BassMunn's PH16 - SPLASHED!!!!
- stickystuff
Kind of weird. Certain water conditions make the hull act in diff. ways. In small choppy conditions the hull gets on top and runs out fairly smooth. Then at other times depending on which direction you are running into the wind or behind it the hull has a tendancy to get just a little squirrely. Only in the stern area. You can feel it. Other tnan that it runs out great. My pad is not a raised pad. All I did was come off each side from center approx 4" ea. wayCut 1x3 clear fir from 3/4 to 0 on edge. This worked out that the side edges were the same hight as the keel. .So no draft was affected depth wise.
Capt. Ken Owens
- stickystuff
I'm tryingAripeka Angler wrote:Great progress Your going to be done before I finish typing this Glass the entire hull on the outside...
Richard
I thought so, after working 12 hours flat out one tends to try find short cuts . When I wake up tomorrow I probably won't even consider not doing it.
What size overlap do I need for the cloth on the side - 2"?
- stickystuff
Users browsing this forum: Ahrefs [Bot] and 12 guests
