Tom's FS14
Posted: Mon May 30, 2011 5:13 pm
I have made several posts relative to this FS14. Thought I should start a builders thread with some photos as I have progressed.
I started building this baby about 7 or 8 months ago but like most of us got sidetracked with other jobs around the homestead for most of the winter time. Well summer is upon us in Steinhatchee with a vengence so I am trying to work inside my air conditioned shop in the afternoons after sweating up a storm outside in the mornings.
Recently flipped the boat over and set her in her cradle I made with home sawn pine lumber. If anyone needs any special sawn lumber let me know as my small woodmizer will do the job.
The inside is all glassed with 6 oz biaial tape and 12 oz biaxial cloth in accordance with the build layup schedule. Settled on leaving the seat frames where the plans call for them after kicking around a lot of different variations. Full sole ruled out due to weight considerations. Partial sole from stringers outboard decided upon to keep from tripping on the stringers. Have built a little platform up under the front deck for a 6 gallon fuel tank and have run a pvc line as a fuel hose conduit.
I am buidling this boat for a 2003 9.9 Johnson 2 stroke which I picked up off craigslist in Tallahassee. It is a short shaft so I cut my transom down to 17 inches which is what motor measured. Wonder now if I did the right thing with reports of stern wave overtaking the boat when coming quickly off plane. Maybe I will build a self draining motor well with a hatch in it to access the drain plug. Maybe install an external drain plug like what is in my other two factory boats and then I don't have to mess with a small hatch.
Any ideas on where to put my tackle box and ice chest? Am planning to build simple live well in the center of the middle seat to hold live shrimp. Will fill it up with sea water from a small bucket and run small battery powered aerater with drain overflow pipe dumping into the bilge. Will need small battery if I install a small bilge pump at the back. Trying to keep it simple and light.
Here are some photos from my builder gallery.
Tom in Steinhatchee
Tom in Steinhatchee
