree with George. What holds them in place?
Daddy
The covers are held in place just with ss screws in the extra frames, the hoses with clamps to the original frame
wegcagle wrote:Looks good from here. I thought that he was going to fiberglass them in, and put access plates on the front. Maybe I'm wrong?
Will
Will
The lower part is permanently glassed in and also functions as a water barrier up to 15 cm water on the sole, the upper part (not jet in fairing compound) is detachable and functions as a cover, the black circle in the pic I planned a cutout for a loudspeaker not a access plate
Last couple of days I didn't make any progress due to the flu
Re: Curacao CS 25
Posted: Wed Nov 30, 2011 1:34 pm
by ks8
Feel better Peter ... now spraying my keyboard with disinfectant and nalozadfkjgawer afvgkuaflighaert asfigar likh f lgasldkjhr lhk,bjkjasdgf asDFOOASDKFAGF SDF _________________________________________________ {Keyboard buffer overflow error:7103:0:2:process terminated}
Re: Curacao CS 25
Posted: Wed Nov 30, 2011 3:21 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed Nov 30, 2011 4:25 pm
by ks8
Not big on star wars... though as I have watched quite a few older movies, and black and whites... it is eye opening to see how many plots George Lucas lifted from other movies, and then squeezed them into his scifi franchise. Hey, there are only so many plots and plot combinations out there, right?
We have a bird in the woods here in NC that sounds something like Edward G Robinson going *whaaaa* like a child that wants candy, but sounding like a little bird version of Edward G Robinson. I call it the *Anakin* bird... after the last two StarWars movies, though, I guess they are more officially SW 2 and 3, out of 6. I'm confused by it all now, and SW is not my movie of choice on a rainy cold day. I'd rather pop the black and white *Captains Courageous* into the DVD player. But SW has given me the *Anakin* bird.
edit - regarding the picture you added... yes, proof that some people have far too much free time...
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
http://www.youtube.com/watch?v=zeB6VhbbY_g
Re: Curacao CS 25
Posted: Sat Dec 03, 2011 12:12 pm
by peter-curacao
Bayport_Bob wrote:peter-curacao wrote: Bob just looked at your website that boat looks very sharp, what did you use for a nonskid? it looks like it is raised very cool I like it.
Hi Peter - the non-skid is called Seadek, there is a similar product called Hydroturf that is a bit cheaper, but the colors are more for the jet ski crowd. It's held up well and is very nice to walk on barefoot.
- Bob
Bob took your post to here so I ain't hijacking Mike's thread again
It's a very cool product a bit expensive but it looks good, did you cut it yourself or did you sent in the templates? if you cut it yourself how did you get those angled sites, just by cutting it under an angle?
Re: Curacao CS 25
Posted: Sat Dec 03, 2011 2:00 pm
by AtTheBrink
peter-curacao wrote:Bayport_Bob wrote:peter-curacao wrote: Bob just looked at your website that boat looks very sharp, what did you use for a nonskid? it looks like it is raised very cool I like it.
- Bob
I put Seadek on the lid of my 70 quart Yeti cooler. It serves a dual purpose as a cooler and casting platform. It is very comfortable to stand or sit on and it has held up great! I put true Seadek on 5 years ago and it shows very little wear. It is adhesive backed high density foam. Very easy to cut and apply. The adhesive is bullet proof, I don't know if I could scrape it off if I wanted to! Great product...
Re: Curacao CS 25
Posted: Mon Dec 05, 2011 3:52 pm
by peter-curacao
I took it to here not to hijack doubleup's thread
Cracker Larry wrote:There's you saying something, But doesn't it get very bulky that way? I mean the wooden rubrail is already very thick, at that rubber rail over it wouldn't that look strange?
The wood part of the rail is only 3/4" thick, and the rubber rail less than that. To my eye, no, I like them bulky. Your styling preference is more European sleek. Just a matter of taste I reckon. But I usually go with function over style. This is at least better than a half dozen old tires, that's how we used to do it
The stainless rails look good on that Carolina hull, and it's fine if you like that, and you rig a few fenders before you pull up next to me. It won't take long for the metal to get dents all over it though.
I'm getting in doubt now, but how the heck am I doing those sections in rubber?
Re: Curacao CS 25
Posted: Mon Dec 05, 2011 4:05 pm
I think you could do it in rubber. The only real problem would be the transition amidships and you could make, or mold, or have made a cover piece to hide that transition joint. It's not as easy as an un-interrupted sheer line, that's for sure. The advice I was giving was more FS18 oriented than for your boat, but I think you could still do it in rubber.
http://gallery.bateau2.com/albums/userp ... shed_3.jpg
Re: Curacao CS 25
Posted: Mon Dec 05, 2011 9:17 pm
by tech_support
found this with a google image search, it may help.
http://www.thehulltruth.com/attachments ... is-10-.jpg
Looks like their solution is to kink the rubrail extrusion to follow the sheer, A rigid or semi rigid rub rail could be cut so it followed the break, take a wedge/angle cut out of the top and kink the rubrail up, the insert. If the insert were flexible enough, it might follow bend, or maybe you would have to cut it a little
Re: Curacao CS 25
Posted: Tue Dec 06, 2011 7:27 pm
by peter-curacao
shine wrote:found this with a google image search, it may help.
Strange I respond to this earlier now it's gone
Anyway Joel thanks for you tip but the rubrail from the boat in the pic is interrupted so it works for that boat, since mine isn't interrupted I think that way on my boat it won't look as good as in the pic, I think I need something like a Y coupling to make it look acceptable.
Re: Curacao CS 25
Posted: Tue Dec 06, 2011 7:35 pm
I think you will too. That ain't no sea for a sailor though
Re: Curacao CS 25
Posted: Tue Dec 06, 2011 7:50 pm
by peter-curacao
Cracker Larry wrote:I think I need something like a Y coupling to make it look acceptable.
Not sure I understand you
Re: Curacao CS 25
Posted: Tue Dec 06, 2011 7:58 pm
That ain't no hill for a climber either...
Sorry, just American shrimp boat slang, another way of saying that it's nothing that you can't solve
Re: Curacao CS 25
Posted: Tue Dec 06, 2011 8:15 pm
by peter-curacao
ahhh now I understand, we say (freely translated) no mountain to high or no sea to far.
Re: Curacao CS 25
Posted: Tue Dec 06, 2011 8:42 pm
Exactly
Re: Curacao CS 25
Posted: Sun Dec 11, 2011 12:19 pm
by TomD
Peter looks like your boat is coming on really well - congratulations. Sorry to go off topic a bit but I have been looking back through your posts as I would like to make curved front benches like yours and I had a few questions:
1) Did you bend them round a mold after cutting the slits or did you just glue them directly in place?
2) Was it difficult to get the tape to follow the curve and bend 90 degrees at the seams?
Trying to plan the next few steps in my head - I now have all my frames and stringers glued in on my C19 so shouldnt be too long till that stage...
Re: Curacao CS 25
Posted: Sun Dec 11, 2011 12:46 pm
by peter-curacao
TomD wrote:Peter looks like your boat is coming on really well - congratulations. Sorry to go off topic a bit but I have been looking back through your posts as I would like to make curved front benches like yours and I had a few questions:
Tom thank you, at the moment I'm not building,here December traditional is a month to do house maintenance and get it pretty for the holidays, so a lot of painting, putting up the Christmas lights outside, well you get it I think.
As for your questions don't be sorry I be glad to answer them the best I can, also proud you like to make yours the same.
1) I draw the curve on the sole and screw some temporary pieces 1,5"x3/4" on the sole what hold the ply in place, then I put the ply level and braced the upper sides with longer pieces 1,5"x3/4" to the frame, after that I spot "welded" them to the sole and side panels
2) it wasn't difficult at all, but I have to say I did cut it in on several places (sole side), I think with biax you won't have troubles at all.
I tried to find you some pics but unfortunately I don't have any of this build progress, so hope it's clear in words only, if not just let me know
Re: Curacao CS 25
Posted: Sun Dec 11, 2011 1:17 pm
by ks8
Biax can be tortured into all sorts of curves... just have clean oil free hands while you work the fibers to get the tape to follow the curves. Woven tape will need relief cuts to take those sorts of curves. have you got a build thread Tom?
Happy decorating Peter
Re: Curacao CS 25
Posted: Mon Dec 12, 2011 10:19 am
by TomD
Peter, thanks - I sort of understand. Did you make your temporary pieces follow the curve that you drew? I was thinking of cutting a temporary mold that was the shape of the curve I wanted and then using this to bend the plywood around and hold it in place vertically until the glue dries. Am I on the right track?
How far apart were your "slits" to get the curve?
Re: Curacao CS 25
Posted: Mon Dec 12, 2011 10:53 am
by peter-curacao
TomD wrote:Peter, thanks - I sort of understand. Did you make your temporary pieces follow the curve that you drew? I was thinking of cutting a temporary mold that was the shape of the curve I wanted and then using this to bend the plywood around and hold it in place vertically until the glue dries. Am I on the right track?
Tom I tried to illustrate this pic, the res dots and lines are the temporary pieces I was talking about, but I think your method works even better,the slits were approximately 1cm apart
Re: Curacao CS 25
Posted: Mon Dec 12, 2011 11:03 am
by TomD
Thanks Peter - I understand now. I will keep you posted on how it goes!
Re: Curacao CS 25
Posted: Wed Jan 18, 2012 1:23 pm
by cape man
Richard gave me the green rum on our recent adventure to Cape Sable. Thanks Man!!!
post some new pictures!
Re: Curacao CS 25
Posted: Sat Jan 21, 2012 6:30 pm
by peter-curacao
cape man wrote:Richard gave me the green rum on our recent adventure to Cape Sable. Thanks Man!!!
You are very welcome, hope you liked it if not same advice as I gave Joel, use it as an antifreeze in your car LOL
Bout the pictures, don't have any, didn't do anything
had family over for the holidays and at the moment I'm held up at work, hopefully first of March I get some more free time.
Re: Curacao CS 25
Posted: Sat Jan 21, 2012 6:59 pm
by gstanfield
No more free time until March
That's just sad
Re: Curacao CS 25
Posted: Sat Jan 21, 2012 7:51 pm
by peter-curacao
gstanfield wrote:No more free time until March
That's just sad
I don't understand why is that sad? I'm very happy, I lost a great tenant (ING) because they were leaving the island, I think I can sign shortly with another multinational, so I'm very happy
just have to accommodate them to their standards what will take some time, after that back to finishing my little addiction
Re: Curacao CS 25
Posted: Sat Jan 21, 2012 8:27 pm
Re: Curacao CS 25
Posted: Sat Jan 21, 2012 8:50 pm
by gstanfield
Well I guess making money is important too
I'm just spoiled because I only work 14-16 days a month
Re: Curacao CS 25
Posted: Fri Jan 27, 2012 1:44 am
by ks8
Everything we do is on someone's clock, whether work or rest. We were made for both.
Re: Curacao CS 25
Posted: Sat Jan 28, 2012 6:41 pm
by peter-curacao
Had some spare time today so I drilled some holes! yeah yeah for those like commenting! touché in advance
I think this Christmas three has only the necessarily ornaments
This one I promised couple months ago, sunken hydraulic steering pump
For those interested I bought my JL speakers
six 7,5 inch 2 way speakers and one 10 inch subwoofer driver
Have a nice evening
peter
Re: Curacao CS 25
Posted: Sat Jan 28, 2012 6:45 pm
by gstanfield
Your Christmas tree looks great Peter! Have a great evening to you too!
Re: Curacao CS 25
Posted: Sat Jan 28, 2012 6:51 pm
by wegcagle
Looks Awesome Peter
I love the console
Will
Re: Curacao CS 25
Posted: Sat Jan 28, 2012 7:06 pm
That is sweet and clean
Have a nice evening
peter
I think I'm going to the freezer right now and pull out some green rum, and Dori and I will toast in your behalf. Great work Peter!
Re: Curacao CS 25
Posted: Sat Jan 28, 2012 9:51 pm
by chicagoross
Looking good! nice tree
Re: Curacao CS 25
Posted: Sat Jan 28, 2012 11:30 pm
by ks8
Re: Curacao CS 25
Posted: Sun Jan 29, 2012 6:58 am
by topwater
Peter nice looking layout
Re: Curacao CS 25
Posted: Sun Jan 29, 2012 7:06 am
by frazoo
Very Nice, especially the recessed screens/monitors.
frazoo
Re: Curacao CS 25
Posted: Sun Jan 29, 2012 4:36 pm
by Larry B
Peter, that
Really looks nice. Do you have a picture you could show the inside of it? How you did it?
The rest looks great also,
Very nice work there Peter
Re: Curacao CS 25
Posted: Sun Jan 29, 2012 5:39 pm
by peter-curacao
Thanks guys I appreciate the compliments
Cheers Larry
Larry B wrote:Peter, that
Sure I can, actually it's very simple, I just glued a box under the console. The hole in the console is as big as the base of the pump because the pump is conical, to close that of cosmetically I made a big aluminum washer, in case water enters the box I made some drain holes for that.
Re: Curacao CS 25
Posted: Sun Jan 29, 2012 6:18 pm
Fine work there
Re: Curacao CS 25
Posted: Tue Jan 31, 2012 6:09 am
by cape man
Beautiful. Not bad for someone who can't get back on the build until March!
Re: Curacao CS 25
Posted: Tue Jan 31, 2012 7:31 am
by peter-curacao
cape man wrote:Beautiful. Not bad for someone who can't get back on the build until March!
Yep change of plans they gave me until the first of may so plenty of time, which also give me some spare time
Re: Curacao CS 25
Posted: Tue Jan 31, 2012 7:35 am
by Aripeka Angler
Peter, awesome job on your console
I really like the layout!
Re: Curacao CS 25
Posted: Wed Feb 01, 2012 10:22 pm
by peter-curacao
peter-curacao wrote:Thanks guys I appreciate the compliments
Cheers Larry
well it was fun but tomorrow there's an other day! have a great evening everyone and have a good and peaceful night
peter
Re: Curacao CS 25
Posted: Wed Feb 01, 2012 11:20 pm
Goodnight. Drain well .
Re: Curacao CS 25
Posted: Mon Feb 06, 2012 9:34 pm
by peter-curacao
Cracker Larry wrote:Goodnight. Drain well .
Sorry don't know why I quoted my own post
Re: Curacao CS 25
Posted: Mon Feb 06, 2012 9:50 pm
Re: Curacao CS 25
Posted: Fri Feb 10, 2012 10:20 pm
by peter-curacao
Touche from Gloria
with a big kiss and hug for you and Dori
http://www.youtube.com/watch?v=iGbxHm6ACVI
Re: Curacao CS 25
Posted: Sat Feb 11, 2012 12:08 am
Very cool
I love it. Kisses back to Gloria
Re: Curacao CS 25
Posted: Sun Feb 12, 2012 5:29 pm
by peter-curacao
Didn't feel like sanding to much so I "finished" the Pelagra tubes this weekend,I know normally there is no lid on a Tuna tube but the Pelagra's does, why ? well I don't know why, guess because I like it that way
Made a level lid base
Other angle
I tried the art of engraving, printed a design on a label out of the CD/DVD era, slapped it on the underside of the lid and away I go!
Here's the result, I know it is far from perfect, still I'm quite happy with it for the first try, I do regret the lettering though
Here's the both of them, I think it combines well with the live bait lid
Edit: Still didn't figure out the locks, I like to keep it clean so I'm thinking strong magnets
Re: Curacao CS 25
Posted: Sun Feb 12, 2012 6:36 pm
by Aripeka Angler
Nice work Peter
I like the personal touch on your lids!
Re: Curacao CS 25
Posted: Sun Feb 12, 2012 7:49 pm
I love the fish engraving, that's cool
Never seen a lid on a tuna tube, but if you like it, why not
Re: Curacao CS 25
Posted: Sun Feb 12, 2012 8:22 pm
by majorgator
I really like the engraving too. Little personal touches like that are certainly worth the time, and they help your boat to stand apart from anything else out there. Like Larry, I've never seen lids on tuna tubes, but I've also never seen tuna tubes mounted in the transom like that. All that I've seen are mounted outside the transom. Again, things like this make your boat stick out from the rest. I think I like them in the transom...and with lids.
Re: Curacao CS 25
Posted: Mon Feb 13, 2012 7:38 am
by topwater
Nice job on the tubes Peter
I think the covers make it a much cleaner installation, very cool
Re: Curacao CS 25
Posted: Mon Feb 13, 2012 8:11 am
by wegcagle
Nice work Peter. I really like the integrated tuna tubes and the covers.
Will
Re: Curacao CS 25
Posted: Mon Feb 13, 2012 4:21 pm
by peter-curacao
Question can I put epoxy thickened with fairing filler over primed areas? I forgot If I have done that on the outside (almost sure I didn't), I like to start priming some areas but I'm sure I have areas that will look bad after primer is on
Re: Curacao CS 25
Posted: Mon Feb 13, 2012 4:36 pm
Is it an epoxy based primer like S3? If so, I'd say yes. I've done some small spots, with QF over primer. Heck, I covered my hull bottom with epoxy/graphite over S3 primer and it's still stuck good
Re: Curacao CS 25
Posted: Mon Feb 13, 2012 4:41 pm
by peter-curacao
Cracker Larry wrote:Is it an epoxy based primer like S3? If so, I'd say yes. I've done some small spots, with QF over primer. Heck, I covered my hull bottom with epoxy/graphite over S3 primer and it's still stuck good
That's fast thanks Larry, yes it will be a epoxy based primer (PPG) , reason I asked is I think it won't be only small spots.
Re: Curacao CS 25
Posted: Mon Feb 13, 2012 4:47 pm
Try a test piece of some scrap wood before going all the way. Make sure it all sticks together, I'm only vouching for S3 primer, not sure about other brands.
Re: Curacao CS 25
Posted: Mon Feb 13, 2012 4:52 pm
BTW, Dori and I have just reserved a 2 bedroom house in Cudjoe Key for the week after the builders meet, June 10-17. If you manage to make it to the meet you can share space with us. Richard and Sandi have booked a house almost next door, and we're going to have a big time that week
Re: Curacao CS 25
Posted: Mon Feb 13, 2012 5:29 pm
by peter-curacao
Thanks Larry I will remember that
Re: Curacao CS 25
Posted: Sat Feb 18, 2012 3:05 pm
by peter-curacao
Sanding is really getting old now, don't know how much longer before I switch to workboat finish
Re: Curacao CS 25
Posted: Sat Feb 18, 2012 3:49 pm
by gstanfield
Looking good Peter. Don't give up on the nice finish
Re: Curacao CS 25
Posted: Sat Feb 18, 2012 5:46 pm
by chicagoross
I can understand that, especially on that size boat. My little tug cruiser can stand a workboat finish more than that sweet CS25. I have noticed that all of Devlin's tugs get the truck bed liner rolled all the way up to the gunnels, looks pretty good to me...
Re: Curacao CS 25
Posted: Fri Mar 02, 2012 7:41 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri Mar 02, 2012 8:05 pm
by chicagoross
I love the flowing lines of the hull and gunnels, sweet looking boat - lots of sexy curves!
Re: Curacao CS 25
Posted: Sat Mar 03, 2012 4:29 pm
by tobolamr
Peter - I'm a landlubber, so these boats didn't really interest me much... But man, watching your pictures of progress... That is a BEAUTY of a boat! Don't skimp - go for the awesome finish the first time! You won't regret it!
Re: Curacao CS 25
Posted: Sat Mar 03, 2012 8:32 pm
by peter-curacao
Thanks guys as always I really appreciate the comments and/or compliments
I received some stuff from Firgelli Automations, Just to give you guys an idea were I'm going with this center console here is a very rough and ugly setup for the door in my CC. I think after fine tuning and trimming the seams I will be okay, upper slider are two sliders welded together because I couldn't find the right one at the moment, I did order the right one in the meantime
Here's a short video
console sliding door
PS tobolamr what's a landlubber?
Re: Curacao CS 25
Posted: Sat Mar 03, 2012 9:05 pm
You don't do anything the easy way, do you
Very cool, when will I get to come fishing?
land·lub·ber
[land-luhb-er]
noun
an unseasoned sailor or someone unfamiliar with the sea.
Re: Curacao CS 25
Posted: Sun Mar 04, 2012 5:31 am
by dbcrx
Now that's just showing off!
Very cool.
Re: Curacao CS 25
Posted: Sun Mar 04, 2012 8:51 am
by topwater
Peter very cool
Re: Curacao CS 25
Posted: Mon Mar 05, 2012 2:13 pm
by tobolamr
In my case - Landlubber means one who is only familiar with smaller, inland, protected waters.
Re: Curacao CS 25
Posted: Tue Mar 06, 2012 9:52 am
by fastlane
Peter...Looking Great !!
I really love that boat. If i could get away with building another one that would be it for sure!
Re: Curacao CS 25
Posted: Fri Mar 09, 2012 10:39 am
by peter-curacao
Thank you guys
tobolamr wrote:In my case - Landlubber means one who is only familiar with smaller, inland, protected waters.
Okay now I understand
I thought the same as Larry explained and couldn't place that on a boating forum
Cracker Larry wrote:You don't do anything the easy way, do you
Overcomplicated?
Larry you know you and Dori are always more than welcome to come fishing
Re: Curacao CS 25
Posted: Fri Mar 09, 2012 11:01 am
by Steven
Very cool.
Re: Curacao CS 25
Posted: Sun Mar 11, 2012 6:11 pm
by peter-curacao
Since lots of people put their fuel tank under their center console I'm not sure this is really necessary and maybe a lot of work for nothing, but with Jacques quote
The rule book clearly mentions minimum distance (24") between ignition parts, fans etc. and fuel connections.For example, 24" between bilge pump and fuel filter.
in the back of my head I decided trying to isolate the fuel system from the CC.
Should this valve receive a ground wire also???
Sealed the the valve dial with a through deck gland, I think it should work.
Glued in the console
Front plate with valve will be glued in with silicone so its accessible after cutting the cured silicone
Re: Curacao CS 25
Posted: Sun Mar 11, 2012 6:23 pm
by Aripeka Angler
Nice looking work Peter
Re: Curacao CS 25
Posted: Sun Mar 11, 2012 6:44 pm
by majorgator
I like that Peter. Good idea
Re: Curacao CS 25
Posted: Tue Mar 13, 2012 5:19 pm
by peter-curacao
Re: Curacao CS 25
Posted: Tue Mar 13, 2012 5:32 pm
Wow. Nice detail. I'm surprised you didn't make it from stained glass
Re: Curacao CS 25
Posted: Tue Mar 13, 2012 9:09 pm
by TRC886
Cracker Larry wrote:Wow. Nice detail. I'm surprised you didn't make it from stained glass
There you go, giving him ideas again
Looks good, Peter
It'll soon be stained with fish blood anyway
Re: Curacao CS 25
Posted: Wed Mar 14, 2012 8:09 am
by peter-curacao
Anyone???
peter-curacao wrote:Should this valve receive a ground wire also???
Re: Curacao CS 25
Posted: Wed Mar 14, 2012 9:28 am
No need for that.
Re: Curacao CS 25
Posted: Wed Mar 14, 2012 10:59 am
by peter-curacao
Cracker Larry wrote:No need for that.
Thanks Larry
Re: Curacao CS 25
Posted: Wed Mar 14, 2012 1:57 pm
by tech_support
wow Peter, that sailfish is nice!
Re: Curacao CS 25
Posted: Thu Mar 15, 2012 10:22 am
by Uncle D
You are very talented Peter. Looks Nice!!!
Re: Curacao CS 25
Posted: Sat Mar 17, 2012 4:25 pm
by peter-curacao
Thanks for the compliments guys.
Put in my anchor not sure what to think of it
Re: Curacao CS 25
Posted: Sat Mar 17, 2012 7:46 pm
by mariocroatia
very very very nice....
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 2:08 pm
by peter-curacao
Thanks mariocroatia but I'm still not sure about it, showed the pic to a friend yesterday evening he thought it was a bit far out, but with this anchor roller it's impossible to bring it further into the bow, any input would be greatly appreciated.
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 3:15 pm
by dbcrx
It does look a little odd to me. Not sure if it's because you've got quite a large anchor (it seems to have a very long neck, if you get what I mean), or if it's just because I don't think I've ever seen an anchor/bow roller coming out the middle of the bow like that.
The only time I've seen anchors coming through the hull is on bigger yachts where they come out the side of the bow.
Maybe with a smaller anchor, one that fits up snugger to the hull, it would look quite cool.
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 3:33 pm
by peter-curacao
dbcrx wrote:It does look a little odd to me. Not sure if it's because you've got quite a large anchor (it seems to have a very long neck, if you get what I mean), or if it's just because I don't think I've ever seen an anchor/bow roller coming out the middle of the bow like that.
The anchor is a 16.5 lbs anchor and rated for boats 20-30 ft if I went 1model smaller 11 lbs I've got an anchor rated 15-25 ft, I played it safe and went for the 16.5 lbs
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 3:55 pm
I don't like it either, Peter. And your anchor isn't too large for the boat. I would carry one larger than 16.5 if it were mine, with a lot of chain. Don't go smaller just because it looks cool.
Me either. If it's going to penetrate the hull, it needs to be off to one side with a lot of plating, but your boat really isn't big enough for doing that. If it were mine, I'd put a pulpit on it. Some things have evolved over the centuries because they work. But I've already said that, and it ain't mine
Now if you had this....
Photo credit to jetskibrian, who is one heck of a photographer
The Enterprise leaving on her last deployment. May she return home safely. More pics here from Brian..
http://www.coastaloutdoors.com/ibf/inde ... opic=25484
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 4:40 pm
by dbcrx
peter-curacao wrote:dbcrx wrote:It does look a little odd to me. Not sure if it's because you've got quite a large anchor (it seems to have a very long neck, if you get what I mean), or if it's just because I don't think I've ever seen an anchor/bow roller coming out the middle of the bow like that.
Sorry, I wasn't suggesting a smaller (lighter) anchor. What I meant was maybe a different brand/style that has a flatter shape, but still with enough rating.
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 4:48 pm
by dbcrx
Something like this maybe
Might need a plate under it though.
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 4:49 pm
by peter-curacao
Me either
Here's where I'm aiming for, this is an interpid boat 24,5 feet but other brands like sea vee also aply it
I took the roller apart so I could put it further into the bow without making the haws pipe bigger, I think it looks much better now and it still functions
Before
After
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 4:52 pm
by peter-curacao
Understood, but this claw anchor is what Jacques recommended
for my area
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 4:54 pm
by dbcrx
That does look a lot better. Still the big gap between the roller and the plate of the anchor looks a bit odd, I think.
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 4:59 pm
by peter-curacao
dbcrx wrote:That does look a lot better. Still the big gap between the roller and the plate of the anchor looks a bit odd, I think.
That's the way the anchor is build, unfortunately I cant change that, with a pulpit that gap would be the same
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 5:42 pm
Interesting
Beauty is in the eye of the beerholder, I reckon
It just seems to me like it would be hard to control a swinging anchor in a choppy sea. Sometimes you need to be able to grab the line and do something with it.
IMO, that claw anchor is the best you can get, nothing wrong with that.
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 5:59 pm
by peter-curacao
Cracker Larry wrote:Interesting
LOL
in my case rum holder but I guess it is indeed, with the modification I don't think it look so bad, one thing is for sure the deck is clean and uncluttered no winches,rollers, cleats etc to trip over and or fall on, therefor I can lay "comfortable" on my belly in case I have to "play" the line. But I don't see myself anchor to fast in a choppy sea.
save that for the tranquil sunny beach days
Cracker Larry wrote:IMO, that claw anchor is the best you can get, nothing wrong with that.
Shiny also eh
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 6:11 pm
Shiny also eh
Not mine
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 6:38 pm
by gstanfield
I actually think it'll look good as long as you put a stainless guard on the hull to minimize scratches like in the pic you posted of the factory boat. It's defiantly a unique look, and unique will always be controversial. In the end it's your boat so if you like it you go with it
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 8:12 pm
by peter-curacao
gstanfield wrote:I actually think it'll look good as long as you put a stainless guard on the hull to minimize scratches like in the pic you posted of the factory boat. It's defiantly a unique look, and unique will always be controversial. In the end it's your boat so if you like it you go with it
Thanks George glad you do like it, I could use that positivity boost, I did plan a SS plate behind it, I just have to cut and build it, they sell plates online what makes me think this setup isn't so special at all, is it?
Bow protecting shield with hole in the middle to pass the hook. It protecting the boat’s bow when you weight anchor.
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 8:30 pm
by gstanfield
A simple template could be made from cardboard and then just trace it onto some sheet stainless complete with lines for where the bends go. Visit a local welder and he could cut it out cheaply and quickly with a plasma cutter
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 9:56 pm
by chicagoross
Looks much better tucked in a few inches in the second photo, Peter. I'd never seen that on a boat before!
Re: Curacao CS 25
Posted: Sun Mar 18, 2012 10:02 pm
by chicagoross
Peter, aren't you mainly coral reef around your island (like Guam)? My MM21 will probably need a roller mounted anchor also, but I'd sure hate to lose an anchor as pretty and as costly as yours! In Mexico, they weld their anchors of curved re-bar (strong enough to hold unless you're really stuck and want to bend the prongs using the boats motor), I did the same in PI only out of stainless (which is cheap there), but those have to be fairly large to work and would be too ugly to display on the bow...
Re: Curacao CS 25
Posted: Mon Mar 19, 2012 8:48 am
by topwater
Peter take at look at the new grady white boats , looks almost the same as what you have done.
Peter check your bow roller, that one looks like its for a danforth anchor, the one i have been checking
out for claw anchors drop down in the front and have two rollers to match the angle of the anchor shaft.
I would post a link but i am not very good at this computer stuff.
Re: Curacao CS 25
Posted: Mon Mar 19, 2012 10:02 am
by tampa_panga
Peter,
You may want to check the clearance between that anchor location and the front bow stop on your trailer (if you plan on storing your boat on a trailer). I've had anchor rollers get caught on the trailer bow roller when launching or retrieving on steep boat ramps.
Re: Curacao CS 25
Posted: Tue Mar 20, 2012 12:05 pm
by peter-curacao
chicagoross wrote:Peter, aren't you mainly coral reef around your island (like Guam)?
Not as much as I would like but yes, popular anchor places like klein (little) Curaçao is mostly sand. Good idea on the self made anchor I understand what you are saying.
Yep that's the one I have second roll sits inside the bow.
tampa_panga wrote:Peter,
I don't have a trailer yet so that would be no problem, but I would be much happier finding a docking place the time I did finish, but unless you are willing to pay a small fortune those are very rare here on the Island.
Brings me to the following question
I put my nav lights into the front corners of my hardtop so no need for shark eye nav lights, therefore I was planning those docking lights
anyone have experience with those? they are sold here but they are relatively very expensive, they look cool I think, but if they don't function it would be a waste of money.
next question
My plans calls for a bow eye, 203 mm isn't that ridiculously big? Can't even find them that long
Peter
Re: Curacao CS 25
Posted: Tue Mar 20, 2012 12:20 pm
I would skip the docking lights, never found those useful at all. There aren't many docks that don't have light on them, and a flashlight will do fine in the rare occasions you are docking in pitch black dark. Big expense, more troubles, more stuff to maintain and repair, for no gain.
My fuzzy math tells me that's about 8"
Must be a typo
Re: Curacao CS 25
Posted: Fri Mar 23, 2012 8:37 pm
by peter-curacao
I'm not doubting Larry, on the contrary,
but are there really no more opinions about those docking lights I posted earlier?
Re: Curacao CS 25
Posted: Fri Mar 23, 2012 10:32 pm
by Steven
peter-curacao wrote:I'm not doubting Larry, on the contrary,
We always used the spot light on the occasions no dock lights were present. Either handheld on smaller boats, or mounted remote control ones on the larger boats. I kind of agree with larry on not adding more than is absolutely needed. You'll have a spot for sure I would think. Might as well use what you have and not add more complexity. Now if you're just looking for a cool factor, go for it. They'll look awesome.
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 8:25 am
by peter-curacao
Thanks Steven and Larry, think camping at deserted beaches with no facility's like lights.
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 9:28 am
Usually when out at night your eyes adjust to the dark, and you have a little starlight and maybe some moon, it doesn't take much to see at night. Those docking lights won't have much range and are more likely to destroy your night vision that to really help you see. I've spent a lot of time out in the dark and find that the less lights on the boat, the better you can see. I seldom even turn on the running lights if I'm not in an area with traffic. Also, the flood lights I've got on the T-top will provide any light necessary for docking, if natural light isn't enough.
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 10:47 am
by tobolamr
I have nowhere near the experience that CL has, but I agree with him on every point he made. A lot of times when we fish late for a tournament, the bow/stern navigation lights make my night vision a little less sharp. The only thing I look forward to having docking lights for is so I can clearly see the trailer I would be about to land the boat on.
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 10:56 am
Good point, but even most of our boat ramps are lit, and again, the spreader light mounted on the T-top works good for that too.
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 11:06 am
by tobolamr
Yeah, one of our local lakes has lights at the ramp, the rest are dark.
But hey, that's why trucks have headlights!
And the "cabin on the lake" can be gotten to through a long, narrow, winding, no-wake, shallow channel - and when it's PITCH black out, those lights would be rather handy for that, too... And most of us landlubbers don't have T Tops..
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 11:36 am
by gstanfield
My old boat had "dock" lights on it, but I never really used them for that. I did use them for being able to see my way into the woods at night to answer the call or to navigate slowly through a swamp at night when it was overcASt and too dark to see without them.
Then again I doubt Peter has to worry about either of those scenarios on his boat
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 12:12 pm
I did use them for being able to see my way into the woods at night to answer the call or to navigate slowly through a swamp at night when it was overcast and too dark to see without them.
For that, I'd really prefer a hand held light. I've kept a Q-Beam on all my boats, ever since they were invented
Much more useful than mounted docking lights. But whatever you like and can afford is OK with me. They look cool and may occasionally be useful for something
Speaking of flashlights, the new high tech LED flashlights have about made big QBeams and such that runs off the boat battery obsolete. As a Christmas present from a couple of my eastern Tennessee boat building buddies, I got the best little flashlight that I've ever seen
It is amazing, runs on 4 AA batteries and will light up the world around you. With about 27 different light modes, you have to read a book and watch a video to figure out how to work it
But it's a bad @ss flashlight !
http://www.ledlenser.com/product/M14
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 12:31 pm
by gstanfield
I agree that a handheld would be better for those uses. My point was that even though my boat came with docking lights I never actually used them for docking
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 12:36 pm
by gstanfield
And as for flashlights, I'm a bona fide junky when it comes to flashlights. I'd hate to add up all the moeny spent on flashlights in the last 5 years, but anything by streamlight, surefire, 5.11, fenix and others will do quite well.
Larry, I've not used on elike you posted, but it looks neat and the reviews are good. Might be time for another flashlight
My favorite so far is the 5.11 light for life. It runs on capacitors instead of batteries. It is extrememly bright, lasts long and recharges in 90 seconds
It wasn't cheap though at about $170
http://www.511tactical.com/html511/static/LFLDemo.html
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 5:23 pm
by Pat4
I asked mysef the same question. The use of bowlights i mean.
very expensive and not very usefull. A spotlight will do better.
It looks great and thats why I searched for a cheaper alternative.
Find bowlights in a navigation type. Much less expensive (about €25 a piece instead od € 219,-) and it looks great.
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 6:10 pm
Aint many good things in life that are cheap
Sometimes it's cheaper to see than not to see. But I bet that's still cheaper than a good pair of docking lights, and a lot more useful.
It's been pouring rain all day and I've been sitting here doing my Mom's income taxes for her. Actually Turbo Tax has been doing her taxes while I fill in the blanks
Slow day in Georgia, but I think the rain is about over with now
3 1/2 inches since yesterday.
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 6:36 pm
by gstanfield
Wow, that's about two months worth of rain here
We had an inch of snow earlier this week, but no rain yet this year other than one 10 minute drizzle that barely wet the cars
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 8:56 pm
by peter-curacao
LOL welcome to my chatbox no need to subscribe! over here the weather is great, any other news from over the ocean?
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 9:42 pm
by gstanfield
I guess we did kinda hijack your thread.
Maybe you can quiet us down a bit by showing some progress on the CS25
Re: Curacao CS 25
Posted: Sat Mar 24, 2012 9:46 pm
I finished her taxes and it finally quit raining
The local Collard Green Festival kicked off today
http://www.wtoc.com/story/17246281/coll ... -wentworth
That was probably a big time, but I missed it
Nah, there ain't much happening. Weather is mostly beautiful, flowers are blooming, fish are biting, turkeys are gobbling in the yard. Been barefooted for a couple of weeks. Ain't had to shoot nothing lately. Life is good if I don't look around too hard
Re: Curacao CS 25
Posted: Sun Mar 25, 2012 8:58 am
by peter-curacao
gstanfield wrote:I guess we did kinda hijack your thread.
Don't worry about it chat all you want I like it better as whats going on down there in the basement
As for the pics not much to show but small progress, put in some hawse pipes at the stern, installed some loudspeaker holding plates under the gunnels also at the stern and I'm busy with the anchor locker
Re: Curacao CS 25
Posted: Sun Mar 25, 2012 8:45 pm
by peter-curacao
Btw should those be sunken into the deck or is it better not to do that because of wear on the deck by friction of the ropes?
Re: Curacao CS 25
Posted: Mon Mar 26, 2012 7:32 am
Yes, the hawse pipe should protect the deck.
Re: Curacao CS 25
Posted: Sat Mar 31, 2012 11:00 pm
by peter-curacao
gstanfield wrote:Oh yeah, to edit the title go back to the very first thread and click edit. While there you can change the title in the "subject" box and after saving it should show up with the new title
Let me try that LOL
let me change Curacao CS 25
Re: Seven bottles of beer on the wall.....
Posted: Sat Mar 31, 2012 11:03 pm
by peter-curacao
That did work!!!!
Re: Curacao CS 25
Posted: Sun Apr 01, 2012 9:22 am
by peter-curacao
Splashed her today
Re: Curacao CS 25
Posted: Sun Apr 01, 2012 11:19 am
by tobolamr
What??? Huh!? And NO PICTURES! ????
Re: Curacao CS 25
Posted: Sun Apr 01, 2012 12:39 pm
With a hose maybe
Re: Curacao CS 25
Posted: Sun Apr 01, 2012 2:10 pm
by Joe H
How much of a Fool do you think Larry is!
Re: Curacao CS 25
Posted: Sun Apr 01, 2012 3:43 pm
by peter-curacao
Your guys surely aren't some April fools
Re: Curacao CS 25
Posted: Sun Apr 01, 2012 4:03 pm
by chicagoross
Re: Curacao CS 25
Posted: Mon Apr 02, 2012 3:04 pm
by tobolamr
See?!?! I TOLD you guys there would be pictures!
Good one, Peter!
Re: Curacao CS 25
Posted: Tue Apr 03, 2012 9:48 pm
by nc_robbie
Peter its looking great I love what your doing and cant wait to see some action shots! Keep up the good work its magnificent. Rob
Re: Curacao CS 25
Posted: Wed Apr 04, 2012 9:04 pm
by peter-curacao
Thanks Robbie I appreciate it.
Hatch gutters
I'm "busy" with the hatches at the bow, the anchor locker is a small completely isolated compartment (white) and won't receive a gutter because water can enter and drain through the anchor hawse pipe
The side lockers as you can see I changed my mind on the form of the hatches, first idea where imo way to big (left) so make them smaller (right side) those lockers are only there to be able to reach the underside of the anchor winch, anchor rope and chain and maybe some fender storage also those sections receive 1 big drain to the cockpit. (half a 2")
One thing (of the many) I'm not so good at is make those hatch gutters
so here's my question do you guys think those two sections should receive a gutter?
Also I don't see any use for hatch gutters in the aft sole to the bilge lockers (bilge pump), input on those would be appreciated also
Re: Curacao CS 25
Posted: Thu Apr 05, 2012 3:03 am
by dbcrx
If you're happy to have them as wet lockers, and they have some way of draining the water out, then I wouldn't bother making gutters. You only need them if you want to have dry storage areas.
Re: Curacao CS 25
Posted: Thu Apr 05, 2012 4:32 pm
by peter-curacao
dbcrx wrote:If you're happy to have them as wet lockers, and they have some way of draining the water out, then I wouldn't bother making gutters. You only need them if you want to have dry storage areas.
Thanks dbcrx, it's not so much if I'm happy with the "wet" locker situation, more important is are my anchor chain, rope and winch happy with it? I know from time to time this stuff gets wet, but to keep it in a "wet" locker? don't know about that
Re: Curacao CS 25
Posted: Thu Apr 05, 2012 9:12 pm
by Aripeka Angler
Peter, I would put some drains under those hatches. I built some hatches into my red boat that didn't drain very well and I was not happy until I replaced them...
Re: Curacao CS 25
Posted: Thu Apr 05, 2012 9:31 pm
I've got a drain in my anchor locker that I can plug. Getting wet won't hurt the anchor gear.
Re: Curacao CS 25
Posted: Fri Apr 06, 2012 5:02 pm
by peter-curacao
Thank you gentlemen! so it seems I have to dig up my router
Re: Curacao CS 25
Posted: Sat Apr 07, 2012 9:47 am
by Cooper
It looking great!!
In my opinion, any locker with anchor line and chain is a wet locker. Knowing that, you can be better prepared for the realities of having a big mass of wet rope and metal bits cramped together in a tight closed area. The solutions I've used over the years are:
1) Make sure the anchor locker has an independent overboard drain so mud and water have a place to go.
2) Prevent the locker's contents from sitting in water.
3) Facilitate as much airflow as possible.
#1 is easy; just drill a hole through the side and cover with a clamshell. #2 and #3 you can achieve with a purpose-built solution or by lining the sides and bottom of the locker with dri-dek (
http://www.dri-dek.com). I use dri-dek to line the bottoms of every single storage location in my boats where something will sit without moving for long periods of time (anchor locker, console floor, some under-floor hatches, beneath semi-permanent coolers, etc.). The idea is to prevent a wet spot staying in one place and forming mold.
All that said, if it were my build, I would not bother with gutters on those bow hatches UNLESS I wanted them to match other guttered hatches throughout the boat (and I probably would, despite everything I wrote above, because I'm stupidly anal in that way
Keep up the awesome work!
Re: Curacao CS 25
Posted: Sat Apr 07, 2012 10:23 am
by peter-curacao
Thanks Cooper great tips! I like the dri-dek idea, only thing is I don't have one flat (horizontal) place in those lockers as you can see in the pic, I do plan to put a drain towards the cockpit at the bottom of that frame
Re: Curacao CS 25
Posted: Sat Apr 07, 2012 5:14 pm
by chicagoross
I like the dri-dek idea too, hadn't thought of that. Those tiles (available at the local big-box here, BTW) can be cut and I see no reason they can't line the angled sides of the hatch as well as a flat bottom. Not only promote draining, but also protect the epoxy and glass from anchor or chain dings. Peter, I can't see any reason you'd need gutters on those hatches, like Cooper said, just good drains and a bit of ventilation.
Re: Curacao CS 25
Posted: Sat Apr 07, 2012 8:41 pm
by nc_robbie
Peter every time in log on and come to your thread I am amazed with your craftsmanship and great ideas….keep it up man, its looking great one day I my tackle a bigger project but in the mean time I have enjoyed your build!!! Rob
Re: Curacao CS 25
Posted: Sat Apr 07, 2012 9:40 pm
by peter-curacao
nc_robbie wrote:Peter every time in log on and come to your thread I am amazed with your craftsmanship and great ideas….keep it up man, its looking great one day I my tackle a bigger project but in the mean time I have enjoyed your build!!! Rob
Robbie you make me blush! to much honor you give me! don't know what to say :oops:apart from thanks that is!
Re: Curacao CS 25
Posted: Sun Apr 08, 2012 9:54 am
by Steven
I have dri-dek for all my lockers. Plan to 5200 some to the in-sides of the anchor locker. No reason to let the anchor beat up the sides, even if it is all glassed in.
Re: Curacao CS 25
Posted: Sun Apr 08, 2012 10:09 am
by tobolamr
Steven wrote:No reason to let the anchor beat up the sides, even if it is all glassed in.
Good call. Even in my current boat, I grabbed a scrap of carpeting and use it under the anchors I keep around. At the store (furniture & flooring), we routinely sell the 18"x27" carpet samples off when they are discontinued, usually for $1 or $2 each, to try to cover our labor. You could get a small remnant or scrap, too. And if you watch, you could get some indoor-outdoor that would last a long time!
Re: Curacao CS 25
Posted: Fri Apr 13, 2012 5:10 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri Apr 13, 2012 6:24 pm
by Hope2float
Peter thanks for the compliments on my boat. The hatches that you are working on look great and probably took you a long time to fit them properly. I enjoy seeing all of your designs and engineering feets. I also take notice to all of your details, they look great!
Dave
Re: Curacao CS 25
Posted: Fri Apr 13, 2012 6:33 pm
by Boater45
Very nice Peter!!!
Where did you get your spring openers?
Re: Curacao CS 25
Posted: Fri Apr 13, 2012 7:55 pm
by wegcagle
Great job Peter. Top notch work as usual
Will
Re: Curacao CS 25
Posted: Fri Apr 13, 2012 8:50 pm
by Aripeka Angler
First class work Peter!
Re: Curacao CS 25
Posted: Sat Apr 14, 2012 9:22 pm
by nc_robbie
Looks great Peter…keep up the good work, you’re an inspiration to us all…Rob
Re: Curacao CS 25
Posted: Sat Apr 14, 2012 10:17 pm
by peter-curacao
Are all my pics gone?
Re: Curacao CS 25
Posted: Sat Apr 14, 2012 10:50 pm
by gstanfield
I hope not, it must be a temporary thing with the forum changing servers. If not I'll be happy that I host my photos elsewhere!
Re: Curacao CS 25
Posted: Sun Apr 15, 2012 11:18 am
by Spokaloo
Tony's having some issues with the PHP, he's working on it today.
E
Re: Curacao CS 25
Posted: Sun Apr 15, 2012 12:32 pm
by peter-curacao
Thanks for the feed back Erik
Re: Curacao CS 25
Posted: Mon Apr 23, 2012 7:43 pm
by Spokaloo » Sun Apr 15, 2012 10:48 am
8 days later...Big issues I reckon
Peter, the new link in your signature brings me to here
This video is unavailable
This video contains content from WMG and Spinnin' Records, one or more of whom have blocked it in your country on copyright grounds.
Sorry about that
Re: Curacao CS 25
Posted: Mon Apr 23, 2012 8:02 pm
by peter-curacao
Cracker Larry wrote:Peter, the new link in your signature brings me to here
Thanks Larry, you should be able to see it now
Re: Curacao CS 25
Posted: Mon Apr 23, 2012 8:46 pm
by Bluefish2
Venus, Mongo Jerry classic.
can't wait to see where the next link goes.
Re: Curacao CS 25
Posted: Mon Apr 23, 2012 8:56 pm
by peter-curacao
Mongo Jerry ?
the link should direct you to Venus from Shocking Blue a Dutch rock band.
Re: Curacao CS 25
Posted: Fri Apr 27, 2012 7:05 am
by Flea
Hi Peter, only come across your thread just of late... must say im lovin what your doing. looking good mate. Cant wait to see this girl splashed! i have always liked this design, and maybe one day, just one day..... meanwhile hope you dont mind me saving up all the tips im getting from your build.
Re: Curacao CS 25
Posted: Sat Apr 28, 2012 6:17 am
by Bluefish2
Hi Peter, I did see Venus by Shocking Blue. I also saw a lot of other titles and Mongo Jerry was just one of them. Great Link.
Mark
Re: Curacao CS 25
Posted: Mon Apr 30, 2012 2:39 pm
by nc_robbie
Peter, looking forward to seeing what you have gotten done over the weekend, please post some pics….Rob
Re: Curacao CS 25
Posted: Mon Apr 30, 2012 3:24 pm
I think he spent all weekend shopping for fishing tackle
Re: Curacao CS 25
Posted: Mon Apr 30, 2012 3:30 pm
by nc_robbie
Re: Curacao CS 25
Posted: Mon Apr 30, 2012 3:39 pm
Yep. and the best thing is, he's shipping it all to me
Re: Curacao CS 25
Posted: Mon Apr 30, 2012 3:49 pm
by nc_robbie
Yea agree 100% shopping from home is the greatest…then the magic UPS/FEDEX makes it all appear….Rob
Re: Curacao CS 25
Posted: Tue May 01, 2012 9:04 am
by peter-curacao
Thank you all!
Boater45 wrote:Very nice Peter!!!
Just the local marine store, funny when I started this build there was only 1 store selling this stuff, now there are 5 stores selling boat stuff,I wonder does that say more about my building speed or the speed the island has been developing
Flea wrote:.... meanwhile hope you dont mind me saving up all the tips im getting from your build.
Please do so I'm happy to share and even happier if some of those things actually would be used by fellow builders.
nc_robbie wrote:Peter, looking forward to seeing what you have gotten done over the weekend, please post some pics….Rob
I wish I could but I haven't done much since I had to work, Nice thing is tackle shops are open at work also
Re: Curacao CS 25
Posted: Tue May 01, 2012 5:16 pm
by chicagoross
Guam's going the other way regarding development, Peter; when I built the HMD there were 3 boat/motors/supply stores; now there's only one left...
Re: Curacao CS 25
Posted: Tue May 01, 2012 5:26 pm
by peter-curacao
chicagoross wrote:Guam's going the other way regarding development, Peter; when I built the HMD there were 3 boat/motors/supply stores; now there's only one left...
Man that sucks big time, lets hope it will take a turn in the positive way.
Re: Curacao CS 25
Posted: Thu May 03, 2012 5:59 pm
by peter-curacao
See a lot of pics of newly bought outboards lately, what made me wondering, I still have her laying like this (see pic) shouldn't I put her in a vertical position? or is this the stupidest question of the century?
don't know a lot of outboards
Re: Curacao CS 25
Posted: Thu May 03, 2012 7:26 pm
I would think so. Not sure with that engine. Probably a good idea anyway.
Re: Curacao CS 25
Posted: Thu May 03, 2012 7:28 pm
Andy has his laying down also..
Re: Curacao CS 25
Posted: Thu May 03, 2012 7:50 pm
by Steven
That's how my Yamaha sat until I installed it. It's a 4 stroke. It ships with no oil in it, so it's not a problem. Not sure if laying on it's side is any different than laying on it's front.
Re: Curacao CS 25
Posted: Fri May 04, 2012 3:00 am
by dbcrx
I think it only matters once it has oil in it. Then you have to make sure you lay it on the right side otherwise the oil will leak out. Most outboards (smaller ones anyway) should have a small sticker on it somewhere telling you which side to lay it on.
Re: Curacao CS 25
Posted: Fri May 04, 2012 5:28 am
by Flea
dbcrx wrote:I think it only matters once it has oil in it. Then you have to make sure you lay it on the right side otherwise the oil will leak out. Most outboards (smaller ones anyway) should have a small sticker on it somewhere telling you which side to lay it on.
\n
I agree, and i dont think its that critical with the two strokes' buy the way, congrates on the new evinrude! YOU WONT BE DISSAPOINTED FOR BUYING THE BEST OUTBOARD MONEY CAN BUY.
Re: Curacao CS 25
Posted: Fri May 04, 2012 7:05 am
by majorgator
Here we go again...
Re: Curacao CS 25
Posted: Fri May 04, 2012 7:16 am
Re: Curacao CS 25
Posted: Fri May 04, 2012 8:08 am
by Flea
LOL, knew i would get a bite. to tell you the truth, i would be happy with any new outboard if i had the money. I do admit evinrude seem to be a bit over the top $$$, still would love one but!
Re: Curacao CS 25
Posted: Fri May 04, 2012 8:54 am
by peter-curacao
Flea wrote: I do admit evinrude seem to be a bit over the top $$$, still would love one but!
Over here they are way cheaper as any other brand in the same size, why do you think this was my choice of motor?
Re: Curacao CS 25
Posted: Fri May 04, 2012 6:00 pm
by Flea
I didnt realise that peter! they are on of the dearer outboards here, and im not talking by a few dollas either! you lucky man.
Re: Curacao CS 25
Posted: Fri May 04, 2012 7:05 pm
by peter-curacao
Flea wrote:I didnt realise that peter! they are on of the dearer outboards here, and im not talking by a few dollas either! you lucky man.
That's so odd, hows that even possible?
Re: Curacao CS 25
Posted: Sat May 05, 2012 9:51 pm
by peter-curacao
Put some trim on my cc door, gave that some tiny filets, then sanded and sanded and sanded, and then sanded trough the glass on the corners I created with foam, so had to put some more layers of glass on, after that put some fairing compound on it and sanded again, hope I can put some primer on tomorrow! just too see where I'm at
Hope you guys understand without pics! this forum is the bomb!!! great gallery!, great pics storage space!
Edit: O yeah one other thing, couple months ago I let have Rambo (my English bulldog) had his way with the Dolphin I catched! he humped the brains out of that fish, today months later we saw the result! a beautiful mermaid was created, well educated also! off course she spoke English (little bullish) but also fisherman Latin imagine that!
for a mermaid she had some nice .... also! It sucks! if only the gallery worked I could show you guys those wonders of this world!
Re: Curacao CS 25
Posted: Sun May 06, 2012 9:17 am
by wadestep
I feel so deprived, not being able to see this beautiful creature from the sea (with her big ....). If only the pictures were working! (PS - I've moved over to photobucket, not to figure out how to get pictures there directly from the phone like Larry)
Re: Curacao CS 25
Posted: Sun May 06, 2012 9:36 am
It's easy Wade, even I can do it
Peter is just teasing us, his Dutch is showing now
Re: Curacao CS 25
Posted: Sun May 06, 2012 6:27 pm
by Flea
we need boat porn! pleeeease..
Re: Curacao CS 25
Posted: Sun May 06, 2012 7:26 pm
by peter-curacao
Flea wrote:we need boat porn! pleeeease..
Yeah I put the console in the high build primer, as expected that brought up lot of points that needs attention
as for the pics I'm still not allowed to post because of the quota, so I won't.
Re: Curacao CS 25
Posted: Mon May 07, 2012 12:44 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon May 07, 2012 1:39 pm
by tech_support
holy mackerel, now that's a console
Re: Curacao CS 25
Posted: Mon May 07, 2012 2:25 pm
by Prarie Dog
Awesome looking console. How did you do the louvers?? Real cool looking
Re: Curacao CS 25
All I can say about that is WOW
Re: Curacao CS 25
Posted: Mon May 07, 2012 2:48 pm
by tech_support
its an "art deco" console
Re: Curacao CS 25
Posted: Mon May 07, 2012 3:30 pm
by Aripeka Angler
Sweet!!!! Fine work man
If our boats ever meet I'm going to hide my console...
edit...gotta get a picture on this page
Re: Curacao CS 25
Posted: Mon May 07, 2012 3:42 pm
by BassMunn
WOW Peter that is the best console I have ever seen. Looks awesome!
Re: Curacao CS 25
Posted: Mon May 07, 2012 4:40 pm
by Doc_Dyer
Re: Curacao CS 25
Posted: Mon May 07, 2012 5:07 pm
by peter-curacao
Thanks guys appreciate the compliments letting me know I'm on the right track
Prarie Dog wrote: How did you do the louvers?? Real cool looking
You can find that here
http://forums.bateau2.com/viewtopic.php ... 50#p249774
BassMunn wrote:WOW Peter that is the best console I have ever seen. Looks awesome!
Are you forgetting your own console? that's a pretty awesome console also
touché
Also like a
Dog
Doc_Dyer wrote:pic request: one of the fish side in primer
Not sure if you mean this
Re: Curacao CS 25
Posted: Mon May 07, 2012 5:13 pm
by Doc_Dyer
forgot about the dog photo
ok forget about fish from outside... do large people fit in the console?
Re: Curacao CS 25
Posted: Mon May 07, 2012 5:19 pm
by peter-curacao
Doc_Dyer wrote:forgot about the dog photo
I'm about 1,85 meters I fit in there, sure it's a bit cramped and you won't be able to read the newspaper, but hey if you have to go you have to go. Door opening is 18 "
Re: Curacao CS 25
Posted: Mon May 07, 2012 6:04 pm
by ks8
Console *processing*...
Re: Curacao CS 25
Posted: Mon May 07, 2012 8:17 pm
by cedarock
That console is out of this world.......beautiful!
Re: Curacao CS 25
Posted: Tue May 08, 2012 3:31 am
by Flea
it does look very awesome!
Re: Curacao CS 25
Posted: Tue May 08, 2012 7:36 am
by Walkers Run
wow!!!
Re: Curacao CS 25
Posted: Tue May 08, 2012 8:21 am
by majorgator
Absolutely beautiful Peter
I have to say that the sliding front cover ups the ante for consoles
Re: Curacao CS 25
Posted: Tue May 08, 2012 10:42 am
by wegcagle
Great work Peter
When can you ship me one?
Will
Re: Curacao CS 25
Posted: Tue May 08, 2012 12:10 pm
by whosmatt
Yeah, that console is all well and good until you're 30 miles out and need to open the pod bay doors
"I'm afraid I can't do that...."
Re: Curacao CS 25
Posted: Tue May 08, 2012 1:15 pm
by peter-curacao
whosmatt wrote:Yeah, that console is all well and good until you're 30 miles out and need to open the pod bay doors
I'm not sure I understand you
Re: Curacao CS 25
Posted: Tue May 08, 2012 2:59 pm
by Spokaloo
It's a reference to the movie 2001: A Space Odyssey from the 1970's.
E
Re: Curacao CS 25
Posted: Tue May 08, 2012 3:24 pm
by whosmatt
peter-curacao wrote:whosmatt wrote:Yeah, that console is all well and good until you're 30 miles out and need to open the pod bay doors
http://www.youtube.com/watch?v=HwBmPiOmEGQ
The console looks great btw.
Re: Curacao CS 25
Posted: Tue May 08, 2012 4:25 pm
by peter-curacao
Spokaloo wrote:It's a reference to the movie 2001: A Space Odyssey from the 1970's.
E
Great Now I'm even more confused
that was one disturbing video
Re: Curacao CS 25
Posted: Tue May 08, 2012 4:49 pm
by whosmatt
Ha, sorry. Build on, nothing to see here.
Re: Curacao CS 25
Posted: Tue May 08, 2012 4:52 pm
by peter-curacao
No problem at all, glad you liked the console did you see the console movie ?
Re: Curacao CS 25
Posted: Tue May 08, 2012 6:53 pm
by whosmatt
peter-curacao wrote: No problem at all, glad you liked the console did you see the console movie ?
No. Why do I get the feeling it's going to be starring Rick Astley ?
Re: Curacao CS 25
Posted: Tue May 08, 2012 7:01 pm
by peter-curacao
whosmatt wrote:peter-curacao wrote: No problem at all, glad you liked the console did you see the console movie ?
LOL
no because of the Space Odyssey remark you made, anyway here it is posted earlier
http://forums.bateau2.com/viewtopic.php ... 30#p270256
Re: Curacao CS 25
Posted: Tue May 08, 2012 7:23 pm
by whosmatt
Holy @#&^ that's amazing. I saw pics but didn't realize it was power actuated. Open the pod bay doors, indeed
Re: Curacao CS 25
Posted: Tue May 08, 2012 7:35 pm
Peter doesn't fool around
Re: Curacao CS 25
Posted: Tue May 08, 2012 9:01 pm
by majorgator
Sheesh, I didn't know it was power-actuated either
That was SMOOOOOTH.
Curiosity, though...do you have a way to open and close it from the inside too?
Re: Curacao CS 25
Posted: Tue May 08, 2012 9:10 pm
by peter-curacao
majorgator wrote:Sheesh, I didn't know it was power-actuated either
That was SMOOOOOTH.
Yes, from the inside you can even close/open it partially.
Well that is the plan, I have the switches etc for it
Re: Curacao CS 25
Posted: Tue May 08, 2012 9:29 pm
by cedarock
If I were to go out on your boat, I would have to hold it......just to use the console!!!
Sweet!
Re: Curacao CS 25
Posted: Tue May 08, 2012 9:31 pm
by whosmatt
Cracker Larry wrote:Peter doesn't fool around
No kidding. That puts my little joke in an entirely different light. I was merely commenting on the fact that he used computer parts in the console.
Re: Curacao CS 25
Posted: Tue May 08, 2012 9:37 pm
by majorgator
Is there anyway that you can get it to make that cool "swishing" sound like the doors on Star Trek?
Re: Curacao CS 25
Posted: Tue May 08, 2012 9:40 pm
by whosmatt
majorgator wrote:Is there anyway that you can get it to make that cool "swishing" sound like the doors on Star Trek?
Oddly enough, that swishing sound is a recording of a toilet flushing on a train
Re: Curacao CS 25
Posted: Fri May 11, 2012 5:26 pm
by peter-curacao
Think I found a name finally?
it is on a T shirt I had for a long time , thought this name fits me a little because... well because it is my first boat build and it was a bit of a lucky shot building this boat, fishing here is a bit of a lucky shot
(something to do with Venezuelan fishermen) and last but not least I do like shots
Let me know what you guys think and don't spare me, if it sucks it sucks simple as that!
PS: Matt don't do so demeaning about your own boat man, you have created a great looking boat! certainly not a 'little joke" as you call it! just so you know!
Re: Curacao CS 25
Posted: Fri May 11, 2012 5:44 pm
I like it
Re: Curacao CS 25
Posted: Fri May 11, 2012 5:54 pm
by cape man
Peter,
Been away from the forum for a while. Super job man, and I love the Lucky Shot name. Still keeping that fighting chair of mine warm I hope...
Re: Curacao CS 25
Posted: Fri May 11, 2012 5:59 pm
by peter-curacao
cape man wrote:Peter,
For sure I do! you can count on that! great to see you here again kind of missed you
(I don't care if that sounds corny or gay or both) Hope to see you in the Keys if you have the time
Re: Curacao CS 25
Posted: Fri May 11, 2012 11:29 pm
by whosmatt
Haha, no I was talking about the 2001 reference to your super futuristic robot console
I like the name!
-M
Re: Curacao CS 25
Posted: Sat May 12, 2012 12:40 am
by Prarie Dog
I like the name too Peter. Great name for a fishing boat.
Re: Curacao CS 25
Posted: Sat May 12, 2012 5:43 am
by Flea
i like the name to. also you could call it "sure shot".... just throwing around another idea for you. either way you go its your boat and im sure whatever you name it will be great, cause it will mean somethng to you, which is all that matters.
Re: Curacao CS 25
Posted: Sat May 12, 2012 2:32 pm
by Walkers Run
Lucky Shot is a great boat name. Can't wait until I need to decide on a name.
Re: Curacao CS 25
Posted: Sat May 12, 2012 10:52 pm
by peter-curacao
Okay so Lucky Shot it will be! I hope that name isn't already forgiven over here otherwise it's back to the thinking chair!
I'm thinking of using the first logo not the parrot just the shot, shot glass
Re: Curacao CS 25
Posted: Sun May 13, 2012 12:25 am
by chicagoross
Sounds great, Peter - can't wait to see your next set of graphics! Wood inlays? stined glass? something new? I'm sure it will awesome!
Re: Curacao CS 25
Posted: Tue Jun 05, 2012 2:04 pm
by Fonda@kauai
That's the most high tech console I've ever seen Peter
Very cool. This is what Matt was referencing:
http://www.youtube.com/watch?v=kkyUMmNl4hk Any chance you could name your console Hal?
Looks amazing brother, build on....
Re: Curacao CS 25
Posted: Wed Jun 13, 2012 3:25 pm
by nc_robbie
Peter your boat is beautiful. I have spent the last day and half going over your thread again and it’s a wealth of information. I have been toying around with scaling down a cs 23 down to a 21 footer…but have not made the commitment yet. However if I do I may copy some of your ideas I love your bench in the front, and your console is right out of star trek, I love it keep up the great work I cant wait to see pics of it in the water…
Re: Curacao CS 25
Posted: Sat Jun 16, 2012 12:35 pm
by peter-curacao
nc_robbie wrote:Peter your boat is beautiful. I have spent the last day and half going over your thread again and it’s a wealth of information. I have been toying around with scaling down a cs 23 down to a 21 footer…but have not made the commitment yet. However if I do I may copy some of your ideas I love your bench in the front, and your console is right out of star trek, I love it keep up the great work I cant wait to see pics of it in the water…
Thanks for the compliments Robbie, I would be honored if you copy some of my ideas
Re: Curacao CS 25
Posted: Sun Jun 17, 2012 2:25 pm
by albatross1954
Greetings from Caracas, "neighbor” and "tocayo"!
I received the plans for my TW 28 just a few days ago. Excited about the journey ahead.
Have read through your thread with awe! Great work you have done!
I have a question for you: Did you buy your materials (plywood, epoxy, etc.) in Curacao, or import them from the US? I am sure you are aware of the conditions here in Venezuela....
Tks in advance
Pedro
Re: Curacao CS 25
Posted: Sun Jun 17, 2012 4:53 pm
by peter-curacao
Tocayo Indeed! although my name didn't come from Pedro but from Pierre, but what's in a name it means all the same, namely a stable reliable rock, at least that's what they say
Thanks for the compliments, I bought the glass and Silvertip epoxy kit from Bateau that will get you trough the basic build, just find a good reliable forwarder, for instance in Miami, it worked well for me.
The ply I bought here at the local marine store, mostly Okume from Bruynzeel beautiful stuff,also bought lots of gallons of West epoxy with the very slow hardener at that same store, this again because the kit will get you through the basic build but isn't enough to do extra stuff. How much extra stuff is all up to you and what you're fantasy will brings you
Good luck with your build
Re: Curacao CS 25
Posted: Sun Jun 17, 2012 5:22 pm
by albatross1954
Thanks a mill tocayo (*)!
Toying with the idea of buying the plywood kit from Bateau ( summer special and all ). Time is of the essence, I`ll turn 60 February 2014 and would really have it finish the "Partager" by then. Wishful thinking on my part? Maybe!.
Negotiating building site at a clients shop, he builds FB peñeros (**)
Pedro
(*) In Spanish having the same given name ( i.e. Pedro, Peter, Pierre)
(**) Small artisan fishing boats
Re: Curacao CS 25
Posted: Sun Jun 17, 2012 5:27 pm
by albatross1954
p.s . We have a relaible forwarder in Miami, need arises.
Re: Curacao CS 25
Posted: Sun Jun 17, 2012 5:31 pm
by peter-curacao
Yeah I understood, funny thing is my mom wanted to call me Pedro, but my granddads name was Pierre (French for Pedro or Peter) so in the end they just called me Peter (Dutch or English for Pierre and Pedro)
Now most call me crazy
Re: Curacao CS 25
Posted: Sun Jun 17, 2012 6:19 pm
by wegcagle
I can vouch for that
Glad you back safely Peter
Will
Re: Curacao CS 25
Posted: Sun Jun 17, 2012 9:17 pm
Me too, but in the best way possible. Peter ain't right
but he isn't wrong much either, and I'm very happy to call him a good friend
Re: Curacao CS 25
Posted: Sun Jun 17, 2012 9:24 pm
by albatross1954
Peter, I know you understood.
The notes were for our fellow builders not familiar with the Spanish language, or our Caribbean slang.
Do you know any one who has used the pre cut plywood kits?
Pedro
Re: Curacao CS 25
Posted: Mon Jun 18, 2012 6:55 am
by peter-curacao
No I don't but I hear they are pretty good.
Re: Curacao CS 25
Posted: Wed Jun 20, 2012 4:27 pm
by peter-curacao
Still sanding away, tomorrow second coat of HB Primer, hopefully next week I'm shooting final primer before paint, man those frames at the floor are a PITA to get them nice and round (I mean the corners where frame, sole and side panel meet)
Some out of whack pics
took them with a broken LCD so didn't see what I was taking, still they are not to bad I think.
Re: Curacao CS 25
Posted: Wed Jun 20, 2012 4:30 pm
by tobolamr
Looking good, Peter, Looking good! Keep up the great work! I really like how your bow is turning out.
Re: Curacao CS 25
Posted: Wed Jun 20, 2012 7:43 pm
by wegcagle
Nice work. You're really getting there now Peter. That boat's gonna be splashed before you know it
Will
Re: Curacao CS 25
Posted: Wed Jun 20, 2012 10:25 pm
by Joe H
Very nice nice Peter, I like the look!
Joe H
Re: Curacao CS 25
Posted: Thu Jun 21, 2012 11:51 am
by Uncle D
Looks great Peter, love that console.
Don
Re: Curacao CS 25
Posted: Thu Jun 21, 2012 2:57 pm
by nc_robbie
Peter its looking great keep up the good work!!!!
Re: Curacao CS 25
Posted: Fri Jun 22, 2012 4:24 pm
by peter-curacao
Thanks guys!
Busy figuring out my leaning post, I had a real complicated setup and build in mind for my seats, but then I saw this on the defender site.
http://www.defender.com/product.jsp?pat ... id=1965091
What do you guys think of it? does it looks good or cheap? it would make my life a lot easier dough, I only have to build the box and drawers etc with this.
Edit: Seat is as wide as the base of my CC, so at seating height it will be wider as my CC, not sure if that looks nice
Re: Curacao CS 25
Posted: Fri Jun 22, 2012 4:48 pm
by Uncle D
Re: Curacao CS 25
Posted: Fri Jun 22, 2012 4:49 pm
by Uncle D
I think it would look good. I bought a bench style seat that is a bit wider than the CC, but it's not as tall as a true leaning post. I think it looks good on mine. Most leaning post are wider than CC's anyways.
Just my .02, Peter
Don
Re: Curacao CS 25
Posted: Sun Jun 24, 2012 8:09 pm
by peter-curacao
Uncle D wrote:I think it would look good. I bought a bench style seat that is a bit wider than the CC, but it's not as tall as a true leaning post. I think it looks good on mine. Most leaning post are wider than CC's anyways.
Just my .02, Peter
Don
Thanks Don I appreciate you're input! I was hoping for some more input though
a well still didn't buy anything exept for the 12 mm okume
Re: Curacao CS 25
Posted: Tue Jun 26, 2012 11:57 am
by peter-curacao
Camo paint job?
Sanding second layer HB primer with 400
Re: Curacao CS 25
Posted: Tue Jun 26, 2012 1:52 pm
by Baseballfireh
The boat looks beautiful Peter. She is definitely one of a kind w the console and fighting chair and I really like the leaning post idea. I hope mine comes out half as nice as yours!
Re: Curacao CS 25
Posted: Tue Jun 26, 2012 8:40 pm
by nc_robbie
peter your boat looks great!!! i was doing some web looking and found something you may enjoy! Rob
http://www.dioncustomboats.com/blog.aspx
Re: Curacao CS 25
Posted: Tue Jun 26, 2012 9:05 pm
by Hope2float
Peter, what can I say? she is beautiful and your work speaks for itself. the world needs more people like you.
Dave
Re: Curacao CS 25
Posted: Tue Jun 26, 2012 9:37 pm
by wegcagle
Nice work Peter
. I don't think there's a flaw left on her. Now paint away
Will
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 11:39 am
by peter-curacao
Still struggling with the decision for my "leaning" post seats, still didn't order sh"t
therefore I can't start building the box
(good for the sanding progress though
So I'm gonna ask again hoping on a bigger response, if you guys don't mind.
This one is my first idea to use, it has a flip back feature what allows fore or aft seating and doesn't cost too much.
This is the second idea, those are 2 separate seats both has also the flip back option but no arm rests but I can order those separately, total set doesn't cost much either, what I do like in this setup is that one can sit fore and one aft.
Last idea is the most expensive, again the flip back option but also a flip up bolster, this setup will also take the most space.
I think I was looking at it to long because I can't make up my mind about it, also second option is hard to find unless I am willing to wait 6 to 8 weeks, I found one that can deliver directly but Paypal didn't except a different shipping and billing address.
http://www.springfieldgrp.com/products- ... red-chairs
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 11:47 am
by Lucky_Louis
Peter, I like them all - they look like good quality chairs that nicely match the character of your boat. Personally I would choose the 1st bench style instead of the individual seat. That's the style I built for mine only because I have family and some some guests who's derrieres simply wouldn't fit the other two styles. The benefit of the rear facing configuration is when you're in tough seas, the skipper has a leaning post while two guests can have their backs to the sea spray or rain and be more comfortable.
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 12:00 pm
I would go with the bench style also. In your seas, you will do more standing and leaning than you will sitting down. A leaning post is more versatile too, and you can fit an extra person or 2 in there if you need to. I would skip the arm rests, they just get in the way and gives you something to slam your gut, or big Jim and the twins into. Looks good in port, not so good in a rough sea. On an open bench you can lay across and sleep on a long trip, I've spent a few hours sleeping across Richard's
You do know that my friend Raymond builds custom leaning posts, and ships all over the world
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 12:01 pm
by tech_support
I personally prefer the single large one. I have only fished one boat that has the separated style leaning post/seat and it seamed like it was in the way with no clear advantage to being separate. If you ever want to sit three across it would be in the way.
They all look pretty nice though
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 12:03 pm
A seat style like the one you posted in your other thread is much more functional in the ocean.
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 12:23 pm
by peter-curacao
Cracker Larry wrote:A seat style like the one you posted in your other thread is much more functional in the ocean.
I wanna use the seat(s) I showed on, a box like that, don't be mistaken, you know the most fishing we (I) do is trolling, at trolling speeds even on our seas it's nice to sit, you are right on high speed trolling and higher speed driven, that's most of the time not doable sitting, as for the arm rests I like those because others standing next to the post can grab onto those also, and very important to, after a couple of Cuba libres it's nice sitting in a chair being able to hang over a armrest
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 12:27 pm
by Aripeka Angler
Something like this would be pretty functional too. Taco makes it, it is nicer than the one that we had on our Keys rental boat.
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 1:34 pm
Yes, that's the style I'm referring to also.
Better to use the T-top frames and grab rails for hanging on to. See the hand rails around that frame in the above picture? The seat arms won't last long for that, I'm telling ya da truth, and when you wrap your nuts around that arm rest, you'll throw it overboard
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 1:41 pm
by peter-curacao
Cracker Larry wrote:Yes, that's the style I'm referring to also.
My nuts
aren't hanging on my belly
Re: Curacao CS 25
Posted: Thu Jun 28, 2012 1:52 pm
Yet
Re: Curacao CS 25
Posted: Fri Jun 29, 2012 12:58 pm
by peter-curacao
Thanks guys for clearing my head on the seat options! Yesterday evening I ordered the first option I had, so the flip back bench! Time will tell if the armrests are in the way, luckily they are bolted on so easy to remove
This morning I did a little more shopping locally, now I can make the brackets inside the center console for those puppies
Re: Curacao CS 25
Posted: Fri Jun 29, 2012 1:01 pm
Re: Curacao CS 25
Posted: Fri Jun 29, 2012 1:02 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri Jun 29, 2012 1:08 pm
Re: Curacao CS 25
Posted: Sat Jun 30, 2012 10:33 pm
by peter-curacao
Thanks everybody for the "overwhelming" input I really needed! on my questions! I think I trim down a bit on my posts and pics also! and try to find some local advice!
Re: Curacao CS 25
Posted: Sat Jun 30, 2012 10:58 pm
by TRC886
peter-curacao wrote:Thanks everybody for the "overwhelming" input I really needed! on my questions! I think I trim down a bit on my posts and pics also! and try to find some local advice!
I always enjoy your posts and pics, and I don't think that you need to "trim down a bit".
Local advice is always good, but don't discount the international variety
Re: Curacao CS 25
Posted: Sat Jun 30, 2012 11:07 pm
by gstanfield
I think there was some sarcasm in there TRC, Peter's not avoiding the international advice, but rather he's not getting any
Peter, I'm sure there are many folks who would love to offer advice, but maybe they are like me and don't want to offer advice on something they have no experience with
Re: Curacao CS 25
Posted: Sat Jun 30, 2012 11:14 pm
by peter-curacao
Yeah right! like I'm the guy who ask hard questions!
Hey! I'm the simple guy! who needs advice also from time too time
Re: Curacao CS 25
Posted: Sat Jun 30, 2012 11:29 pm
by TRC886
gstanfield wrote:I think there was some sarcasm in there TRC, Peter's not avoiding the international advice, but rather he's not getting any
You're probably right. I'm in the third week of our summer schedule, (four 10 hour days), and I'm really dragging. I cannot seem to get to bed before midnight, and I've got to get up around 4 AM...and I'm too dang old to get by on 4 hours of sleep per night
I don't get much accomplished on the weekends, and I don't think too straight, 'cause I'm too danged tired
Getting old really SUCKS
Re: Curacao CS 25
Posted: Sat Jun 30, 2012 11:37 pm
by peter-curacao
It does!!! good night!
Re: Curacao CS 25
Posted: Sat Jun 30, 2012 11:42 pm
by TRC886
peter-curacao wrote:It does!!! good night!
Yes it does
Sweet dreams
Re: Curacao CS 25
Posted: Sat Jun 30, 2012 11:48 pm
by gstanfield
Maybe not hard, but still. I answered on the PPG paint stuff because I have about 20 years experience with that, but I have no experience with leaning posts or marine audio stuff
All of my boats have been either bench seat tiller steered or they have been "walk through" types with double consoles. As to your questions about your friend's boat I replied to that one before I came to work, but my internet died while typing (the joys of living on a mountain). I'll go repost it
Re: Curacao CS 25
Posted: Sun Jul 01, 2012 8:39 am
I don't know squat about marine audio systems
Re: Curacao CS 25
Posted: Sun Jul 01, 2012 11:33 am
by peter-curacao
I'm sorry about the postings above
I am very happy with all the advice and knowledge on this forum and what is given to me by you guys! I don't know what got into me
Re: Curacao CS 25
Posted: Sun Jul 01, 2012 12:12 pm
Something Dominican
Re: Curacao CS 25
Posted: Sun Jul 01, 2012 5:31 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun Jul 01, 2012 5:58 pm
WOW
Re: Curacao CS 25
Posted: Sun Jul 01, 2012 6:44 pm
by wegcagle
Absolutely amazing Peter. You really do great work
Will
Re: Curacao CS 25
Posted: Wed Jul 04, 2012 3:27 pm
by peter-curacao
Doesn't look like I have done much lately but as everybody knows looks can be deceiving
, with exception to the inside of the console and around the sole hatches everything is sanded and ready for a white primer. If you look closely you can already see some "shine" here and there
Back(in) side of the console door with vent pipe
Outside console door
Stern
Inside console
Bow
Overall from bow
Overall from stern
Re: Curacao CS 25
Posted: Wed Jul 04, 2012 4:12 pm
by Larry B
Peter all I can say is
AWESOME!!!!!!
Re: Curacao CS 25
Posted: Wed Jul 04, 2012 5:49 pm
by Prarie Dog
Peter, that looks incredible, awesome job man!!
Re: Curacao CS 25
Posted: Wed Jul 04, 2012 5:53 pm
by Aripeka Angler
Re: Curacao CS 25
Posted: Wed Jul 04, 2012 7:23 pm
by Seadation
Hello Peter,
That really looks great! The boat will be a fantastic fishing platform and your work/attention to detail is outstanding.
/david
Re: Curacao CS 25
Posted: Thu Jul 05, 2012 7:01 am
by Walkers Run
Really beautiful. Your hard work is paying off.
Re: Curacao CS 25
Posted: Thu Jul 05, 2012 7:37 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Jul 05, 2012 8:26 pm
if you found different shut the hell up and find another boat to fish of
Looks great to me, when can Dori and I come fishing
Re: Curacao CS 25
Posted: Thu Jul 05, 2012 8:32 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Jul 05, 2012 8:43 pm
While a Mercedes is nice, a Toyota will get you down the road too
I figure it will at least run for a few days while we are there.
Re: Curacao CS 25
Posted: Fri Jul 06, 2012 7:39 am
by topwater
Looking good Peter
Larry dont hold back tell us how you realy feel
Peter what are you useing to shoot paint
HVLP or regular gun
Re: Curacao CS 25
Posted: Fri Jul 06, 2012 8:47 am
by thb
Peter,
I think we builders are all too picky with the finish on our boats. You get to a point after fairing, sanding numerous times that I just say, fxxx it that is good enough. Sure I can see some imperfections in my build and maybe some other builders can too but who cares. Finish it and enjoy it. I think we all get too carried away with the finishing process. I think I will build my XF20 to work boat finish.
You should see some of the local around here who have build mullet boats with exterior ply and galvanized nails with polyester resin. They work all the same. Maybe they wont last forever, but they dont care.
Regards
Tom in Steinhatchee
Re: Curacao CS 25
Posted: Fri Jul 06, 2012 1:13 pm
by peter-curacao
Thanks guys
Topwater as far as I know all my guns are HVLP.
Re: Curacao CS 25
Posted: Fri Jul 06, 2012 5:57 pm
by peter-curacao
This is what I was talking about, I'm hoping it's only visible because of the suns floodlight
(is that the correct name?) otherwise there's nothing else to do as accept it or put a big kiwi grip patch over those area's, I think
Re: Curacao CS 25
Posted: Fri Jul 06, 2012 6:31 pm
I would Kiwi Grip the entire gunwale and move on. I wish I had done that on my OD18 instead of just putting the Kiwi Grip on in places as step pads. It's a place where people walk on everywhere. Or try to break up the imperfect areas and make step pads with KG where there are problems. Symmetrically of course. That was my solution, but I'd do it differently again.
One thing I've learned about boat building, perfection can never be totally achieved, but you can get pretty dang close, and I think you are about there
Re: Curacao CS 25
Posted: Fri Jul 06, 2012 6:33 pm
It's amazing how a surface can look perfect, until you put a glossy paint on it
Re: Curacao CS 25
Posted: Fri Jul 06, 2012 11:18 pm
by wej
That thing is some kind of sweet Peter. 2 thumbs up.
Re: Curacao CS 25
Posted: Sat Jul 07, 2012 6:50 pm
I've been priming the FS18 today with about the same results, the first coat showed me the spots that need some more attention
This FS18 is almost like building a model compared to your CS25. Makes me tired just to think about fairing your boat
Oh yeah, I need to tell you this. I heard today from a very reliable source that a fellow forum member whom you know bought a 26' Cape Horn this morning. Center console fishing boat, with twin Etecs! I told him I'd rather have a sister in a cat-house than a friend with Etecs, but he did it anyway
Glad I don't have any sisters
Re: Curacao CS 25
Posted: Sat Jul 07, 2012 6:55 pm
by Steven
I Kiwi Gripped all of the side decks and I'm happy with the results. You can step anywhere without thought. It is very grippy.
Re: Curacao CS 25
Posted: Sun Jul 08, 2012 10:57 am
by peter-curacao
Already two friends with ETECS ! where does it go with this world?
Re: Curacao CS 25
Posted: Mon Jul 09, 2012 7:49 pm
by peter-curacao
Now she's in white primer I felt like playing around a bit with some led lighting I bought for the gunnels
White mode
Stealth mode
Docking mode
Saint Patrick's day mode
There's also a Disco
mode but I will spare you guys a video from that
Re: Curacao CS 25
Posted: Mon Jul 09, 2012 8:56 pm
by chlli willie
Very cool lights, great lookin work!
Re: Curacao CS 25
Posted: Mon Jul 09, 2012 9:03 pm
by Hope2float
Those lights are cool looking. Lane has some LED in a blue color. They look better in person than on pictures. Peter that is some really nice work. The stiffeners on the console looked great as well. Keep up the above avg work. I look forward to what's next.
Dave
Re: Curacao CS 25
Posted: Mon Jul 09, 2012 10:03 pm
by tobolamr
Peter... I want to see the video of the lights in disco mode!!
Seriously! I do! And that lighting looks GREAT! I'm sure the red and the white will be really nice to have on the water.
Re: Curacao CS 25
Posted: Mon Jul 09, 2012 10:24 pm
by Fonda@kauai
I like it! I pre-drilled my frames for led's under the gunnel, just gotta choose the color...
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 7:53 am
by peter-curacao
Fonda@kauai wrote:I like it! I pre-drilled my frames for led's under the gunnel, just gotta choose the color...
Why not take the multicolored one? that way you don't have to choose anything.
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 10:17 am
by majorgator
TOO COOL
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 11:02 am
What, no disco ball
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 12:52 pm
by Aripeka Angler
AWESOME!!!! I really like the lights
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 2:24 pm
by Fonda@kauai
I may have to Peter. Mind if I ask where you got it?
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 3:30 pm
by peter-curacao
Fonda@kauai wrote:I may have to Peter. Mind if I ask where you got it?
I bought it locally but their are many online stores, here's 1
http://www.eaglelight.com/category/led-light.rgb-led/ just shout if you need any more help.
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 5:52 pm
by peter-curacao
tobolamr wrote:Peter... I want to see the video of the lights in disco mode!!
Seriously! I do!
Well you asked for it!!
WARNING !! the following video can cause epileptic reactions, Viewer Discretion Is Advised!!
http://www.youtube.com/watch?v=tp-u7zZXPZ0
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 6:06 pm
That's too cool
Edit: Don't even need a disco ball with all that going on
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 6:10 pm
by Joe H
PSYCHEDELIC DUDE!
jOE h
Re: Curacao CS 25
Posted: Tue Jul 10, 2012 6:31 pm
by wildbill
Holy Tarpon Boiling Squid Run !
Re: Curacao CS 25
Posted: Wed Jul 11, 2012 12:54 pm
by tobolamr
LOL That is really cool!
PS Peter - As a side note - Thank you SO much for taking the time to make the video. Life's been a real bear up here lately, and that brought a lot of happiness to my corner of the universe. It is much appreciated!
Re: Curacao CS 25
Posted: Wed Jul 11, 2012 1:19 pm
by peter-curacao
tobolamr wrote: that brought a lot of happiness to my corner of the universe.
And that makes me happy
Re: Curacao CS 25
Posted: Wed Jul 11, 2012 2:18 pm
by 94Virago
Now you have to make the lights pulse to the beat of your sound system. Your neighbors will LOVE IT!
Re: Curacao CS 25
Posted: Thu Jul 12, 2012 5:10 am
by chicagoross
Laughed so hard through the disco boat video my son came in to check out what I was up to
...Thanks Peter!
Re: Curacao CS 25
Posted: Thu Jul 12, 2012 8:36 am
by Walkers Run
[/quote]Well you asked for it!!
http://www.youtube.com/watch?v=tp-u7zZXPZ0[/quote]
That's the best thing I've ever seen
Re: Curacao CS 25
Posted: Thu Jul 12, 2012 9:40 am
by tech_support
Re: Curacao CS 25
Posted: Thu Jul 12, 2012 9:54 am
by peter-curacao
Glad I could bring some joy and happiness to you guys
Re: Curacao CS 25
Posted: Thu Jul 26, 2012 10:37 pm
by peter-curacao
started with the seat box
Re: Curacao CS 25
Posted: Fri Jul 27, 2012 8:03 am
by peter-curacao
Seat came in last Monday
It's a nice seat a little big, unfortunately it came damaged. The back rest flips back and forward so you have 2 seating configurations. Now I have to make the box for it to bolt on this will also be storage space. Don't think there is enough room behind it to mount the fighting chair I made, so that has to go.
Backward seating
Forward seating
Shipping damage? or did they sent a damaged one because they knew it was to expensive to sent back?
Well I will see, sent them an email about it.
Started with the seat box yesterday, I'm going to try to fabricate the cabinets and drawers from starboard so in case lures and hooks penetrate the material it won't rot
Still have no idea how to shape this square box in something elegant, I will figure it out I think
Re: Curacao CS 25
Posted: Fri Jul 27, 2012 8:34 am
by topwater
Peter one thing about that seat box is that you will have a ton of storage space
How far back from the center console are you going to mount the seat
Re: Curacao CS 25
Posted: Fri Jul 27, 2012 9:28 am
Too bad the seat came damaged
Sure looks nice and comfy.
Re: Curacao CS 25
Posted: Fri Jul 27, 2012 7:35 pm
by chicagoross
Put cleats inside the 4 vertical corners, then you can round a nice big radius on the outside?
Re: Curacao CS 25
Posted: Fri Jul 27, 2012 8:01 pm
by peter-curacao
chicagoross wrote:Put cleats inside the 4 vertical corners, then you can round a nice big radius on the outside?
Hi Ross there are vertical cleats, sorry forgot to post this picture
started today to give the box some more shape so it isn't so boxy looking, I always get my ideas along the way, so no drawings, had a idea to put in a cutting board hope this will work, if it does I think it will be cool
topwater wrote:How far back from the center console are you going to mount the seat
I have no idea yet
, what's the standard, if there is a standard
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 12:05 am
by nc_robbie
Nice peter, I love your ideas I cant wait to see how it ends up!
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 12:40 am
by Prarie Dog
Peter, could you get some of that round ply from Larry or Richard. That would really make some nice round corners.
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 5:39 am
by dbcrx
Actually, looking at it with the seat on, I don't think the corners want to be rounded too much. It matches the corners of the seat quite nicely as it is.
With all the drawers and whatever cut out of the front, that will break it up a bit and make it look a bit less like a solid lump. Then I'd just maybe cut or paint some nice graphics on the sides or something.
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 10:37 am
by peter-curacao
Prarie Dog wrote:Peter, could you get some of that round ply from Larry or Richard. That would really make some nice round corners.
Yes I can get everything here if I'm willing to pay for it, for example that seat I bought at Defender costed me after a price match US$ 292,- freight and taxes over here costed me US$ 327,-
dbcrx wrote: Then I'd just maybe cut or paint some nice graphics on the sides or something.
Exactly,that's why I came up with this yesterday, it does break the boxy look a little , I think I like it
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 12:20 pm
by wildbill
Peter it's absolutley perfect. I think your looking at the ultimate new trend in center console comfort.
wildbill
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 6:38 pm
by peter-curacao
Started working with the starboard today, nice material but a PITA to work with, well that's how I experienced it
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 8:47 pm
It is a PITA and it shows every tool mark. A router is the only thing that will cut it clean and you have to use mechanical fasteners for all connections, it doesn't glue. It is heavy stuff too. How about just a drop in prefab unit that uses standard size plastic tackle compartments?
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 9:01 pm
by peter-curacao
Cracker Larry wrote:It is a PITA and it shows every tool mark. A router is the only thing that will cut it clean and you have to use mechanical fasteners for all connections, it doesn't glue. It is heavy stuff too. How about just a drop in prefab unit that uses standard size plastic tackle compartments?
Larry that's a good idea I think!
but I'm to far in to it as we speak, I have to finish it now, did 3 drawers today, can you imagine 3 drawers in a whole day???
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 9:04 pm
Heck, that's pretty good
Might take me 2 days
Starboard is nice stuff but it does take some practice to work with.
Re: Curacao CS 25
Posted: Sat Jul 28, 2012 9:57 pm
by peter-curacao
Cracker Larry wrote: Starboard is nice stuff but it does take some practice to work with.
Hell yeah!!!! hope I can share some pics tomorrow
Re: Curacao CS 25
Posted: Sun Jul 29, 2012 1:46 pm
by wildbill
peter-curacao wrote:Cracker Larry wrote:It is a PITA and it shows every tool mark. A router is the only thing that will cut it clean and you have to use mechanical fasteners for all connections, it doesn't glue. It is heavy stuff too. How about just a drop in prefab unit that uses standard size plastic tackle compartments?
Heck around here some people can go a whole week with 3 pairs of drawers.
P.S. it would be nice if you could make some room for a deep drawer for our mono leader material or maybe incorporate it onto the inside of the doors for our skinny spools of leader material.
bill
Re: Curacao CS 25
Posted: Sun Jul 29, 2012 4:31 pm
by peter-curacao
Seat box with storage, 3 drawers and 5 plano boxes.
This was the idea I had for the cutting board
(in starboard also) what turns inside the seat, I ain't gonna do it I think It's to close to the upholstery what is asking for it, also the workspace is to low I think.
wildbill wrote:P.S. it would be nice if you could make some room for a deep drawer for our mono leader material or maybe incorporate it onto the inside of the doors for our skinny spools of leader material.
bill
Thanks Wildbill that's exactly what I planned, this also wil keep the drawers and boxes in place
Re: Curacao CS 25
Posted: Sun Jul 29, 2012 9:26 pm
by Hope2float
Peter as always great work. Good use of storage, which imo is the most important thing on the boat. It keeps a limited area for us to use clean and clutter free. Once agin very nice.
Dave
Re: Curacao CS 25
Posted: Mon Jul 30, 2012 7:52 am
by Walkers Run
That's a great set up Peter. My last boat had a similar set up. The combo of drawers and Plano boxes is a perfect way to stay oganized. If I ordered mine now when could you deliver?
Re: Curacao CS 25
Posted: Mon Jul 30, 2012 8:22 am
by topwater
Nice well thought out work as always Peter
Re: Curacao CS 25
Posted: Wed Aug 01, 2012 10:41 am
by peter-curacao
Thanks guys just dismantled everything so I can glass and glue it
lots of parts
Re: Curacao CS 25
Posted: Wed Aug 01, 2012 2:29 pm
by wegcagle
Great work as always Peter. That leaning post is completely tricked out
I wouldn't expect anything less when looking at the rest of your build.
Will
Re: Curacao CS 25
Posted: Fri Aug 03, 2012 10:15 am
by peter-curacao
I have no idea yet
Anyone?
Re: Curacao CS 25
Posted: Fri Aug 03, 2012 11:03 am
Standard sitting position from Nicholson's Boat Data book: backrest to center of wheel: 23 to 25" (585 to 635 mm).
Re: Curacao CS 25
Posted: Fri Aug 03, 2012 11:06 am
It's going to depend on the seat height, the wheel and control height, your height, which is pretty high
Most of them are mounted too far back to suit me. You want to be able to comfortably lean against it while standing and driving, yet you also want to be able to reach the controls while seated, without having to stretch. It wears you out quick if you have to stretch to reach the wheel, or have to sit on the edge of the seat.
Just put it in there and adjust it to fit you, that's the only way to get it right.
Re: Curacao CS 25
Posted: Fri Aug 03, 2012 11:16 am
Take Richard's boat for instance, it's a fine and sturdy boat, and I'm not criticizing, but the leaning post is too far back. It's OK when standing, but when seated and my back against the rest, I can't reach the wheel without stretching. My arms are probably 2 inches longer than Richard's are, and when he sits back in the seat he has to steer with his feet. The position of his might work fine for you, being 5 inches taller than I am. Fiddle with it until it feels right.
Re: Curacao CS 25
Posted: Fri Aug 03, 2012 11:50 am
About the dimensions I gave: those are for steering in sitting position. That rarely happens.
My preferred seat type is a folding bolster seat. It allows you to stand at high speed and sit when slowing down.
The backrest of the bolster seat could be at 20 to 22" from the center of the wheel for me.
Peter is taller and may need more. Plus, it depends very much on the shape of the seat.
There is not one dimension that will work for every situation,
Get the seat and move it back and forth until it feels good.
Re: Curacao CS 25
Posted: Fri Aug 03, 2012 2:08 pm
by wildbill
Peter, I went to a Defender website and could not find the particular seat you are using. Can you by any chance post the link to the site with the model number ?
Thanks' bill
Re: Curacao CS 25
Posted: Fri Aug 03, 2012 4:57 pm
by peter-curacao
Thanks guys I will play with it until right
Wildbill here's the defender page
They did a price match to this site what has more choice but won't ship outside the us and won't take non us creditcards, so for you it might be a better alternative to defender
http://www.cascadedepot.com/servlet/the ... Categories
Re: Curacao CS 25
Posted: Fri Aug 03, 2012 5:10 pm
by Aripeka Angler
Cracker Larry wrote:Take Richard's boat for instance, it's a fine and sturdy boat, and I'm not criticizing, but the leaning post is too far back. It's OK when standing, but when seated and my back against the rest, I can't reach the wheel without stretching. My arms are probably 2 inches longer than Richard's are, and when he sits back in the seat he has to steer with his feet. The position of his might work fine for you, being 5 inches taller than I am. Fiddle with it until it feels right.
I wish I could move my leaning forward about 10 inches but the aluminum feet would on top of two inspection plates. Peter, if I were you I would place the leaning post where it is the most comfortable for you
Just like the Captain said, fiddle with it
BTW, I really like the way you built the seat pedestal!! First class work as usual
Re: Curacao CS 25
Posted: Sat Aug 04, 2012 9:12 am
by peter-curacao
Aripeka Angler wrote:I wish I could move my leaning forward about 10 inches but the aluminum feet would on top of two inspection plates. Peter, if I were you I would place the leaning post where it is the most comfortable for you
Thanks Richard, I was thinking, I never saw your boat but can't you move your post forward and mount it hinged? so in case you have to be under those inspection plates you can flip it away?
Re: Curacao CS 25
Posted: Sat Aug 04, 2012 6:25 pm
by Aripeka Angler
peter-curacao wrote:Aripeka Angler wrote:I wish I could move my leaning forward about 10 inches but the aluminum feet would on top of two inspection plates. Peter, if I were you I would place the leaning post where it is the most comfortable for you
Peter, that is an awesome idea
I will have to do that. Constantly stretching to reach the wheel will wear your ass out on a 140 mile round trip fishing adventure. Thanks for the idea
Re: Curacao CS 25
Posted: Sun Aug 05, 2012 1:25 pm
by peter-curacao
Everything looks better in paint
Re: Curacao CS 25
Posted: Sun Aug 05, 2012 3:26 pm
by Joe H
WOW, Peter that really looks nice, you have done some fantastic things with a little glue and wood!
keep it coming
joe h
Re: Curacao CS 25
Posted: Sun Aug 05, 2012 4:51 pm
by wegcagle
Great job Peter. That looks awesome
Will
Re: Curacao CS 25
Posted: Sun Aug 05, 2012 6:21 pm
I think Peter has been sandbagging again
Hell yeah, that looks nice
Re: Curacao CS 25
Posted: Mon Aug 06, 2012 11:21 pm
by peter-curacao
Cracker Larry wrote:I think Peter has been sandbagging again
I had too look that up, honestly Larry i'ts not my niche LOL
sandbagging
The act of sexual intercourse with a quadraplegic amputee, (person without arms and legs), thus being reminiscent of humping a sandbag.
Re: Curacao CS 25
Posted: Tue Aug 07, 2012 12:32 am
by TRC886
peter-curacao wrote:Cracker Larry wrote:I think Peter has been sandbagging again
sandbagging
That's (kind of) funny
It's the language barrier again
What he means is; you are holding out on us. In other words; you are
sooo much more capable than you let on.
See definition "2-d"..."sandbag" is the root word; adding "ging" the to the root word means that you are in the process of doing the "sandbag" thing.
http://www.merriam-webster.com/dictionary/sandbagging
Also, look at this; definition number 3
http://www.learnersdictionary.com/search/sandbag[2]
Uh-oh...the 2nd link didn't quite go to the definition. Near the top of the page, you'll have to click on "sandbag(verb)", then look at definition number 3.
BTW: You should THANK Larry for the compliment
Re: Curacao CS 25
Posted: Tue Aug 07, 2012 7:50 am
sandbagging
I've never heard that definition!
Re: Curacao CS 25
Posted: Tue Aug 07, 2012 11:11 am
by peter-curacao
LOL
TRC886 I was just joking around with Larry
And Larry I did had to look it up but didn't make up that definition
http://www.urbandictionary.com/define.p ... andbagging
Edit PS Larry thanks for the compliment I appreciate it
Re: Curacao CS 25
Posted: Wed Aug 08, 2012 8:02 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed Aug 08, 2012 10:49 pm
by Larry B
That looks Fantastic Peter
Re: Curacao CS 25
Posted: Thu Aug 09, 2012 8:03 am
by ericsil
Wow! If you guys don't cut that out you will have me totally refurbishing the P19 one of these days.
Re: Curacao CS 25
Posted: Thu Aug 09, 2012 9:04 am
Mighty fine Peter
Re: Curacao CS 25
Posted: Thu Aug 09, 2012 9:31 pm
by chlli willie
Excellent workmanship!
Re: Curacao CS 25
Posted: Thu Aug 09, 2012 11:05 pm
by TRC886
Peter,
There are artists, and there are craftsmen. Very few can mix the artistry and the craftsmanship as well as you can
BTW: Larry's right, you're sandbagging us
You only allow us to see a small portion of your talents
Re: Curacao CS 25
Posted: Sat Aug 11, 2012 6:41 pm
by peter-curacao
Thanks guys
Leaning post cabinet painted en loosely fit in there until I can secure the seat permanently.
Trying to figure out the placement of the leader spools on the inside of the doors, those should also keep the drawers and plano boxes in place when doors are closed. 2 big spools 4 small spools.
Btw TRC886 I'm really honored by your compliment, a bit to much imho but I still like it
Re: Curacao CS 25
Posted: Sat Aug 11, 2012 6:59 pm
by Knottybuoyz
TRC886 wrote:Peter,
Ahhhh yes! But............... can he catch fish?
Just kidding. Very nice work Peter. Very nice indeed.
Re: Curacao CS 25
Posted: Sun Aug 12, 2012 4:49 pm
by cape man
Sorry Capeman I think the fighting chair has to go! but if you come over I will mount it on the pool deck so you can sit in it
Perfect! Bottle of green rum and good conversation works for me.
Been gone from the forum for a while (life has a hold of me!!!!). The boat is looking fantastic Peter!
Re: Curacao CS 25
Posted: Sun Aug 12, 2012 10:47 pm
by TRC886
Re: Curacao CS 25
Posted: Tue Aug 14, 2012 1:51 pm
by tobolamr
I LOVE that video... That brings a HUGE smile to my face every time I see it!
Peter - I hope to God I get a chance to meet you one day, and shake your hand, and congratulate you for your stellar attitude in all things Bateau, and salute your originality!
Re: Curacao CS 25
Posted: Wed Aug 15, 2012 1:49 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed Aug 15, 2012 2:32 pm
by Aripeka Angler
Sweet
Fabulous job on the seat pedestal
You are making me want to start building something again
Re: Curacao CS 25
Posted: Wed Aug 15, 2012 2:48 pm
Peter, dang it mi amigo. Did you really build that
I've had that pleasure now on several occasions
Boating, fishing, eating and drinking. He is a fine man in every respect.
You meet a lot of people in the course of a life, but there are usually just a few who are really special. Peter is one of those to us. Dori and I plan to be on Curacao when that boat gets launched
Re: Curacao CS 25
Posted: Thu Aug 16, 2012 5:25 pm
by TRC886
It is a well deserved compliment, my friend
There are many,
many, craftsmen on this board. All of them do outstanding work, but you stand a little apart from them. It's not that you are a better craftsman than they, it's the artist in you that sets you apart
Don't ask me to explain this...art is too subjective for
me to be able to explain it; but that's how I see it
BTW: Don't let this go to your head...G. says that your head is too big already
Re: Curacao CS 25
Posted: Thu Aug 16, 2012 6:14 pm
If you think his head is big, you should see the rest of him
Try carrying him across A1A, and a big parking lot, and up the stairs, and down the hall of a Holiday Inn at 4AM Unless you are a professional, never enter a drinking match with him, and if you are and you do, make sure that you lose, because he's more likely to be able to carry you than you are to carry him. Of course, I've never seen you, but it took Will, me and Peter to carry us all upstairs, and if Mrs Cracker hadn't heard us crawling down the hallway and help us get into a room, any room, I think we might all still be in jail in Marathon
Re: Curacao CS 25
Posted: Thu Aug 16, 2012 9:17 pm
by wegcagle
I have no recollection of what you are talking about
All I remember is how I wasn't quite as happy helping pull all those boats out of the water the next day
BTW Peter, I haven't commented recently because I've been on a killer work run the last month and a half. But damn you sure do nice work
I second everything C.L. has said about Peter. He is one hell of a great guy. I had a blast getting to meet him in Marathon. By the end of the 3 days it felt like I was saying goodbye to a longtime friend
......with a headache
Will
Re: Curacao CS 25
Posted: Thu Aug 16, 2012 9:33 pm
That's just because you have a professional career in your future, and I don't
Re: Curacao CS 25
Posted: Thu Aug 16, 2012 10:08 pm
by wegcagle
It certainly could be that.....or that last glass of rum
Either way I'd rather find a new job than to have missed that trip
Will
Re: Curacao CS 25
Posted: Fri Aug 17, 2012 8:45 am
by peter-curacao
wegcagle wrote:I had a blast getting to meet him in Marathon. By the end of the 3 days it felt like I was saying goodbye to a longtime friend
Will
That feeling was certainly mutual Will!! Also I don't have any recollection of what Larry is talking about
Re: Curacao CS 25
Posted: Fri Aug 17, 2012 8:51 am
I'm not surprised
I don't have any recollection of why I was covered with blood when I finally made it home, either
Re: Curacao CS 25
Posted: Fri Aug 17, 2012 8:59 am
by peter-curacao
Cracker Larry wrote:Also I don't have any recollection of what Larry is talking about
I'm not surprised
Home?? ROFL
your hotel door was across mine
You hit your arm at my doorjamb, doorjambs fault! it was crooked you were walking perfectly straight !
Re: Curacao CS 25
Posted: Fri Aug 17, 2012 9:18 am
That was quite a night. I think
Re: Curacao CS 25
Posted: Fri Aug 24, 2012 6:07 am
by misterfly_nl
I know Peter as a formidable guy and have seen progress of the boat in the last 4 visits to Curacao.
But now it is time to show some new progres pictures I think.
Evert
Re: Curacao CS 25
Posted: Sat Aug 25, 2012 10:31 am
by peter-curacao
Not much progress to show Evert, you know it's hurricane season, and with every tropical storm or hurricane passing the Greater Antilles our nice trade breeze is sucked away, so because of Isaac there's no wind and it is hot as hell so progress goes slow, ahh well better no wind as getting that actual hurricane
General question: I see lot's of people bolting or screwing their leaning post to the sole, for instance Fitz 21 CC Transom Stringer Sole R&R, I glued mine to the sole, did I make a mistake? should I have bolted it also?
Re: Curacao CS 25
Posted: Sat Aug 25, 2012 6:03 pm
by Mad Dog
peter-curacao wrote:General question: I see lot's of people bolting or screwing their leaning post to the sole, for instance Fitz 21 CC Transom Stringer Sole R&R, I glued mine to the sole, did I make a mistake? should I have bolted it also?
Do you plan to remove it? Any reason to get under it? If not you did the right thing. Joel bolted and glued the console on his SeaCraft.
MD
Re: Curacao CS 25
Posted: Sat Aug 25, 2012 6:11 pm
by peter-curacao
Mad Dog wrote:peter-curacao wrote:General question: I see lot's of people bolting or screwing their leaning post to the sole, for instance Fitz 21 CC Transom Stringer Sole R&R, I glued mine to the sole, did I make a mistake? should I have bolted it also?
MD
Thanks Mad dog, no not not really unless there is a problem with my fuel tank, but then I have to cut open the sole anyway.
Re: Curacao CS 25
Posted: Sat Aug 25, 2012 8:15 pm
by Aripeka Angler
Peter, glue is stronger than screws
Re: Curacao CS 25
Posted: Sat Aug 25, 2012 8:27 pm
by peter-curacao
Aripeka Angler wrote:Peter, glue is stronger than screws
That's what I thought Richard! , I think we can hoist her from that leaning post! I glued that post on the sole using the two by one cleats , after that I gave a fillet inside and out, that should be rock solid! Only way to remove that post in a decent way is the multitool I think.
Re: Curacao CS 25
Posted: Sat Aug 25, 2012 9:16 pm
by wegcagle
I'm with you Peter. I double taped my console with no screws or bolts. I hope we are right.
Absolutely beautiful work BTW
Will
Re: Curacao CS 25
Posted: Sat Aug 25, 2012 9:27 pm
by peter-curacao
wegcagle wrote: I hope we are right.
Will
You know we are! and if not I pour us another rum that should convince us we are!
Thanks for the compliment I appreciate it!
How's work still working/studying like a madman busting your balls? Americans should be very happy with a men like you, it insures them to get very professional medical help when needed! keep up the good work even if it delays your build! some things are more important! great having you as a friend
(although its long distance)
Re: Curacao CS 25
Posted: Sun Aug 26, 2012 7:02 am
Late to the party, but I vote for glue and glass also. Just like the rest of the boat.
Re: Curacao CS 25
Posted: Sun Aug 26, 2012 8:28 am
by peter-curacao
Cracker Larry wrote:Late to the party, but I vote for glue and glass also. Just like the rest of the boat.
LOL I pour you a glass of rum also
Re: Curacao CS 25
Posted: Sun Aug 26, 2012 10:05 am
by cape man
Re: Curacao CS 25
Posted: Sun Aug 26, 2012 7:31 pm
by wegcagle
You know we are! and if not I pour us another rum that should convince us we are! Thanks for the compliment I appreciate it!
How's work still working/studying like a madman busting your balls? Americans should be very happy with a men like you, it insures them to get very professional medical help when needed! keep up the good work even if it delays your build! some things are more important! great having you as a friend (although its long distance)
Watch out. I may take you up on that rum
Work is still work, but it pays the bills. It also helps that I get the satisfaction of helping out kids. They are really amazing and tough. I couldn't imagine doing anything else.
On the upside, I just got back from a week long trip to the Bahamas where I spent the entire time away from my phone and internet. Just me, my wife, and kid...all about the family.
It's good for the soul every now and then.
I appreciate your compliments. Truth is that there are plenty more people who work longer hours and tougher jobs for a lot less. In this economy I'm just happy to have a guaranteed paycheck and job security.
Keep up the good work,
Will
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 3:15 pm
by peter-curacao
Will
Bring it on my friend!!!
For those who doesn't read this part of the forum
http://forums.bateau2.com/viewtopic.php?f=4&t=30729
Opinions and ideas are more than welcome and very appreciated
Peter
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 3:18 pm
Nah, not for me anyway. I could mail you some raccoon and fox tails to hang from the mirror though
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 3:34 pm
by peter-curacao
Cracker Larry wrote:Nah, not for me anyway. I could mail you some raccoon and fox tails to hang from the mirror though
LOL If you do you have to mail me a mirror also
So you don't like the kevlar/carbon add ons?
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 3:51 pm
by wegcagle
I think it looks pretty cool, but I don't think I would do anything to take away from her lines. It would be like sweat pants and an oversized coat on a pretty woman
Will
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 3:54 pm
by Uncle D
I'll add a pair of fuzzy dice.
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 4:21 pm
Maybe some of those spinner hubs too
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 4:33 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 4:35 pm
don't know why but finally put the sole hatches in!
So I don't fall down the holes when I come fishing
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 4:37 pm
by peter-curacao
Cracker Larry wrote: don't know why but finally put the sole hatches in!
LOL yeah it's written down a little strange
, I meant don't know why I kept dragging this job.
Re: Curacao CS 25
Posted: Mon Aug 27, 2012 5:25 pm
I do. I have jobs like that also
I know they need doing, but I put them off and drag them out. They usually aren't that difficult, but I can't seem to do them until the time feels right. When the time is right and the spirit moves me, I can knock it out and move on. Then I wonder what I was waiting for
I was waiting for the time to be right and the spirit to move me. Otherwise you are fighting nature and will screw it up. All things in it's due time
Re: Curacao CS 25
Posted: Tue Aug 28, 2012 3:40 pm
by Uncle D
I'm gonna use that on my wife next time she wants something done..."When the time is right and the spirit moves me" I like that CL.
Re: Curacao CS 25
Posted: Tue Aug 28, 2012 6:57 pm
by peter-curacao
Not much longer before paint, primed the inside of the CC today tomorrow wet sanding.
Re: Curacao CS 25
Posted: Tue Aug 28, 2012 7:16 pm
by wegcagle
Just awesome Peter. That's definitely the coolest console bathroom I've ever seen
Will
Re: Curacao CS 25
Posted: Tue Aug 28, 2012 7:18 pm
Looks like you could hang a LOT of toilet paper rolls in there
Re: Curacao CS 25
Posted: Tue Aug 28, 2012 7:21 pm
It works for mine, but she's been with me now for almost 40 years and understands my idiosyncrasies
Re: Curacao CS 25
Posted: Tue Aug 28, 2012 7:35 pm
by majorgator
Which begs the question in my curious mind: what is the purpose of all those holes? Are they meant to hold gear? Are they for chase tubes?
Forgive me if you addressed this earlier in your build.
Re: Curacao CS 25
Posted: Tue Aug 28, 2012 7:56 pm
by peter-curacao
majorgator wrote:Looks like you could hang a LOT of toilet paper rolls in there
You are forgiven
Those are console stiffeners, because I cut out the door I cut away some corners that made the console stable, not that it is unstable now, just a precaution, the vertical ones also function as an amplifier rack, two amps will bolted in there and also the fish finder booster,amp,blackbox or whats the name? the holes I made in there because I think it looks cool a little industrial, and second because I can Tyrap or bind cable bundles to it.
Re: Curacao CS 25
Posted: Wed Aug 29, 2012 4:23 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed Aug 29, 2012 5:43 pm
by TRC886
Nice
Re: Curacao CS 25
Posted: Wed Aug 29, 2012 9:42 pm
by Hope2float
Peter take this in a good way. That console looks like it was designed for the Apollo missions. Very cool
Dave
Re: Curacao CS 25
Posted: Thu Aug 30, 2012 3:29 am
by misterfly_nl
When we go fishing i want to the toilet if it is only to experience this great solution
Evert
Re: Curacao CS 25
Posted: Sat Sep 01, 2012 1:01 pm
by peter-curacao
Cleat cutouts
front ones I placed them just so that the backing plate also can be clued to the bulkhead.
Mid ones you cant see in the pics but they are just in front of the fuel fill close to the frame.
Re: Curacao CS 25
Posted: Sat Sep 01, 2012 4:51 pm
by peter-curacao
No wind so it's very hot, so small jobs today.
I put in the holes for the last two speakers.
Re: Curacao CS 25
Posted: Sat Sep 01, 2012 6:24 pm
Dang, that sure is looking good
You are getting good with the router too. Is that a spiral cutting bit or a trim bit?
Re: Curacao CS 25
Posted: Sat Sep 01, 2012 6:32 pm
by peter-curacao
Cracker Larry wrote:Dang, that sure is looking good
Thanks Larry I always appreciate your compliments a lot! It's non of the two I think, don't know the exact name of all the bits, I think it's a sink bit? it's a bit just like this one.
Re: Curacao CS 25
Posted: Sat Sep 01, 2012 10:28 pm
by Mad Dog
Peter, I'm pondering putting two more cleats on my 22 footer. I have bow cleats in relatively the same place as yours and on the stern. I had some issues with dock lines the last trip out. So, I'm thinking about putting one mid way on either side help at the dock.
MD
Re: Curacao CS 25
Posted: Sun Sep 02, 2012 9:28 am
by peter-curacao
Mad Dog wrote:Peter, I'm pondering putting two more cleats on my 22 footer. I have bow cleats in relatively the same place as yours and on the stern. I had some issues with dock lines the last trip out. So, I'm thinking about putting one mid way on either side help at the dock.
MD
I know some others disagree but personally I think you can tie a boat better if you have a mid cleat also, it's also handy to hang a fender, I know that there are fender hooks and clips, but this way you won't need them.
Re: Curacao CS 25
Posted: Sun Sep 02, 2012 9:38 am
I use my mid cleat more than any other on the boat.
Re: Curacao CS 25
Posted: Mon Sep 03, 2012 2:12 pm
by peter-curacao
Whoops I think I forgot something
not sure but a question about limber holes made me doubt about it
Should I have drilled drain holes in the half pipe? under my fuel tanks?.
Re: Curacao CS 25
Posted: Tue Sep 04, 2012 12:01 pm
by wadestep
Hey Peter -
I saw your question about the drain holes. I went through the same question about my fuel tank and I decited not to drain the tank compartment (it's the bottom 1/2 of my console). Instead, I have it completely sealed except for access hatches. They won't be perfectly dry, so I installed fairly large vents - one on each side. That way, if/when a small amount of water ever gets in there, it will evaporate and not mold.
wade
Re: Curacao CS 25
Posted: Tue Sep 04, 2012 12:09 pm
by peter-curacao
wadestep wrote:Hey Peter -
wade
Thanks Wade that's kind of a relief,I also put the question in the powerboat section.
I also have completely sealed my tank compartments, even the hatches I spot welded those in and then sealed them up with silicone. The idea of venting that is still easy doable for me, I can put those two vent's in the lower compartment under the center console, but then gas fumes can enter the console, not sure what to do now
Re: Curacao CS 25
Posted: Tue Sep 04, 2012 12:35 pm
I wouldn't worry about it Peter. Think of it this way, if you had cut drain holes in the half tube, they would be letting in more water than they would probably ever drain. The fuel compartment would get wet any time there was water in the tube. That compartment is well sealed, water isn't going to get in there. A small vent is not a bad idea though.
Re: Curacao CS 25
Posted: Tue Sep 04, 2012 12:48 pm
by peter-curacao
Thanks guys this is a real relief!
Re: Curacao CS 25
Posted: Tue Sep 04, 2012 5:12 pm
by peter-curacao
Re: Curacao CS 25
Posted: Tue Sep 04, 2012 5:13 pm
That sure is a pretty hole
Re: Curacao CS 25
Posted: Tue Sep 04, 2012 5:23 pm
by Doc_Dyer
Nice work Peter
Re: Curacao CS 25
Posted: Tue Sep 04, 2012 9:53 pm
by peter-curacao
Doc_Dyer wrote:Nice work Peter
Thanks Doc is it me or do I hear some Banjo's ? I have to run for?
Re: Curacao CS 25
Posted: Wed Sep 05, 2012 11:35 am
by cterese12
Thats an incredible build peter. You're gonna have a classy rig there.
Re: Curacao CS 25
Posted: Wed Sep 05, 2012 1:06 pm
Re: Curacao CS 25
Posted: Wed Sep 05, 2012 4:46 pm
by peter-curacao
Larry I was just teasing the Doc
Re: Curacao CS 25
Posted: Wed Sep 05, 2012 4:55 pm
I hear he picks banjo
Re: Curacao CS 25
Posted: Wed Sep 05, 2012 4:57 pm
by peter-curacao
Cracker Larry wrote: I hear he picks banjo
I don't known I just reposted his question LOL :lol:There was a cool Banjo battle movie with it, don't understand why he deleted it
Re: Curacao CS 25
Posted: Wed Sep 05, 2012 5:16 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed Sep 05, 2012 7:53 pm
by Doc_Dyer
peter-curacao wrote:Cracker Larry wrote: I hear he picks banjo
Too long for response,
got to thinking might have been funny only to me
And inappropriate so I deleted it
Re: Curacao CS 25
Posted: Wed Sep 05, 2012 7:57 pm
by peter-curacao
Doc_Dyer wrote:peter-curacao wrote:Cracker Larry wrote: I hear he picks banjo
Okay probably I didn't understand your comment completely, I for sure didn't had a problem with it.
Re: Curacao CS 25
Posted: Thu Sep 06, 2012 6:13 pm
by peter-curacao
Bought a new air compressor today, what a very nice machine, to everyone who's thinking about buying a air compressor I can highly recommend this one, it doesn't loose pressure once the tank is empty and activate the pressure switch, which is really nice (no waiting time) I paid US 740,- for it, probably in the states you pay way less for it , but I think it is still worth it, I prefer having stuff like this over money.
Ofcourse having a nice air compressor does not give you the assurance to a nice paint job
I painted the CC and the seatbox today this is how it came out
I think I have to polish it
although I'm not sure about that either, it's not real visible in the pics but there are a lot of uneven spots and bumps
Re: Curacao CS 25
Posted: Thu Sep 06, 2012 7:21 pm
Me either
Doc and I just pick at each other, it's all in fun. We aren't serious
And it was a pretty hole.
Nice compressor, mine is almost identical to that. Still too small to run air sanders and air files, and can only handle a chisel in short bursts, but it runs almost anything I use. My spray painting skills still suck too. I usually get better results rolling and tipping. Spraying always frustrates me. So far unsuccessful with that, so I usually just don't
Re: Curacao CS 25
Posted: Thu Sep 06, 2012 8:11 pm
by stickystuff
Senco is an awsome product. It is designed to mainly power air powered nail guns and other fasteners.I once had prob. $2000 invested in senco nailers. Best nail gun on the market as far as I was concerned.This compressor is designed for their guns to be able to be used constantly with the correct air pressure to operate the guns while in use.Your boat is awsome. Would love to see it up and close. Only a winning lottery ticket will make this happen. Great Job.
Re: Curacao CS 25
Posted: Thu Sep 06, 2012 8:29 pm
by peter-curacao
Cracker Larry wrote:[quote
Nice compressor, mine is almost identical to that. Still too small to run air sanders and air files, and..............
Larry read Stickystuffs comment it is exactly as he describes! I had similar looking compressors before also
from Ferm to Zebra all a bunch of toys compared to this one
Keep in mind I would never ever recommend something on this site if it wasn't up to par
this is above par
Re: Curacao CS 25
Posted: Thu Sep 06, 2012 8:40 pm
by peter-curacao
stickystuff wrote: Only a winning lottery ticket will make this happen. Great Job.
A Miami Curacao ticket isn't that expensive
you are always more than welcome!
Re: Curacao CS 25
Posted: Thu Sep 06, 2012 11:11 pm
by Doc_Dyer
Re: Curacao CS 25
Posted: Fri Sep 07, 2012 5:07 pm
by wegcagle
Looks pretty dang good from here Peter.
Re: Curacao CS 25
Posted: Sat Sep 08, 2012 2:19 pm
by peter-curacao
Shooting paint.
Mini gun so I can shoot the rubrails between the house and boat, tight space
Re: Curacao CS 25
Posted: Sat Sep 08, 2012 4:01 pm
by ks8
What paint are you using there?
Re: Curacao CS 25
Posted: Sat Sep 08, 2012 4:26 pm
by peter-curacao
ks8 wrote:What paint are you using there?
PPG Concept 8001
Re: Curacao CS 25
Posted: Sat Sep 08, 2012 4:37 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Sep 08, 2012 4:59 pm
by misterfly_nl
But Peter this is a workboat
You put a load of work into it
And with a stunning result.
Evert
Re: Curacao CS 25
Posted: Sat Sep 08, 2012 5:17 pm
by ks8
Ditto.
Re: Curacao CS 25
Posted: Sat Sep 08, 2012 5:34 pm
Re: Curacao CS 25
Posted: Sat Sep 08, 2012 5:38 pm
by wegcagle
Peter. It looks amazing from here.
I think you've got a case of being overly critical of yourself. I would be that 10 out 10 people you take on a ride won't notice a single imperfection.
Nice work,
Will
Re: Curacao CS 25
Posted: Sun Sep 09, 2012 5:51 pm
by peter-curacao
Thanks guys yeah maybe I'm to hard on myself, but on the pics you don't see what I see, I tried to capture it, but it's hard to capture, in the fifth picture you can see what I'm talking about.
Spent almost the whole day masking the Acapulco deck
for the Kiwi grip, man what a time consuming job and I'm still not finished 8OI'm almost cross eyed from it so I decided to leave it for today.
Re: Curacao CS 25
Posted: Sun Sep 09, 2012 7:14 pm
Dang Peter, that is going to be sweet
When should we buy plane tickets? Dori and I want to be there for the launch.
Re: Curacao CS 25
Posted: Sun Sep 09, 2012 7:30 pm
by dbcrx
Have you used the kiwi grip before? It's pretty thick stuff and the tape has to be pulled when it's still wet. When I had a go with it here in about 25-30 degrees we only had about 10-15 working time before it was too late and chunks of paint came off with the tape. Also because of the thickness of it, you may struggle a bit getting the fine detail of your 'cs 25' to stay neat. It may work ok, but I would consider making the font a little bolder.
Re: Curacao CS 25
Posted: Sun Sep 09, 2012 8:04 pm
by jorgepease
If I build another, it will be this one! Great Job!
Re: Curacao CS 25
Posted: Sun Sep 09, 2012 8:27 pm
That is a fact. Pull the tape with the KG wet, as soon as possible when you finish rolling it. Work in small areas and pull the tape before proceeding to the next section. If the KG sets up even a little bit, it will make a ragged tape line. In your temps, I would guess about 15 minutes working time before that tape needs to come off.
Re: Curacao CS 25
Posted: Sun Sep 09, 2012 9:24 pm
by peter-curacao
Thanks for the warning I appreciate it, this video by kiwigrip made it seem easy to do, I guess some practice won't be a bad idea.
http://www.youtube.com/watch?v=h_GsZQXdico
I was thinking penetrating the letters from behind with a pushpin so I can lift them up later with some nose pliers.
Can I put the stuff in the fridge before use to stretch the working time?
Re: Curacao CS 25
Posted: Sun Sep 09, 2012 9:41 pm
I don't know. Maybe
Re: Curacao CS 25
Posted: Mon Sep 10, 2012 4:40 pm
by peter-curacao
Well that wasn't so bad at all, kept the paint in the bedroom last night so it was in the airconditioning all night.
But still you have to work fast indeed, but that wasn't any different with the epoxy works, only difference is that this is the finishing stage, as I rolled forward I removed the tape.
The idea I had with the pushpin worked like a charm if I may so so myself just cut of the white plastic protection so it is as flat as possible, the tip in the video I posted earlier to have some Q tips handy was also a great idea, I can highly recommend both to anyone who is thinking about doing something more or less the same.
I do have some difference in structure though but I hope nobody is going to notice, one thing did went wrong, I used a marker what I think was water based also, so now on the rounded edges there is some coloring in the kiwi grip what was transferred from the masking tape, hopefully it washes off in time but I think that's wish full thinking
Re: Curacao CS 25
Posted: Mon Sep 10, 2012 5:30 pm
Sweet
Kiwi Grip is fun stuff.
Re: Curacao CS 25
Posted: Mon Sep 10, 2012 9:09 pm
by ks8
Me likey...
Re: Curacao CS 25
Posted: Mon Sep 10, 2012 9:14 pm
by wegcagle
Great job Peter. That really finishes the boat perfectly. Nice tip on using kiwigrip
Will
Re: Curacao CS 25
Posted: Mon Sep 10, 2012 9:32 pm
by Larry B
Fantastic job Peter
You do very nice work
Re: Curacao CS 25
Posted: Mon Sep 10, 2012 9:50 pm
by Hope2float
Peter she looks better and better every day. That is some fine work you do. My friend is like you he has that artistic side that allows him to create and the mechanical that allows it to be built. Not many people have that ability. My theory is you are born with one of two brains Artistic or mechanical. What a bonus to have harnessed both. Great work and mind.
Dave
Re: Curacao CS 25
Posted: Tue Sep 11, 2012 6:03 am
by dbcrx
Glad it worked out for you, it looks great!
Re: Curacao CS 25
Posted: Tue Sep 11, 2012 6:33 am
by cape man
PRACHTIG!!!
Re: Curacao CS 25
Posted: Tue Sep 11, 2012 8:35 am
by topwater
Nice job Peter
That boat is SWEET
Re: Curacao CS 25
Posted: Tue Sep 11, 2012 2:44 pm
by Tiwaz
Looking good,
Re: Curacao CS 25
Posted: Tue Sep 11, 2012 5:58 pm
by wildbill
Can't wait to see the Marlin on the deck behind the Master Piece.
Re: Curacao CS 25
Posted: Tue Sep 11, 2012 8:50 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed Sep 12, 2012 1:32 pm
by tobolamr
Wow Peter - Your front seats/lockers look REALLY sharp! I'm going to make a note to look at how you built those again when my time comes to build... Keep up the great work!
Re: Curacao CS 25
Posted: Wed Sep 12, 2012 3:24 pm
by peter-curacao
tobolamr wrote:Wow Peter - Your front seats/lockers look REALLY sharp!
LOL Is that because of the Cuba Libre standing on there?
but thanks
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 8:29 am
by wadestep
Uh-Oh - you were not 'masking under the influence', were you?
That much tedious masking would drive anyone to drink - but it's looking great!
wade
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 2:56 pm
by tobolamr
No, Peter - it is a sincere compliment! When I saw where they started from, I was wondering how it was going to look when you got it painted. Now I am not so concerned about possibly duplicating the look in a future PH22 build. If I "borrow" your idea, I promise to give you full credit!
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 4:19 pm
by cape man
The Cuba Libre is nice, but the boat is freakin' AWESOME! Wow Peter!
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 5:26 pm
by majorgator
HAPPY BIRTHDAY PETER
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 5:37 pm
And Felis Kumpleaño
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 7:17 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 7:20 pm
by Aripeka Angler
Nice looking work Peter
I need to start saving for a road trip!
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 8:28 pm
by ks8
Re: Curacao CS 25
Posted: Thu Sep 13, 2012 10:11 pm
by Doc_Dyer
HAPPY BIRTHDAY
Re: Curacao CS 25
Posted: Fri Sep 14, 2012 4:01 am
by chicagoross
Happy Birthday, Peter! The curves of the lockers, console, and seating just look perfect in this boat. With the Kiwi on, you must be getting anxious for the real birthday present to yourself - the splash!
Re: Curacao CS 25
Posted: Fri Sep 14, 2012 11:10 am
by Uncle D
Dang Peter, That just looks EXCELLENT
Re: Curacao CS 25
Posted: Fri Sep 14, 2012 11:18 am
by tobolamr
Wait a minute - You mean Peter's B-Day was the 13th? That was mine, too! LOL Note to self, I share a birthday with a boat building celebrity...
Those pics sure look nice, Peter... Keep up the great work! I hope to see this boat one day!
Re: Curacao CS 25
Posted: Fri Sep 14, 2012 1:00 pm
by ks8
Happy Birthday!
The kiwigrip was an excellent present to give to yourself.
Re: Curacao CS 25
Posted: Fri Sep 14, 2012 2:37 pm
by tech_support
looks awesome.
Re: Curacao CS 25
Posted: Sat Sep 15, 2012 12:29 pm
by wegcagle
Happy belated B-day,
Great work. She sure has turned out amazing. The kiwigrip really finishes it off nicely
Will
Re: Curacao CS 25
Posted: Sat Sep 15, 2012 5:40 pm
by whosmatt
Looking great! And Happy Birthday!
-M
Re: Curacao CS 25
Posted: Mon Sep 17, 2012 4:08 pm
by peter-curacao
Thanks everybody
Bilge hatches
Re: Curacao CS 25
Posted: Mon Sep 17, 2012 6:49 pm
by Walkers Run
Very very cool!!!!
Re: Curacao CS 25
Posted: Mon Sep 17, 2012 9:36 pm
by cape man
SHOW OFF!!!
Peter, you continue to surprise me. Beautiful. Just pure beautiful.
Re: Curacao CS 25
Posted: Mon Sep 17, 2012 9:46 pm
He's just pissing me off now
That bar is higher than mine. Great work Peter
Re: Curacao CS 25
Posted: Thu Sep 20, 2012 3:04 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Sep 20, 2012 4:05 pm
That's funny how he put his head under the water
I can't get Cane to do that yet, trying to teach him to retrieve from the bottom of the pool. He's in the pool right now, cooling down. I'm about to join him.
I met a black lab once in the Dry Tortugas who would dive underwater and catch fish on command
The owner was cruising the world on a 40' sailboat, and he would send his dog down to catch dinner. He was good at it too
Amazing what a dog will do.
Re: Curacao CS 25
Posted: Fri Sep 21, 2012 4:42 am
by chicagoross
Met a local dog on a beach in Baja years back that would fetch rocks thrown into the ocean off the beach. Not only would he dive and fetch, he got the right rock about 9 times out of ten! On about the tenth time he's fetch a substitute. Never figured out how he got the right rock most of the time!
Re: Curacao CS 25
Posted: Sat Sep 22, 2012 9:46 am
by peter-curacao
It's an English Bulldog I'm happy he stays afloat
This type of dog swimming doesn't happen to much because they are top heavy, he can go underwater for a longer time ( see this
Clip when he was younger) I try to prevent that now a days, don't want him to drown
Re: Curacao CS 25
Posted: Tue Sep 25, 2012 3:12 pm
by PrometheusNL
i'll trade you some rain for sunshine
makes me want to hop on a plane and go where you are. Way to nice weather over there.
Re: Curacao CS 25
Posted: Wed Sep 26, 2012 4:45 pm
by peter-curacao
PrometheusNL wrote:i'll trade you some rain for sunshine
Funny you say that we had lot's of rain last couple of days
I put in the tank fills and vents so I could screw in the hose covers,to break the big white area I painted them metallic blue, if I may say so myself I like it, made some trim pieces from aluminum and 1/4 starboard to finish it off.
Re: Curacao CS 25
Posted: Wed Sep 26, 2012 4:46 pm
by chicagoross
Sweet!
Re: Curacao CS 25
Posted: Wed Sep 26, 2012 5:25 pm
Jeez Peter, stop
You are making the rest of us look bad. I'll never be able to jump that bar. Dang it man
Beautiful work, my friend
Re: Curacao CS 25
Posted: Wed Sep 26, 2012 8:00 pm
by Larry B
Peter, I'm really impressed with those trim pieces
Impressed with the whole thing
Re: Curacao CS 25
Posted: Wed Sep 26, 2012 8:20 pm
by Aripeka Angler
Wow
Fabulous
Re: Curacao CS 25
Posted: Thu Sep 27, 2012 8:16 am
by topwater
Thats a well thought out boat right there
Good looking also
Re: Curacao CS 25
Posted: Thu Sep 27, 2012 8:57 am
by wegcagle
Awesome Peter. Just awesome
Will
Re: Curacao CS 25
Posted: Thu Sep 27, 2012 9:50 am
by wadestep
Wow, Peter, she's really turning into a beauty!
wade
Re: Curacao CS 25
Posted: Thu Sep 27, 2012 12:12 pm
by ks8
Cracker Larry wrote:Jeez Peter, stop
I need better eyes... can't even see that bar anymore -- its so high up there! Forget about jumping it!
Re: Curacao CS 25
Posted: Thu Sep 27, 2012 4:11 pm
by peter-curacao
Thanks guys! again on pics everything looks better as in real life
Modified rod holders for in the center console, great idea from Joel (slightly different) thanks Joel for sharing a while ago!
Re: Curacao CS 25
Posted: Fri Sep 28, 2012 9:15 am
by tech_support
good idea going with the 3/8" pipe fittings, mine are 1/4" and they take a while to drain (but they still work). The 1/4" fittings on the drain gutters of my hatches should be 3/8" The 1/4" there is not enough to keep up with a heavy dose of water
Re: Curacao CS 25
Posted: Sun Sep 30, 2012 5:52 pm
by peter-curacao
shine wrote:good idea going with the 3/8" pipe fittings, mine are 1/4" and they take a while to drain (but they still work). The 1/4" fittings on the drain gutters of my hatches should be 3/8" The 1/4" there is not enough to keep up with a heavy dose of water
I'm impressed you can see that from a picture
, yeah it is 3/8
Made some more metallic blue accent pieces today, also a cover for a hole I had on the bottom of the center console, yeah yeah I hear some of you mumbling "all that work just to cover up a hole!
" hey I just happen to like spent my spare time doing stuff like that, if not I sure wouldn't do it that way
Hydraulic steering pump bezel
Bezel and window frame
Window frame
Hole cover
Hole cover
Edit: Never enough pics
Re: Curacao CS 25
Posted: Sun Sep 30, 2012 5:56 pm
It just keeps getting better
How did you make the bezel? What are you cutting that with? Looks fantastic.
Re: Curacao CS 25
Posted: Sun Sep 30, 2012 6:02 pm
by peter-curacao
Cracker Larry wrote:It just keeps getting better
I made the bezel just like the window frame from aluminum, I cut it with an ordinary jigsaw with the appropriate blade in it.
Re: Curacao CS 25
Posted: Sun Sep 30, 2012 6:06 pm
That's some fine jigsaw work
Re: Curacao CS 25
Posted: Sun Sep 30, 2012 6:15 pm
Are you painting it after cutting it, or is the aluminum blue anodized?
Re: Curacao CS 25
Posted: Sun Sep 30, 2012 6:18 pm
by peter-curacao
No it's spray painted same metallic blue as the hose covers I showed earlier.
Re: Curacao CS 25
Posted: Sun Sep 30, 2012 11:45 pm
by ks8
Nice work!
Re: Curacao CS 25
Posted: Tue Oct 02, 2012 12:01 pm
by wadestep
Your build and attention to detail are outstanding!
wade
Re: Curacao CS 25
Posted: Tue Oct 02, 2012 7:14 pm
by peter-curacao
Thanks Wade, I do my best
Re: Curacao CS 25
Posted: Thu Oct 04, 2012 9:41 pm
by peter-curacao
Cracker Larry wrote:Are you painting it after cutting it, or is the aluminum blue anodized?
I'm thinking painting the pump blue also, or should I leave it black?
Re: Curacao CS 25
Posted: Thu Oct 04, 2012 10:07 pm
The steering pump? Leave it black I think. The contrast is better.
Re: Curacao CS 25
Posted: Thu Oct 04, 2012 10:16 pm
by peter-curacao
Yea that's what I thought
Re: Curacao CS 25
Posted: Sat Oct 06, 2012 11:12 pm
by Knots
Peter,
Cool boat! I like the seat / drawer storage you got going on. Is the actual seat/cushion a custom ordered job or is it an off the shelf item?
Re: Curacao CS 25
Posted: Sun Oct 07, 2012 9:25 am
by peter-curacao
off the shelf.
Re: Curacao CS 25
Posted: Fri Oct 12, 2012 6:30 pm
by peter-curacao
Some more but also the last blue paint.
Vent center console
Inside/backside center console "door"
Re: Curacao CS 25
Posted: Fri Oct 12, 2012 9:40 pm
by AtTheBrink
Peter, your workmanship is awesome! I would hate to even guess what a boat built like yours would go for retail.
All the fine details in your little ship make it a work of art. Truly a "One Off" boat! Do you have an approx. Date for splashing that thing and sliming the decks?
Re: Curacao CS 25
Posted: Fri Oct 12, 2012 10:28 pm
Somebody once said about boats, if you have to ask what is cost, you probably can't afford it, even at wholesale, and Peter has build that one right all the way
His anchor probably cost more than some of the small boats built here
Re: Curacao CS 25
Posted: Fri Oct 12, 2012 10:33 pm
by AtTheBrink
So true Larry, so true...
Re: Curacao CS 25
Posted: Sat Oct 13, 2012 10:44 am
by SmokyMountain
Peter,
Your an artist!!!
So nice.....
Re: Curacao CS 25
Posted: Sat Oct 13, 2012 1:45 pm
by Aripeka Angler
Beautiful work Peter!!! Bravo! Fabulous detail
Re: Curacao CS 25
Posted: Sat Oct 13, 2012 7:14 pm
by peter-curacao
Thanks guys!
Pulling wire/cable is hard when you work alone, but I managed did cost some time though.
Hopefully tomorrow I can temporary connect the radio so I have some music while working, that would be nice
Subwoofer connection
Amps wired so far
Subwoofer, please ignore the dirty sole, I will scrub her tomorrow
Re: Curacao CS 25
Posted: Sat Oct 13, 2012 7:25 pm
by wegcagle
Looks great Peter. Really clean job on the wiring so far
Will
Re: Curacao CS 25
Posted: Sun Oct 14, 2012 9:03 am
by wadestep
So now I know where to go for a calf muscle massage!
Re: Curacao CS 25
Posted: Sun Oct 14, 2012 6:28 pm
by peter-curacao
Anchor locker I think I misplaced the cleat
, I have to see how it works while anchoring, if it's bad I place it further back to the winch, still waiting on my chain and rope
Re: Curacao CS 25
Posted: Sun Oct 14, 2012 7:36 pm
by peter-curacao
Well I put in my radio today (temporary) so I have music while working, NICE!
Found some online sine wave test tones, so after connecting my laptop to the amps I was able to adjust them as they should be set according to the specs.
click -> Let there be music!! <- click
Off course this movie doesn't the sound much good after all this was recorded with a photo camera
Re: Curacao CS 25
Posted: Sun Oct 14, 2012 7:38 pm
That cleat location should work fine.
Dori likes the music and the disco lights
Re: Curacao CS 25
Posted: Sun Oct 14, 2012 9:22 pm
by peter-curacao
Thanks Dori it is
La Mosca from Argentina, real party music imo.
Took out the lights for painting have to find an amp because the string is to long
Edit: If you want I bring you a copy next time
Re: Curacao CS 25
Posted: Mon Oct 15, 2012 11:25 am
by Uncle D
I'll hear you when you hit the Gulf of Mexico, Peter.. So nice.
Re: Curacao CS 25
Posted: Mon Oct 15, 2012 7:09 pm
by wildbill
La Mosca Muy Bueno!
Astalauego
Giermo
Re: Curacao CS 25
Posted: Mon Oct 15, 2012 7:42 pm
by cottontop
Peter, your boat is truly a magnificent work of art. We can really tell how talented you are. I do not belive the bar you have set will ever be matched. John
Re: Curacao CS 25
Posted: Mon Oct 15, 2012 9:00 pm
by cterese12
I'm not sure if you noticed, but your console has fins. Its like a hybrid offspring from a ferrari testerosa and something else badass. Peter...you're outragous.
Yes thats a don johnson smilie
Re: Curacao CS 25
Posted: Mon Oct 15, 2012 10:13 pm
And wait until you meet him
Re: Curacao CS 25
Posted: Thu Oct 18, 2012 7:03 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Oct 18, 2012 10:31 pm
Dang Peter, that's a lot of weight to lose so fast
Maybe too much, those winds blow hard down there and you've got to keep yourself anchored down. I might can imagine you going 5 weeks without a filet mignon, but not without a Cuba Libre
Those hatch stiffeners look great
Re: Curacao CS 25
Posted: Sat Oct 20, 2012 5:34 pm
by AtTheBrink
Re: Curacao CS 25
Posted: Sat Oct 20, 2012 7:36 pm
by peter-curacao
Thanks nice to know some like it me sharing my stuff
, the next share I have to warn you guys! it's wrong ! it's very wrong!! It's insanely wrong!!! but nice it is!
Thanks Larry I know it is fast! this morning it was even more as I was telling , I lost a total of 16 kg (32 pounds) over 5 weeks.
I decided this was the last day of my diet so started to celebrate (in a very wrong way) this morning, went to Quisno's and ordered small Parmesan bread filled with black Angus, duschi bon!!
Then I went to the supermarket went home and created this for me and the girls! sooo wrong but so nice! the bacon bomb!!
Ingredients
Makes: 1 roll
2 pounds bacon, thick sliced
2 pounds sausage (italian, breakfast, sage. Whichever you prefer) I used Argentinian Sausage
1 cup cheddar cheese (finely shredded)
2 whole green onions (thinly sliced)
4 cloves garlic (minced)
1 jar barbecue rub (your favorite brand)
1 bottle barbecue sauce (your favorite brand)
Take 1 to 1 1/2 pounds of the bacon and do a basketweave/lattice of bacon like the picture shown. Sprinkle the weave with some of the barbecue rub. Cook the remaining bacon until crispy. Remove the bacon from the pan and reserve the cooked bacon for the filling.
On a cutting board, roll out the sausage to the same size as the weave. I use a gallon ziploc bag and leave the top open a bit so the air can escape. It makes a perfect square that will fit on your bacon weave. Cut the plastic bag away from the sausage and discard the bag. Place the sausage square on top of the weave.
Sprinkle the crumbled cooked bacon, the cheddar cheese, garlic and the green onions over the sausage. Pour some of the barbecue sauce on top of the filling and sprinkle with more of the rub.
Roll up the sausage in the bacon weave into a tight roll.
Place the roll in the smoker for approx. 2 hours (give or take, depends on your heat source) or until the internal temperature reads 165 degrees F. During the last 20 - 30 minutes, baste the roll with the remaining barbecue sauce.
When the roll comes out of the smoker, let it rest for 30 minutes before slicing. Serve on freshly baked biscuits.
Tip
For crispier bacon on the roll, when you remove it from the smoker, place the roll in the broiler for approx. 5 minutes to crisp up the outside then baste with the barbecue sauce.
topped it with a TG Fridays famous Jack-Daniels grill glaze sauce clone I found @
http://www.topsecretrecipes.com
1 head of garlic
1 tablespoon olive oil
2/3 cup water
1 cup pineapple juice
1/4 cup teriyaki sauce
1 tablespoon soy sauce
1 1/3 cups dark brown sugar
3 tablespoons lemon juice
3 tablespoons minced white onion
1 tablespoon Jack Daniels Whiskey
1 tablespoon crushed pineapple
1/4 teaspoon cayenne pepper
1. Cut about 1/2-inch off of top of garlic. Cut the roots so that the garlic will sit flat. Remove the papery skin from the garlic, but leave enough so that the cloves stay together. Put garlic into a small casserole dish or baking pan, drizzle olive oil over it, and cover with a lid or foil. Bake in a preheated 325 degrees F oven for 1 hour. Remove garlic and let it cool until you can handle it.
2. Combine water, pineapple juice, teriyaki sauce, soy sauce, and brown sugar in a medium saucepan over medium/high heat. Stir occasionally until mixture boils then reduce heat until mixture is just simmering.
3. Squeeze the sides of the head of garlic until the pasty roasted garlic is squeezed out. Measure 2 teaspoons into the saucepan and whisk to combine. Add remaining ingredients to the pan and stir.
4. Let mixture simmer for 40-50 minutes or until sauce has reduced by about 1/2 and is thick and syrupy. Make sure it doesn't boil over.
Makes 1 cup of glaze.
Re: Curacao CS 25
Posted: Sat Oct 20, 2012 7:57 pm
by Bowmovement
I have always wanted to make one of those. How was it?
Matt
Re: Curacao CS 25
Posted: Sat Oct 20, 2012 8:02 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Oct 20, 2012 8:05 pm
by Bowmovement
LOL
Think I may make one tomorrow.
Re: Curacao CS 25
Posted: Sat Oct 20, 2012 8:09 pm
Aw man, I haven't had supper and Dori's out tonight. I sure didn't need to see that masterpiece, while I was thinking of making me a peanut butter sandwich
Damn, That's beautiful. A work of art. And I'm a lean 175, so not worried about the calories
What in heck am I going to eat now
Re: Curacao CS 25
Posted: Sat Oct 20, 2012 8:16 pm
by peter-curacao
LOL
whatever you do don't eat your Miami Curacao ticket
Man Miami sucks but boy do I miss it every day I'm not there! Am I sick? Is something wrong with me??
Re: Curacao CS 25
Posted: Sat Oct 20, 2012 8:42 pm
Island fever
Re: Curacao CS 25
Posted: Sun Oct 21, 2012 9:49 am
by peter-curacao
Cracker Larry wrote:Island fever
Not sure I do understand you here my friend.
Edit: wait I do now had to read back
Re: Curacao CS 25
Posted: Mon Oct 22, 2012 6:20 am
by torodelmar
Boat looks great !
Suggestion for anchor winch detailing.
Anchor winches dont like to get wet. They are weatherproof, not waterproof.
With a stem launched bruce ,you will pick up substantial water when working to windward.
Locker drains the size of sewer pipes and blocking the winch base up and off the locker sole are good defensive strategies.
Remember to fit beefy ss chafe bars on the topsides on either side of the stem launch anchors fair lead. Chain frequently jumps off a roller in heavy anchoring conditions. Chain will saw right thru your boat.
As for length of chain to carry ...good question. In the perfect world 100 meters. On a small craft this may not be possible. 5 times the depth of water is a good guide. If you frequently anchor in 5 meters then fit 25 meters of chain with a rope tail. Rope is difficult to handle. Best if you typically only shoot the chain.
One way to supercharge the rope anchor rode is to use lead core line. Sink line. Check with any fishing supply shop. Ive used Robline lead core with success. Many different manufacturers.
http://www.teufelberger.com/en/products ... eidon.html
Re: Curacao CS 25
Posted: Mon Oct 22, 2012 9:14 am
by peter-curacao
Thanks for the suggestions
The winch is on a sloped angle so in theory water coming in should go out the same way, if to much water is coming in I can always put in some rubber flaps behind the hawse pipe.
The rope and chain locker is "separate" from the anchor locker and of course also has a drain (2")
Maybe I'm missing something
but I don't see how the chain/rope would jump of the roller, it is locked into the anchor roller.
Hmmm 5 times the water dept, with an average dept of 3000 meters that would be 15000 meter
LOL I need a bigger boat
Thanks for the link but I already ordered my chain and rope
Re: Curacao CS 25
Posted: Mon Oct 22, 2012 4:32 pm
by peter-curacao
Bench hatches primed, they were quite labor intensive for something out of sight
Re: Curacao CS 25
Posted: Mon Oct 22, 2012 4:35 pm
Wow! You've done it again.
Me either, now
Re: Curacao CS 25
Posted: Sun Oct 28, 2012 9:09 pm
by Steven
Nice work a always. Can't wait to see her on the water.
Re: Curacao CS 25
Posted: Wed Oct 31, 2012 7:25 pm
by peter-curacao
thanks guys
No boatbuilding news but not sure where to place this so I place it here because I like to share it
http://www.codewit.com/africa/africa/32 ... ore-photos
Re: Curacao CS 25
Posted: Thu Nov 01, 2012 9:20 am
That's very interesting Peter, I'd like to see that when it comes out. Danny Glover always does a great job.
Slavery is something that I've never understood, it's the most heinous sin that one man could ever commit against another
I would not make a good slave, they would have to shoot me to get any work out of me, and they better never turn their back.
Re: Curacao CS 25
Posted: Sun Nov 25, 2012 1:58 am
by AtTheBrink
Anything new with your build, or did you finish her up and are too busy fishing to update?
Re: Curacao CS 25
Posted: Wed Dec 05, 2012 12:35 pm
by tobolamr
Peter, any updates as of late?
Re: Curacao CS 25
Posted: Wed Dec 05, 2012 1:02 pm
I talked to him a couple of days ago, he said he had been real busy at work and getting ready to go to the DR for several weeks. I doubt you will see an update until after New Year.
Edit: DR is Dominican Republic, not doctor
Re: Curacao CS 25
Posted: Wed Dec 05, 2012 6:05 pm
by tobolamr
Thanks, CL! For some reason I saw DR and thought DR Congo...
Must be getting close to miller time...
Re: Curacao CS 25
Posted: Mon Dec 31, 2012 11:44 pm
by johns.
I was lurking around this time last year and seem to remember the Bait Tank had just been fabricated. Sensational looking build Peter, thank you for sharing it with us all.
Re: Curacao CS 25
Posted: Fri Jan 18, 2013 8:37 am
by Pikatje
Petertje,
holiday is over, so either DR pictures of the three rumqueteers or boat talk.
Re: Curacao CS 25
Posted: Fri Jan 18, 2013 8:02 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri Jan 18, 2013 8:39 pm
Re: Curacao CS 25
Posted: Sat Jan 19, 2013 1:28 am
by chicagoross
Re: Curacao CS 25
Posted: Sat Jan 19, 2013 4:32 pm
by misterfly_nl
Peter,
It has all the features of a fishingboat, but the luxury of a Cruiseship.
Evert
Re: Curacao CS 25
Posted: Wed Jan 23, 2013 10:52 am
by peter-curacao
Larry just to let you know, package came in today, again thank you very much my friend.
Those clips are way better in comparison to the clips I redesigned to fit the ball brackets.
Before
After
Re: Curacao CS 25
Posted: Wed Jan 23, 2013 10:58 am
Glad to help, Peter
Glad they worked for you too
That was quick shipping!
Re: Curacao CS 25
Posted: Wed Jan 23, 2013 12:49 pm
by torodelmar
Gas rams contain oil to lubricate the seal. If you mount them shaft up, barrel down the oil cant lubricate the seal. Reverse your rams barrel up, shaft down, to achieve full service life.
Re: Curacao CS 25
Posted: Wed Jan 23, 2013 1:15 pm
That's very good information! I never thought about that and you usually see them mounted opposite, like Peter did.
Re: Curacao CS 25
Posted: Wed Jan 23, 2013 2:33 pm
by tobolamr
Looking good Peter! Nice remote control door, too!
Re: Curacao CS 25
Posted: Wed Jan 23, 2013 4:44 pm
by peter-curacao
Cracker Larry wrote:That's very good information! I never thought about that and you usually see them mounted opposite, like Peter did.
It depends if they are fully damped or not, I believe mine aren't so torodelmar thanks for the remark, already changed them
Re: Curacao CS 25
Posted: Wed Jan 23, 2013 9:46 pm
by Hope2float
Peter love that remote controlled door. Nuf said
Dave
Re: Curacao CS 25
Posted: Sun Feb 03, 2013 9:24 am
by peter-curacao
Patiantly waiting for my bracket to arrive
I was hoping it was here when I returned from my vacation but unfortunately it wasn't
Re: Curacao CS 25
Posted: Sun Feb 03, 2013 3:49 pm
by AtTheBrink
What bracket did you go with? Can't wait to see that E-Tec hanging off the stern!
Re: Curacao CS 25
Posted: Sun Feb 03, 2013 6:05 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Feb 07, 2013 5:51 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Feb 07, 2013 6:00 pm
I would shorten it by 5 or 6 inches, if it's not too much trouble. The boat will probably trim better. That's a lot of weight and the further you put it aft, the more bow up trim you will have.
Re: Curacao CS 25
Posted: Thu Feb 07, 2013 6:06 pm
by peter-curacao
Cracker Larry wrote:I would shorten it by 5 or 6 inches, if it's not too much trouble. The boat will probably trim better. That's a lot of weight and the further you put it aft, the more bow up trim you will have.
Thanks Larry, yeah he made it like this because he was worried the motor cover was going to hit the transom (in up position), I really can't tell from that drawing
Re: Curacao CS 25 Need some input on bracket please page 177
Posted: Thu Feb 07, 2013 6:59 pm
by wildbill
My last boat I had a Stainless Marine Bracket with a 30'' setback. The 250 optimax ended up about 2 1/2'' from the transom when fully tilted up. looking at your drawing you would be about the same at 30". It was plenty of room on the full transom platform with a ladder. Have you researched the height of your bracket mounted on the transom? I believe I heard you can set your engine's cavitation plate at about 2 1/2'' above the keel of the boat with a 30" setback.(I believe it's 1" of rise per foot of setback) I'm sure you've got it covered but I wanted to touch base before you drilled the transom. My engine/boat ran perfect at 3" above keel. You just want to be able to raise or lower the height of your engine to optimize the performance after she's set. You may even end up a little higher. Double check my numbers.
Looking good.
Posted: Thu Feb 07, 2013 8:12 pm
by AtTheBrink
I'm with Larry on this. 5 or 6 inches shorter will be right on the money. In that drawing it looked like 28 and some change was the min. so at 30" you should have plenty of clearance.
Posted: Fri Feb 08, 2013 6:18 am
by peter-curacao
Thanks guys I just messaged him to shorten it to a 30" setback, wildbill 1" of rise per foot of setback is correct, thanks for thinking with me
Posted: Fri Feb 08, 2013 9:44 am
by tech_support
30" is plenty for my F250 to trip all the way up with a couple inches to spar.
Is the welder going to make the top of the bracket level with water line? It would sure give you a better look, not to mention you can have a taller/wider bolt pattern and it will spread the loads out better.
Posted: Fri Feb 08, 2013 11:16 am
by AtTheBrink
Another question on your brqcket. Are you going to have it watertight of fill it with foam to give you some floation for your motor?
Posted: Fri Feb 08, 2013 11:32 am
by tech_support
AtTheBrink wrote:Another question on your brqcket. Are you going to have it watertight of fill it with foam to give you some floation for your motor?
you want to keep those things hollow, saltwater mixed with foam against aluminum will cause corrosion/pitting quickly. Add the stainless fasteners into the pot (dis-similar metals) and you would have galvanic corrosion party
The buoyancy comes from the hollow space (displacing the water around it), not the foam inside. bracket floats the motor the same foam or hollow. Technically, the bracket filled with foam will weigh a little more (foam has some weight) so the hollow one will have more buoyancy. Of course this all assumes the bracket is made water tight
Posted: Fri Feb 08, 2013 12:22 pm
by peter-curacao
shine wrote:30" is plenty for my F250 to trip all the way up with a couple inches to spar.
Joel thanks for your response, not sure I understand you though, If you look at the pic the part under the red line will be cut away, are you saying to cut the part above the yellow line also to give it a better look? I don't understand how that will spread the load better it would have a big part of the motor mounting plate above the "box" and a smaller box against the transom or.....
Also the box will receive a swimming platform left and right from the "box" in thinner aluminum, don't think that will handle well so close to the water, especially when backing up for a marlin or something (thinking about Larry's post
Of course I won't fill it with foam it only receives an inspection plate on the top
Posted: Fri Feb 08, 2013 12:33 pm
by tech_support
sorry, from one of the previous pictures, I though the top of the bracket was angled up. I can see now that its normal
by AtTheBrink
shine wrote:AtTheBrink wrote:Another question on your brqcket. Are you going to have it watertight of fill it with foam to give you some floation for your motor?
I understand about the foam adding weight
, I was just thinging about filling it in case of a leak. I had no idea that the foam was corrosive? Or is it that it might trap the saltwater against the metal and not allow it compltely dry?
Posted: Fri Feb 08, 2013 12:43 pm
by peter-curacao
AtTheBrink wrote: I was just thinging about filling it in case of a leak.
That's what the inspection plate is for i.a.
Posted: Fri Feb 08, 2013 12:46 pm
by tech_support
I had no idea that the foam was corrosive? Or is it that it might trap the saltwater against the metal and not allow it completely dry?
yeah, its not the foam itself it salt water moisture held against aluminum. Same thing would happen if it were a wet rag or wet piece of wood. Its the reason you use strips of neoprene under a bare aluminum tank.
Posted: Fri Feb 08, 2013 12:58 pm
by peter-curacao
Joel in case you missed this one
peter-curacao wrote:shine wrote:30" is plenty for my F250 to trip all the way up with a couple inches to spar.
Posted: Fri Feb 08, 2013 3:42 pm
by tech_support
I made a response earlier, but it did not post
Sorry Peter for the false alarm, in the previous pictures it looked like the top surface of the bracket was sloping up towards the motor - its was just an illusion, as I can see from the picture above it is level.
One thing that might help stiffen up the bracket is to have the top part, where the motor hangs "boxed" vs. just plate - maybe the guy was going to do that anyway. This is what mine looks like. I think its just a large section of channel welded to the rear plate to make the "box", then the top part of the bracket (swim platform) its welded to the channel's top surface.
Posted: Fri Feb 08, 2013 3:53 pm
by peter-curacao
shine wrote:I made a response earlier, but it did not post
Thanks Joel, he was talking about reinforcing it but I didn't ask him how, the way yours is done is imo the most beautiful way to do it, I certainly sent the pic to him.
One other question how big is that kicker plate and how is it reinforced, I'm guessing with two strips or channel towards the transom?
Edit: what about the bolting holes in that "boxed" area did he (your welder) weld a piece of pipe in there?
Posted: Mon Feb 11, 2013 8:03 am
by peter-curacao
Hey guys hopefully my bracket will be "finished" this week, would this the correct way to treat it?
- sand all the welds smooth
- clean it with thinner?
- spray it with etching primer
- smooth it out some more with fairing compound
- spray it with epoxy primer
- shoot paint
- paint anti fouling below the water line
One other thing should I place anodes anywhere on the boat, bracket or motor?
Posted: Mon Feb 11, 2013 8:30 am
I'm no painting expert, especially aluminum, but I "think" a zinc chromate primer would be the thing to use. That's what they use on outboards at the factory.
Yes to the anodes on the bracket. The engine should already have anodes on it. None required for the hull.
Posted: Mon Feb 11, 2013 9:41 am
by peter-curacao
Cracker Larry wrote:I'm no painting expert,
Me either I saw it on American restoration, they told the way to prime aluminum is to do it with etching primer.
What kind of anodes should the bracket receive and were should I place them?
Posted: Mon Feb 11, 2013 9:50 am
by tech_support
Here is the page of my SC build where I painted/prepped the bracket
http://forums.bateau2.com/viewtopic.php ... &start=160
etch
treat (alodine)
epoxy chromate primer
high build primer
fairing compound
finish primer (could be more high build)
Paint
I do not have a zinc on my bracket. There is a giant on on the bottom of the outboard. If it was to be kept in the water long term then I think might have zincs on it plus some on the trim tab plates too.
I dont think it would hurt much if you omitted the alodine treatment, its prob.not easy to get (aircraft supply).
Posted: Mon Feb 11, 2013 10:07 am
Any kind of bar type anode would be fine. I'd mount it on the rear of the bracket below the waterline. Probably center it in front of the engine. Like Joel said, you will want zincs on the tabs too. They make them especially for tabs. Obviously they would mount on the top, not the bottom.
Posted: Mon Feb 11, 2013 10:23 am
by peter-curacao
shine wrote:Here is the page of my SC build where I painted/prepped the bracket
etch
treat (alodine)
high build primer
fairing compound
Paint
Okay thanks I hope i can find all that stuff you are showing here
Posted: Mon Feb 11, 2013 12:32 pm
by peter-curacao
Cracker Larry wrote:What kind of anodes should the bracket receive and were should I place them?
Okay thanks Larry,I better ask my welder to weld a thread end to the bracket
Posted: Mon Feb 11, 2013 4:54 pm
by Uncle D
I will need to paint my motor, Wonder if this would be the way to do it ??
Posted: Mon Feb 11, 2013 7:57 pm
by AtTheBrink
Uncle D wrote:I will need to paint my motor, Wonder if this would be the way to do it ??
There is a thread where a guy is restoring an old 65 HP Bearcat from the 60's and he is doing something very similar with his paint job.
Posted: Mon Feb 11, 2013 8:31 pm
Peter, it might be better for him to weld on a doubled piece of aluminum to the inside, then drill and tap a blind threaded hole that will accept a stainless bolt. You can't weld stainless to aluminum, I'm sure you know that, and I don't think an aluminum threaded stud would be a good idea.
Posted: Tue Feb 12, 2013 6:22 am
by peter-curacao
Cracker Larry wrote:Okay thanks Larry,I better ask my welder to weld a thread end to the bracket
Yeah didn't think about that
Posted: Tue Feb 12, 2013 7:15 am
by Walkers Run
If your bottom paint has copper in it be sure the aluminum is insulated from the bottom paint. The high build primer should do the job. I've always used non-copper bottom paint on my trim tabs (which doesn't work as well) I wonder if the same treatment for the trim tabs would work. Glad your getting all this worked out before me.
Posted: Tue Feb 12, 2013 10:02 am
by peter-curacao
Walkers Run wrote:If your bottom paint has copper in it be sure the aluminum is insulated from the bottom paint. The high build primer should do the job. I've always used non-copper bottom paint on my trim tabs (which doesn't work as well) I wonder if the same treatment for the trim tabs would work. Glad your getting all this worked out before me.
Don't know to be honest, but I think the stainless from the trim tabs will not etch as easy as the aluminum, and if I understand correctly the etching is an important part in the process. I think (but again I don't know) it's better to leave the tabs stainless
Posted: Thu Feb 14, 2013 11:29 am
by peter-curacao
etch
treat (alodine)
high build primer
fairing compound
Paint
Hey guys,Joel, Believe it or not but I found step 1 and 2 (@ US 100,- a gallon expensive stuff btw), only the epoxy chromate primer is harder to find, as soon as I put the chromate in they are lost and don't know what I mean, its hard to explain to them because I also don't know what it is
So I took some pics maybe it's on there without me knowing it.
Posted: Thu Feb 14, 2013 11:51 am
by tech_support
Excellent, you have everything you need to do it the same way I did.....
Step one and two are in this picture (#1 Etch with Alumiprep, #2 treat with Alodine)
The you use the Chromate epoxy primer, which is the Awlgrip S9001, you dont sand it, then you go to you regular epoxy high build primer to build some thickness, then you fair it, prime again and then paint.
It seems like a lot of steps, but it not much trouble in the scope of building a boat
Posted: Thu Feb 14, 2013 11:58 am
by peter-curacao
shine wrote:The you use the Chromate epoxy primer, which is the Awlgrip S9001,
Thanks Joel
since it's also yellow I was hoping it was that one, why don't they just put Chromate epoxy primer on the can?
Posted: Thu Feb 14, 2013 12:01 pm
by peter-curacao
Btw am I stuck to awlgrip now or can I put an other brand highbuild over the 9001?
Posted: Thu Feb 14, 2013 12:09 pm
by tech_support
Its for "professional use only"
Your supposed to know what you need.
Its their way "out" to not print all directions and precautions on the cans. Sterling is the same way, it just has a number on the can.
I do understand their reasoning, they want to make certain people read the literature and instructions before application, and there is just way too much information they need to have it printed on a can. With something like a 2 part LPU there is about 2 pages worth of information one needs to know just about proper surface prep.
Anyway, im happy you have everything you need. Its easy to understand why most manufacturers use powder coating instead of painting
painting would add a lot of labor cost to their brackets!
Posted: Thu Feb 14, 2013 4:12 pm
by peter-curacao
shine wrote:Its for "professional use only"
Yeah right like I know what I'm doing LOL
Posted: Thu Feb 14, 2013 6:50 pm
by AtTheBrink
That is good that you were able to find all the stuff you need to paint your bracket right there on your island.
When is the welder going to get your bracket finished?
Posted: Fri Feb 15, 2013 8:02 am
by peter-curacao
Hopefully today, I will post pics when I received it
Posted: Wed Feb 20, 2013 9:29 am
by AtTheBrink
No bracket yet?
Posted: Wed Feb 20, 2013 11:21 am
by peter-curacao
Unfortunately not
but maybe, maybe this afternoon!
Posted: Wed Feb 20, 2013 8:18 pm
by peter-curacao
peter-curacao wrote:Unfortunately not
NOT!
Posted: Wed Feb 20, 2013 8:27 pm
by AtTheBrink
Posted: Sat Feb 23, 2013 11:36 am
by peter-curacao
Posted: Sat Feb 23, 2013 12:24 pm
Awesome
Posted: Sat Feb 23, 2013 1:16 pm
by AtTheBrink
Good looking bracket you got there Pete! A week late is better than never, right? How many bolts are going to hold that thing on? 25 was the best count I could get.
Posted: Sat Feb 23, 2013 6:19 pm
by peter-curacao
AtTheBrink wrote:Good looking bracket you got there Pete! A week late is better than never, right? How many bolts are going to hold that thing on? 25 was the best count I could get.
You got that right
In the following pic you can see the holes better, the vertical holes were drilled double because the first ones were to close to the frames, the holes in the swim platform I don't know if I have to use them all
, all those holes in the transom doesn't make me to happy
Did the etch, alodine and epoxy chromate primer treatment, had to do it in two
(upper and under side) phases because the bracket is to heavy to flip with me and Gloria so when the upper side is finished I have to call a friend help me flip it over.
Posted: Sat Feb 23, 2013 6:40 pm
Very nice
Dang Peter, She ain't as big as a minute. That bracket weighs twice more than Gloria
Tell her that I wouldn't treat her like that
Posted: Sat Feb 23, 2013 7:53 pm
by peter-curacao
Thanks Larry
Hey I told Gloria what you said, she told me to say next time she wants to arm wrestle with you, loser pays lunch
Larry before you accept let me warn you, she grew up with a lot of platanos, salami and sancocho
Posted: Sat Feb 23, 2013 8:03 pm
I'll take that bet. I ain't scared of plantains or salami, left or right handed
And I'll gladly buy her lunch when I lose, or even if I win
That sancoho looks great
It might give her a slight edge, but tell her to practice up
Sure hope to see her this summer.
Posted: Sat Feb 23, 2013 8:11 pm
Wait a minute, are these men her brothers
Posted: Sat Feb 23, 2013 8:15 pm
by peter-curacao
Cracker Larry wrote:Wait a minute, are these men her brothers
haha
there you go!
Posted: Sat Feb 23, 2013 8:17 pm
In that case, maybe we'll skip the wrestling match and I'll just buy her lunch
Posted: Sat Feb 23, 2013 8:20 pm
by peter-curacao
Cracker Larry wrote:In that case, maybe we'll skip the wrestling match and I'll just buy her lunch
hahaha just pissed my pants ROFL
that's some funny shit going on here
Posted: Sat Feb 23, 2013 8:21 pm
But wait a minute, don't you owe me a lunch anyway
Maybe we can work this out without anybody getting hurt
Posted: Sat Feb 23, 2013 8:23 pm
by peter-curacao
Cracker Larry wrote:But wait a minute, don't you owe me a lunch anyway
No no told you I would get you that anyway regarding what, and I think for that help it should be dinner not lunch I owe you!
Posted: Sat Feb 23, 2013 9:16 pm
I'm always happy to help, you know that. This is between Gloria and I now though
There ain't no way I can back out of a public challenge like that, so tell her that I accept. As long as she doesn't bring her brothers, I may escape without serious injury. I hope, but even losing is sometimes fun
Capt. Hiram's in June
Posted: Sun Feb 24, 2013 8:31 am
by peter-curacao
Posted: Sun Feb 24, 2013 2:02 pm
by peter-curacao
Flipped and painted
Posted: Sun Feb 24, 2013 2:53 pm
Dang Peter, I think that recipe will feed 50 people
It really looks good though
I don't see any holes in the bracket for mounting the engine ? It might be good to drill, treat and prime those too?
Re: Curacao CS 25
Posted: Mon Feb 25, 2013 12:49 pm
by peter-curacao
That's correct couldn't find those measurements in it's booklet, and its difficult to measure them in the box so I will drill them when the moment is there to hang it.
Re: Curacao CS 25
Posted: Mon Feb 25, 2013 3:07 pm
by peter-curacao
High build primer on and "visible" welds touched up.
Re: Curacao CS 25
Posted: Tue Feb 26, 2013 3:25 pm
by tobolamr
Looking really good, Peter! Keep it up!
Re: Curacao CS 25
Posted: Thu Feb 28, 2013 4:29 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Feb 28, 2013 6:10 pm
by Aripeka Angler
Coming together now, looking good.
Re: Curacao CS 25
Posted: Sat Mar 02, 2013 6:30 am
by misterfly_nl
Still following this build with great respect.
Can,t wait to see the real deal again in september.
Evert
Re: Curacao CS 25
Posted: Sat Mar 02, 2013 3:32 pm
by peter-curacao
Thanks guys.
Went from a 25 to a 28 footer
Drilled and filled the holes, as you can see on the right I had to relocate the 3 side holes on the left and right because they were to close to the frame and stringer to put a decent backing plate, I know stupid but it is what it is.
Hung the bracket to the transom on the upper center bold to drill the platform holes and exactly mark the box holes on the epoxy plugs. Bracket looks a lot smaller hanging from the transom.
Re: Curacao CS 25
Posted: Sat Mar 02, 2013 3:49 pm
Did Gloria hold it up while you put in the bolt ?
That looks great!
Re: Curacao CS 25
Posted: Sat Mar 02, 2013 4:30 pm
by peter-curacao
Cracker Larry wrote:Did Gloria hold it up while you put in the bolt ?
That looks great!
Thanks Larry.
Yes she did hold it up, she had to train for some kind of arm wrestling match she told me
Re: Curacao CS 25
Posted: Sat Mar 02, 2013 5:20 pm
That's what I was afraid of
Re: Curacao CS 25
Posted: Sat Mar 02, 2013 5:22 pm
by Walkers Run
Wow that looks great. Hugh milestone. Can't wait to see it floating.
Re: Curacao CS 25
Posted: Wed Mar 06, 2013 4:12 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Mar 07, 2013 4:58 pm
by peter-curacao
Did some 1500 then 2000 sanding followed by some buffing.
Re: Curacao CS 25
Posted: Thu Mar 07, 2013 5:44 pm
Sure looks good
Re: Curacao CS 25
Posted: Thu Mar 07, 2013 8:25 pm
by Larry B
That looks great Peter
It's probably in your thread someplace, but what kind of paint are you using?
Re: Curacao CS 25
Posted: Thu Mar 07, 2013 8:46 pm
by peter-curacao
Larry B wrote:That looks great Peter
Thank you!
it's PPG Concept
Re: Curacao CS 25
Posted: Fri Mar 08, 2013 3:45 pm
by peter-curacao
Applied non skid at the swimming ladder area
Re: Curacao CS 25
Posted: Fri Mar 08, 2013 8:06 pm
by jorgepease
Very nice!
Re: Curacao CS 25
Posted: Sat Mar 09, 2013 7:32 am
by callyb
Peter, you are the kiwi grip master
Re: Curacao CS 25
Posted: Sat Mar 09, 2013 8:35 am
by Dougster
Sensei Peter-Curacao, Picasso of kiwi!!
I couldn't execute it that well and sure couldn't have come up with such a cool design. An earlier pic you posted of how you tape was a guide for me and my simple work. Those kind of pics, the work in progress ones, are especially useful for lots of folks I bet.
Sends a belated thanks Dougster
Re: Curacao CS 25
Posted: Sat Mar 09, 2013 9:09 am
An artist with masking tape
Re: Curacao CS 25
Posted: Sat Mar 09, 2013 2:07 pm
by tobolamr
There we go again, stoking his ego some more!
Nicely done, Peter! Keep wow-ing us!
Re: Curacao CS 25
Posted: Sat Mar 09, 2013 5:15 pm
by peter-curacao
Thanks for the compliments guys I appreciate it, but it is just some tape, paint and patience, and in real life the boat doesn't look as good as in the pics.
Dougster you are welcome, glad I could be of any help, your boat really looks fantastic and doesn't look simple at all
Btw the design
( if you can speak of a design) of the kiwigrip just came out like this because I wanted to be able to safely jump/dive from the back and climb on the site of the platform
Re: Curacao CS 25
Posted: Sat Mar 09, 2013 6:17 pm
by wegcagle
Looks great Peter. Love the kiwi grip design. You planning a splash date yet?
Will
Re: Curacao CS 25
Posted: Tue Mar 12, 2013 5:57 pm
by peter-curacao
Hung the bracket today, have to charge my camera battery so a quick smartphone pic has to do.
Tomorrow more pics.
Edit: Will I didn't set a date but I'm hoping somewhere half this year, but I ain't pushing it, a couple months more or less doesn't matter anymore
Edit 2:Another phone pic, let there be light!
Re: Curacao CS 25
Posted: Tue Mar 12, 2013 9:09 pm
Re: Curacao CS 25
Posted: Tue Mar 12, 2013 9:35 pm
by tobolamr
Nice!
Re: Curacao CS 25
Posted: Wed Mar 13, 2013 12:37 pm
by wegcagle
WOW
That certainly turned out nice
Will
Re: Curacao CS 25
Posted: Thu Mar 14, 2013 8:01 pm
by Hope2float
Peter, VERY nice! looks great as always.
Dave
Re: Curacao CS 25
Posted: Fri Mar 15, 2013 4:31 am
by chicagoross
Looks great, Peter! I'm sure I'd like it just as much close up! Wish our islands were closer...
Re: Curacao CS 25
Posted: Fri Mar 15, 2013 6:32 pm
by Bluefish2
When do we get to see a picture of the whole boat all rigged out?
Great job Peter! It will be a work of art I am sure.
BF2
Re: Curacao CS 25
Posted: Sat Mar 16, 2013 4:06 pm
by peter-curacao
Put some anti fouling on the bracket and did bold the anode in its place.
mounted the tabs and screw in the scuppers.
Unfortunately I couldn't mount the actuators because the provided pipe nipples were a bit to short for my transom, so Monday I will let a machine shop fabricate longer ones.
Did put some kit over the 5200 seal to make a nicer seam also mounted the ladder and secure thingy for the ladder, also I put in some transom/trailer eyes.
Re: Curacao CS 25
Posted: Mon Mar 18, 2013 9:37 am
by tech_support
Can you smell the finish line ?
Re: Curacao CS 25
Posted: Mon Mar 18, 2013 9:53 am
I can smell it from here! Smells like fish
Re: Curacao CS 25
Posted: Mon Mar 18, 2013 10:02 am
by tech_support
or Rum, or both
Re: Curacao CS 25
Posted: Mon Mar 18, 2013 10:35 am
by peter-curacao
Lol :lol:I think it's rum, last weekend Blue Marlin tournament, 40 boats 23 strikes 11 released , so not to much fish over here at the moment
Re: Curacao CS 25
Posted: Mon Apr 01, 2013 3:06 am
by antoniekruger
Hi Peter,
Sorry if this have been discussed - I notices 2 mounting plates (1 center and another offset) on the bracket. What is the thinking behind this? A main motor with a backup, or main and trawling? What size main and second motor are you mounting? Is the bracket made from aluminium or stainless? It looks great and gives that extra space. I have not seen that arrangement in our local waters. Dit lyk baie goed, boet. You have certainly set the benchmark high, a true inspiration.
Cheers
Antonie
Re: Curacao CS 25
Posted: Mon Apr 01, 2013 10:14 am
by peter-curacao
antoniekruger wrote:Hi Peter,
Cheers
Antonie
Antonie I was thinking main and a backup, for the main I choose a ETEC 300 HP because Larry likes those a lot!
Backup I didn't buy yet, but it wouldn't be a very expensive one, probably a 10 to 15 HP Parsun or Tohatsu or something like that.
The bracket is made from aluminum, I think for a bracket like this stainless would become to heavy, not to mention the $$$
I'm not to happy about the kicker plate, I think it's too big, but since I was waiting for the bracket for a long time I didn't want to sent it back to the welder.
I had to do a lot of searching and asking for measurements and all, so I know it's not easy to find for this boat, Joel was a big help as for the thickness of the material, so if by the time you are struggling with this also just let me know and I post a drawing of it.
The arrangement your talking about would be looking something like this
Re: Curacao CS 25
Posted: Tue Apr 02, 2013 5:29 am
by antoniekruger
Yip, that looks right - Its not only Larry that likes these - seems like many people rave about these:
http://www.boattest.com/engine-review/E ... -H-P-_2010
I see a piece of timber wedged between the motor and the mounting plate. Is this a spacer or vibration control?
Cheers
Re: Curacao CS 25
Posted: Tue Apr 02, 2013 7:34 am
Re: Curacao CS 25
Posted: Tue Apr 02, 2013 7:41 pm
by peter-curacao
Cheers
I don't know but my first guess is his or hers kicker plate is to thin.
Re: Curacao CS 25
Posted: Tue Apr 02, 2013 8:45 pm
by Hope2float
Peter as always it looks great. I smell victory in your camp and rightfully so. You deserve it the time has been seriously put in on that project and it's almost time to let her rip. The smile on your face will be wound so tight that your jaw will be hurting. Soak it in when it happens.
Dave
Re: Curacao CS 25
Posted: Wed Apr 03, 2013 6:14 pm
by tobolamr
And make sure you have a trusted person to get you lots and lots of pictures of EVERYTHING as it happens! And splash that boat porn all over this site!
Re: Curacao CS 25
Posted: Fri Apr 12, 2013 2:39 pm
by cape man
Peter,
Been missing from here for a while, but your's was the first project I caught up on. Wow. PRACHTIG!
Re: Curacao CS 25
Posted: Fri Apr 12, 2013 3:46 pm
by peter-curacao
cape man wrote:Peter,
Thanks Craig, but at the moment it's not so prachtig, I have a BIG FAIL
on my bench hatches, they were impossible to close nicely with the epdm seal installed, so now I'm struggling to correct this , I'm scraping of some wood of the flange what doesn't make it look nicer, hopefully I can correct it cosmetically later.
Here a pic of the mess
Re: Curacao CS 25
Posted: Fri Apr 12, 2013 4:21 pm
Well, it's about time you made a mess out of something
Was starting to wonder if you were human. I'm sure you will fix it to satisfaction.
Re: Curacao CS 25
Posted: Fri Apr 12, 2013 4:28 pm
by peter-curacao
Cracker Larry wrote:Well, it's about time you made a mess out of something
LOL
Forgot about my notching stringer mistake??
Re: Curacao CS 25
Posted: Fri Apr 12, 2013 4:34 pm
Minor, and years ago. You were past due for another
Personally, I've got a hair full of 5200 today. How in the world can I get 5200 smeared in my hair gluing in a gas tank
I need a trip to Cape Mans' St Baldrich barber
Re: Curacao CS 25
Posted: Fri Apr 12, 2013 4:45 pm
by peter-curacao
I hear you, that stuff goes everywhere it shouldn't go
Re: Curacao CS 25
Posted: Fri Apr 12, 2013 8:01 pm
by peter-curacao
Hmmmm never heard of it and never saw it before, but maybe a battle saddle is the way to go as replacement for the chair I made, Craig what do you think?
Re: Curacao CS 25
Posted: Sat Apr 13, 2013 10:03 am
by Joe H
I'm no Craig but I think it looks really cool, I'd like to see a bikini clad babe fighting a big one in there!
Joe H
Re: Curacao CS 25
Posted: Sat Apr 13, 2013 4:22 pm
by wegcagle
You'll get the hatches figured out. No sweat.
Wow! That's a beautiful chair Peter. Hell, I think it would even make my a$$ look good in a bikini
Will
Re: Curacao CS 25
Posted: Sun Apr 14, 2013 5:41 pm
by peter-curacao
Today I cut all three flanges, result is the "gutters" aren't so deep anymore, but on the other hand every cloud has a silver lining
(hope that's the right expression) I think now there is space to put a double epdm seal in
Any of you have an idea how to determine how well those seals are pushed against the hatch?
Re: Curacao CS 25
Posted: Sun Apr 14, 2013 9:21 pm
by AtTheBrink
You can dust your seals something like chalkline powder and close the hatch. When you open it you should see chalk on the hatch anywhere the lid came in contact with the seal. Would that work for you?
Re: Curacao CS 25
Posted: Sat Apr 20, 2013 9:03 pm
by peter-curacao
Thanks at the brink, it wasn't really necessary as soon as I opened the hatch I saw that the epdm seals were compressed, went over them with the pressure cleaner and they stay dry inside.
Today a little early decorating of the Christmas tree
Bradley (Doc Dyer) this one is for you, hope you can sit it out LOL
http://www.youtube.com/watch?v=ZK9w-Mdy30g
Re: Curacao CS 25
Posted: Sat Apr 20, 2013 9:09 pm
by Aripeka Angler
Great video Peter
Re: Curacao CS 25
Posted: Sat Apr 20, 2013 10:07 pm
That's awesome Peter
Nice tree
Re: Curacao CS 25
Posted: Sat Apr 20, 2013 10:13 pm
by Larry B
Your a talented man for sure, Great Video
What program did you use to put that video together??
Re: Curacao CS 25
Posted: Sun Apr 21, 2013 12:22 am
by Doc_Dyer
Wow nice tree
Was wondering if you were going to have enough daylight to finish
Re: Curacao CS 25
Posted: Sun Apr 21, 2013 5:15 pm
by peter-curacao
Thanks guys, LarryB I just used windows movie maker to make that movie, works real simple
Re: Curacao CS 25
Posted: Sun Apr 21, 2013 7:28 pm
by peter-curacao
All hatches in bow area are finished, anchor en seat hatches, only thing left is some kiwigrip on the anchor (deck)hatches for sure but I have a little doubt about the bench hatches
there will be cushions on there later, what do most of you guys do? my first instinct is kiwi grip it and when you need the space kick up the cushion, on the other hand standing on the cushion gives a pretty neat grip also. hmmm
Re: Curacao CS 25
Posted: Sun Apr 21, 2013 9:30 pm
by Joe H
Love the tree video Peter, only you.
If your going to get the boat wet before you get the cushions then yes kiwi grip, but if the cushions are coming before the launch then why bother?
I'm about to apply kiwi grip to my sole, did you tint yours?
Joe H
Re: Curacao CS 25
Posted: Mon Apr 22, 2013 7:43 am
by Walkers Run
Wow Peter! You are so close to splash day. I had a Pursuit years ago with a similar set up. I had the cushions that snapped in and rarely used them. There was non skid there. I fought a lot of fish standing there and was glad for the non skid. I am planing on stealing most of your ideas, and I am going to kiwi grip those areas.
Re: Curacao CS 25
Posted: Tue Apr 23, 2013 1:09 pm
by tobolamr
To: Peter-Curacao
We DEMAND that you not only provide pictures of the boat on the trailer, heading to the water, just hitting the water for the first time, etc etc etc... But also VIDEO. And VIDEO of the E-Tec running for the first time. And so on and so forth. Document your splash to within an INCH of it's life! LOL
Go Peter Go! You're making great progress! I can't wait to see her in the water!
Re: Curacao CS 25
Posted: Tue Apr 23, 2013 4:32 pm
by pee wee
Gee, it'd be a shame to get her all wet and dirty after all the work you've done on her.
Seriously, when you launch her you'd better wear a hat with a chin strap- your smile might be so wide it meets in the back and your head will fall off!
Re: Curacao CS 25
Posted: Tue Apr 23, 2013 5:40 pm
by peter-curacao
Thanks guys your comments really does a person good!
It was bit of a long way but but I think I'm almost there, hopefully somewhere half this year (still have to paint the hull though).
JoeH I didn't tint the kiwi, the kiwi you see in the pic is just very dirty
it did surprise me how white the kiwi is, when I did put it on the deck and sole, the paint what looked white as snow became a little greyish next to the kiwi but overall it looks good, I like it.
Walkers run I think you are right on the kiwi on the hatches, I have still plenty of kiwi so I think I'm gonna do that, maybe it keeps the cushions better in place also when in use.
Installed the oil tank this afternoon and chased the hose and sensor line towards the transom.
Re: Curacao CS 25
Posted: Wed Apr 24, 2013 9:48 am
by tech_support
Thats great that they allow the oil tank to be that far away, does it have a pump in the tank ?
Your boat is looking awesome
BTW, I had my first offshore experience with E-tecs. Friend bought a used 30' with twin 250's, I think they were 5 years old they have 500 hours on them. Ran about 250 miles in two days with no problems. They are not as quiet as 4 stroke, and they burn more gas on the troll, but I think the fuel burn was close to 4 stoke at a reasonable cruise speed. Once it get over 4000 rpm the burn rate went up pretty quick. They started right up with hardly any smoke. Cant wait to see how the 300 pushes your boat
Re: Curacao CS 25
Posted: Wed Apr 24, 2013 11:27 am
by peter-curacao
Thanks Joel,
Yeah it is cool on a 25" foot you can place it almost anywhere, the maximum length of oil supply
hose that can be fitted to the oil tank is 25 ft, as long as it is a continues hose, luckily the hose supplied was more than sufficient in length. No except for the bulb it doesn't have a pump in it.
Good to hear you had a positive experience with Etec, I will post my experiences once the day is there, although I don't think the conditions here are real comparable to your waters ?
Re: Curacao CS 25
Posted: Wed Apr 24, 2013 1:46 pm
by Boater45
Peter, what material did you use to seal your hatches? And where did you get your hatch supports?
Thanks,
Will
Re: Curacao CS 25
Posted: Wed Apr 24, 2013 6:43 pm
by wegcagle
Great work as always my friend. Can't wait to see in action. That thing looks crazy fast! Sorry we won't be hanging out again this year, but we will soon enough
Will
Re: Curacao CS 25
Posted: Thu Apr 25, 2013 9:32 am
by peter-curacao
Boater45 wrote:Peter, what material did you use to seal your hatches? And where did you get your hatch supports?
Thanks,
Will
Will I used EPDM seals, supports I bought locally but you can find them online and on Ebay also
http://www.ebay.com/sch/Boat-Parts-/264 ... ng&_sop=15
Re: Curacao CS 25
Posted: Thu Apr 25, 2013 9:46 am
by peter-curacao
wegcagle wrote:Great work as always my friend. Can't wait to see in action. That thing looks crazy fast! Sorry we won't be hanging out again this year, but we will soon enough
Will
Thanks Will, maybe you can hitch a ride on Larry's plane when he is visiting, would be cool, 3 rum runners in te Caribbean
Re: Curacao CS 25
Posted: Thu Apr 25, 2013 12:45 pm
by wegcagle
CUBRA LIBRE
I will certainly do my best. That would be one fun trip
Full of headaches.....but REALLY fun. First, I've got to get through the move back to Georgia (mid-June). We are closing on a house next week, and my wife already has about a month's worth of projects stacked up for me.
The handy-er I get; the more intricate her needs
Will
Re: Curacao CS 25
Posted: Thu Apr 25, 2013 12:55 pm
by Boater45
Thanks Peter
Will
Re: Curacao CS 25
Posted: Tue May 07, 2013 6:36 pm
by peter-curacao
Re: Curacao CS 25
Posted: Tue May 07, 2013 6:49 pm
by pee wee
It just keeps on getting better, looking rather awesome.
Re: Curacao CS 25
Posted: Tue May 07, 2013 6:59 pm
Peter, that is beautiful
Re: Curacao CS 25
Posted: Wed May 08, 2013 7:43 am
by cottontop
Are you sure the boat isn't store bought? No one that hasn't seen these treads will ever believe you built it. Very fine job! John
Re: Curacao CS 25
Posted: Wed May 08, 2013 7:52 am
by tcason
How do you cut the masking tape to make such perfect curves in your non-skid corners?
Kinda a basic question but hoping to learn a secret I can steal/use!
Re: Curacao CS 25
Posted: Wed May 08, 2013 9:26 am
I agree, it's beautiful work.
About the masking tape, I have a number of round objects that I use to draw nice curves. I stick to 3 sizes: the beer can, the 1 liter paint can and the 5 gallon pail.
Draw your straight lines, mask then roughly and push your curve, paint can for example, tangent to the straight lines and that's it.
I believe that repeating a limited number of circle sizes is more pleasant to the eye than a different one for every corner.
Re: Curacao CS 25
Posted: Wed May 08, 2013 1:24 pm
by tcason
How do you then cut the radius without cutting/damaging paint underneath - with razor blade??
Re: Curacao CS 25
Posted: Wed May 08, 2013 2:43 pm
by peter-curacao
Hey thanks guys
tcason here's an example of the tape work on my swimming platform, you can see I first did the straight lines after that I put a piece of tape in the corner which I cut with a x-acto knife, you can see it laying between the 2 tape rolls.
I mostly use a coin for the radius or other round objects as Jacques suggested , if I use a coin or another small radius I don't even bother marking the tape I just use the coin as a guide for the knife.
About not cutting in the paint, you will get a feel for it pretty quickly, but if you do cut into the paint don't worry about it to much because with the kiwi grip you have to remove the tape when still wet, because of this an accidental cut will disappear because the kiwi grip will fill it, at least that's my experience.
Edit: o yeah for a bigger radius I also used pin striping tape, just draw the radius with pencil then follow the line with the pin stripe tape, tape with wider tape over the pinstripe tape
(never use a water based marker! it will mix with the kiwi, don't ask me how I know)
Re: Curacao CS 25
Posted: Wed May 08, 2013 7:52 pm
by AtTheBrink
Your boat is looking great Peter, how's the.wiring coming along? Getting close to splashing her!
Re: Curacao CS 25
Posted: Thu May 09, 2013 7:39 am
by tcason
peter-curacao wrote:Hey thanks guys
THANKS for the explanation - time and paitence!
Re: Curacao CS 25
Posted: Thu May 09, 2013 10:19 am
by peter-curacao
You're welcome,it's my pleasure, you know the Kiwi grip is very neat stuff
and it is easy on the feet I'm glad I used it instead of other more traditional non skid products.It's easy to use and you can do some cool stuff with it, when I saw this video tutorial
http://www.youtube.com/watch?feature=pl ... _GsZQXdico from their site I had to try it, instead of a decal I just used wide tape and the x-acto knife to cut the letters, if you like it you should give it a try , it's easier as you would think.
Re: Curacao CS 25
Posted: Sun May 12, 2013 7:06 am
by majorgator
Excellent work Peter. I wish I had seen that video earlier
The personal touches you've added to your build are truly to be admired
Re: Curacao CS 25
Posted: Thu May 16, 2013 1:03 pm
by tobolamr
How are you doing on this now, Peter? I thought you were going to be launched by now? Just curious. And I'm hoping all is well!
Re: Curacao CS 25
Posted: Thu May 16, 2013 6:11 pm
by peter-curacao
tobolamr wrote:How are you doing on this now, Peter? I thought you were going to be launched by now? Just curious. And I'm hoping all is well!
Hi Tobolamr I launched her two weeks ago did you missed that?
Nah just kidding!
I'm not in a hurry couple of weeks or months more doesn't matter anymore on those what is it, 4 years?
I'm currently busy cooking spaghetti under the center console, killer for my ankles but I made some progress today, remote cables, hydraulic hoses, harness, and daisy chain for instrument lights are in, have to start now with the the gps, fishfinder, 2 bilge pumps, 2 live well pumps, freshwater pump, hose down pump, trimtabs and so on
here some pics of the entangled mess
I'm thinking of making some starboard covers for bussbars, fuse panels, and instruments, I think that would look a lot cleaner even if everything is tied in later.
Re: Curacao CS 25
Posted: Thu May 16, 2013 7:49 pm
Buy me a plane ticket and I'll come fix that mess
Re: Curacao CS 25
Posted: Thu May 16, 2013 7:55 pm
by peter-curacao
Cracker Larry wrote:Buy me a plane ticket and I'll come fix that mess
Nah I think i can handle it
But if you want I buy you a plane ticket anyway! just for fun and be able to have some cool one's together!
Re: Curacao CS 25
Posted: Thu May 16, 2013 8:55 pm
I'm leaving, on a jet plane, don't know when I'll be back again
(John Denver)
Re: Curacao CS 25
Posted: Thu May 16, 2013 10:00 pm
by peter-curacao
Cracker Larry wrote:I'm leaving, on a jet plane, don't know when I'll be back again
(John Denver)
Great song!
Re: Curacao CS 25
Posted: Fri May 17, 2013 2:56 am
by glossieblack
Peter, Paul amd Mary covered by John Denver?
Re: Curacao CS 25
Posted: Fri May 17, 2013 7:31 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri May 17, 2013 7:41 pm
by Larry B
Super nice there Peter.
Re: Curacao CS 25
Posted: Sat May 18, 2013 9:20 am
Just a thought but you might want to consider a dimmer control. Mine are so bright that they mess with my night vision, but if I turn them off I can't read the compass
Re: Curacao CS 25
Posted: Sat May 18, 2013 9:36 am
by AtTheBrink
Lookin' good Peter! I like your set up. What GPS units do you have there?
Re: Curacao CS 25
Posted: Sat May 18, 2013 12:38 pm
by Corto Maltese
Red light doesn't disturb night vision.
Beautiful work.
Dario
Re: Curacao CS 25
Posted: Sat May 18, 2013 1:53 pm
by tobolamr
I 2nd what Dario said - Go red. We had a Pontiac with red dash lights, and man, it really didn't interfere with night vision to me at all. And my night vision is NOT what it was 10 years ago...
Re: Curacao CS 25
Posted: Sat May 18, 2013 3:45 pm
by peter-curacao
Thanks guys,
@ AtTheBrink, the units are from Sitex (see pic) nothing fancy schmancy, just 2 down to earth units without a lot of bells and whistles , but at least they didn't cost me an arm and a leg.
@ Corto Maltese, tobolamr & Larry, I know red doesn't disturb, when I was in the army we had red lenses with our flashlights for night trails, It's just that I like blue better and most of the time we only use gps and turn off the rest completely, Although not to fancy, the GPS and Fishfinder do have a night setting (black screen/ red details)
Re: Curacao CS 25
Posted: Sat May 18, 2013 5:03 pm
by AtTheBrink
Thanks Peter, I will check those out.
Re: Curacao CS 25
Posted: Sat May 18, 2013 5:47 pm
by ks8
Re: Curacao CS 25
Posted: Sat May 18, 2013 8:12 pm
It does if it's too bright and you are looking directly into it.
Yes, but you are not looking directly into the flashlight like you do with a gauge. Mine are red, and I wish I could dim them down. They only need to be bright enough to read them. Just saying. Blue and green are fine too, if they are dim.
Re: Curacao CS 25
Posted: Sat May 18, 2013 8:44 pm
by peter-curacao
Don't worry yall! This is what I would mostly will see at night
(ps I had to adjust the screen to full brightness for the camera to pic it up. )
Re: Curacao CS 25
Posted: Mon May 20, 2013 11:17 am
by peter-curacao
Doing this felt weird !
Re: Curacao CS 25
Posted: Mon May 20, 2013 7:56 pm
by AtTheBrink
I can't quite make out what you did there Peter. Are you punching holes in your hull for the water pick ups?
Re: Curacao CS 25
Posted: Tue May 21, 2013 7:28 pm
by peter-curacao
Hi Mike,
Yeah I'm punching holes, the one in the pic is for the transducer, transducer is in already but I forgot a backing plate, hope this is not a to big of a deal?
bottom thickness there is 18 mm or 3/4
Re: Curacao CS 25
Posted: Tue May 21, 2013 9:02 pm
by AtTheBrink
Always scary cutting holes in the hull of a perfectly good boat!
Re: Curacao CS 25
Posted: Wed May 29, 2013 8:49 pm
by peter-curacao
Let me be the creep freak show tonight!
Big day tomorrow! she's gonna see sunlight for the second time since I created her !! Mwahahahaahhaha !
But not for long! once stable I put her back in darkness !! Mwahahahaahhaha !
(above is with a reserve)
Re: Curacao CS 25
Posted: Thu May 30, 2013 7:38 am
by topwater
Must be putting her on her trailer
Getting close now Peter
Re: Curacao CS 25
Posted: Thu May 30, 2013 9:29 am
by Boater45
Take pictures Peter!! We would love to see her in her daylight glory!!
Re: Curacao CS 25
Posted: Thu May 30, 2013 12:19 pm
by ks8
Re: Curacao CS 25
Posted: Thu May 30, 2013 3:18 pm
by misterfly_nl
Drumrollllllllll, and still waiting.
Evert
Re: Curacao CS 25
Posted: Thu May 30, 2013 8:25 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu May 30, 2013 8:40 pm
by pee wee
That's big! Congratulations, must feel good. The boat looks great, nice to see an overall shot of it.
Re: Curacao CS 25
Posted: Thu May 30, 2013 8:51 pm
by AtTheBrink
That is an Awesome Boat Peter! It looks so much better outside! Keep it up!
Re: Curacao CS 25
Posted: Thu May 30, 2013 10:11 pm
by Boater45
I LOVE IT!!! Loks "BEAUTIFUL" Peter!!!!
Re: Curacao CS 25
Posted: Thu May 30, 2013 10:53 pm
Damn nice job Peter
Re: Curacao CS 25
Posted: Thu May 30, 2013 11:12 pm
by ks8
Re: Curacao CS 25
Posted: Fri May 31, 2013 12:47 am
by misterfly_nl
She,s looking great.
Evert
Re: Curacao CS 25
Posted: Fri May 31, 2013 6:19 am
by antoniekruger
Well done mate. That's a masterpiece. It's good to see that your choices and decisions came together this good.
I bet those riggers were very nervous, but seems like they did a good job. Do you have a final weight estimate?
Good job.
Re: Curacao CS 25
Posted: Fri May 31, 2013 8:53 am
by Dougster
WOW
Makes me want to stand up a salute
Dang near speechless Dougster
Re: Curacao CS 25
Posted: Fri May 31, 2013 9:37 am
by willg
Truly awesome. Bravo!
Re: Curacao CS 25
Posted: Fri May 31, 2013 11:07 am
by wegcagle
Nice work Peter. She's a beaut
I gotta say that I don't envy you having to back that beast in and out of there on a trailer
Will
Re: Curacao CS 25
Posted: Fri May 31, 2013 12:02 pm
by tobolamr
Will - If he can build like that, I'm guessing back that in and out on the trailer ain't nothin' for him!
Peter - Bravo, my man! Bravo! BEAUTIFUL!
Re: Curacao CS 25
Posted: Fri May 31, 2013 4:58 pm
by Walkers Run
so nice!!! You should be very proud!
Re: Curacao CS 25
Posted: Sat Jun 01, 2013 1:47 pm
by peter-curacao
Thank you all for the very nice compliments I appreciate it a lot!
But part of those compliments has to go to
Jacques,
(as far as I know the designer of the CS series) boy o boy he gave her IMHO a very sexy sheer line.
antoniekruger wrote:Do you have a final weight estimate?
Antonie no I still don't have that, there wasn't a scale on that crane truck but I hope to weigh her some day, hopefully before the splash
tobolamr wrote:I'm guessing back that in and out on the trailer ain't nothin' for him!
Rofl
I suck big time in driving with a trailer
Re: Curacao CS 25
Posted: Sat Jun 01, 2013 1:50 pm
by HTJ
Absolutely beautiful boat, now hang that Etec and get to fishing !
Re: Curacao CS 25
Posted: Sat Jun 01, 2013 2:05 pm
by peter-curacao
HTJ wrote:Absolutely beautiful boat, now hang that Etec and get to fishing !
I wish!
still have some stuff to do,for instance, painting the sides, some wiring, drilling water pick ups, installing pumps, Ttop has to be made, so I'm close but not that close. I stood on a nail during the lifting, went right trough my flip flop, so a little downtime at the moment, those days flipflops aren't what they are used to be
on the other hand they do have a build in bottle cap opener, so that's kind of a good thing
Re: Curacao CS 25
Posted: Sat Jun 01, 2013 3:48 pm
by HTJ
From what I gather the honorable CL has an approved medication for just such injuries:)
Re: Curacao CS 25
Posted: Sat Jun 01, 2013 4:36 pm
by Larry B
peter-curacao wrote:HTJ wrote:Absolutely beautiful boat, now hang that Etec and get to fishing !
I wish!
Boat looks great Peter
You did a fine job on her
btw, where do you find flip flops that have a built in bottle opener? Man that would be handy for me
Re: Curacao CS 25
Posted: Sat Jun 01, 2013 4:38 pm
While I may be considered a professional in some circles, let me assure you that Peter knows as much as, or more than I do about approved medications. If you even think you might be a reasonable contender, please bring someone else along besides me, and preferably larger than Will, to help carry us all up the stairs
Bring bandages too
Unless you can do about 12-18 beers in the afternoon,then a couple of margaritas, then about 6 Cuba Libres, then a few Mojitos, dang they go down smooth! Then about 6 or 12 oyster shooters
Then switch over to Japanese beer for dinner, with a large bowl of saki on the side, all of this washed down with a bridge full of raw fish, and finish that up with a few specialty shots, and maybe a bottle of wine, then walk down the street and have a few hot buttered rum drinks, and are still good to go, you ain't even in the money
A pickup truck has been known to be needed. People have been known to fall out the truck in Duval Street. it wasn't Peter, he was still upright
Wasn't me either, I was driving
Injury? What injury
In fact, the last time I saw Peter he climbed safely out the back of my truck in Key West
We hugged and kissed and said "hasta luego, mi amigo"
Re: Curacao CS 25
Posted: Sat Jun 01, 2013 7:59 pm
by tobolamr
Cracker Larry wrote:Unless you can do about 12-18 beers in the afternoon,then a couple of margaritas, then about 6 Cuba Libres, then a few Mojitos, dang they go down smooth! Then about 6 or 12 oyster shooters
Okay, it's official, I'm not just thinking I'm a puss - I am 100% a puss! Holy christwagons! Dude, 2 beers or 1 margarita and I'm toast!
Note to self: After "internet reconnaissance" I will not attend a builder's meet as I would be the ONLY non-drinker there.... WOW....
And The Rest of the Story - I have a medication that amplifies alcoholic effect. I'm actually kinda jealous you all can "go have a good time."
Have a few extra for me, please!
Re: Curacao CS 25
Posted: Sun Jun 02, 2013 12:41 am
by whosmatt
Wow. I go away for a little while and look what I've missed. The boat is beautiful, can't wait to see it in the water.
-Matt
Re: Curacao CS 25
Posted: Sun Jun 02, 2013 7:46 am
by stickystuff
You have nothing on the guy that built the boat in his basement.For a carport build this is an amazeing job. Absolutely beautiful. Congrats peter.
Re: Curacao CS 25
Posted: Sun Jun 02, 2013 5:47 pm
by HTJ
"Unless you can do about 12-18 beers in the afternoon,then a couple of margaritas, then about 6 Cuba Libres, then a few Mojitos, dang they go down smooth! Then about 6 or 12 oyster shooters Then switch over to Japanese beer for dinner, with a large bowl of saki on the side, all of this washed down with a bridge full of raw fish, and finish that up with a few specialty shots, and maybe a bottle of wine, then walk down the street and have a few hot buttered rum drinks, and are still good to go, you ain't even in the money A pickup truck has been known to be needed. People have been known to fall out the truck in Duval Street. it wasn't Peter, he was still upright Wasn't me either, I was driving "
hmmm we might just could qualify you for a South Texas visa.......my last good offshore trip last summer my buddy and I drank 46 beers between 10 and 3, and an equivalent amount of water. Fortunately it was only 107 that day so we didn't run out of ice
Re: Curacao CS 25
Posted: Mon Jun 03, 2013 5:46 pm
by peter-curacao
tobolamr wrote:Cracker Larry wrote:Unless you can do about 12-18 beers in the afternoon,then a couple of margaritas, then about 6 Cuba Libres, then a few Mojitos, dang they go down smooth! Then about 6 or 12 oyster shooters
Haha
don't worry Larry exaggerates just a little bit
yes we do like a drink but Larry is putting together I think 3 meetings in one story lol, It did make a good story though, almost pissed my pants
But really you should attend a builders meet they are BIG FUN I had a great time last time and it kind of sucks that I can't make it this time.
Re: Curacao CS 25
Posted: Mon Jun 03, 2013 6:50 pm
by cottontop
Re: Curacao CS 25
Posted: Mon Jun 03, 2013 8:45 pm
by wegcagle
Those memories sure do seem to hurt
. but I'm with Peter on this one...He was light as a feather, easy to carry, and a whole lot smaller than me:lol: Let me know ahead of time before you splash her. I sure would enjoy helping you bloody those decks. Now that I'm done with all this medical training my life just got a little bit better. Don't think we exchanged numbers during the meet, but I could have easily forgotten
Will
1-Seven 0 six-3 four 0-six 5 two 3.
Or shoot me an email
Re: Curacao CS 25
Posted: Mon Jun 03, 2013 9:08 pm
by peter-curacao
wegcagle wrote:.He was light as a feather, easy to carry, and a whole lot smaller ..........
Not sure I understand but you know you are always welcome here Will! no need to call
I think I found her a home!
It's close to the round about and by car not even one minute from my home, I have to check in next Friday with the owner so wish me luck, if you want
Re: Curacao CS 25
Posted: Mon Jun 03, 2013 9:40 pm
by Aripeka Angler
Beautiful
Congratulations on getting her on a trailer
Re: Curacao CS 25
Posted: Mon Jun 03, 2013 10:13 pm
by wegcagle
CL had jokingly said that he wanted a bigger man than me to help us get back to the hotel room next time. I was being sarcastic, and making fun of my 5'8" 165lb frame. For those of you who haven't met him, Peter's well over 6', strong as a horse, and a good person to have around when you are caught in a bad neighborhood
Will
Re: Curacao CS 25
Posted: Mon Jun 03, 2013 10:36 pm
by gstanfield
Looks like a nice home for the boat Peter, good luck working out the details with the owner.
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 8:52 am
by AtTheBrink
That is a beautiful marina! It will make a great home for a beautiful boat.
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 9:23 am
Wishing you luck!
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 11:21 am
by Boater45
Peter, just show the owner some pictures of your boat and explain how your boat will add to the beauty of the marina....you are a shoe in!!
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 1:13 pm
by tobolamr
After I get a boat built, I plan to make a special trip to a "Southern" meet! And, it would be nice to get a "Midwest US" meet going at some point, too.
Marina looks great, Peter! Thanks for letting me know that those were several meets all rolled into one!
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 1:47 pm
Sure
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 4:41 pm
by tobolamr
Gee, thanks, CL!
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 5:33 pm
by peter-curacao
Haha you two cracking me up
After almost finishing a whole boat I'm still learning
, don't use fast hardener to drill/fill/drill holes! the resin will kick in to fast causing fine cracks. Luckily I saw it because of light under the boat, before putting the water pic ups in
Btw do you guys use the 4 screw holes on the strainers or just use 5200 and it tighten with the nut? I'm asking because I see strainers without screw holes also and the less holes below the waterline the happier I am.
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 9:37 pm
Just 5200 and the nut. I'd skip the screws.
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 9:50 pm
by peter-curacao
Cracker Larry wrote:Just 5200 and the nut. I'd skip the screws.
Thanks I was waiting for you my friend
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 10:22 pm
I might be slow, but you know I'm here
Re: Curacao CS 25
Posted: Tue Jun 04, 2013 10:23 pm
Once the 5200 sets you could take off the nut and it would still hold. It's badazz stuff.
Re: Curacao CS 25
Posted: Sun Jun 09, 2013 9:15 pm
by AtTheBrink
Peter, I just looked back to see when started your build. 5 years and one day ago you made your first post! Now you are just a few weeks away from splashing her! Time flies!
Re: Curacao CS 25
Posted: Mon Jun 10, 2013 12:11 pm
by peter-curacao
AtTheBrink wrote:Peter, I just looked back to see when started your build. 5 years and one day ago you made your first post! Now you are just a few weeks away from splashing her! Time flies!
Yeah tell me about it
took me a long time to finish her
Re: Curacao CS 25
Posted: Mon Jun 10, 2013 12:42 pm
by pee wee
Peter, I don't know anyone who could have done what you have done, and done it any quicker . . . and have a life.
Re: Curacao CS 25
Posted: Mon Jun 10, 2013 12:46 pm
by cottontop
Might not want to scratch her when you christen her at the launch. Suggest you use a balloon full of water and drink the liquor.
John
Re: Curacao CS 25
by cottontop
John
Re: Curacao CS 25
Posted: Wed Jun 12, 2013 5:53 pm
by misterfly_nl
Peter,
Did you get a place in the marina?
Evert
Re: Curacao CS 25
Posted: Mon Jul 08, 2013 7:44 pm
by peter-curacao
Hi guys,
No building news here but I thought I check in to give a sign of life
still trying to entertain my family while they here, yesterday we went for an island drive and showed them Boca Table, it's a cave where the sea rolls in, that also gave me a chance to film one of my fishing spots when on top of the cave,for those interested
http://www.youtube.com/watch?v=-Qmm93HI17M
misterfly_nl wrote:Peter,
Evert
Owner said it's mine, went there today to meet him again unfortunately he wasn't there, but I was glad to see the 4 extra places were ready, mine should be the one closest to the camera the moment I zoom in
https://www.youtube.com/watch?v=CCvS2f75pq0
Re: Curacao CS 25
Posted: Tue Jul 09, 2013 6:58 am
Re: Curacao CS 25
Posted: Tue Jul 09, 2013 9:52 am
by pmoody
Peter,
I've been glued to my computer for over a week reading and researching all about boat building. I have read all 199 pages of your thread two times and wanted to tell you thanks for the information you have let us "new guys" in on.
As others have told you your attention to detail and patience over the last years is spectacular! Maybe one day I can build a boat that looks half as good as yours is going to when you get her finished. Thanks again for the inspiration!
Paul
Re: Curacao CS 25
Posted: Wed Jul 17, 2013 5:37 pm
by peter-curacao
Thanks Paul and you're welcome it's a pleasure
Took some time off today playing the tourist guide and did some more work on the bilge area, started to install pumps and stuff.
I hope I didn't shoot myself in the foot with the tuna tubes, because of those I did some things the baitwell pump instructions clearly tells not to do.
Do not allow tubing to sag
well it does sag because otherwise I couldn't get under the tuna tube to connect the hose.
Tubing must enter at top of the tank
well that's a little odd for a tuna tube.
Ah well I will see what happens once on the water.
Still have to connect the wires
Here's some dirty
(sole) porn
Edit:Took a second look at the instructions drawing, I think I'm good with the sagging of the tubes, this because all the sagging occurred below the waterline
Re: Curacao CS 25
Posted: Wed Jul 17, 2013 8:49 pm
Nice looking work, Peter
Re: Curacao CS 25
Posted: Thu Jul 18, 2013 8:18 pm
by peter-curacao
Thanks Larry, connected them today and they are all up and running, wiring is almost done with exception of second main cables set and hardtop stuff
Re: Curacao CS 25
Posted: Fri Jul 19, 2013 12:49 am
by misterfly_nl
Its looking swell like always.
Can't wait to see all that beauty fulI work live.
Evert.
Re: Curacao CS 25
Posted: Fri Jul 19, 2013 5:25 am
by BarraMan
Peter, for the more ignorant (ie me!) can you explain what you have in those hatches?
The two bilge pumps I have sussed, but what is the other stuff - 2 x "no steps", black boxes in the upper hatch!
Great build!
Cheers
Lee
Re: Curacao CS 25
Posted: Fri Jul 19, 2013 6:33 am
by majorgator
Peter, that's some fine looking work...nice and clean.
Based upon what I think I see in the pictures, I would recommend replacing the black plastic hose on the bilge pumps with the same style reinforced hoses you show in the same picture. Reason is that I've seen (and experienced) those cheaper plastic hoses get brittle and crack over time. The more substantial hoses are less likely to do that.
My apologies if I'm not seeing it correctly.
Re: Curacao CS 25
Posted: Fri Jul 19, 2013 9:40 am
by peter-curacao
BarraMan wrote:Peter, for the more ignorant (ie me!) can you explain what you have in those hatches?
Great build!
Cheers
Lee
You are correct 2 x 2000 gph rule bilge pump with 2 level switches, 2x 1100 gph shurflo’s baitsentry (no step) feeding the tuna tubes and live bait well.
Upper hatch 1x marpac wash down pump, 3,5 gpm 40 psi (salt, fresh is under the console) I x Bennet hydraulic unit for trim tabs
majorgator wrote:Peter, that's some fine looking work...nice and clean.
thanks, I leave them for now,if they get brittle I will replace them with other style hoses, maybe due to no mayor temperature changes over here they last longer
Re: Curacao CS 25
Posted: Fri Jul 19, 2013 9:56 am
by majorgator
Understood
I know a lot of people use them and some of the bilge pumps actually include them in the package. But I have certainly seen them fail. You should be alright...I doubt both of them would fail at the same time
Re: Curacao CS 25
Posted: Fri Jul 19, 2013 9:15 pm
by ks8
Re: Curacao CS 25
Posted: Mon Jul 22, 2013 4:08 pm
by peter-curacao
Couldn't resist, had to try
Re: Curacao CS 25
Posted: Mon Jul 22, 2013 4:36 pm
by AtTheBrink
Looks like you just about got her whooped Peter. Looks good. Loos like you have decent pressure with that washdown. Freshwater washdown/shower, thats a great idea!
Re: Curacao CS 25
Posted: Mon Jul 22, 2013 5:43 pm
by peter-curacao
AtTheBrink wrote:Looks like you just about got her whooped Peter. Looks good. Loos like you have decent pressure with that washdown. Freshwater washdown/shower, thats a great idea!
Hi Mike yeah it's okay, spray goes about 2 meters horizontal before it drops down, good enough for a short after swim shower, wash down pump(salt) has a bigger capacity so if everything works okay that has enough punch to wash the blood of the deck during trips.
Re: Curacao CS 25
Posted: Tue Jul 23, 2013 9:58 am
by tech_support
so does mean she has been "splashed" ?
Re: Curacao CS 25
Posted: Tue Jul 23, 2013 5:43 pm
by peter-curacao
shine wrote:so does mean she has been "splashed" ?
LOL I wish
struggling with some last things to finish
Re: Curacao CS 25
Posted: Wed Jul 24, 2013 9:59 am
by gk108
peter-curacao wrote:Couldn't resist, had to try
Glad you did. I am putting a washdown in the cockpit of my rebuild. A little bitty pump was included with my faucet for the cabin sink. I didn't think it was enough of a pump and bought the same pump as you. That picture shows the kind of water flow I am looking for and the little pump didn't do the job when I tested it.
Re: Curacao CS 25
Posted: Wed Jul 24, 2013 10:40 am
by Hope2float
Peter she looks great and I don't think it could have been any better. She will soon splash.
Dave
Re: Curacao CS 25
Posted: Wed Jul 24, 2013 11:13 pm
by Matt Gent
majorgator wrote:I know a lot of people use them and some of the bilge pumps actually include them in the package. But I have certainly seen them fail. You should be alright...I doubt both of them would fail at the same time
Mine failed as well, nearly sunk the boat in the canal right behind the house. Bilge pump became a recirculating pump.
Re: Curacao CS 25
Posted: Fri Jul 26, 2013 7:29 pm
by peter-curacao
gk108 wrote:peter-curacao wrote:Couldn't resist, had to try
The specs of the pump I showed earlier has even a little bit more capacity as the shower pump , so you must be good I think
With my little boat near completion and almost time to spray paint her again it was time to clean the place up, said goodbye to the strongback and a lot of other junk, jeez the amount of junk a person saves while building a boat is amazing, well in my case it is
the boat building junk is under the garden junk
Re: Curacao CS 25
Posted: Fri Jul 26, 2013 7:48 pm
by ks8
just today I've been taking mine apart (to salvage hardware) and off to the dump goes my first wood painting and launching trailer, and the carpeted supports used to haul my cv16 from NY to NC. Somehow I feel lighter...
Happy cleaning to you!
Re: Curacao CS 25
Posted: Sat Jul 27, 2013 10:36 am
by AtTheBrink
I am about to have to do the same thing with my garage. I am gonna need a dumpster...
Re: Curacao CS 25
Posted: Mon Jul 29, 2013 3:34 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon Jul 29, 2013 4:06 pm
by gstanfield
Looking good Peter!
Re: Curacao CS 25
Posted: Mon Jul 29, 2013 4:08 pm
by wegcagle
Looks pretty amazing from here.
I'm not sure you can make up anything else to do to her....except splashing her and bloodying those pretty decks.
Will
Re: Curacao CS 25
Posted: Mon Jul 29, 2013 5:18 pm
Dang Peter, that's tight
Re: Curacao CS 25
Posted: Tue Jul 30, 2013 1:50 am
by misterfly_nl
Peter,
I think youre being tot hard on your self, like every thing I see you make it looks stunning.
Can't wait to see her going.
Re: Curacao CS 25
Posted: Tue Jul 30, 2013 12:22 pm
by antoniekruger
Howzit Peter,
I agree with you - That brings out all the dents and imperfections - a thing of beauty
. Like all good things in life. Good job.
I like the trailer - I would like to see the pic of you hooking her onto your SUV and heading to the launch. Sooooo close.
Re: Curacao CS 25
Posted: Wed Jul 31, 2013 12:15 pm
by Joe H
Peter,
It looks good from here but I know what you mean, the paint seems to bring out the little dents and dings!
Almost ready for the rub rail?
Joe H
Re: Curacao CS 25
Posted: Wed Jul 31, 2013 4:59 pm
by peter-curacao
Thanks guys! but it is as Joe says
it bring out the little dents and dings
but also the big ones
Cracker Larry wrote:Dang Peter, that's tight
Yeah too tight especially now my belly is back again
so I'm hauling her in and out to do this side
Sanded her today and did some cosmetic work on the chine fender,Joe I hope to put the rubrail on somewhere end this week or next week.
Re: Curacao CS 25
Posted: Thu Aug 01, 2013 6:42 pm
by ks8
Re: Curacao CS 25
Posted: Thu Aug 01, 2013 9:37 pm
by peter-curacao
Today I put primer on the cosmetic work I did, after that I decided to put permanent wiring on the console door, now I can open her with a remote control and with a rocker switch between the 2 screens
just fooling around with the remote control while "inside" the house
http://youtu.be/OQSxlGZ7riE
Re: Curacao CS 25
Posted: Sun Aug 04, 2013 2:55 pm
by peter-curacao
Painted the port side today, more or less the same result as the other side, well it is what it is.
Re: Curacao CS 25
Posted: Sun Aug 04, 2013 3:00 pm
by ks8
soooooooo.... close
Re: Curacao CS 25
Posted: Sun Aug 04, 2013 6:53 pm
by wildbill
Look's Beautiful, be careful sliding it back in it's hole
bill
Re: Curacao CS 25
Posted: Mon Aug 05, 2013 5:41 am
by Knottybuoyz
peter-curacao wrote:Today I put primer on the cosmetic work I did, after that I decided to put permanent wiring on the console door, now I can open her with a remote control and with a rocker switch between the 2 screens
Keep playing with it and you'll get hairy palms and go blind!
Re: Curacao CS 25
Posted: Tue Aug 06, 2013 8:05 am
by wegcagle
Great job Peter
As an aside
It must be hell living in paradise like this....I'm definitely a little jealous
Will
Re: Curacao CS 25
Posted: Tue Aug 06, 2013 9:26 pm
by peter-curacao
Thanks Will!, I do my best! please remember the grass is always greener at the other.........................
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 1:46 pm
by cape man
That's what she said.
That's what she also said.
Sorry Peter, Had to.
Been away from the forum for awhile and checking in. The boat is looking absolutely awesome!
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 5:50 pm
by peter-curacao
cape man wrote:Sorry Peter, Had to.
Don't worry about it, I would have been disappointed if you didn't
Rub rail is on, only have to find some stainless for the chine fenders.
This is for now the most acceptable solution for this situation, maybe later I think up something else.
Carved the back of the white rail so that it did fit over the horizontal rail, then I glued the insert to the upper part of the rail.
I used contact cement for this but I'm almost sure this isn't gonna hold, 5200 didn't hold either, anyone some idea's for a good glue?
Bow section: insert went in good but I had to give the lip on the undersides of the white rail some small cuts.
After having done the 2 horizontal rails I found that putting in the insert was very demanding on the joints of my thumb and fingers, so I came up with this, that actually did help getting it in a little more easy
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 6:19 pm
The only thing that holds better than 5200 is epoxy.
Those rail inserts are really a 2 person job, one to stretch it tight while another works it into the slot. Soapy water helps a lot. Too wavy mi amigo, I think I'd pull it out and do it again if possible. ¿Cuál es el otro día?
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 6:28 pm
by peter-curacao
Cracker Larry wrote:The only thing that holds better than 5200 is epoxy.
Larry this rub rail is semi rigid and doesn't stretch
what i still have to do is tap it with a rubber mallet to help it set, but I didn't have one so I have to buy one tommorow
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 6:40 pm
Oh, OK. How did you get this far without a rubber mallet? I use mine almost every day.
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 8:19 pm
by pee wee
Cracker Larry wrote:Oh, OK. How did you get this far without a rubber mallet? I use mine almost every day.
Me too, Larry. My brother refers to them as "French hammers". Not exactly sure what that means, but I don't think it's meant to be complimentary.
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 9:25 pm
by peter-curacao
I used and finished it hitting my own head! while asking questions like WHY!!
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 9:47 pm
by peter-curacao
I'm talking about hard vinyl, epoxy doesn't stand a chance to glue that! it's like gluing plastic foil with epoxy, it doesnt work unfortunately!
Re: Curacao CS 25
Posted: Wed Aug 07, 2013 10:36 pm
by AtTheBrink
Did rough up the joining pieces with something before you tried the 5200? That stuff usually sticks to any thing and everything. I don't know of a better adhesive. Your boat is looking super sharp! Keep it up.
Re: Curacao CS 25
Posted: Thu Aug 08, 2013 5:41 am
by stickystuff
if in cooler weather you need to heat this stuff. I used a heat gun on mine while It was being stretched.The rubber has to be soft for a correct fit. Def. a two person job.
Re: Curacao CS 25
Posted: Thu Aug 08, 2013 7:19 am
by peter-curacao
AtTheBrink wrote:Did rough up the joining pieces with something before you tried the 5200? That stuff usually sticks to any thing and everything. I don't know of a better adhesive
Thanks, I thought the same thing but unfortunately it didn't work.
stickystuff wrote:if in cooler weather you need to heat this stuff. I used a heat gun on mine while It was being stretched.The rubber has to be soft for a correct fit. Def. a two person job.
I'm in the tropics
Ken this isn't flexible rub rail this is semi rigid, installation is different, here you have the instructions for the insert.
Flexible Vinyl Rub Rail Installation
V12-0003, V12-0005, V12-0810
Install inserts beginning either at an end cap or at the transom.
1)Using a heat gun, heat approximately 3’of insert until it compresses with a pinch.
2)Flatten the insert between your fingers and insert it into the rub rail until the heated section has been installed.
3)Repeat in maximum 3’increments until the entire insert has been installed.
Semi-Rigid Vinyl Rub Rail Installation
V12-4144, V12-9809
1These flexible vinyl inserts can be installed at room temperature.
2)Squeeze the insert between your fingers and insert it into the channel of the rub rail until the entire insert has been installed.
3)Tapping it with a rubber mallet will help set the insert
Re: Curacao CS 25
Posted: Thu Aug 08, 2013 4:10 pm
by stickystuff
I know where you live. Just south of BF Egypt.Just some info for some of the northerners.I always used the 5/8 Nylon rope for the insert. don't like the plastic. It has a tendancy to shrink over a period of time. Looking for the splash of yours if you haven't already done so. Awsome job.
Re: Curacao CS 25
Posted: Thu Aug 08, 2013 4:28 pm
by peter-curacao
stickystuff wrote: BF Egypt.
Had to look that up
Bum Fuck Egypt" or "Butt Fuck Egypt" -- in the middle of nowhere -- an extremely isolated, inaccessible and inconvenient location.
We do have an airport you know
Re: Curacao CS 25
Posted: Thu Aug 08, 2013 4:47 pm
by Uncle D
peter-curacao wrote:stickystuff wrote: BF Egypt.
Had to look that up
Maybe a plane too.
I'm cracking up Peter
Re: Curacao CS 25
Posted: Thu Aug 08, 2013 4:58 pm
Common term, BFE. That's where I live too
Re: Curacao CS 25
Posted: Thu Aug 08, 2013 5:08 pm
by Rogerdog
Larry may actually be more remote than Peter!
Re: Curacao CS 25
Posted: Thu Aug 08, 2013 5:41 pm
by gk108
Hmmm... I'm only 12 miles from Cairo. That has to be close to BFE.
Re: Curacao CS 25
Posted: Sun Aug 11, 2013 7:20 pm
by peter-curacao
Can't see it but I actually did a lot for a change
on the main wiring, breaker, switch etc, tomorrow some more from the solenoid to the anchor winch
Re: Curacao CS 25
Posted: Mon Aug 12, 2013 6:30 pm
by AtTheBrink
She is coming together nice Peter
Detail, detail, detail. Those things take time.
Re: Curacao CS 25
Posted: Tue Aug 13, 2013 2:53 pm
by peter-curacao
Re: Curacao CS 25
Posted: Tue Aug 13, 2013 3:57 pm
by Boater45
Nice!! That's awesome Peter!!
Re: Curacao CS 25
Posted: Tue Aug 13, 2013 5:01 pm
by misterfly_nl
I Think I take a bottle of champagne with me in my luggage, so that we can baptise it when we are on Curacao.
Evert
Re: Curacao CS 25
Posted: Tue Aug 13, 2013 5:38 pm
by Dougster
Well, that remote control windless takes the cake. What a cool thing! The first mate anchors with the push of a button. I must not let my wife see that
It's beautiful and inspiring work to follow and see pics of.
Shaking his head Dougster
Re: Curacao CS 25
Posted: Tue Aug 13, 2013 5:50 pm
by AtTheBrink
Love it Peter! Sure makes deep water anchoring a cinch!
Re: Curacao CS 25
Posted: Wed Aug 14, 2013 6:13 pm
by peter-curacao
Sanded one side today first 1500 then 2000 after that I buffed it out, I'm much happier with the paint job now.
You can not see the difference in the pics to much
live the difference is really noticeable, feels much better also.
In the third pic you can see it a bit I think, port side is done starboard side still have to be sanded.
Before
After
Re: Curacao CS 25
Posted: Wed Aug 14, 2013 6:36 pm
Jeez Peter, do you take your gates off the hinges to back it in there
I'd hate to try that after a few cuba libres
That anchor and winch is the real deal. Looking great mi amigo. You don't fool around
Re: Curacao CS 25
Posted: Wed Aug 14, 2013 7:11 pm
by peter-curacao
Thanks Larry, yeah my right arm feels like I'm around 14 years old again LOL
but the irritation about the paint job won it over my laziness, and I'm glad it did! tomorrow the other side, then I really know I did the best I could
Are you still planning coming over this way ? I think it would be great and you know you and Dori are always more then welcome, can't wait to see you two again. either here or over there
Re: Curacao CS 25
Posted: Wed Aug 14, 2013 7:57 pm
by AtTheBrink
You have a happy boat Peter. The anchor looks like a smile!
Re: Curacao CS 25
Posted: Wed Aug 14, 2013 8:10 pm
by wegcagle
Just awesome Peter
you are truly an artist. Now get the dang thing splashed
Will
Re: Curacao CS 25
Posted: Thu Aug 15, 2013 3:17 am
by blueflood
What a great job Peter. What a project and what inspiration, to finally be at that stage is monumental. You are making a few of us very envious right now with splashing being so close
Marc
Re: Curacao CS 25
by blueflood
Marc
Re: Curacao CS 25
Posted: Thu Aug 15, 2013 7:37 am
That's what it's all about. Your best is mighty dang good
Yes, for sure, but not sure exactly when Dori will get some time off this fall.
Re: Curacao CS 25
Posted: Thu Aug 15, 2013 8:11 am
Peter, you had asked about a good plastic glue for the rub rail. I saw this and think it will work..
http://www.jamestowndistributors.com/us ... viewHeader
Re: Curacao CS 25
Posted: Thu Aug 15, 2013 8:14 am
by tcason
What brand primer and paint did you use?
I went back in thread and saw you sprayed but did not see brands.................
Awesome boat!!
Re: Curacao CS 25
Posted: Thu Aug 15, 2013 6:37 pm
by peter-curacao
Thanks all, I need those last kicks under the butt, to move forward
Cracker Larry wrote:Yes, for sure, but not sure exactly when Dori will get some time off this fall.
If you need anything for example advice/thoughts on hotels car rentals and so on please let me know.
Cracker Larry wrote:Peter, you had asked about a good plastic glue for the rub rail. I saw this and think it will work..
Thanks Larry, the contact cement is still holding up, but when it fails I will certainly see if I can find it here, and give it a try.
tcason wrote:What brand primer and paint did you use?
PPG Concept
Starboard also sanded and polished, much better if you ask me
Re: Curacao CS 25
Posted: Thu Aug 15, 2013 10:56 pm
by Aripeka Angler
Peter, your boat is looking awesome man
No, better than awesome. Kickass awesome
Re: Curacao CS 25
Posted: Fri Aug 16, 2013 7:41 pm
by peter-curacao
Aripeka Angler wrote:Peter, your boat is looking awesome man
Thanks Richard for the kind words, wish you and Sandi could come over with Larry and Dori, that would be great fun I think.
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 8:38 am
by ks8
smoooooooooth...
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 10:03 am
by Aripeka Angler
peter-curacao wrote:Aripeka Angler wrote:Peter, your boat is looking awesome man
Peter, is November a good month to visit Curacao?
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 10:52 am
November would probably be good for us too.
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 3:30 pm
by Knottybuoyz
Wait! I see a bump!
Better go back to sanding Peter!
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 3:50 pm
by pee wee
Now that you mention it, I see it too!!! Better keep at it 'til you get it right.
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 4:02 pm
by AtTheBrink
Naw, just leave it Peter. The dimples will make you go faster! Hooked It!
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 5:07 pm
by misterfly_nl
Just two in one a fishingboat on a golfcourse
Evert
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 9:47 pm
by peter-curacao
Knottybuoyz wrote:Wait! I see a bump!
Can you point it out please I don't catch it!
show me and I will take care of it!
Re: Curacao CS 25
Posted: Sat Aug 17, 2013 9:57 pm
by peter-curacao
Yes but December, January, February,March, April,May,June, July,August,September, October are also good months!
As long we are meet again!
Re: Curacao CS 25
Posted: Sun Aug 18, 2013 4:38 pm
by peter-curacao
Two steps forward one step back
Put in the hatches in the bulkhead, had to make some room in the foam for the lock on the middle hatch, so I thought to do it quick with the multi tool, I went a little over the top with this result in the bait well
So tomorrow it's glassing time again
Re: Curacao CS 25
Posted: Sun Aug 18, 2013 7:37 pm
by pee wee
'tis not so deep as a well, nor so wide as a church-door, but 'tis enough, 'twill serve.
Re: Curacao CS 25
Posted: Sun Aug 18, 2013 8:35 pm
It's about time you screwed something up, I was starting to wonder if you were really human
That one is easy to fix
Re: Curacao CS 25
Posted: Tue Sep 17, 2013 3:43 pm
by peter-curacao
Just a short update
I'm getting bored, nothing to do but waiting until my welder has time to start the Ttop, I probably haul her out tomorrow so I can hang the motor while she's in front of the house, otherwise there's no way I'm getting her out of there, my street is just to narrow.Hopefully I can bring her to my welder next week.
Ever got a compliment that made you happy but also didn't made you happy or made you worry at the same time? well today I did, last week I went to the Curacao Ports authority to register my boat, had to put in some paperwork like identification, description and measurements of the boat, some color photo's and a declaration that I build it, the lady at the window was very helpful pointing me in the right direction with all of this.
So when I had all the paperwork in order I went back too CPA and gave it to the same nice lady, I paid the fee and on my receipt there already was the registration number of my boat "NC 335", SWEET!! me very happy
had to come back today to pick up the official registration card, hey didn't mister... call you? the lady asked me, no why is there a problem? well he thinks the boat looks to nice to be a self build boat so he want to give you a visit for inspection
To speed things up here's his number, better call him yourself tomorrow she told me.
After this there's 2 more steps to go, inspection and certification of the VHF and after that inspection of the boat itself.
Wish me luck
Re: Curacao CS 25
Posted: Tue Sep 17, 2013 3:51 pm
You don't need luck, it will pass any inspection
But I'll wish you luck anyway.
Re: Curacao CS 25
Posted: Tue Sep 17, 2013 3:55 pm
by wegcagle
Good luck! At least you have this website and thread to show him the entire build
Will
Re: Curacao CS 25
Posted: Tue Sep 17, 2013 5:12 pm
by Aripeka Angler
Good luck Peter. You are almost there
Re: Curacao CS 25
Posted: Tue Sep 17, 2013 5:16 pm
by Shamrock Kid
GOOD LUCK SEÑOR! But your not going to need luck. Your going to need lots of rags or towels. That's to wipe up all their drull of your decks as they inspect it. I have to keep a rag on my keyboard when I go through the pics of her
, WOW she's a beautiful boat.
Re: Curacao CS 25
Posted: Tue Sep 17, 2013 5:18 pm
by ks8
so close!
as Will said -- just show them this thread.
Re: Curacao CS 25
Posted: Tue Sep 17, 2013 8:01 pm
by Joe H
Good luck Peter, also, I agree it's not needed but there ya go!
Joe H
Re: Curacao CS 25
Posted: Wed Sep 18, 2013 6:40 pm
by misterfly_nl
I will see the awsome boat live on saterday, i think i will be bter than the pictures.
I will take a picture with the builder in front of it.
evert
Re: Curacao CS 25
Posted: Fri Sep 20, 2013 9:17 pm
by peter-curacao
Elvis has left the building!
http://www.youtube.com/watch?v=GH22DfuD ... e=youtu.be
His horses arrived at his stable
Expensive but way cheaper as 300 real horses
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 6:59 am
That's a BIG horse! Must be a Clydesdale
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 8:22 am
by Knottybuoyz
Nice trolling motor!
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 10:43 am
by Larry B
Won't be long now Peter and this will be you smiling
http://www.youtube.com/watch?v=ACcVismTIVU
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 2:42 pm
by ks8
Vrooom!
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 7:04 pm
by peter-curacao
Good news she has power!
Hanging the motor went well, the Evinrude dealer was so nice to loan me a special lifting eye and a drilling template.
Bad news is my shifting and gas cables are a bit to short, not a real surprise I was worrying about that the moment I pulled them in, that's why I saved the boxes.
Already called the dealer luckily there's no problem exchanging them, I have 18 Ft now I think 20 ft will do it.
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 7:09 pm
by misterfly_nl
And Elvis is hanging on the back of the boat.
Peter with his boat that is in live even better than on the pictures.
Evert
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 8:14 pm
by ks8
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 8:26 pm
by Shamrock Kid
The crown jewel on a beautiful boat. Great job!
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 9:00 pm
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 9:36 pm
by peter-curacao
Thank you guys
Hahahaha
that's funny! no way!!! I'm gonna wear the Evinrude apparel, if that is what it is
thank you Larry that means a lot coming from you
(bateau expert)
Hah I see that jig you loaned tried to f.ck you over to? why in hells name the middle holes?? they where on my jig also but why???
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 9:57 pm
by Aripeka Angler
Looking awesome Peter
Is that a Presidente you are holding in the pic? Cheers and congratulations for building a beautiful boat...
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 10:15 pm
I'm not really sure either
Re: Curacao CS 25
Posted: Sat Sep 21, 2013 10:25 pm
by peter-curacao
Aripeka Angler wrote:Looking awesome Peter
Man are you raised or made by hawks? that's a very sharp eye you got there my friend!
Cracker Larry wrote:why in hells name the middle holes?? they where on my jig also but why???
LOL Suckers wants us to fail or what?
Re: Curacao CS 25
Posted: Sun Sep 22, 2013 9:28 am
by gstanfield
It's great to see that big outboard hanging there.
I can't wait to see her on the water
Re: Curacao CS 25
Posted: Sun Sep 22, 2013 12:16 pm
by ks8
The other holes might be for a different engine. One template for two different engines.
Re: Curacao CS 25
Posted: Mon Sep 23, 2013 9:16 am
by tech_support
Re: Curacao CS 25
Posted: Mon Sep 23, 2013 6:42 pm
by wildbill
Your the Man!
lovethepowertorateratio
Re: Curacao CS 25
Posted: Tue Sep 24, 2013 8:51 am
by wegcagle
Awesome Peter! Have you had the second inspection yet?
Will
Re: Curacao CS 25
Posted: Thu Sep 26, 2013 6:30 pm
by peter-curacao
Thanks you all, Will if everything is alright I can pic up my numbers tomorrow, after that she goes to the welder for the T Top and after that I can do the second inspection, VHF and Nav. lights are in the hard top without those no inspection.
Well I cranked her over today and she breathes, coughs, roars, purrs, call it whatever you like
click ->
http://www.youtube.com/watch?v=a6lHse25 ... e=youtu.be <- click
Re: Curacao CS 25
Posted: Thu Sep 26, 2013 6:37 pm
As long as she didn't choke
Re: Curacao CS 25
Posted: Thu Sep 26, 2013 6:45 pm
by peter-curacao
She did
didn't you heard the alarm? no biggie didn't prime the oil enough, she's good to go now.
Re: Curacao CS 25
Posted: Thu Sep 26, 2013 7:24 pm
Re: Curacao CS 25
Posted: Thu Sep 26, 2013 8:26 pm
by gstanfield
Congrats Peter. I like how the engine has a place to attatch the water hose!
Re: Curacao CS 25
Posted: Thu Sep 26, 2013 8:45 pm
by ks8
Getting to work on the break-in?
What is the break-in procedure?
Re: Curacao CS 25
Posted: Thu Sep 26, 2013 10:59 pm
by Larry B
On a E-tec there is no break in
Re: Curacao CS 25
Posted: Thu Sep 26, 2013 11:02 pm
by Mad Dog
Congrats Peter!!! Love the way it purrs.
That's easy... there isn't one. The computer provides extra oil during the first few hours then tappers off to normal by about 20 hrs.
MD
Re: Curacao CS 25
Posted: Fri Sep 27, 2013 9:04 am
by ks8
thank you.
Re: Curacao CS 25
Posted: Fri Sep 27, 2013 3:10 pm
by peter-curacao
ks8 wrote: thank you.
Sorry I was late but the other guys already explained
Re: Curacao CS 25
Posted: Sat Sep 28, 2013 7:18 am
by blueflood
Way to go Peter, to have the motor rigged and running; it must feel great after so much anticipation. What a monster motor that is...yikes
It would eat my 9.9 for breakfast....
Marc
Re: Curacao CS 25
Posted: Sat Sep 28, 2013 10:52 am
by wegcagle
Dang Peter. Somehow I missed the video of the ETEC running. She's got some growl for sure
Not too many more steps now
Will
Re: Curacao CS 25
Posted: Sat Sep 28, 2013 2:57 pm
by TRC886
Great job, Peter
I love the way she looks and sounds
Re: Curacao CS 25
Posted: Sat Sep 28, 2013 6:43 pm
by whosmatt
peter-curacao wrote:Thanks you all, Will if everything is alright I can pic up my numbers tomorrow, after that she goes to the welder for the T Top and after that I can do the second inspection, VHF and Nav. lights are in the hard top without those no inspection.
click ->
Inspection? I thought we had it bad in California! Took my boat to the DMV to get my numbers and they didn't even want to look at it. I tried to get them to, I was damn proud of it!
Can't wait to see her in the water. That motor is a beast.
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 5:59 pm
by peter-curacao
third time's the charm?
Made the tuna tube lids for the third time now, first with smaller tuna's, then I put tube 1 and tube 2 on them what seemed like a nice idea at the time, but later I realized it looked stupid, If I can't get to remember which tube is which I don't belong on a boat but in a Alzheimer clinic
I postponed it as long as possible, but finally they there hopefully this is the last set I made.
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 6:23 pm
I think it's safe to say that those are the nicest tuna tubes ever built here
Sweet work my friend
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 6:50 pm
by ks8
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 7:02 pm
by wegcagle
Great job.
As an aside. If you want to mail me your first and second attempts, they would be more than acceptable on any of my boats
Will
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 7:11 pm
Will, I know I tend to rig out a boat, but I really don't think your GV15 will ever need tuna tubes
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 8:33 pm
by ks8
Cracker Larry wrote:... but I really don't think your GV15 will ever need tuna tubes
What does that have to do with whether or not to add them? They look cool.
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 9:00 pm
Nothin I reckon
I'm sure Peter would send Will the unused tuna tubes and we'll put them in there
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 9:12 pm
by peter-curacao
ks8 wrote:Cracker Larry wrote:... but I really don't think your GV15 will ever need tuna tubes
LOL
Exactly they also hold a 2 liter bottle of rum
never tried staggering them but I think at least 2 or otherwise 3 two liter rum bottles, maybe I have to change her name from Lucky Shot to Rum Runner
Also a idea
when there's no tuna make a two part foam part what fits in the tube, put it in there put the bottle on top of it down in the tube, when you want to offer your guest a drink just turn on your pump, do the same with the other tube but put a bottle of coke in there!
Edit: Will if you really wanna have the lids I sent them over, but I think it's better to wait till the next meet, mention flapper wheels to Larry and he explain
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 9:49 pm
Shipping charges do tend to be a little high between here and there
Re: Curacao CS 25
Posted: Sun Sep 29, 2013 9:58 pm
by ks8
peter-curacao wrote:LOL
Also a idea
Open outer doors, tubes one and two.
Fire one! Fire two!
Now you owe us at least one youtube link of that one!
Re: Curacao CS 25
Posted: Mon Sep 30, 2013 8:31 am
by wegcagle
Hmmmm. I didn't think about using them as a rum dispenser......Now I REALLY want them, but now for my back porch
I can see it now... "Hold your cup here and put on this wet suit. Oh, and here's your umbrella you're gonna need it."
Thanks for the offer Peter, but I was mostly complimenting your skills. It would be a long haul for me to get to the land of tuna so they wouldn't get used enough
Will
Re: Curacao CS 25
Posted: Mon Sep 30, 2013 5:54 pm
by Hope2float
Peter saw the motor run, sounds mean like a race motor ready to go. Good luck now that you are at the end of one road.
Dave
Building complete!
Re: Curacao CS 25
Posted: Tue Oct 01, 2013 3:58 pm
by peter-curacao
Thanks Larry I also thought that was the way to go, but since I always saw them as in your first link I didn't realize there were special anodes for that purpose let alone finding them here on the island, well guess what ....................................?
Found them!
funny when I started this project there was only one decent marine shop over here so I had to do a lot of improvising, now there are 5 including one with good fishing gear
Those Benett anodes are almost double the price of the anodes I had earlier, but a lot less hassle and no drag, so I'm a happy camper
Re: Curacao CS 25
Posted: Tue Oct 01, 2013 7:09 pm
Always happy to make you happy
And I bet you have been keeping them in business. When you finish your build, 4 of them will probably close
Re: Curacao CS 25
Posted: Tue Oct 01, 2013 7:46 pm
by peter-curacao
Hahaha
not true but still it brought a chuckle to my face thanks for that!
Re: Curacao CS 25
Posted: Fri Oct 04, 2013 3:06 pm
by peter-curacao
Brought her to the welder today, she suddenly looks like a little dinghy
Re: Curacao CS 25
Posted: Fri Oct 04, 2013 4:49 pm
by gk108
But
... Yours has better lines.
When you put them side by side like that, it's easy to tell which one came from a mold designer.
Re: Curacao CS 25
Posted: Fri Oct 04, 2013 4:54 pm
Yep, size isn't everything. You've got the better boat and I bet the other one wasn't built by one man under a carport
Is that windmill in the background pumping water or making electricity?
Re: Curacao CS 25
Posted: Fri Oct 04, 2013 7:51 pm
by Southern Gent
Peter, Your Boat takes no Second Seat to any craft around it. You did a Great Build.
Re: Curacao CS 25
Posted: Fri Oct 04, 2013 7:55 pm
by wegcagle
She sure does look pretty out in the open
can't wait to see the t-top
Will
Re: Curacao CS 25
Posted: Fri Oct 04, 2013 11:20 pm
by bigtalljv
Exactly. His boat may be longer but did he build it?? Anybody can just go out and buy a boat but there is no art in that.
Jason
Re: Curacao CS 25
Posted: Sat Oct 05, 2013 11:13 am
by antoniekruger
Peter, I suspect the owner of that beast is trying to compensate for an inferior dingdong. I've seen one like that at one of my local dealers - it had 2x350 yammies on and towed it with a truck. It was awesome, but over the top. That 300 looks good on the boat. I always had a soft spot for Elvis.
Re: Curacao CS 25
Posted: Sat Oct 05, 2013 8:57 pm
by ks8
Re: Curacao CS 25
Posted: Sat Oct 05, 2013 9:02 pm
+2 on the fine print
Edit: KS, why did you edit out your fine print
Re: Curacao CS 25
Posted: Sat Oct 05, 2013 9:07 pm
by ks8
I didn't edit it out. Just my dopey tablet didn't show that a change I made made it microscopic!
Fixing it now on the computer, so I can really tell the size of it.
edit: fixed -- I think
Re: Curacao CS 25
Posted: Sat Oct 05, 2013 9:09 pm
Well fix it
Re: Curacao CS 25
Posted: Sat Oct 05, 2013 9:14 pm
by ks8
Man -- you're quick on the draw tonight
All fixed Captain. Humans should be able to read it again, instead of dust mites.
Re: Curacao CS 25
Posted: Sat Oct 05, 2013 9:28 pm
Fine print is back, I'm happy now
Edit again: Still takes a dust mite to read it
Re: Curacao CS 25
Posted: Mon Oct 07, 2013 9:25 am
by ks8
T-top update Peter?
Re: Curacao CS 25
Posted: Mon Oct 07, 2013 11:51 am
by wadestep
Hey Peter -
It maybe just me, but in that picture your boat looks far aft on the trailer. Do you have enough tongue weight? (enough weight forward on the trailer hitch.) Just checking, don't want any problems with it on the trailer.
The rule of thumb is 10% of the total weight on the tongue, not to exceed the rated capacity of the vehicle/hitch. If you've already thought this through, never mind and she sure is beautiful!
wade
Re: Curacao CS 25
Posted: Mon Oct 07, 2013 12:23 pm
by Joe H
Peter your boat looks great out in the open! Can't wait to see her with the T-tops.
The one's with smaller boats always say that! ha.
Joe h
Re: Curacao CS 25
Posted: Thu Oct 10, 2013 11:04 am
by peter-curacao
Thanks guys, I agree I like the lines of my boat better also
not because I build it just because they are nicer, so two thumbs up for the designer. Just to be clear I don't envy the guy with the Seavee, I think he's an idiot, as I heard from my welder that boat is for the third time there to repair and reinforce the Ttop, just because he drives his boat like a maniac, well I guess easy comes easy goes?
Cracker Larry wrote:Is that windmill in the background pumping water or making electricity?
Larry that's a water windmill, you still see them quite a lot on the island, but most just use electric deepwell pumps
wadestep wrote:Hey Peter - It maybe just me, but in that picture your boat looks far aft on the trailer.
Wade thanks for pointing this out to me, you are right it is a bit aft on the trailer I noticed this directly when putting her on there, first I didn't understand how this was possible because I borrowed this trailer from someone with a 25 feet Dusky but then it truck me, those fabricators include there bracket in the overall length of the boat, so the Dusky is a around 23" without the bracket while mine is 25" without the bracket. Luckily the distances here are very short and we can drive slowly, she has only 2 trips to go, one to my house to connect VHF, nav lights, antennas etc. etc. and the other one to the dock.
Edit:
ks8 wrote:T-top update Peter?
KS hopefully they start tomorrow, my welder had a big job an the sailing yacht from Nelson Piquet, so they didn't had the time yet to do my top. They had to extend the cabin on this boat (picture) to the left and right over the outriggers, housing an extra cabin and bath on one side and a private cinema on the other side
Re: Curacao CS 25
Posted: Thu Oct 10, 2013 11:57 am
Thought so. We still have a few of them in around in my neighborhood pumping water. Looks the same. Some of them have to be 100 years old.
Re: Curacao CS 25
Posted: Fri Oct 11, 2013 6:19 pm
by peter-curacao
KS hopefully they start tomorrow, my welder had a big job an the sailing yacht from Nelson Piquet, so they didn't had the time yet to do my top..........
Well they are still not finished, now it will be probably Tuesday they start my top, ah after all those years it doesn't bother me to much.
Re: Curacao CS 25
Posted: Fri Oct 11, 2013 7:49 pm
by ks8
Re: Curacao CS 25
Posted: Sat Oct 12, 2013 9:51 am
by misterfly_nl
Good things take time.
Re: Curacao CS 25
Posted: Tue Oct 15, 2013 10:15 pm
by peter-curacao
I'm so bored I'm getting crazy waiting!
have to do something!
wait,
found something to do!
Re: Curacao CS 25
Posted: Wed Oct 16, 2013 6:44 am
by danieloldhouse
Re: Curacao CS 25
Posted: Wed Oct 16, 2013 5:10 pm
by misterfly_nl
Re: Curacao CS 25
Posted: Wed Oct 16, 2013 7:13 pm
And some height
Re: Curacao CS 25
Posted: Thu Oct 17, 2013 2:24 am
by danieloldhouse
Re: Curacao CS 25
Posted: Thu Oct 17, 2013 2:45 am
by ks8
so THAT'S what the double yellow line is for!
Re: Curacao CS 25
Posted: Thu Oct 17, 2013 6:06 am
by blueflood
Laughing my ass off
Re: Curacao CS 25
Posted: Thu Oct 17, 2013 6:13 am
by TomTom
Peter, your boat is looking sweet! Might be a race to the finish line... mine is out of the shed and we are fitting the canopy... of course the C19 isn't quite the task that yours is, but I have appreciated your thread and inspiration throughout the last three years... pics on my build thread.
Re: Curacao CS 25
Posted: Sat Oct 19, 2013 2:20 pm
by peter-curacao
Thank you Tom tom, looked up your pics your boat looks great!
Look what came in today
now I can start with the hardtop and radio box.
Re: Curacao CS 25
Posted: Sat Oct 19, 2013 4:26 pm
by ks8
Re: Curacao CS 25
Posted: Sun Oct 27, 2013 1:48 pm
by peter-curacao
Moving slowly forward, decided to go with the lost mold method, time will tell if it works or not.
Foam boards glued together and tied to the frame
First layer Biax
Rounding the corners
Second layer Biax in opposite direction with poor peel ply
sanded for fairing
Now I have to do the under side
Re: Curacao CS 25
Posted: Sun Oct 27, 2013 7:16 pm
by wegcagle
Looks good from here Peter.
Are you going to cut out areas and add plywood/fiberglass so that you can mount antenna, etc? Or does that foam have enough compression rating to hold bolts? I'm sure you've thought about all of that stuff, but I was just curious.
Will
Re: Curacao CS 25
Posted: Sun Oct 27, 2013 8:07 pm
by peter-curacao
wegcagle wrote:Looks good from here Peter.
Will
Hi Will nice to see you're active on your boat again!
must feel good!
No I consider the foam as a lost mold, so you are right I'm making 18 mm ply inserts were needed, hope to get an answer from the sure shade guys (
http://forums.bateau2.com/viewtopic.php?f=6&t=58113) soon so I can take that also in consideration
Re: Curacao CS 25
Posted: Mon Oct 28, 2013 6:29 pm
by peter-curacao
Underside ready for fiber, I think.
Re: Curacao CS 25
Posted: Mon Oct 28, 2013 10:21 pm
by peter-curacao
I'm a bit confused, installation manual of my gps antenna tells me to place it at least 4 meters from a vhf whip antenna! I have a vhf antenna, no clue is it's a whip antenna
if that matters at all! My top isn't that big that I can separate stuff for 4 meters!
Now what? antennas I gonna place are a vhf and a am/fm both are fiberglass build
Re: Curacao CS 25
Posted: Mon Oct 28, 2013 10:37 pm
4 meters is ridiculous, nobody has a top big enough to do that
Well, not many anyway. Mine are about 1.5 meters apart, I know of a lot of boats that have them closer, works fine. Not to worry.
The top is looking great
Re: Curacao CS 25
Posted: Mon Oct 28, 2013 10:43 pm
by peter-curacao
Cracker Larry wrote:4 meters is ridiculous, nobody has a top big enough to do that
Thank you my friend
Re: Curacao CS 25
Posted: Tue Oct 29, 2013 8:22 am
by Doc_Dyer
Peter,
my VHF is on one side of my T-top and the GPS is on the other
works fine.
looking good
Bradley
Re: Curacao CS 25
Posted: Tue Oct 29, 2013 11:21 am
by peter-curacao
Doc_Dyer wrote:Peter,
works fine.
looking good
Bradley
Thank you for confirming Bradley, that layout is how I planned it originally also, but got confused and worried last night reading through the manual.
Re: Curacao CS 25
Posted: Tue Oct 29, 2013 12:47 pm
by flattie
Hard to tell from the photo but is what you are showing location wise where you are going to be mounting the head units (ie: suspended from the t-top just above eye level) or is that where you are mounting the antennaes?
Most/many boats with t-tops tend to mount the antennae's near the edge of the t-top. This makes it easy to raise/lower the antennaes for trailering and any low clearance bridges for example.
A typical set up is the am/fm on port(starboard), with the VHF antennae on starboard(port) with the gps mushroom dead center.
The benefit of mounting near the edge of the t-top is that you can run your cabling through the hollow t-top tubing.
Re: Curacao CS 25
Posted: Tue Oct 29, 2013 12:57 pm
by Doc_Dyer
yea mine are on the outside edge on each side
Re: Curacao CS 25
Posted: Tue Oct 29, 2013 5:32 pm
by Aripeka Angler
I love the top Peter
It is going to be sweet!
If I were you I would mount the GPS sensor and the AM/FM antenna on the extreme outside of the top and the VHF antenna on the other extreme outside of the top. That would leave the middle open for radar (just in case you want to add it later
Re: Curacao CS 25
Posted: Wed Oct 30, 2013 10:51 am
by wadestep
Hey Peter - just wanted to be sure you knew these existed:
http://www.westmarine.com/webapp/wcs/st ... sNum=50192
It's a splitter that uses your VHF antenna to recieve FM radio. Some people like them, some don't. I've had one installed since 2005 on my boat and I have had no problems. It eliminates one antenna. some people say it can create interference, but mine has operated flawlessly.
just FYI.
wade
Re: Curacao CS 25
Posted: Wed Oct 30, 2013 11:29 am
by peter-curacao
wadestep wrote:Hey Peter - just wanted to be sure you knew these existed:
just FYI.
wade
Wade thanks a lot for pointing this out to me, funny a while back I was at the marine store (budget marine) I mostly buy my stuff and asked them if I could use one antenna for VHF and FM/AM, not possible they told me. Guess what? the splitter you pointed out to me is in their 2013 catalog for US$ 91,-
So I'm gonna pay them a visit later
http://www.budgetmarine.com/Catalog/Ele ... oduct.aspx
Again thank you very much
Re: Curacao CS 25
Posted: Wed Oct 30, 2013 1:01 pm
by wadestep
No problem. I've been very happy with mine.
wade
Re: Curacao CS 25
Posted: Thu Oct 31, 2013 7:04 pm
by peter-curacao
Thanks for the comments guys
put in a extra "backing" plate, put the wires in and fibered the underside, which made the top real stiff, what actually amazed me
Probably this works great for a canvas top, but since I'm gonna screw or rived the top to the frame I ain't gonna put wires in the outside tubes!
underside in fairing compound
Re: Curacao CS 25
Posted: Thu Oct 31, 2013 8:12 pm
by pee wee
Peter, I'm curious about those strips/pieces you laid in the underside, four at an angle and one down the center- what are they and what purpose do they serve?
Re: Curacao CS 25
Posted: Thu Oct 31, 2013 8:30 pm
by peter-curacao
pee wee wrote:Peter, I'm curious about those strips/pieces you laid in the underside, four at an angle and one down the center- what are they and what purpose do they serve?
Peewee those are small cable ducts I routed in, if you look closely (or back in the thread) you will see them more clearly
Re: Curacao CS 25
Posted: Sun Nov 03, 2013 12:27 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sun Nov 03, 2013 1:21 pm
by pee wee
very cool!
As usual, you've given it that extra something.
Btw, thanks for the explanation on those channels.
Re: Curacao CS 25
Posted: Sun Nov 03, 2013 5:05 pm
Dang Peter, that's some nice work
Again
Re: Curacao CS 25
Posted: Mon Nov 04, 2013 3:13 pm
by AtTheBrink
You never cease to impress Peter! I just got caught up on you progress, That is on fine boat you built. Impressive, very impressive!
Re: Curacao CS 25
Posted: Mon Nov 04, 2013 8:27 pm
by peter-curacao
Thank you guys
I do my best
Re: Curacao CS 25
Posted: Wed Nov 06, 2013 1:36 am
by glossieblack
The top is looking great Peter. You’ve inspired me to take a similar approach to replacing the fabric awning on my cruising yacht, which finally gave way last week after 8 years of service. It too is over a stainless steel frame, and is approx 2.2 metres square. I’m wondering how you are going attach your ‘fibreglass lid’ to your steel frame. Thanks.
Re: Curacao CS 25
Posted: Wed Nov 06, 2013 3:41 am
by ks8
Will we see a radio in there, or a shiny chromed blower?
Re: Curacao CS 25
Posted: Wed Nov 06, 2013 3:48 pm
by peter-curacao
glossieblack wrote:The top is looking great Peter. I’m wondering how you are going attach your ‘fibreglass lid’ to your steel frame. Thanks.
Thank you
Funny you ask, yesterday my welder was at my house he asked me the same thing, My intention from the beginning was to rivet it to the tubing, he thinks that looks like shit or at least not good
I think maybe he is right, talked with him about gluing it with 5200, he and most of you here think it's crazy strong stuff, so do I, but that roof is gonna pull a lot of forces also, it's 1,40 m x 2,60 m. Other option is screw through the pipe into the flange, not sure what of the 3 options or combinations of those to choose
ks8 wrote:Will we see a radio in there, or a shiny chromed blower?
LOL
if it fits all of the above
Re: Curacao CS 25
Posted: Wed Nov 06, 2013 5:08 pm
by Shamrock Kid
peter-curacao wrote:glossieblack wrote:The top is looking great Peter. I’m wondering how you are going attach your ‘fibreglass lid’ to your steel frame. Thanks.
Thank you
I wouldn't use just 5200, sure it's some crazy strong stuff. But to put all that work into something. Then add all the expensive toys to make it function. To do all that and have it blow off in a 25 mph head wind and sink to Davey Jones locker would make for a really bad day amigo. I would use 5200 in conjunction with some type of mechanical fastener. I don't think pop rivets will do a classy enough job for that boat either. Just my .02 but all in all that's a great looking top to crown a fantastic boat.
Re: Curacao CS 25
Posted: Wed Nov 06, 2013 5:26 pm
I agree with John, not just 5200. Not rivets either. I think I'd through bolt it in about 6 places.
Re: Curacao CS 25
Posted: Wed Nov 06, 2013 7:27 pm
by peter-curacao
Shamrock Kid thanks for your suggestions. I will certainly take them all in consideration
Cracker Larry wrote:I agree with John, not just 5200. Not rivets either. I think I'd through bolt it in about 6 places.
Don't you think stainless flush pop rivets looks nicer as through bolts?
Re: Curacao CS 25
Posted: Wed Nov 06, 2013 8:02 pm
by glossieblack
Thanks for the response Peter. If I’m understanding what you, Cracker Larry and others are discussing, there would be a continuous bead of 5200 between the inside junction of the lid’s top and side and the ss frame, augmented by a number of ss fasteners (either rivet or through bolts) running horizontally through the lid sides and the ss frame. Is this correct?
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 9:12 am
by tech_support
I think I would have some angle brackets welded to the frame so that I could thru-bolt through the top
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 3:05 pm
by peter-curacao
glossieblack wrote:. Is this correct?
Yes it is
Thanks for the suggestions guys how about this? screws from the inside into the flange
(12 mm ply + 2 layers biax with matt backing, outside only) but not trough the flange.
example
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 3:31 pm
by tech_support
Peter, Im sorry i cant remember if that tubing is Aluminum or stainless
If its aluminum, i would try to avoid putting stainless screws/bolts through the tubing.
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 3:38 pm
by peter-curacao
shine wrote:Peter, Im sorry i cant remember if that tubing is Aluminum or stainless
, its aluminum, i would try to avoid putting stainless screws/bolts through the tubing.
No problem, It's aluminum, antennas will be screwed through the roof to those square tubing's you see, what should I use then?
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 4:49 pm
by glossieblack
Thanks Peter.
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 5:08 pm
by misterfly_nl
Peter Why not using blindbolds on the inside.
http://www.youtube.com/watch?v=j3imSL7A3WU
Evert
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 7:00 pm
by glossieblack
Peter, Rivnuts are a combination of blind rivet and nut. Here in Oz the Landrover mob use them to repair their aluminium 4WDs or add Al chequerplate. Could be a solution.
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 8:34 pm
by Steven
That looks nice Peter. You could rivet it from the outside on the centerline of the edge. Then make a decorative strip that goes around the perimeter covering the rivets. Maybe a little bright work, or have your fabricator make something from AL or SS.
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 8:38 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 8:48 pm
by Steven
I figure with your propensity for fancy detail, it will be very nicely done.
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 10:11 pm
by AtTheBrink
Or a decorative aluminum strip first and then rivet thru. The rivets could be an accent.
Just thinking out loud.
Re: Curacao CS 25
Posted: Thu Nov 07, 2013 10:13 pm
by cali123
You could bond the tube to the top with automotive urethane window sealant. GM uses it to bond the SMC body panels to the roll structure. Its nearly impossible to remove when cured. 3-M window weld fast urethane #08609 is great stuff. If you want help with it, call a mobile auto glass installer. They make working with it look easy. There is another bonding material that you could use.It's LORD Fusor # 116 plastic to metal bonding adhesive. That's used on Corvettes to bond the rear bucket to the frame. Either system would make a clean permanent bond.
Re: Curacao CS 25
Posted: Fri Nov 08, 2013 9:43 pm
by AtTheBrink
Peter, any update on you top from your fabricator? looking forward to seeing it on your boat and your boat in the water
Re: Curacao CS 25
Posted: Sat Nov 09, 2013 7:07 pm
by peter-curacao
cali123 thank you! I'm gonna check that out and see if it's available here, I'm guessing NAPA?
AtTheBrink wrote:Peter, any update on you top from your fabricator? looking forward to seeing it on your boat and your boat in the water
He's working on it thanks for asking I appreciate it, from what I saw till now, I think it will be nice, It's different and for sure not everyone is gonna like it, but I think I do! He designed to my instructions, so if you don't like it blame me
I still am working on the roof it's in high build now, not long to finishing paint
Re: Curacao CS 25
Posted: Sat Nov 09, 2013 8:47 pm
by AtTheBrink
peter-curacao wrote:cali123 thank you! I'm gonna check that out and see if it's available here, I'm guessing NAPA?
As long as you like it! I'm looking forward to seeing your concept of a T-Top. If it's anything like the rest of your boat I am sure it will be awesome. You have come up with really cool one-off stuff. That console with the sliding, remote control door! Who even thinks that stuff up! Peter does!
Re: Curacao CS 25
Posted: Sun Nov 10, 2013 10:24 am
by peter-curacao
AtTheBrink wrote: I'm looking forward to seeing your concept of a T-Top.
Well since it's supported front and back it's not really a T-Top anymore think
, it has 4 supports tubes bolted on the center console and 2 bolted on the seat box, nothing is bolted on the sole
Btw the sliding door, I stole that idea
but thanks any way
Re: Curacao CS 25
Posted: Sun Nov 10, 2013 1:35 pm
by AtTheBrink
But does that door have a remote control?
Re: Curacao CS 25
Posted: Sun Nov 10, 2013 4:43 pm
Heck yeah, that door has remote control
What else would you expect
Mine has 4 legs to the sole, and 4 connection points on the console, should we call that an octo-top
Re: Curacao CS 25
Posted: Sun Nov 10, 2013 5:21 pm
by cali123
Peter, the Window Weld Urethane might be available at Napa but not sure about the Fusor products. I'd suggest you check the yellow pages for a body shop supply store. The use of bonding materials has exploded in the last 10 years or so for auto collision repair. Lord Fusor is not the only brand available but it offers a wide range of bonding adhesives and they have worked closely with the auto manufactures and other industries. Check out their website to see what is available. I'd be happy to share a few tips once you decide what material you want to use. The urethane will do the job for about half of the cost . Glossybacks idea of using nutserts is a really clean way to add some mechanical fasteners to the top.
Re: Curacao CS 25
Posted: Tue Nov 12, 2013 2:39 pm
by peter-curacao
Sneak peak
Re: Curacao CS 25
Posted: Tue Nov 12, 2013 3:37 pm
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 7:54 am
by misterfly_nl
full metal jacket I think
But d%#*mm it looks good.
Evert
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 12:24 pm
by AtTheBrink
I had to go back and look thru some pictures of your hard top to get oriented fore and aft. That is going to be a cool top! Connected to the console and the leaning post, right? Very unique design, I like it! Good job Peter.
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 2:55 pm
by peter-curacao
AtTheBrink wrote:I had to go back and look thru some pictures of your hard top to get oriented fore and aft. That is going to be a cool top! Connected to the console and the leaning post, right? Very unique design, I like it! Good job Peter.
Thank you, yeah that's right, in the picture you see the aft legs that go to the leaning post in front of the pic.
Top and radio box painted, I decided to give those also some accent in metallic blue, same as the hose covers and other stuff
Edit: Running lights installed, spreader lights are in back order @ West marine
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 3:37 pm
by ks8
nice. clean.
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 5:07 pm
by Walkers Run
Beautiful Peter!
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 6:26 pm
by Shamrock Kid
Peter, that is a beautiful finish on that picnic table. But looks like you got a little warp to it.
That's a funny looking paper towel holder mounted to the side there.
But it sure is pretty, would make a great top for a boat.
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 6:40 pm
by peter-curacao
Shamrock Kid wrote:That's a funny looking paper towel holder mounted to the side there.
I'm sorry, I have no idea what you are talking about, so I can't give you a reasonable explanation,I don't understand the warp comment either
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 7:22 pm
by justin_dwyer
That is a sweet looking job you have done there Peter, nice work!!!
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 9:00 pm
by Joe H
Man Peter that looks great! Very talented.
Joe H
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 9:41 pm
by Doc_Dyer
peter-curacao wrote:Shamrock Kid wrote:That's a funny looking paper towel holder mounted to the side there.
Edit: didn't get that till explained
Peter I think he's joking saying your top looks like it could also be used for a
BIG picnic table and the warp would let the food run off onto the ground
No worries
What ever it's called it looks killer !
Re: Curacao CS 25
Posted: Wed Nov 13, 2013 10:27 pm
by bigtalljv
Sarcasm or tongue in cheek can be difficult in writing, I get what he was trying to say. With the top laying that way it looks big enough to be a picnic table but it's not flat. The antenna stub would be your paper towel holder. Its big, it's pretty, it's more of your usual work. I think we have used up all the normal superlatives to continue to describe your work. It's amazing as usual
Jason
Re: Curacao CS 25
Posted: Thu Nov 14, 2013 12:51 am
by misterfly_nl
Think that the toiletpaper holder is de stair that is standing ad the left end on the picture.
But no kidding the top is looking beautiful.
Evert
Re: Curacao CS 25
Posted: Thu Nov 14, 2013 8:22 am
by topwater
Nice job on the top Peter
Are you going to put a taller anchor light on on it ? I am pretty sure it has to be
at least 36" above your running lights .
Re: Curacao CS 25
Posted: Thu Nov 14, 2013 8:52 am
by peter-curacao
topwater wrote:Nice job on the top Peter
I couldn't get one at the moment, so I called ports authority, they told me to put this one up and we will see at the inspection if they can accept it. so fingers crossed
Re: Curacao CS 25
Posted: Thu Nov 14, 2013 10:35 am
by HTJ
From my limited internet based observation if Peter were to make a picnic table it would no doubt be from highly figured Circassian Walnut, heavily checkered at 24 lines per inch with elaborate fleur di lis on all the legs and a highly detailed purple heart inlay of a grander blue tail walking across the Caribbean.
The workmanship on that top, like every other nook and cranny on your boat, is superb.
Re: Curacao CS 25
Posted: Thu Nov 14, 2013 10:36 am
by peter-curacao
Jason
Aha! now I get it, sometimes I'm a little slow
thanks Jason
Re: Curacao CS 25
Posted: Thu Nov 14, 2013 12:59 pm
I think you are right
Re: Curacao CS 25
Posted: Thu Nov 14, 2013 1:13 pm
by Shamrock Kid
Sorry Peter, I was being sarcastic, your work is beautiful!
Re: Curacao CS 25
Posted: Thu Nov 14, 2013 6:46 pm
by peter-curacao
Thank you guys I appreciate all the compliments a lot, but again keep in mind in pics things looks much better as in real life.
Re: Curacao CS 25
Posted: Fri Nov 15, 2013 12:31 am
by bigtalljv
peter-curacao wrote:Thank you guys I appreciate all the compliments a lot, but again keep in mind in pics things looks much better as in real life.
Not true, I don't look any better in pictures...
Re: Curacao CS 25
Posted: Fri Nov 15, 2013 12:57 am
by misterfly_nl
Indeed bigtalljv
In real it even looks better.
Evert
Re: Curacao CS 25
Posted: Fri Nov 15, 2013 11:24 am
by HTJ
Re: Curacao CS 25
Posted: Fri Nov 15, 2013 4:19 pm
by misterfly_nl
He assured my that the next time i am on Curacao we will go fishing.
The next time wil be around september 2014
Evert
Re: Curacao CS 25
Posted: Fri Nov 15, 2013 4:32 pm
by peter-curacao
Almost getting her back, probably end of tomorrow ,they are bolting the top on right now, but they forgot the rocket launchers
so those will be weld on tomorrow.
Re: Curacao CS 25
Posted: Fri Nov 15, 2013 4:51 pm
by AtTheBrink
Lookin' good Peter! That top should keep you and your wife dry and sunburn free, and look good doing it!
The blue accents you added to the hard top and the radio box look very sharp. You just used a rattle can spray paint for that right?
So, are you ready to splash her?
Re: Curacao CS 25
Posted: Fri Nov 15, 2013 5:26 pm
by peter-curacao
AtTheBrink wrote: You just used a rattle can spray paint for that right?
No I used a small hvlp gun, same as I'm using in the pic bellow, the blue is Sikkens metallic blue followed by a clear coat.
Still have some small things to do before the splash, but it will be soon, almost sure I will be fishing with the holidays
Edit:I have troubles finding a good graphic designer, they all advice plotting but I don't like that! no depth ts achieved with that.
Re: Curacao CS 25
Posted: Sat Nov 16, 2013 6:28 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Nov 16, 2013 7:06 pm
by AtTheBrink
That is one awesome top you designed Peter. Not really a T-Top, or a K-Top. Not sure what to call it. I like P-Top
Re: Curacao CS 25
Posted: Sat Nov 16, 2013 7:13 pm
by Hope2float
Wow! Looks great.
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 12:05 am
by willg
Amazing! What beautiful work - congratulations!
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 12:19 am
by ks8
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 12:32 am
by glossieblack
Elegant design and execution - congrats.
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 5:22 am
by Aripeka Angler
Beautiful
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 7:40 am
by Walkers Run
Great job Peter! Can' wait to see see her floating.
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 8:05 am
by Shamrock Kid
She looks great, it's hard to believe that it's built by hand.
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 10:03 am
It's a beautiful thing
I sure hope the console is well attached to the sole.
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 11:28 am
by cape man
Awesome Peter. Really sets the whole thing off.
Re: Curacao CS 25
Posted: Sun Nov 17, 2013 1:46 pm
by Steven
Looking good. Did decide how you are going to attach the top?
Re: Curacao CS 25
Posted: Mon Nov 18, 2013 5:26 pm
by peter-curacao
Thanks guys, to be honest I wasn't sure I liked it but it starts to grow on me now, and off course all the compliments helped also
Cracker Larry wrote: I sure hope the console is well attached to the sole.
LoL me to
Steven wrote:Looking good. Did decide how you are going to attach the top?
Steven since I couldn't find the other stuff recommended here I decided to go with 5200, also its bolted to the frame with 8 x 8mm bolts (antenna mounts) and a bunch of screws coated in Tefgel through the frame pipe in the "flange"
Re: Curacao CS 25
Posted: Mon Nov 18, 2013 5:36 pm
Do you have a street light on your top too?
Beautiful work my friend. Fantastic
Re: Curacao CS 25
Posted: Tue Nov 19, 2013 7:47 am
by pee wee
Looks really good. Those G-clamps give it kind of an industrial look, though.
Re: Curacao CS 25
Posted: Tue Nov 19, 2013 8:35 am
by wegcagle
Jeez Peter, I'm gone for a couple of weeks, and come back to a bomb shell of boat porn
The top looks absolutely awesome, but I think you are starting to run out of stuff to do
Will
Re: Curacao CS 25
Posted: Tue Nov 19, 2013 12:19 pm
by HTJ
I am afraid this entire project has come to a grinding and embarassing halt - the galvanizing on the rear trailer wheel is abit darker than the front, and that wrinkled fender - UNACCEPTABLE!
Seriously that is one fine, fine,fine looking rig.
Re: Curacao CS 25
Posted: Thu Nov 21, 2013 5:35 pm
by peter-curacao
Re: Curacao CS 25
Posted: Thu Nov 21, 2013 5:40 pm
No disco ball
Re: Curacao CS 25
Posted: Thu Nov 21, 2013 8:16 pm
by ks8
Re: Curacao CS 25
Posted: Thu Nov 21, 2013 8:41 pm
by Joe H
[img]Cracker Larry wrote:
No disco ball [/img]
Too funny ks8.
Peter whats not to like????? Man that top completes it!
Joe H
Re: Curacao CS 25
Posted: Fri Nov 22, 2013 12:15 pm
by peter-curacao
Came home today found her like this, some idiot backed up his pick up into her
, luckily my neighbor was working in her garden and asked his number before he could drive away without saying anything.
Don't know what to claim this guy
there's not a lot of money involved repairing this I think,
just more time I did not taken into account. pfff
Re: Curacao CS 25
Posted: Fri Nov 22, 2013 12:53 pm
by pee wee
I'm sorry that happened, Peter. I know you can make it good as new, but it seems like you should be paid for your time to repair, it just like if you had to take it somewhere to have it done. What an idiot. Where are the red lens pieces from, his truck?
Re: Curacao CS 25
Posted: Fri Nov 22, 2013 1:42 pm
by Shamrock Kid
I could see backing into a small boat or pwc that was not visible. How did he miss that boat, he must of had one heck of a blind spot. jeez that sucks, add another thing to your "To Do List".
Re: Curacao CS 25
Posted: Fri Nov 22, 2013 2:22 pm
by ks8
She's a tough girl.
Re: Curacao CS 25
Posted: Fri Nov 22, 2013 2:23 pm
by antoniekruger
Hi Peter, that sucks - what an ass. That is annoying. Put a price tag on your time as a claim. Are they building across the road? It might be an idea to move her (Yeah, I know - space at a premium).
The T-top looks great.
If you have to find the upside - luckily it is on the fender and not a ding through the hull itself.
Re: Curacao CS 25
Posted: Fri Nov 22, 2013 3:45 pm
by danieloldhouse
Very sorry for your boat Peter, but the funny thing is that it seems he has had more damages than the boat.
Re: Curacao CS 25
Posted: Fri Nov 22, 2013 6:05 pm
by Doc_Dyer
Re: Curacao CS 25
Posted: Sat Nov 23, 2013 8:20 pm
by wildbill
I drove into a cable trenway in my crew truck last week. 32 years in this line of work; now I'm that guy.
it must be in the air
Sorry Peter
a little sawdust, a little glue, a little paint, good as new.
Re: Curacao CS 25
Posted: Sun Nov 24, 2013 3:16 pm
by peter-curacao
Thanks for the compassion guys, indeed the guy's truck has more damage as my boat, from what I understood his whole side panel is trashed and as you could see on the street his back light is also wasted, he didn't see the boat because he was more busy with a hole the power company dug on the other side of the street.
Anyway since the top and the radio box are on I was finally be able to finish the inside of the center console,tied the cables and wires, put in a "porta potty", it's more like a luxury bucket that flushes
still I think the ladies will appreciate it.
See it in action
https://www.youtube.com/watch?v=nAoAaDIcmnc
Re: Curacao CS 25
Posted: Sun Nov 24, 2013 7:47 pm
by Shamrock Kid
Re: Curacao CS 25
Posted: Tue Nov 26, 2013 9:46 am
by peter-curacao
Transom "art"
Re: Curacao CS 25
Posted: Tue Nov 26, 2013 9:51 am
Re: Curacao CS 25
Posted: Fri Nov 29, 2013 3:47 pm
by peter-curacao
Re: Curacao CS 25
Posted: Fri Nov 29, 2013 5:16 pm
Very nice
I like the name, very suitable. The only thing better might have been Oyster Shooter
Re: Curacao CS 25
Posted: Sat Nov 30, 2013 9:12 am
by topwater
Peter the boat looks awesome , love the name
Can't wait to see the launch pic's and video .
Re: Curacao CS 25
Posted: Sun Dec 01, 2013 6:57 am
by justin_dwyer
Looks bloody awesome, can't wait to see some fish laying on the deck
Re: Curacao CS 25
Posted: Mon Dec 02, 2013 12:56 am
by misterfly_nl
She will be a lucy ship.
Evert
Re: Curacao CS 25
Posted: Mon Dec 02, 2013 9:29 am
by tech_support
super cool
Peter, Do they catch many swordfish in Curacao?
Re: Curacao CS 25
Posted: Tue Dec 03, 2013 10:28 am
by wegcagle
Absolutely awesome Peter
I like the name a lot. Larry says "Oyster Shooter", but I was also thinking "Cuba Libre"
I think you're almost out of excuses....Have you set a splash date yet?
Will
Re: Curacao CS 25
Posted: Tue Dec 03, 2013 10:39 am
by gstanfield
Very nice job Peter, I hope she performs as good as she looks!
Re: Curacao CS 25
Posted: Tue Dec 03, 2013 11:44 am
by peter-curacao
Thanks guys, Joel not to many swordfish over here
Will if everything goes as planned we are gonna make a test drive Thursday afternoon, if everything is okay I will leave her at the dock, only thing is I can't drive her officially so I'm taking a risk getting a fine if caught, I'm still waiting on the bureau of telecom to inspect my radio, if they give me a thumbs up I can ask ports authority to inspect the boat.
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 5:58 pm
by peter-curacao
She floats, and how!
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 6:11 pm
by gk108
43.2? That sounds more like flying!
Congratulations
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 6:19 pm
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 6:40 pm
by dbcrx
peter-curacao wrote:She floats
And that's the only pic we get!
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 7:30 pm
by peter-curacao
She handles far beyond my expectations
she tracks like an arrow without having to fumble with the little fin on the motor.
Although it was a almost mirror like sea I mentioned she handles chop very well, and as long going straight into the chop she and her flair keeps you dry.
As shown in the earlier pic she reached 43 mph wind in the back and about 42 with head winds, still I'm missing a few rpm's because the computer is breaking her in, after 20 hours I think it will be about 45 + mph.
Here's a vid, obvious I didn't take to much attention shooting it
still I hope you guys like it, better pics and vids will follow
https://www.youtube.com/watch?v=WBSmk8SutkE
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 7:55 pm
by tcason
WOW
That is awesome - a clean minimal wake and beatiful looking boat!
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 7:56 pm
by Steven
Awesome!!! I'm watching the video and found myself with a big grin. I can imagine how much smiling you did. Such a gratifying accomplishment.
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 8:04 pm
by garym
That looks fantastic.
Must be a great feeling to have her out for the 1st time.
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 8:16 pm
by justin_dwyer
Great looking boat Peter!!
That is inspiration for us all.
Good work!
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 8:25 pm
by ks8
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 8:45 pm
by wegcagle
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 8:50 pm
by willg
Beautiful! Congratulations. Looked like a dry ride in the chop, too.
Will
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 10:16 pm
by pee wee
Very nice!! Congratulations, and what a nice beginning to your next phase- actually using the boat!
Re: Curacao CS 25
Posted: Thu Dec 05, 2013 10:50 pm
by Aripeka Angler
Beautiful launch
Congratulations my friend
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 1:00 am
by bigtalljv
congratulations! that is quite a boat and accomplishment.
jason
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 2:54 am
by glossieblack
Juicy. Choice. Fanbloodytastic!
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 3:53 am
by misterfly_nl
Congratulations Peter.
I think a lot of use wil miss the great reporting of the build and the solutions you made.
I known se will be a lucky ship.
Evert
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 6:28 am
by Walkers Run
All I can say is WOW!!!! All that hard work pays off. Congratulations!
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 8:35 am
by Joe H
Been a long time coming Brother! Fantastic!
Congrads Peter.
Joe H
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 8:53 am
by Dougster
What an achievement! Thanks for all the time you spent documenting this build, 'cuz it's sure been fun following along. Beautiful boat and beautiful water. Look out fish, Peter, the fisherman, is afloat
Still sittin' on the dock of the bay Dougster
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 8:55 am
I'm wondering what he's going to build next
I know he's got a case of BBV now
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 9:25 am
by tech_support
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 4:37 pm
by gstanfield
Congrats on the launch!!!
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 4:40 pm
by HTJ
I really have no words, that is tremendous. Congratulations
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 8:33 pm
by Hope2float
I have no words as well except yippie wahoo great wow. It has been along time that I have been watching this build. I couldn't be happier for you. I know what it takes to make that happen and I always said your artistic side has met well with your mechanical side. Please keep the videos coming of her on the water. I don't think any of us will grow board of that girl. Well I quess for you I will end FISH-ON!!!
Dave
I must have been sleeping to have missed this
Re: Curacao CS 25
Posted: Fri Dec 06, 2013 10:06 pm
by Larry B
Not much more I can say, WOW, very very nice, Congrats on a fine build.
Re: Curacao CS 25
Posted: Sat Dec 07, 2013 8:31 am
by Bowmovement
Congrats on the launch Peter
Beautiful boat you built, enjoy her
Matt
Re: Curacao CS 25
Posted: Sat Dec 07, 2013 8:54 am
by topwater
Late to the party..... Peter the boat looks great , congrats. I have one question is that a bottle of tums i see on the console
Cant wait for the next vid ..
Re: Curacao CS 25
Posted: Sat Dec 07, 2013 1:22 pm
by bigtalljv
I do believe that Peter should now be posting any updates in the "Finished Boats" section!!
Jason
Re: Curacao CS 25
Posted: Sat Dec 07, 2013 3:57 pm
by danieloldhouse
Beautiful job Peter! Now enjoy it as much as possible!
Re: Curacao CS 25
Posted: Sat Dec 07, 2013 4:01 pm
by Prarie Dog
Great job Peter, she looks fantastic!!
Re: Curacao CS 25
Posted: Sat Dec 07, 2013 5:50 pm
by chicagoross
Congrats, Peter! What a great video! Now the rewards for theyears of work and all of the attention to detail - I'll bet you're spending a lot of time at the ramp explaining your boat!
Re: Curacao CS 25
Posted: Sun Dec 08, 2013 4:05 pm
by designlady
Awesome boat Peter. You should be proud
Now it's time to enjoy her
Willie
Re: Curacao CS 25
Posted: Sun Dec 08, 2013 7:44 pm
by BarraMan
Congratulations Peter! Your build is inspirational.
Re: Curacao CS 25
Posted: Mon Dec 09, 2013 8:04 am
by peter-curacao
Thanks guys for all the congratulations and compliments
Also thanks to all of those who helped me with the problems I encountered and gave me suggestions to successfully finish my build.
Again thanks! great forum, great people.
Re: Curacao CS 25
Posted: Mon Dec 09, 2013 9:11 am
peter-curacao wrote:She handles far beyond my expectations
That is what I wanted to hear! Great job, thanks for the pictures and the detailed building write-up.
Many future builders will read this thread and learn from it.
Re: Curacao CS 25
Posted: Mon Dec 09, 2013 11:34 am
by ks8
Now for the big decision...
What month in the Bateau calendar will feature this beauty?
Re: Curacao CS 25
Posted: Tue Dec 10, 2013 9:36 am
by Rogerdog
Peter:
Your boat looks great. Congratulations!
I am assuming the name and logo are some type of sticker or transfer. What are they made of, and where did you get them? Is there a website?
Thanks,
Re: Curacao CS 25
Posted: Tue Dec 10, 2013 10:04 am
Rogerdog, any good sign shop can do the vinyl graphics but I've used this website a couple of times with great success and service.
http://boatletteringtoyou.com/
Re: Curacao CS 25
Posted: Tue Dec 10, 2013 10:52 am
by peter-curacao
Rogerdog I used a local sign shop as Larry mentioned,I believe the lettering is made of vinyl.
At first I had a problem with the logo because those shops like to plot their lettering for boats, but with plotting apparently you can't get much dept and detail. Finally I found a shop that printed the logo and laminated that for uv and water protection, ones on the boat I had to paint the edges with clear coat also for protection. All lettering is plotted.
Re: Curacao CS 25
Posted: Wed Dec 11, 2013 9:54 am
by wadestep
I love the video. Amazing build, amazing boat.
wade
Re: Curacao CS 25
Posted: Thu Dec 12, 2013 5:39 am
by antoniekruger
Well done. She was quite a journey and turned out a stunner. I'll have a cold one on you tonight. Love the video as well.
Re: Curacao CS 25
Posted: Thu Dec 12, 2013 1:49 pm
by tobolamr
Peter,
Wow! Bravo! Beautiful job! Now you have something extra to celebrate during the Christmas season!
Re: Curacao CS 25
Posted: Thu Dec 12, 2013 2:48 pm
by Doc_Dyer
its about (*&%$n time for another video
Re: Curacao CS 25
Posted: Fri Dec 13, 2013 12:55 pm
by blueflood
Wow Peter, nice job
...I think you have inspired many on this forum and ones looking to build as well. Great for Bateau2.com to have an ambassador.
Marc
Re: Curacao CS 25
Posted: Fri Dec 13, 2013 1:02 pm
by steve292
That's truly beautiful Peter, my hat is off to you
Steve
Re: Curacao CS 25
Posted: Sat Dec 14, 2013 4:15 pm
by ericsil
Dang, your latest gallery shots are enough to make a boat builder drool. That and the fact that you were in shirt sleeves last week while most of us were freezing our hind sides off. Really inspiring build.
Re: Curacao CS 25
Posted: Tue Dec 17, 2013 1:21 pm
by peter-curacao
Doc_Dyer wrote:its about (*&%$n time for another video
I wish I could give you that!
Day 9 now, man this sucks
,but I have to know her better and have more hours on her before I ignore or don't ignore an advice like this
I don't wanna be this
http://www.curacaochronicle.com/local/b ... n-curacao/
CODE ORANGE: SMALL CRAFT ADVISORY
A SMALL CRAFT ADVISORY IS IN EFFECT
DATE ISSUED: TUESDAY, DECEMBER 17, 2013, 12.00 PM
VALID UNTIL FURTHER NOTICE
THIS IS A SMALL CRAFT ADVISORY FOR ALL THE LOCAL WATERS.
Winds: Easterly and moderate to fresh, force 4 to 5 (20 to 39 km/hr, 11 to 21 knots). Occasionally strong, force 6 (40 to 50 km/hr, 22 to 27 knots)
****** SEAS LOCALLY >7 FT ******
EXPECTED IMPACTS:
Coastal waters, bay and inland waters will become somewhat rough
Breakers can damage small crafts if left onshore, close to the water line
PRECAUTIONARY/PREPAREDNESS ACTIONS:
Mariners operating small vessels should avoid navigating in these conditions
Vigilance and caution should be exercised while over the north and east zones
Next bulletin will be issued WEDNESDAY 18 december at 12 P.M.
SPECIAAL BERICHT NO. 9
Well If it takes much longer I can always sitandfish
Re: Curacao CS 25
Posted: Tue Dec 17, 2013 4:15 pm
by Doc_Dyer
that sucks big time
hope the weather straightens up soon
at least you can sit on her in her berth and drink some green rum
Re: Curacao CS 25
Posted: Wed Dec 18, 2013 8:47 am
by ks8
Let's hope that crew member is found soon.
Good to hear Lucky Shot has a wise skipper caring for her. May she gladly return the kindness to you for many years.
Re: Curacao CS 25
Posted: Wed Dec 18, 2013 5:57 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed Dec 18, 2013 6:13 pm
by pee wee
That's funny! And also, your boat must have turned heads. Another compliment to your build as well as Jacques' design.
Re: Curacao CS 25
Posted: Wed Dec 18, 2013 6:25 pm
Get used to it
Re: Curacao CS 25
Posted: Wed Dec 18, 2013 7:58 pm
by peter-curacao
Re: Curacao CS 25
Posted: Sat Dec 28, 2013 8:27 am
by cape man
Don't know when, but I am definitely coming to Curacao someday to see her in person. Wow Peter. Wow.
Re: Curacao CS 25
Posted: Sat Dec 28, 2013 9:55 am
by peter-curacao
cape man wrote:Don't know when, but I am definitely coming to Curacao someday to see her in person. Wow Peter. Wow.
Thank you Craig, you know your more then welcome, your chair is waiting at the pool, but I have to tell you the only thing you're gonna catch there are Cuba libre's
Re: Curacao CS 25
Posted: Sat Dec 28, 2013 10:48 am
by TRC886
Peter, we know that you were not fishing for compliments nor patting yourself on the back
You were impressing the local folks just the same as you've impressed us, the forum members
It's just a "happened so" that your welder was there to overhear it and relay it to you. I'm confident that Lucky Shot has started a whole lot of similar conversations that we are not aware of
I'd love to come see her in person, too
That's beautiful island you live on, as well as a beautiful boat
Re: Curacao CS 25
Posted: Sat Dec 28, 2013 6:27 pm
Fishing for mermaids there
Re: Curacao CS 25
Posted: Sat Jan 11, 2014 7:49 pm
by peter-curacao
Just like to know
IF! how much?
Re: Curacao CS 25
Posted: Mon Jan 13, 2014 2:41 pm
by cape man
MORE than I have!
Re: Curacao CS 25
Posted: Mon Jan 13, 2014 3:40 pm
by BB Sig
I'll take it for a $(US) or your equivalent.
Can you put a price on it? Probably not!
Re: Curacao CS 25
Posted: Mon Jan 13, 2014 5:21 pm
$225,000 USD, at least.
Re: Curacao CS 25
Posted: Mon Jan 13, 2014 6:34 pm
by Shamrock Kid
"One Million Dollars" as Dr. Evil would say.
Re: Curacao CS 25
Posted: Mon Jan 13, 2014 7:55 pm
by peter-curacao
Come on guys
but serious what price tag can I put on her? just curious, I had a discussion with a friend of mine who was comparing her with a Dusky just recently sold here, I thought he was low balling me with the figure he came up with
Re: Curacao CS 25
Posted: Tue Jan 14, 2014 7:23 am
I was being serious
Re: Curacao CS 25
Posted: Tue Jan 14, 2014 8:15 am
by peter-curacao
Cracker Larry wrote:I was being serious
WOW
didn't expect such a big number!
Re: Curacao CS 25
Posted: Tue Jan 14, 2014 8:36 am
by Randy
Less than you have in it.
And WAY LESS than what it is worth to you!!!!!!
Re: Curacao CS 25
Posted: Tue Jan 14, 2014 9:11 am
by gk108
Cracker Larry wrote:$225,000 USD, at least.
Plus delivery charges.
Re: Curacao CS 25
Posted: Tue Jan 14, 2014 11:21 am
by peter-curacao
gk108 wrote:Cracker Larry wrote:$225,000 USD, at least.
For that kind of money I will trow in shipping to Miami for free.
Re: Curacao CS 25
Posted: Tue Jan 14, 2014 3:51 pm
by Marshall Moser
A Sea Hunt 30 Gamefish with no electronics and twin 300's is selling for $140kUS brand new. That is without electronics or a head. With all the goodies you have installed/designed into/customized, I would put you right at or just over the $200k mark as well.
Re: Curacao CS 25
Posted: Wed Jan 15, 2014 9:59 am
by HTJ
Putting a price on a work of art like Peters is tricky, especially when most new 25' center consoles are going for 95k - 130k with twin Yamahas. 80 of 100 potential boat buyers will never have any appreciation for the quality and workmanship, 19 will be hard core off shore guys that cant see beyond big fish boxes and 24 degrees of deadrise. Now find the 1 in 100 guy that can appreciate what he is seeing and you have a potential buyer.
Re: Curacao CS 25
Posted: Wed Jan 15, 2014 10:24 am
by HTJ
Let me amend that, 17 of the 19 are pretend offshore guys that think 24 degrees of deadrise is mandatory because thats how Contender, Yellowfin and Capehorns are built and all of the "cool" guys are running them.
Re: Curacao CS 25
Posted: Wed Jan 15, 2014 3:39 pm
by Boater45
Here is a 2007 25' Contender asking $95k:
http://www.boattrader.com/listing/2007- ... n-99927279
I'm guessing you could get at least that....and probably up to $175k. You have very detailed documentation of your boat build.....but a quarter of a million $$$$??, that might be a little much.
Don't get me wrong...I absolutely love your boat!!
I had my boat appraised and insured it for $21k replacement value(not including electronics or trailer). Maybe you can find someone there that could appraise it for you.
Re: Curacao CS 25
Posted: Thu Jan 16, 2014 7:27 pm
by peter-curacao
Thanks guys for all the answers, I'm not planning on selling just wanted to know what's she's worth, friend of my told me Nafl 90.000,- divide that by 1,8 and you have it in US$, I think it's safe to say he was low balling me
Anyway! backorder from West marine finally came through, so I have a little job for the weekend, boy those little s..kers are potent! don't look directly into them, they blind you for some time
good product at a reasonable price, of course I still don't know how they hold up in sea conditions, but they look like they are well build
Re: Curacao CS 25
Posted: Sun Jan 19, 2014 10:58 am
by Matt Gent
HTJ wrote:Putting a price on a work of art like Peters is tricky, especially when most new 25' center consoles are going for 95k - 130k with twin Yamahas. 80 of 100 potential boat buyers will never have any appreciation for the quality and workmanship, 19 will be hard core off shore guys that cant see beyond big fish boxes and 24 degrees of deadrise. Now find the 1 in 100 guy that can appreciate what he is seeing and you have a potential buyer.
I agree with this sentiment. Its nothing against your work, but the resale market for a home built wood-cored boat in that class is very limited. And the people who would buy that type, will commission it from a SC builder with a name, and a warranty, and a Yamaha (or diesel).
I would venture 60-80% of the new price of an equivalent sized & equipped production boat. Never know, maybe you find that one guy.
http://www.boattrader.com/listing/2013- ... -101902010
http://www.boattrader.com/listing/2014- ... -102143977
Re: Curacao CS 25
Posted: Tue Jan 21, 2014 2:48 pm
by Jerry-rigged
There is a Texas fishing internet forum I frequent with a very active "boat for sale" classified. Home built boats show up on there fairly often (once ever month or two). Seems most of them start the listing with "Custom" and a starting price tag about 125% of a similar mid-level production boat, and ends with the boat getting marked down to well below the same similar production boat...
Sad to say, but for 90% of boat buyers, "homebuilt" and "Wood Core" = Run away...
Re: Curacao CS 25
Posted: Wed Jan 22, 2014 4:22 pm
by peter-curacao
Sometimes it sucks to live on an Caribbean island
kill bag arrived today, nice and durable product as I can judge it for now.
Invoice kill bag
Invoice shipping and handling
Re: Curacao CS 25
Posted: Wed Jan 22, 2014 4:29 pm
Wow! But at least it's warm
Re: Curacao CS 25
Posted: Wed Jan 22, 2014 4:31 pm
by peter-curacao
Cracker Larry wrote:Wow! But at least it's warm
Yeah as if we have a problem with that over here
Re: Curacao CS 25
Posted: Thu Jan 23, 2014 6:42 pm
by peter-curacao
Safe to say I think those 90 % aren't
boaters, just some don't know's with some money to spent?
Re: Curacao CS 25
Posted: Fri Jan 24, 2014 12:32 pm
by Steven
Could someone in the states have shipped you the cold bag as a "gift"?
Re: Curacao CS 25
Posted: Mon Feb 03, 2014 9:19 pm
by peter-curacao
Finally she's fully inspected and legal to take her out to sea
(Bonaire , Aruba, Venezuela and so on!) my Dutch captains papers are also legally accepted now,all happened today, so as Larry would say,
no (more)excuse let's use this baby!!!!
Re: Curacao CS 25
Posted: Tue Feb 04, 2014 12:49 am
by glossieblack
That's great news Peter. What enticing prospects you have! Before the curse of international piracy in the Gulf of Aden dampened my wife's and my sailing circumnavigation dream, the prospect of crusising the West Indies, Cuba, Venezuela etc was an adventure much anticipated. Enjoy!
Re: Curacao CS 25
Posted: Tue Feb 04, 2014 12:57 pm
by wegcagle
Awesome Peter! Congrats.
Now I expect that you will be taking your 2 weeks of paternity leave? That baby is gonna need a lot of attention
Will
Re: Curacao CS 25
Posted: Tue Feb 04, 2014 2:03 pm
by tech_support
time for fun
Re: Curacao CS 25
Posted: Wed Feb 05, 2014 10:41 am
by Knottybuoyz
Don't forget to properly christen her too!
Re: Curacao CS 25
Posted: Thu Feb 06, 2014 9:55 am
by ks8
Re: Curacao CS 25
Posted: Thu Feb 06, 2014 7:44 pm
by cottontop
ongrats Peter. Your now all dressed up and ready to go. Enjoy. You and your family have earned it. John
Re: Curacao CS 25
Posted: Tue Apr 01, 2014 5:22 pm
by peter-curacao
Re: Curacao CS 25
Posted: Wed Apr 02, 2014 8:41 am
by ks8
so.... who's driving the boat?
Re: Curacao CS 25
Posted: Wed Apr 02, 2014 8:48 am
by gk108
Makes me think of the Captain Phillips movie. "Look at me! Look at me! I am the Captain now."
Interesting rig on the sailboat. I wonder what they call it. Double Bermuda rig??
Re: Curacao CS 25
Posted: Wed Apr 02, 2014 8:58 am
by ks8
anyone get video yet, from the shore or another boat, of you buzzing by?
Re: Curacao CS 25
Posted: Wed Apr 02, 2014 9:31 am
by peter-curacao
ks8 wrote:anyone get video yet, from the shore or another boat, of you buzzing by?
Couple months ago I posted a vid, bad quality because it was shoot from a long distance so I had to crop it
Should be somewhere in this thread or in my finished boat thread.
ks8 wrote:so.... who's driving the boat?
You should know Bateau boats drives them self's
Re: Curacao CS 25
Posted: Wed Apr 02, 2014 9:35 am
by peter-curacao
Hahaha good one
gk108 wrote:Interesting rig on the sailboat. I wonder what they call it. Double Bermuda rig??
I have no clue
isn't that info on the website I posted?
Re: Curacao CS 25
Posted: Wed Apr 02, 2014 10:49 am
by gk108
Summit of Simplicity – an Aerorig
A lot of good ideas combined in the Aerorig.
Re: Curacao CS 25
Posted: Wed Apr 02, 2014 12:09 pm
by wegcagle
Dang Peter, you really do live in paradise.
Nice pics.
Will
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 12:41 pm
by peter-curacao
peter-curacao wrote:ks8 wrote:anyone get video yet, from the shore or another boat, of you buzzing by?
here's a new short clip
http://forums.bateau2.com/viewtopic.php ... 11#p344011
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 12:47 pm
by tech_support
nice clip!
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 12:58 pm
Very cool. That boat handles the water nicely
Nice pics.
Will, the only problem with that piece of paradise is the dang wind never quits blowing, and I ain't talking about no light breeze either
It takes a good boat and a strong stomach in the ABCs.
Notice the palm trees in the background of this picture. They are all pointing in the same direction for good reason
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 1:18 pm
by peter-curacao
Cracker Larry wrote: It takes a good boat and a strong stomach in the ABCs.
So very true! luckily god gave me that stomach (cuba libre also helps
)And Jacques gave me that boat!
Yesterday Enrique Iglesias was shooting his new music video on Curaçao (Fuik bay), Rambo is watching, not sure our boats appear in the clip, comparing the body's of those girls to mine and my buddy's probably not!
Well we will see
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 1:24 pm
That sure is one ugly dog. Hard to tell if he is coming or going
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 1:41 pm
by blueflood
Hi Peter...nice spot ! Re your dog...looks like he is having a blast
Marc
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 1:49 pm
by tech_support
Any dog can be a "chick magnet", but bulldogs are more like a tractor beam, women cannot escape.
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 7:56 pm
by gk108
shine wrote:Any dog can be a "chick magnet", but bulldogs are more like a tractor beam, women cannot escape.
So says the guy who went to UGA.
Re: Curacao CS 25
Posted: Mon Apr 07, 2014 7:59 pm
Re: Curacao CS 25
Posted: Tue Apr 08, 2014 9:05 am
by tech_support
Maybe Im a little biased
Re: Curacao CS 25
Posted: Tue Apr 08, 2014 3:54 pm
by ks8
peter-curacao wrote:Yesterday on our way back to port a friend of my was shooting a short clip on his Iphone from a Viking he was riding, sorry for the vertical screen
try to crop it but that again gave a blurry pic
Just switch to full screen for easier watching.
Trimmed the motor a little up to keep it dry inside
https://www.youtube.com/watch?v=9bUpH_11DqI
Nice!
Now can you get another clip like that one, but launch something out of the tuna tubes...
Re: Curacao CS 25
Posted: Tue Apr 08, 2014 5:15 pm
by wegcagle
Woof Woof
Re: Curacao CS 25
Posted: Tue Apr 08, 2014 9:20 pm
by ks8
Re: Curacao CS 25
Posted: Wed Apr 16, 2014 10:08 pm
by peter-curacao
Joel talking about that transfer paper in the longboard topic brought me to an idea.
Sunday we have a small head to head (or boat to boat if you want) competition, me against a 45 ft Viking
this idea started of course @ the bar
The idea I got for the transfer paper is that if me and my crew are gonna loose we must loose in style
, this goes for winning also
so I made this test polo shirt, I think I like it, tomorrow I will buy some new polo's and give them to the crew
Re: Curacao CS 25
Posted: Wed Apr 16, 2014 10:22 pm
Well said
Nice shirts. Send me one
Re: Curacao CS 25
Posted: Thu Apr 17, 2014 9:16 am
by tech_support
I like it
Re: Curacao CS 25
Posted: Thu Apr 17, 2014 9:11 pm
by TRC886
shine wrote:I like it
I do, too
Good luck to you
Re: Curacao CS 25
Posted: Mon Apr 21, 2014 8:11 pm
by peter-curacao
Thanks guys!
Well the polo's didn't help, sea was rough we were soaked from top to bottom, and stepped of the boat like salted herring without any fish catched
luckily we didn't loose because the $$$$ Viking with her $$$$ equipment didn't catch anything either!
only difference was they weren't soaked like us, so from now on I call them salon fisherman
That didn't stop both of us from chilling @ Barbara Beach with some BBQ afterwards though, since I'm still on a diet I had Cevichi and no booze
Re: Curacao CS 25
Posted: Mon May 05, 2014 10:48 am
by antoniekruger
Hi Peter, I love the new profile pic - very sexy. Good shot of Lucky shot. Awesome job, again.
Re: Curacao CS 25
Posted: Mon May 05, 2014 11:27 am
by peter-curacao
antoniekruger wrote:Hi Peter, I love the new profile pic - very sexy. Good shot of Lucky shot. Awesome job, again.
Thank you Antonie appreciate the comment
"full" pic and some more you can find in my finished boat thread over here
http://forums.bateau2.com/viewtopic.php ... 20#p344280
Re: Curacao CS 25
Posted: Tue Nov 11, 2014 3:40 pm
by misterfly_nl
I had the privilege to have a fishing-trip with Peter and the Lucy Shot.
All the hard work has finished in a great boat.
Cleaning the boat.
[/URL]
Hope to take a trip again next year.
Evert
Re: Curacao CS 25
Posted: Thu Nov 13, 2014 4:42 pm
by peter-curacao
Yeah we had a couple of nice trips, unfortunately no fish
still I had a blast!
Remember we salvage that little boat, with broken mast
Here some more of your pics, hope you don't mind me sharing them here
http://s418.photobucket.com/user/peter- ... ot%20tocht
Re: Curacao CS 25
Posted: Thu Nov 13, 2014 4:45 pm
by misterfly_nl
No its fine to share them.
Indeed they where great trips specially the sunset trip with Gloria and Anja.
Re: Curacao CS 25
Posted: Thu Nov 13, 2014 8:11 pm
Please share
Re: Curacao CS 25
Posted: Thu Nov 13, 2014 8:12 pm
by peter-curacao
Cracker Larry wrote:Please share
larry the link is on previous page
Re: Curacao CS 25
Posted: Thu Nov 13, 2014 8:19 pm
I don't see that one in the link
Gloria looks a lot better than you do
Re: Curacao CS 25
Posted: Thu Nov 13, 2014 8:22 pm
by peter-curacao
Cracker Larry wrote: specially the sunset trip with Gloria and Anja.
LOL don't shoot the messenger, I didn't took the pics
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 9:15 am
by peter-curacao
Saw the video of Salvatore and I really liked it,IMHO it's way more pleasant to watch a builders gallery like that.
So he inspired me to do more or less the same, well not as fancy as he did but I did my best hope you guys like it.
I first wanted to put captions in there explaining what's going on, but later I thought they were more a distraction then doing good, also I think it's captioning the obvious, isn't it?
If I'm wrong please don't hesitate to tell me
http://youtu.be/3ENfKOCFf3g
Salvatore thx for this idea I like it
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 9:52 am
Peter, that is fantastic! I need to learn how to do that. What program did you use to put that together?
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 10:19 am
by terrulian
Thanks for putting this video together. Amazing planning, execution, and craftsmanship...not to mention, that stainless steel Bruce probably cost more than my boat.
You and CL and others attempt insane stuff, and pull it off!
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 10:29 am
You just have to be insane like us to pull it off
Like your favorite musician said "if we weren't all crazy we'd all go insane"
Got to be crazy to build boats.
Peter, when you have time could you email me the basic procedure to put something like that together? Not the boat, the slide show
I don't know where to start. Thanks.
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 10:38 am
by terrulian
Ask anyone under the age of 18
I think both iMovie and Windows Movie Maker will do it.
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 10:59 am
by Noles309
Very cool Peter. I may have to try that as well.
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 11:08 am
by blueflood
Your boat looks really sharp Peter
and what a beautiful spot !
Marc
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 1:46 pm
by danieloldhouse
Wow Peter! I love your boat and that video is really impressive, all seems easy there!
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 2:07 pm
by blueflood
There has to be a direct flight from Ottawa
Get Harmony shipped there and stay a while !
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 3:06 pm
by ks8
Good job Peter! Nice slide show and video.
Re: Curacao CS 25
Posted: Sun Nov 30, 2014 5:05 pm
by Walkers Run
Very cool Peter!
Re: Curacao CS 25
Posted: Mon Dec 01, 2014 10:47 am
by tech_support
great video peter, do you mind if we link to it from FB page?
I like the clip of you reading the paper
Re: Curacao CS 25
Posted: Mon Dec 01, 2014 12:03 pm
by peter-curacao
Thx Guys
shine wrote:great video peter, do you mind if we link to it from FB page?
Sure Joel no problem share all you like
terrulian wrote:that stainless steel Bruce probably cost more than my boat.
Not sure what that is?
Edit: Okay I got it's the Anchor
Cracker Larry wrote:Peter, when you have time could you email me the basic procedure to put something like that together?
Larry as terrulian mentioned I used windows movie maker, it's not all that difficult once you get the hang on it, I first made a folder with all the pics in the correct order, then I copy paste them all at once to the open program window.
In the program you can do a bunch of stuff set the times for the pics, at music at more video, at effects, subtitles and so on it's a pretty user friendly drag and drop program and it comes free with windows. If you have any specific questions please let me know
Re: Curacao CS 25
Posted: Wed Feb 10, 2016 8:48 pm
by peter-curacao
misterfly_nl wrote:I had the privilege to have a fishing-trip with Peter and the Lucy Shot.
Cleaning the boat.
[/URL]
Evert
browsing my thread I think I missed those! sorry Evert
great pics my good friend hope to see you and Anja very soon again
Re: Curacao CS 25
Posted: Fri Mar 11, 2016 10:58 am
by TomTom
Hi Peter - your boat looks great. Was just wondering if you had any fuel burn figures for it?
Re: Curacao CS 25
Posted: Thu Mar 17, 2016 9:59 pm
by bwhite829
I've been talking to Jacque on email and he referred me to the forums, I watched your video and I'm torn between a CS25 and a GS28X. At first I wanted a cuddy in a center console, but decided the small "jump cabin" of the GS28x will be plenty. Just want it for overnighters in the bahamas or to get out of the weather sometimes, but looking at this build is making me second guess myself and just settle for a head in the console so that I can have seating in the front.
I was also debating about tuna tubes, but the layout of your livewell/tubes is fantastic. Going to order plans for one or the other this year, and start the build next year. I figure I can amortize the cost of the build over 6 years conservatively and by the time my oldest son is 10 years old take him on a celebratory trip out to blue water(he's 18 mo now, looking forward to being able to build a boat that is 100% for us). Can you ballpark the build cost? I know a comparable production CC is around $50k+ new, I figure if I can build it for half that I would be happy, though I doubt it.
Re: Curacao CS 25
by bwhite829
Re: Curacao CS 25
Posted: Fri Mar 18, 2016 9:28 am
For the cost, take the BOM and get the prices at BoatBuilderCentral.com.
You will not find better prices and don;t take shortcuts with garage floor epoxies relabeled marine to save a couple $.
To start, the first year, you need all the plywood and enough epoxy to coat the ply and do some assembly work: let's say 3 gallons and 1 or 2 rolls of the tape.
Some of the builders use much more epoxy than others, take that in account. As you progress, you"ll get a feel for the resin and you will use less which is better anyway.
One way to save is to buy the epoxy in larger quantities especially if you use Silver Tip resin. Once you get to 6 gallons, there is a nice price break.
One more thing: don't focus too much on the price of plywood or resin. I don't get it when people hesitate about a couple hundred for resin or ply but then put for $ 10,000.00 of electronics on the same boat.
You can always upgrade electronics but you are stuck with the hull. Start with the best quality hull you can afford and delay the purchase of gadgets.
And if you have a trailer and don't mind driving, come and get your supplies here from the warehouse, no shipping.
Re: Curacao CS 25
Posted: Fri Mar 18, 2016 6:31 pm
by Aripeka Angler
bwhite829 wrote: Can you ballpark the build cost? I know a comparable production CC is around $50k+ new, I figure if I can build it for half that I would be happy, though I doubt it.
I would doubt it too
Re: Curacao CS 25
Posted: Fri Mar 18, 2016 7:30 pm
by bwhite829
In talking to my wife I think an XF20 is on the horizon first. I'd like to dive in to a GS28X or CS25 first but I think the time and money spent in buidling a smaller, simpler boat beforehand will go a long way in wasting time/money on such a major project as a GS28/CS25...I've got a 14 ft mod V that I'm rebuilding that has been in the family for 30 years that I grew up fishing on. I'll be rebuilding the hull for that next year, so might just make a trip to the warehouse on one of our trips to disney to get the supplies for that and the XF20, and can give the 14 footer to my cousin after I get my XF20 built.
Re: Curacao CS 25
Posted: Fri Mar 18, 2016 7:49 pm
by bwhite829
Aripeka Angler wrote:bwhite829 wrote: Can you ballpark the build cost? I know a comparable production CC is around $50k+ new, I figure if I can build it for half that I would be happy, though I doubt it.
Yeah, after thinking about it from a more realistic perspective, I realize the cost for engine/electrical systems itself will be close to $30k probably.
Re: Curacao CS 25
Posted: Sat Mar 19, 2016 4:09 am
by BarraMan
For what its worth, I have spared no expense with my build in terms of quality of materials and fittings, although I have tried to buy as well as possible.
My boat is of similar scale to Peters - 22', side console, 250 hp 4 stroke motor, trim tabs, jacking plate, duel axle trailer, trolling motor, electronics etc.
I have about US$37k invested in my hull. All up - hull, motor, trailer and accessories about US$75k. That's converted from Aussie dollars - I suspect you could build it in the US for less than that given that much of the stuff in my boat is imported from the US.
Re: Curacao CS 25
Posted: Sat Mar 19, 2016 8:43 am
by topwater
Wow
I dont think i want to total up my receipts just yet. Ball park figure , motor , trailer ,nav,radio
15,800 US. I'll have to wait till i am done to total the rest of the materials .
Re: Curacao CS 25
Posted: Sun Mar 27, 2016 10:36 am
by peter-curacao
bwhite829 wrote:Can you ballpark the build cost? I know a comparable production CC is around $50k+ new, I figure if I can build it for half that I would be happy, though I doubt it.
Sorry for the late reply and Thx for the compliments, I didn't keep track on the costs I thought it was better that way
It's a 28 foot boat go figure
But as Jacques says start with the BOM, my advice go for the Silvertip, Keep in mind the BOM gives you the basic bare hull, no CC, no benches, no leaning post etc etc. so if you al want that you need more ply and resin, but there are more and other things you can source on forehand, you can ask quotations for the engine (engine dealer or warehouse) steering and controls (for instance West marine online) engine bracket (Armstrong marine) T top (Cracker Larry's friend).
Also keep in mind I had to import everything to this little Island so even if I did had figures they wouldn't apply to you, hopes this helps a bit
TomTom wrote:Hi Peter - your boat looks great. Was just wondering if you had any fuel burn figures for it?
Hi Tom also to you sorry for the late response, no sorry no figures, I fill her up when she's empty
, also I don't think my figures would be accurate for you to base yourself on, I probably burn more fuel because the conditions over here, lots of wind,strong current, lots of waves, video underneath gives you with exception of the clouds an idea about the average conditions here, in the video it looks calmer as it really was, hard to capture.
[youtube]
https://youtu.be/pNcJ32kk7m8[/youtube]
Re: Curacao CS 25
Posted: Tue Mar 29, 2016 3:55 pm
by TomTom
Oh that - we call that a mill pond out here!! Too smooth for water-skiing unless you are a beginner!!
What were you fishing for there?
Re: Curacao CS 25
Posted: Sat Apr 09, 2016 10:09 pm
by peter-curacao
The usual Tuna, Mahi and Wahoo.
Re: Curacao CS 25
Posted: Mon Apr 11, 2016 11:30 am
by cape man
Re: Curacao CS 25
Posted: Mon Apr 11, 2016 11:32 am
by cape man
I also like to reply when asked what I am fishing for...because I can.
Re: Curacao CS 25
Posted: Mon Apr 11, 2016 1:39 pm
by peter-curacao
Re: Curacao CS 25
Posted: Mon Apr 11, 2016 2:46 pm
by cape man
First time I visited the States (Miami) over 25 years ago I visited a restaurant having Dolphin on the Menu I thought what the heck are the serving sea mammals over here? I tried it anyway after some explaining but it was a bit confusing at first LOL
And that is why we too call it Mahi in the stores here.
I gave Richard a real rash accusing him of being a fake native Floridian when he called them Mahi.
Probably more common names for that fish, in more languages, than any other as it circumnavigates the world in warm waters, is a great fighter, is beautiful, and is delicious!
So you never call them Cabishots? According to Fishbase.org that's a common name in Papiementu.
Re: Curacao CS 25
Posted: Mon Apr 11, 2016 2:50 pm
I French it is dorade and I think in Spanish dorado but it depends on the location.
The latin name is Coryphen something . . .
Re: Curacao CS 25
Posted: Mon Apr 11, 2016 3:08 pm
by peter-curacao
No not that I know of we mostly call it Dorado or more commonly Dradu in word and writing.
jacquesmm wrote: I think in Spanish dorado
That's correct it is the Spanish term
Re: Curacao CS 25
Posted: Mon Apr 11, 2016 3:55 pm
by Fonda@kauai
We call the little ones here Cane Knives
Re: Curacao CS 25
Posted: Wed May 17, 2017 10:34 am
by devinfox
Peter, this is an awesome build. Did you stretch the design +3 feet or are you considering the bracket as the extended length? What's your top end with that 300? thanks!
Re: Curacao CS 25
Posted: Sun May 21, 2017 3:05 pm
by danieloldhouse
He didn't stretch the design, the extra length is due to the bracket
Re: Curacao CS 25
Posted: Thu Jul 06, 2017 10:58 pm
by jbarr89
found this link through your youtube video; great looking boat!
while perusing youtube I also came across someone else copying your video as their own:
https://www.youtube.com/watch?v=LukDNuTHIDo
Re: Curacao CS 25
Posted: Mon Jul 10, 2017 9:10 pm
by peter-curacao
Thank you, asked him to remove it from his channel
Re: Curacao CS 25
Posted: Thu Aug 24, 2017 8:35 pm
by peter-curacao
peter-curacao wrote: ↑Mon Jul 10, 2017 9:10 pm
Thanks again it looks like he doesn't give a shit, asked him nicely, bombed answers on questions on "his" movie, he doesn't respond in any way, you tube is asking to much private stuff to ban it, so I think I leave it like it is, again thx for the notification
Re: Curacao CS 25
Posted: Fri Aug 25, 2017 6:23 am
by cape man
Mimicry is the greatest form of flattery.
Re: Curacao CS 25
Posted: Fri Aug 25, 2017 6:54 am
by blueflood
The guy is an a-hole, outright copying and saying it's his own
Burns my butt.
Marc
Re: Curacao CS 25
Posted: Fri Aug 25, 2017 11:13 am
I had never seen that video but yes, it is clearly Peter's boat and video.
I wonder why he posted that. I don't see any of his comments. He probably admire your work Peter but he could have posted a link to your video and made his own video titled something like "This is the boat I am dreaming about".
I added a comment on YouTube confirming that it is your boat and your video.
Re: Curacao CS 25
Posted: Fri Aug 25, 2017 11:40 am
by peter-curacao
Thx Guys
Re: Curacao CS 25
Posted: Sat Aug 26, 2017 8:26 pm
by flyfishingmonk
I would imagine he is doing it simply in the hope of getting add revenue.
Casey
Re: Curacao CS 25
Posted: Sat Aug 26, 2017 10:25 pm
by TomW1
Peter feel for you guy after all the time and effort you put in on her.
Re: Curacao CS 25
Posted: Sun Aug 27, 2017 11:48 am
by danieloldhouse
I also commented on youtube, couldn't resist
Re: Curacao CS 25
Posted: Wed Nov 29, 2017 9:27 am
by PatrickH
peter-curacao wrote: ↑Thu Aug 24, 2017 8:35 pm
Very sorry for that Peter, I also left a message there regarding what he did. Beyond that, super awesome build!
Re: Curacao CS 25
Posted: Wed Nov 29, 2017 10:29 am
by csotelo
Well the video was posted by a Brazilian compatriot...
Judging by the other videos he uploaded, I think it´s a simple person and had no idea of the implications.
I left a comment in portugueses to him.
Regards,
Carlos
Re: Curacao CS 25
Posted: Wed Nov 29, 2017 10:43 am
by peter-curacao
Thanks for the support guys
csotelo wrote: ↑Wed Nov 29, 2017 10:29 am
I think he does because as far as I know it was taken off by Youtube after Mr. Kaiser reported it, now it's back up again, meaning that or he uploaded it again or it wasn't taken off
Re: Curacao CS 25
Posted: Wed Nov 29, 2017 10:54 am
by csotelo
I think it wasn't taken off...
Published on Sep 24, 2016
Sorry for that.
Re: Curacao CS 25
Posted: Wed Nov 29, 2017 11:29 am
by terrulian
Hey, Peter, on another note:
A stainless Bruce? Bruce doesn't make them, do they...(of course Bruce is gone now, but)?
In any case, sweet!
Re: Curacao CS 25
Posted: Fri Mar 16, 2018 2:28 pm
by peter-curacao
Haha how did this thread became a sticky?
Made me find terrulian post though
terrulian wrote: ↑Wed Nov 29, 2017 11:29 am
In any case, sweet!
Not sure I understand
Re: Curacao CS 25
Posted: Wed May 23, 2018 9:58 am
by Nenad
Hello Peter,
I realy love your boat, and video that you put on youtube, boat looks like a milion dollars
Really great stuff.
Do you know weight of the boat without engine, and by your opinion, woud 150hp 4stroke be enough power for that kond of boat?
Re: Curacao CS 25
Posted: Tue May 29, 2018 12:16 pm
by peter-curacao
Sorry I never weight the boat but I know it's light very light for it's size but that's common for all the boats you find here
On the engine it depends what you want, it will push the boat forward but personally I would follow the specs
Re: Curacao CS 25
Posted: Sun Jun 03, 2018 3:11 pm
by Nenad
Thanks Peter,
I am really amazed with your built, and how boat end up.
All your story of building it, giving me push to do same thing myself.
Re: Curacao CS 25
Posted: Thu Oct 18, 2018 11:36 am
by terrulian
Weird, I just found this:
terrulian wrote: ↑Wed Nov 29, 2017 9:29 am
In any case, sweet!
Didn't I see a picture of your boat with a stainless steel Bruce anchor? Bruce is no longer in business and don't think they ever made a stainless anchor. I think Lewmar makes a knock-off.
