Page 1 of 28
CS 25 Stuart FL
Posted: Mon Apr 23, 2012 1:48 pm
by Walkers Run
Re: CS 25 Stuart FL
Posted: Mon Apr 23, 2012 2:26 pm
by wegcagle
Great start! By the looks of it, this ain't your first rodeo. Clean work. I hope you're not going to sand in there too. That place will be full of fiberglass dust
Will
Re: CS 25 Stuart FL
Posted: Mon Apr 23, 2012 3:01 pm
by tobolamr
Glad to see another Flooring guy on the board!
Re: CS 25 Stuart FL
Posted: Mon Apr 23, 2012 3:24 pm
by tech_support
looking good, thanks for sharing the pictures.
Re: CS 25 Stuart FL
Posted: Mon Apr 23, 2012 5:18 pm
by peter-curacao
Great progress
to the site and good luck
Re: CS 25 Stuart FL
Posted: Fri May 04, 2012 12:19 pm
by Walkers Run
I found some more pictures
over head the flair does'nt reall show up
transom lamination
Wide cloth on the bottom
wide cloth on the port side. I hope the get the starbord side and transom this weekend
Decided to go with cardbord for the counsol, lighter, cheaper. I did use the premium 3M tape though
Re: CS 25 Stuart FL
Posted: Fri May 04, 2012 12:21 pm
by Walkers Run
wegcagle wrote:Great start! By the looks of it, this ain't your first rodeo. Clean work. I hope you're not going to sand in there too. That place will be full of fiberglass dust
Will
I built a plastic room for sanding
Re: CS 25 Stuart FL
Posted: Fri May 04, 2012 12:33 pm
by Joe H
So what's it gonna be? Carpet or Congoleum for the sole?
Your counsol looks good to, I'm using the same material this weekend for my seat boxes.
Your build is looking GREAT!
Joe H
Re: CS 25 Stuart FL
Posted: Fri May 04, 2012 1:23 pm
by peter-curacao
that hull looks very fair, wish I had done a good job like that, keep up the good work
Re: CS 25 Stuart FL
Posted: Fri May 04, 2012 5:58 pm
by tobolamr
Keep up the great momentum! You are FLYING!
