OB15 coming together in Central Texas
Posted: Fri Oct 09, 2009 9:30 pm
I have been working on this OB15 for about 6 months now and am just finishing her up. This is another OB15 in the style of a flats skiff. The bottom is painted with the epoxy and graphite mix outlined in this forum (about 40% by volume). This extends to just above the chin and from the chine to the sheer it is painted using Sterling's Ice Blue. The decks and cockpit are painted using System Three Orcas White and the non-skid in the cockpit will be done using the non skid additive sold here mixed with System Three paint. Kiwigrip in light blue will be used for the upper decks.
Currently, I am working on finishing paint, non skid and rigging but I do not have any recent pictures that reflect this yet (I don't like to take pictures with it all taped up for painting). Here are some of the pictures of the build and if you want to follow the link at the bottom, you will find more pictures of the build.
Here she is on the molds just after I taped in all of the seams.
Applying primer to the bottom in preparation for the epoxy/graphite application
My three year old boy decides he needs to leave his mark on the boat too
He decided that one hand print was not enough
Got her flipped and in the cradle. The bottom looks pretty good and is finished at this point.
Had to find enough weight to hold the stringers flat against the hull while they dried
Glassing the vertical stringers in as I raised the sole to the level of the inside chine
I should have taken more pictures of applying the sole and pouring the foam under. This is the finished product.
This is a good shot at the shear curve of the bow. I trimmed it down due to my plan to apply decks level with the shear.
I missed a lot of photo ops before this stage also. At this point, all of the decks are installed and glassed
Here is a good shot of her in the light. I washing with soap and water preparing to apply primer
The outside is now painted with Sterling Ice Blue. That stuff is awesome
Now only the sides of the cockpit lack paint and I have the rubrail, hawse pipes, rod holders and hatches installed. I will get more pictures and post them another day. Enjoy the boat porn and here is the link to more pictures I promised.
http://picasaweb.google.com/atxsyndicat ... directlink
I built her to take a tiller motor as I think a full size console just gets in the way. I have included a very small box to put the electronics in and to connect a grab bar like Shine did on his FS17. Also, if any of you are in Texas, I am looking for a good 1995 - 2005 40 hp two stroke motor for my OB15. In texas, it is pretty hard to find good tiller model engines of this size. If I have to I will purchase a tiller kit and add it to the right motor. Please let me know if you have any tips on where I could find one. I don't really want to spend the 6000 on the new etec 30 or 5500 on a new yamaha 4stroke 40.
-Adam
-Adam
