My hull sides did not stay where I thought I put them
Since it's a balsa model, I can fix it. Since it's supposed to rain for 3 solid days, I guess I've got the time. Anyway, I'll post some pictures later, should be worth a grin for you guys.
I fixed it. ( repaired photo to come )
I've started looking at skegs and lifting strakes, and I have some questions on hydrodynamics, build methods, best practices, whatever you want to call it about how these affect handling what is the best way to shape them, how should they be shaped and oriented. You may notice I've added the skeg ( not shaped yet )
I think I get the idea about the tracking and strakes lifting and grabbing in corners to prevent "skidding", but what is the experience or design elements that make these work the best without adding additional unnecessary drag. And before anyone says anything about design. I am not looking to change or add or modify the design. I just want to understand what other builders have found worked or didn't for them, and to understand the part these play when the boat manuvers in different sea conditions. Like what happens if the strakes are at different angles or too big?
Ive looked at many builds posted here, reviewed the shop manual, and took at look at some production boats in regard to skegs and strakes. What I've found so far is that there are as many ways to do this as there are people doing it. So at the risk of starting a debate, I ask for experienced builders to comment and toss in their opinions. I haven't built a boat, so I can guess, I need to hear from people that have actually built these, or fixed them, and / or have gotten them wet and seen for themselves how the boat acted.
The chine and strakes on this key west seem to have a revers angle on them like the not only lift, but actually tunnel water, trapping under the lip of the chine and strake. What's the idea or advantage? Dissadvantage ?
These maintain a perfectly horizontal bottom plane (which actually means the mold that made them twisted as it came around the bow and under the boat )
Notice how thin the chine is at the stern here. Does a designer modify or take into consideration what's going on the back of the boat when he designs the chine section at the transom? In this case we see twins mounted on a bracket, does this affect the design. If not considered or added to the design after it leaves the designer, how much risk is a builder taking in adversely affecting the handling he adds a bracket, for that matter what if he adds an armstrong vs. somthing else, some other bracket manufacturer? Again, I know at this point for me this is all academic. But I've got the engineering mind. Just wanna know how it's supposed to work.
Anyone care to throw in their $.02 here on the points labeled A - E?
What have you guys used, on what size boats? I'm "building" the AB23 so I'm also wondering about the size of these elements.
