Hello just a few new photos, getting excited about finishing!
FS14 OZ
- BarraMan
Re: FS14 OZ
Looks pretty schmick!
Congratulations on your fine work.
Re: FS14 OZ
Looks good!
So I guess it's better to prime and paint the outside before flipping it? I've been wondering if that was the case. I guess that really cuts down on how many times you flip it. I'm still a long way from that point.
Re: FS14 OZ
Cheers, the paint is by no means a show room finish, but i could spend a lot more time and money trying to get it perfect. I decided that it was better to progress with the build and test the paint in the real world to see how it holds up with use, sun and salt.
I choose to paint the outside first because it is the first boat i have built and i wanted to give the whole process of fairing and painting a go, the paint is a lot tougher than the fairing compound. Also now that it is the right way up it can stay the right way up.
I spent today sanding and profiling the old epoxy tack fillets and cut the fibreglass cloth to length. Im going to epoxy coat the inside then immediately make the fillets and the glass over the fillets, this will be very shortly followed by the glass sheath. Hopefully all the layers will chemically bond and make a nice strong unit.
Re: FS14 OZ
i have put a dead line of floating by easter in time for my parents coming to visit, so i have been really powerin into the build now.
i have all the stringers in and fibreglassing done.
you can see here the bow deck, the foam esky that will be built in (but removable for cleaning x2) and all the battens to support the seating and the decks.
yo can clearly see the chase tubes for steering, electronics and fuel that will we covered up by a decking. this photo is inbetween the front and back seats, im installing decking on the two outside sections but leaving the middle piece open. may change in the future but for now that is the plan.
i have started putting in floatation foam around the gunwale and have cut out som plywood to cap it off, will post some photos of it shortly. im not using any pour in place foam but will be using lots of sheet, im also trying to get as much foam as high up as possible to achieve level flotation.
i have cut out hatches in the bow x1, and in the rear seat x3 using the router. i cut a template square taking into account the offset from the edge of the router to the centre of the bit so i could just run the router around the edge, making sure to set the depth of cut just short of all the way through so that the template doesnt move. using a 2mm bit im going to use the cut out middle piece as the hatch and im pretty happy with the results, saving a bit of wasted ply.
my motor arrived today just have to pick it up from the shop, 18hp tohastu twostroke, electric start, forward controls. also my order of all the gear for fit out should arrive anyday now. will aim to get the bare necesities in place to register the boat and then take more time to get the finish done the best i can.
a question for the pros, fibreglass isnt on the plans for the seats, im going to put a layer on the decks and near the anchor for durability, it is a good idea to cover the seats too?
also for the peopl following my build, i havent given up on the steer by wire, but postponed it and will get the boat going with conventional single cable steering and engine controls, then at a less stressful time work on a reliable and robust electronic control system.
Re: FS14 OZ
You certainly are man, nice work!!boat_AUS wrote:so i have been really powerin into the build now
Where abouts are you in WA? I spent the first 26 years of my life in the hills of Perth, I'm in Darwin now.
Keep it up, going great guns.
- glossieblack
Re: FS14 OZ
Very nice work.boat_AUS wrote: i have cut out hatches in the bow x1, and in the rear seat x3 using the router. i cut a template square taking into account the offset from the edge of the router to the centre of the bit so i could just run the router around the edge, making sure to set the depth of cut just short of all the way through so that the template doesnt move. using a 2mm bit im going to use the cut out middle piece as the hatch and im pretty happy with the results, saving a bit of wasted ply.
- glossieblack
Re: FS14 OZ
- BarraMan
Re: FS14 OZ
So am I!im pretty happy with the results,
I gotta give that a try.
Re: FS14 OZ
I have started the fit out. Pick up a stupid amount of stuff to fit in, wish I had a bigger shed.
Motor is in place temporarily to get controls cables and steering in place and routed you can also see the helm/cockpit area being fitted up. Need to get the engine controls mounted, but need to have the gunwales on to make sure of clearance.
On a different note, the trailer I built for the boat passed inspection and is now registered
