Wouter's PH18 Namibia
Re: Wouter's PH18 Namibia
Beautiful work!!!!! Jeff
Got the carpeting done over the weekend, what a job!! Super happy with the results though!
Beautiful work Wouter!!!! Jeff
It certainly creates the counterpoint to those of us who think "workboat works on my boat".
Gorgeous finish.
Gorgeous finish.
Did the cockpit floor with an anti-slip over the weekend. Used a local truck-bed liner product that worked easily and I'm very happy with the results. Still need to fit the hardware on the hatch lid for the floor live well and cockpit drainage fitting.
I need some advice: what are you all using on the inside of the motor well to secure the motor bolts in terms of washers etc. Are large washers sufficient..? Size, thickness, material..? or should I use a type of plate that covers a larger area..? I would appreciate some input.
Regards
Regards
This question was just addressed on another thread for a PH16, the advice from Aripeka Angler was: "When you get to the rigging stage, I would recommend using the metal bolt backing plates on the forward side of your transom.Wouter wrote: ↑Mon Apr 29, 2019 5:25 am
Regards
This will prevent the motor bolts from sinking into the wood on the transom."
X2 use plates and spread that force out over a larger area.
Users browsing this forum: Google [Bot] and 20 guests
