SPLASHED - FS 14 - First Timer
FryFly
Post by FryFly »
Thought I would say hello.
I've just ordered the plans for a FS17 and they are on there way across the pond. It'll be the first boat I've ever built. Actually if you dont include a couple of model planes and a spice rack its one of the first things I've ever built. I may have some silly questions to ask :D
I'm in the U.K. and winter has just arrived so should have plenty of time to chuck in. With any luck my best mate Tommo and I will have her ready for summer.
Currently I am thinking of extending a casting platform in the front and back, and moving the centre console a little further back it will mostly be used for Flyfishing our coastal waters (Bays and inshore) for our local bass. I'm also looking to integrate a seat/cooler into the console as follows. Excuse the terrible sketch...
Would I need to approach any design engineers before I attempt this sort of modification with the decks and console, I've been warned about structure integrity?
I hope to prove EVERYONE wrong and stay afloat. Hope you can help. :oops:
Many thnaks,
Glynn
steve292
Re: FS 17 - First Timer
Post by steve292 »
You can do more or less what you want within reason, as long as you keep the frames where they are.
The FS 17 is a smallish boat & you need to think about weight & where you put it .
Anything major you want to alter you need to post in the power boats section, & get Jacques or Shine's input.
Where are you? If you are near Weston-super-mare, I can show you mine.
Steve
remedy32
Post by remedy32 »
Hi Glynn,
Steve's quite right that the boat is a bit smallish. You should be sure to locate the console where it's shown on the plan to maintain correct fore/aft balance. (Modest) Steve should also mention that his 360 (or so) photos on this site have helped myself and others immensely in picturing how the boat looks and goes together!
So far with about 8 hours on the water I'm very happy with the boat in just about every way.
Bill in CT USA
FS17
FryFly
Post by FryFly »
Thank you both for your comments - I'll be very considerate of size/weight.
Steve I'm in Maidenhead. Not a million miles away and it would be great at some point to come and have a look. I saw your build but the pictures on later pages seem to be missing. I'll have a good search around.
macs
Post by macs »
Welcome to the world of boat building. Ask lots of questions, others will learn from the questions and the answers. Post lots of pictures also. Good luck and welcome again :)
Macs
wegcagle
Post by wegcagle »
You should be able to build that console without much of a problem. I would take a look at the plans and see how wide the sole is at the level of the console. My opinion is to keep the console as thin as possible to do the job. That way you have more foot room around the center console. I also built my console first (I actually built 2 consoles first. Just didn't like the looks of the first one when I was done. It was too plain and too tall. I wanted sleek and fancy :lol: ). Building the console first was probably the best thing I did, because it is a GREAT introduction to the tools and method used here. I'm apparently a big nerd (you'll see why in a second). I first came up with the total length, width, and height. Then I used the pythagorean theorem 8O (AKA the nerd part) to come up with my triangular measurements for all of the fancy parts in between. (That's A squared +B squared = C squared). Worked like a charm and all of the pieces fit together perfectly :D (on both consoles :lol: ) I used a layer of 12oz biax tape on the outside and inside, and then fiberglassed each side with 9 oz weave (because I had alot of extra). You are also going to want to put backing blocks on all of the places that things will get attached to. (fishfinder, speakers, gauges, steering wheel, handle bars, etc) It'll just make you console tough as nails.
Good luck and post LOTs of pictures.
Will
FryFly
Re: FS 17 - now FS14
Post by FryFly »
So here's the thing, lots has changed due to building location issues. I'm dropping the FS17 Build as it cant fit in the garage that I have available to me. I ordered the FS14 plans which arrived as promptly as the FS17.
We've cleaned out the garage and built some trestles to put the strong backs on. We ordered the epoxy, tape etc. The woods delivered and cutting has commenced. I think the boat will be great for two people flyfishing and a few people pleasure cruising on the river. We have a 4 stroke 15HP and will convert it to steering for the console.
I'm planning a few alterations. Taking the middle seat out and installing a console. adding Gunwales. I'll be adding Foam under the sole and installing 2 sole hatches. Casting platform and also a potential rear platform with storage hatches and a livewell.
I hope the FS14 will handle the inshore chop. I'm quite excited - however this turns out, it's going to be fun. :roll:
Colour wise we are planning red/white.
As a matter of interest while sourcing the materials etc, I built a little balsa scale version of the hull to get a feel for it, i'm deffinitly going to ba an addict.
Just the colour scheme idea - the red on the deck will be non slip
mechdave
Post by mechdave »
Just a suggestion. The FS14 is a pretty small boat. With your 15 hp why not keep it tiller steered and leave it more open to fish. You want to keep it light for the best performance. You could always add a small side console at a later date and run the controls down the side. This would get you in the water quicker to. It's hard not to add more features in but try to keep it simple and I think you'll be more satisfied with the results.
chicagoross
Post by chicagoross »
"Bucket test" the console - can you carry a 5 gallon bucket past it? We always seem to be using these multi=purpose tools on a small boat - you don't want to lift a full one over the console.
TomW
Post by TomW »
Yep do the bucket test. This FS14 was built in the Netherlands 4-5 years ago. It has a small console as you can see. Nothing as elaborate as you are going for. I just don't think there is room but go for it if there is.
C17ccx, Mirror Dinghy
Users browsing this forum: Bing [Bot] and 4 guests
