I extended 6 flex tubes, with pull strings and wire into the upper console. Neatened it up good. Then sprayed the lower console area with a Prevail sprayer and EMC paint. It worked like a charm, did a real nice job. You could paint the whole boat with a few of these. One more coat under there tomorrow will finish that up..then I have to Kiwi Grip the bottom of it. Need to get that done tomorrow also before the weather turns cold again.
Pulled a few more wires through the chase tubes..
Me either. I've got to show you this trim plate for the steering pod. It will mount flush under the wheel on Peter's cigar box The center hole is for the steering wheel shaft. Rogerdog bought a 1/4 X 7" stainless disk, sent it to Raymond for a mirror finish polish, then sent it to an engraver for laser engraving Then he drilled the center hole and I cleaned up the burrs with a Dremel tool. It's like looking into a mirror, you can see the bottom of my roof really well Hard to take a picture of it,I can't wait to see that Helm station finished on that box
Building on
