FS12 (many liberties taken)
Posted: Thu Nov 11, 2010 12:28 am
by deering
My intended use of the boat was to be the tender for my big boat (35' aluminum power catamaran in Juneau, Alaska). But it needed a few features that I couldn't find in any building plans. Here were some of my criteria:
- flotation in the stern because I would be launching it stern-first from the aft deck of the big boat, and I was afraid it would bury the stern and swamp.
- fit through my big boat transom gate which is 6' wide.
- be light enough to drag up onto the big boat manually
- be super stable and unsinkable (cold water up here - mishaps not allowed)
- really dry ride (did I say the water was cold?)
- capable of carrying at least 4 people and a 70 lbs dog. Getting up on step would be a bonus.
- reasonably smooth ride for a small boat
Doesn't sound much like your basic FS12, does it? Well, I started with that design and then started taking liberties, making it up as I went along. The results far exceeded my expectations, and yielded the best small skiff I've ever ridden in, hands down. No bragging here -it was all dumb luck.
Here are some pics: http://picasaweb.google.com/lh/sredir?u ... feat=email
Bob
Re: FS12 (many liberties taken)
Posted: Thu Nov 11, 2010 1:12 am
by sitandfish
Looks like you had fun building it. I like the chine being chopped off. It might have worked (IMO) on a displacement hull but looked scary, otherwise. It does plane, doesn't it. Have any action shots of it running?
Posted: Thu Nov 11, 2010 1:33 am
by sitandfish
deering wrote:...Doesn't sound much like your basic FS12, does it? Well, I started with that design and then started taking liberties, making it up as I went along. The results far exceeded my expectations, and yielded the best small skiff I've ever ridden in, hands down. No bragging here -it was all dumb luck... Bob
I had to go back and give the pictures more than a quick glance. You truly did build a FS12. :wink: What had initially thrown me was that hump in the sponsons at mid ship. Thought I was looking at a displacement shape for a minute.
Cool process. I really like the interior layout. If I did an FS12, I would have to copy this interior layout exactly. The paint detail on the inwale is a really nice touch. Thanks for posting the building process shots.
Posted: Thu Nov 11, 2010 9:30 am
Impressive, this must be the most heavily modified FS12. The bottom is still FS12 and she should perform well.
She may not be lighter than the original, that would be difficult.
Posted: Thu Nov 11, 2010 11:25 am
by gstanfield
Wow, you aren't kidding about "heavily modified" 8O She looks nice though :D
Posted: Thu Nov 11, 2010 12:33 pm
by heloman30
Wow, that's cool! Were you thinking of a RIB when you added all that floatation up high? Does it act like one? Looks like it would be very stable sitting on the wide "sponsons" at rest but then run normally with them lifted out of the water once on plane, like a RIB. Why did you cut the lower edge of the sponsons off?
Posted: Thu Nov 11, 2010 6:58 pm
by col555
WoW, i like it.
C
Posted: Thu Nov 11, 2010 8:52 pm
by gstanfield
heloman30 wrote:...Why did you cut the lower edge of the sponsons off?
The caption below the above picture said "Decided I didn't like that corner - too much chine trip potential"
Just wanted to add some pics in the thread :D
Posted: Fri Nov 12, 2010 11:27 am
by deering
Hi All,
Sorry for the delayed response to your questions - I updated my profile and had to wait for my Bateau account to be reauthorized.
sitandfish wrote:It does plane, doesn't it. Have any action shots of it running?
Yes, it planes very well. With the Honda 20, it can easily get 3 large adults and a big dog on step. 4 + dog is borderline if there are fatso's like me onboard. Top speed with one person (+ dog of course) is 23 mph with the current prop. More importantly, it can stay on plane down to around 9 mph, which is useful in lumpy water when you want to save your back. It also transitions transparently from displacement to planing, with almost zero change in trim. This is a utility tender, so top speed is less important than all-around good behavior. 23 mph does not feel fast in this boat - I think it would feel fine at 35 mph if it had the power to do that - though I'm not sure the hull design would accommodate that speed very efficiently. I don't have any action pics, but I know several were taken by others so I need to round them up. Wake is minimal, trim is good, and you can really see the collar deflecting spray.
sitandfish wrote:What had initially thrown me was that hump in the sponsons at mid ship. Thought I was looking at a displacement shape for a minute.
Yeah, understand what you're saying. It looks odd at first. The aft collar slopes up away from the chine, but is parallel to the water line. My intent was to keep the collar above the water line so most of the hull/water interaction is with the relatively narrow FS12 hull. My thinking was that would give me a smoother ride and better handling in rough water. If the collar was in contact with the water all of the time, I would effectively have a much wider boat with the associated rougher ride and poorer handling characteristics. Turns out my thinking was correct. The collar engages with the water in the following circumstances:
- When the stern dips while getting on step, especially with a load. The added planing area then assists with planing, but then lifts clear of the water.
- When running into big waves the collar forward provides add'l bow buoyancy and knocks down the spray. That's why it's sloped upward - this bow just will NOT be buried, which is always a worry with small boats.
- When leaning over the edge, to land a fish or just being careless. Two large men can stand side-by-side fully on the collar and there's no fear of capsize or flooding. Try that in a stock FS12 (but wear your PFD)!
jacquesmm wrote:Impressive, this must be the most heavily modified FS12. The bottom is still FS12 and she should perform well.
Thanks Jacques, I appreciate that. You may recall that I originally consulted with you last fall regarding adding the stern sponsons and you blessed the idea. The rest of the modifications...you can't be held culpable for! It is certainly a bit heavier, maybe by 50 lbs at most.
heloman30 wrote:Why did you cut the lower edge of the sponsons off?
I was concerned that the sponson corners would trip or maybe 'grab' waves that hit at an angle and cause the boat to rudder into them abruptly. In retrospect, I think I could have left the corners in place on the aft few feet of collar. Would have helped 'carve' corners in steep banks, though the large twin skegs provide great tracking as is. If I didn't have the big skegs this would be a bigger consideration. Also would have provided a bit more planing surface for getting on step, but planing hasn't been a problem. I do think I did the right thing trimming them off on the forward portion though. Up toward the bow I wanted to retain as much planing surface as possible - if the bow was buried that deeply, I figured lift would be more important than steering at that point, so that's why I didn't ease the corners there.
gstanfield wrote:Just wanted to add some pics in the thread :D
Thank you. I tried to do that but I'm too dumb to figure it out. No doubt the instructions are out there somewhere.
I would do a few things a bit differently:
- Because the aft sponsons provide more lift, I would make the aft bench seat smaller, moving the driver back a bit. This would give more interior room and make running the tiller more comfortable without an extension.
- Alternatively, if money were no object...I'd put a 30 hp on her with a console. Still sitting on the aft seat. That would then be a real 'fun machine', but still a practical tender. It would add more weight which would complicate loading and unloading from the big boat a bit, but manageable.
- I want a bigger work skiff of the same design now! I'm looking for the same type of hull, a fairly narrow planing hull. The Panga 20 is my current thinking. The 6' 1" beam would allow a 1' wide collar all the way around and still be trailerable. Also, the collar takes the place of the gunnels in providing structural rigidity of the side hull panels, so that allows more interior space and a cleaner interior look.
Posted: Mon Nov 15, 2010 9:12 am
by heloman30
Did you think at all about putting foam in the "collar," did you think it would add too much weight, what do you think about that now that you've run it? A panga modified like this would be very interesting, I hope you build it. Also, I remember when you were first discussing building this, and I'm surprised at the speed that you completed it. Very impressive!
Posted: Mon Nov 15, 2010 9:34 am
by gk108
I like it! Among other things, you have most of the advantages of an RIB type boat with none of the drawbacks. 8)
Posted: Mon Nov 15, 2010 4:24 pm
by deering
heloman30 wrote:Did you think at all about putting foam in the "collar," did you think it would add too much weight, what do you think about that now that you've run it? A panga modified like this would be very interesting, I hope you build it. Also, I remember when you were first discussing building this, and I'm surprised at the speed that you completed it. Very impressive!
I did briefly consider foam for the collar, but didn't see much point at the time. The collar is segmented into separate chambers, all filleted and taped, so it would be nearly impossible to compromise the integrity of all of the compartments at one time.
Now that I've run it for the summer, there's very little I would change. This little boat is a huge winner in my book. The collar was a complete success.
Started it in January and launched it in June. If I hadn't spent so much time monkeying with the collar design, I could have completed the stock FS12 in a month or less. One big motivator is having a wife who is demanding her side of the garage in the winter...
Posted: Mon Nov 15, 2010 4:31 pm
by deering
gk108 wrote:I like it! Among other things, you have most of the advantages of an RIB type boat with none of the drawbacks. 8)
A few drawbacks perhaps. It's a bit heavier than a RIB would be, and it doesn't flex to absorb shock loads (though that hasn't been a problem - the ride it terrific). It also doesn't function like a giant fender when tying off to bigger boats.
But aside from those, none of the other inflatable nonsense that I've dealt with in the past. I no longer carry a pump, and gaffing a halibut is no longer a life-threatening experience (at least in the boat-puncturing sense).
If I builder a bigger version with a Panga 20 base hull, I'll add water-tight hatches into the collar for storage. Can't do that with a RIB!
Posted: Thu Nov 18, 2010 9:02 pm
by eril n
oh wow! looks great mate.
hehe... I built an fS12 finished a year ago... it went great, but then i decided to also 'modify' mine with sponsons etc.
However, i was too scared to post anything after the finished FS12 build as I considered it may be blasphemy hehe:) .
But now seeing yours, I am inspired!
I might post progress on the end of my thread now, but here is a quick pic or two.
if anyone wants to see more I'll post on my own thread.
(I also raised the sides and did a center 'çhop' and stretch, so yes - very naughty hehe)
well done mate!Image
Posted: Thu Nov 18, 2010 9:46 pm
by sitandfish
eril n wrote:...However, i was too scared to post anything after the finished FS12 build as I considered it may be blasphemy...
That's unfortunate. I haven't seen the designer discourage people from making changes to accommodate their specific needs.
That being said, you shouldn't expect this site to support changes that may alter the design in ways that weaken the structure or alter the performance of the design. There are several boats that are being built currently that other builders and the designer are spending a lot of their time trying to help the builders add sponsons, flair the bows, etc...
But be ready for some direct (and sometimes harsh, if needed) comments concerning your changes.
Here is another modified boat that I think worked quit well. Others may have differing opinions? But, I doubt anyone will claim "blasphemy"? :wink:
Posted: Thu Nov 18, 2010 9:54 pm
by eril n
yes yes :) my comment was mainly tongue in cheek hehe.
thanks!!
Posted: Thu Nov 18, 2010 9:59 pm
by sitandfish
eril n wrote:yes yes :) my comment was mainly tongue in cheek hehe.
thanks!!
I think I got that from the "he he's". :wink:
Posted: Mon Nov 22, 2010 5:54 pm
by Uncle D
I can attest to that!! I made a mod that changed the design. Had to cut it out and then went back to the original design plans. Took a lot of time to change it but I took it as constructive criticism and a learning experience. I think that add-ons are pretty much okay but wholesale changes get quick and sometimes harsh responses. I didn't feel as if I was being down-trodden, but that if I kept the changes, I couldn't expect whole support from the board and at worst a structural failure. My .02
All in all, great support here. Don
Posted: Mon Nov 22, 2010 7:46 pm
by sitandfish
And I will be 100 percent blunt. Concerning your build (UncleD) I stopped contributing to your build thread for a while because, I felt your modifications would result in a dangerous boat. I hope you realize that the contributors are here to help people build safe boats based on very well thought out designs. And as you said, some of us (me included) need the direct approach when it cones to comments. Your boat is looking great! And more importantly, it is being built following sound and time tested building methods.
This is just MY opinion. There are countless changes that can be made to these designs. But, they have to result in a safe boat. :wink: Did I mention, you are building a great boat UncleD? :D
Posted: Tue Nov 23, 2010 9:40 am
by Uncle D
I appreciate your support, Jim and everyone's too. Sorry, Bob, don't mean to hijack your thread. You have a fantastic build. Happy Thanksgiving everyone.
Don
