BassMunn's PH16 - SPLASHED!!!!
- stickystuff
Shame Ken you don't have to send me your printed photos, but if you want to send to:
Umm could you rather send me a mail so that I can get your email address, I don't really want to post all my details on the net. I would send you a pm but it seems that my messaging service on here doesn't work (I don't think my account has ever been activated properly)(did you get the pm I sent earlier?)
Thanks
Thanks
Thanks Chalk. No I cut the parts as per the plans. I've obviously got the odd slight cutting error here and there, but so far I haven't found anything that a slight sanding can't sort out.Chalk wrote:Nice looking build - did you add some to the sheer? On my Ph16 there was only enough room for two - three wire ties at the bow. Looks good
I did have my cable ties very close together on the bow, I tried 3 at first, but they snapped twice so I put more in, the holes were about 1 1/2" apart.
Chalk, I've just checked everything out and my measurements are correct.
But there definately seems to be a plan change somewhere along the line.
If I look at the PH16's built by Doug Skogman, Casey Jones and your picture and John Pelligrino's PH18, they all have the smaller (more tapered) hull side points.
But if I look at mine and Gordons (Not sure his surname) they have the larger less tapered points. Here is the link to Gordons build site. You can clearly see there is a difference. http://desertphantom.blogspot.com/
The latter seems to be the newer plan
Do you have a build log by the way, I like to see each builders work to see if i can pick up some new ideas.
Thanks
Thanks
