A visual, it will be a little bigger than the cooler in the pic
OB19 in SW FL
Re: OB19 in SW FL
Completed : OB19, CC14, GV10.
Re: OB19 in SW FL
I built one a little bigger than that and used on layer of 1700 top and bottom. It seems to be enough.
Re: OB19 in SW FL
Ok, thanks. Maybe 12oz will be enough. I'll recheck after taping the seams. It's just so easy to glass before cutting into lots of little pieces.
Re: OB19 in SW FL
When I built my cooler I was worried about the same thing and used plywood on the exterior and interior with the foam sandwiched under, between and on top. Yes it made it heavier. I am thinking about building another with scrap materials and am curious about how yours turns out.
I agree it is much easier to laminate a larger flat panel if you have a big enough piece of cloth and then cut everything to size later.
Why not try a destructive test on a small piece of the fiberglass covered foam before you assemble it? Laminate both sides and hit it with something like a hammer or drop something heavy from above and see if it will dent, delaminate or crack.
Looking forward to seeing what you come up with. Good luck with your project.
Re: OB19 in SW FL
Delamination is more my concern. Watching with interest. I have lots of scrap, and have this project on the books.
Re: OB19 in SW FL
I cut the pieces today, and with the scrap tested the delamination strength. The glass skin on a 1" wide scrap was not hard to peel back. However, it actually peeled back a small layer of foam with it - so I guess it adhered to the foam well enough. The foam essentially peeled apart, not glass off of the foam. It's temporarily glued right now, need to tape it up on the inside and then grind the outside radius smooth next.
Re: OB19 in SW FL
Hello Wade,
Nice summery on the OB19.
I'm giving some serious thought about building the OB19 for fishing the great lakes, I love my P19 and will never get rid of her but she's a little tough to do some of the type of fishing I like to do, I need a trolling motor on the bow and something that doesn't act like a sail, (my P19) so i'm thinking the OB19 would be an excellent addition to my fleet!
Raising the sole I get, wish I would have done that on my P19, do you think and inch would do it on raising the sole, any other suggestions you could give me would be greatly appreciated!
Joe H
Joe H
Re: OB19 in SW FL
90 degree peel tests are notoriously disappointing..wadestep wrote: ↑Mon Aug 10, 2020 4:52 pm I cut the pieces today, and with the scrap tested the delamination strength. The glass skin on a 1" wide scrap was not hard to peel back. However, it actually peeled back a small layer of foam with it - so I guess it adhered to the foam well enough. The foam essentially peeled apart, not glass off of the foam. It's temporarily glued right now, need to tape it up on the inside and then grind the outside radius smooth next.
The only real way to test foam bonds is coupon pull of testing.
My panels also peeled easier than I had hoped.
Re: OB19 in SW FL
It is 'slappy' when running into a head sea, even only of 1 foot or so. It does not ride like a deep-V boat. Running into waves provides a jolt or slap, more than I was hoping for. However, the beneficial trade-offs include batter MPG, faster with same HP, more stable at rest, faster to plane, more beam=more room, etc...
Knowing what you know now would you have gone with a deeper V boat design?
Joe H
Re: OB19 in SW FL
Hi Joe, sorry for the delayed reply. I used to get email reminders for this thread...
Anyway, I do still think I would raise the sole only about an inch or less in order to create a trough at the back in front of the motor well bulkhead. This would enable complete self bailing with the exception of a little water remaining in the trough. As it is the drains are at the deck level which means that it doesn't drain 100%. Lowering the drains even a very little bit would improve the drainage. It could even be raising the sole a half inch. I don't think this is unique to the OB19.
Users browsing this forum: Google [Bot] and 12 guests
