Joe's P19 RE-LAUNCH
Posted: Tue Oct 20, 2009 7:33 pm
by Joe H
Hi All,
I have been kinda working on the P19 for a few weeks now as seen in some other post but with the weather being off and on here in Michigan so has my boat building and fishing but here's where I am to date.
I started with drawing everything up in CAD for the build of the hull so we could CNC the wood, it's has been a learning experience if anything, we cut the transom, clamping boards and bottom so far and they turned out perfect but I have decided, after we are done with the sides, that's all that will be cut on the CNC machine for now, between having to haul the wood an hour away from my house to the CNC shop, cutting a few pieces of wood and then re-loading the wood and driving back home it's just too much hassle, besides that it's taking some of the personal aspect of cutting it myself away, sounds weird but I like that one on one with cutting the wood myself, not to mention the CNC cutting was painfully slow because we only had cutters made for cutting steel. I should also mention here that my daughter's boyfriend really knows his stuff and when he gets his own CNC machine set-up with a 4 X 8 table and a wood cutting cutter we will be able to fly through the next phase or boat we decide to do.
I finally got the frame together and all aligned after some challenging moments and thoughts of what did I get myself into but all is good now, well almost,
I don't know if you can see it but at the front of the outside stringer the bottom of the frame does not line up with the bottom of the stringer???
I'm not sure where I went wrong but I'll crunch some #'s tonight and see what I come up with.
Next I will lay the CNC cut panels on the frames and see how she lines up.
Joe H
Re: Joe's P19
Posted: Tue Oct 20, 2009 7:54 pm
by michaelwpayton
Looking good Joe... thanks for posting the pics.
-Mike
Re: Joe's P19
Posted: Tue Oct 20, 2009 8:43 pm
by Bowmovement
Very Nice! I look forward to following a P19 build...
Matt
Re: Joe's P19
Posted: Tue Oct 20, 2009 10:07 pm
Great start Joe 8) That's some serious looking machinery 8O
Re: Joe's P19
Posted: Tue Oct 20, 2009 11:49 pm
by gk108
Even when you have the right cutting tool, speed is limited because of heat. You can run a stream of coolant on metal, but slowing down is about the only way to keep rotary wood cutting tools cool. 8)
Re: Joe's P19
Posted: Wed Oct 21, 2009 1:45 am
by TomW
Agree with Gary you have to slow down with a CNC wood cutter to make it work well. Instead of 20,000 rpms your down to 8-9000 rpms. To slow you'll be leaving burned marks. A metal cutter can be a lot slower depending on the thickness of what it is cutting.
Re: Joe's P19
Posted: Wed Oct 21, 2009 8:55 am
by Murry
Lools great Joe, and I'm looking forward to seeing it come together.
What happen to that professional crew you had. :lol:
Re: Joe's P19
Posted: Wed Oct 21, 2009 9:39 am
by mecreature
Looks great.. That is one huge boat.
I like the shot from the transom you can see to bottom already.
Re: Joe's P19
Posted: Wed Oct 21, 2009 9:48 am
by tech_support
fantastic machine :!: For those rough cut flute bits you need to run slow enough RPMs to allow the chips to get clear. There are various calculators for RPM and cutting speed, but we have found that the wood speci (density) also is a significant variable.
Re: Joe's P19
Posted: Wed Oct 21, 2009 7:55 pm
by Joe H
The CNC machine is pretty much retired from any actual production work so they didn't mind us setting up a jig for cutting plywood, how would you like to have one of those in your garage! you guys are right on about slowing the RPM's down and the travel speed, we used a 1/4 dia cutting bit usually used for cutting steel, one of the workers there said it was one of the best cutters you could buy, I'm not sure what kind of special cutter it was but the tip was gold in color, Tom your close we slowed it down to 10,000 rpm's for the best results and no splinters.
Hey Murray, I had to let my crew go they were fun to have around for awhile but they were smoking all my cigarettes and drinking all my booze!
I hope to get the bottom and side panels spliced together this weekend and try a dry fit but only if the weather sucks, I still might have a couple of weekends before I have to pull the OD16 out of the water and perch fishing is great this time of year, that is as long as the duck hunters don't take my head off!
Joe H
Re: Joe's P19
Posted: Mon Oct 26, 2009 6:58 pm
by Joe H
Got a little work done this weekend on the P19, finished cutting the side panels on the CNC machine, I was way off on the rpm's, we were turning 2500rpms @ a feed rate 10" every 2 ½ minutes in order not to splinter the plywood.
I splice the bottom panels together and temporarily place them on the frame, more or less just to get them out of the way so I could splice the sides together, I was able to do the lower sides but it looked like the weather was turning nice and I think my OD16 was getting a little jealous of all the time I was spending in the garage with another boat so I went out fishing.
BTW: I made what I hope is a small mistake when splicing the lower sides together but if no one can see it from the pictures I think I'll just let it go and deal with it later.
Kind regards
Joe H
Re: Joe's P19
Posted: Mon Oct 26, 2009 7:24 pm
That sure is a pretty OD16 8)
Big boats looking good, just fix it and move on :wink: Is it just the camera lense, or does the rear portion of the bottom have a hook along the keel?
Re: Joe's P19
Posted: Mon Oct 26, 2009 7:35 pm
by Aripeka Angler
Joe, glad to see that you are boat building and fishing :) Is that a thunderstorm I see behind your OD in the pic :doh:
Good luck on your boat and say hi to Janet from Sandi and I. Hope to see you in Boca Grande next year....
Richard
Re: Joe's P19
Posted: Mon Oct 26, 2009 8:03 pm
by ericsil
I can't tell dimensions very well from the pictures, but it looks like the sum of the two side panels just adds up to the length of the bulkhead sides. The upper side panel is supposed to overlap the bottom panel by a several inches. If the former is true you are working with an earlier set of drawings that had the dimensional mistake. I hope for your sake I am just imagining this. (You can see the whole story by starting with my post of March 10, 2007 on the P19 side panels and following the discussion until the panel drawings were changed in late March.) Otherwise, go for it. The next few weeks are very rewarding.
As for possible hook in the hull, just shim on top of the stringers until everything is dead flat before you get serious about taping the joints.
Re: Joe's P19
Posted: Mon Oct 26, 2009 9:00 pm
by Joe H
Wow, Eric I read your post and had to go out and measure right away, I'm good with 6" of overlap.
I just put the fiberglass splice on the wrong side, I had it all laid out on the floor and was reading the building notes and they said to put the splice on the outside of the lower and upper sides so I hurried and flip them over and put on the splice, sat down in my thinking chair and noticed I put them on the wrong side, ha, too late.
Good eye Larry, I have to adjust the stringers under the bottom ply yet but it's not nearly as bad as the picture show's it.
I love that OD16, Richard we were heading out to do some night fishing in the river for walleye, it was great weather all day until we got to our destination and that storm came out of nowhere, we pulled up to someones island to find shelter and drink a couple of beers until the storm blew over, never did get to fish, but that's okay we had a blast driving home in 3 to 4 footers and a good reminder of why I'm building the P19, we got our butts kicked but the OD16 held up just fine.
Man, I really want to go to Boca Grande but just don't know yet, soon. Tell Sandi we said hello.
Joe H
Re: Joe's P19
Posted: Mon Oct 26, 2009 11:15 pm
by Murry
Your OD is pretty Joe. :D
I can't wait to see your P19.
Re: Joe's P19
Posted: Tue Oct 27, 2009 8:27 am
by ericsil
Sorry for the false alarm. That extra hull work is forever burned into my memory.
Re: Joe's P19
Posted: Tue Oct 27, 2009 5:48 pm
by ericsil
I didn't quite understand your comments on the splices. Just make sure that the fiberglass splices near the bow include the outside of the panels. Those pieces are under a lot of stress due to the hull shape. You will not get a fair curve if the panel does not have a lot of strength at the splice. It is fun watching another P19 come together. You will be the first to post pictures of a hull the way Jacques designed it.
Re: Joe's P19
Posted: Tue Oct 27, 2009 7:05 pm
by TomW
Joe isn't that typical midwest/Great Lakes weather. :cry: I have never been out on the lakes when it hasn't changed for either the worst or the better. :lol: :x
Re: Joe's P19
Posted: Tue Oct 27, 2009 8:25 pm
by Joe H
Eric, I put the fiberglass splice on the inside of the lower panel, it was supposed to go on the outside, I don't think it will be a big deal? I'm glad you are watching my build, I'll try and document it as a go along and I'll have a lot more questions.
Thanks Murray, I really like the OD16 but I don't know how to slow down in a chop and end up really hurting after a day out on the water and as Tom pointed out the weather seems to catch me off guard way to often, the bay I live on is called choppy Anchor Bay for a reason, I need a "V" bottom!
Joe H
Re: Joe's P19
Posted: Tue Oct 27, 2009 9:39 pm
by Dougster
Nina requires the fiberglass splice on both sides. I'd think you'd for sure need it at least on the outside or you'd risk breaking the splice when bending it around the frames with no glass on the outside of the bend. Mine seemed pretty flimsy till I flipped it and did the other side. After both sides were done it was plenty strong. EricS will know better than I do though.
Says it's lookin' good Dougster
Re: Joe's P19
Posted: Wed Oct 28, 2009 9:58 am
by ericsil
Joe,
The reason for avoiding tape on the outside is so the top panel will lie nice and tight when it overlaps the bottom panel. This may work on the HM19, but it is a big mistake here. The curve is so hard at the position of that splice that it is impossible to hold it fair when you lace the hull. I know, that's how I did it. A bucket of fairing compound later I can still see a little break in the hull shape when the light is right. The best approach is probably to put tape on the outside below the overlap of the upper panel. This will give you the strength to make the bend and still let the top panel lie firmly against the lower.
Good luck.
Re: Joe's P19
Posted: Wed Oct 28, 2009 12:00 pm
by D2Maine
nm
Re: Joe's P19
Posted: Wed Oct 28, 2009 12:07 pm
by Joe H
Got-it, sounds like a plan, I already taped the inside, and I'll go back and tape the outside avoiding the 6" overlap, I also mixed a little wood flour and resin and put it between the joints before I taped it, most of it probably squeezed out but it makes me feel better.
I also got the upper side panels spliced together last night.
Thanks a ton!
Joe H
Re: Joe's P19
Posted: Wed Oct 28, 2009 12:13 pm
by Joe H
D2Maine,
I didn't see your post until after I posted. What do you guys think, any advantage to what D2 is saying?
It's after 12:00, I gotta get back to work!
Joe H
Re: Joe's P19
Posted: Wed Oct 28, 2009 3:09 pm
by wegcagle
I think it would work either way. I have the plans for the C21, and Jacques says that the outer (top panel) you add a full fiberglass splice to the outside and a fiberglass splice to the point of the overlap on the inside. Vice versa on the innter (bottom panel). Full length inner splice and a splice that stops at the area of overlap on the outer face of the ply. My personal feeling is that if the designer says that this is good enough then it's probably good enough :D
Will
Re: Joe's P19
Posted: Wed Oct 28, 2009 4:24 pm
by ericsil
There is more than one way to skin a cat. I don't see why both wouldn't work perfectly. It's builder's choice. Go for it.
Re: Joe's P19
Posted: Tue Nov 03, 2009 12:03 pm
by Joe H
I finished splicing the side panels together but I had to move the jig over to make room, after moving it back into position everything was out of alignment, I must have gotten lucky the first time because it seemed to take me forever to get her re-aligned, not perfect but the bottom panel seemed to fit real nice so I stitched them together.
Put the lwr sd pnls on but just wasn't satisfied,
So I took it all apart and put 1/2" dia PVC under each stitch and what a difference, every panel just fell into place, I have to believe the CNC cut panels & PVC made all the difference in the world, perfect fit!
Dry fitted the upr pnls, nice! Looks like a Boat!
Also got a good deal on some epoxy from Craigslist, went to look at clamps, he sold the clamps but had 2 gallons of West System Epoxy with Hardener he no longer had a use for, $80.00, not bad, especially since I just paid $85.00 the day before for 1 Gal & Hardener.
My Granddaughter & Grandson are always willing to lend a helping hand!
Joe H
Re: Joe's P19
Posted: Tue Nov 03, 2009 12:36 pm
by tech_support
looks like you have it right, but you generally need a fiberglass splice on the outside of the bend, especially with the more tightly bent parts (side panels towards bow) - otherwise a splice on the inside will be in compression and could buckle. Ont he outside it will be intention and quite strong
Re: Joe's P19
Posted: Tue Nov 03, 2009 2:07 pm
by Joe H
Hey Joel,
I'm not sure what you mean, the fiberglass splice is on the outside toward the bow just as the plans discribe, are you seeing something in the pics that doesn't look right? All was fixed from my previous conversations.
Joe H
Re: Joe's P19
Posted: Tue Nov 03, 2009 2:21 pm
by Fonda@kauai
The bottom appears to be missing a piece of tape where the bottom panels are joined. You need a piece of tape on both sides when you join long panels, one side is under tension, the other compression. Looks good 8)
Re: Joe's P19
Posted: Tue Nov 03, 2009 2:44 pm
by tech_support
you have it right, I was just confirming that and also offering an explanation why the splice should be on the outside :)
Re: Joe's P19
Posted: Tue Nov 03, 2009 2:59 pm
by Doc_Dyer
I believe that they are talking about the area circled in red
Re: Joe's P19
Posted: Tue Nov 03, 2009 6:57 pm
by Joe H
Thanks Joel,
Yep, you guys are right I put the fiberglass on the wrong side on that 1 bottom panel, it is on the other side so I didn't think it would make a difference, I'll throw another piece of fiberglass on the outside before I glass the whole thing, just to be sure!
Joe H
Re: Joe's P19
Posted: Sun Nov 08, 2009 9:13 pm
by Joe H
Quick update,
I finished gluing the outer panels together and everything fit together pretty good, the bottom and side are extremely fair but I still have to tape and glass.
However at the front or bow of the upper panels I ended up with a gap of just over an inch, I don't think this should be to much of a problem, I'll glue, woodflour & epoxy, it together and glass over it.
I'll be ordering some tape and glass next weekend when my financier releases some $$.
Joe H
Re: Joe's P19
Posted: Sun Nov 08, 2009 10:27 pm
by ericsil
That hull looks really great. The gap is nothing to worry about. It just leaves enough room for the fairing compound to make a nice shape on the bow. After 9 layers of tape and epoxy you will never know it was there.
Have you made sure the bow is pulled back as tight toward the stern as it should be? It is a surprisingly hard bend to get the curvature as designed. Cut out the bow deck panel if you need a template. Otherwise you will have some droop at the bow, like many of the boats in this forum, including mine.
Re: Joe's P19
Posted: Mon Nov 09, 2009 6:44 pm
by Joe H
Thanks Eric,
I've got enough drooping going on without my boat drooping! I'm not sure on how I could use the bow deck to check for droop, wouldn't the frames be in the way? I used the bow mold and it lined up as far as coming together lengthwise, I attached the upper side panels to the transom first and bent it to the bow 1 foot at a time, it seemed to go together real nice, I wonder if I could measure from the tip of of the bow to the transom, or if I should even be concerned about it at this point?
Joe H
Re: Joe's P19
Posted: Mon Nov 09, 2009 8:21 pm
by ericsil
What I was thinking was that the bow deck piece would give you the shape of the last couple feet of the hull and the desired angle at the bow. Alternately, you may be able to sight near the floor and see if the top edge of the hull makes a fair curve all the way to the bow, getting closer and closer to the floor, or tends to curve back upward for the last couple feet. A little variation here is no big deal. Several of us have proven that the boat will float whether or not the bow droops a little.
Re: Joe's P19
Posted: Mon Nov 09, 2009 9:29 pm
by Dougster
What about a cable with a come-a-long from bow tip to stern. Just a little pull might lift the nose (considering her as right side up) and even tighten those side panels. Still, like Eric says, that's no big deal gap, and will disappear. Dunno if it's worth fooling with, cuz it looks pretty good to me, but I sure haven't built one. I have climbed around Eric's though, and let me tell you it's a fine boat.
Did all kinds of odd things hangin' my side panels Dougster
Re: Joe's P19
Posted: Tue Nov 10, 2009 8:19 am
by ericsil
I was looking at some of your earlier pictures. Since you are hard against the bow mold it must be pretty close to the right position. If there is nothing obvious after you check a little, I would slap on that fairing compound and go for it.
Re: Joe's P19
Posted: Tue Nov 10, 2009 7:18 pm
by Joe H
Eric, I have to glass it before I can fair it but I'm going for it, I just got in from the garage glued the front together and plug the holes I put in when I screwed the side panels together.
Dougster, I been watching your tread pretty much from the bigining, side panels and all, Oh, and I'm going to have an aluminum gas tank made for the boat. :)
Joe H
Re: Joe's P19
Posted: Wed Nov 25, 2009 11:10 am
by Joe H
I filled in the gaps with woodflour & epoxy mix, put in a ½" fillet on all the hard edges and I'm ready to glass, I have some time off for Thanksgiving so will see what I can get done between eating & fishing.
Happy Thanksgiving!
Joe H
Re: Joe's P19
Posted: Wed Nov 25, 2009 2:27 pm
by mecreature
Looks cool..
Nice to see another pic.
Re: Joe's P19
Posted: Sun Nov 29, 2009 8:39 pm
by Joe H
I made a little progress over the long Thanksgiving weekend, I managed to tape all the outside seems but I had to do the Transom twice because of air bubbles, the only difference was I used slow hardner on the chines and fast hardner on the transom, I ended up sanding it all down and re-doing the whole thing, I put more of a radius on the transom edges just to be sure, they might have been a little smaller then 1/2". :oops:
It was worth re-doing it though because it came out perfect the second time around and I feel much better about it.
Here's a few pictures of my progress.
Joe H
Re: Joe's P19
Posted: Sun Nov 29, 2009 9:20 pm
by Dougster
Wow, that's real neat work. I never quite seem to get it that nice, but then I'm used to me by now. I have noticed it's usually worth it to do over if you're agitated over it. Always a good feeling to make it better. 'Course there's that good 'nuff point of view, but it's a risky path. No risk for you up on that high road you're travelin'
Watchin' it happen Dougster
Re: Joe's P19
Posted: Mon Nov 30, 2009 8:53 am
by Joe H
Thanks Dougster, beleive me there are plenty of good 'nuff area's that only the builder know's about! :lol:
Joe H
Re: Joe's P19
Posted: Mon Nov 30, 2009 9:00 am
by wegcagle
Very neat work Joe. I agree; make sure it's done correctly now and no heart ache in the future :D I'm currently in the midst of grinding down and cleaning up an area that I did a "quick job" on a few months ago right before I flipped my boat. It'll end up costing me an extra 10-15 hours to do what should've been done right the first time :oops: Live and learn.
Will
Re: Joe's P19
Posted: Mon Nov 30, 2009 8:12 pm
by Joe H
Hey Will, don't know if I can make it any shinyer but I'll keep on fixing the f, huh, over sights. :)
Joe H
Re: Joe's P19
Posted: Tue Dec 01, 2009 10:35 am
by SmokyMountain
Joe,
Looks great!! I'll be chatching up with you soon :P I only hope I can be that neat as you.
I know with system 3 epoxy you can mix slow and fast to make a medium set. So you have time to glass, but it cures quick enough to sand and keep production going. I did that with my previous build and it woked good.
Andrew
Re: Joe's P19
Posted: Wed Dec 02, 2009 7:12 pm
by Aripeka Angler
Joe your boat is looking great :!: Nice clean work and great pics as well. Keep up the fine work and we hope to see you in Boca Grande in the Spring....
Richard
Re: Joe's P19
Posted: Wed Dec 02, 2009 7:35 pm
by Joe H
Thanks Richard and Andrew,
I was supposed to go oversea's for work next year but no one is saying much of anything about next year, we are scary slow so I'm just laying low, if all works out I'll see you guy's in the spring!
I have more questions about my build so see ya in the power boat section.
Joe H
Re: Joe's P19
Posted: Thu Dec 03, 2009 10:03 am
by ericsil
That is a really neat taping job Joe. I did not start posting until after I had painted the hull, partly to give me time to fair over the mess I made along the way. Hope you can keep going all Winter like that.
Since you are soon to be adding the skeg, let me comment. One problem I have with the P19 handling is its ability to scoot sideways in the wind when you are creeping up to the dock. Admittedly, most of my previous experience was with well-keeled sail boats, so I noticed the difference immediately. I would make sure your skeg is at least as large as the plans call out. I made mine a bit shorter and have regretted it ever since it hit the water. In fact, I might have made it 30% deeper and been happier in the Maine winds. The boat has a fair amount of windage for its weight and needs all the help it can get when you are barely moving. At speeds of 6mph or higher, the tracking is great.
Re: Joe's P19
Posted: Thu Dec 03, 2009 7:48 pm
by Joe H
Thanks again Eric, did you use a strake? I still don't know if I'm going to.
I couldn't help myself so I drew up another picture.
Joe H
Re: Joe's P19
Posted: Thu Dec 03, 2009 7:57 pm
by ericsil
Joe,
I did not consider any strakes, partly for the cautions mentioned by Tom. I had not settled on a trailer at that point and did not know where the bunks, or rollers, or whatever, were going to hit. I doubt they will add as much for a V hull as for the dory designs like the HM19.
Re: Joe's P19
Posted: Thu Dec 03, 2009 8:27 pm
Joe, you sure draw cool pictures 8) I think I'd leave off the strakes and install a larger skeg.
Re: Joe's P19
Posted: Thu Dec 03, 2009 9:19 pm
by Joe H
Hey Larry,
Yeah, no strake and a little bit bigger skeg, that seems to be the general consensus.
It's amazing what can be done on CAD these days,we can simulate the entire build of a vehicle and set it in any environment so it's like you looking at a real picture or movie, almost as good as computer games! ha ha
Joe H
Re: Joe's P19
Posted: Thu Dec 03, 2009 9:22 pm
by TomW
Joe I'm just the opposite. With a v-hull you don't need a skeg as much. You have a 10 degree V. On my C17ccx I'm going to go the same way that the C19 is setup and go with four strakes and no skeg. The C19 has only an 11 degree deadrise. First the skeg adds to the draft as it is not included in the draft numbers. Second with a V hull a 3/4" peice of lumber is not going to do any more for you than 2 3/4 peices of strakes. 3rd every boat I have had with a skeg I end up replacing the skeg or repairing it to d**** often. 4th I am going with a true reverse chine so that they will help with the steering also. That means attaching a peice under the hull instead of beside the hull. I was a little surprised to see your change to that in your present drawings from the previous ones.
Re: Joe's P19
Posted: Thu Dec 03, 2009 10:10 pm
Tom, come on, how many power boats have you owned with skegs? What kind of boats were these, specifically? How many production boats even have skegs? I've never even seen a production V hull boat of this size with a skeg. Can you show me one? Jacques told me that all of them would have skegs, if they could figure out how to produce them in a mold.
A boat with a skeg behaves better than one without, and strakes are not much help in tracking or lateral drift. And if you build it tough, you'll never have to replace it. I'm confident that mine will last as long as the rest of the boat, even banging oysters like I do.
Re: Joe's P19
Posted: Thu Dec 03, 2009 10:18 pm
by Steven
TomW wrote: Second with a V hull a 3/4" peice of lumber is not going to do any more for you than 2 3/4 peices of strakes. 3rd every boat I have had with a skeg I end up replacing the skeg or repairing it to d**** often.
Not sure about that. The strakes are at a shallow angle to the water flow in a sideways drift. The skeg provides much more lateral resistence to water flow. I would think the strakes would be good for tracking without impacting draft, if that's important. A skeg provides tracking and lateral resistance at the cost of added draft.
Re: Joe's P19
Posted: Fri Dec 04, 2009 1:04 am
by TomW
Stephen the less the deadrise the more important the skeg is. Your OB19 only has 7 degrees of deadrise so a skeg is much more important. Joe and my 10 and 11 degrees of deadrise is larger and can be done with strakes and proper reverse chines. A skeg will help some but is not as critical as on your boat or the 6" skeg on an OD18. It all depends on the boat the and the deadrise whether a skeg is required or optional. A skeg will never hurt a boats perfomance unless draft is important, I'm just not crazy about putting a 3/4x3/4 peice of wood on and then spending the money to put a peice of aluminum on it when I know that it can be replaced by two strakes 1x1x1 1/2 roughly.
Re: Joe's P19
Posted: Fri Dec 04, 2009 8:30 am
I doesn't change the running draft. The engine foot will always be lower than the skeg and will meet the bottom 12 inches sooner than the skeg will. It would only increase draft with the engine up, but you can't go far with the engine raised, without poling or paddling, and you ain't going to paddle that P19 very far :help:
Re: Joe's P19
Posted: Fri Dec 04, 2009 10:25 am
by ericsil
I second Larry's comments about the draft. Maybe it is a big deal on some boats, but not on a P19. Just to drag out the discussion a little longer, here is what I ended up with. Doing it again I would have made the skeg 9-10 ft long instead of 6 ft, but probably not much bigger in cross section.
Re: Joe's P19
Posted: Fri Dec 04, 2009 10:55 am
by tech_support
Referring to the picture above... that a nice size, it will really help when docking and at lower speeds.
I would not go any taller though on a high speed (planing hull). I also would not go any further forward, you do not want that skeg to become a "keel" while coming down a wave, in the extreme it could cause the boat to pivot and/or bow steer. Also, ideally the skeg will taper off towards the end, to keep the flow of water from becoming too aerated/disturbed.
Jacques and I attended a "boats behaving badly" seminar this year at IBEX where many design issues were exposed (manufactures names were protected) and discussed. There was one boat in particular where the traditional keel they had used for years (with lower powered boats) was causing alarming bow steer and the boat could spin like a jet ski if it hit a wave just right, the boat was over 30' 8O. They removed the keel altogether and the problem was solved.
The lecture was given by a Marine Engineer from a very well known Naval Architect Firm> He gave us all a link to a tool that can be used to predict some of these issues. If was very helpful to give a graphical representation of how changing the LCG of a boat to far forward can lead to quirky behavior.
Re: Joe's P19
Posted: Fri Dec 04, 2009 11:19 am
by steve292
Here's the skeg on mine(FS17) FWIW.
Re: Joe's P19
Posted: Fri Dec 04, 2009 12:34 pm
by Daddy
Joel, what about the skeg on Nina, very deep (8") at the stern tapering to nothing at 12 feet long. I was told by the technical editor of WB magazine that it would help when coming off a steep wave but what you are saying sounds different or maybe (I can't imagine) I am just misunderstanding. :P
Daddy
Re: Joe's P19
Posted: Fri Dec 04, 2009 1:19 pm
by D2Maine
nm
Re: Joe's P19
Posted: Fri Dec 04, 2009 8:04 pm
by Joe H
Hey Tom, I still have the original drawing the last one is just another rendition, I just thought the 3/4 round would be an easier installation then the first design.
Here is a rear view of my old Sea Ray, I think it backs up what Tom is saying about the reverse chine and strakes but that would be hard to duplicate on my P19 and I don think it's necessary to that extreme. It goes to a V behind the beaver troll, no skeg of course.
Here's a rear view of my brother-in-laws last build, nothing right at the stern but if you look at the second picture behind Janet and Donny you can see strakes.
I have a little way to go before I have to decide but I'll go with the skeg as the design shows for now and figure out the rest later.
Hey Larry I'll see if I can make some more cool pictures, maybe the spray rail next, maybe the whole boat! :lol:
Thanks for all the fantastic feed back.
Joe
Re: Joe's P19
Posted: Fri Dec 04, 2009 9:13 pm
by longrod
I wanna see more pics of curvaceous!!!!! Got any? That thig is awsome.
Re: Joe's P19
Posted: Fri Dec 04, 2009 10:23 pm
by Joe H
Longrod
I don't know if this link will work but I'll give it a try, Mayea - Intro
Plus there's a couple more in my Gallery.
Joe H
Re: Joe's P19
Posted: Fri Dec 04, 2009 10:51 pm
by sitandfish
Joe H wrote:Longrod
Joe H
http://www.mayeaboats.com/
Joe, let me know if this is wrong.
Re: Joe's P19
Posted: Fri Dec 04, 2009 10:55 pm
by Joe H
That's it Sitandfish! Thanks.
Joe
Re: Joe's P19
Posted: Sat Dec 05, 2009 8:05 am
by tech_support
that boat is a work of art, amazing. No problem posting pictures of her, the more the better. I do not think anyone will confuse her with one of kits. :)
Daddy, I was referring to only higher speeds boats. Nina is not going fast enough o have any of those issues But, if you pushed nina say maybe twice as fast as designed, with a large keel you could encounter strange issues.
Re: Joe's P19
Posted: Sun Dec 13, 2009 7:40 pm
by Joe H
I ordered 20 yrds of 12oz Biax the other day, I thought I'd put on the rub rail while I was waiting for the glass to arrive, now of course I'll need more epoxy, how much epoxy and glass do you think it will take to do the bottom? According to the plans I only have to go 6" above the chine with the glass, I'm okay with that but I noticed a lot of you go all the way to the rubrail, why if the plans don't call for it?
Joe H
Re: Joe's P19
Posted: Mon Dec 14, 2009 12:10 am
by TomW
Joe to protect the wood from things that go bump in the night. :lol: You don't need to use 12oz you can use 6oz. Or I'm going to use a slurry of epoxy and fiberglass milled fibers at a 50/50 ratio to protect the wood, 2-3 coats the other name for this is liquid fiberglass.
Re: Joe's P19
Posted: Mon Dec 14, 2009 7:15 pm
by Joe H
Hey Tom,
I just looked and didn't see any milled fiberglass here, maybe I missed it or can I just make my own?
Joe H
Re: Joe's P19
Posted: Mon Dec 14, 2009 8:29 pm
by TomW
It's under fillers here's the 4lb: http://boatbuildercentral.com/proddetai ... =E_mil_4lb I like it because you have to coat the wood anyway and mixing it 50/50 is about the same as a layup with fiberglass cloth at 50/50, without the expense and fussiness of the cloth and extra fairing of cloth. When I did the Mirror's deck it was a light white in the deep depression after one coat and a light white after two coats all over 3 coats makes another layer of depth. Dropped both a hammer and a sander on it with no damage. A quick coat of fairing on it then smooths it out unlike the cloth.
Re: Joe's P19
Posted: Mon Dec 14, 2009 8:48 pm
by Joe H
:oops: Thanks Tom!
I finished one side of the rub rail and put 1 layer on the otherside.
Joe
Re: Joe's P19
Posted: Fri Dec 18, 2009 7:52 am
by fastlane
Joe
Your P19 is looking good.. I'm building a P21. I used some glassed in strakes.
I thought about a skeg and even built one but decided not to use it.
Re: Joe's P19
Posted: Fri Dec 18, 2009 10:48 am
by Joe H
Thanks Fastlane,
Where are you at on your build, do you have a gallery going, I'd like to see some pic's.
I hope to be glassing the bottom over the Christmas Holiday but I'm down to 1/2 gallon of epoxy and Santa doesn't know where the epoxy store is located, I'm measuring my CAD model right now to see exactly how much I'll need.
I'm still going back and forth on the skeg, strakes and chine, but I do like the idea behind the reverse chine.
Joe
Re: Joe's P19
Posted: Fri Dec 18, 2009 12:16 pm
by Joe H
Okay, I measured the area for square yards on the bottom piece (1/2) and included the 6" of overlap at CL and 6" up the side it equals 6.08 yards X's 2 gives me about 12 yard's + the transom @ 1.4 yards = 13.4 yards of 12oz biax cloth.
13.4, lets round up to 13.5 X 12 = 162 oz's of epoxy needed to complete the glassing for the bottom. I have about ½ gallon left, = 64 oz's, I'll buy another gallon today plus the hardener that will be 160 oz's,
64 + 160 = 224 ounces of epoxy, that means, even with the armature factor built in, I should be able complete the bottom without having to spend money I don't have on more epoxy, man Santa was way to generous this year.
What do you more experience laminators have to say, am I way out in left field?
Joe H
BTW: I received my fiberglass the other day, thanks Joel for the quick responce and it was nice talking with you.
Re: Joe's P19
Posted: Fri Dec 18, 2009 2:43 pm
by tech_support
Hi Joe,
Glad you got the materials quickly. :)
I think you have plenty margin for this, but your going to have to be pretty stingy, and the wood cant soak up too much.
Re: Joe's P19
Posted: Fri Dec 18, 2009 4:02 pm
by kdog
Joe, your boat is looking great, I would have built one of those if I had the space. I gave up trying to figure out exactly how much epoxy I needed for a given application because I was never close with my guesses. You definately don't want to run out laminating such a large piece of cloth.
I have a question about your bottom hull panel seam. I'm refering to the second pic on page 8, the seam up towards the bow. From the pic it looks like the joint doesn't have any glass on it. Am I seeing things or does the lamination schedule call for this?
Re: Joe's P19
Posted: Fri Dec 18, 2009 4:42 pm
by Joe H
Yeah, you guy's are right, why second guess it, maybe I'll wait until I can get that 5 gallon bucket of epoxy, if I can stand not working on it all of my Christmas break thats what I'll do........ :roll:
John, you are right on, see page 4,
it's so nice you take your Dad out fishing with you, even if he can''t bring the smaller fish home you know he's enjoying it, I hope my son returns the favor some day.
Joe H
Re: Joe's P19
Posted: Fri Dec 18, 2009 5:40 pm
by kdog
Oh OK Joe I see you took care of that seam, just checking.
Yeah taking my dad out fishing is the least I can do for him after all the things he's done for me over the years. He really does enjoy it. I'm sure you're son will do the same.
Re: Joe's P19
Posted: Fri Dec 18, 2009 6:39 pm
by Joe H
Hey, it cut the front part of my pictures off, whats with that? ha.
John, I didn't fix the front splice yet but I will tomorrow, I should also be able to finish the rub rails.
Joe H
Re: Joe's P19
Posted: Fri Dec 18, 2009 11:32 pm
by gk108
Joe H wrote:Hey, it cut the front part of my pictures off, whats with that? ha.
Not only that, but the transom isn't drawn level. Maybe you need to put something under the right legs of the drafting table to level it up. :lol:
Re: Joe's P19
Posted: Sun Dec 20, 2009 9:34 am
by Joe H
Hey Gary, maybe I can just tip the monitor to straighten up the transom.!
Fastlane, I was watching your build, I don't know why I didn't make the connection, I'll blame it on old age.
How about an update on your build, I seen your latest picture, very nice.
I like your Foxbody, maybe I should clarify that, your Ford Mustang Foxbody, I sold mine last spring (sad day) to make room in the garage and buy the plywood for my P19 (happy day).
I'm heading out to the garage to finish the rubrails, later.
Joe H
Re: Joe's P19
Posted: Sun Dec 20, 2009 2:00 pm
by kdog
Ahh too bad you had to sell that convertible. :( I have two Mustang GT's, an 85 and 86 sitting in my yard just begging to put back on the road. Man I miss driving that 5 speed 302, what a fun car.
Re: Joe's P19
Posted: Sun Dec 20, 2009 4:11 pm
I used to have a 66 with a 302. What a car! It would run 100mph in second gear. Had to sell it to pay some taxes a few years back :cry: Probably a blessing that I got rid of it though, before my son reached driving age :D
Re: Joe's P19
Posted: Sun Dec 20, 2009 4:51 pm
by kdog
Cracker Larry wrote:I used to have a 66 with a 302. What a car! It would run 100mph in second gear. Had to sell it to pay some taxes a few years back :cry: Probably a blessing that I got rid of it though, before my son reached driving age :D
What a car indeed! My brother is doing a frame off restoration of his 67 GT fastback. 390 big block, top-loader trans with the big ol 9 inch rear.
Sorry Joe just blabbing about cars. Back to your boat, keep up the good work!
Re: Joe's P19
Posted: Sun Dec 20, 2009 5:28 pm
by Joe H
I grew up in Algonac Mich, home of Christ Craft and have been working in Detroit for the Auto industry for 30 years now, so if it ain't about cars it's about boats and if it ain't about boats it's about cars....................
I had a 67 Mustang 289, I took my wife out for our first date in it, the heat didn't work and it was the middle of winter, it was really a piece of junk but ran like a bat out of he!!, she still jokes about it to this day, there's a lot more to the story but I'll let it go at that. ha. :D
Yeah Larry I'll bet you son didn't think it was the right move!
I could go on and on about cars but I have to go out to the garage and make sure the epoxy for the rails went off, my wife was mixing well I was installing them, I know it's fine, just have to check.
Joe H
Re: Joe's P19
Posted: Tue Dec 22, 2009 7:42 am
by fastlane
Joe H wrote:Hey Gary, maybe I can just tip the monitor to straighten up the transom.!
Joe H
Joe.. My build is coming along very nice. Getting ready to prime it with some yaught primer in the next week or so.
I really need to update my build page. Have lots of pictures but too many projects going on.
As for cars.HEHE. Before i started the boat project i raced. I have built many fox mustangs.Had a little race shop going for a few years and built cages and did chassis fab and engine work. The one you see in the garage is my street car. It runs 9.30 @ 150 on DOT legal drag radial and c16. on pump gas it runs 9.90's in the 140's all day. I got into a big accident a few years ago and wound up rolling and burning that car. I fixed it up and now we cruse around and to test and tune once in a while. It has a 306 with a Precision turbo PT-76 turbo and a carb. Its apart rite now for some upgrades. 363 stroker and a 88MM turbo. shooting for 8's in spring in street trim.
some video...
http://www.youtube.com/watch?v=J9KfACOZ8HI
Re: Joe's P19
Posted: Tue Dec 22, 2009 9:05 am
by gk108
"Horse" power :!:
My dad has been restoring a '69 Mustang for a couple of years. It's almost there.
He also has a Fox body convertible, a '94 I believe.
Then there's cousin Bill's race prepared machine...
Bill also has a '67 coupe with a landau top that he bought from my dad a few years ago.
Sometimes, family gatherings in Indiana look like a Mustang rally. 8)
Re: Joe's P19
Posted: Tue Dec 22, 2009 9:29 pm
by Joe H
Nice video, brings true meaning to Fastlane, WOW!
"69" was a good year.
I have a link to a Ford web-sit where you can build your own Custom Mustang, it's really cool, but I'm missing something when it comes to posting links?
Here's my computer rendition: (2010 Mustang)
Back to Boats after this, really.
Joe H
Re: Joe's P19
Posted: Tue Dec 22, 2009 10:07 pm
I'll find a picture of my 66, with a 1971 boss engine. Other than fast and it looked good, it wasn't much of a car. The lights worked sometimes, same with the turn signal, wipers and brakes. It made gawdawful squeaks too, but it sure was fast 8O
Re: Joe's P19
Posted: Wed Dec 23, 2009 12:01 am
by gk108
I need to test drive a new Mustang. :D
Larry, up until this last one, dad would have told you that all of those characteristics are what makes owning an old Mustang a unique experience. On this red car, somebody disconnected all of the taillight wiring and taped it back into the harness. Same thing with the neutral start safety switch on the tranny and a few other circuits. :doh: He finally got it all worked out a couple of months ago, but never could figure out any reason for it.
Bill's car was an old wrecked racer when he bought it. It was mostly original, but had a tubular front chassis that he didn't like, so he designed and fabricated his own. New firewall, floorpan, rear firewall, roll bar. Gas tank moved to rear seat area, headers run under the passenger seat. Body widened 6". Powered by a souped up 302 that dyno tested around 400 HP. Altogether around $120K invested by the time he was done. It's also still street legal. 8O
Re: Joe's P19
Posted: Fri Dec 25, 2009 10:39 am
by Joe H
Build your own virtual Mustang before you test drive: (this is really cool)
http://www.fordvehicles.com/the2010mustang/?id=
I'm not sure how to post a link, just copy & Past the above.
Merry Christmas!
Joe H
Re: Joe's P19
Posted: Sun Dec 27, 2009 11:08 am
by Joe H
I finished the rub rails, I used 3 layers of 1/4" Image
At the transom
I had to cut a curve into the last 4 feet or so at the bow to get it to line up properly, all in all it went on without an issue.
I have the next week off so I hope to get off this couch and get some work done on the boat and maybe a little ice fishing for some perch, I know, I would much rather be down south fishing for some of those grouper & reds but that may have to wait until spring for now I'll take what I can get and I hope I can give an update on the "Anyone Fishing" thread before the weeks end.
Just noticed this guy out fishing behind the house.
He's nuts!, I'll have to go see if he's catching anything after this post.
Bundling up in Michigan
Joe H
Re: Joe's P19
Posted: Sun Dec 27, 2009 12:41 pm
He's nuts!,
The understatement of the month 8O
Re: Joe's P19
Posted: Sun Dec 27, 2009 1:30 pm
by SmokyMountain
He's nuts!,
I was thinking very dedicated or very hungry!!!
Joe - Did you use plywood strips because you had left over wood or planned it from the beginning?
Andrew
Re: Joe's P19
Posted: Sun Dec 27, 2009 2:09 pm
by kdog
Looks good Joe, I did the same on my build with the leftover ply. The 3 layers of 1/4" makes it super strong, docks and other boats will fear it :lol:
Whats wrong with a little ice fishing, it's the only game in town come Jan-Feb.
Re: Joe's P19
Posted: Sun Dec 27, 2009 3:24 pm
Are yall standing in the ice to catch bait :doh:
Re: Joe's P19
Posted: Sun Dec 27, 2009 3:31 pm
by kdog
Cracker Larry wrote:Are yall standing in the ice to catch bait :doh:
Haha, pretty much. Good eating, you just need to catch about 46367 of em and fillet for about 5 hours and you've got yourself a great meal.
Re: Joe's P19
Posted: Sun Dec 27, 2009 3:47 pm
You'd need that many for bait where we fish :lol:
You telling me that you stand out in the snow and dig a hole in the ice to fish specifically for those little things :help: Must be very bored or very hungry. I've got a 5 letter word for that- DELTA :lol:
Here, this will be good for your soul. Delta can have you fishing in just a few hours..
http://www.youtube.com/watch?v=hRk_EVNG5Xs
Re: Joe's P19
Posted: Sun Dec 27, 2009 5:13 pm
by Joe H
Andrew, I planned it on this build, as kdog mentioned it added a ton of strength and I found that to be true on my OD16 as well when I did just use leftover ply, so I figured I would repeat it, it's really an easy process it just takes a couple of days and lots of clamps.
Kdog, not all of us can get a pretty girl like that out ice fishing with us! That might even change Larry's mind.
Hey Larry, thats just not nice, ha ha, how far is it to heaven?
I'll have to admit the grouper you guys caught and Richard cooked up at Crystal River was mighty tasty but I sure wouldn't mind some fresh perch right about now!
Here's to walking on thin ice and eating fried perch! :doh:
Joe H
Re: Joe's P19
Posted: Mon Dec 28, 2009 9:32 pm
Yep Joe, you really need to come down and get on a grouper trip. I went down and fished with Richard again in November. The night before we stayed up until 0200 catching bait, then the next morning I caught bait while Richard got the boat ready. We put almost 200 pin fish in the bait well, and they were all bigger than those perch :lol: We used every one of them grouper fishing 8) Plus 25 pounds of brined cigar minnows and 5 pounds of squid.
I didn't even notice there was a girl under those clothes :doh: I couldn't do nothing with it anyway in those temps :!:
Re: Joe's P19
Posted: Mon Dec 28, 2009 9:36 pm
by Bluefish2
You have not experienced fishing until the water is hard and the temperatures are below 0 F. Some of the biggest freshwater fish I have caught was on hard water, three pound perch, 5lb pickeral (as big as they get) and a whole string of 5lb and larger bass. I have heard of pike large enough to get stuck in the 8" whole. can't take the cold anymore.
Boat is really moving along and looks good.
BF2
Re: Joe's P19
Posted: Mon Dec 28, 2009 9:42 pm
Now were talking fish that would make a decent bait :wink: I like fish that gives 80 lb tackle a work out :D When you can get a 400 lb marlin through that ice, it might be worth me standing on it. Until then, it aint gonna happen :lol:
Re: Joe's P19
Posted: Tue Dec 29, 2009 8:23 am
by wegcagle
C.L. One more little thing they forgot to tell you about ice fishing.
It requires at least a fifth of liquor per person per trip, and that's just to keep warm. It takes twice that much to catch a good buzz :lol:
Will
Re: Joe's P19
Posted: Tue Dec 29, 2009 10:07 am
by Joe H
Yeah a good buzz helps, but you can't to carefull when you out on the ice, I've caught some of the biggest Walleye ever through the ice. There is an extended duck hunt this weekend and for the last week there have been hundreds of thousands of ducks out in the bay, Redheads, Canvasbacks, teals, but the duck hunters are going to be real disappointed, there was a deep freeze last night and the bay is frozen over, the ducks have moved out, duck hunters are crazier then ice fisherman, they'll find the ducks. :lol:
Glassing the bottom of the boat in the next couple of days, I'll post updates.
Joe H
Re: Joe's P19
Posted: Tue Dec 29, 2009 1:03 pm
by wegcagle
Best time to hunt ducks is when everything is frozen. You get out there a couple of hours earlier and bust up the ice (I usually use the butt of my shotgun, but the ice here never gets more than an inch thick in a REALLY bad freeze). Since you're the only open water in town all the ducks come a runnin'
Will
Re: Joe's P19
Posted: Tue Dec 29, 2009 4:49 pm
by mecreature
boat is looking good..
We ice fish round these parts too. It gets you out and about.
Re: Joe's P19
Posted: Thu Dec 31, 2009 11:22 am
by Joe H
Thanks Mecreature, I hope you enjoyed your D15 with your crew this past summer.
I managed to get what I think is a big step out of the way, I laminated the bottom of the boat yesterday.
I started out by cutting the cloth to the proper size then filling in the weaves on the tape job I did a couple of weeks ago with a slurry mix of epoxy and woodflour, I was wishing at that point that I would have went wet on wet but in actuality it only took me about 45 minutes to prep for the cloth.
My son walked into the garage just as I was attempting to lay the cloth back onto the boat, he seen I was struggling, hee hee, and said "hey do you need a hand" ha, gotch ya!
4 hours later we were done. We took turns using a 7" roller to apply the epoxy and a 6" squeegee to spread and thin it out, this system worked very well well, one was spreading the epoxy the other was mixing, the only down side was I didn't listen to everyone's suggestion on prepping the epoxy before hand, I use the West System, I know, I know, but for reasons it's my epoxy of choice but I also use the pumps and after about 3 or 4 sessions of 15 pumps of epoxy and 15 pumps of slow hardener, well, it was obvious this was going to be a real pain in the arss, very tiring, I'll pour the epoxy next time.
With the prep work and cloth I used almost 2 gallons epoxy, my brother-in-law saved the day by bringing me an extra gallon of epoxy along with the slow hardener right about the time I was thinking I wasn't going to have enough to finish. He also returned about an hour later with cut examples of what I should do for strakes and chines, I'll elaborate on that later with pretty CAD renditions.
Well all and all I think it turned out very nice, what do you think?
Thanks for all the comments and help up to this point.
Joe H
BTW: 12 oz cloth isn't really 12 oz cloth, it's more.
Re: Joe's P19
Posted: Thu Dec 31, 2009 12:25 pm
by Murry
It looks good from Virginia Joe. :D
Great Job. Yeah, haveing someone do the mixing saves a ton of time, a must have doing a large boat like yours.
Re: Joe's P19
Posted: Thu Dec 31, 2009 12:57 pm
by kdog
Hey that hull shape looks very familiar. Looks like you did a nice clean glass job.
No worries about your method, you can try the other technique on the inside.
On to the fairing!
Re: Joe's P19
Posted: Thu Dec 31, 2009 7:29 pm
by BassMunn
Nice neat glass work, fairing should be pretty easy on that clean hull
Re: Joe's P19
Posted: Fri Jan 01, 2010 2:52 am
by Steven
Looks very nice. Good job.
Re: Joe's P19
Posted: Fri Jan 01, 2010 9:14 am
by cottontop
Happy New Year to you and your family Joe. What a great job on your new build. Keep up th good work. John
Re: Joe's P19
Posted: Fri Jan 01, 2010 10:10 am
That looks great Joe! Happy New Year to you and Janet :D Not sure what you're going to do with that big boat and all that frozen water though :doh: If I lived up there where the water was hard, I'd be building one of these :lol:
Yall should talk to Jacques about plans. Wonder if he'd design a 100 mph sailboat 8O
Re: Joe's P19
Posted: Sat Jan 02, 2010 12:39 pm
by gk108
Cracker Larry wrote:Yall should talk to Jacques about plans. Wonder if he'd design a 100 mph sailboat 8O
I'd never be able to wrap my mind around close reaching in a 50 knot tailwind. :lol:
On the other hand, if I still lived up there, I'd entertain the thought of making a set of skates to clamp on the bottom of the V10. She would be Hell on ice :!: :lol:
Re: Joe's P19
Posted: Sun Jan 03, 2010 8:51 pm
by Joe H
Thanks for the great comments guy's, I went trough extra measures to make sure the bottom was good a fair before I glassed so we will see how the fairing goes.
John, glad to hear everything is going well, full recovery takes time, I hope to see you in the spring, and with the build Bassmun is doing it's no wonder your going for the same boat.
I have seen a few of those ice boat out on the bay early in the year but I think the snow tends to slow then down, 100mph are you kidding me? That would be a blast. Larry please keep a small corner of your boat open for me at Boca Grande I'm still not 100% certain if I can go this year but it's looking good.
I glassed the transom yesterday, and will be ordering some micro balloons and fairing compond tomorrow.
Back to work tomorrow, it's going to be tough after being off for the last 2 weeks but someone has to pay for this addiction!
Joe H
gk108, have you built your new Mustang online yet? Let me know if and when you need a pin #. :)
Re: Joe's P19
Posted: Mon Jan 04, 2010 12:54 am
Not to worry Joe, I've got a spot reserved for you in No Excuse :wink:
Re: Joe's P19
Posted: Fri Jan 15, 2010 1:55 pm
by mecreature
that hull looks sweet...
You are getting some work done despite the cold weather.
That last blast was chilly.. We got an unusually large amount of lake effect snow from Lake Michigan all the way down here on the north side of Indy last week from that crazy system. We use these cold spells to plan our summer trip up north. I think we are going to UP maybe to the 2 hearts river.. or somewhere in that area.
Keep up the good work.
That P19 is the boat.
Re: Joe's P19
Posted: Fri Jan 15, 2010 7:12 pm
by Joe H
Thanks Mecreature,
This warm up is ruining my outdoor plans. :)
I received my order of mix of micro balloons and silica the other day and I'm ready to fill in the weaves of the 12oz biaxial cloth, I have already sanded the edges of the cloth and knocked down the radical threads a little and I think I'm ready to apply the slurry, I'll mix it up to a catsup type consistency and slap it on and use a rather large straight edge to spread it out, wait a day and sand it down, right? This will be new to me because I just used woodflour and epoxy then sanded like crazy on my OD16, to much work.
My brother in-law, who is a pretty good boat designer in his own right :) , stopped by with a couple of examples of how I should do the strakes and chine.
I drew up a CAD rendition, no skeg, he said if I were going to be beaching her or running where I had a chance running up on rocks or oyster then by all means put one on, but it will add nothing for the perfomance of the boat, also start right at the transom with the strakes & chine then we will adjust the strakes forward after the first ride if needed. They measure 1" high by 2 1/4" wide.
Joe H
Re: Joe's P19
Posted: Fri Jan 15, 2010 8:05 pm
by Steven
Your first goal is to fill the weave. The consistency for this is too thin to build up. Once the weave is filled, use a straight edge to find the humps and hollows. Mix it to a thicker consistency to fil in the hollows. A straight edge to drag works good at this stage. At least that's how I do it.
Re: Joe's P19
Posted: Fri Jan 15, 2010 9:12 pm
by TomW
Joe I like the strakes and chine. I might make the chine one a little taller instead of 1' maybe 1 1/4 -1 1/2 just because of the volumn of water comin off the hull at that point. Talk to your brother-in-law. I'm doing about the same thing.
Re: Joe's P19
Posted: Sat Jan 16, 2010 10:51 am
by Joe H
Yeah Tom it's very similar to what you suggested in the first place, he's already mentioned making the chine just a bit larger, you must have been listening in. :)
I'm heading out to the garage to spread some slurry and fill the weave.
Steve, I'll use quickfair to fill in the humps and hollows, pics to follow!
I'm getting a late start but it will be a good weekend to work on the boat, the Saint Clair river is jammed up with ice in Algonac not allowing much water through from Lake Huron so the water level in Lake Saint Clair is dropping like crazy making it very un- safe for ice fishing, there are a few freighters caught up in the mess so the coast guard have been vey busy with their cutters trying to open it up, it's quite the operation, those guys in the cutters are amazing.
Thanks guys.
Joe H
Re: Joe's P19
Posted: Sun Jan 17, 2010 12:33 pm
by Joe H
I started to fill in the weaves of the glass yesterday but ran out of epoxy before I could finish, I used 1/2 gallon and almost 3/4 of the mix of balloons and silica and managed to just finish 1/2 of the boat and the transom, I may have put it on a little thick but it looks good this morning no runs and covered most of the weave, I wish I would have used fast hardener instead of slow, it's still tacky this morning, all I can do now is watch it dry. :roll:
Joe H
Re: Joe's P19
Posted: Sun Jan 17, 2010 1:50 pm
by wegcagle
Fairing putty can be spread along way....but I also found that it disappears quickly too :D She sure does look good from here. While she's drying just sit back and enjoy a warm cup of hot chocolate and knock out a few honey dos (that's what I try to do anyway :lol: )
Will
Re: Joe's P19
Posted: Sun Jan 17, 2010 3:49 pm
by Joe H
Sounds like a plan Will.
Lazy day in Mich
Joe H
Re: Joe's P19
Posted: Sun Jan 17, 2010 6:51 pm
by Larry B
I just love watching epoxy dry (setup, cure) kinda like watching the grass grow. Except I don't like grass to grow, then you have to mow it.
Come to think of it after the epoxy sets you have to sand it :doh:
Re: Joe's P19
Posted: Sun Jan 17, 2010 7:22 pm
Lazy day in Mich
Joe H
Joe, you could always drill a hole in the ice and catch us some bait. Just leave it outside until you come to Boca Grande in the spring, put it in a cooler and we'll feed it to something :lol: :lol:
Your boat is looking great 8)
Re: Joe's P19
Posted: Sun Jan 17, 2010 7:31 pm
by SmokyMountain
Joe,
What part microballoons, silica, epoxy did you use for you slurry? Also, will that slurry with the micro-balloons be strong enough to hold your strakes and skeg? ( I have never used microballoons before and don't know their strength.) I plan on filling the weaves with a slurry too....before fairing .
Looks great!!!
Andrew
Re: Joe's P19
Posted: Sun Jan 17, 2010 8:27 pm
Andrew, I don't know the ratios but if you get the blended filler from here it works great. No filler is structural, it's cosmetic, it has no strength. Install all your strakes and skeg before doing any filling and fairing.
Re: Joe's P19
Posted: Sun Jan 17, 2010 8:30 pm
by Joe H
Hey Larry that's funny but what even worse is I'd be out there catching that bait if the ice were just a little more stable, this little warm up is killing me! If I can't get out fishing soon your gonna see me on your door step with fishing pole in hand!
Andrew I ordered the blended filler from here at Boat Builder Central, but thats a good question, I planned on using quickfair over the filler then put on the strakes but thinking about it I think I've read fairing after putting on the strakes and chine???? :help:
Weird but I can't wait, I get to try out my new hand made sanding long board.
Joe H
Re: Joe's P19
Posted: Sun Jan 17, 2010 8:31 pm
by Joe H
Hey Larry posting at the same time, I filled in the weaves with the mix, still need to put on strakes and chine, now what?? :help:
Joe H
Re: Joe's P19
Posted: Sun Jan 17, 2010 10:10 pm
by TomW
Strakes over your slurry Joe the Quik Fair doesn't have enough strength. If you want a definative answer ask Joel up in Epoxy, Paint section.
Re: Joe's P19
Posted: Sun Jan 17, 2010 10:23 pm
Joe H
Grinder :help: Joe, don't glue anything over fairing compound, it's just for cosmetics, it has no strength.
Re: Joe's P19
Posted: Sun Jan 17, 2010 10:29 pm
by SmokyMountain
Grinder Joe, don't glue anything over fairing compound, it's just for cosmetics, it has no strength.
Larry, does that mean you can glue the strakes/skeg over the microballoon/ silica slurry?? :doh: ... just making sure I understand. I know you can't over fairing compound, or is the microballoon/silica slurry for fairing too?
Andrew
Re: Joe's P19
Posted: Sun Jan 17, 2010 10:45 pm
Andrew, the the micro-balloon/ silica is strictly a fairing compound, it has no (minimal) structural strength. Install all your skegs, strakes and spray rails directly over glass. If you have to fill first, use wood flour or milled fibers, a structural filler.
Re: Joe's P19
Posted: Sun Jan 17, 2010 10:51 pm
by TomW
Larry I just went through Joel's FS17 build because I seemed to recall he put his strakes on after the slurry as I mentioned above. Well he did. Not only after the slurry but after totally fairing the hull. So apparently Quik Fair has enough strength to hold the strakes. Or Joel seems to feel it does. Joe, Andrew, you can see his attachment of the strakes on page 10 of his FS17 build at the top of this section
Re: Joe's P19
Posted: Mon Jan 18, 2010 8:01 am
by Joe H
I'm not sure now but when I ordered the microballoon/ silica slurry I talked with Joel and I thought he mentioned it was okay to attach the skegs and such to the slurry, I checked out his build and yes he did.
If anything, I just put 1 coat on 1 side, I can grind it down or I have a whole coffee can full of brass screws!!! :lol:
Thanks for pointing this out Andrew.
Maybe Joel will comment, if I don't hear from him by lunch time I will do as suggested Larry and ask in the epoxy/paint section.
I'm at work now but can't think, must think about cars not boats.................... it's no use.
Joe H
Re: Joe's P19
Posted: Mon Jan 18, 2010 9:37 am
by cape man
BBV...it's a wonderful thing! :lol: :lol: :lol:
Re: Joe's P19
Posted: Mon Jan 18, 2010 11:56 am
by Joe H
I got it good and I got it bad!
Re: Joe's P19
Posted: Mon Jan 18, 2010 12:14 pm
by cottontop
Joe, You sound like me when I was building "EZMORNING". I took off quite a few days earlier than I should have. How bout taking a picture of your fairing board and posting it? Keep up the good work. John
Re: Joe's P19
Posted: Mon Jan 18, 2010 12:22 pm
by Joe H
With the slurry of slurry excitment I almost forgot, just before I fiberglassed I noticed a bit of a dip in the hull, maybe 1/4", 5' from the transom, so I climbed under the hull and propped it up right under the dip, it worked great, I have since removed the prop-up, after the glass cured, and no dip.
Joe H
Re: Joe's P19
Posted: Mon Jan 18, 2010 7:15 pm
by cape man
8) 8) 8)
Re: Joe's P19
Posted: Mon Jan 18, 2010 8:10 pm
by Joe H
It's not much John, I bought the handles at Lowes for a few bucks, sandpaper for a belt sander and some 3M spray on adhesive, here it is!
It was someone else's idea here on the site, I just borrowed it.
Joe H
Re: Joe's P19
Posted: Mon Jan 18, 2010 9:15 pm
by wegcagle
It's a step up from mine. I just used an extra chunk of plywood cut to size with 2 more extra plywood clunks for handles. Then I scraped out the remainder of a epoxy putty bag and..... voi la, instant red neck fairing board :lol: :lol: Most of us around here make them. Have you seen the price to buy one :help: Lookin' good Joe.
Will
Edit: I also bought my sandpaper on line. I just googled, "stick on sandpaper" and played around until I found the big rolls. Then I layed the sticky side down on the fairing board, cut to size, and watched my arms get bigger :D
Re: Joe's P19
Posted: Mon Feb 01, 2010 7:15 am
by Joe H
Did lots of sanding over the weekend, I don't know if my arms are any bigger but I'm sure they are going to fall off sometime today, my wonderful Dentist gave me some pain relievers last week after 2 root canals, I think I need to ease the pain. I used the micro balloons and silica blended filler on one side and woodflour & epoxy on the other, the blended filler was a pleasure to sand compared to the side with the woodflour but both side came out nice and we will see if the strakes fall off of the side with just the blended filler, I did do some extra sanding for the strakes and chine.
I also cut the strakes and chines and placed them on the hull temporally just to see how they looked, next step is to install them permanently.
Lee gave some excellent installation advice on another thread but I am still not sure how to maintain the proper alignment to the centerline of the boat, any suggestions would be appreciated. Lee mentioned a template??
CAD concept:
Actual:
Joe H
Re: Joe's P19
Posted: Mon Feb 01, 2010 1:45 pm
by SmokyMountain
Joe,
When you figure that out let me know too. I was discussing this subject that with Bradley this morning. I still have my centerline on the stern. Don't know if that will be much help.
Bradley suggested lining up two strips of straight material (same thickness) parallel to the center line (same distance from either side of the centerline) and measuring the diagonals of the strips so they are parallel. So in theory the skeg in the middle of the strips should be aligned. ( A laser level would help too) You would base the alignment of you strakes off the skeg. Sound like it might work... :doh: but I'm not there yet :P . I'll lean from you!! :P
Hopefully, I'll have everything filled and sanded by the end of the week. Try to get a little done each night.
Your boats looking great, keep on truck'en!!
Andrew
Re: Joe's P19
Posted: Mon Feb 01, 2010 1:55 pm
by cape man
Check out Peter's suggestion/solution. I like it!!!
http://forums.bateau2.com/viewtopic.php?f=2&t=22444
Re: Joe's P19
Posted: Mon Feb 01, 2010 5:37 pm
by Joe H
It's very cool, did you see it Andrew? I'll use it! I already told my wife I'll need a "laser" level though. :lol:
Thanks Peter.
Joe H
Re: Joe's P19
Posted: Mon Feb 01, 2010 5:42 pm
by peter-curacao
Thanks Peter.
Joe H
Your very welcome, you know I have a laser level and for some reason I couldn't get it done with that thing :doh: still a very cool toy though so don't cancel that order :P very useful to set your waterline :wink:
Re: Joe's P19
Posted: Thu Feb 04, 2010 7:56 pm
by Joe H
How do you like this Peter, I couldn't help myself it's what I do. I think it could be made out of aluminum or wood but I will never make it, 1- I don't have the tools, 2- I'll be done this weekend using Peters home made version, but it was fun to draw, I drew holes every 1" and drew it to be adjustable by 1" I figure that should cover anything from 4" from C/L to 26". If anyone is intrested in making it I have detailed up some 2D drawings or I could send you the 3-D file.
Designed by NASA
Netherland Antilles Society of Appropriate technology
Joe H
BTW: The picture was trimmed down when I edited, to see the full pic go to the gallery or is it just me?
Re: Joe's P19
Posted: Thu Feb 04, 2010 8:10 pm
by peter-curacao
Very Cool !!!! 8) 8) I wish I could do that, I started once with it but didn't had the patience to put it through :|
Edit one suggestion though I would have done the adjustment with 1 wing nut
Re: Joe's P19
Posted: Thu Feb 04, 2010 9:19 pm
That's a sweet tool right there 8)
Re: Joe's P19
Posted: Fri Feb 05, 2010 3:27 pm
by Joe H
Peter I thought about doing that but for one, have you ever tried drawing a wing nut! pain in the arss. but really, if you only have one slot with a wing nut then there is nothing to keep the 2 pieces parallel to each other, know what I mean?
Larry, thanks, now we just need someone to make one and we can throw it in the tool exchange. I have our tooling department intrested but they have been pulling back on what we call goverment jobs (personal stuff) at work. :roll:
Joe H
Re: Joe's P19
Posted: Fri Feb 05, 2010 4:07 pm
LMAO :lol:
Here's my idea, don't laugh too hard, I'm not an engineer :lol: All you need is 2 plumb lines, and a roof overhead. Hang one plumb bob from the ceiling directly over the center line at the transom. Hang the other one directly over the center line up forward, even with the longest strake. Then pull a string line between those 2 points on the ceiling. From that line measure (using a square to insure a 90 degree angle) the distance that you want the strakes spaced and mark those points on the ceiling. Pull a line between them. Eyeball them for parallel. Sometimes the eye is better than a measurement. Now drop your plumbs anywhere from the new line and they will point to the exact centers of the strake position, anywhere along their length. You don't have to index to the center of course, you could use an edge instead.
Re: Joe's P19
Posted: Fri Feb 05, 2010 5:56 pm
by peter-curacao
Joe H wrote:Peter I thought about doing that but for one, have you ever tried drawing a wing nut! pain in the arss. but really, if you only have one slot with a wing nut then there is nothing to keep the 2 pieces parallel to each other, know what I mean?
I meant leave those nuts as guides and take one wing nut to lock, reason I said is when I was busy with my home edition tool I wish I had 3 hands :wink: So wing nuts doesn't come with autocat??? :doh:here you go then Image
Re: Joe's P19
Posted: Fri Feb 05, 2010 9:02 pm
by Joe H
Larry, I had to read that 3 times before "BAM" I got it, and you are so right about the eye being better then a measurement, I had calculated the perfect angle for cutting the rectangle in half for the strakes, after wasting the first board I went by eye and the others came out much better.
I see what you mean Peter, that gives me an idea , I'll use dowels in place of the bolts and 1 wing nut, on the drawing that is because I'll never build it.
I think you meant Autocad, and in my neck of the woods we call it kindercad. :lol:
I use a CAD system called Catia, pretty powerful tool, not that Autocad isn't, just different applications.
From one nut to another nut, thanks for the wing nut.
Joe H
Re: Joe's P19
Posted: Wed Mar 10, 2010 7:39 am
by SmokyMountain
Joe,
Saw you strakes in the builders gallery. They look great!!! How did you attach yours to the boat while gluing.? :doh: You'll start looking like Popeye this weekend!! :P
Andrew
Re: Joe's P19
Posted: Wed Mar 10, 2010 11:58 am
by Joe H
Hey Andrew,
I used the tool, idea stolen from Peter, to mark alignment lines down the hull then drilled some pilot holes in the strakes about every 20" and temporally attached them with drywall screws to the hull one at a time, some looked a little wavy so I adjusted by eye, then, when I was satisfied with the alignment, I drew an outline around each one removed them and used woodflour and epoxy mix to permanently attach them removing the drywall screws the next day, I also did this before fairing as Larry suggested to ensure they don't fall off when I'm hulling A$$ across the lake!
You can see in the pictures I started fairing too, I used a mix of West System 410 Microlight & 406 silica with Westsystem epoxy and I'll have to say I didn't like it the first time around, it just seemed heavy if you know what I mean, it didn't go on as smooth as the purple stuff from bateau here, but in all fairness I had a pretty flimsy straight edge so I will try again this weekend with the Westsystem stuff, simply because I already bought and paid for it, and a stiffer straight edge, if I don't like it for the second time I will move on to Quickfair, thoughts?
As far as sanding, I will have to try again this weekend but as Richard from OZ would say, I stuffed my back about 5-6 weeks ago and things haven't been the same since, the back seems better but now my right shoulder, arm and hand are paying the price and sanding just seems to aggravates it, it sucks getting, huh, older but of course I'll be out there sanding Saturday just so I can bitch about not being able to lift my cup of coffee on Sunday.
more pics in my gallery:http://gallery.bateau2.com/thumbnails.php?album=1061
Joe H
BTW: Nice Trout
Re: Joe's P19
Posted: Wed Mar 10, 2010 1:56 pm
by Dog Fish
The boat is looking good Joe, keep up the good work Image Image
Brian Image
Re: Joe's P19
Posted: Wed Mar 10, 2010 6:32 pm
by Joe H
Thanks Brian,
Man wish I was in Florida fishing even though it was a mild winter here in Michigan I need some warm weather.
Re: Joe's P19
Posted: Wed Mar 10, 2010 6:38 pm
Looks great Joe! You really need to clean your camera lens though :wink:
Delta is ready when you are :lol: Well, they used to be :?
Re: Joe's P19
Posted: Wed Mar 10, 2010 7:24 pm
by Joe H
Hey Larry, I don't think it's the camera lens, it's floating dust bunnies.
Delta huh. I don't think it's going to happen this year, you don't know how much it's killing me just to admit that.
Re: Joe's P19
Posted: Wed Mar 10, 2010 7:28 pm
Oh no Joe :( I was really hoping you and Janet would make the meet again this year.
Re: Joe's P19
Posted: Wed Mar 17, 2010 4:10 pm
by TomW
Joe meant to ask you earlier why didn't you extend the spray rail further forward. I think you may have a wet boat with them that short. You have nothing on the front leading edge to direct the water out and away from the boat.
Re: Joe's P19
Posted: Wed Mar 17, 2010 6:41 pm
by Joe H
Ya know Tom I was thinking the same thing, just the opposite of Andrews problem, but the reason I put them there is because that's where my boat building brother-in-law marked the hull to stop it and then go 45 degress toward centerline to end the strakes, I didn't question it at the time but I was thinking of putting a small splash rail along the line where the 2 panels come together if needed, just big enough to break the water, It does have the cabin up front so maybe it doesn't matter? :?
Joe H
Re: Joe's P19
Posted: Thu Mar 18, 2010 1:04 am
by TomW
Yea, Joe the cabin will help a good bit, but still.........., I'd want the spray rail going further forward even if it narrowed and got smaller towards the bow. But, then your brother-in-law should know what he's doing. :D
Sorry your not going to make it to Boca this year but things come up and understand. Enjoy the Walleye run! :D That's always fun!
Re: Joe's P19
Posted: Thu Mar 18, 2010 7:58 am
by Joe H
I'm going to look at extending the chine further up the bow, it might take a little work but I think your right, better take care of it know then say yeah I should have after it's in the water!
Joe H
Re: Joe's P19
Posted: Thu Mar 18, 2010 8:44 am
by SmokyMountain
Joe,
I know what you mean.... better take care of it now. Thanks for pointing out my rail... It didn't feel right installing it ... should have listened to my "gut". Take a look of my theory and see what you think. See my last post on my thread. Boat looks great!!
Andrew
Re: Joe's P19
Posted: Thu Mar 18, 2010 12:07 pm
by ericsil
I thought a couple of pictures might help you make a decision. Note that at 30mph the P19 cut water is far enough back that the spray hits the break well back on the hull. However, at 9-10 mph, the spray break moves well forward and, if not interrupted, could go high enough to blow into the boat if there is much wind at all.
I would worry more about how far forward you ran the inner strakes. This is going to give you more lift in the bow than on my boat and may???? cause you to run more nose-up. I also wonder a little about whether this could cause some bow steering. Needless to say this is a difficult modeling job which is well beyond my capabilities.
Anyway, have at it. You are doing a great job and I want to see the results.
P.S. I can E-mail you full resolution pictures if you need a closer look.
Re: Joe's P19
Posted: Thu Mar 18, 2010 1:10 pm
by Joe H
Eric, I was looking for those pic's, yes please email me higher res pictures. Thank you very much. It's beyond mine too, from what I'm told in the traditional way of boat building you tune the strakes after you take her for your first a ride.
Andrew, gut feelings seem to go along way here, I'm at work right now but will check out your thread tonight.
Joe H
BTW: Tom, I called my brother-in-law, he will be stopping by this weekend, we will see what he has to say. :|
Re: Joe's P19
Posted: Thu Mar 18, 2010 7:22 pm
by TomW
Joe, since the strakes were brought up, that also sort of concerned me when I saw how you had done them on your boat. The Westlawn course I took covering strakes make yours sort of counter intuitive. They are reversed from what is normally considered good design. Normally the outer one is the longer one and the inner one is the shorter one. That way as the boat comes up on plane the longer outer one will maintain contact with the water for a longer period of time, until it is equal to the inner and both then provide steering control for you. But I took my course in the 70's so things may have changed since then. :doh:
Again something to bring up with your brother-in-law. I don't know if the current set up will cause bow steering or not as Eric suggests but he has more experience with his boat and over 2 years in Maine should know how she handles.
Re: Joe's P19
Posted: Fri Mar 19, 2010 10:47 pm
by Joe H
Donny, my brother-in law who is a 3rd generation boat builder and designer stopped by and had a look at the strakes and chine, his word's "perfect" exactly what he had in mind, it will give it the proper lift and maybe even add some top end speed. Tom, I explained your concern and he said with strakes and chines ask 20 different designers and you will get 20 different answers, this is what he recommends for this particular hull design and they are far enough back were they will not cause any bow steering, lengthening the chines however will cause bow steering, and the current design will have just the opposite effect of what you described but if they were further up the bow it could happen. we may have to tune them after the first ride but that would mean taking some off from the back side.
We may add splash rails in the back, he had some good ideas which will have function and form.
Back to the fairing, did I mention fairing sucks!
I have questions about the 410 west system micro light fairing stuff compared to Quick Fair, I can tell you I'm not impressed with the 410.
Joe H
Re: Joe's P19
Posted: Fri Mar 19, 2010 10:50 pm
Joe, I don't think anything compares to Quick Fair for ease of use, nothing I've ever tried anyway.
Re: Joe's P19
Posted: Sat Mar 20, 2010 3:36 am
by TomW
Okay Joe the master has spoken. 8) I totally agree with him that you should see some lift and additional top end speed with the design of the strakes and you'll be more efficient at midrange speeds on plane. They are perfectly designed for that! :D I just wasn't sure on the length inside vs. outside. Guess I have to rethink that on my boat. :doh: My only real concern is the length of the spray rail and like he says we will see.
Re: Joe's P19
Posted: Sun Mar 21, 2010 10:03 am
by Joe H
Hey Tom, we will see when the boat hit the water, I'm still concerned about no splash rail up front as Erics pictures shows it will be needed.
I also showed Donny pictures of the P26 built in Turkey and he suggested bringing my P19 to thier boat works to finish the top side to show boat quality, it's tempting but I don't think I can afford thier work, even if I would be doing all the work to his instructions, but he also wants to change things up to look a little like the C19, it's a lot to think about but I have a little time before I need to make that decision, hell it might be the closest I ever get to owning a Mays Craft.
Larry, I was sanding the 410 stuff from westsystem yesterday, well you were out fishing with the misses, and it came off real nice but I'm moving on to the quick fair, I'm ording some today from bateau, I can't find it anywhere localy.
If you guy's ever find a reason to come up to Michigan I would be more then happy to give you the 5 cent tour through the Mayea Boat Works, they do have some real classic beauties there, and Herb Mayea who's 90 years old and still designing and building boats, of coarse they keep him away from the power tools now!
Thanks guy's
The ice is finally out of the canel, fishing is in the short term future!
Joe H
Re: Joe's P19
Posted: Mon Mar 22, 2010 7:38 pm
by Joe H
I was able to open the garage door for the first time in several months and blow out all the saw dust and get a decent front view picture.
Sanded the first coat of fairing compound and still have a few low spots to fill in and sand again, fill in and sand again and so on.........
I just finished sanding 3/4 of the boat and putting on the first coat of fairing compond on the rest of the boat, advil time.
Joe H
Re: Joe's P19
Posted: Mon Mar 22, 2010 7:44 pm
by Larry B
Lookin good there Joe, aint sanding fun :D :wink:
Re: Joe's P19
Posted: Mon Mar 22, 2010 9:41 pm
by Dog Fish
What ya got there Joe, a Outlander 400, my daughter used to have one. The rack looks familiar.
Boat looks good, bet that was nice to pull that door up and breath some fresh air and get a different perspective on the boat from a distance.
Brian
Re: Joe's P19
Posted: Tue Mar 23, 2010 11:40 am
by Joe H
Hey Larry, I can't wait to get home from work and do a little more sanding, but I just put the more fairing compound on yesterday so it may not be cured enough today to sand,(one can only hope) I only had slow hardner and it went down to 40 degree's last night.
Brian, that's a 440 high output outlander, good eye, I use it mostly for ice fishing in the winter and trail riding up in northern michigan in the summer, it's a great machine but I really messed myself up on it coming of the ice very early in the year and it put an end to my ice fishing for the rest of the winter, at the time I would have traded it in a heartbeat for a new outboard for the P19 but now that I have had time to think about it I'll just keep saving my pennies for the new engine.
In the mornings the sun shines right into the garage on the boat bottom, man I thought I did a better jod of fairing, the sun shining on it showed every little inperfection, but it was still very nice to be able to open the doors.
Joe H
Re: Joe's P19
Posted: Tue Mar 23, 2010 11:55 am
by Larry B
Joe H wrote: Brian, that's a 440 high output outlander, good eye, I use it mostly for ice fishing in the winter and trail riding up in northern michigan in the summer, it's a great machine but I really messed myself up on it coming of the ice very early in the year and it put an end to my ice fishing for the rest of the winter, at the time I would have traded it in a heartbeat for a new outboard for the P19 but now that I have had time to think about it I'll just keep saving my pennies for the new engine.
Joe H
Joe, thats a dilemma I've been struggling with for awhile now. Do I sell one of my toys to buy the outboard or just save :doh: As of now I'm with you, just keep saving my pennies for the new outboard. I'm going to love my boat, but I love my other toys also :doh: Some just never get used like the waverunners, but on certain occasions they are fun and the wife likes them :doh: :wink:
Re: Joe's P19
Posted: Tue Mar 23, 2010 5:38 pm
by Dog Fish
I got ya there Joe, I had to sell my two quads but my wife still has her Yamaha 400 4x4 so when I want to do a little riding I take that.
Joe not to worry, you can't see those imperfections when the boat is upright and your fishing.
Re: Joe's P19
Posted: Tue Mar 23, 2010 5:55 pm
by cottontop
Joe, I've been following your new build for quite some time now. You sure are doing a jam up job. Maybe you'll have her finished for next years meet. Love to see you and your wife again. John
Re: Joe's P19
Posted: Tue Mar 23, 2010 6:01 pm
by Dog Fish
Yea Joe, what John said. 8)
Re: Joe's P19
Posted: Wed Mar 24, 2010 7:17 pm
by Joe H
Thanks guy's but I won't be bringing any boats down south until I'm ready to stay! :D But we are already making plans so we can attend next year wherever it may be.
Larry B, the wave runners went a couple of years ago, I sold my mustang last year to buy the wood for this boat, the ATV may have to go so I can get the engine, but I hope not.
I'm a little bummed right now, I did some fairing Monday and still can't sand today, it just gums up the sand paper, :doh:
Starting to think about primer, I used interlux InterProtect 2000E/2001E epoxy primer on my OD16, it worked very nice but it's not a high build primer and I would like to try some high build stuff this time, I'm assuming the high build will help hide any small inperfections? If there is any of course. :roll:
Joe H
Re: Joe's P19
Posted: Wed Mar 24, 2010 10:40 pm
by Steven
Joe H wrote:Thanks guy's but I won't be bringing any boats down south until I'm ready to stay! :D But we are already making plans so we can attend next year wherever it may be.
Joe H
I really like the S3 Yacht primer. I used Interlux on my GV11, and I much prefer the S3. Very nice to work with.
Re: Joe's P19
Posted: Thu Mar 25, 2010 1:10 am
by TomW
Yes Joe the S3 Epoxy Yacht Primer Joel sells is really nice. It will fill anything up to an 80 grit sanding scratch and maybe a little more but not much. That is about all you can expect from the high builds. The key to a final perfect finish is fairing as good as you think you can. Then put on one layer of high build. Do a speckle coat of something like Krylon Fast Dry and then a light sand with the boards to show where your highs and lows remain. There will be some. :lol: Fill the lows with Quik Fair and sand the hi's. Another coat of primer and Krylon, fair and sand if you want. Then 2-3 coats of primer. Sand with 220-330 for your final top coat.
I don't know how long it's going to take me to do an 18' boat but it took me 2 weeks for an 11' one to get it the way I wanted.8O
I may start doing the Krylon after the first or second fairing sanding. :wink:
Re: Joe's P19
Posted: Thu Mar 25, 2010 12:51 pm
by Dougster
Tom, now that you bring that up, I'm curious. I tried the Krylon spray thing and put it on WAY to heavy. Made it too tough to sand off, so that taught that lesson pretty good. But I always wondered if you have to sand it completely off or can just leave a bit in the lows, to show you where to QuickFair? My concern was it would trouble the bond, but maybe it's a trivial bit and not to worry?
Got curious Dougster
Re: Joe's P19
Posted: Thu Mar 25, 2010 1:39 pm
by gstanfield
I've been using the same technique for years on cars and I've never had an issue with a little guide coat under the filler, but then again I spray it on so light that one can lasts me 5-6 entire car paintjobs. If you're worried (and you put it on light) just scrub the krylon overspray off before you lay down the quickfair. It doesn't take much to remove it and if it helps you sleep better then it's not a waste of time :D
George
Re: Joe's P19
Posted: Thu Mar 25, 2010 6:32 pm
by TomW
A little bit won't hurt as there is more QF to speckles. But if you have more paint to QF take the paint off. The key to getting speckles is standing off aways and moving the can quickly.
Speckles good, solid bad.
Re: Joe's P19
Posted: Fri Mar 26, 2010 6:53 am
by Joe H
I'll be doing the Krylon this weekend after a little sanding.
I'd like to use the S3 Epoxy Yacht Primer Joel sells but with shipping cost, ouch!
I can get awlgrip and interlux products for cost so I'm forced to checked that out first, I'm sure 1 of them will have a good high build epoxy primer??
Thx
Joe H
Re: Joe's P19
Posted: Fri Mar 26, 2010 7:04 am
by cape man
Both of them do. Getting at cost I would go for the Awlgrip. Nice paint, similar to Sterling in the final finish, and you are doing a lot of prep for a good paint job.
Re: Joe's P19
Posted: Fri Mar 26, 2010 8:39 am
by fishingdan
I agree with Cape Man. Awlgrip and Interlux products are very good and getting them at wholesale is great. Awlgrip's high build primer is better than the Interlux product (fills better) in my opinion. That said, I do like the S3 high build primer most. In the end, they will all work and it comes down to preference.
For me, the decision is usually about the location I have for paining. If I'm painting in the garage under my house, I use the S3 product line due to the vicious fumes of the other stuff. If I can paint in another space, my favorite approach is S3 primer followed by Interlux Perfection paint.
Re: Joe's P19
Posted: Fri Mar 26, 2010 2:05 pm
by TomW
Decisions, decisions right Joe! :lol: The Awlgrip primer from what I know is better like Dan says, again get the high solids one I think it is listed for filling 80-120 grit sanding streaks. Either Perfection or AwlGrip should serve you well as a top coat with AwlGrip probably the better paint. You'll need a respirator with a chemical filter with either of them and good ventilation.
Re: Joe's P19
Posted: Fri Mar 26, 2010 5:46 pm
by Joe H
Actually you guy's have help with those decisitions, on my OD 16 I used Interlux 2000E primer, Interlux antifouling bottom paint and interlux brightside on the sides, I didn't admit it at the time but if Craig can I guess I can too, I used porch paint for cement on the interior, it all has held up beautifully for the last 3 years, but interlux doesn't have a high build epoxy primer, not that I can find anyway, awlgrip does, interlux doesn't have the special color I want, awlgrip does, so I'm glad to hear you all think the quality is very good, I might give thier fairing compound a try too, awlgrip it is.
Yeah ya can't beat whole sale Dan but it's through my in-laws account so believe me I still pay a price , I stopped by the marine stuff supplier and $52.00 for 2 quarts or $85.00 for 1 gal of awlgrip highbuild primer, sounds pretty good to me.
I'm still a couple weeks away from priming, more fairing and sanding in my immediate future, I can't wait to get that sander out tomorrow.
Another question, I know it's been answered here before but can't find it, I'm using 60 then 80 grit paper for sanding the fairing compound, what should I use just before priming?
Thx
Joe H
Re: Joe's P19
Posted: Fri Mar 26, 2010 7:46 pm
by TomW
The Awlgrip should be able to handle 80 grit Joe. Give it a try for your first coat and speckling. If it doesn't then you know you'll have to go to 120.
Re: Joe's P19
Posted: Sun Apr 04, 2010 8:48 am
by Joe H
I finally got out to do the Krylon, man I really thought the panel were flatter then that, it really showed the low spots, I had layed a straight edge on the bottom and it looked fair but the Krylon told a different story as seen in the photo's, I filled in the low spots and sanded the whole boat, time for another coat of fairing compound, I'd say the last but I know better.
Joe H
Re: Joe's P19
Posted: Sun Apr 04, 2010 1:58 pm
by TomW
The speckles really show it Joe, don't they. :wink:
Re: Joe's P19
Posted: Tue Apr 27, 2010 3:29 pm
by Joe H
This doesn't sound boat building related but it's directly related to my boat building, I have a big decision to make tomorrow, I have been diagnosed with Carpal Tunnel Syndrome in both wrist, severe in the right hand, and I will be seeing an Orthopedic Surgeon to decide on next steps, he's a surgeon so I imagine he will be pushing surgery, I'm not convinced that would be the right thing to do though, If I have the operation done then that's it, I'm done boat building for quite some time, weeks? Months? I don't know, this is a real shitty time of year for this to happen, there's the boat I'm building, there's fishing, there's fishing in the boat I built, I have an old 25hp manual start outboard on my boat to go fishing, oh, almost forgot, there's work, I work on a computer and believe it or not that's when it hurts the most! There are other things too but I think I can just switch hands for that.
I've read, on the internet of course, that you can just get a shot of cortisone/steroids and that will alleviate the pain but not correct the problem, hmmm, the problem is pain, plus it's only 50/50 that it will work.
Anybody ever had the operation? How long were you laid up for? Any long lasting side affects?
So, is it cut me Doc and be done with it or boot me up and hope for the best?
Oh, I did get what I hope to be the last full coat of fairing compound on the boat but I cannot use the 5" orbital sander to knock down the high spots, my hands would be humming like a $20 hooker, and I haven't tried the long board for more then a couple of minutes, but I can see the long board is the only way to go from this point on.
Anybody interested in doing a little sanding? :lol:
Joe H
Re: Joe's P19
Posted: Tue Apr 27, 2010 4:13 pm
by wegcagle
Hey Joe,
Sucks to hear about your carpel tunnel. The good news is that there is a cure :D There are many things that can help and prolong/prevent surgery. The best thing is proper wrist splints, and wearing them almost 24/7. These will keep your wrists straight and keep the nerve from getting pinched while typing(one of the WORST culprits of carpel tunnel), driving, sanding, painting, fishing, sleeping, etc.
Your hands hurt badly after work and after a good days sanding b/c the radial nerve runs up the palm side of your forearm and enters your hand through "carpel tunnel." The problem is that a bunch of tendons also run through it. These connect the muscles in your forearm to your fingers and make them flex into a fist. So all this stuff in there makes the carpel tunnel a tight little area. When you do too much with your hands, your tendons will swell which pinches the nerve causing bad pain in your fingers, weakness, etc. If it is not controlled then you not only have to worry about the pain, but it can cause numbness in your hand and eventually the muscles will get weaker and smaller, b/c the nerve isn't making them work.
The steroids make you feel better, because they help decrease the swelling in that area, but it doesn't fix the problem. The problem is that the area is too tight.
I'm a doc, so I would say follow your doc's advice. (pretty worthless advice huh :D ) The carpel tunnel surgery is quick, safe, and relatively painless. (At least until the nerve starts working properly again :help: :D ) It does take some time to get back on your feet, but the boat can wait, your work can and will wait, and the fish will only get bigger, but your hands and your health can't wait. They are too important to screw around with.
Just my 2 cents. Hope you get good news, heal well, and get back to that boat soon.
:D
Will
Re: Joe's P19
Posted: Tue Apr 27, 2010 4:50 pm
by cottontop
:D :( Joe, Sorry to hear about the "carpal tunnel". There s a brighter side at the end of the "tunel" so to speak. :P I've had the "carpal tunnel" surgery and then the "funny bone nerve surgery" done over the past 2 years along with all the other surgeries I've had and discussed briefly. As to the carpal tunnel, find a surgeon who does it ( I'm goimg to spell this wrong.) orthoscopically. It is quick and nearly painless. I had it done 2 years ago on my left wrist(I'm right handed.) It consisted of about 4 hours in outpatient surgery/recovery, 3 stitches, and I had no pain to speak of. I did have to take it easy on that hand for about 6 weeks. It stinks but the pain/numbness went away immediately. I waited far too long to get it done. I can do anything I did before just without the numbness and aching. I had the other surgery done last year on the same hand, because the pinky finger and ring finger began getting numb and aching more than the carpal tunnel. I realize this is a crappy situation, but I reccommend you follw your good dr.'s suggestion. Good luck and keep us posted. John
Re: Joe's P19
Posted: Tue Apr 27, 2010 7:22 pm
by Joe H
Will,
Thank you so much for commenting as much as I don't want to admit to what you are saying it sounds like the only permanent solution is the surgery, I have had an EMG done by a beautiful young Doctor, first thing she said was welcome to my house of torture, but she quickly followed up with "just kidding" when she seen my face of fear. The electric shocks were bearable but the needles to listen to the muscle, OUCH! Conclusion, Carpal Tunnel.
I wore the wrist splints for 3 weeks but couldn't keep them on 24/7, I already have the numbness along with needle like pain and it's happening all the time now after all the things you mentioned and then some.
Hey John, how have you been?
It helps a lot hear you have been through this and have come out 100% I just can't stand the thought of the down time, I will ask about endoscopic surgery, I just looked it up on the Internet, that's how I knew how to spell it, I could watch the endoscopic but not the invasive, Will, they cut the whole ligament, don't you need that?? Holy cow, I shouldn't have looked.
I will follow the good Doctors advice, I may just wait a little while longer, at least until I get the bottom of the boat sanded and I have a freezer full of Walleye. :help: :doh:
Okay, I'm asking this for my wife guy's, how long really before I'll be able to get back to working on the boat after surgery?
Thanks a ton.
Joe H
Re: Joe's P19
Posted: Tue Apr 27, 2010 9:32 pm
Sure sorry to hear that Joe :( I've got it myself, so does my wife. We both got it from windsurfing, mostly. My fingers usually stay numb, at least the last couple of them. Weird but my Dad had it too, maybe hereditary, but he's pulled a lot of lines too? He had surgery on his, said it was no better, but he was a cranky sort anyway. Who knows. Dori nor I have had any surgery. Sometimes it hurts, sometimes it doesn't, usually it's just numb, which is better. All that sanding doesn't help a bit.
They ain't operating on mine until I can't stand it, or can't use it :wink: But that's just me. 20 years and counting.....
Re: Joe's P19
Posted: Tue Apr 27, 2010 10:11 pm
by TomW
Damn Joe your wrists and my knee. We make a good pair. I haven't really worked on the boat since Feb. as I can't put any weight on it and any twisting about knocks me down. Just finally decided to go to the doc a couple of weeks ago. Good luck on what ever you decide to do. I had my MRI on my knee today. Meet again with the doc next Wed. I hate docs and don't want to go under again. But if it will help it is better than not. Deb has tunnel carpel and wears a brace when she does things that may aggravate it. Not ideal but keeps her from having surgery. However she doesn't spend a lot of time on a computer. As a nurse she has looked into surgery and if it gets worse she feels it will help her a lot. The new technology used is much better than it was 10 years ago. Since your in Detroit you should be able to find a top notch surgeoun there or Ann Arbor.
Asked Deb about the time before you can get back on the boat and all she could say is it depends on how fast you heal and how significant the surgery is.
Re: Joe's P19
Posted: Wed Apr 28, 2010 6:51 am
by cottontop
I knew I had the spelling wrong. My 11th grade english teacher, Mrs. Mitchell, would roll over in her grave. Joe I have an excellent surgeon. She said it would be about 6 to 8 weeks, depending on my recovery ability. It was about 6 weeks for me. One thing I've learned from all my recent surgeries is to take the time to heal right. I'm hard headed and want to get back to normal before tne body is ready. On everything thing else, 6 months with no cancer present, hand has healed up well, elbow hurts like the devil at times, but doc says it's still healing. I am getting back to a healthier state and getting much more done. Good luck. John
By the way, your boat looks great. Very good worksmanship.
Re: Joe's P19
Posted: Wed Apr 28, 2010 7:34 am
by wegcagle
Joe, I agree with cottontop about the orthoscopic surgery. This is where they make a really small incision and put a camera through it and then they do the surgery through the camera. It's the future in surgery b/c of recovery time, the incisions being used are way smaller than the old way, bleeding, etc.
The best way to figure out how long it will take to get back to sanding is to ask your Ortho surgeon. The surgeon may want you to go through some rehab as well, but that's not usually the case with carpel tunnel unless it's really bad.
As an aside, C.L. it sounds like you have ulnar nerve impingement syndrome. (This is the funny bone nerve problem talked about above) The ulnar nerve (nerve that hurts when you hit your funny bone) supplies the outside half of the 4th finger and all of the 5th finger, where the radial supplies the thumb, 2nd, 3rd, and the inside 1/2 of the 4th finger. So if your outside fingers are numb it's probably a problem of the ulnar nerve getting pinched as it runs through the funny bone part of your elbow. It sucks just as bad, but the difference is that you still have good strength in your thumbs. Our thumbs are God's gift to us to help with sanding :lol:
If you let it ride you WILL loose strength in your 4th/5th fingers over time, and all the meat on the outside of your hand will start to go away and you'll get bony old man hands :lol: Seriously though, you will start to drop more things than usual and you won't have the hand strength you once did. If you can live with it, then live well :D
I always try to give all the info to my patients', tell them my recommendations, and then let them make up their own minds. The biggest thing is that i hope you get well soon, and are able to get back to the boat with as much function, strength, and ability as you've always had.
Will
Re: Joe's P19
Posted: Wed Apr 28, 2010 9:21 am
by topwater
Joe sorry to hear about your wrists. At least they they got it figured out.
I was tested three times for that over last five years all came back negative.
Finaly got so bad i could swing a hammer or hold a wrench any more " heavey equipment mech"
they opened my wrist up and found two torn tendedons and that my wrist bones were rubbing against each other.
Spent the next 8 weeks in a cast up to my shoulder .They told me i now need a artifical wrist
and i have to wait at least 10 years until they get them perfected. My wife wanted to know how i was going to
build a boat like this , i told her to buy stock in advil :!:
Re: Joe's P19
Posted: Thu Apr 29, 2010 8:53 pm
by Joe H
Well,
Went to the Doc's yesterday and Will was right, he suggested surgery as soon as it's convenient for me, huh?, if I wait until it's convenient it'll never happen, he doesn't do the orthoscopic surgery and he had a few very good reasons but I am going to wait for a few weeks and maybe even a month, I don't know yet.
One would think after all the medical BS I've been through a little cut on the wrist wouldn't be anything, but I'm with Larry and Tom, I don't want another surgery right now so I got the shot, I will get the surgery done just not right now, but I have to say, especially to you Larry and Tom and spouses, go in a get a shot, I did and he said it would take a couple of days to take full affect but I am typing this right now with NO pain! :D :D . Ten times better then advil Topwater, how are you building a boat after all that?
Larry, my son also has it, he's a roofer, so I asked the Doc about it being hereditary, he said it has just been published in a medical journal and it absolutly contributes to it.
First I'm going to take a week or so off of work in 2 weeks and try to finish the boat bottom that is between fishing to fill the freezer with Walleye and then go to see an orthoscopic surgen, just hope the injection of steroids last that long.
Thanks for the support, can't stop thinking about getting out to the garage and working on the boat, this BBV thing has no cure and I'm convinced nothing will stop us from building!
BTW: Topwater, are you anywhere near Fox Lake, my sister & brother in law live there and we are going to visit sometime this summer.
Joe H
Re: Joe's P19
Posted: Thu Apr 29, 2010 9:01 pm
by TomW
Joe glad the shot worked maybe you can get the big girl flipped before the surgery. Maybe :?: :wink:
Re: Joe's P19
Posted: Thu Apr 29, 2010 9:37 pm
Do you still have one hand that works? That's all ya need with a little practice :lol:
Re: Joe's P19
Posted: Thu Apr 29, 2010 9:42 pm
by wegcagle
That's great to hear Joe. I'm glad the shot worked so well. Like your doc said, the shot reaches maximum effect at about 2-3 days. So if you are doing this well now, then that's awesome. Bad news is that it will wear off over time, but some people get a couple of weeks out of it and some get a few months, only time will tell. Personally, I'm hoping it will last a few months so you can get us some boat porn :lol:
Just remember, keep wearing the splints and ice them 2-3 times per day 20 minutes at a time.
Will
Re: Joe's P19
Posted: Thu Apr 29, 2010 10:19 pm
by Dog Fish
Re: Joe's P19
Posted: Fri Apr 30, 2010 12:36 am
by peter-curacao
Dog Fish wrote:Welcome to the C.T gang Joe, I have been dealing with it in both hands for quite some time now, but the last year and a half its gotten bad. I drop shit all the time, I am even having a hard time tying fishing knots, and that is not good. Good luck with it Joe, it really sucks.
Snip Snip :!: It looks easy to do. :roll:
hey is it thanks giving already?
fill it up!! and put it in the oven!!!
Re: Joe's P19
Posted: Fri Apr 30, 2010 8:15 am
by topwater
Joe i am not to far from fox lake maybe 30 miles.
JB and i live in the same town, JB is the one with the real nice od16 "blue and white one"
I would post a pic but dont know how.
Re: Joe's P19
Posted: Sat May 01, 2010 7:14 pm
by Joe H
Hey, give me some slack, I was dropped at birth!
Enough said... :lol:
Topwater, JB's OD16 is very nice, I would be afraid to park my OD16 next to it!, I don't recall seeing a motor mounted on it!
I managed to get some sanding done today, I'll post pic's when I get the other half done.
Joe
Re: Joe's P19
Posted: Mon May 03, 2010 9:21 pm
by Joe H
I did some sanding over the weekend, lots of sanding, it's still not there but close, real close.
Joe H
Re: Joe's P19
Posted: Tue May 04, 2010 7:16 am
by Murry
Close indeed :!:
Looks great Joe. :D
Re: Joe's P19
Posted: Tue May 04, 2010 9:34 am
by steve292
Looking good Joe. 8)
Steve
Re: Joe's P19
Posted: Mon May 10, 2010 12:46 pm
by Joe H
Thanks Guy's,
I did more sanding over the weekend, when I should have been in Boca Grande, next year for sure, but I'm close on the sanding, real close! :roll:
I'm picking up primer and paint this week and taking next week off from work to paint the hull, so I have to wrap this sanding thing up real quick. :help:
Joe H
Re: Joe's P19
Posted: Wed May 12, 2010 7:53 am
by cape man
Sweet times! The end of sanding... But wait!!! There's more (LOTS more) to come!!! :help: :help: :help:
Will be nice to see her with paint. What type and color are you looking at?
Re: Joe's P19
Posted: Wed May 12, 2010 3:50 pm
by Joe H
Thanks Craig I was trying to fool myself into thinking I was almost done with the sanding, how about one stage complete? :lol:
I was a little hesitant to announce the colors but since I am picking up the paint Friday here goes:
I'm using Pettit High build white epoxy primer for the whole boat, next is Pettit CopperBronze Antifouling bottom paint for below the water line and Awlgrip Mahogany Red Topcoat for the sides, still up in the air about the boot stripe, white & bright red or just white or just black, I'm thinking the interior will be mostly white with real mahogany trim work.
You can probably guess the look I'm going for, I'll give ya a hint, I'm from Algonac Michigan. :wink:
Joe H
Re: Joe's P19
Posted: Wed May 12, 2010 3:59 pm
by cape man
Why the antifouling? Plan on leaving her in the water?
The color and mahogany trim sounds sexy to me..
Re: Joe's P19
Posted: Wed May 12, 2010 4:21 pm
by TomW
Craig as I recall from pics of his OD16, he has a canal back of his house so he can leave her there all summer long..... 8)
Re: Joe's P19
Posted: Wed May 12, 2010 7:10 pm
by Joe H
That's right Tom, it'll be in the water from april -sept, the antifouling paint is amazing, it keeps the bottom algae free all summer long, without it the algae grows like crazy, 6" or more and it's next to imposible to clean off.
Joe H
Re: Joe's P19
Posted: Wed May 12, 2010 8:31 pm
by TomW
Joe are you sure about April! :lol: That's a pretty little granddaughter! :D
Re: Joe's P19
Posted: Thu May 13, 2010 6:38 am
by Joe H
Joe are you sure about April! That's a pretty little granddaughter!
Thanks Tom, she was at the Cyrstal River meet 2 years ago.
You can kinda see the OD 16 in the picture with my Grandaughter, the boat went in April 16, I went walley fishing that night and it's been under the cover since then, I'm off work next week I hope the weather turns nice so I can get out for more walleye or perch, I need the fish because I'm planning a fish fry to entice a bunch over for the flipping of the P19. :D
(your all invited)
Joe H
Re: Joe's P19
Posted: Thu May 13, 2010 7:11 am
by cottontop
Joe I love your fishing partner. She's a real beauty and the boats looking good too. Glad to hear the shot worked. Maybe it will give you enough time to get the P19 done. I'm looking forward to seeing the paint scheme. Have a great week. John
Re: Joe's P19
Posted: Thu May 20, 2010 12:32 pm
by Joe H
Well I didn't get nearly as far as I wanted to this week, life things happen, I did manage to get 2 coats of high build epoxy primer on yesterday and I am waiting very impatiently to get some bottom paint on her, I keep going out and trying to sand before I put the bottom paint on but it just keeps gumming up the sand paper, maybe tomorrow!?? :roll:
It's a fanatastic day today so I'm going for a boat ride before the wife finds someting for me to do, she doesn't seem to understand I'm on vacation, only boat stuff this week.
Here's some pic's:
Joe H
(I gotta remember to ajust those pics sizes next time)
Re: Joe's P19
Posted: Thu May 20, 2010 7:20 pm
by BassMunn
Looking good Joe. That's a major milestone you've reached. I love seeing a boat get paint for the first time, it just changes the look so drastically for the positive. Can't wait to see the topcoats go on.
Re: Joe's P19
Posted: Thu May 20, 2010 7:22 pm
by Aripeka Angler
Joe, that is looking really nice :!: Good luck on the sanding, it is tonic for the soul. I hated the sanding at first, but it aint all that bad. (easy for me to say now :) )
Re: Joe's P19
Posted: Thu May 20, 2010 7:50 pm
by TomW
Looking good Joe the paint really brings her together. :D
Re: Joe's P19
Posted: Thu May 20, 2010 11:05 pm
by Joe H
I don't mind the sanding, but this is my first time using high build epoxy primer (Pettit) is this normal?
Orange peel affect, this is after 2 coats.
Do I sand this down to be perfectly smooth, I might have to sand it all off to get there. :help:
Good from afar far from good.
Joe H
Re: Joe's P19
Posted: Thu May 20, 2010 11:32 pm
by TomW
Yes you need a perfectly smooth primer for the topcoat. Sanding with 220 will knock it down faster than you think. Have you put on all your primer if not try rolling and tipping the last coat to get a better finish and filling in the orange peel. What size knap did you use on the roller or did you spray, that also looks like you almost put on to much paint at one time.
Re: Joe's P19
Posted: Thu May 20, 2010 11:59 pm
by Joe H
Hey Tom,
The Dynex(3/8” nap) roller, (recommended) I put 2 coats on and used 1 gallon of primer, it went on very thick, nothing like the interlux 2000E I used on the OD16, but that wasn't high build. I'll try sanding tomorrow but I have a feeling I'll be sanding most of it off and re-coating, roll & tip or just brushing it on.
Joe H
Re: Joe's P19
Posted: Fri May 21, 2010 12:20 am
It doesn't look normal to me Joe. It's way too thick. I've used Petit before, on my GF16, it didn't look like that :? More like this,...
I've also used S3 high build a few times, and it's never looked like that :doh:
Re: Joe's P19
Posted: Fri May 21, 2010 12:45 am
by Joe H
It doesn't look normal to me Joe. It's way too thick. I've used Petit before, on my GF16, it didn't look like that More like this,...
Yeah, thats what I thought when putting it on, shet, but the stuff was mixed and I had to use it, or so I thought at the time,the only thing I can think of right now contains lots of expletives, so I'm going to to bed, maybe fishing in the morning, sanding in the afternoon.
I feel like going out and sanding it all off right now.
Joe H
Re: Joe's P19
Posted: Fri May 21, 2010 12:50 am
I recommend fishing. Make sure someone is holding the line :wink: Ain't nothing but a thing.
Re: Joe's P19
Posted: Fri May 21, 2010 7:58 am
by cape man
Think you might want something more than 220 grit to start with... :( I'm with Larry. Go fishing first :D
Re: Joe's P19
Posted: Fri May 21, 2010 9:23 am
by Joe H
It's raining this morning so no fishing, I just got in from the garage, I started sanding with the 220 and your right it's just not getting it done so I tried 100 and it's better but gumming up pretty quick so maybe another day of dry time, I don't know, how long does it take to properly cure? I put it on Wednesday and temp and humidity have been good. :doh:
Anyway I have a ice cream social this morning at my Grandsons pre school :D , and then off to the big lot for a stack of 100 grit sandpaper, ugh. :help:
I know "it's just a thing" I don't know about the boat but I'll be getting right this afternoon in the garage. :wink:
Joe H
Re: Joe's P19
Posted: Fri May 21, 2010 10:26 am
by tech_support
never used that primer, but I have sanded orange peel like that on sterling primer. My advise is use 60/80 for just one pass all over the boat, then to 100 or so, then to 220. You have to remove a lot of primer to get it smooth.
If you knew you could get one thin/smooth coat to cover some of that it would save a lot of time and primer. Im trying to think of a better way to say this :| ..... If a smooth coat could be applied to fill in some of the orange peel it would save you from haing to take the orange peel all the way down, that save primer and time.
Does that make any sense :?: :)
Re: Joe's P19
Posted: Fri May 21, 2010 10:50 am
by wegcagle
I like Joel's idea. Run some 60/80 across the boat just to take the top of the orange peel off(don't have to get it completely smooth) Then go back with 2-3 THIN layers of primer and make sure you tip it well after painting. I personally did a 4-6ft section, tipped it quickly and proceeded on. No orange peel on my primer or top coat. After it's dryed a couple more days then go over the boat with 120 grit (at least this was the instructions on my top coat I'm sure different brands have different instructions) then apply top coat. You can always sand the top coat layers down as far as you want to make her pretty. The highest grit I went was 220 and I am very happy with the end results, but some of the OCD people around here have gone MUCH higher, with MUCH more professional results. :lol: 8)
Best part about building a boat is that you work on something until you are happy and tell everyone else they can kiss it :wink:
The boats is looking GREAT Joe. I love the P/C series they are no nonsense tank-like fishing machines 8)
Will
Re: Joe's P19
Posted: Fri May 21, 2010 11:03 am
by cape man
I used 60 grit on mine, and then 120 before the top coat. I am not OCD at ALL, and my finish shows it. Maybe they were just being nice, but no one has ever said "what a lousy paint job". I wanted to fish, not sand!
Re: Joe's P19
Posted: Fri May 21, 2010 2:14 pm
by Joe H
This is really starting to suck, I tried 120 grit and that's just not doing it, it's gumming up in a matter of seconds. Will, I like Joel's idea too, back up to Lowes for 80 & 60 grit, I'll hit it a couple of times and see where I end up, do you guy's think I should let it cure for a couple of days, it seems cured but the sand paper is gumming up in no time at all. :doh:
I used all my primer, 1 gallon! Looks like I'll need more but that will have to wait for payday, I spent all my boat $$ on the Copper Bronze bottom paint and Awlgrip Topside, ouch.
Cape, I did exactly the same on my OD16, it looks pretty good, but I'm going to try for just a little better on this one, maybe.
I'm far from OCD but I have the OD16 to get me out fishing so I can spend a little more time trying to get things right on the P19 , maybe. Ha.
Joe
Re: Joe's P19
Posted: Fri May 21, 2010 2:29 pm
by Joe H
Holy shet, just hit Old Salt status, I been gabbing way too much, old yes, but the only sea salt this Great Lakes fresh water fisherman has had in my face is when I was with Cracker Larry going through Boca Grande Pass, I could use some of that right now!
Joe
Re: Joe's P19
Posted: Fri May 21, 2010 2:33 pm
by wegcagle
Joe, Is the paint wet underneath the hardened outside? (Kinda like that bubble gum you bite and it's juicy on the inside :lol: ) Is that why it's gumming up? If it is then I would definitely let it set up a couple more days until it's good and dry all the way through. Warm it up if you can that'll shorten the time, otherwise take to beer drinking for a few days, order some more primer, and wait for it to get to your house before you restart the sanding.
If you start to get withdrawal you can always start on the console. That should buy you a couple of days anyway :D
Will
Edit: At least it took you 2 boats to get there :lol: I'm still on my first
Re: Joe's P19
Posted: Fri May 21, 2010 4:57 pm
by TomW
Joe it sounds like beer drinking, fishing and honeydew lists :lol: for another day or two while the under layer of that primer drys. It will take extra time with that extra thickness. :(
Re: Joe's P19
Posted: Fri May 21, 2010 8:14 pm
by Joe H
It sure doesn't seem wet underneath, it past the finger nail test but
I think thats it, I'll try to give it a few days not that I'm in a race or anything but I'm falling way short of my goal for this past week, no big thing, I'll try and knock at least 1 thing off the honey do list, :roll:
Time for that drink. :D
Joe H
Re: Joe's P19
Posted: Fri May 21, 2010 8:30 pm
Have ya about 3, then get out the 40 grit. :lol:
Re: Joe's P19
Posted: Mon May 24, 2010 1:23 pm
by mecreature
Its looking very nice..
You could always flip it and come back to it later....
nothing wrong with 40 grit.
Some times slowing your sander speed down a bit will keep the heat down enough so the paper will not get so gummy.. and maybe not.
still looks great.
Re: Joe's P19
Posted: Thu May 27, 2010 8:45 pm
by Joe H
Flipping this beast more the once will not be an option, I took all the suggestions and rolled them into this, I hit it with 80 grit over the entire hull, slowed the 5" orbital sander down to half speed for lots of it, it took 50 disc but I got-er-done, 2 day's later I hit the entire hull with120 grit, another 50 disc plus a few, so I get to the point where I say good enough and I have to get some paint on her, there were a few places where I went right down to the fairing compound so by brother–in-law, Donny, brought over some extra interlux 2000E epoxy primer and I covered those spots, waited another day and sanded those with the 1 piece of 120 grit I had left, all in all, it's looking pretty good, not perfect, but pretty good.
Note: At my brother-in-laws boat works that's all they use is west foam rollers, the yellow ones, and a good quality foam brush to feather or tip after rolling for all the painting they do, wish I would have known that 2 weeks ago, the 3/8's nap roller and not tipping was my down fall with the primer.
I scribe a waterline, we, Donny and I adjusted it 3 times, I measured down 8" for the designed draft and added an 1 ½", took a laser level and marked a few point all the way around the boat and at the bow, Donny took 1 look at it and said no way, he then spent several silent minutes looking at the plans then looking at the boat, walked up to the bow and marked a line about 6" up from BOL from the point I marked earlier (that’s up from the waterline). Now I'm thinking no way, so I printed pictures of Eric's P19, thanks for sending me those pic's Eric, and Fargio's P19 and showed him how high the bow sits up in the water, after the pic's he agreed the bow does appear to be riding high on both, so we lowed the bow point 3", I jacked the front of the boat up so the bow point was in line with the transom point and scribed the theoretical water line, here she is with the Copper Bronze anti foulinng paint on her pretty bottom.
I wasn't 100% satisfied with the finish of the bottom paint but after talking with the company that makes it that's just the way it is, they say it doesn't cure completely until after it's been in the water for awhile, whatever, it's done I'm okay with it.
I was thinking about hitting the sides with 220 grit before I put the Awlgrip on, oh, and west foam rollers and tip with a foam brush fer sure.
Joe
Re: Joe's P19
Posted: Thu May 27, 2010 8:59 pm
by cape man
Nice thorough post. Thanks Joe. Looking much better!
Re: Joe's P19
Posted: Thu Jun 03, 2010 3:12 pm
by Joe H
I put 1 coat of Awlgrip mahogany red on last night, looks more red then mahogany but I think I like it.
I seen a boat built by Ellis Boat Co in Southwest Harbor, ME so I emailed the building asking what color he used and to my pleasant surprise he E-mail me right back telling me the manufacturer of the paint and the color used to paint it, he used claret red but suggested I try the mahogany red seeing I was looking to duplicate the color of he old mahogany speed boats, it's really red, a dark red, maybe I should have stuck to the lighter claret red. :doh:
Anyway, I only have the one coat on her but noticed this morning, I had to check her out before I went into work and it's been bugging me ALL day, that there are a couple of paint runs (2), and I seen in another post where George mentioned a tool to take runs out but can't find the post.( I can't spend to much time looking here at work) :help:
Comments please.
Joe
Re: Joe's P19
Posted: Thu Jun 03, 2010 3:43 pm
by kdog
Looks really good Joe, I like the darker red a lot! I need to get some color on my boat.
Not sure about the name of the tool but it's like a small metal block with a razor blade in it to shave down those runs. Most autobody/paint suppliers should have them.
Re: Joe's P19
Posted: Thu Jun 03, 2010 3:45 pm
by wegcagle
Beautiful Joe.
Why can't you just hit those spots with 220grit before putting on the next coat????
Will
Re: Joe's P19
Posted: Thu Jun 03, 2010 3:50 pm
by kdog
Just found this, it's called a nib file and a run blocker http://autobodystore.com/run_repair.shtml
Re: Joe's P19
Posted: Thu Jun 03, 2010 4:43 pm
by tech_support
I LIKE IT :!:
Re: Joe's P19
Posted: Thu Jun 03, 2010 4:59 pm
by ks8
Nice red. :) That was the color of some of my mahoghany after the epoxy seal coat, but it has since darkened up even more. That color will turn heads. Can't wait to see her all done. :)
Re: Joe's P19
Posted: Thu Jun 03, 2010 6:32 pm
by SmokyMountain
Very Nice Joe. I painted my drift boat a similar color alway get comments. I'm glad someone can finish a task all the way through (faring), unlike me 8O . Looks great!!
Andrew
Re: Joe's P19
Posted: Thu Jun 03, 2010 6:46 pm
by TomW
Joe that is the color I wanted to go with but SWMBO said no. Love it and may it last a hundred years for you. :D
Re: Joe's P19
Posted: Thu Jun 03, 2010 6:54 pm
by cottontop
JOE, i love the red. Did you roll and tip; or spray? It looks that good. John
Re: Joe's P19
Posted: Thu Jun 03, 2010 7:35 pm
by Joe H
Thanks guy's, maybe the red is growing on me, nib, that was it! I guess sanding just sands the whole area and doesn't remove the run unless you take it all the way down to the primer, I may end up doing that anyway, someone else could explain better I'm just doing what was suggested, I plan on using the nib, if I can find one, on the runs and then sand the whole thing with a very fine sand paper and then another coat or 2.
I'll have to admit I took a picture of the good side the other side will require a little more sanding then the side in the picture, ha.
Janet rolled it with a foam roller while I feathered with a foam brush, together we made pretty quick work of it!
I have to wait a day or 2 for the paint to completly dry so I can get back to work on it, it's killing me, it's like, like watching paint dry!
Thanks again.
Joe
Re: Joe's P19
Posted: Thu Jun 03, 2010 8:09 pm
by wegcagle
Joe,
I LOVE that red color. I am now putting that color in the books to use on my next build 8)
Will
Re: Joe's P19
Posted: Thu Jun 03, 2010 8:35 pm
by gstanfield
I like that dark red, looks very classy in my opinion. I'm glad someone found the Nib File link for you, I was busy with school and don't have the freedom to check in very much.
George
Re: Joe's P19
Posted: Thu Jun 03, 2010 10:14 pm
by cape man
Missed the unveiling so a little late in saying what you've already heard....like it...like it a lot.
Re: Joe's P19
Posted: Fri Jun 04, 2010 1:38 am
"There are only two colors to paint a boat, black or white, and only a fool would paint a boat black." -Nathanael G. Herreshoff
What does he know? I like red 8)
Re: Joe's P19
Posted: Fri Jun 04, 2010 2:45 am
by molaine
Hi Joe,
nice build and very cool color. Here in Finland you never, ever see boats that are not either white or blue (ok, wooden boats are with a clear coat)... very boring.
markus
Re: Joe's P19
Posted: Fri Jun 04, 2010 7:28 am
by Joe H
What a family of designers!, wasn't his brother blind?
Hi Joe,
markus
All my boats, and I have had a few, have been white or natural wood, so this was a bold step for me, the boot stripe should cap it off, that will be white, or white and red, or white and black……………………..
Thanks for the comments, the red will stay.
Joe
Re: Joe's P19
Posted: Fri Jun 04, 2010 9:49 am
by jgroves
I like that color red! Beautiful boat and great work!!!
Re: Joe's P19
Posted: Fri Jun 04, 2010 6:23 pm
by steve292
jgroves wrote:I like that color red! Beautiful boat and great work!!!
Ha!! where have you been hiding? :lol: :lol:
Bold colours & bold colour choice is always a head turner, & sets you out from the crowd, you'll get loads of comments with that 8)
Beautiful colour Joe.
Steve
Re: Joe's P19
Posted: Tue Jun 08, 2010 8:22 pm
by Joe H
Thanks Steve, not nearly as bold as yours, I love your colors and your boat.
jgroves, I just seen the boat by Caliber Yachts in your Gallery, I like the red even more, I also like the white transom, makes me wonder what the white transom on mine would look like, my OD16 would have been an FS17 had the design been out, both your boats are something to aspire too.
I had to order more red paint to finish up the sides.
Joe
Re: Joe's P19
Posted: Wed Jun 09, 2010 11:07 am
by mecreature
Looks great. It does take guts to paint a boat red. You will get some gawkers for sure.
Re: Joe's P19
Posted: Sun Jun 13, 2010 10:31 pm
by Aripeka Angler
Joe, I have just got caught up on your build and it looks great 8) I love the red paint :!: Very nice work :)
Re: Joe's P19
Posted: Tue Jun 15, 2010 7:10 am
by Joe H
Thanks Mecreature,
Richard, you beat me to the red, different shades but yours looks great, I'm glad you got the whole paint thing squared away, I have nightmares every time I think abouut it!
I wasn't real happy with the finish so after painting the boot stripe I sanded down the first coat of red almost until there was nothing left, I hope to get the second coat on tonight, I have a picture of the bottom paint on and the finished boot stripe with the red sides sanded down, looks sick so I didn't post it, I might later, I have to re-paint the red ASAP.
Joe
Re: Joe's P19
Posted: Tue Jun 15, 2010 9:36 pm
by Aripeka Angler
Joe, sorry to hear of your paint misfortune! I can't believe you had to sand it off, your boat looked very nice to me in your pictures.
I don't know much about the paint you are using but I have learned by trial and error that thin coats are the way to go. Don't get in too big of a hurry as well.
Continued good luck on your build....
Richard :)
Re: Joe's P19
Posted: Wed Jun 16, 2010 9:24 pm
by Joe H
Not too much of a misfortune Richard, I'm just considering it the first of 3 coats and moving on.
It was to humid to paint yesterday, hopefully tomorrow, I'll post pics when it's done but this is what it looks like right now.
On a brighter note, I took a break the other day to get away from boat building to get out in the boat I built. :doh:
My Granddaughter loves to swim!
Joe
Re: Joe's P19
Posted: Wed Jun 16, 2010 9:38 pm
by gstanfield
Nice to have another boat to get away and refresh when you're building a boat :D What boat is that int he last picture?
Re: Joe's P19
Posted: Wed Jun 16, 2010 9:45 pm
by Aripeka Angler
gstanfield wrote:Nice to have another boat to get away and refresh when you're building a boat :D What boat is that int he last picture?
George, that is an OD-16.
On a brighter note, I took a break the other day to get away from boat building to get out in the boat I built. My Granddaughter loves to swim!
Great picture 8) What is the water temp up there?
Re: Joe's P19
Posted: Wed Jun 16, 2010 9:55 pm
by gstanfield
Water temp is high 40's I think. I haven't checked in a few days now. It may have even reached the 50's in places downstream.
Re: Joe's P19
Posted: Thu Jun 17, 2010 7:50 am
by Joe H
Richard, we were in our bay off Lake St.Clair in between Lake Huron and Lake Erie, the water temp was a cool 72 degree's that day, too cool for Janet and my Daughter but it's getting a little warmer each day, 76 yesterday.
Lake St.Clair is known for it's world class Musky but is also a great fishery for Walleye, Perch, Bass, Pike,,,, well you get the picture.
George, Richard is right, That's my OD16 fishing machine, I built it in 2007 and it still looks brand new and beleive me I use the crap out of it.
Joe
Re: Joe's P19
Posted: Tue Jun 22, 2010 7:14 am
by Murry
All that sanding will only make it a better finish in the end Joe.
Love the boot stripe. :D
Daniel
Re: Joe's P19
Posted: Tue Jun 22, 2010 12:35 pm
by Joe H
Thanks Daniel,
Yeah the sanding was worth every soar muscle, after 3 coats I'm happy with the finish, I sanded the first coat down with a combination of fine grit sandpaper and just lightly sanded the 2nd coat with 380 just enough to scuff her up and take out a few fuzzies that found there way to the surface before it dried, after painting the 3rd coat we shut the garage door in hopes of avoiding anymore fuzzies floating around, it worked but a few little flying bugs still found their way to the sticky surface to make it their last stop, 14 I counted.
My wife Janet rolled the paint on and I feathered it out behind her the process worked out great, we used the yellow foam rollers and a foam brush to feather and this time I only mixed what I needed, the mix ratio with the Awlgrip paint was 2 parts paint 1 part converter and 25-35 % brush reducer or thinner. 2s coat with the second quart, I ruined the 1st quart by mixing it all up at one time, and all the other stuff and I still have some left for touch-ups when I drill all the holes in the hull.
I also climbed underneath and disassembled the jig and frames to make it a little easier to pull it out of the garage and flip, anyone want a disassembled jig for a P19, just kidding I will recycle all of it myself to build the cradle, which will poses another problem, the keel can only be 1-2" off the floor or I won't be able to get it out of the garage when it's done, and that’s only going to give me an estimated 3 to 4" of clearance, estimated I say, I have an 85" opening.
Speaking of flipping I'm planning on flipping the hull this weekend if I can get enough help, anyone going to be in Michigan Saturday or Sunday??? I have fresh Walleye!!!
It actually has to get done this weekend or it may be a little time before I can get back to it, I'm going in on the 30th to have the Carpal Tunnel surgery, the shots didn't last long.
Here's some pictures:
Oh, I know I said I was going to wait on the boot stripe but I could'nt help myself. :lol:
Joe H
Re: Joe's P19
Posted: Tue Jun 22, 2010 12:55 pm
by steve292
That looks fantastic Joe 8)
If I was there I,d help you flip :D
Good luck with the surgery.
Steve
Re: Joe's P19
Posted: Tue Jun 22, 2010 1:22 pm
by cape man
Wow!
Re: Joe's P19
Posted: Tue Jun 22, 2010 1:54 pm
That's beautiful Joe 8) Mail me a ticket and I'll be on my way :wink:
Re: Joe's P19
Posted: Tue Jun 22, 2010 5:57 pm
by Aripeka Angler
Sweet paint job Joe :!: Even with the pain you have done a fabulous job :!:
Good luck with your procedure. Sandi sends her well wishes and says hi to Janet. Keep up the great work on the boat 8)
Richard
Re: Joe's P19
Posted: Sat Jun 26, 2010 5:13 pm
by Murry
Very nice Joe! :!: I love that color. :D
How much unmixed color did that take Joe?
Re: Joe's P19
Posted: Sat Jun 26, 2010 10:09 pm
by Joe H
Thanks guy's the paint did come out nice, the awlrip is a very nice paint to work with. I built a frame around the boat today to help in the flipping, I had my Grandson with me so it took all day, living on the canel you can't leave him outa sight for even a second, he's 5 and on the go 100% of the time but we managed to get it done and I have a few buddies comming over tomorrow morning to help me flip it. I wish I could afford to fly you all out and do a little Musky fishing, we could have a Great Lakes Boat meet!
Murry, I used just under 1 1/2 quarts before mixing and that gave me 3 coats, as good as it came out they say awlgrip is even better sprayed and after seeing how nice you priming job came out, well I can't wait to see the final coat.
Tomorrows the day!
Joe
Re: Joe's P19
Posted: Sat Jun 26, 2010 10:24 pm
by sitandfish
Joe H wrote:Thanks guy's the paint did come out nice, the awlrip is a very nice paint to work with. I built a frame around the boat today to help in the flipping, I had my Grandson with me so it took all day, living on the canel you can't leave him outa sight for even a second, he's 5 and on the go 100% of the time but we managed to get it done and I have a few buddies comming over tomorrow morning to help me flip it. I wish I could afford to fly you all out and do a little Musky fishing, we could have a Great Lakes Boat meet!
Tomorrows the day!
Joe
Can you put him in some sort of bubble that floats?
Re: Joe's P19
Posted: Sun Jun 27, 2010 5:24 am
by sideslippa
Very nice looking paint job there Mate. Top Job 8)
Steve.
Re: Joe's P19
Posted: Sun Jun 27, 2010 6:08 am
by ericsil
Joe, you are giving me a bad case of finish envy. If you keep going like that I may have to invest in some more sandpaper. Thanks for the tip on the Awlrip. I have not tried that particular brand, but I will keep it in mind. Good luck on the flip and the rest of the build.
Re: Joe's P19
Posted: Sun Jun 27, 2010 7:39 am
by Joe H
Good morning Mate! (always wanted to say that, I think I'll say it all day)
IT"S FLIPPING DAY! Wish me luck.
Eric, I was just getting ready to send our a search party to look for you! I read your post on the fin, you had mentioned the bow rides high, that's why we build the strakes like we did, I hope it works.
Did I mention it's flipping day!
Joe H
Oh, where can I get one of those bubbles, the little guy spent the night last night, I'm beat.
Re: Joe's P19
Posted: Sun Jun 27, 2010 10:44 am
by Murry
Tomorrows the day!
Joe
Good Luck with the flip Joe. I'm excited for you and excited to see her right side up for myself.
Thanks for the reply and compliment. The only thing about using awlgrip that has me nervous is that they reccomend not wet sanding and buffing. What you see after painting is what you get. It's tough paint though, Sterling and Awlgrip are right up there together. Very good low maintenance marine finishes.
I hope mine shines like yours.
Re: Joe's P19
Posted: Sun Jun 27, 2010 8:56 pm
by TomW
Great looking job on the paint Joe! Good luck on the surgery, hope it releaves the pain like my knee surgery did! :D It's 6 wks and I'm still not up to full speed yet though. :?
Re: Joe's P19
Posted: Mon Jun 28, 2010 8:59 pm
by Joe H
Flipped the boat yesterday, when I was posting them to my Gallery I didn't like the order and when I tried to delete them I inadvertently deleted my whole freaking gallery, I already e-maile Joel, maybe he can get it back.
If not here's where I start over.
Anyway the flip went great.
The rest are in my NEW freaking gallery:
http://gallery.bateau2.com/thumbnails.php?album=1193
Joe H
Re: Joe's P19
Posted: Mon Jun 28, 2010 10:01 pm
by ks8
Shiney... ooooooo....
:D
Re: Joe's P19
Posted: Mon Jun 28, 2010 10:27 pm
by wegcagle
Great job on the flip Joe. She's a beautiful boat.
Will
Re: Joe's P19
Posted: Tue Jun 29, 2010 12:36 am
by TomW
All right Joe! Congrats that step is done and now it's all uphill from there. You start at the keel and build up hill. :lol: Again good luck on the surgery Wednesday.
Re: Joe's P19
Posted: Tue Jun 29, 2010 9:28 am
by topwater
Joe the paint looks great :!:
Re: Joe's P19
Posted: Wed Jun 30, 2010 7:41 am
by cottontop
Joe, The boat is beautiful. Did you have enough flippers? Hope your surgery goes well. Are they doing it (I know I'm going to spell this wrong.) orthoscopically? That's how mine was done. Very quick recovery time. Nearly no pain. Your grandson sure is handsome. We had just one, he's nearly 4 and now have one 8 weeks old annd my daughter is due for her 2nd son anytime between now and July 29th. I'm going to have a boatload of fishermen and looking forward to it. John
Re: Joe's P19
Posted: Fri Jul 02, 2010 6:20 pm
by Joe H
thanks for the well wishes, the surgery went fine, john, they used the knife, he said much cleaner that way. :doh:
typing with one hand sucks so I'll keep it short, the boat looks great flipped I can't wait to get at the inside but will have too for a least a couple of weeks, I have 2 -3 weeks off of work but I'm bored already, I have to find someone to take me fishing, even if I can't reel a fish in I gotta get out!
I do have plenty to do re-building my gallery, looks like it's gone for good, but just this little typing takes way to long.
See ya
Joe
Re: Joe's P19
Posted: Sat Jul 03, 2010 2:23 pm
by TomW
Glad everything went well Joe. Wishing you a speedy recovery! :D
Re: Joe's P19
Posted: Sun Jan 23, 2011 10:15 pm
by Joe H
I can't believe it's been just over six months since I worked on the P19, it wasn't just the operation on the hand, life, fishing, work and fishing just got in the way, and of coarse spending time with my beauitiful Grandchildren, but it was just to damn cold to go out fishing this weekend, I've been out fishing in -11 degrees with a smile on my face but this weekend was just too cold, 6 above this morning, I must be getting old.
Anyway back at boat building yesterday and today, I filled all the inside seams yesterday and taped them today, it felt great to get back at it, got epoxy back in the blood, now lets see if I can finish this baby!
Joe H
Re: Joe's P19
Posted: Tue Jan 25, 2011 7:36 am
by cottontop
I am amazed at how absolutely beautiful the boats built on this site are. Joe, your work is magnificient. The red/burgundy is really going to bring in the lookers and then your going to win them over with your fine craftsmanship. John :P :P
Re: Joe's P19
Posted: Tue Jan 25, 2011 8:21 am
by topwater
That is one awsome paint job :!: Good to see you are back at it Joe.
Re: Joe's P19
Posted: Tue Jan 25, 2011 8:59 am
by wegcagle
NIce work Joe. Glad to see you back at it.
By the way are you bracing the sides to prevent flairing and drooping? Just a thought.
Will
Re: Joe's P19
Posted: Wed Jan 26, 2011 8:07 pm
by Joe H
Thanks guys,
Will, funny you should mention that, I measure across where each station is going and I'm pleased/surprised that it's right on every time, but... I think your right :) I'm going to make up some bracing and the minute after I glass the inside I will connect the braces, that should insure it stays where it should as it dries, thanks.
Oh yeah, I got the transom all taped yesterday, I was going to glass the rest of the interior this coming weekend but got an invitation to fish Lake Simcoe just north of Toronto so it may have to wait.
Joe H
Re: Joe's P19
Posted: Sat Mar 26, 2011 7:20 am
by Joe H
Inside glassed.
Joe H
Re: Joe's P19
Posted: Sat Mar 26, 2011 8:09 am
by Aripeka Angler
Your boat is looking nice Joe!! Very clean work.I also really like the shape of that hull :wink:
Hope you get some warmer weather up that way soon...
Re: Joe's P19
Posted: Sat Mar 26, 2011 8:14 am
by Joe H
Thanks Richard, did you see my pic in the Boat Builders Meet Thread, man it's cold here right now.
Joe H
Re: Joe's P19
Posted: Sat Mar 26, 2011 9:04 am
by topwater
Looking good Joe, i cant wait to get to that point and start laying down some glass again :!:
Fairing sucks :wink:
Re: Joe's P19
Posted: Sat Mar 26, 2011 11:11 am
by Steven
That looks great Joe. Wish it wasn't so hot down here. :) I'd love a pretty dark color, but it would just be too hot.
Re: Joe's P19
Posted: Sat Mar 26, 2011 6:56 pm
by Aripeka Angler
Joe H wrote:Thanks Richard, did you see my pic in the Boat Builders Meet Thread, man it's cold here right now.
Joe H
Joe, I did see the picture with all the snow. That's crazy!! If you ever need to get out of the cold, we have an empty guest house. Look forward to seeing you and Janet again at Boca :)
Re: Joe's P19
Posted: Sat Mar 26, 2011 8:23 pm
by Larry B
Boat is looking nice there Joe, Can't wait till I can see the finished product, She is going to be nice. :D
Re: Joe's P19
Posted: Mon Mar 28, 2011 12:20 pm
by Joe H
Thanks Guy's, I placed the stringers in yesterday, pic's to follow.
Richard, I'm so close to taking you up on your offer, this cold weather is really starting to get the better of me, the damn Bay was frozen over again this past weekend, people were out there ice fishing all over again, not me, I refuse.
Looking for a way.
Joe H
Re: Joe's P19
Posted: Mon Mar 28, 2011 7:00 pm
by Joe H
Stringers in, I spent a fair amount of time making sure they were all perfectly aligned and level, proceeded to spot glue the center 2 with a mixture of epoxy and wood flour from stern to bow, I stepped up in the front to better position myself for the last bit of glue, slipped and fell and knocked all four stringers out of position, I sure am glad no one was watching, after a few choice words I put them back into position, marked their location and finished spot gluing them down, the white tape was put in to act as a dam to stop the glue from running.
Now I'm debating on whether or not I should glue the outboard stringers down tonight or should I remove them and finish gluing and glassing the inboard one's first, seems like that would give me more room to work.
Joe H
Re: Joe's P19
Posted: Mon Mar 28, 2011 7:14 pm
by Aripeka Angler
You are on a mission Joe. Looking good :)
It's a standing offer Joe. Anytime you ever need a break from the cold let me know. It was 88 here yesterday. Jumped in the pool for a half hour. We had 5 inches of rain today and it is still pouring, not sure what is up with that :doh:
Re: Joe's P19
Posted: Wed Mar 30, 2011 8:16 am
by Joe H
I decided to take the day off of work today, woke-up with a migrain, took some meds and now the wife wants me to go shopping with her, ha, I didn't take that many med's, I'm heading out to the garage to putt's around on the boat or heading to Cabela's to pick-up some fishing supplies for the spring walleye run, I'm in a tournament on April 16'th and 17'th, need more stuff.
Also read my boat building instructions, say I'm to put the stringers and frames in first then start glassing, I have the stringers but need to cut all the frames, maybe today.
Joe H
Re: Joe's P19
Posted: Wed Mar 30, 2011 9:55 am
by Crazy Terry
I am following your thread Joe.
Your build is looking great. That looks like it will be a perfect walleye boat.
I can't wait to get started on mine. But I have a lot to do just to get ready to begin. And the purchasing of materials is going slower than I would like.
Any way yours is looking good. Keep up the good work. :D
Re: Joe's P19
Posted: Wed Apr 06, 2011 9:35 pm
by Joe H
More Pic's, some frames temporarily installed, I hope to get them all aligned, leveled and spot welded in place this weekend.
Joe H
Re: Joe's P19
Posted: Thu Apr 07, 2011 12:04 am
Nice :!: That boat keeps looking bigger and bigger :D
Dang Joe, only 8 weeks to go until yall get to see me again , and I get to see yall again too :D We're going to get a tarpon this year, hold on to your stomach :lol:
Re: Joe's P19
Posted: Thu Apr 07, 2011 6:46 am
by SmokyMountain
Looks great Joe, glad to see you back at it 8) .
Re: Joe's P19
Posted: Thu Apr 07, 2011 7:00 am
by cottontop
That is one biggggggggg boat Joe. Hope you get to feeling better. John
Re: Joe's P19
Posted: Thu Apr 07, 2011 7:08 am
by Joe H
Dang Joe, only 8 weeks to go until yall get to see me again , and I get to see yall again too We're going to get a tarpon this year, hold on to your stomach .
Man I can't wait!!! I hope you have room in your boat we have a lot of people coming out this year, I just want to be close when someone hits into one of those monsters, that reminds me, I have to get on-line to get my FL fishing license, hell I have to get my MI license! I might show up on your door step if this weather doesn't break, Richard already has me thinking about jumping in my car and heading down south, 8 more weeks, 8 more weeks.................. 8)
Joe H
Oh yeah, the boat, I have to re-cut all the frames because the first set were just molds from particle board and the dimensions are for all the full size molds with the individual pieces taken off of them, I'm having a hard time transposing the separate pieces to the plywood like the layout sheets show, I have the molds drawing up on CAD so I was thinking I could draw the smaller parts on those, apply all the dimensions and move it to the layout sheets with set-up dimensions, think this will work? There has to be an easier way? hell I don't know if I understand what I just asked, I'll draw pictures later today, at lunch time of coarse, and show you what I mean.
My guy's are asking work related questions already, can't they see I'm busy! :)
Thanks Andy, Thanks John, you guy's are up early!
Re: Joe's P19
Posted: Thu Apr 07, 2011 8:21 am
by topwater
The boat looks good Joe :!: Boy when you flip them over they sure get big.
I cant wait to get to this point, i dont know how much more of this sanding i can take :help:
Re: Joe's P19
Posted: Thu Apr 07, 2011 9:20 am
by ericsil
That boat is looking really nice. You can see how come the hull is so strong when you look at the geometry of those stringers and bulkheads. Good luck with all the epoxy and glass tape around the stringers. I thought that was probably the ugliest part of the build. My back hurts just being reminded about it, especially the part when I tripped with a full cup of epoxy in my hand.
Re: Joe's P19
Posted: Thu Apr 07, 2011 12:09 pm
by Joe H
Topwater, mine is only a 19' wait until you flip that 23', you have to be real close to flipping?
Eric, thanks for your response on frame "C" and I will add a little width for the decking to accommodate the rubrail. :roll:
The P19 is a much bigger boat but has less fishing space then my OD16, but I think the Wife and Grandkids will be a little more comfortable in the P19 with someplace to lay their heads and a head, plus I'll like it for night fishing and longer excursions.
Now that I'm back to work on the boat that's all I can think about well I'm here at work is getting home and working on the boat!
Back to work.
Joe H
Re: Joe's P19
Posted: Thu Apr 07, 2011 1:46 pm
I can't wait either. I'm a lot farther south than you are, but this winter just hasn't quit. We've been in the 30s the last 3 nights, had a frost yesterday 8O You've got priority space, you're already a veteran on No Excuse in Boca Grande pass :lol: There are lot of boats coming this year too, along with people 8)
Good reminder on the fishing license, mine is almost expired too. It's quick and easy online at http://myfwc.com/license/recreational/s ... r-fishing/
Re: Joe's P19
Posted: Fri Apr 08, 2011 8:27 am
by topwater
Joe i am not even close yet, getting ready to do the fourth round of fairing on the bottom and transom,
havent even started on the sides yet 8O I can only sand about 2.5 hours at a time and then my
wrist swells up and i have to stop. This is the last round its time to say good enough and move on.
Re: Joe's P19
Posted: Fri Apr 08, 2011 10:22 am
We all reach that point :lol: One thing I have learned though is to never make the good nuff decision at the end of a day when you are tired, sore and disgusted. Back off, let it rest a couple of days, check it out again with a fresh mind and body. Then if it's still good nuff, it's time to move on. That's how I do it anyway :D
Re: Joe's P19
Posted: Wed Feb 01, 2012 8:17 pm
by Joe H
Time to dust this one off!
I was finally able to get back to work on the boat after about 6-7 months of down time, a couple of things had gotten in the way of me physically able to do much of anything except sit in front of my computer and work. A week after getting home from Boca Grande I ended up in the hospital, I had heart stents put in back in 2005 and scare tissue ended up clogging one of them almost 100%, luckily they were able to clean it up pretty good, then, as if that wasn't enough, 3 weeks later my shoulder finally gave out and I had to have major surgery, that didn't go so well, the arthritis had already destroyed the ball joint and socket, the surgeon did what he could cleaning it up but I only have about 60% of motion back at this point, it sucks getting old but I can't let it hold me down anymore. I've been walking 3 miles a day and eating much healthier, lost 10lbs and working on more, best thing is I'm back to working on the boat, I think that's about the best therapy one can do, mentally and physically.
Well enough of my issue's.
Some pics of my progress over the last couple of weekends.
Got the stringers glued and taped.
Cleats installed.
Next, I'm not sure? Ha. :D
Joe H
Re: Joe's P19
Posted: Wed Feb 01, 2012 8:30 pm
Love ya Joe, glad to hear you are back on the mend. :D
Did I scare you that bad in Boca Grande Pass 8O
You do have a lot of choices left on what to do next :lol: Take care my friend. Did you get a pass for the Keys in June?
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:01 pm
by Joe H
No way man, Something must have been up before we even got there.
Not yet, but one never knows.
Thanks Larry, love you too! :)
Joe H
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:10 pm
by peter-curacao
Joe H
LOL http://www.youtube.com/watch?v=NNC0kIzM1Fo
great build btw! 8)
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:11 pm
by peter-curacao
Joe H
LOL http://www.youtube.com/watch?v=P2-VGDF4 ... re=related
great build btw! 8)
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:18 pm
Tom Jones :help: :help:
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:22 pm
by peter-curacao
Cracker Larry wrote:Tom Jones :help: :help:
You have two options ( by accident) go for the first one :wink:
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:23 pm
by Joe H
:lol: :lol: :lol:
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:24 pm
I hit it first, John Paul young is better, but not much :lol:
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:33 pm
by peter-curacao
Cracker Larry wrote:I hit it first, John Paul young is better, but not much :lol:
Okay okay alternatives here :lol: even in German :lol:
http://www.youtube.com/watch?v=RT_u6w7gq0U
http://www.youtube.com/watch?v=nA6g-KJWO7Y
http://www.youtube.com/watch?v=FQhrjNdTOBo
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:40 pm
by Aripeka Angler
Wow Joe, I didn't know you were sick! Man I'm glad you are on the mend 8) We're loving you here too my man! Sandi sends her best to you and Janet as well. Your boat looks great! We always have room for y'all on the hill if you want to escape the cold :D
Re: Joe's P19
Posted: Wed Feb 01, 2012 9:58 pm
by Joe H
Thanks Richard,
That's the funny thing, I never felt sick.
I'm working on getting down there in the soon, even if it's just the Key's, but you know we will have to visit Mom in Zephyrhills if we're in Fl, we will certainly get together then.
Joe
Re: Joe's P19
Posted: Thu Feb 02, 2012 8:32 am
by topwater
Joe glad to see you are feeling better, you have to get to the keys the fishing there is wicked sick :D
I have the same problem with my wrist,elbow and sholder. Now book your flight and get down there :!:
Oh yea the boat looks great.
Re: Joe's P19
Posted: Mon Feb 06, 2012 12:21 pm
by Joe H
Thanks John, I'm working on it!
Re: Joe's P19
Posted: Sat Feb 18, 2012 9:35 am
by Joe H
I've been cutting out the parts as I go but got a little carried away through the week and cut a bunch of parts.
The boat has sole, well just temporarily, dry fitted just to see and sure enough had to trim them up to fit.
I used my buddies laser level to mark the lines for the cleats for the sole in the cuddy cabin.
The heats on in the garage so I better head out and get some work done before the wife finds something else for me to do.
Oh,does anyone know the typical height of a porta potty, that will determine the the sole height in the cabin.
Joe H
Re: Joe's P19
Posted: Sat Feb 18, 2012 3:11 pm
by peter-curacao
Looking good 8)
Height porta potty 12" to 15"
Re: Joe's P19
Posted: Sat Feb 18, 2012 6:25 pm
by Joe H
Thanks Peter, I'll use the 15" just to be on the safe side.
Your boats coming along great, I went back through your thread to see how you built your gunwales, I want mine to look as nice as yours.
Joe H
Re: Joe's P19
Posted: Sat Feb 18, 2012 6:30 pm
by peter-curacao
Joe H wrote:Thanks Peter, I'll use the 15" just to be on the safe side.
Joe H
Thanks Joe , If you go for the 15" put your sole at 16", because the 15" potty's are slightly higher as 15"
Re: Joe's P19
Posted: Sun Feb 19, 2012 8:12 am
by cape man
Haven't been paying much attention here lately. The boat looks fantastic!
Re: Joe's P19
Posted: Sun Feb 19, 2012 9:11 am
by Joe H
Thanks Craig,
The natives are getting restless, wife, mother-in-law, daughter and grandson, getting ready for church, I better get out to the garage now before they try sucking me into it! :lol:
Joe H
Re: Joe's P19
Posted: Sat Mar 03, 2012 11:46 pm
by Joe H
My first attempt with foam didn't work out as I thought it should, the foam was supposed to fill 8-9 cubic ft, the area I show in the picture measures 6.2 cubic ft and it didn't even fill that.
I heated the garage up to 65 degree's but I'm thinking it must have been cooler inside the hull of the boat between the stringers causing the foam not to expand as much as it should have.
Fuel Tank
Joe H
Re: Joe's P19
Posted: Sun Mar 04, 2012 8:46 am
by topwater
Joe try putting the cans in hot water for a while , everybody says it works better the hotter it is .
Re: Joe's P19
Posted: Sun Mar 04, 2012 9:05 am
by wadestep
Hey Joe -
I also didn't get the expansion I wanted, even in 90 deg weather. However, I discovered (towards the end of the pouring) that pouring large batches into one spot caused significantly better expansion that pouring a large batch and spreading it out over a big area. IE - kinda like epoxy, a bunch of liquid foam in one spot will kick off much faster/better, and the exothermic reaction will really help with the expansion. Then just use the cut-offs in another compartment.
wade
Re: Joe's P19
Posted: Sun Mar 04, 2012 10:44 am
by Joe H
Hey John, I stored it in the house to keep it warm but I will try heating it up a bit.
Wade, that might have something to do with it too, i poured about 4 plastic cup fulls in each box and spead it around, maybe not the best thing to do.
I'll try both idea's because I'm not thrilled about having to spend $500 more for foam.
Joe H
Re: Joe's P19
Posted: Mon Mar 05, 2012 7:46 am
by topwater
Joe let us know how it works out , i'll be right behind you in a month or so . Hope it warms up some
before i have to foam my boat :help:
Re: Joe's P19
Posted: Mon Mar 19, 2012 1:03 pm
by mecreature
I checked in on your build a few times during your down time.
Re: Joe's P19
Posted: Mon Mar 19, 2012 8:00 pm
by Joe H
Thanks mecreature, feels good getting back into it.
I managed to finish pouring the foam and putting the floor in this past weekend, 4 more gallons of foam and it still wasn't enough, but good enough. The glass guy said that 9 cubic feet of foam expansion is in free state, 6.2 cubic feet between the stringers is about right for 2 gallons, whatever, it's done and covered.
What do you think, do I need to glass the whole sole?
Joe H
Re: Joe's P19
Posted: Mon Mar 19, 2012 8:26 pm
by peter-curacao
Nice 8) I would put a light woven over it, very easy and fast to do
Re: Joe's P19
Posted: Tue Mar 20, 2012 8:09 am
by topwater
Joe i plan on glassing mine .
Re: Joe's P19
Posted: Tue Mar 20, 2012 8:12 am
by icelikkilinc
Not for strength but for durability and protection.. I would..
Re: Joe's P19
Posted: Tue Mar 20, 2012 12:35 pm
by Joe H
Yep, sounds like a plan, I just didn't want to use the 12oz, seemed like too much, would 4 or 6 oz be enough or even lighter?
Joe H
BTW: For future refererence, I'm short 2 sheets of 3/8 ply, the nesting plans need to be updated, it's as if the CAD guy scaled some peices down just to fit it on the 4X8 Sheet. :doh:
Re: Joe's P19
Posted: Tue Mar 20, 2012 1:15 pm
Joe H wrote:. . .
The nesting is tight but it works, nothing is scaled down.
Which part do you think was scaled?
A CNC kit will require more plywood because of the width of the router bit: 1/4" for each piece when you have up to 10 pieces lined up on the same sheet = 5" (2 edges) but if you cut with a jigsaw, it fits.
Re: Joe's P19
Posted: Tue Mar 20, 2012 4:23 pm
by Hope2float
Joe I would definitely glass the sole. The 6oz will be perfect. This will stop any checking or blistering. It seems like the wood is not as good as claimed, Not directed at Bateau but the manufactures. I had multiple coats of epoxy on that boat one day of rain, let it sit walla checking.
Dave
Re: Joe's P19
Posted: Tue Mar 20, 2012 6:39 pm
by Joe H
On the nesting plans check out the stringers on the top 2 sheets of the 3/8 ply and the Motor well bottoms, no big deal, I need at least one more sheet for the seat boxes anyway. (P19 # D246/2)
But I'll bet ya a 6 pack of Canada's finest beer to a 6 pack of original Belgium Beer that I'm right! :)
(I spent a few months in Genk Belgium, no better beer in my opinion.)
Hope2float
I didn't even think about any checking or blistering, good point. I keep my boat sitting in the canal out back in the sun and weather for 6 months out of the year, best to protect.
Joe H
Re: Joe's P19
Posted: Mon Mar 26, 2012 10:23 pm
by Joe H
I picked up 2 more sheets of 3/8 ply this weekend, 1 sheet will be used for the seat boxes and I was able to use the other for the pieces that didn't fit on the original 7 pieces of 3/8 ply called out in the BOM.
You can see the difference in the stringers from the original nesting plans to what I drew up on CAD from the dimensions, plus take a closer look at the motor well bottoms, they are also shown smaller on the nesting plans the actual.
No big deal but bottom line is you will need 1 more piece of 3/8 ply then what is called out in the BOM and shown on the nesting plans for the P19.
Joe H
BTW: I glassed the whole sole this past weekend too, looks good, pics to follow.
Re: Joe's P19
Posted: Sun Apr 01, 2012 9:18 am
by Joe H
I've decided to eliminate the hard cover, thanks Cedarock, ha, BTW: your GF14 is looking good,
I've been tossing this idea around for awhile.
I would like to achieve this look, my dream boat. (anybody know anything about it)
Okay, I know I should have just built the CX19.
Joe H
Re: Joe's P19
Posted: Sun Apr 01, 2012 9:34 am
by topwater
Joe kinda looks like a dyer 29 or a seaway, eastern. Love that look . Northeast open bass boat.
Take a look at the dyer 29 and you always put a soft top on like theirs on sunny day or rain.
LOVE IT :!: I had a pic of a nv 23 open that looked the same , it mite be in my gallery , but
it was done almost the same.
Re: Joe's P19
Posted: Sun Apr 01, 2012 7:40 pm
by Happychappy
Doing the same to my HM19, I got the CX19 upper cabin section plans no charge included with with my plans (some mods required). I renamed it a HMX19. I built a model of the modified boat, see my album, listed under HMX19. I love the look of the soft cover too.
Re: Joe's P19
Posted: Sun Apr 01, 2012 9:12 pm
by cedarock
I think that would look great Joe......look forward to seeing the progress. Looks great!
Re: Joe's P19
Posted: Sun Apr 01, 2012 9:28 pm
by Joe H
The dyer 29 is one sweet looking boat, got some good idea's, thanks John.
Happychappy, I like the look, anymore progress? Anymore pictures?
I was out in the garage working most of the day today, finished the floors in the motor well and the back 2 compartments and the sub flooring in the cabin area, I'm out of epoxy, woodflour, and have very little fiberglass tape left, putting in the floors really sucked up the supplies, Eric, you might be right, this boats going to be a little heavy at this rate. Time to order more stuff.
Joe H
Re: Joe's P19
Posted: Tue Apr 10, 2012 12:32 pm
by Joe H
Well got a little work done on the boat in the last few days,
Cabin sub-floor:
Cabin floor:
In construction:
Topside, just dry fit, I cut all the panels 1" wider, over laid them on the boat, traced from the underside and re-cut them, so glad I did, thanks for the heads up Eric & Chicagoross, still had to re-cut the bow piece even wider!
Here's a preview of the modifications I'm making.
I guess I'm not going to be able to call her a Pilot House 19 anymore! Ha.
Joe H
Re: Joe's P19
Posted: Tue Apr 10, 2012 3:57 pm
by wegcagle
Great work Joe. She's a beauty for sure 8) I really like the modification. 8)
Will
Re: Joe's P19
Posted: Tue Apr 10, 2012 4:43 pm
by chicagoross
I like it! Have you designed the windshield yet? I'm tyhinking a 3 panel instead of 2, so you can hinge the center easily and flip it open for for'd access and ventilation.
Re: Joe's P19
Posted: Wed Apr 11, 2012 1:08 pm
by Joe H
Thanks Will, we like it too.
Ross,
I haven't given that any thought but I was trying to achieve this look:
I'll have to take a look at it tonight, I'm going to incase the entire upper portion in teak or mahogany for strength and looks, a third panel might add to much complexity for this simple mind!
BTW: This change makes my comments about the nesting plans kinda moot, the plans still should be updated but not my concern anymore.
Joe H
Re: Joe's P19
Posted: Wed Apr 11, 2012 7:59 pm
by Joe H
Ross,
How high did you make your boxes for the helm seats? The plans call out for 18", seems a little high unless you like sitting on plywood, ha.
Thanks.
Joe H
Re: Joe's P19
Posted: Wed Apr 11, 2012 8:20 pm
by tobolamr
Hey - good idea with the cardboard to protect your sides while working on the interior!
Re: Joe's P19
Posted: Wed Apr 11, 2012 8:57 pm
by Joe H
by tobolamr » Wed Apr 11, 2012 7:20 pm
tobolamr,
I think the cardboard has saved me more then once, can't take credit for it though, someone on the forum here suggested it, are the walleye running up there yet?
Joe H
Re: Joe's P19
Posted: Wed Apr 11, 2012 9:11 pm
by cedarock
That is looking sharp Joe! I can't remember how tall my seat boxes are but they are perfect for me with a 34 inch inseam. I think they are close to 18 inches tall with a seat mounted. I will measure them this weekend. I find myself standing most of the time when running.
Re: Joe's P19
Posted: Thu Apr 12, 2012 1:40 am
by chicagoross
Mine are tall enough that you need a footrest; tall enough to see over the cabin. And I'm not actually joking! :) I know they changed a lot from what the plans called for, but measuring mine doesn't do too much good.
There's at least an inch for the seat swivel. My seats actually were about 2 1/2" tall (butt to swivel) yours may vary. Either make them tall for now or just wait until you're further along. You will need the windshield cutouts mounted, then start with about 16 or 18", and your actual seat and swivel(if available) and then stack 2x4's, scraps of ply, phone books etc. until you are getting the picture through the windshield that you want.
Re: Joe's P19
Posted: Thu Apr 12, 2012 12:03 pm
by ericsil
I am only 5'-7" tall. By the time I thought I had a good line of sight through the windshield I needed a short foot rest to put my feet on. I think you are just going to have to experiment, as suggested, until you get the position you like. That is one of the advantages of building your own boat.
Re: Joe's P19
Posted: Thu Apr 12, 2012 12:45 pm
by Dog Fish
Joe, she is starting to come together and looking mighty fine, I bet the anticipation is starting to grow. You are doing a professional job for sure. I like your cradle too, well supported. Keep up the terrific work my friend.
Brian...........I like your boat Joe.......... 8)
Re: Joe's P19
Posted: Thu Apr 12, 2012 8:32 pm
by Joe H
Thanks guys, I wanted to build the boxes this weekend and install then before I put any fairing down, the bottom of my windshield will be at the same hight as the HM19 and the P19 as designed.
It's like the biggining of the build all over again Brian, I can't wait to get out there and get some work done on her, problem is I can't afford to get everything I need to keep rocking like right now! ha. And of course there's family, fishing and work that keeps getting in the way. :D
Life is GOOD.
Joe H
Re: Joe's P19
Posted: Fri Apr 13, 2012 9:05 am
by fastlane
Joe,
When i first saw what you wanted to do i was like WTH.. but now that i look at it i LOVE it. I wonder if its to late to get the sawzall out and modify my P21 :)
Re: Joe's P19
Posted: Fri Apr 13, 2012 11:00 am
by Joe H
FS,
Never to late, take a look at what cedarock did with his HM19! Looked great before, Looks great now and better suits his needs.
Joe H
Re: Joe's P19
Posted: Fri Apr 13, 2012 11:12 am
That looks great, Joe 8) Good modification!
Re: Joe's P19
Posted: Fri Apr 13, 2012 5:09 pm
by mecreature
Looking great. I am curious if your modifications was more fashion or function .
Re: Joe's P19
Posted: Fri Apr 13, 2012 10:08 pm
by Joe H
Thanks Larry, man I sure am gonna miss not seeing you guys down south this year.
mecreature,
I really liked the look of the hardtop, I even went as far as putting the rear frame up but kept hitting my head on it, I couldn't see keeping it there as a permanent structure, so it started out as purely function but now, after seeing it partly designed, fashion ain't so bad!
Joe H
Re: Joe's P19
Posted: Sat Apr 14, 2012 9:54 am
Sure going to miss you and Janet also. It won't be the same without yall :-( Are you sure you can't come?
Re: Joe's P19
Posted: Sun Apr 15, 2012 2:23 pm
by ericsil
Your aggressive redesign is a beauty. What are you going to name it? You have got me thinking about my next round with the P19. Since I no longer have to tow down I95, I can open things up a bit to be a better picnic boat. As you point out, also getting rid of that head knocker at frame D would be extra nice. Keep the cards and letters coming, I think you are really onto something.
Re: Joe's P19
Posted: Mon Apr 16, 2012 10:06 pm
by Joe H
Thanks Eric,
What's the deal, are you not towing the boat to Maine anymore? Or the other way around?
I plan on building it up with the 1/4 ply as in Jacques plans with my design deviations and then incase it in Mahogany, my brother and brother-in-law are both accomplished wood workers and have some nice ideas, as do I, so it should be interesting to see what we come up with, everything's subject to change at this point but the head banging frame "D" was a no brainer,OUT, we'll keep you posted!
Joe H
Re: Joe's P19
Posted: Tue Apr 17, 2012 6:22 pm
by ericsil
No more towing Joe. The boat stays in Maine year-round.
Re: Joe's P19
Posted: Mon Apr 30, 2012 12:43 pm
by Joe H
I don't know if Dan is still out there (dlr280z) but I just wanted to say thanks for the Quickfair, George you may remember, Dan sent me the 3 quart kit of Quick fair a couple of years back and I just got around to using it!
For the outside hull I used West System Products for fairing so this was my first experience with Quickfair, I can tell you it's the BEST system I have used yet, went down smooth with no rolling and sanded down much easier then the 410 west system (still sanding though), I managed to cover all the inside corners with one coat before I ran out, gonna need more but what a nice product to work with.
Thanks again.
Joe H
Re: Joe's P19
Posted: Fri May 11, 2012 3:11 pm
by Joe H
I'm getting the OD16 Ready to drop in the water, it amazes me how dirty it gets just sitting under a cover all winter, anyway I was almost done scrubbing her down when a storm moved in and I had to pull her in the garage, so OD16 meet P19.
I also installed a scupper on each side of the OD16, I think they look like shit but hopefully they will do their job while she's in the water for the next few months, plus I'm going on the 5th season for the antifouling paint, I don't know how long the antifouling paint is supposed to last but last year it was just fine, hope to get another season without any algae growing on the bottom!
Going night fishing for Walleye tonight with my brother, I hope to have a good report and some pictures for the Anyone Fishing thread.
Joe H
Re: Joe's P19
Posted: Sun Jul 15, 2012 9:09 am
by Joe H
Been doing a little work on the build in between fishing and my real job.
The top of the cabin came out a little narrow, had to re-cut a new peice for it.
Some progress, Tough to make in this heat we all been having!
Heading out to the garage, see if I can mock up a windshield.
Thanks for looking
Joe H
Re: Joe's P19
Posted: Sun Jul 15, 2012 9:34 am
by topwater
Looking good Joe , looks like you nailed that Dyer 29 look 8)
Re: Joe's P19
Posted: Sun Jul 15, 2012 4:17 pm
by cottontop
Joe, how is the new grandbaby doing? Our youngest grandson turned 2 yesterday. We have 3 grandsons. 2- 2yr. old and one nearly 6. I'm planning on retiring in 2 yrs. Looking forward to taking them fishing in the OD18 and starting my new boat. I've finally decided on the "Phantom 22". It will be big enough to carry them and their parents. Your P19 is looking fine. John
Re: Joe's P19
Posted: Sun Jul 15, 2012 5:46 pm
by Joe H
Thanks John and John,
More like the Seaway 21 John, I was suprised how close it is! Thx for the links.
Hey John, the Phantom 22 should do it, and you have a few good examples on the forum here.
What will you do with your OD18? I'll keep my OD 16 and outfit it with a center counsole for the kids use.
These kind of puts a face on the boat.
Joe H
Re: Joe's P19
Posted: Sun Jul 15, 2012 10:02 pm
by Hope2float
Very cool Joe, it has a nice look and should still keep you dry. Build on and fear no fish! 8)
Dave
Re: Joe's P19
Posted: Sun Jul 15, 2012 10:34 pm
by Steven
That looks great Joe. Please be careful with that step ladder. That is the same one I used that collapsed twice, sending me to the hospital in an ambulance the second time. I chucked it and got one that locks open.
Re: Joe's P19
Posted: Mon Jul 16, 2012 7:51 am
by topwater
Joe how far back from the bulkhead did you put your seat boxs :?:
Re: Joe's P19
Posted: Mon Jul 16, 2012 9:31 pm
by Joe H
Thanks Dave, "Build on and fear no fish!" :D
Steven, your boat looks great and congrads on the launch! My wife has told me the same thing about the step, you would think I'd listen after 35 years, consider it gone, I've been warned no way I can use it now! ha.
John, the seat boxes are just sitting there, I'm not sure they are going to stay just yet, besides I'm waiting for you to install yours first so you can give me the proper distance. (there about 17" from the bulkhead) :)
Oh yeah, my new bedroom:
Joe H
Re: Joe's P19
Posted: Mon Jul 16, 2012 11:35 pm
by Steven
Thanks Joe. Just tell her you finally decided to listen to her wise advise. :)
Re: Joe's P19
Posted: Tue Jul 17, 2012 7:34 am
by topwater
Joe it will be awhile on the seat boxs :( I am thinking about 22" from the bulkhead.
I figure about 6 " for the helm sticking out with a flat wheel on it.
Re: Joe's P19
Posted: Wed Jul 18, 2012 7:22 am
by cottontop
Joe, It has been great watching you build this one. It is going to be one very fine boat. Certainly should keep you and your family dry. I plan on keeping the OD 18. I was going to sell her to get a little extra money for the next build, but my daughter wants it. It will remain parked under the barn at my house.
Re: Joe's P19
Posted: Thu Aug 02, 2012 9:00 pm
by Joe H
work on the p19 has come to a screeching halt! since my exploratory scope and clean up of my shoulder joint last year my pain has just worsened, several weeks ago something broke, felt like I broke a tooth off a gear, ouch, so my orthopedic surgeon suggested total shoulder joint replacement, my arthritis wore the glenoid ?? down to nothing, bone to bone, so i opted for the op and now have a new socket and joint.
so here i am 1 week post opt.
i do have a question about the build, i would like to build a conventional wood frame windshield instead of the plywood, mahogony, redwood or something like that. does anyone have or know where i can get some plans or ideas?
something like this:
i also like the bi-fold cabin doors, they fold out by the way.
jason,
give me a call in another week or so, you can come out and get some measurements.
joe h
Re: Joe's P19
Posted: Thu Aug 02, 2012 9:04 pm
by peter-curacao
Joe H wrote:work on the p19 has come to a screeching halt! since my exploratory scope and clean up of my shoulder joint last year my pain has just worsened, several weeks ago something broke, felt like I broke a tooth off a gear, ouch, so my orthopedic surgeon suggested total shoulder joint replacement, my arthritis wore the glenoid ?? down to nothing, bone to bone, so i opted for the op and now have a new socket and joint.
Man that kind of sucks!! wish you all the best man! good healing and good luck! 8)
Re: Joe's P19
Posted: Thu Aug 02, 2012 9:21 pm
by Joe H
thx peter, yeah, sucks and not in a good way, 6-8 weeks home from work, i have very good short term disability pay from work but still worry about whats going on in my absence.
meds are good and strong, just can't do anything!
Re: Joe's P19
Posted: Fri Aug 03, 2012 12:55 am
by cali123
I wish you the best with that new shoulder. OUCH :cry:
Re: Joe's P19
Posted: Fri Aug 03, 2012 8:00 am
Ah man, that hurts to think about it :help: Get well soon Joe!
Re: Joe's P19
Posted: Fri Aug 03, 2012 8:55 am
by topwater
Sorry to hear about your shoulder Joe . For the windshield frame just use the one you have for the pattern,
Build it out of 1 " thick wood , where you are going to put glass figure out how much of a flange you will
need to mount them and make the frame that much wider and use your pattern again and a router to
make the mounting flange. That way its all one piece. Hope i made that clear enough.
Good luck with therapy, your going to love it 8O
Re: Joe's P19
Posted: Fri Aug 03, 2012 2:13 pm
by ericsil
That shoulder is a real bummer with the boat so close to the finish line. Take your time. Nothing worse than a relapse because you jump back in too soon. Good luck with the PT.
Re: Joe's P19
Posted: Fri Aug 03, 2012 3:16 pm
by Joe H
thx guy's, yeah this just sucks, but in the next few months i hope to have 75 = 85% mobility back and best of all pain free, but i do hear the PT ain't no picnic.
My employer wants to send a computer to my house for the next 6 weeks so i can work from home, isn't that thoughtfull of them! ha, I'll bet that computer will be down more then it's up. :lol:
john, i know what you mean but i can't help but think there is much more to it, still looking for plans.
typing with one hand sucks too.
joe h
Re: Joe's P19
Posted: Fri Aug 03, 2012 4:45 pm
by Aripeka Angler
Sorry to hear about your shoulder Joe! I hope you heal up quick my friend :) Sandi say hi and sends her best as well...
Re: Joe's P19
Posted: Mon Aug 06, 2012 10:43 am
by Joe H
thx Richard,
i'm trying to talk janet into bringing me out to the lumber yard so i can pick out the lumber for my whindshield, but she just laughs at me, i've been in the house for 1 1/2 weeks, watching womens water polo (olympics) can only take you so far! i gotta get out.
CL, still hurts, trying to go without the strong pain pills today, ha, i'll let ya know how that goes.
joe h
Re: Joe's P19
Posted: Mon Aug 13, 2012 1:01 pm
by cottontop
Been on vacation fr 3 weeks. Your shoulder surgery really stinks. I've been told by many that our "senior years" are golden, but so far the only gold I've seen is what goes to the doctors. Take your time to heal and Shella and I will keep you in our prayers. When you want to do something you shouldn't, just remember the grandchildren need your time. John
Re: Joe's P19
Posted: Tue Aug 14, 2012 11:51 am
by wadestep
Hi Joe -
your build has been looking great - I've just got caught up with it. I hope your Pain and Torture from your Physical Terrorist is going well (or will start soon - docs are different about the start times). The good news is that once it's all over, you should be happy with your new shoulder!
Wade - PT
Re: Joe's P19
Posted: Mon Aug 20, 2012 9:06 pm
by Joe H
Sorry for the late reply, I hear ya John, thanks.
Wade, Physical Terrorist is correct, but I'm just doing static streching for now and then the real thing in a couple of weeks.
The biggist thing is just sitting here doing nothing, but I'll have to admit I did get out and glass the cabin top on the P19 yesterday the wife bitching at me the whole time, don't tell her but my arm feels like it's going to fall off today!
Joe H
Re: Joe's P19
Posted: Tue Aug 21, 2012 8:33 am
by topwater
There ya go Joe boat therapy :wink:
Re: Joe's P19
Posted: Thu Aug 23, 2012 10:17 pm
by Hope2float
boat therapy is way better than the kind where they intentionally set out to hurt you. Boat work will hurt as well, you just don't know when it's coming.
How are you doing with the arm? It take a long time to heal but it should be bullet proof in the end
Dave
Re: Joe's P19
Posted: Fri Aug 24, 2012 6:44 am
by cape man
Joe,
I'm sure you'll be happy in the end with the new joint. Amazing what they can do these days. Do follow the plan during the healing and PT. It will be over sooner than you think. I did a quick search and couldn't find anything solid for windshield plans, but got to believe you can get something from one of the Wodden Boat forums if no one here has plans.
Re: Joe's P19
Posted: Sun Aug 26, 2012 10:09 am
by Joe H
PT! taking a phrase from my daughter, "REALLY!" it F**&%ing hurts
But I did manage, and I won't tell you how long it took, but the cabin is glassed.
I did find a good article in WB for building a solid wood windshield, also my brother-in-law stopped by yesterday and had some very interesting idea's, I'm going to do a little fairing on the cabin and think about next step.
Joe H
Re: Joe's P19
Posted: Sun Aug 26, 2012 5:12 pm
Wouldn't that be hard to see through? :lol:
Re: Joe's P19
Posted: Sun Aug 26, 2012 6:18 pm
by cape man
You beat me to it! ROFL :lol: :lol: :lol: :lol: :lol: :lol:
Re: Joe's P19
Posted: Sun Aug 26, 2012 8:50 pm
by Joe H
:lol: :lol: :lol: must be the drugs!
"Solid wood framed windshield"
Joe h
Re: Joe's P19
Posted: Tue Nov 06, 2012 9:07 pm
by Joe H
Well my shoulder has been getting better and better as time goes on so I've been able to get a little more done and have a few updates on the boat build.
Cockpit, windshield is just a template, my brother-in-law is making the actual windshield at the boat works.
laminating the mahogany windsheild sides to the 1/4" plywood.
Scupper & Gunwale sides
Scupper Drain Tube
Second coat of Fairing, using West System 410 Microlight, very good stuff once you get the hang of it.
I've been collecting some bits a pieces for the boat, I don't need 3 Stern light/flag poles but that's what I managed to put together out of the box of parts I've been collecting, these are very hard to find and I'm glad I could put together 3 of them, all genuine old school Chris Craft.
And I saved the best for last, I won the bid on a 2006 Yamaha 90 hp on Ebay, it's in Hialeah Fl, but free shipping can't be beet!
After talking with Cracker Larry and Richard (Richard has the same motor) I feel very confidant about this purchase, up here in the Great Lakes area Evinrude, Johnson & Merc seem to be the best sellers but I'm seeing more and more Yamaha's.
Can't wait to see it on the back of the boat, hopefully in the spring.
Joe H
Re: Joe's P19
Posted: Wed Nov 07, 2012 2:46 am
by chicagoross
That windshield's gonna be pretty! :D Varnished, I presume?
Re: Joe's P19
Posted: Wed Nov 07, 2012 8:04 am
by cottontop
Joe, with all your physical ailments you really are making some very fine progress. I really love your work. John
Re: Joe's P19
Posted: Wed Nov 07, 2012 8:10 am
by topwater
Joe nice score on the yammy 8) The windshield frame is going to look awsome when finnished, good
to see you back working on the boat :!:
Re: Joe's P19
by peter-curacao
Man that looks real good Joe, thanks for sharing the pics 8)
Re: Joe's P19
Posted: Thu Nov 08, 2012 12:24 pm
by Joe H
Thanks Guys,
Yep the windshield and the side of the windshield will be varnished mahogany, I have already varnished the mahogany Stern light/flag poles, that varnish is some strong stuff!
Cottontop, gotta love Modern Medical technology, everything’s fixed and better then new, well almost, ha.
I just hope that yammy shows up at my door sometime soon, my brother is a Pilot out of Miami Airport, he doesn’t know much about outboards but he is going to take a ride to Hialeah just to make sure that there is an engine to send to me, but we still can’t guarantee that the seller will create it up and send it to me, he has a pretty good rating so I feel okay with it.
I can get a discount on Teleflex Controls, cables and steering cable’s but I cannot figure out (I must be a dumb ass) what will work for my 2006, 90 hp Yamaha, can anyone help?
What controls do I need? Can I even use Teleflex or do I need to stick to something like this, Yamaha Side Mount Remote Control 703-48207-17-10,703-48207-1A-10 Shifter.
Thanks.
Your welcome Peter.
Re: Joe's P19
Posted: Thu Nov 08, 2012 1:21 pm
Glad the bid worked out Joe 8) Very good buy and a great engine.
You can use any standard Teleflex. My 70 is the same year model and basically the same engine. I used Teleflex for everything. Controls, cables steering and gauges.
I used a CH7500 control box, and still very pleased with it. Crisp and smooth.
http://www.teleflexmarine.com/products/ ... 0-control/
And Teleflex 4.2 NFB steering system and cable.
Re: Joe's P19
Posted: Thu Nov 08, 2012 1:32 pm
by Joe H
Thanks A Ton Larry!
Re: Joe's P19
Posted: Thu Nov 08, 2012 1:38 pm
Glad I could help, Joe :D I'm a giver, and a toker :lol:
Re: Joe's P19
Posted: Thu Nov 08, 2012 2:19 pm
by Steven
I used the same as Larry and it does work well. It will require you cut some of the harness wires and manually wire it. A yamaha controller will be more plug and play if the factory harness is intact. But plenty of help here to get it wired without any problem.
Re: Joe's P19
Posted: Thu Nov 08, 2012 8:47 pm
by Joe H
Glad I could help, Joe I'm a giver, and a toker
Yeah, I'm thinking about giving one of them up! :lol:
Steven, your making me nervous, I like plug and play. I don't know if the factory harness is intact, maybe I should wait until I get the motor before I order the harness.
Joe H
Re: Joe's P19
Posted: Sat Nov 10, 2012 11:21 am
by Matt Gent
I have the same engine, same year even. I used the 703 side mount, it's plug and play and works great. Yamaha factory controls and cables are very smooth.
Re: Joe's P19
Posted: Sun Nov 11, 2012 7:18 pm
by Joe H
Matt,
That is the same controller the guy I purchased the engine from recommended, I was hoping to save a few $$ with Teleflex but if I can find a 703 for the right price.. sure is a good looking unit.
How do you like your Yamaha?
I've always been a Johnson or Evinrude man but this is a pretty convincing crowd and I've been out in Cracker Larry's OD 18 a few times and his 70 Yamaha ran flawlessly, sounded good, and this may sound weird but I liked the smell of a running 2 stroke engine , ha.
Joe H
Re: Joe's P19
Posted: Wed Nov 14, 2012 9:34 pm
by Joe H
Hey Larry,
Why the dual cable steering system? Do I need to do anything special at the engine?
BTW: You did a fantastic job on your build, your customer seems very pleased, my in-laws customers have to wait 3 - 5 years for their custom build boats, you blew it out! Nice.
Joe H
Re: Joe's P19
Posted: Wed Nov 14, 2012 9:51 pm
It's not a dual cable system, just a single.
http://www.jamestowndistributors.com/us ... ng+Systems
Their reputation exceeds mine :D By about 100 years 8) I bet the price does too 8O
Re: Joe's P19
Posted: Wed Nov 14, 2012 10:03 pm
by Joe H
Hmm, my catalog doesn't show a single in the 4.2 just the dual.
I'll show them your link.
Joe
Re: Joe's P19
Posted: Sat Nov 17, 2012 12:32 pm
by Joe H
It's not a dual cable system, just a single. And Teleflex 4.2 NFB steering system and cable.
I stopped at my Marine supply store yesterday and they can order it, Thanks Larry! ($156.00, no shipping charges)
I also picked up some more fairing powder and some Primer for the interior.
Started out looking for a classic style light/flag pole for the P19, I thought I was going to have to pay big bucks for one from ebay but I put some feelers out and ended up with 3 of them, 1 came from a a burnt down boat house, it was black from tip to tip, it took several hours of scrapping, sanding and cleaning but I managed to get it to this stage:
Not to shabby, I was told it came from a 22" Chris Craft Utility, nice.
This next one I put together from a box of different pieces my brother-in-law brought over, Hacker Craft I'm thinking, I like it best but it's not all original, in fact I bought the light dome from ebay for $5.00 (plastic) looks good though, huh?
What do you guys think? Maybe I'll keep them both, but my brother is pushing hard for me to give him one of them.
It was 28 degree's here this morning, I've had the heat on in the garage, should be warm enough to go out and do some more sanding and fairing, fairing and sanding,,,,,,,,,,,,,,, I hurt already. Ha.
Joe H
Re: Joe's P19
Posted: Sat Nov 17, 2012 9:19 pm
by cali123
The wood in the original one is beautiful, I'd keep that one. 8)
Re: Joe's P19
Posted: Sun Nov 18, 2012 9:06 am
Me too :wink:
Re: Joe's P19
Posted: Sun Nov 18, 2012 9:17 am
by icelikkilinc
+1 for the first...
the wood work going from thicker to thinner and the light has a better fit at the top whereas the second has the light sitting on top rather than the firsts better fit...
Re: Joe's P19
Posted: Sun Nov 18, 2012 7:00 pm
by Aripeka Angler
Joe, that is some mighty fine work on the windshield frame 8) I really like the look of the topside of your boat! It has a very classy look.
Did you pull the string on the Yamaha? It looks nice in your picture, I think it will be a perfect fit for your boat...
Edit...Oh yeah, just say no to the plastic light pole :lol:
Re: Joe's P19
Posted: Sun Nov 18, 2012 8:11 pm
by cottontop
Joe, Go with the wood pole. You will never regret it. John
Re: Joe's P19
Posted: Sun Nov 18, 2012 10:32 pm
by Joe H
Looks like the Chris Craft Light pole is the clear winner, the wood grain shows up much better and I like the idea that's it's all original, the other one is a vintage mahogany pole from the 40's or 50's too, it's just the light dome itself that's plastic, can't find the original glass dome anymore and if you do they want hundreds of $$ for them, no kidding, no way.
Richard, I did pull the trigger on the Yamaha, it's supposed to be here tomorrow or Tuesday, I can't wait!
I sent the template for the front of the windshield to my brother-in-laws at the boat works, we'll see how that works out.
Thanks for the comments.
Joe H
Re: Joe's P19
Posted: Fri Nov 23, 2012 11:52 am
by Matt Gent
Joe H wrote: How do you like your Yamaha?
It's generally been very good. Light and compact, and I like the oil tank in the hood.
It is rather low on torque compared to other 90hp outboards, I previously had a 90 Johnson that was much stronger out of the hole.
I had one issue with a missing o-ring on the fuel filter on the engine causing an air leak and stalling. Easily fixed though.
I also think I'm down a few mph and couple hundred rpm at wot from new (now at 110hrs), no idea why.
Re: Joe's P19
Posted: Fri Nov 23, 2012 12:09 pm
by TRC886
Joe H wrote:, and this may sound weird but I liked the smell of a running 2 stroke engine , ha.
Joe H
A mixture of creosote and burnt outboard oil is one of the very best smells I know. It reminds me of going rock fishing with my dad when I was just a kid 8)
Glad your shoulder is better, and you're back at work on your boat. It's looking really good 8)
Re: Joe's P19
Posted: Thu Dec 13, 2012 4:11 pm
by Joe H
Smells are one of the strongest triggers for memories, good or bad, ha!
My new engine in my garage at last.
My new neighbor and I built these in a hour or 2 and it only cost me a 12 pack of Coors Light, hey, it’s what he drinks, he’s a cabinet maker and Richard I have a new respect for cabinet makers, this guy is good and very meticulous, I had the doors all laid out in my garage when he came over to check out the boat, he say’s bring those cabinet doors over to my garage and I’ll square them up for you, low and be-hold he has a whole wood working garage set-up over there with all of only the best of tools, he didn’t just square them up, he practically re-built them! I’m stocking up on Coors light, ha ha.
Picks of the 3rd round of fairing, almost ready to prime.
I have the box seat installed now too, pic’s to follow.
Joe H
Re: Joe's P19
Posted: Thu Dec 13, 2012 5:14 pm
by Aripeka Angler
The doors look great Joe 8) You have a talented friend for sure and you can't beat the price :lol: The boat looks awesome, do you think you will be able to splash and enjoy it next summer?
Re: Joe's P19
Posted: Thu Dec 13, 2012 6:37 pm
by Larry B
Joe, boat looks great.
What are you putting on the sole? Kiwi Grip?? or something else?
Reason I ask is I faired half of my sole (a lot of dang work) to where I could have put sterling on it and it would have looked good similar to what I see in your picture, I put kiwi grip on it and where I didn't do much in the way of fairing and it looked the same in both places :doh:
Larry B
Re: Joe's P19
Posted: Thu Dec 13, 2012 6:45 pm
by cottontop
Puuuurrrty! She is going to be one fine boat. Glad you are healing up nicely. Looking forward to the launch. John
Re: Joe's P19
Posted: Thu Dec 13, 2012 8:19 pm
by AtTheBrink
Larry B wrote:Joe, boat looks great.
Larry B
That is what I am looking forward to! Like texture on drywall, hides a lot of stuff!
Your boat is looking great!
Re: Joe's P19
Posted: Thu Dec 13, 2012 9:21 pm
:D
Re: Joe's P19
Posted: Fri Dec 14, 2012 10:41 am
by Joe H
I certainly hope to launch in the spring Richard.
Larry B, yes Kiwi Grip, I have a gallon ready to go, I wasn’t planning on fairing it out as much as I had too, I used 4oz cloth on the sole for some protection, when I laid it down a wetted it out it looked fine, but as it dried overnight it developed little ripples, like waves in several areas, they were only about 1.0mm high, maybe more, but rather than sanding them down I filled them in, I figured more protection that way and I wasn’t sure if the Kiwi grip would have covered it, I know I will never use 4oz clothe again!
Me too, I’ve been buying gauges, controls, hardware, this and that, every day the post man brings me more, Janet’s getting jealous of all the packages I have been receiving, I’ll have to throw one in for her, I keep telling her all that stuff is for the boat and the boat is for you and I Honey, she ain’t buying it!
Thanks John, thanks Mike.
Larry, that wasn’t as tough of a decision as I thought it was going to be for being a Great Lakes Man and into Evinrude and Johnson motors all my life, I go out to the garage and look at it every night, ha. I don’t know if those yammy colors are going to go with my paint scheme though, I might have to re-paint the boat!
Re: Joe's P19
Posted: Wed Dec 19, 2012 3:38 pm
by Joe H
Interior primed with first coat, man do the imperfections jump after priming!
Picture quality not so good, taken with my phone.
Joe H
Re: Joe's P19
Posted: Wed Dec 19, 2012 4:39 pm
by AtTheBrink
Joe H wrote:Interior primed with first coat, man do the imperfections jump after priming!
Joe H
You got that right! Just when you think it is all good, just when you start to smile and think you are done sanding... :? :x
Just take it one spot at a time and go thin on the filler, that is what has worked for me so far.
Your work looks great! Love the boat!
Re: Joe's P19
Posted: Wed Dec 19, 2012 8:52 pm
by Hope2float
Ditto what he just said. the boat looks like its coming along just fine.
Dave
Re: Joe's P19
Posted: Thu Dec 20, 2012 7:54 am
by topwater
The boats looking real nice Joe 8)
Re: Joe's P19
Posted: Tue Dec 25, 2012 10:04 pm
by Joe H
Mike and Dave, that's what I did and doing, one spot at a time, it's getting there. :roll:
John, how ya doing man?
I have bought myself a few present, steering system, Yamaha Controls, Gauges, how does one go about deciding where to mount this stuff, I've looked at other boats, other builds, held the stuff in position well sitting, standing, can't decide, I think I'll just drill holes and hope for the best!
Seriously, should I mount the controls and gauges looking and feeling best in the sitting position or standing position? :doh:
Merry Christmas!
Joe H
Re: Joe's P19
Posted: Wed Dec 26, 2012 1:08 am
by AtTheBrink
Joe, mount them where ever it will be the most comfortable for you in whatever position you are going be operating the boat in most.
Re: Joe's P19
Posted: Wed Dec 26, 2012 9:29 am
by Joe H
Thx Mike, that much I got, ha! I stood up driving my Sea Ray most of the time, I think I'll
Set this up for sitting down.
Pics to follow, oh yeah, bow eye, just going to go for it today, I hope.
Thanks again
Joe H
Re: Joe's P19
Posted: Wed Dec 26, 2012 9:59 am
by AtTheBrink
I did the same thing! I hemmed and hawed over it a month while doing other stuff. I finally just picked up my grinder, ground down a flat spot where I thought the eye should be and drilled the holes! It worked out great! I think it looks good.
Try to go for a compromise on your controls. You are going to need to stand in rough conditions. A tilt wheel helps!
Re: Joe's P19
Posted: Sun Dec 30, 2012 6:07 pm
by Joe H
Okay Guys, as suggested I just picked a location and drilled for the Bow Eye, I think it's to high but it'staying put now! ha.
Bow Eye Support inside the cabin, reinforced with 1/4 plywood and a 2x4 cut to the shape of the bow, I think it will be plenty strong enough.
Some miscellaneous pics.
Joe H
Re: Joe's P19
Posted: Sun Dec 30, 2012 6:15 pm
by AtTheBrink
That is a cool steering wheel! Looks sharp!
Re: Joe's P19
Posted: Sun Dec 30, 2012 6:27 pm
by cottontop
Joe, Hope you and your wife and family had a Merry Christmas. The New Year is almost upon us. Hope yours ishealthier, happier, and more prosperous. When you finish this one, will you be starting another? Or is this to be the final one? She sure is looking great. I'm in the process of refinishing the inside of my OD18. I never realized how hard it would be to just remove the paint. I'm going to add gunwales to her. Thanks to the two Larry's(Cracker and Larry B), I now have a good idea how to accomplish this task. John
Re: Joe's P19
Posted: Tue Jan 01, 2013 6:52 pm
by Joe H
Thanks Mike, the steering wheel is solid Mahogany, is over 20 years old but never installed, unfortunately it will block the view of any gauges installed behind it so I'm going to have to build a gauge box to put on top of the dash, working on that now.
Hey John, I've been watching your build, I thought your OD18 was perfect to begin with but I think you will like the addition of gunwales.
When I get this boat out of the garage I'm going to do a refresh on the OD16 with a center console and new paint, make it a little more user friendly, I'm tired of the tiller, I want an electric start and steering wheel for her, after that I'm looking at the RB16, I've had a couple of old rum runners in the past that I have refurbished, loved them but I think it will be easier to build one using the S&G method.
Have a Happy New Year! :)
Joe H.
Re: Joe's P19
Posted: Mon Jan 07, 2013 2:45 pm
by Joe H
3rd coats of varnish on the Bi-fold cabin doors, looking good, I think 1 more coat should do it.
The Mahogany steering wheel I have blocks any chance of putting the gauges on the face of the helm, plus I think they would be tough to see from a standing position so I built this little gauge box, I should be able to put my all my gauges, compass and an auxiliary power supply in it.
Front view of some of the bright work, and the template for a windshield once again.
Joe H
Re: Joe's P19
Posted: Tue Jan 08, 2013 7:50 am
by topwater
Looking good Joe 8) That's some real nice wood you are using. What kind of wood are you using
for the anchor roller :?:
Re: Joe's P19
Posted: Tue Jan 08, 2013 8:00 pm
by Joe H
Hey John,
It's 2 layers of pine laminated together, coated with epoxy, mahogany stain and 3 or 4 coats of Interlux Schooner Varnish with UV protection.
I'm not sure how I'm going to attach it yet, glue it, lag bolt it, we'll see.
Joe H
Re: Joe's P19
Posted: Wed Jan 09, 2013 7:57 am
by topwater
Joe glue it down and put some bolts and backing plates in , should be good to go .
Nice progress now get back to work 8)
Re: Joe's P19
Posted: Wed Jan 09, 2013 8:59 am
by fastlane
Looking good Joe. I love the wheel. I have the same one on my P-21.
Re: Joe's P19
Posted: Wed Jan 09, 2013 8:37 pm
by Joe H
I seen that Fastlane, and when I seen mine on Craigslist I had to have it, same controls too, I was going to go with Teleflex but the Yamaha controls were less expensive.
How do you like the location of your gauges? I'm not sold on my gauge box on the dash just yet.
I'd work on it day in and day out if my employer would give me more time off work! :) :)
Joe H
Re: Joe's P19
Posted: Thu Jan 10, 2013 9:01 am
by fastlane
Joe,
The location of the gauges works just fine for me. I never have a problem seeing them when i need to.
I put that radar and sonar/nav up on top of the dash. That's what i really need to see. Your gauge box does look nice though.
Re: Joe's P19
Posted: Wed Jan 23, 2013 10:26 am
by mecreature
looking great.
How do you like the cold blast going thru.
perfect time to use the fast epoxy.
Re: Joe's P19
Posted: Wed Jan 23, 2013 12:17 pm
by Joe H
"0" this morning!! :help:
(time to hit the hard water)
Re: Joe's P19
Posted: Fri Jan 25, 2013 1:47 pm
by Joe H
Getting a little work done, main thing is the kids are having fun, my boat is their new Fort!
Joe H
Re: Joe's P19
Posted: Fri Jan 25, 2013 1:51 pm
by tobolamr
Those are AWESOME pics!
Re: Joe's P19
Posted: Fri Jan 25, 2013 2:06 pm
Dang, Joe, you can't spring for some heat in there :?:
Great pics of the kids!
Re: Joe's P19
Posted: Fri Jan 25, 2013 2:20 pm
I save that picture! :D
Re: Joe's P19
Posted: Fri Jan 25, 2013 3:47 pm
by Boater45
Great picture and great memories for you and your children!!!
Re: Joe's P19
Posted: Fri Jan 25, 2013 7:37 pm
by Joe H
Thanks guys, I love my Grandbabies, they can't wait until launch day and spend the night out in THEIR Pirate Boat! (I can't wait either) :D
Larry, they come in from the cold to get warm, and stop production, and out they go again. :help:
Come on Spring!!!
Joe H
Travelocity alert:
Detroit to Savannah
Fares are 9%* lower than they've been in the last 30 days.
Save up to 40%!
Book Flight + Hotel
Together and Save Big.
$406 :cry:
Re: Joe's P19
Posted: Fri Jan 25, 2013 10:40 pm
by Hope2float
Joe great crew to set out to sea with. Their imaginations are full of adventure. They don't have worry about the monthly bills just the adventures. They will always remember the fun. Great progress keep at it.
Dave
Re: Joe's P19
Posted: Sat Jan 26, 2013 9:10 am
by topwater
Love the pic's Joe :!: Now get back to work :!:
Re: Joe's P19
Posted: Sat Jan 26, 2013 9:54 am
by Joe H
Don't I know it Dave, I have 3 grown children and 3 Grand children they all live close by so we are blessed to have them as much as we do.
Take it easy on me John, the heats on in the garage and I'm heading out as soon as I work out all the kinks in my old body! ha
Of course my neighbor is heading out ice fishing, I may have to keep him company. :D
Joe H
Re: Joe's P19
Posted: Sat Feb 02, 2013 4:41 pm
by Joe H
Finally able to get out and try my new ice fishing pole!
Also, back to the build, I have about a 13' run from the batteries to the engine, I'm thinking 2 AWG gauge but wonder if I can get away with 4 AWG?
Joe H
Re: Joe's P19
Posted: Sun Feb 24, 2013 9:56 am
by Joe H
I bought these fixed portlights on ebay for a really good price, I like them but the wife things they are to big, what do you guys think?
I have these i'm my cart on ebay, I like them better but they are not cheap!
Joe H
Re: Joe's P19
Posted: Sun Feb 24, 2013 10:02 am
by topwater
Joe what size are the stainless ones :?: Your wife mite be right they look a little big to me also.
The boat looks great , thanks for the offer on the scuppers but I already have the same ones .
Re: Joe's P19
Posted: Sun Feb 24, 2013 10:37 am
Janet is right, trust a women on those things :wink:
The other set would look a lot better, and years from now you will forget how much it cost.
Re: Joe's P19
Posted: Fri Apr 12, 2013 11:52 am
by Joe H
Getting a little done each weekend, I have to pick-up my pace before Dave fly’s right past me with his P21!
Richard, do you still have a hole pattern template to mount the engine or was that you Larry, I’m sorry I looked all over for the thread on this but couldn’t find it.
Larry, I seen your hand drawing simple wiring schematics on another thread, very helpful, thanks.
I have an 8 gang switch panel with built in fuses for most everything but it’s my understanding that the bilge pump should be on a separate circuit?
Some boat porn.
Comments, criticism or suggestions welcomed. :)
BTW: John, I read the fine print on the stainless port lights and I thought the price was too good, they were only partially complete so I’m ordering some real nice looking plastic round one’s.
Re: Joe's P19
Posted: Fri Apr 12, 2013 2:02 pm
by 94Virago
I'm probably late to the party on this, but I freaking love that seat.
Re: Joe's P19
Posted: Fri Apr 12, 2013 4:26 pm
:doh: I was thinking the seat had to go.
Looks great otherwise though, Joe. Glad to see you lived thru winter again :D I've got a transom drilling template but it's a big heavy thing. I can duplicate it on some heavy paper and send it to you. I think Richard has a CNC file for a template that would be more accurate though. Mine is getting a little sloppy, too much drilling.
Re: Joe's P19
Posted: Fri Apr 12, 2013 4:32 pm
by peter-curacao
Cracker Larry wrote::doh: I was thinking the seat had to go.
It indeed does look a little cheap on a classy boat like that, boat looks great love the color 8)
Re: Joe's P19
Posted: Fri Apr 12, 2013 5:33 pm
by 94Virago
I was looking at it with a more practical eye. I love the drink/stuff holder on the side.
Re: Joe's P19
Posted: Fri Apr 12, 2013 9:10 pm
by Joe H
You guys crack me up, 94virago, your the first one that liked them, besides me, they are yours as soon as I can afford the one's I want, I bought the pair of them off craigslist for $40.00 brand new, I got them just to kinda set things up and buy me a little time, the one's I want are over 400 bucks for the pair and with everything else I needed before I can launch , well, their gonna have to wait.
As far as the hole pattern, thanks Larry, that's okay, I found a .pdf of the hole pattern online that I can download and plot out at work, should do the job.
Peter, they are just temporary I promise.
I hope to finish the windshield this weekend, I'm going to put a 1 X 2 mahogany cap and some braces on it then sand and varnish, the glass is on order.
Joe H
Re: Joe's P19
Posted: Fri Apr 12, 2013 10:05 pm
by Aripeka Angler
Joe, I have the drilling jig plotted in my CNC. It will take me about ten seconds to pop one out and send it to you. Text or email me your home address and it will be done my friend :)
BTW, Sandi likes your seat too. She said it looks like a good place to store a beer :lol:
Awesome work Joe, looking good!!! You have come a long way 8)
Re: Joe's P19
Posted: Sat Apr 13, 2013 7:49 am
by topwater
Joe the boat looks awesome :!: If you were aiming for the down east maine look you nailed it 8)
Re: Joe's P19
Posted: Sat Apr 13, 2013 9:39 am
by Joe H
Richard, email sent, thanks a Ton!
Maybe I should just pick it up :) , we will be in Zephyrhills on the 28th :D , coming down to visit Mom and meet her new, uh, friend, it would be very nice if Janet and I can take you and Sandy out for a bite?
Larry, in your wiring diagram you show a main circuit breaker, is this something required? I never had one in any of my other boats, as far as I know, what amp would I need?
John, I kinda wish I put scuppers in like your's and Peter's, they look like they will really do the job, I got lazy with mine and just ran a 1 1/2" dia pvc tube, should work okay, plus I have a bilge pump. Your boat is coming along great. I'm not sure what style I was going for, I think a mix between ChrisCraft (growing up in Algonac) and the Down east style.
Joe H
Re: Joe's P19
Posted: Sat Apr 13, 2013 10:33 am
Yeah Joe, the breaker is required. 50 amp is what I use, made by Blue Sea.
Re: Joe's P19
Posted: Sat Apr 13, 2013 10:36 am
by peter-curacao
Cracker Larry wrote:Yeah Joe, the breaker is required. 50 amp is what I use, made by Blue Sea.
But that one you put at the "beginning" of the system don't you?
Re: Joe's P19
Posted: Sat Apr 13, 2013 8:30 pm
by Aripeka Angler
Joe H wrote:Richard, email sent, thanks a Ton!
Joe H
Sounds like a plan Joe :) We would love to see you and Janet again. How many days are you going to be in Zephyrhills? Maybe we can wet a line? Dinner will work if you don't have time to kill some big fish :lol:
I will cut the transom drilling jig and have it here so you can take it home with you...
Re: Joe's P19
Posted: Sun Apr 14, 2013 1:20 pm
by ericsil
Joe, I haven't been around for awhile and missed all the good things you are doing with that boat. Despite comments to the contrary, that seat will keep you nicely in place while you are bouncing over the waves. It happens to be a close cousin to the one I use. Besides, the cost is great.
Let me compliment you on another change. That large hatch in the cabin will mean you should be able to weigh anchor or tie up to your mooring without going outside, (with or without the windlass). This can be very helpful when the gales are howling. As for the windows in the cabin. The Ebay models looked fine to me.
However, what's the story on that bow sprit? Are you planning to ram other boats like the ancient Phoenicians? My personal opinion is that it will detract from the overall looks unless it is much shorter.
Re: Joe's P19
Posted: Mon Apr 15, 2013 12:03 pm
by Joe H
How many days are you going to be in Zephyrhills? Maybe we can wet a line? Dinner will work if you don't have time to kill some big fish.
I personally have all the time in the world to kill some big fish!
We will be there on the 28th – the 5th, Sunday to Sunday, the only commitment I made was to visit my sister in St. Pete Beach, no time frame yet, It will be great to see you guys again, I’ll give you a call as the time gets nearer.
Hey Eric, how are you? Yeah, the bow pulpit is there to accept the plow anchor as the windless pulls it up, (I know u already know that) I may have put it out there a few inches too far but I don’t want the anchor to crash into the bow of the boat as the anchor comes up, we will see. Thanks for the complements, that hatch had to be big enough to get my fat ass through it, but I think it will work well, I’m getting closer to launch every day. Have you been out in yours lately? How is she holding up?
Thanks Larry, I'm picking up the breaker tonight, put it at the biggining of the system, got-it Peter.
Well, gotta get back to work, this all aluminum door outer is giving me fits.
Joe H
Re: Joe's P19
Posted: Sun Apr 21, 2013 10:08 pm
by Joe H
Finished building and sanding the windshield, now ready to varnish!
Boat porn.
Richard,
We will be in Zephyrhills next week Sunday night, Mon, Tue and Wed, heading to St Pete Beach on Thursday, I hope you guys will be in town.
See ya in sunny Florida in1 week, 29 degree's here last night, ugh.
Get back to work John!
Joe H
Re: Joe's P19
Posted: Mon Apr 22, 2013 8:47 pm
by Hope2float
Joe great looking windows that mahogany is going to jump out at you when you put varnish on them. Very retro look to the boat. You are almost there man. BUILD ON!
Dave
Re: Joe's P19
Posted: Mon Apr 22, 2013 8:57 pm
Beautiful 8) What kind of varnish are you using?
Re: Joe's P19
Posted: Tue Apr 23, 2013 12:16 pm
by Joe H
Thanks Guy's,
Larry I'm using Interlux Schooner Classic high gloss varnish with UV protection, pretty good stuff. Good luck on your new endeavor, get that GW (fantastic boats) outa there! I wanted so bad to head right down to Georgia this year and drop in on you but Mom's not feeling so great so it's straight to Florida, hope to escape with Richard for at the very least, dinner and drinks.
Joe H
Re: Joe's P19
Posted: Sat Apr 27, 2013 10:34 am
by Joe H
Pick up on some boat stuff yesterday, including my 50 amp breaker, Delta recommended this 9lb anchor for up to a 20 ft boat but I don't think it looks big enough, I usually use a danforth style anchor but thought this would look nice on the front of the boat, and I hear a plow anchor is the best way to go, we will see.
I'll be on the plane to sunny Florida this time tomorrow!
Joe H
Re: Joe's P19
Posted: Sat Apr 27, 2013 11:20 am
Good anchor, but maybe a little light. Put some chain on it and it should hold you in most conditions. A danforth is great for sand and mud, but not much else. A plow type works well in about anything.
What's up with West System epoxy :P
I'm jealous! Talked to Richard last night, he and Sandy are fishing all weekend, weather is perfect in Florida :D It's blowing 20 kts here and going to rain :? Have a good trip :!:
Thanks!
Re: Joe's P19
Posted: Sat Apr 27, 2013 11:12 pm
by Joe H
Good eye, what gave it away, the pumps?
I figure if it's good enough for Miss America it's good enough for me, Oh, it doesn't hurt that I get it for $92 for the kit, that's epoxy and hardner! :) (Janet's Dad used West on her for the rebuild.)
I'm jealous! Talked to Richard last night, he and Sandy are fishing all weekend, weather is perfect in Florida It's blowing 20 kts here and going to rain Have a good trip
Drive on down, we'll crash Richards and Sandy's, :) I do want to see his PK12, I also secretly want to build one.
Joe H
Re: Joe's P19
Posted: Sun Apr 28, 2013 7:25 am
by TRC886
Beautiful :!: :!: :!:
Re: Joe's P19
Posted: Sun Apr 28, 2013 7:21 pm
by peter-curacao
Joe I don't know what's with the downtalking on West, I used both Silvertip and west, sure there is a difference but I think West works great also! especially with the extra slow hardener, I used and sill use it a lot, imho nothing wrong with that stuff 8)
Re: Joe's P19
Posted: Sun Apr 28, 2013 8:47 pm
I wasn't down talking it Peter, it is good stuff. Just a LOT more expensive than others and the 5/1 ratio is a pain, and it does blush worse than S3 or Marinepoxy, but it's good stuff for sure. I've used a lot of it. But I can get 3 gallons of Marinepoxy for $160 and West cost $145 for a 1.2 gallon kit. Bateau sells both brands.
Where you are and having to pay shipping charges, West may be a better deal for you than it is me, and I like 2/1. Keeps it simple :D
Re: Joe's P19
Posted: Mon Apr 29, 2013 9:24 am
by peter-curacao
Larry I wasn't pointing fingers specifically to you, I was more talking about the down talking of west in general :wink:
Re: Joe's P19
Posted: Thu May 30, 2013 9:53 pm
by Joe H
This is just 1 coat of varnish, I now have 4 coats on, only 2 more to go.
I cut the templates for the windshield glass but I'm wondering if anyone knows what thickness of tempered glass I should be using.
My little helper:
Finally after 3 sets of port lights a pair I like!
Joe H
Re: Joe's P19
Posted: Fri May 31, 2013 7:59 am
by topwater
Nice job on the windshield frame , I would think 1/4 " would be plenty thick for the glass . That is what I plan to use on mine.
Build on, the boat is looking awesome 8)
Re: Joe's P19
Posted: Tue Jun 04, 2013 12:24 pm
by Joe H
Thanks John, 1/4" huh, I think you are right but that seems so thick , that would leave me with a 1/2" molding on the outside holding it in place, even less depending on how thick the adhesive has to be, hmm.
Joe H
Re: Joe's P19
Posted: Fri Jul 19, 2013 9:47 am
by Joe H
Joe, I noticed you changed your signature line...
Sad days indeed.
majorgator,
Yep, born in Detroit, now I can't stand to even drive through it! :cry:
Unfortunately I have to get to work, I’ll find a way around! Ha.
Re: Joe's P19
Posted: Mon Jul 22, 2013 8:33 pm
by Joe H
Painted the top side with 2 coats Pettit Easypoxy Sandtone, it went on real nice and leveled out great, more then happy with the results.
I also installed the Taco rub rail with a stainless steel insert, it's a rigid rub rail and was no problem to install.
The windshield frame turned out nice:
4 coats of varnish, I was going to put 6 coats on but I think I'm done for now.
John, I picked up the glass for the windshield, got it where the in-laws get the glass for their boats, they recommended 3/16 thickness not 1/4", they said 1/4" would be to heavy, it's 2 layered tempered safety glass tinted green.
Thanks for looking.
Joe H
Re: Joe's P19
Posted: Mon Jul 22, 2013 8:55 pm
by peter-curacao
Joe H wrote: I also installed the Taco rub rail with a stainless steel insert, it's a rigid rub rail and was no problem to install.
Cool Joe to see that! I have the same rubrail (I think) in white, did you need the heat gun at the bow?
Re: Joe's P19
Posted: Mon Jul 22, 2013 9:05 pm
Dang, that looks nice Joe 8) 8)
Re: Joe's P19
Posted: Tue Jul 23, 2013 7:11 am
by KeeperOfThePuros
As usual I must agree with cracker.....that's one fine lookin' vessel!
Re: Joe's P19
Posted: Tue Jul 23, 2013 7:40 am
by Walkers Run
Joe H wrote: The windshield frame turned out nice:
Joe H
Looks like everything turned out nice! Great job I love the color scheme, Looks great with the bright work.
Re: Joe's P19
Posted: Tue Jul 23, 2013 8:46 am
by topwater
Looking more and more like a down east boat every day. Thanks for the info on the glass.
Getting real close now , boat looks awesome :!:
Re: Joe's P19
Posted: Tue Jul 23, 2013 10:55 am
by wegcagle
Absolutely beautiful Joe. She sure is turning out to be a looker 8) Love the windshield and the color scheme.
Will
Re: Joe's P19
Posted: Tue Jul 23, 2013 2:25 pm
by danieloldhouse
Great job, Joe!
Re: Joe's P19
Posted: Tue Jul 23, 2013 7:11 pm
by wildbill
Absolutely Beautiful.
Re: Joe's P19
Posted: Tue Jul 23, 2013 7:26 pm
by Southern Gent
Joe H. Great job, Nice work
Re: Joe's P19
Posted: Tue Jul 23, 2013 8:16 pm
by Joe H
Thanks guys, I’m really satisfied with the way it has turned out so far, your comments are my inspiration to build on!
I looked at my first post for this build and I can’t believe I’ve been building this thing for going on 4 years, wow, seems like I started yesterday, I don’t think it will be splashed this summer, unless I use Peters method, but I’m okay with that, I gave my OD16 a face lift and we have been enjoying that this summer.
Peter, the last 2 feet at the bow gave me a bit of a fight but with my wife holding it well I put the screws to it got the job done without the heat gun, but you have a little more arc to yours, you may need heat, have you put it on yet?
Joe H
Re: Joe's P19
Posted: Tue Jul 23, 2013 11:08 pm
by Aripeka Angler
Fabulous looking work Joe 8) Sandi and I miss you guys between your visits down south :D
Re: Joe's P19
Posted: Wed Jul 24, 2013 3:36 am
by glossieblack
Wow, what a beaut looking boat! Congrats Joe!
Re: Joe's P19
Posted: Wed Jul 24, 2013 8:19 am
by peter-curacao
Joe H
Thanks Joe, no I didn't put mine on yet, have to finish some small things on the inside then close the top with plastic foil so I can spray paint the hull.
Re: Joe's P19
Posted: Wed Jul 24, 2013 10:43 am
by Hope2float
Joe absolutely some fine looking work. Top notch job
BUILD_ON
Dave
Re: Joe's P19
Posted: Thu Jul 25, 2013 7:54 am
by Rogerdog
Very pretty boat Joe.
What brand and what is the name of the color you used for the hull sides? It is a very sharp look.
Also, was that old Yamaha unused and did the seller have others?
Re: Joe's P19
Posted: Thu Jul 25, 2013 12:20 pm
by Joe H
Thanks Richard, we sure miss being there, I really want to get out with you and Larry, next time you guys are going out for grouper let me know, one never knows.
BTW: little sis has gone out with Kyle at least a couple times so far, do you ever see him?
Thanks Glossieblack, hey can you buy one of Fords new Rangers and send it stateside for me?
Rogerdog, I used Awlgrip red Mahogany, very nice stuff, the Yamaha I bought was used very little, 2006 90hp looks to be very clean but it may be awhile before I find out how she runs, I’m running out of summer here in Michigan!
I’m building on Dave, building on, it’s just this work thing keeps getting in the way, we don’t all have it as good as Larry!
Working out the live well this weekend.
Joe H
Re: Joe's P19
Posted: Fri Jul 26, 2013 8:32 am
by gk108
Howdy Joe. I'm curious about the Awlgrip. Catalogs and such have warnings about professional application that make it sound like it's drastically different to apply the paint. Is it really that different?
Re: Joe's P19
Posted: Fri Jul 26, 2013 12:28 pm
by Joe H
gk,
Yeah, even on the paint cans it says for professional use only, but I had no issue’s with it, they have their own brand of brush thinner that I used and I used good quality rollers and brush, my wife rolled it on as I was using the brush to feather it out, maybe it was the 2 person application that made it work, I don’t know but it sure laid down nice, looks like it was sprayed on for the majority of it, I would use it again in a minute and I'm no professional!
Joe H
Re: Joe's P19
Posted: Sat Jul 27, 2013 12:49 pm
by gk108
That's good to know. Maybe the warning is there for CYA purposes. :roll:
Or, it could be that you two are a team of professionals, since you got professional results from a paint for professionals. :D
One day I'll have to choose a paint, but there's a lot of sanding and priming and sanding and.... :)
Re: Joe's P19
Posted: Sat Jul 27, 2013 2:30 pm
by pee wee
You sure have built a nice looking boat, Joe. The colors look great with the bright work, too. Very nice, you're about to get there. :D
Re: Joe's P19
Posted: Tue Jul 30, 2013 2:49 pm
by mecreature
Wow Joe, that is a beautiful P19. That bright work is unbelievable.
Re: Joe's P19
Posted: Wed Jul 31, 2013 1:38 pm
by Joe H
Thanks pee wee/mecreature,
More brightwork to come! :)
Here’s the beginning of the live well/bait well
I’m thinking of coating the inside with either white tinted epoxy or I have some leftover interlux topside epoxy paint.
Joe H
Re: Joe's P19
Posted: Wed Jul 31, 2013 2:10 pm
by AtTheBrink
I think that the tinted epoxy would be the best bet. You would never have to worry about having paint bubble and peel from the constant moisture in a baitwell. Just my 2¢.
Your boat is looking awesome! Love the brightwork! Still trying to figure out how/where to incorporate some brightwork on my boat. I have a bunch of beautiful mahogany that is just sitting there waiting to be part of the boat...
Re: Joe's P19
Posted: Wed Jul 31, 2013 7:49 pm
by Joe H
Thanks Mike
All my bright work is mahogany, love the look, you will find a place for it.
I sanded the live well and put one coat of tinted epoxy, did not like the way it covered or should I say didn't cover but I understand it will take a few coats.
Typing on my wife's kindle, this sucks, but it does have spell check well I'm on the forum, my PC doesn't .
Joe H
Re: Joe's P19
Posted: Wed Jul 31, 2013 8:49 pm
by AtTheBrink
For the areas that I am using tinted (white) epoxy,like the bilge and other hidden areas, I am priming it first with the system 3 high build primer. Then I will give it a couple coats of epoxy to seal it up. In my storage compartments I am going all out with the sterling paint.
Re: Joe's P19
Posted: Mon Aug 05, 2013 9:21 pm
by peter-curacao
Joe H wrote:T
Joe H
Hi Joe,
I started with the rub rail today, and I found it's very much doable on your own without a helper, only thing that bothers me is some bump's or wave lines, its''s hard to explain, i tried to play with the tightness of the screws, but it seems it doesn't make any difference, did you have the same issue ? and if so does it disappear once set? can't see the issue in your pics. 8)
Re: Joe's P19
Posted: Tue Aug 06, 2013 8:34 am
by Joe H
Peter,
I used a rigid rub rail and didn't have much wave too it at all, what I did notice I took out by playing with the tightness of the screws as you have already tried, I also installed mine upside down, the lip on the rub rail was supposed to be on the bottom but I flipped it over to the top side and that put it in perfect alignment.
I'll try and get pictures when I get home tonight.
Joe H
Re: Joe's P19
Posted: Mon Aug 26, 2013 8:06 pm
by justin_dwyer
Hi Joe,
Awesome looking boat!!
I am building the P19 as well, it is my first big build, and I must say a little daunting at times.
I have never done any fibreglassing with the cloth before, would you be able to tell me how you layed out the cloth on your boat, I am not sure of the best way.
Thanks for your help.
Cheers
Re: Joe's P19
Posted: Tue Aug 27, 2013 8:54 am
by Joe H
Hi Justin,
First I laid out all the cloth on the boat dry to cut it to the pieces to the proper size, rolled it all back up making sure I labeled it so I knew exactly how to lay it back out when wetting the glass.
It really helps to have a helper at this point, someone to mix the epoxy while another is laying out so you can do wet on wet, set up a mixing station.
Do all the corners first with your 6” tape, then lay the big pieces over that after it sets up for a little, don’t rush it, if you have to do all the corners one day and the rest later, no big deal, it’s important to do it right not fast, I was lucky to have help so we did it all in one setting.
Prep the hull taking all burrs and such off so the glass cloth doesn’t hang up on anything, I put a coat of neat epoxy on the hull and let it get tacky, helps to hold the glass in place, then started laying the pieces down and wetting it out using a 4” stiff brush and spreading it with a 6” straight edge, pouring the epoxy right on the hull at times.
My son and I took turns one mixing the epoxy and the other wetting the cloth out, it took a few brutal of hours and just over 2 gallons of epoxy, maybe 3, I don't remember, but all turned out great.
Check out some of the other threads, Cracker Built GF 18, Topwaters NV23, they have some nice pictures and a good explanation of the process, mine were all deleted. :oops:
Hope it helps!
Joe H
Edit: Help me out guys, if I missed anything please let Justin Know.
Re: Joe's P19
Posted: Tue Aug 27, 2013 8:33 pm
by BarraMan
Justin
I have glassed my boat in a similar manner to that described by Joe H.
1) You can see from my build thread that I mark the hull up with where the tape or cloth is to go.
2) Measure tape or cloth for the run + 10% and roll it up.
3) Apply neat epoxy to the marked out area (I use a Uni Pro 100mm hard foam roller).
4) Roll out the tape or cloth onto the epoxy wet area, positioning it as it is rolled out. I need Mrs Barraman to help with cloth, but I can do tape solo.
5) Roll the tape or cloth out smooth onto the hull using a steel fibre-glassing roller.
6) Wet out the tape or cloth. I use Uni Pro 100mm hard foam rollers. I go through 8 - 10 of them for 7.0M of cloth cause the epoxy wrecks them. I figure its a small price to pay for an excellent job - I am getting about 50/50 glass/epoxy.
7) Roll out any air bubbles with the steel roller.
I have done my overlapping taping wet-on-wet, but have let my cloth runs go off and sand with 80 grit paper on an orbital sander between layers.
I don't pre-trim the cloth just cut it to length + 10%, I trim it on the boat once I have rolled it out onto the epoxy-wet hull.
The above has worked well for me.
Cheers
Lee
Re: Joe's P19
Posted: Wed Aug 28, 2013 8:16 am
by justin_dwyer
Thanks guys, awesome tips.
I am getting heaps out of these forums
Really appreciate it!!
Re: Joe's P19
Posted: Sun Sep 01, 2013 7:06 am
by blueflood
Hi Joe,
Nice job on her. I love the two colour boot stripe design, very classy and fitting for that style boat. All the outfitting is complementary to each other. Lucky to have a shop like that too, all painted white !!
Marc
Re: Joe's P19
Posted: Tue Sep 03, 2013 11:19 am
by Joe H
Thanks Marc,
Man you are cruising on your build, looks great, I hate to see you stop now but I get it! I have only been as far east as Lake Simcoe for some fantastic perch fishing, thru the ice of course.
Yeah I like my garage, heated so I should be able finish this boat for spring of 2014. :roll: My Father-in-law used to build boats in there so it’s nice to be able to carry on the tradition.
I did get a little work done over the Holiday weekend, little things not so picture worthy, cleats, painting, some bright work, and over drilled filled with thicken epoxy the holes to mount the motor, thanks to Richard for the hole pattern template, it worked out great.
Also managed to get a little fishing in this weekend, I’ll post some pictures in “Anyone Fishing” thread.
Joe H
Re: Joe's P19
Posted: Thu Sep 12, 2013 7:18 pm
by Joe H
Getting a few small things out of the way,
Transom oversized holes drillled and filled with thickened epoxy and motor well cover temporarily in place, I won’t glue it down until after the motor is on, I want to make sure everything fits and I have enough access underneath. Thx again Richard for the motor mount hole template.
Livewell and rear flagpole/anchor light installed.
Helm.
Rear Hawse and cleat,
Bow Grab rails and Hatch,
Cabin painted and ready for cushions, man that was no fun, on my back and little ventilation.
Brass Bow light, I’m thinking it might be from an early Century or maybe a Hacker Craft, either way it’s old and real glass in there.
Bow cleat and Windlass.
Bow view, I installed the beauty ring for the port lights and installed the horn tonight.
Best of all my latest little helper.
Thanks for looking.
Joe H
Re: Joe's P19
Posted: Thu Sep 12, 2013 7:31 pm
Show off :P That's beautiful Joe 8)
Re: Joe's P19
Posted: Thu Sep 12, 2013 7:45 pm
by Joe H
Thanks Larry, I'm pretty sure you know where I got the Hawse and Cleat idea! :)
Joe H
Re: Joe's P19
Posted: Thu Sep 12, 2013 8:09 pm
by gstanfield
Classy! 8)
Re: Joe's P19
Posted: Thu Sep 12, 2013 8:57 pm
by Joe H
Thanks George.
How have you been?
Joe H
Re: Joe's P19
Posted: Thu Sep 12, 2013 9:48 pm
by Aripeka Angler
Nice looking work Joe 8)
Re: Joe's P19
Posted: Thu Sep 12, 2013 10:23 pm
by gstanfield
Been good Joe, staying really busy with new promotion, family, etc. Hoping to finally start a large boat build sometime this winter.
Re: Joe's P19
Posted: Fri Sep 13, 2013 8:00 am
by topwater
Getting closer Joe , boat looks great with paint on her :!:
Re: Joe's P19
Posted: Fri Sep 13, 2013 11:36 am
by ericsil
Wow! Just when I think you have hit the top you come back with an even nicer looking boat. I am very curious to hear how that windless works out. I am getting too old to be running forward every time I want to drop a hook.
My P19 is on the trailer for another winter while I am back in Austin. Still giving us lots of fun, although the bright work needs some TLC when I get back to Maine. Hope you have friends with great cameras to record the launch.
Re: Joe's P19
Posted: Mon Oct 28, 2013 12:40 pm
by Joe H
Thanks Eric,
Texas and Maine are on my list of places to visit, you’re a lucky man, did you get hit with the bad weather?
I did a little work on the Cabin Doors this weekend.
I used mahogany plywood for the backing plates and trimmed it out with mahogany planks then several coats of varnish.
Thanks for looking.
Joe H
Re: Joe's P19
Posted: Mon Oct 28, 2013 3:33 pm
by Aripeka Angler
Beautiful work Joe 8)
Re: Joe's P19
Posted: Mon Oct 28, 2013 4:08 pm
It's a little ship. Nice woodwork. I like the way you installed the anchor windlass on the bow.
Re: Joe's P19
Posted: Mon Oct 28, 2013 6:25 pm
by peter-curacao
Stunning work 8)
Re: Joe's P19
Posted: Mon Oct 28, 2013 6:53 pm
by justin_dwyer
Looks Fantastic Joe, I hope mine looks half as good as yours. :D
Re: Joe's P19
Posted: Mon Oct 28, 2013 10:43 pm
Dang Joe, that's some sweet work there 8)
Re: Joe's P19
Posted: Tue Oct 29, 2013 7:34 am
by topwater
Niiiiiiiice :!:
Re: Joe's P19
Posted: Tue Oct 29, 2013 11:09 am
by wegcagle
Beautiful Joe 8) Love the mahogany door. That's some great work.
Will
Re: Joe's P19
Posted: Tue Oct 29, 2013 2:04 pm
by pee wee
Beautiful work :!: That boat is the intersection of a lot of good things.
Re: Joe's P19
Posted: Tue Oct 29, 2013 5:16 pm
by Hope2float
Joe , what can I say it looks great and I personally know what it took to get it there.
Re: Joe's P19
Posted: Tue Oct 29, 2013 7:37 pm
by blueflood
Very nice work Joe, she is a beauty indeed with classic bright work. How was the fairing inside corners at window frames ? You seem to have nice filets there and that is one spot because of the acute angles I can see being a real pain to make respectable. Looks like you did it :)
Marc
Re: Joe's P19
Posted: Wed Oct 30, 2013 6:35 pm
by Joe H
Thanks for the compliments, give's me the incentive I need to get out in the garage and get more done, those pictures aren't great I had to take them with my Iphone.
They were a real pain Marc, I taped about 1" from each corner and ended up using my finger to create a good filet but it took about 4 coats of fairing compound to complete, I then sanded as much as I could with my multi tool and hand sanded the rest, they came out good but don't look to close, ha.
This forum is great, doesn't just give you the instructions on how to get it done but the support to continue on, 4 years and counting next month.
Joe H
Re: Joe's P19
Posted: Sun Nov 17, 2013 11:34 am
by cape man
Worth every day. Great job Joe.
Re: Joe's P19
Posted: Thu Nov 21, 2013 12:45 pm
by Joe H
Thanks Craig,
Gonna miss ya at Boca Grande, Cayman Islands huh, ya I don't think your going to miss us.
Joe H
Re: Joe's P19
Posted: Thu Nov 21, 2013 3:18 pm
by Joe H
Making a little progress, not very picture worthy but what the heck.
Home for the batteries:
2 batteries going in there, no that’s not where the switch and circuit breakers are going. :roll:
Yamaha controls almost all hooked up, just have to figure out where all those wires go!
Cables came out perfect length.
A little accent:
Joe H
Re: Joe's P19
Posted: Thu Nov 21, 2013 5:31 pm
8) Looks great Joe! Good to talk with you too.
Re: Joe's P19
Posted: Thu Nov 21, 2013 8:33 pm
by Joe H
Larry, Thanks, I hope it was helpful>
I have your wiring schematics taped up in my boat and doing all the wiring in my head and by placing all the electrical stuff in it's place just to try and get an idea of how to wire everything up, I have it all done, unfortunately only in my mind, I'll be slinging wire's, hooking up switches and drilling holes this weekend so wish me luck and keep your phone handy! ha.
I too am electronically challenged.
I have a a working stern light! Just hooked up to a little battery. :lol: I had to re-do all the old wiring and light socket to a modern set up, glad to see it works, it was originally from an old Hacker Craft.
Joe H
Re: Joe's P19
Posted: Thu Nov 21, 2013 8:58 pm
Phone usually stays on Joe, except when it's not, if not I'll call you back :D Compared to what you have done the electronics are easy.
Re: Joe's P19
Posted: Mon Jan 06, 2014 12:03 am
by Joe H
Well, it's been a little while since I posted, I had shoulder surgery 2 weeks ago and I'm still in recovery, not the total shoulder joint replacement like I had on my left shoulder a couple of years back but still some major reconstruction.
Anyway, I did manage to get a little done before and after the surgery.
Some vents put in, a total of 7.
My buds at work made me an aluminum backing plate for my motor mnt.
Trying to find a good place for my Lowrance, made a little mounting box out of mahogany.
Installed a couple of flush mnt Cabela's Rod Holders.
Doing a little wiring.
I have a question about the wires coming out of the 703 Yamaha controls, I should probably post this under power boats but lets see what happens here. There's a 10 pin that goes to the motor, a 4 wire harness for the tilt gage and a 4 wire harness:
Red - Battery +
Black - Ground
Green - Tach signal
Yellow - Ignition on 12V
Red being Battery Positive does that mean I attach it to the positive post from the battery? I would have thought the power would come from the 10 post on the motor? I don't want to burn anything up.........
It's snowing like crazy here and very cold, -7 tonight.
Joe H
Re: Joe's P19
Posted: Mon Jan 06, 2014 4:24 pm
by glossieblack
Looking mighty fine Joe - love the navy blue, white and varnished timber combo. Do you still have the Century Restorer?
Re: Joe's P19
Posted: Mon Jan 06, 2014 6:40 pm
by Joe H
I wish I still had the Century, it was a great go fast ski boat but I'm more into the fishing these days! :)
I sold it back in the 80's when my second child was born, needed the $$ for something, probably rent, ha.
I'm not sure where you see the Navy Blue, the hull is Mahogany Red.
Joe H
Re: Joe's P19
Posted: Mon Jan 06, 2014 10:05 pm
by justin_dwyer
Hey Joe,
Looks great buddy. Can't wait to see yours on the water.
That backing plate for your Yami is a good idea :)
What sort of trailer are you putting her on?
Cheers
Justin.
Re: Joe's P19
Posted: Tue Jan 07, 2014 2:34 pm
by peter-curacao
Wow 8O that all looks great! 8)
Re: Joe's P19
Posted: Tue Jan 07, 2014 3:48 pm
by tech_support
Im looking for a similar flag for the runabout, very nice 8)
Re: Joe's P19
Posted: Tue Jan 07, 2014 4:12 pm
by Joe H
Thanks Peter,
Justin,
I'm not sure if I'm going to put her on a trailer, my house is on a canal with direct access to the Great Lakes so I'm thinking about having an hydraulic boat hoist installed along the seawall, when I was at Richards ( aka Aripeka Angler) in sunny Florida he has his boat set-up on a hoist and it so convenient, pile all your fishing stuff in the boat push a button and lower her in the water and off you go. and for the winter I think I can just winterize her right on the hoist.
I still have to do a cost comparison between a hoist and a trailer.
Joel, are you talking about the Flag or the flag pole? In my search for an original old time flag pole I ended up with 3 of them, I might be able to help you out.
Joe H
Re: Joe's P19
Posted: Tue Jan 07, 2014 6:07 pm
by Hope2float
Joe, she is really starting to come together. I like the flagpole with the all around light too. I know what you mean about the wiring it looks challenging. I have the same controls for my Yami and just finished the backing plate as well. I will post a pic of mine in the tread. I am not familiar with the wire harness, but I would think that it would be best to get some advise before connecting it. It could be powered by the cables going to the motor. I need to find out the same info. I lost the manual and any installation guidence given by Yamaha. If you find out give us a poke.
I bet you can almost see it in the water. We are both getting close and have the rest of the winter to prepare these boats properly without thinking to ourselves just get it in the water. Anyway she looks great and she will have a good launch
BUILD-ON!
Dave
Re: Joe's P19
Posted: Tue Jan 07, 2014 9:57 pm
by cape man
Wow! Just Wow! You've done so much since I last visited this. Looking great man! Love the Flag and backing plate. What's the temp tonight? We may hit 35 here.
Re: Joe's P19
Posted: Wed Jan 08, 2014 9:12 am
by wegcagle
Great work Joe. She's magnificent! That's got to be the prettiest depth-finder mounting box I've seen 8) I am partial to mahogany though.
Will
Re: Joe's P19
Posted: Wed Jan 08, 2014 10:05 am
by cottontop
What more can anybody say, she is just fantastic. Hope your recovery goes well. It certainly is he-- to get older, but sure beats pushing up daisies. John
Re: Joe's P19
Posted: Fri Jan 10, 2014 7:32 pm
by Joe H
Thanks for all the positive comments, keeps me going.
Dave,
I need to find out the same info. I lost the manual and any installation guidance given by Yamaha.
I have the 703 Yamaha control manual but it's not much help when it come to the wiring, I can copy the wiring schematics and send them to you if you would like.
I like your backing plate, I just used a 2 X 6 and countersunk the nuts, yours looks great.
Craig,
34 today, go figure.
Wade,
I like mahogany too, I have had a couple of mahogany speed boats and think my next build will be one of the RB's with tons of mahogany trim.(for the Grandkids of course)
BTW, your new rod holders look much better, hope to see ya in Boca.
Hey John, thanks for the well wishes, sure does beat pushing daisies, my Doc tells me I can return to work next week, what? already? ha, I'm lucky to have an employer that understands and pays me a pretty good percentage of my take home $$$ well I'm off, I'm getting so many calls and emails from my guys and my boss I may as well be there anyway's.
Joel, I have this vintage stern light/flagpole, it's yours if you can use it.
Thanks again.
Joe H
Re: Joe's P19
Posted: Thu Jan 23, 2014 8:40 pm
by Joe H
Can't do much with my shoulder the way it is but did manage to mount my anchor roller.
Sorry about my picture quality lately but my camera won't let me load pictures onto my computer anymore so I have been using my Iphone
Joe H
Re: Joe's P19
Posted: Thu Jan 23, 2014 9:05 pm
by justin_dwyer
That looks great Joe :D
Where are you running your anchor rope and chain to ?
You just going to run up with a bucket ?
Can't wait to see the launch!
Cheers
Justin
Re: Joe's P19
Posted: Fri Jan 24, 2014 9:19 am
by Joe H
Hey Justin, how goes the build? The anchor rope goes into the cabin at the very front, yes a bucket or some sort of plastic bin to drop the rope into and the store in one of the cabin compartments when not in use, should work okay.
Me either but with this crazy polar vortex going on the Great Lakes are freezing over, that doesn’t happen too often, so I have a feeling it’s going to be a late spring, it’s going to take a little longer than usual for all the ice to move out.
Joe H
Re: Joe's P19
Posted: Fri Jan 24, 2014 3:48 pm
by justin_dwyer
Joe,
If you have a picture of where the rope comes through into the cabin, I'd love to see it. I assume it drops in just after the windless?
My build is on hold due to weather aswell, however I am at the other end of the spectrum, tropical monsoon. Been raining for 3 weeks now, and looks like another week to go. All the flood plains are full which means the fish will be up there breeding and we should have a great barramundi season :)
But the downside is that even everything is growing mould, tiles, bricks, shoes...you name it. I am not sure what the boat will look like when I take the cover off, was hoping to have it glassed by now, but just didn't make it, needed a could more days. I am ready to go though, as soon as the weather breaks I am ready to glass.
Keep tinkering in the meantime Joe, will be spring before you know it!
Cheers
Justin
Re: Joe's P19
Posted: Tue Feb 04, 2014 7:48 pm
by Joe H
Justin,
I have a new computer and do not have any Microsoft stuff loaded yet so I can't adjust the size of my pictures, I know there's other ways but don't care to get into that now, I'll load some pictures tomorrow at work. :)
Joe H
Re: Joe's P19
Posted: Wed Feb 05, 2014 9:27 am
by tech_support
Thats a nice windless 8)
Is the light/pole removable or fixed? Thanks for the offer :!:
Re: Joe's P19
Posted: Mon Feb 17, 2014 12:41 pm
by Joe H
Justin,
Sorry it took me so long to get back to this:
This picture show’s where the chain and rope enter the cabin from above.
Next is where it enters the cabin,
Then a few looking in the cabin where the chain and rope enters.
It’s just dropping into the box it was shipped in right now but I will have a bucket or some sort of Tupperware for it to drop into as a permanent solution, something I can store out of the way.
This was my first crack at installing a windlass too so if anyone else see’s anything wrong please let me know now.
Joe H
Re: Joe's P19
Posted: Mon Feb 17, 2014 7:40 pm
by justin_dwyer
Hi Joe,
Thanks for that, I think it looks great. :)
Did you put any glass around the inside of those holes, to stop the chain eating away at the wood?
I was thinking of building a small shelf and box about where the style line is, so I could still slide my feet underneath on the bed. Just my initial thoughts at this stage. Still got two years or so to think about that as I haven't even glasssed the hull yet :P
Can't wait for a break in the weather so I can get some glass down.
Thanks again.
Cheers
Justin.
Re: Joe's P19
Posted: Tue Feb 18, 2014 11:16 am
by ericsil
I also like the windlass idea, if I can find some way to deal with the mooring line without going forward. It seems to make more sense with every passing year. I am waiting for the results.
Keep in mind, whatever you put the rode into had best drain into the bilge. That rope and chain carries a lot of water and maybe seaweed, mud, etc when it goes down the hole. I left a gap at the front of my bed panels and mounted a heavy canvas bag above my feet with the bottom slanted toward the gap. Sorry, no pictures. The boat is in Maine for the winter.
Re: Joe's P19
Posted: Tue Mar 11, 2014 11:00 pm
by Joe H
Hey Eric,
I know what you mean, I had a 24ft Sea Ray, the dirtiest part of the whole boat was the anchor storage box, it drained right out the side of the bow, I may do the same thing, I'd like to see what you did with the canvas, heading back to Maine soon?
Speaking of canvas, I just had covers quoted for my boat, cockpit cover, running canvas top, kinda like a bimini top but attached to the windshield, side windows made of clear plastic (isen glass) and canvas, cover for my windlass and a boot for the bimini, $3600.00 sounds like way to much for me!
I had a separate quote from another canvas guy for just the cockpit cover, $800.00, I guess I'll start there, I need a cockpit cover, this is the kind of cover I had him quote $800.00 just seems like a lot of $$
Joe H
Re: Joe's P19
Posted: Wed Mar 12, 2014 5:29 pm
by ericsil
I'll be back in Maine about May 1st. Time to repaint the bottom on the p19 and touch up the decks. This is the last boat I ever put a lot of bright work on. I am too embarrassed to send you a photo of my cabin after seeing what yours looks like.
I know what you mean about the canvas costs. I gave up trying to buy some and got out the sewing machine and a grommet kit from mcmaster Carr. I only use the deck cover if we are parked for the night or my passengers are getting wet. Out on the mooring I just let the deck get wet. The boat drains fairly well out of the scuppers and has the sump pump for backup. However, I can see how my boat is doing from my bedroom window. Just keep remembering that more boats sink from rain than leaks in the hull.
Re: Joe's P19
Posted: Wed Mar 26, 2014 2:26 pm
by Joe H
Approaching another milestone! :D
Joe H
Re: Joe's P19
Posted: Wed Mar 26, 2014 3:37 pm
by justin_dwyer
Looks great Joe, will be keen to see how the 90 pushes her along.
Nearly there :D
Re: Joe's P19
Posted: Thu Mar 27, 2014 8:38 am
by topwater
Getting so close now Joe , Motor looks great hanging on the boat. Just think you will be able to launch
pretty soon :) That is if it ever warms up :wink:
Re: Joe's P19
Posted: Fri Mar 28, 2014 8:42 am
by Joe H
Yeah John still 2’ of ice on the bay!
I’m hoping I didn’t bite off more than I can chew with this motor install, the motor is used so I’m going through it and doing a compression check, change all the fluids, replace the impeller and fuel filter and whatever else I find along the way.
Also I’m finding I need a few things for the install:
1. Drag link for the steering cable ends
2. Throttle and shift cable ends at the motor
3. Couple of drain screw caskets
4. Fuel filter
5. Impeller
6. ????????
Problem is none of the dealers around here have all that stuff on the self, I’m looking on ebay but I may break down and order all the stuff tomorrow if I can’t find it today.
Re: Joe's P19
Posted: Fri Mar 28, 2014 8:56 am
by callyb
Been a long time since I have posted, but...
I am pretty sure that Inshore Marine in AuGres keeps Yammy parts in stock. That may be farther than you want to drive for parts, but I figured I would toss it out there.
Carl
Re: Joe's P19
Posted: Fri Mar 28, 2014 11:47 am
by Joe H
Hello cally,
Yeah, nice area but that's a long hull for me!
Already found the cable ends, if their the right ones.
Joe H
Re: Joe's P19
Posted: Fri Mar 28, 2014 11:49 am
by peter-curacao
Joe H wrote:Approaching another milestone! :D
Congratulations Joe on this milestone, boat looks fabulous! 8)
Re: Joe's P19
Posted: Fri Mar 28, 2014 12:04 pm
by Joe H
Thanks Peter, I hope you’re having fun with your boat!
I had to move the boat forward some to get the transom under the I beam so I could use it to mount the motor, I almost moved it to far, I can drag the boat forward but cannot push it backwards, I had to remove the anchor and anchor roller just to shut my garage door.
Joe H
Re: Joe's P19
Posted: Sun Mar 30, 2014 9:45 am
by Joe H
90 hp Yamaha mounted and looking pretty, the hole pattern lined up perfectly to the template provided by Richard, I still have lots of work to do but getting a slow start this morning, one to many Margarita's last nights!
I'm doing a PM on the motor, anything out of the ordinary I should be looking for? as mentioned earlier, I'm doing a compression check, changing all the fluids, replacing the impeller, changing the fuel filter, checking the spark plugs, ????.
Janet's barking out something behind me, I better get out to the garage now.
Edit:
Back in the house, got some of the electrical stuff out of the way today, all I could handle.
Go Mich time.
Joe H
Re: Joe's P19
Posted: Mon Mar 31, 2014 9:24 am
by topwater
Looking good Joe :!: Joe can you take a pic of the companion way so I can get some ideas on door and hatch setup .
John
Re: Joe's P19
Posted: Mon Mar 31, 2014 12:00 pm
by Joe H
Hey John,
Check out page 57, I took those with my cell phone so the quality sucks, I'll take some better pictures tonight.
Joe H
Re: Joe's P19
Posted: Tue Apr 01, 2014 9:10 am
by topwater
Thanks for the pic's Joe . What I was looking at was the hatch , looks like you used ply top with cleats all around
and offset hinges correct :?: Just trying to come up with a game plan for my hatch . Yours looks real nice so I thought
I would ask .
Thanks John
Re: Joe's P19
Posted: Tue Apr 01, 2014 9:15 am
Sure is looking good, Joe 8) You are going to love that engine, it's about bulletproof.
Post by callyb » Fri Mar 28, 2014 7:56 am
Where the heck have you been ? :D
Re: Joe's P19
Posted: Tue Apr 01, 2014 9:45 am
by wegcagle
Nice milestone Joe 8) Your boat is a looker for sure. Hope the margaritas wear off soon :help:
Will
Re: Joe's P19
Posted: Tue Apr 01, 2014 12:58 pm
by Joe H
Thanks Guys,
Getting close!!!!! :) :)
Yep John, I had grandeurs plans for that hatch lid, it was supposed to be a bi fold solid mahogany hatch but I had the ply and the cleats laying around,,, turned out okay.
Had to throw this in because I think it looks cool!
Joe H
Re: Joe's P19
Posted: Tue Apr 01, 2014 6:18 pm
by justin_dwyer
I think it looks cool too Joe, awesome work!!
You are going to have some great times in her I am sure!
Cheers
Justin
Re: Joe's P19
Posted: Thu Apr 10, 2014 12:23 pm
by Joe H
More boat porn.
I've been doing lots of little things trying to get her ready to launch as soon as the ice is out of canal.
I have the marine mechanic from my in-laws boat works helping me out with a few things, I’m not sure yet if he was a blessing or, well something else, he is making sure the Boat can be coast guard approved if necessary, he is very meticulous and today he is spending the day in my garage finishing (re-doing) what needs to be done, his job before he went to work for Mayea’s was installing outboard motors on new boats and all the electrical, that included wiring the whole boat, so, he pointed out about 10 things he would have done, in his kind words, differently, so he’s hired! Ha, this will give me a complete professional and approved system install, I can’t wait to get home to see the progress he has made!
A few more pictures, sorry about the quality, taken with my IPhone.
The fog bell was a birthday present from my Wife, thank you Janet!
And the Compass was a gift from a good friend of mine who’s been with me morally through this entire build, he even drew up a few of the parts on CAD for the CNC cut, thanks Jim!
Joe H
Re: Joe's P19
Posted: Thu Apr 10, 2014 12:28 pm
by garym
Looks great.
Getting her wet soon?
Re: Joe's P19
Posted: Thu Apr 10, 2014 1:11 pm
by peter-curacao
Joe H wrote:A few more pictures, sorry about the quality, taken with my IPhone.
The quality of your work makes up a 1000x the quality of your phone pics, maybe you should go work for Apple and teach them a thing or 2 :D
Men! Joe that's really a boat to be proud of! 8) 8)
Re: Joe's P19
Posted: Thu Apr 10, 2014 5:47 pm
by justin_dwyer
Definitely a boat to be proud of Joe. Beautiful work!
Re: Joe's P19
Posted: Thu Apr 10, 2014 10:03 pm
by Hope2float
Joe she looks fine and you are getting close. Keep up the great work and get ready for some reel fun.
Dave
Re: Joe's P19
Posted: Fri Apr 11, 2014 7:54 am
by Walkers Run
Love your boat. Can't wait to see it in the water.
Re: Joe's P19
Posted: Sun Apr 13, 2014 11:59 am
by blueflood
Hi Joe,
I love her functionality and those filets :D. Did you go the distance and fair the cockpit and cabin or simply left the glass
exposed ? My plan is to make the seams symmetrical and tidy then apply 3 coats of tinted epoxy only over primer so those filets will take some work around everything - I mean everything.
Marc
Re: Joe's P19
Posted: Fri Apr 18, 2014 2:21 am
by Joe H
Thanks Guys, please keep the comments coming they keep me going! ha
Gary, soon, very soon.
Hey Peter, I think I'll keep using the Iphone, makes my work look better, thanks man,
Can't wait for that reel fun Dave, but I think at this pace you may beat me in the water!
Marc, I faired most of the interior, the fillets took about 4 or five coats to build it up inside the windshield but I think it came out okay, well worth the effort.
I had a very good vacation week so far, my mother-in-law, who has been living with us for the past couple of years is spending the next couple of months at my sister-in-laws, my Grandson and daughter also live with us but they have been, well, elsewhere for the past week, Grandson at his good for nothing dads for spring break and my daughter at her good for nothing boyfriends for the last week, don't get me wrong, I miss them all but man has it been nice and quite around here, and a much needed break for Janet plus I've been catching up on a lot of little things around the house and on the boat, nothing really picture worthy but did fit the glass for the windshield.
Walkers, man you boat looks great, with Peter doing such a fine job on his you have a lot to look forward too, you are in the toughest part of the build, just keep rocking!
Justin, sorry I didn't respond earlier, I've been away from my computer, I used 1 kit of QF and 2 containers of 410 west system, I faired the inside and out, I still have some left in the second container of 410, I also used the purple stuff from Bateau to fill in all the weaves on the glass before I faired, I'll check tomorrow on the 410 container size and respond on your thread.
Joe H
Re: Joe's P19
Posted: Fri Apr 18, 2014 4:35 am
by justin_dwyer
Thanks Joe, that'll be great.
Re: Joe's P19
Posted: Thu Apr 24, 2014 12:36 pm
by mecreature
Looking Great Joe. Your work is great.
How did last winter treat you up there.
I think we broke every record we could down here in Indy.
Re: Joe's P19
Posted: Fri May 02, 2014 9:14 pm
by Hope2float
Joe, Thanks for the shout out. By the way your boat looks great and its getting close. As for the answer to your question on putting the boat on the trailer it is easy. It is a little time consuming. In simple steps block up the transom in each corner either with concrete blocks or wood cribbing, then support the keel toward the bow with blocking. raise boat up high enough for trailer to clear underneath. Back the trailer up by hand and raise tongue up or down to get bunks parallel to the planing surface. When the support is up against the bow blocking set another set of cribbing in front of the support and remove the rear one and continue to move trailer backwards. You can use the crank to move the trailer toward stern. repeat this procedure until you have cleared the last cross support on the trailer.
BUILD_ON!
Dave
Re: Joe's P19
Posted: Fri May 02, 2014 9:29 pm
What Dave said. You don't crank the boat onto the trailer, you crank the trailer underneath the boat. The boat is much heavier than the trailer. Trailer has wheels, boat doesn't :wink: Just take it slow and easy and work it back.
Re: Joe's P19
Posted: Sat May 03, 2014 10:41 am
by Dougster
I love this build and the work sure looks great. I will vouch for the above approach, having Dougstered the other way around approach with Nina. Dragging her up on that trailer with a come-a-long was an effort. I kept hoping nothing broke and came flying may way 8O My arm was sore for 3 days from heaving on that dang come-a-long. Live and learn.
Must I always Dougster :roll:
Re: Joe's P19
Posted: Sat May 03, 2014 10:55 am
Live and learn.
I hope so! As long as I'm living I intend to learn something every day. Usually it's the hard way :lol:
Re: Joe's P19
Posted: Sun May 04, 2014 8:45 pm
by Joe H
LOL, I'm glad you guys posted, I was heading the Dougster way fer sure!
Makes perfect sense now that I see it in print.
My brother brought his trailer over today but it may be a couple of weeks away yet, I finished putting the glass in and the mahogany moldings to help hold the glass in, most of the electric I have done, the bilge pump and windlass were a real pain but got her done, it just seems like I have a ton of small things to do before I drop her in but soon real soon.
I didn't get anything done on the boat today but the good news is I went fishing with my brother and his son, and we got our limit of Walleye!
mecreature , the weather hasn't changed much, still waiting for spring to arrive.
Thanks, Dave, Larry and Doug.
Joe H
Re: Joe's P19
Posted: Mon May 05, 2014 8:25 pm
by Joe H
Finished the windshield, made up some moldings from some leftover mahogany, getting the 45's cut and lined up properly took several attempts but got her done eventually, I used 3M clear sealant to water proof and 1" lg brass nails to fasten them down,
Joe H
Re: Joe's P19
Posted: Tue May 06, 2014 3:59 am
by justin_dwyer
That looks awesome Joe, I really can't wait to see her floating. :D
Re: Joe's P19
Posted: Tue May 06, 2014 7:34 am
by Aripeka Angler
Beautiful 8)
Re: Joe's P19
Posted: Tue May 06, 2014 7:58 am
by topwater
Thats some nice looking Finnish work Joe 8) Looks like you are building your own hatch on the cabin , show
a couple of shots of that when you are done . Thats a mighty fine looking boat :!:
Re: Joe's P19
Posted: Thu May 08, 2014 1:35 pm
by Joe H
Hi John,
I am eventually going to build a wood hatch but I have to tell ya, I found a cheap plastic hatch on ebay and for launch sake that is what is going on there for now.
I have a picture of it around here someplace, I'll see if I can find it.
Joe H
Here it is:
Re: Joe's P19
Posted: Thu May 08, 2014 6:44 pm
by glossieblack
That hatch looks pretty nice for a temp job Joe. Eagerly looking foward to splach pics!
Re: Joe's P19
Posted: Thu May 15, 2014 12:13 pm
by Joe H
Thanks Glossieblack, it’s literally made out of plastic, I don’t know how long it will last!
Well, another milestone, I went down to the DMV the other day to get my MC #’s and hull identification #’s, when my number was finally pulled by an, I’ll say older women, she seemed very confused at what I was asking for, great I thought here we go!! So she had me fill out an affidavit with what she called a very detail explanation of my build process, when I was done with that I went back up but she was busy with someone else so another women said she could help me, I showed her what I had, she rolled her eyes and said you don’t need all that, she says all you have to do is fill out this one pager saying it is a home built boat and show me a couple of your main recites , pay $42.00 and I was on my way with my new MC and Hull ID #’s! yahoo, my boat is now official, well as soon as I receive my Decals from Boatus and slap them on.
It seems in the state of Michigan anything under 20 ft does not require a title or a Coast Guard inspection so it’s a very easy process.
Also installed my swim platform:
I just have to apply some kiwi grip on the floor, get her up on the trailer and drop her in the water, but before that happens I have a canvas cover being made, it should be done by tomorrow but I will NOT bring her outside until I have the cover, once I put her on the trailer there's no getting her back into the garage.
Joe H
Re: Joe's P19
Posted: Thu May 15, 2014 1:05 pm
by garym
Glad to hear your DMV trip went smoothly.
It can be a horror show if you don't get the right person.
My decals will be here tomorrow so I know what I'm doing Saturday.
I hope we're both in the water real soon
Re: Joe's P19
Posted: Thu May 15, 2014 1:17 pm
by Joe H
I'm with you Gary! Pretty exciting huh? My #'s should be here tomorrow too, but I will not be launching until next weekend, I have a 4 day weekend coming up so that will be it, I hope. Good luck on your launch, we'll be watching.
Joe H
Re: Joe's P19
Posted: Thu May 15, 2014 7:24 pm
by Hope2float
Joe good luck when that day comes. You have surely earned it. Everything is looking great and she is almost ready for launch. We will all be watching with enthusiasm.
BUILD_DONE!
Dave
Re: Joe's P19
Posted: Fri May 16, 2014 8:47 am
by topwater
Good to hear the boat is going in the water soon. You better take a bunch of pic's and shoot some video.
Or better yet have some one else do it because you wont be thinking of pic's on launch day .
Congratulations Joe on finishing your build she is beautiful :!:
Re: Joe's P19
Posted: Mon May 26, 2014 9:24 am
by Joe H
Hello All,
Well, we launched the P19 and she is at home in the back yard, I don't have any running stats because she is not running, walking, yes but not good, she ran on the hose in the driveway but when we launched we couldn't get her started but when we finally did she wouldn't rev up, only idle and idle rough, I limped home from the launch site on idle hoping she needed to blow 2-3 years of sitting in the create out and I'd be fine, it wasn't to be so yesterday I took the carbs off, and made my attempt at re-building them, she started right up after the re-build and sounds great at an idle now but when I put it in gear and increase the throttle she just stalls out.
I brought the specs up on line so today I will try to sync and adjust the carbs if that doesn't work I will call in a professional tomorrow.
I'm not going to load to many pictures right now because I'm a little disappointed but here's a teaser.
More reports to come.
Joe H
Re: Joe's P19
Posted: Mon May 26, 2014 10:05 am
She looks real good in the water 8)
I finally got my pressure washer running yesterday Joe :D I'm getting pretty good at cleaning carbs :lol:
Re: Joe's P19
Posted: Mon May 26, 2014 11:23 am
Meant to also tell you, after talking with you Saturday I went out and cranked my Yamaha. Let it run for an hour on the hose. You scared me :lol:
Re: Joe's P19
Posted: Mon May 26, 2014 12:29 pm
by garym
Looks great. You will be up and running before you know it.
Re: Joe's P19
Posted: Wed May 28, 2014 9:54 pm
by Joe H
Thanks Gary,
I tried adjusting the carbs after re-building them, changed the spark plugs, cleaned the fuel filter the engine still will not advance past an idle, every time I put the throttle down she just stalls out, she'll start right back up just won't advance.
I took the fuel pump out tonight and ordered a re-build kit, it didn't look bad but didn't look good either, I hope that's it's.
Larry, I called my mechanic but he's slammed at this time so I had to try something, I could not stand her just looking pretty out there and not running right, I'll keep trying until the mechanic can take a look at her.
Here's some more picture's.
The Grand kids didn't seem to mind that she wasn't running right.
Joe H
Re: Joe's P19
Posted: Thu May 29, 2014 1:54 am
by justin_dwyer
Hi Joe,
Just been away for work so haven't had much time to check in on the forum.
But I come back to see you boat launched....She looks awesome!! :D
That is a real bummer that your motor is having trouble, bet it is killing you not being able to take her for a spin. It will be all the sweeter when you get her going.
Great work on a really nice boat.
Cheers
Justin.
Re: Joe's P19
Posted: Sun Jun 08, 2014 4:03 pm
by blueflood
Hi Joe,
YEAH !! ...Super nice job Joe, those lines are really classy and just the right hardware. Glad it's done..but it never really is I guess.
Marc
Re: Joe's P19
Posted: Tue Jun 10, 2014 12:46 pm
by Joe H
Thanks Guys,
Well, so far I cleaned the carbs by removing them and removing everything on them, spraying with carb cleaner and blowing out with compressed air, 2 times, making sure everything was set to spec, re-built the fuel pump, replaced the spark plugs, compression check, double checked all the gas lines, even used a separate tank and gas line just to make sure, replaced one slightly cracked internal gas line (i think I cracked it), and still dies out when trying to go full throttle, my brother held his hand over the carb intakes on the last sea trial, and she took off like a raped ape! So once again back to the carbs, except this time the marine mechanic was able to come and check her out, he took all 3 carbs with him and they are now being professionally rebuilt, he seems to think the gaskets need replacing and something is obstructing one of the ports that I just can't see or get too, so we will see.
Stay tuned.
Joe H
Re: Joe's P19
Posted: Tue Jun 10, 2014 3:51 pm
by Matt Gent
If it has the basket in-line filter like my 90, check that it is tight, and that the o-ring is in place.
I had similar (though not as severe) symptoms and found that the o-ring was missing. Would run OK if I just cranked it down until I could get the o-ring in there.
Re: Joe's P19
Posted: Tue Jun 10, 2014 4:27 pm
by garym
Sorry your still having trouble :(
Never seen one of those. Is that fast :?:
Re: Joe's P19
Posted: Tue Jun 10, 2014 9:42 pm
by justin_dwyer
Fingers crossed Joe, really hope you get it sorted soon.
Joe H wrote:she took off like a raped ape!
I've never heard this quote before, but I'll be using it in the future... :lol: :lol:
Cheers
Justin
Re: Joe's P19
Posted: Tue Jun 10, 2014 10:30 pm
It's a Yankee thing, they get real bored in the winter when they are snowed in for months :lol: :lol:
Re: Joe's P19
Posted: Wed Jun 11, 2014 8:46 am
by Joe H
:lol: :lol:
Never seen one of those. Is that fast garym
Me either, too fast!
Matt, I forgot to mention, it does and I did take it off and clean it but I don't recall seeing an o-ring, I'll take a look when I get the carbs back.
It's killing me waiting for the mechanic to call and let me know whats going on!!!
Joe H
Re: Joe's P19
Posted: Sat Jun 28, 2014 8:17 am
by topwater
Joe did you get your engine problems straighten out yet ? Just wanted to know how you were doing haven't
seen anything from you in awhile .
Re: Joe's P19
Posted: Sun Jun 29, 2014 6:50 pm
by Joe H
Hello John, nope , still having engine problems, I'm on my second mechanic, the first one couldn't seem to get it right then he just baled on me , it's at the marina next door now and he seems to still think its the carbs even though they have been rebuilt once, he has them all apart and ordered rebuild kits, I hope to have it back for the holiday weekend , we are running out of summer here!
Thanks for asking.
Joe H
Re: Joe's P19
Posted: Sun Jun 29, 2014 9:17 pm
Already :?: All six weeks of it :?: Dang Joe, I'd have to move south. Summer is just getting started good down here. We like to start them about the first of March and end them about the first of November. If summer can't last 8 months I ain't living there. And if the water freezes in the winter I ain't living there either :lol: Don't understand how you stand it :doh:
Hope you get that engine fixed before you freeze over again.
Re: Joe's P19
Posted: Mon Jun 30, 2014 9:37 am
by justin_dwyer
I sure hope you can get it sorted Joe, I would love for your sake for you to be able to experience the joy of seeing how she goes.
Hang in there buddy :)
Cheers
Justin
Re: Joe's P19
Posted: Mon Jun 30, 2014 10:01 am
by Joe H
Already All six weeks of it Dang Joe
Kinda kidding a little, but really only have July and August left, boats come out end of August for the most part, I usually leave mine in for most of Sept for the fall fishing but each year the she comes out of the water earlier and earlier, I can't take the cold like I used to Larry, the sooner I get down south for the winters the better, still have that 5 acres? I'll take it!
Thanks Justin, me too, we have been doing a lot of fishing in my brother’s boat so it helps to take the edge off.
(you hang in there too, I'm sure you'll get things sorted out, personally I would just replace the one bad sheet of ply and move on, you can hold the shape with a few extra bits on the inside.)
I'd say I'm waiting patiently but I'm the most impatient person there is, I'll stop by the Mechanics shop on the way home from work today just to see how he's coming along, ha.
Joe H
Re: Joe's P19
Posted: Wed Jul 02, 2014 2:20 pm
by Joe H
My engine has been fixed, I just received a call from the mechanic and he said all is good and she's running great, :D I'm at work right now but the second I get home I'll be out on the water, reports to follow!!
It’s an hour drive home for me from work, if I had a helicopter I couldn’t get home quick enough!
Joe H
Re: Joe's P19
Posted: Wed Jul 02, 2014 2:47 pm
by garym
Thats great news. What was wrong with the engine?
Re: Joe's P19
Posted: Wed Jul 02, 2014 6:17 pm
by justin_dwyer
I would have felt "sick" straight away and taken sick leave :wink:
That is great news Joe, I'm really happy for you and can't wait to hear how she goes.
Cheers
Justin
Re: Joe's P19
Posted: Wed Jul 02, 2014 9:55 pm
by Joe H
Just got in from a very nice boat ride, I went earlier but it was very rough and could not get any good readings, just long enough to find out she was running great!
Second time out the winds had died down a little, she jumped right out of the water, up on plane with very little effort, rode high and tracked great, topped out at about 33mph at 4800rpm's, I think that's pretty good!
My buddy was out on his boat and took some videos, but he hasn't them to me yet, as soon as he does someone will have to show me how to post them.
I'll post some pictures this weekend.
Feels fantastic to have her running right and ride so nice, thank you to Jacques for such a great
design and for all the fantastic support from this forum!
Videos coming soon!
Joe H
Re: Joe's P19
Posted: Wed Jul 02, 2014 10:23 pm
by justin_dwyer
That is awesome news Joe. You did a great job with your build and I hope to follow suit.
Can't wait to see some pics.
Now it is time to enjoy 8)
Cheers
Justin
Re: Joe's P19
Posted: Wed Jul 02, 2014 10:36 pm
by Joe H
Thanks Justin!
Gary, it was the carbs all along, I guess they just needed a professional touch!
I can't wait to get out and do some fishing in her.
Woohoo the P19 is ready to run!!!!!
Joe H
Re: Joe's P19
Posted: Wed Jul 02, 2014 10:39 pm
I ain't going to say I told you so a month ago, or half the summer ago to you :D
Re: Joe's P19
by justin_dwyer
I'd be keen to see how she goes in a bit of chop, whether or not you get water spray over the decks.
Such a great feeling I bet Joe, Well done again mate. :D
Re: Joe's P19
Posted: Thu Jul 03, 2014 3:50 am
by glossieblack
Joe H wrote:Woohoo the P19 is ready to run!!!!!
Well done Joe. I admire your work.
Re: Joe's P19
Posted: Thu Jul 03, 2014 7:46 am
by Joe H
Thanks glossieblack!
I have some video but they are .3gp files and I am unable to load them, any help?
Joe H
Re: Joe's P19 LAUNCHED & RUNNING!
Posted: Thu Jul 03, 2014 8:08 am
by icelikkilinc
YouTube recommends using the MP4 file format for the best quality video uploads. So, while you can quite easily upload 3GP videos to YouTube, you should consider taking the time to use a free converter to change the video into an MP4 before uploading. There are several free converters available
Read more : http://www.ehow.com/how_6346216_upload- ... utube.html
Posted: Thu Jul 03, 2014 8:50 am
by Joe H
Thanks ice but when I try and load the .3gp to YouTube through my Iphone it tells me no go, I'm at work right now and we do not have permissions to download anything on work computers, they are very strick about that.
I'll keep trying.
Joe H
Posted: Thu Jul 03, 2014 9:58 am
I uploaded the videos from Joe, but the resolution is awful. Sorry Joe.
Posted: Thu Jul 03, 2014 10:09 am
by Joe H
Thanks Larry, I'll get some better one's over the weekend, I opened an account with YouTube so I'll give it a shot when I have the videos, and more pictures.
Fishing tonight after the weekend warriors are off the water, it's going to be crazy on the water during the day with the Holiday weekend.
(edit)
I think I better just go home for the day, I'm not getting anything done here at work, ha. (work related that is)
Joe H
Posted: Thu Jul 03, 2014 10:15 am
I uploaded that to photobucket, didn't try youtube. Maybe it will be better. I'll leave that sorry one up there just to prove it runs :lol:
Posted: Thu Jul 03, 2014 8:18 pm
by topwater
Good to hear everything is fixed Joe 8) Cant wait for the videos :!:
Posted: Fri Jul 04, 2014 12:08 pm
by Joe H
My Brother came by this morning to check out the boat, he's one of the most critical/cynical people I know, he loved the boat, the way it rode and handeled, it's always nice to impress your big brother!
Here are some teaser pictures, I'll upload more, and a video as the weekend goes on.
Joe H
Posted: Fri Jul 04, 2014 12:34 pm
by Steven
Beeeeeeutiful!!!!!!!! all that hard work payed off.
Posted: Fri Jul 04, 2014 2:42 pm
Steven said it. Beautiful 8) Nice work Joe.
Posted: Fri Jul 04, 2014 2:45 pm
by Noles309
She looks good running for sure!
Posted: Fri Aug 15, 2014 2:11 pm
by Joe H
Trolling motor mounted, works great!
Thanks for looking.
Joe H
Posted: Mon Aug 18, 2014 9:50 am
by crackedconch
Very nice!!!!
Posted: Mon Aug 18, 2014 4:55 pm
by cottontop
She's one great looking work of art. Way to go Joe. What's up your sleeves next? John :D
Posted: Tue Aug 19, 2014 12:32 pm
by Joe H
Thanks crackedconch, and it catches fish!
Hey John, how's retirement treating you? I would like to get started on the RB-16 but I'll have to sell my OD16 first to get a little extra cash for the supplies and make a little room in the garage! ha, I'll just enjoy the P19 for now.
Joe H
Posted: Tue Aug 19, 2014 6:03 pm
by Hope2float
Hey Joe CONGRATS on her and the fishing
Dave
Posted: Mon Nov 03, 2014 2:40 pm
by Joe H
Well she’s all stored away for the summer, this was one of the last outings! P19 performed flawlessly, we had tons of fun on her this year even though it was a short summer, we pulled her out of the water after being in for 3 months and the bottom still looked great and no water in the bilge! The small cabin came in real handy with the grand children and when my wife wanted to get out of the sun, I have a few things to do before she gets back into the water next spring but knowing she’s all wrapped up and behind the garage with no access until spring is kinda tough.
Thanks to Jacques and everyone who contributed to this build!
Now, what next?
Joe H
Posted: Mon Nov 03, 2014 6:11 pm
by wadestep
I like that picture - She's a beauty!
Joe H wrote:Now, what next?
You'd better start another boat before the honey-do list gets too long... :lol:
wade
Posted: Mon Nov 03, 2014 7:16 pm
by justin_dwyer
She's a ripper Joe!!!
Do you have any pictures of the cabin with people in there, would love to see the space occupied?
I read your whole build thread in the last few days (again), it was a great read and makes me keen to continue on with mine.
I am flipping it this weekend :lol:
Posted: Tue Nov 04, 2014 10:30 am
by mecreature
Nice job Joe. She is gorgeous.
Posted: Tue Nov 04, 2014 2:44 pm
by Joe H
Thanks mecreature!
She's trying already wade, wants to re-do the kithen, I gotta get going on something soon.
That's cool Justin, now you seen how I flipped mine, no problem. Hmm, Ripper, I like that, she doesn't have a name yet!
I looked for pictures of the cabin and I could not find any, guess you'll have to wait until spring. :)
Thanks for looking.
Joe H
Re: Joe's P19 RE-LAUNCH
Posted: Thu Apr 16, 2015 11:45 am
by Joe H
A successful re-launch of the P19, I got in kinda late in the season for Michigan last year so was very anxious to get her in early this year, I’m happy to report all went well!
The Yamaha fired right up on first crank and ran beautifully all weekend, in one of the pictures you can see ice coming from Lake Huron still flowing down the river, on the Lorance the water temp is reading 39°.
I’ll take some pic’s of the cabin for you this weekend Justin.
Oh, one more thing, I sold my OD16, sad and happy day all at the same time.
Joe H
Posted: Thu Apr 16, 2015 12:47 pm
Glad to see you out of the ice finally!
Sold the OD? I'm thinking about selling mine too and upgrading :D
Posted: Thu Apr 16, 2015 9:04 pm
by justin_dwyer
Joe H wrote:I’ll take some pic’s of the cabin for you this weekend Justin.
Thanks Joe, that would be awesome, I am about to start building again, looking at mixing some epoxy next week (got relatives in town this weekend).
Must be a really good feeling to be in her again?
I think my son will be at least the age of your skipper there, maybe a bit older by the time I finish my boat (and I started before he was born). My wife is pregnant again so I'll try and make some progress on the boat in the next 6 months before #2 arrives. I seriously "overestimated" the amount of work I would get done with a few small ones around. :lol:
A great looking boat, don't be shy in posting plenty of pics, I love seeing them :D
Cracker Larry wrote:Sold the OD? I'm thinking about selling mine too and upgrading :D
Cracker, you'd probably knock out a TW28 in a few months :wink:
Cheers
Justin
Posted: Mon Apr 20, 2015 8:37 pm
by Joe H
Congratulations Justin!
Here’s some pics of the cabin as promised, I hope to have cushions made for it soon.
That’s Rider in the pictures, he’s new to boating so still a little nervous about it.
When sitting in there my head hits the top of the cabin and I’m only 5’ 8” but it’s a great place for my little skippers to get out of the sun.
Hey Larry, before I sold my OD16 I made sure I had something in the backyard to replace it, so what are you thinking?
Joe H
Posted: Mon Apr 20, 2015 8:42 pm
by justin_dwyer
Thanks Joe, they are great pictures.
Rider looks like a pretty cool customer 8)
The idea is to have the cabin for the two little ones to sleep in while Mum and I fish :lol:
How does she go with a 90?
I am thinking of putting a 115hp on it so I can load it up with fuel, water and camping gear. I am thinking of putting two fuel tanks in.
Posted: Tue Apr 21, 2015 2:14 pm
by Joe H
Hey Justin, I think you would do much better with the 115, the 90hp is okay, I can get up to 36mph according to the GPS with just me in the boat but get her heavily loaded and the 90 struggles, she has a stock prop on her now I may go with a stainless.
I have a relatively small fuel tank, 25 gal hasn’t been an issue yet.
I just installed an on board 2 bank battery charger over the weekend, very nice option to have.
Same reasoning for me with the Grand kid’s, they love it, the cabin is their fort and the boat is their pirate ship!
Joe H
Posted: Tue Apr 21, 2015 4:19 pm
by Rogerdog
Is Rider a young whippet, or is he an Italian greyhound? I have a whippet named Jack who has very similar color markings.
That is a beautiful boat.
Wayne
Posted: Tue Apr 21, 2015 7:34 pm
by Joe H
Thanks Wayne,
I've read Larry's stories about Jacks adventures, I was hoping to see some pictures of him, we have had a couple of rescued whippets in the past but Rider is an Italian greyhound, he's something else but he does love going for boat rides!
Your boat is out of control, fantastic.
Joe H
Posted: Tue Apr 21, 2015 8:29 pm
Posted: Tue Apr 21, 2015 8:35 pm
by justin_dwyer
Joe H wrote:Hey Justin, I think you would do much better with the 115, the 90hp is okay, I can get up to 36mph according to the GPS with just me in the boat but get her heavily loaded and the 90 struggles, she has a stock prop on her now I may go with a stainless.
I just installed an on board 2 bank battery charger over the weekend, very nice option to have. Joe H
I would rather have the power and not use it than flog an undersized one(I think I'd get better fuel economy that way too).
Good idea with the on board chargers, does that just run off the motor, you would need to do a few miles for it to get any charge in there wouldn't you (sorry if this is a silly question, electrics will be my least favourite part of my build)
Joe H wrote:Same reasoning for me with the Grand kid’s, they love it, the cabin is their fort and the boat is their pirate ship!
I can see that game being played as well, expect Dad will be the fishing pirate and the cabin will be the locked dungeon :lol:
Cheers
Justin
Posted: Wed Apr 29, 2015 6:28 am
by Joe H
Hi Justin, sorry for the late reply, the on board battery charger has to be plug into an outlet, that way it keeps a constant full charge well she's moored behind the house, the motor keeps the cranking battery charged for the most part but I also have a deep cycle trolling battery that I use for the trolling motor and windlass, this is the one I have,
http://www.basspro.com/Bass-Pro-Shops-X ... /10224683/
Joe H
Posted: Wed Apr 29, 2015 7:05 pm
by TomW1
Justin you can run your extension cord to a plug like this which leads to your charger. http://www.cabelas.com/product/Boating/ ... _104205780
This will allow you to not even have to step into the boat depending where you place it to plug in your extension cord to your battery charger. I am not promoting this brand as I believe there may be better ones out there but it shows the best way IMHO to connect a charging system whether you have a 1,2 or 3 bank system to an extension cord.
Posted: Wed Apr 29, 2015 8:20 pm
by justin_dwyer
Thanks guys, that is a great idea I hadn't thought about...I will definitely think about it now though.
Posted: Wed Apr 29, 2015 8:40 pm
That is very cool, I hope my boss doesn't see that or I'll be installing 2 of them :help: :lol:
Posted: Wed Apr 29, 2015 10:56 pm
by jayb01
I've got this on an aluminum boat and it works well. Two banks (for two batteries) and 10amps per bank so it can charge pretty quick.
http://www.hodgesmarine.com/GUEST-2620A ... Q&click=19
Posted: Fri May 20, 2016 11:44 am
by Joe H
P19, finally at home where she belongs, it was a rough start to the spring here in Michigan weather wise but this week promises to be a good one!
Still trying to dial in the prop, Tom’s going to like to hear this, started with a 13 X 19 steel prop (came with the engine), went to a 17 pitch, 15 pitch, you were right Tom, 13 ¾ X 13 aluminum seems to be the closest I could get for running the proper RPM’s, still only getting 5900 rpm’s at full throttle but my prop guy has given up on me, says it must be the motor, close enough he says , is it? I don’t know.
Going fishing tonight regardless.
Joe H
Posted: Fri May 20, 2016 12:48 pm
Yep, close enough :D
Boat looks great now that ice is out. Don't know how you stand those winters!
Posted: Fri May 20, 2016 1:32 pm
by Joe H
I may have to go the way of Topwater soon Larry!
Joe H
Posted: Fri May 20, 2016 10:18 pm
by TomW1
Hi, Joe it's not your motor or any thing else. E-mail me arrowhead @ live.com and we will get you set up. Let me know what the rpm's were with the original prop and the 17 and 15 inch props. We were going to get you a SS prop so no use in settling for an aluminum one now, since you started with a steel prop. Let me also know the brand and model of the props they gave you to try. This will give me the rake and cup that you were dealing with. in example Michigan Raptor.
Joe I'll be glad to help. I may want to start from scratch if I don't get enough info from above.
Regards, Tom
Posted: Sat May 21, 2016 9:49 am
by topwater
Joe the boat is sure looking good in the water again 8) Come on down to Florida i haven't put on a long
pair of pants since i have been here . Much better than -50 degree wind chill .
Posted: Sat May 21, 2016 11:23 am
Geeez 8O I had to go turn on the heater after seeing that picture, and it's 85 degrees here :help:
Posted: Sun May 22, 2016 9:22 am
by topwater
:lol:
Posted: Tue May 24, 2016 11:32 am
by Joe H
Tom,
I’m done for now, not kidding, my prop guy has seen enough of me and I don’t have the cash for a stainless right now, I think I’m okay, I can get her up to 6000 and more by trimming the motor way up just before she lets go, she feels real good at a cruising speed of 25, thanks for all your help, oh, I ended up with a 13 3/4 X 13 Michigan Wheel.
6 more years of this rat race before I can go John, besides Larry gave away my 5 acres, now where am I gonna go. :lol:
New launch this weekend, now her Mom what’s me to build her a Kayak so they can go out together.
Joe H
Oh, one more thing, Jacques, I love my P19, everything about it, I have a guy here in Michigan that wants me to build him one, he's willing to pay but I do not have it in me to build for someone else, I have my own list I want to build before I can't, so if you know someone who would willing and can do a professional job please let me know.
Posted: Tue May 24, 2016 11:57 am
I know a couple of builders here in Florida but none in Michigan, sorry.
I am glad you enjoy the boat: you did a great job building her.
Posted: Tue May 24, 2016 1:35 pm
I could probably come up with another 5, since it's you :lol:
Posted: Tue May 24, 2016 6:52 pm
by TomW1
Tom,
Joe H
Joe, no problem with the prop. Glad you got it dialed in with the 13 3/4 x 13. Have a great summer of fishing.
Posted: Mon Dec 19, 2016 7:39 am
by blueflood
Hi Joe,
I had to look up your neck of the woods; Fair Haven MI on Google. So you are around Lake St. Clair ? If you are I have to say, what an amazing area especially around Anchor Bay, Goose Bay and Clay Township. All those channels, the hundreds of Islands and access to the Great Lakes. Boating paradise :D
Marc
Posted: Mon Dec 19, 2016 9:09 am
by Joe H
Marc
It's a great area Marc, Only an hour away from the big city where I work and when I'm out in the boat it feels like I'm hundreds of miles away, I don't think a lot of people realize how vast it really is, well because it's nothing but Lakes and rivers! ha,
Funny thing is I'll be up your way next week on one of the best ice fishing lakes in the world! Lake Simcoe.
Joe H
Posted: Mon Dec 19, 2016 9:41 am
by blueflood
Indeed, when I visited Lake Huron a few years ago...those are like oceans actually and they can get pretty nasty real fast. Plan is to cruise the Rideau Canal and on to Kingston for her maiden voyage (that can be done by canoe inside of 2 weeks) and maybe Toronto and your area eventually. You have to respects those lakes, safety is paramount so one small trip at a time - and close to shore :lol: Those docking areas by your houses 8) - nothing remotely like that at all in my part of the world. Love it.
Have fun on the ice Joe ! The Kawartha region is beautiful. Walleye I guess ?
Marc
Posted: Wed Dec 21, 2016 9:51 am
by Joe H
Marc,
If you ever make it to my area you are more then welcome to dock up anytime for as long as you'd like!
Joe H
Posted: Mon Apr 03, 2017 3:27 pm
by Joe H
When I first launched the P19 2 years ago my seats were supposed to be temporary, well I finally got around to replacing them with something that complements the boat!
Getting her ready for spring launch!
[image]http://gallery.bateau2.com/albums/userp ... G_1385.JPG[/image]
(I know it's been awhile but the posting of a picture doesn't work like it used to.)
Joe H
Posted: Mon Apr 03, 2017 3:59 pm
by cape man
Looking good!!
Posted: Mon Apr 03, 2017 4:45 pm
by Eric1
Very Nice! 8)
Posted: Mon Apr 03, 2017 5:10 pm
by Jeff
Absolute Classic!!! Very nice!! Jeff
Posted: Tue Apr 04, 2017 11:53 am
by Joe H
Thanks for the fix Craig!
Eric, I just went through you entire thread, very nice work, that’s a lot of boat! I was caught checking your boat out here at work and one of my coworkers said “Oh no Haynes is building another boat” Ha! Not yet but I have my eye on Browndogs FS 19,
Thanks for your kind comment.
Hey Jeff, thank you, you’re doing a great job too, hope you are liking it with Bateau.
I hope to be dropping her in the water for the summer this weekend, let the fun begin!
Joe H
Posted: Tue Apr 04, 2017 3:36 pm
by TomW1
Joe nice seats. Go get those walleye after you launch.
Posted: Tue Apr 04, 2017 3:56 pm
by Jeff
Joe, Thank you and yes, really starting to feel at home here!! Jeff
Posted: Tue Apr 04, 2017 6:49 pm
by Joe H
The Walleye are running already Tom, I'll be after them soon!
Thx
Joe H
Posted: Thu Apr 06, 2017 9:02 am
by topwater
Joe you better post some pic's of the boat in action .
Posted: Tue Apr 18, 2017 11:50 am
by blueflood
Happy Birthday Joe. The world became a better place on this day :D Took the day off :D
Marc
Posted: Tue Apr 18, 2017 4:45 pm
by Aripeka Angler
Happy birthday Joe :D
I like the seats, nice color match to the boat!
Joe H wrote: Tue Apr 04, 2017 11:53 am I hope to be dropping her in the water for the summer this weekend, let the fun begin!
Joe H
Birthday and boat re-launch sounds like a great excuse for a party! Have fun and post up some fish pics...
Posted: Wed Apr 19, 2017 11:50 am
by Joe H
Richard and Marc,
Thank you very much for the Birthday wishes!
We had one hell of a surprise Birthday Party for our 60th, I didn't think I could still drink that much tequila, or should I say I found out I can't still drink that much tequila! ha.
My twin brother and I have 3 kids each, all in their 30's now and 5 grandkids each, my Mom and sister came in from Florida and throw in a few friends, well we partied like rock stars! Great fun, the problem was neither one of us could get up for fishing the next day, but the boats in the water, running great and the Walleye are starting to run so life is good!
John, I'll get more pictures up soon, I still have to spend a few minutes to figure out how to post pics again, copy the URL and pasting in between the brackets no longer works for me.
[image]http://gallery.bateau2.com/displayimage.php?pid=64366[/image]
Joe H
Posted: Thu Apr 27, 2017 2:28 pm
by Joe H
Okay, just not happy with my prop, not getting the speed I think I should and she cavitates easier now,
From last summer:
Tom,
I have to trim the engine up way high to reach about 5800 rpm's before she slips, maybe I should go with a 4 blade?
Joe H
Posted: Thu Apr 27, 2017 6:05 pm
by TomW1
Okay Joe let's see if we can get you properly propped. Let's start from scratch since you now have used the P19 and have her loaded the way you use her. Fully trimmed in is not good.
So 1st her weight as used. Hull, motor, people, accessories, gear, ice, beer, safety gear and anything else you put onboard when you leave the dock. This is the most critical measurement you can give me 200 lbs. may mean 1 mph depending on HP.
2nd What motor do you have. HP, 2st, 4st, gear ratio(2.08, etc), max rpm. If you can't find these I probably can especially if it's a 4 stroke.
Now what prop do you have on the motor at the present time. 13.25 x ? or ? x ?
I think a 4-blade SS will be a good choice for your P19. I like to work with Power Tech as if the first prop isn't right on they do exchanges for $40 or 60. Maybe your prop guy handles them. I also know there cup and rake specifications better than others as most of the guys I have propped are in the south. But I have also use Michigan and Turbo. If you have a preference let me know.
We'll get you trimmed in and running smooth. The 4 blade will help you in rougher water and maneuvering as well as maintaining course.
By the way Belated Happy Birthday!
Regards, Tom
Posted: Fri Apr 28, 2017 1:03 pm
by Joe H
Thanks Tom,
Not much has changed since last season,
• Modified P19 @ not sure of the weight, 2500 lbs ?
• 90 hp Yamaha 2 stroke, 2.0/1 gear ratio, 274 lbs.
• Full throttle with just me in the boat 32-34mph turning 5500-5800 rpms.
• 4 strakes seems to help with rear lift and tracking, no high riding bow.
• 3 blade aluminum prop, Dia. = 13 ¼ Pitch is 13 now.
Speed has dropped a little and now she cavitates more then ever before.
Joe H
Posted: Fri Apr 28, 2017 11:17 pm
by TomW1
Joe got in late tonight and with a quick run the numbers came out funky. Will redo them tomorrow and then get back to you. Hopefully we will get as close as I have done with Cracker Larry and others.
You have a good weekend.
Okay Joe got this settled out shouldn't try to do something technical when I have been out for the night :idea: . The Prop I can recommend for you is Power Tech's RED4 or there RXB4 both in a 12 pitch. Both have a moderate amount of rake and cup, which means they will help with lift and steering control as I addressed in my last post. The RED4 will give you more bow lift so if you have a heavy bow with grand kids up there or gear stowed up there it will be the better choice. The RXB4 is from what they call there Accelerator series with equal lift and good all around performance. I think either prop will work for you. You can contact them direct at sales@ptprop.com or 318 688 1970. They also have one dealer in MI Henry H Smith in Algonac if that is any where close to you. They are in the northern suburbs see www.henrysmith.com
Personally I would go with the RXB4 and if it did not work change to the RED4. Let me know how things go. I looked at the Michigan Wheel props and could not get down to a 12 pitch in a SS.
Posted: Fri May 05, 2017 5:02 pm
by Joe H
Thanks Tom,
I grew up in Algonac, home of CC and Henry Smith Props, they supplied my last 3 props, I don't think they want to see me again, at least not for another trade in, the last prop from them was the 3 blade aluminum, 13 1/4 X 13.
I called Accelerator and sent them specs and pictures of my P19, they recommended the same prop I have on her now but did say I might get a little better performance with the RXB4, I just haven't decided if I want to drop down $400.00 to find out!
Thanks again
Joe H
Posted: Sat May 06, 2017 1:01 am
by TomW1
Joe H wrote: Fri May 05, 2017 5:02 pm Thanks Tom,
Thanks again
Joe H
Yes it would be better used to spoil the grand kids. LOL :D
Posted: Wed Apr 18, 2018 7:10 am
by glossieblack
Happy birthday Joe!
Please post a report of how you used your pretty P19 this coming summer :D
Posted: Wed Apr 18, 2018 4:21 pm
by Joe H
Hope to get her in the water this weekend! I have a folder around here someplace called summer fun 2017, lots of good boating pictures, I see if I can find it!
Joe H
Posted: Wed Apr 18, 2018 8:11 pm
by TomW1
Hey Joe good to hear from you. Long winter for you up there. Me too, had snow flurries just a couple of days ago. :lol: The tops of the mountains are covered with 5-9" of snow. How is the family doing. Hope all is well and you escaped the flue bug. Take care.
Posted: Thu Apr 19, 2018 10:38 pm
by Joe H
Hello Tom,
Snowed here this morning, funny you should mention the flu, I've been home for 3 day's with, yeah, the flu!
Tomorrow it's supposed to be in the 50's so maybe I can get outside for some fresh air!
Joe H
Posted: Tue Apr 24, 2018 8:48 am
by Eric1
Hope you get past that flu soon!
Posted: Tue Apr 24, 2018 12:26 pm
by Joe H
Thanks Eric1,
Back to work yesterday after being off for 4 days, still not feeling 100 % but gotta make it to spend it!
I just need to change the dope in the lower unit and put some new spark plugs in, not a big deal, I was taking on a little water last year so I have to find out where that’s coming in from, I have a pick-up for the live well on the bottom of the boat, I’m pretty sure that is where the problem is, if it’s not raining when I get home I’ll crawl under and take a peek!
Water temp is around 39 degree’s right now, the Walleye really start biting when it reaches 42, that could be this weekend so I have to get my old ass in gear and get her ready to drop in the water.
Can’t wait to see your flip! Keep on building!
I don’t remember if I posted this bad boy from last year or not!
Joe H
Posted: Tue Apr 24, 2018 1:59 pm
by Jeff
Nice catch Joe!!! Hope you are better!! Jeff
Posted: Tue Apr 24, 2018 5:04 pm
by Eric1
Nice!
Posted: Tue Apr 24, 2018 6:03 pm
by TomW1
Go Joe I love walleye and think they are the best eating fish in the world. Catch a bunch.
Regards, Tom
Posted: Thu Oct 31, 2019 2:10 pm
by Joe H
I had a great summer with the P 19 but while taking her out of the water the other day I had a little incident! Very rough water and came loose from the trailer cable.
Joe H
Posted: Thu Oct 31, 2019 2:11 pm
by Jeff
Sorry Joe!! Jeff
Posted: Thu Oct 31, 2019 5:40 pm
by glossieblack
Fix and forget. :D
Posted: Thu Oct 31, 2019 6:36 pm
You built it so you can certainly fix it. As someone would have said "ain't nothing but a thang" :wink:
Posted: Sat Nov 02, 2019 9:21 am
by Eric1
Crap luck! Sorry.
Posted: Sat Nov 09, 2019 11:54 pm
by Fair WX Pilot
Wow, that sucks. Other than the big hole in it, the boat looks great. Like the others have said, fix it and it will just be another boating story.
Posted: Thu Nov 14, 2019 2:06 pm
by Joe H
Absolutely right guy's, "ain't nothing but a thang" I'm already tossing around idea's on how to fix it but she's covered up for the winter, going to wait until spring.
Joe H
Posted: Mon Apr 18, 2022 6:51 pm
by glossieblack
Happy birthday Joe! Hope you're still enjoying the P19. :D
Posted: Mon Apr 18, 2022 7:36 pm
by Joe H
Yes I’m still enjoying the P 19, brought her out to the driveway last weekend to de-winterize and drop in the water, she has 4 inches of snow on it today maybe next weekend lol.
I’m also still enjoying your adventures keep them coming!
Joe H
Posted: Mon Apr 18, 2022 11:42 pm
by TomW1
Hey Joe, Tom spring sure has been finickity this year hasn't it. You should be out slaying Walleye by now. :lol:
Posted: Tue Apr 19, 2022 8:14 am
by Joe H
Hey Tom, nice to hear from you, yes I should be out chasing those walleye problem is I still have a couple Inches of snow on my boat!
Hopefully this weekend.
Joe H
