Page 1 of 291
A Cracker Built GF18- Finished 6/28/15
Posted: Sat Apr 20, 2013 9:08 pm
It's time to start another one :D
We're going to build a tricked out GF18 for a client in Augusta, GA. This one will have all the bells and whistles, plus a few modifications. 22 sheets of plywood are on the way, along with (according to UPS) 207 pounds of epoxy and fiberglass 8O Still not quite finished with the Grady White, but real close and I was waiting on epoxy to cure again, so we got started today. Built the construction platform/jig, cleaned the shop and made room for incoming materials.
I've got my apprentice broke in and ready to work, he is a go getter .....
Built the frame from 2 X 6s, 18" high. 4' wide and 16' long. I struggled with the FS18 jig being too high through the entire build and had to stand on blocks to work on it. This one is lower. Should help my back a little I hope.
Got everything level and square then covered it with plywood sheathing.
BBV is a BAD disease :help:
Re: A Cracker Built GF18
Posted: Sat Apr 20, 2013 9:10 pm
by peter-curacao
You are a boat building machine 8)
Posted: Mon Apr 22, 2013 8:55 pm
The big brown truck came today and brought us almost half of a boat. Some assembly required :D
Posted: Mon Apr 22, 2013 9:05 pm
by Hope2float
Larry I hope there is some rum in that drink or maybe alot of rum! I be watching and learning as you build. BUILD ON !
Dave
Posted: Mon Apr 22, 2013 9:33 pm
by reiko1078
first page! and i get to watch a build from the beginning
Posted: Mon Apr 22, 2013 9:38 pm
Bourbon. The brown truck came after 5 :D
Posted: Tue Apr 23, 2013 7:51 am
by cottontop
CL, I think we're all lost when you aren't building. I love your builds and the tech info/tips I pick up reading your threads(as well as the laughter). Quick question if you don't mind? How would you go about painting graphite on the bottom of my OD18? It's painted now. Keep up the good work. john
Posted: Tue Apr 23, 2013 10:29 am
by MarkOrge
CL - you are a machine ! Can't wait to see this one come together....
Posted: Tue Apr 23, 2013 11:38 am
I appreciate the comments. Y'all need to remember that this is my full time job, not just something I do in my spare time :D
Ah man, that's going to be tough. You've got to get most of the paint off and sanding it upside down would be miserable. I think I would use a good paint stripper and a pressure washer. If it's S3 paint it might blow right off. Mine does :lol: Do you have a way to hang the boat and get it clear of the trailer?
Speaking of job, it's time to crawl back in that GW and start hooking up some wires and cables. I'll be real glad when that one is finished :?
Posted: Tue Apr 23, 2013 12:02 pm
by cottontop
It's S3, but is holding up real well. I can hang it. I'm not going to start that until next year though. Thanks, John :D
