CS 25 Stuart FL
Re: CS 25 Stuart FL
Thank you Walkers Run for the tip on raising the sole that's something I probably need to do because I'm thinking of putting twin 150's on it . Since you did raise your sole would you recommend me adding 2.5 to my frames or just use taller cleats under the sole . Thanks again.
Re: CS 25 Stuart FL
Thank you Jacquesm I guess I type faster than I think sometimes and should have said stringers and frames under the sole
Re: CS 25 Stuart FL
Can you tell me how you made your hatches? Going through the pictures, its hard to tell.
- Walkers Run
Re: CS 25 Stuart FL
Really nice looking CS25!!! Outriggers are a nice touch!!! Jeff
- Walkers Run
Re: CS 25 Stuart FL
Marshall, sorry I just saw this post.Marshall Moser wrote:Can you tell me how you made your hatches? Going through the pictures, its hard to tell.
I made a template for my hatches and cut them out with a router.
I used the cut out as the hatch. I used foam to build the thickness and add insulation
I routed out the edge and used a round neoprene gasket as a seal.
Re: CS 25 Stuart FL
So the gap is the width of your router bit?
Users browsing this forum: Google [Bot], joe2700 and 8 guests
