Panga 22 Curacao
- Fonda@kauai
- peter-curacao
- peter-curacao
Just take an air compressor blow a string trough it with a little piece of foam attached to it, then pull the wiring with the string trough the pipes no headache at allFonda@kauai wrote:Just a suggestion, but I would run the electrical through that 2" before you glue down the sole. Those short turn 90's might give you a headache
I ran my electric through 1.5" with short elbows no problem. It got a little crowded but everything went through in the end. I used a shop vac to suck a piece of wadded up paper tied to a piece of 100lb braided line, and then pulled everything individually (tie another piece of line to the wire you are pulling). Wished I had used 2" so I'm sure you will be fine.
Boat is looking great. Was my other choice when I was looking but it's too much for the 40hp motor I own. You and Peter are going to have to go fishing together!
That is probably 52 mm radius, 10 cm diameter.
I agree that large scuppers as safer.
Re: Panga 22 Curacao
here are some photos where im at right now:
started with primer on the inside:
trying out hardware on the console:
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 8 guests
