Panga 22 Build - The Saga Begins
Re: Panga 22 Build - The Saga Begins
nm
- peter-curacao
I would listen to Jacques and Ross, those two are very experienced in this build method
After about 24 hours and two pots of boiling water the straps haven't gotten any looser. Right now the tie-downs are VERY tight, the board makes cracking sounds and I'm afraid if I tighten it anymore the board is going to break. This is what the gaps still look like.
Station C -
Chine
Keel
Station B -
I think I might have to just take it off and kerf it. I'm going to wait a couple more days and see.
Station C -
Chine
Keel
Station B -
Kerf it, for sure.
I'm with Larry. I had the same kind of spaces with my LB22. I think Meranti just can't make the bend with some of these designs. Seems like I read Jacques saying he used Okoume specs for that in the software that does the panels. I did more than kerf, which required a bit of fairing. It worked fine, but I'd just kerf next time. Here's pics of my effort:
I wouldn't wrestle with it anymore. I bought that T-shirt.
Says you'll get it Dougster
Welcome. Your build is already looking good. As the others have said, Listen to Jacques and the other experts. They do know what they are saying you should do. John
I used Okume on my Nina Dougster but it took an extra pair of hands and a lot of cussin' to get it done without kerfingDougster wrote:I'm with Larry. I had the same kind of spaces with my LB22. I think Meranti just can't make the bend with some of these designs. Seems like I read Jacques saying he used Okoume specs for that in the software that does the panels. I did more than kerf, which required a bit of fairing. It worked fine, but I'd just kerf next time. Here's pics of my effort:
Daddy.
I built the panga about 4 years ago. Kerf it until it hurts. Inside only, as shown on the bottom sketch. To bring the keel down to the frames use pieces of angle and eye bolts to wrench it down.
Been a long time since I updated this but we're getting some work done!
Ready for glass -
Ready for glass -
Glassing
Users browsing this forum: Bing [Bot] and 17 guests
