Cedarock's gf14
Posted: Sat Mar 17, 2012 6:29 pm
I almost forgot how much fun it is to see a boat come together from a stack of plywood and some epoxy!
Here is the backbone of the little boat......I picked it up on Thursday and with Bateau's great service and quick shipment of the supplies, I was able to start on Friday evening. Running into snags is part of the fun to me, keeping me on my toes! Check out the gap under the transom end on the next pic!
I walked around, measured.....walked around some more......measured.......I know I used a chalk line, it is supposed to flat from the transom to about 6 inches in front of the middle seat! Why in the world is it teeter totting under the middle seat! Something triggered me to put the level on the floor.....wouldn't you know it, the floor is level to that point and then slopes to the garage door! The only other stupid thing of the day was when I ran a drywall screw through the side of full jug of epoxy that was holding the panels upright. I didn't even know it until I started to see a puddle of epoxy at my feet!
I do have something that I will have to address and my options are limited. The plans has the transom height at the clamping point at 19 7/8 inches. After installing the floor, I suppose, it would be 20 1/4 inches. I want to use a 15 inch motor and made the transom about 16 inches tall giving me 15 inches vertical to the plane of the boat bottom. I think that is how I did it with the fs12 and it runs with the anti-cavitation plate even with the bottom! It is not here, so, I can't measure it to see. Anyway, in the next pic you can see my dilemma!
The rear frame is 14 1/2 inches tall. I will have maybe 2 inches to clamp the outboard on, which will not be enough. I will either have to cut down the rear seat, which I really don't want to do or cut a rectangle out of the rear seat in front of the clamping location. I am not opposed to that and if I do, I will make it large enough to shove a portable tank in there and fill both corners of the compartment with flotation.......like I did with the fs12. Of course, I would double or triple the tape for the rest of the transom to rear seat joint if I have to go that route. Hopefully, I am wrong about the height of the transom and can add a little to it and make it work.....I like the full rear seat and originally planned for flotation in the middle leaving enough room on the side to slide a portable tank in there. I will be able to measure my motor this weekend and know for sure, but if anyone has any suggestions, please throw them at me!
The boat is looking great and seems large for a 14 foot boat. Can't wait to see it come together!
