Birmingham RB14
jacquesmm
Re: Birmingham RB14
Post by jacquesmm »
94Virago wrote:End-of-stringer to the first notch is 16 3/4. Does that mean I need to lop an inch and three quarters off of the end of my stringers or do I need to re-notch?
I did not see that one.
Yes, that's what you should do: cut the end of the stringers.
94Virago
Re: Birmingham RB14
Post by 94Virago »
Luckily I did measure subsequent notches from that first one. Will trimming the stringers not make them too short?
--Wolfe
"When in doubt, give it more throttle."
jacquesmm
Re: Birmingham RB14
Post by jacquesmm »
No, they will be exactly as on the plans.
All your frames are in the correct place, the hull shape is correct.
That was easier to fix than to add to it but I was ready to recommend to sister the stringers if they were too short.
I will add a big bold line to the building notes. I understand how the confusion happened.
94Virago
Re: Birmingham RB14
Post by 94Virago »
By the way, thanks for the rapid response.
--Wolfe
94Virago
Re: Birmingham RB14
Post by 94Virago »
I got a Google alert in my email for an outboard that fit my specifications: A 1959 35hp Johnson Super Sea Horse. And he only wanted $200! He had that and a similar motor as a parts donator. I plunked down the cash and took them both home.
--Wolfe
rjezuit
Re: Birmingham RB14
Post by rjezuit »
Hell, You'll be lucky if they only last another 50 years.
94Virago
Re: Birmingham RB14
Post by 94Virago »
rjezuit wrote:Hell, You'll be lucky if they only last another 50 years.
And if I'm unlucky, they'll last 150?
--Wolfe
94Virago
Re: Birmingham RB14
Post by 94Virago »
After another lengthy hiatus while I learned the proper spelling for "hiatus", my dad and I got to work un-screwing-up my stringer situation. My dad noticed something that I'd like to ask you pro builders.
Towards the bow of the boat, should I round over the edges of the stringers to match the shape of the hull? It looks like the hull is going to lean more towards the vertical as it goes forward, especially when it gets to the notches in Station B. I'm concerned about there being too much gap to fill with putty.
--Wolfe
jacquesmm
Re: Birmingham RB14
Post by jacquesmm »
You can do that or use putty with little wedges. Up to a 1/2" gap there is normal. For more than 1" I would fill with wood wedges and putty.
94Virago
Re: Birmingham RB14
Post by 94Virago »
My dad and I got down and dirty yesterday. We grinded/sanded down the stringers so they would conform to the hull shape better.
Then we built some quick jigs from 2x4's to hold each station in place and draped the whole thing in tarpaulin.
After that, we had just enough daylight left to do a quick fit of the bottom hull panels.
The plan is to drape the hull panels in steamed towels to get them to better form around the stations and bow guide. Does anyone have a better idea?
--Wolfe
