Wouter's PH18 Namibia
Posted: Mon Apr 21, 2014 12:59 pm
by Wouter
Hi fellow boat builders.
It's the end of Easter weekend and I've startedwith my PH18 build. So far so good, jig finished last weekend and now all bulkheads and stringers are finished.
However I still need to get all epoxy and fibreglass products so going to need to wait till I recieve those before I can butt join the stringer.
I'm doing the transom from two laminated 12mm ply pieces so also need to wait before I can continue with those.
The boat was inspired by BassMunn's boat and I hope to get somewhere near his immaculate build. Also planning a bass boat layup to be used for fresh water river fishing, mostly on the Zambezi and Kavango rivers.
As I'm in Namibia, products and materials are hard to come by so most will have to be imported or sourced in one way or another and hoping This forum would help ally some alternative solutions if I get stuck.
Will post some pics shortly.
Regards
Wouter
Re: Wouter's PH18 Namibia
Posted: Tue Apr 22, 2014 4:05 am
by Wouter
Posted: Tue Apr 22, 2014 7:53 am
by peter-curacao
Wouter wrote:
Welcome, good luck and have fun!
If you didn't already, don't forget to put some diagonal cross members in your strong back
Posted: Tue Apr 22, 2014 8:01 am
by Wouter
Hi Peter-curacao, Thank you.
The 'jig' has got cross members and angle iron to keep it straight, with caster's so i can push it around. It does twist a little as my floor is not perfectly straight. But I have jigs inside to sort out the twisting issue.
This pic should be better.
Posted: Tue Apr 22, 2014 8:08 am
by peter-curacao
I see but I was talking diagonal supports, probably some ply triangles on/in the corners is enough, this should take out the twist completely, keep in mind the heavier it gets the more it wiggle, especially when pushing it around, you want to keep that strong back as straight as possible
The rest is looking good you are on to a great start
Posted: Tue Apr 22, 2014 9:38 am
by Wouter
Point taken, diagonal supports makes sense, I'll add some and do something on the corners too.
Thanks!
Posted: Mon May 05, 2014 10:46 am
by antoniekruger
Hi Wouter,
Where in Namibia are you?
Good luck with the build.
Antonie
Posted: Tue May 06, 2014 5:31 pm
by Wouter
Hi Antonie
I'm in Oshakati.
Thanx, looking forward to receiving the fibreglass products soon so I can continue
Posted: Wed May 07, 2014 2:34 pm
by antoniekruger
Hi Wouter, that's far north. I wanted to make a turn, but I go as far as Swakop. We're running a site at Husab. The last time I was in Oshakati was with national service back in 1987. Where are you buying resin from - Windhoek?
Posted: Wed May 07, 2014 3:41 pm
by Wouter
Hi Antonie,
Yes, Oshakati is a bit in the middle of nowhere and materials are a bit of a problem. I imported the marine ply from CT, took three weeks to get here, so I'm foreseeing delays in obtaining materials.
So far I've been dealing with AMT Composites in regards to resins and fiberglass products, haven't placed any orders yet but it seems as if they are able to export and deliver to me which is a great help. I also know Brian from my earlier sailing days so trust the advice and input he has already given me tremendously.
I've sneak peak at your build and it seems like it is coming along nicely! As you are a long way ahead of me I'm sure I'll be able to get some advice from you too!
I've just returned from a weeks fishing in Rundu at the annual Crockango Bonanza with a borrowed boat, which left me on the side for most of the event, so it reinforced the motivation to get to it with my own boat
If you are ever up north in Nam, let me now, you are more then welcome to visit!
Regards.
Posted: Wed May 07, 2014 4:43 pm
by tobolamr
BassMunn built in South Africa. His build thread is here:
http://forums.bateau2.com/viewtopic.php?f=12&t=17806
Maybe some of the suppliers could also help you out? I noticed you mentioned you are still checking out glass/resin suppliers.
I hope this helps!
Posted: Thu May 08, 2014 12:53 pm
by antoniekruger
Hi Wouter, CT, goodness that's far to order. The chaps from AMT are starts. I buy my resins and cloth from them as well. I build experimental drones as another part time and these guys are extremely knowledgeable. I've had multiple conversations with Brian and he was helpful, indeed.
I use SP106 for the bulk of the build so far and stumbled onto a special in their shop today and took another 20kg.
Build on bud, I hope to be able to visit you when we get a job in Angola with the new oil expansions.
When you're ever down this side, youre welcome to visit and swop out. I'm 10 minutes from the airport.
Antonie
Posted: Tue May 13, 2014 3:13 pm
by Wouter
Hi Antonie,
Yes, it's a bit of a mission to get stuff here. But I'll persevere.
I do have a question for you on the fairing compound you used, was it AMT's Fair 600..? I'm about to place my order and have no idea of how much I'll need. Would you be able to help with any sort of estimate..?
Regards
Posted: Wed May 14, 2014 1:40 am
by antoniekruger
Hi,
Yip, I use the S-FAIR 600. I bought 5l part A and 5l part B. My pots are around 75% used on the outside of the boat. I'll have to get another 2l of each to finish fairing the inside bits. I would think the (5l A+5l B) pots would be enough for the PH18. A great help is using peel ply. It is a fabric that is similar to the olden days pants pocket material - a nylon/silky cloth. There are many benefits in using this. If your not working wet on wet, this will help ensure a good secondary bond since you peel the blush off with the peel ply. If you use it on a final layer it reduces the need for fairing a lot and preps the surface for fairing/paint ect. Some of the guys use sheets of plastic as peel ply on final surfaces - they call it poor man's peel ply - It does not get rid of the blush, though.
You can reduce the need for fairing quite a bit by using some form of peel ply. If your hull is fair before your layup(Jacques mentions this in his building notes - get it as smooth and true to shape as possible) and your layup is neat and you use some sort of peel ply, your need for fairing will be hugely reduced.
Something else to watch for is blush - it is the waxy residue that forms on the epoxy when it is curing. This is one of the components of the hardener. You need to get this off before you put another layer down. You wipe it with acetone and sand the surface as a key prep.
Have a look at how the other guys fair. Some use resin with micro balloons - its a red compound that is painted on. I like this since it seem to give a better secondary bond.
I hope this helps,
Antonie
Posted: Wed May 14, 2014 3:50 am
by antoniekruger
Hi Wouter, my apologies if I'm covering ground that have already been discussed. I was just doing a small layup and thought that I should share with you the little guys that makes a huge difference - seeing youre about to order, keep these in mind. AMT stocks these.
1. They sell a little nylon roller with a wire handle - it has thread on it like a screw. This is not to apply the epoxy. Once your placed the cloth and wet it out you roll it with this little guy. It squeezes the epoxy trapped under the cloth out and helps to secure a good contact between the cloth and wood/bottom layer. They are a must and dirt cheap. You get very fancy ones, but I find that these ones work great and clean well.
2. AMT has a selection of squeegees. They sell a little orange one that is the size of a bank card. Also dirt cheap. You use this to spread epoxy and to collect excess after rolling. I seldom use a brush to apply epoxy. Between my squeegee and roller all is good.
3. You'll see many of the guys have dispensing pumps on their epoxy bottles. Two squeezes resin and one squeeze hardener....or something like that. I could not find and since every epoxy has its own mix ratio, I use a scale. Get a decent electronic scale. AMT sells a good scale for around ZAR900. If you screw up you mix ratio's it will lead to the epoxy not curing as expected and can you trust that portion to be structurally sound? Put it in a plastic bag before starting to use.
4. The stuff you'll mix with the epoxy is called cotton flocks. That is our version of the wood flour the other guys use to make the glue and fillers. It is a white flocky substance(powder) and works very well for fillets, glues and fillers. I'm on my second 1kg bag.
5. Neoprene gloves. AMT sells boxes of these(like a tissue box). I think 50 sets per box. Also well prices. This is essential.
6. The last one I can think of now is the cleaner. Many guys use acetone, witch is great for cleaning off splats and blush, BUT Evan from AMT introduced me to a water soluble cleaner after buying acetone from him for a year. I is a blue liquid that I use to clean all my equipment. IT IS BRILLIANT. I surpasses acetone by far for this purpose. The code is G220.
Hope this helps.
Antonie
Posted: Wed May 14, 2014 4:31 am
by Wouter
Hi Antonie,
Thanx a million for all the tips! That's why these forums are so great!
Think I'll spend the next few days getting a decent list of materials together before I place the order.
On the cotton Flock, what is the mix ratio to resin for the fillets? I'm also getting fumed silica, and as I understand the cotton Flocks and silica go 2:1 but i'm not sure to what factor of resin? Suppose it will be determined by the consistency or thickness of the fillet required. How much cotton flock/silica would you recommend I order? Was thinking around the 3and1 1/5 kg range. Not sure if it's too much..? With transport and import cost I'd like to rather get two much then to little. Not keen on importing small amounts later.
I'm definately planning on using peel ply as well, seems like it is well worth the extra expenditure.
All your help is much appreciated!
Posted: Wed May 14, 2014 6:28 am
by antoniekruger
Hi Wouter,
I've never used the fumed silica, to be honest. I would estimate that 3kg of cotton flocks would be ample. I'll have to check it out.
Have a look at the technical help tab on the Bateau website. There are a whole lot of tutorials and videos on what need to be done and how to do it. The glue mix(for your transom for example) is different than the fillet mix as peanut butter from tomato sauce.....I had a whole lecture from some of old hands on the consistency of the various glue mixes. I'm sure some of them will add some wisdom here as well.
At the end of the day the fillet needs to fill the corner and give enough shape to the outside to lay your tape on without leaving voids. You will be amazed how strong the fillets become.
The glue mix is exactly that - the epoxy is too runny on its own, and it should be thickened up enough to be applied as a glue. The same consistency as 'cold wood glue'.
I would suggest you glue some scraps and get a feel for the stuff before you glue the transom and clamping board.
With your temperatures up there, be wary of large batches - once the mix heats up it will exotherm. This is when the chemical reaction speeds up, releases heat generated and solidifies the pot of epoxy. SP106 have been good to me, but I've had fillet mix going smokey after trying to do a long fillet.
Check out the tutorials - there are good info there. -
http://bateau2.com/
Cheers, Antonie
Posted: Tue May 20, 2014 4:44 pm
by Wouter
Hi Guys,
I'm having difficulties in getting any form of adequate wood for the transom clamp. So I've come up with an idea to do the transom from 12mm laminated marine ply.
I thought of doing two layers across the whole transom, giving me a thickness of 24mm all the way across. And making slits for the outer stringers to fit into the inside board/panel. Then fitting an extra 12mm piece in between the inner stringers giving me a thickness of 36mm in the OB compartment, with the inside stringers fitting alongside the 3rd piece of 12mm ply.
Any comments, feedback on the design aspect..?
Then, when laminating the boards together, are there any advantages/disadvantages of adding fiberglass in between the layers?
I hope this drawing makes it a bit clearer.
[img]
http://gallery.bateau2.com/albums/userp ... nation.JPG [/img]
Regards,
Posted: Tue May 20, 2014 7:16 pm
None, no need for that. Just glue them up.
Posted: Wed May 21, 2014 9:05 am
Plywood is a fine substitute.
Posted: Wed May 21, 2014 3:43 pm
by Wouter
Thanks Jacques,
Got a long weekend coming up, looking forward to gettingsome work done!
Posted: Thu May 22, 2014 9:15 am
by antoniekruger
Yip, same here - pay weekend for the construction industry - Friday and Monday off.
Posted: Fri May 23, 2014 5:31 am
by antoniekruger
Hi Wouter,
A quick heads up. I've just visited AMT's shop in Jo'burg. They are discontinuing SP106. Apparently the supplier is putting up the price by 10Euro's/kilo. I took the last 20kg in 5kg containers they had. I would suggest to look at an alternative like the Ampreg 21. I used this before on some drone wings with vacuum bagging - not on the biax fabric. Evan gave me another kilo as a demo to try and give feedback. I'll be taping stringers this weekend somewhere - I'll give him feedback then. The biggest difference that comes to mind now is that SP106's viscosity is lower and the wetting out happens faster. SP106 needs less cleaning after curing for secondary bond than 21. I'll dig up the data sheets and compare from a structural side as well.
Maybe have a chat with Brian the Lion with help for an alternative. I will dearly miss SP106 - from production and financial perspective.
Oh
the gloves are not neoprene. They are called NeoGloves.
Posted: Tue May 27, 2014 7:10 am
by Wouter
Hi all,
Been a productive long weekend and I got a lot done! Transom panels are cut out and ready for lamination, also did the bottom and side panels. So pretty much all the wood work is now done for now and everything is ready to be put together.
Thanx Antonie for the heads up on the SP106 resin, I've contacted AMT to find out what alternative they would suggest. But have done some digging and found Harvey's Composites, they carry the WEST Systems products, I'm awaiting the price list (thinking it would probably be pretty expensive). Also found Ivory again, they now fall under Flowcrete and also carry various epoxy products. I've used their products before and was satisfied with the qaulity etc, they are also fairly competitively priced, similar to AMT's. But, they are not sure if they can export to me yet, so need to sort that out with them.
Either way, i need to sort this out and get some products here, I'm itching to start putting things together!
Here's a quick pic of the Transom mock up.
Posted: Sun Jun 22, 2014 5:35 pm
by Wouter
Hi All,
Update time! Got a big parcel delivered on my B-day! A big batch of epoxy and Fiberglass!! Nice pressie, even if it was self bought
As I hadn't worked with the particular epoxy before I spent a few days testing it out to get a feel for the sticky stuff again. I made a test block for the fillets (I know I'm getting ahead of myself but couldn't resist) at first I struggled a bit to get it right but tweeking the mix got me on track and it came out pretty nice, also now have a nice self made tool for doing the fillets, should be much easier now.
Spent some time on the transom, got it laminated, drilled the holes for the through hull fittings and filled them with epoxy. Thought it would be easier to do lying flat on the work bench, came out nice!
Had to get a little creative when laminating the transom cause I ran out of clamps, came up with this idea. Did the job! I'm almost certian i'll use them again at some point during this build
Stringers also got butt joined and a final sanding, they now fit nicely in the bulkheads and I have hot glued them in place. Now there's a nice solid and true base for the bottom and side panels to go on
One bottom Panel is butt joined and looks good, now got to finish the other one and the sides in the week and hopefully I can get started at fitting the bottom and side panels next weekend!
Building on!
Posted: Sun Jun 22, 2014 7:18 pm
by Walkers Run
Your off to a great start. I love the PH 18
Posted: Mon Jun 23, 2014 10:47 am
by antoniekruger
Jaaaaa, chom - dis nou mos pap en vleis
Looks brilliant, bud. Off to a great start. So did you go with AMT?
Posted: Mon Jun 23, 2014 11:02 am
by Wouter
Thanx Walkers Run!
Hi Antonie, dankie! Jips, went with AMT. Using their Ampreg 21 as epoxy, works very well! I got the slow hardener and with the cold of the last few weeks it's taking a while to kick and cure, but it gives a long working period that I like. Think it will be nice when doing the big fiberglass pieces! I will order some fast hardener for some other applications.
Also been using the cotton flock and sillica, I just love the silica! Makes it very easy to get the batch to the consistency I want for a application. Very happy with the Ampreg.
Posted: Sat Jun 28, 2014 7:32 am
by Wouter
Dry fitted the bottom panels this morning, fits pretty good!
Posted: Thu Jul 03, 2014 9:30 pm
by flyfishingmonk
I am looking forward to watching your build.
Casey
Posted: Fri Jul 04, 2014 7:18 am
by Wouter
Thanx Casey!
Looking forward to sharing, and getting feedback and inserts from all you experts!
It's almost weekend time, next on the list is squaring up the transom and then getting on the stitches.
Posted: Sun Jul 06, 2014 4:23 pm
by Wouter
Posted: Mon Jul 07, 2014 12:53 am
by flyfishingmonk
Nice work!
Posted: Wed Jul 30, 2014 6:02 am
by Wouter
Thanx Casey,
Been slow going lately, got a bit caught up at work and traveled a bit so not a lot of hours at home to spend on the boat. Did do a few little things when possible.
I wasn't happy with the transom, was about 1/2 mm off center, so took it out fixed it and re glued it, now I'm 100% happy
The time spend will be worth it on my consciouns.
The side panels were intentionally cut 2cm longer, I'll trim them square with the transom next.
Cables ties have been cut and the 1st round of sanding is done.
Bow came out nice and symmetrical! I have filled the gaps and the holes, and it's ready for the second round of sanding. Hopefully get that done over the next few evenings. Then on to the fg taping, possible this weekend. (work dependent
Posted: Wed Jul 30, 2014 11:04 am
by Uncle D
You are doing a fine job, sir! This part of the build was my favorite.
Posted: Wed Jul 30, 2014 11:29 am
by antoniekruger
Wouter, looking good.
Posted: Wed Jul 30, 2014 9:17 pm
by jorgepease
very clean, like it!
Posted: Wed Aug 06, 2014 6:45 am
by Wouter
Posted: Wed Aug 06, 2014 7:09 am
by BarraMan
2nd from the top gets my vote!
Posted: Wed Aug 06, 2014 7:40 am
by antoniekruger
I like the top one. Nice designs
Posted: Wed Aug 06, 2014 7:42 am
by wegcagle
I like the last one
To each their own.
Will
Posted: Sun Aug 10, 2014 4:18 pm
by Wouter
Seems like the paint scheme designs are on the money if everyone likes different ones
Still have lots of time to ponder on it
Put some good hours in this weekend and made some progress.
Glassed the transom in with biaxial, two layers. And finished the keel and chines today! Looking good I think. Used peel ply all around as I had to cut the 'tape' from a standard roll of biaxial and had issues getting the edges nice, peel ply sorted that out.
Close up of the fg on the starboard transom side.
Peel ply still on.
Now time for a well deserved BEER!
Posted: Mon Aug 11, 2014 5:08 am
by antoniekruger
Hi Wouter, looks neat.
Big glass next?
Antonie
Posted: Mon Aug 11, 2014 5:16 am
by Wouter
Thanx,
Jips, big pieces next. But on a work trip for the next two weeks and then off to the Zambezi for ten days fishing! So will have to wait till next month
Might be home this Saturday and Sunday, if I am, I'll see if I'm up to the challenge.
Posted: Fri Sep 05, 2014 4:08 pm
by Wouter
Back from my fishing trip on the Zambezi, was a tough week for fishing with a cold front hitting us the day of arrival.
Been at the boat building again. The biaxial taped corners came out nice, but I had a few dips in it. The areas were the cloth wasn't perfectly aligned gave some shallow spots. Btw, I did not have biaxial tape and had to cut the pieces from a full roll. The shallow spots worried me a little so I filled it with a epoxy filler and sanded it smooth, much happier now to put a new layer of FG over it. They grey in the taped areas is the epoxy filler. I figured it would be better to fill it then have air bubbles on the next layer. (will still try and upload detailed pics of this)
I put down a layer of neat epoxy tonight, going to tackle the big pieces in the morning! Gonna be a marathon of a day on my own!
Dry fitting the cloth
Posted: Fri Sep 05, 2014 4:10 pm
by Wouter
Posted: Sat Sep 06, 2014 2:41 am
by antoniekruger
Hi Wouter, welcome back. Looks good.
Posted: Sat Sep 06, 2014 6:08 am
by cottontop
Sorry I haven't noticed your thread before. Love the fine work you have completed so far. Looks real good. Taking your time will help you enjoy the process and final results much more. I like the 2nd paint scheme. John
Posted: Sat Sep 06, 2014 10:46 am
by Noles309
Very clean work there. I'm seriously jealous of your shop though.
Posted: Mon Sep 08, 2014 3:30 am
by Wouter
Thanx guys!
What a weekend! Got the 1st layer of biaxial on! Looking good I think!
Taken a tip from CL and had all the Resin and Hardener pre-measured, ready to mix.
Beeing on my own I layed down the cloth 1st. However it wasn't easy as I primed the hull with a layer of epoxy the previous evening and it was still tacky (using super slow hardener) so stuck to the cloth easily and took me a while to get it all layed up. I only realised later that I made a mistake with my overlap of the second piece, it should have had another few cm of overlap. Struggling to get it layed up, I used a touch to much cloth at the transom and came up a little short on the bow. Don't think it will be a problem.
It was only at this point when I realized my overlap wasn't correct!
Slowly made my way forward.
About 8hrs later I was done!
I do have a question for all the experts! I want to put down another layer of FG over the top. however, the current layer does have some imperfections between the weaves. See pic hereunder. Can I glass straight over onto the current layer or would it be better to first fill these imperfections with an epoxy filler, sand it down and then lay down the next layer..? (as I did on the keel and chine) My concern is that if I do it straight over the current layer I might have some air bubbles that I won't be able to get out...?
Have a great week everyone!!
Posted: Mon Sep 08, 2014 3:35 am
by Wouter
Posted: Mon Sep 08, 2014 12:41 pm
by jorgepease
Really nice glass work!
Posted: Mon Sep 08, 2014 2:17 pm
by antoniekruger
Mooi werk, boet - very nice indeed.
Posted: Mon Oct 06, 2014 5:33 pm
by Wouter
Thanks for the compliments guys!!!
Made some progress over the last few weeks. Did the 2nd and last layer of FG, used 410gram woven for this. Came out really nice!! Although I had no helper this time around, so did it on my own and knocked it out in around 6hrs or so in 38deg!! The heat made the Epoxy flow like water so was a pleasure to work with! Here's a few snaps from my phone, excuse the qaulity.
Preparing and cutting the cloth:
Almost there:
Done:
The transom and first 60cm of the bow has been faired but no pics yet. Reverse chines and strakes next before I start fairing the rest of the boat. Going to use Meranti for these, if I can get them cut good enough with the tools I have otherwise I'll come up with an alternative method.
Meanwhile my dad is building a small scale model of the boat to keep him busy
Not sure that it will end up looking exactly like that, but think it's pretty cool
Posted: Fri Oct 17, 2014 9:19 am
by Wouter
Getting on with the reverse chine and strakes.
Lots of filling and sanding to do before the two layers of FG goes on.
Posted: Mon Oct 20, 2014 8:29 am
by jorgepease
great model!! Boat is looking great too!
Posted: Fri Nov 07, 2014 6:18 am
by Wouter
Thanx Jorge,
Been making steady progress over the last few weeks. Still have a lot of filling and sanding rounds to go, but I feel like its getting closer to that 1st primer coat. Getting a bit difficult to eyeball things with so many layers and different colours. I'm sure a primer coat will help show me better where work still needs to be done.
Here's a few pics.
Made a jig to ensure the strakes are // to each other.
Strakes glassed on.
Boat getting it's first taste of water: getting washed.
Chines are 95% smooth to the sides, needs a little more tlc.
Strakes inside edge getting filled as well as the transom edge made square with epoxy mix.
Getting there,slowly but surely.
Taking a break and going down to Cape Town: Primarily for the Volvo boats and the in-port race next Saturday!
Looking forward to seeing those machines in action!
Posted: Fri Jan 02, 2015 6:08 pm
by MarkOrge
Nice sharp edges. Great to see another PH18 out there
Posted: Thu Jan 08, 2015 3:28 am
by Wouter
Hi All.
Not much to report on the boat building side of things, been on a well deserved holiday.
I did get my seats made and they are enroute to me!
Also received the bow and Stern eyes, they will be fitted next so that I can flip the boat and start inside, should happen in the next few weeks.
Here's a few pics from my holiday, awesome destination: Camp Kwando, Caprivi Namibia
Nice size Three Spot
Thunderstorm in the back ground
Amazing sunset
Another Three Spot
A good size Redbreast
All the best for the builders for 2015!!
Posted: Thu Jan 08, 2015 8:48 am
Great pictures! Beautiful place
Nice fish too.
Posted: Thu Jan 08, 2015 11:18 am
by antoniekruger
Wooouuuter, dit is moerse kurpers - well done!! Nice fish, uuuugly angler
How was your trip to CT.
The boat looks good as well
.Where do you get time to build with all these breaks??
Build on.
Cheers
Posted: Thu Jan 08, 2015 11:31 am
by Wouter
Thanx CL!
Haha Antonie, CT was awesome! Those Volvo boats are some serious machines! Got a chance to go out on the water for the in-port race! What an experience!
Boat building gets done in between all the trips
explains the slow progress. But no trips planned for the next three months so should get some good work done, at least that's the plan.
I noticed between bulkheads c and d I have a slight sag. So going to flip first and do the stringers and bulkheads first, then flip it back and finish the bottom. I'm hoping this will sort the problem out.
Posted: Thu Jan 08, 2015 11:41 am
by antoniekruger
Hi,
I was wondering, is the Caprivi strip part of the delta from Botswana side. I've been wanting to head out there for some time, but the lodges out on the delta would not allow kids under 13 fro the fear of predator pick offs - leopards and lion. A colleague had a pride of lion walk through his camp site (between his camp and ablution) with very few other campers noticing. I want to head to the delta soon....how soon, I don't know, but as soon as the $$$ and oil allows.
Antonie
Posted: Thu Jan 08, 2015 11:55 am
by Wouter
Antonie,
Not so much part of the Botswana Delta. That's where the Okavango river leaves Namibia and enters Botswana to form the delta. It is also where the caprivi strip starts,at Divundu. From there the strip is that small finger like area stretching all the way to Katima Mulilo. On the southern side it does border with Botswana.
I stayed and fished on the Kwando river, which runs from Angola through Namibia and then on to Botswana to join the Chobe river eventually. As for the lodges, I know the Botswana delta lodges are very safety aware, but the lodges on the Namibian side are much more relaxed. It is still a very untouched piece of land and we had elephants walk through the camp, I've also spotted Lions on the banks of the river before. And don't forget the hippo's they are ever present on that small river! So caution does need to be taken when visiting those areas.
Having said that, it's also the reason that I frequently visit the Kwando river! It's truly an amazing piece of land!
Posted: Mon Jan 12, 2015 8:22 am
by Jim_Davisson
Boat looks great! Awesome fishing pictures. What an amazing fishery you have in your backyard. Do you have tiger fish there and how do they fight? They look like a boat load of fun to catch.
Posted: Mon Jan 12, 2015 8:50 am
by Wouter
Thanx for the compliments Jim!
Yeah, the Caprivi is a very special place! Although not quite on my doorstep, still need to drive 1100km from where I live, but I make the drive without a sweat any day!
As to the Tigerfish, I fish for them often, but more on the Okavango and Zambezi rivers. They do exist in the Kwando river but are very seldom caught, although there has been reports of some 7-8kg fish been taken there. (one day I wish to be one of those lucky guys to get one on the Kwando) On the two other river systems they are relatively common and big fish come out yearly, but they are also seasonal fish and very dependent on the water levels within the systems. They are ferocious fish to catch and give a supreme fight, especially if fished for by spinning. It is said that they can hit your lure at 60km/h!!! Being fast flowing river fish, they are extremely fit so give a great pound for pound fight!
I'll post a pic of a nice tiger my boat partners daughter caught last year during a comp on the Zambezi.
Regards,
Posted: Mon Jan 12, 2015 8:57 am
by Wouter
As promised, I pic of a nice Tigerfish caught on the Zambezi, weighed 5.4kg
Posted: Mon Jan 12, 2015 9:59 am
by Jim_Davisson
Great fish for that youngster. Nothing beats those smiles. I have let everyone else catch all the toads off my boat last year, I find it even more gratifying than catching them myself. I have to agree wholeheartedly that river fish have big shoulders fighting the current everyday. The river stripers I chase fight twice as hard as the ocean variety. Most times they hit it and check the hell out, ocean stripers are like reeling in a log.
The fishing is only part of the adventure, the scenery is the other, you certainly have both!
Posted: Fri Jan 16, 2015 6:44 am
by Wouter
I got a little bit done this week.
Filled and squared the chines and strakes to the transom. Got some nice sharp edges. Will have to sand them a little bit before painting.
Posted: Fri Jan 16, 2015 12:14 pm
Dang, that looks great
And that fish has got a fine set of teeth
Posted: Fri Jan 16, 2015 2:16 pm
by garym
Looks like a cracked up Striped Bass on steroids!
Posted: Fri Jan 16, 2015 5:34 pm
by peter-curacao
Wouter wrote:I got a little bit done this week.
Wow
that looks amazing ! great job
Posted: Fri Jan 16, 2015 9:24 pm
by willg
Wouter, nice job there, and nice sharp edges too. Just fyi when I got to that stage I called System Three and asked what edge radius their primer needed, and was told 1/8". I bet any primer would want that sort of radius. I drilled a 1/4" hole in a small block of wood, cut out about a quarter of the circumference and laid sandpaper into the groove. The small piece of wood was maneuverable and using a little jig like that gave me a consistent edge. Maybe I made the job harder than necessary. Freehanding it would probably work just as well.
Posted: Sat Jan 17, 2015 5:33 am
by Wouter
Will, thanx for that info. Much appreciated. I'll look into making a small jig too, see how it goes.
Posted: Tue Feb 17, 2015 3:46 pm
by Wouter
Hi Guys,
Been a while since a report. But have had some medical issues: ended up in the ER a few weeks ago with heart attack symptoms, but it eventually turned out (after plenty of bucks and tests) to be a severe Esophageal spasm. So luckily all systems are still 100% and the Dr, advised I spend more time om my hobbies, that was however before he knew my hobby was building a boat. He was entriqued and actually came to visit me at home to have a look at the project. A few hours and a whiskey or two maybe three - who's counting - later he gave me an all clear to continue work. With moderation in mind though.
I got the console and seats from Tribal Bass Boats SA
I've alse been working on the Bow EYE fitting and getting it mounted properly, Still needs a bit of touch up but will do for now to do the flip.
I have also started with the support structure for the bottom of the hull once I flip her.
Build on everyone!!
Posted: Tue Feb 17, 2015 9:40 pm
by MarkOrge
Glad to hear you are doing OK, that console looks wicked !
Posted: Wed Apr 01, 2015 4:08 pm
by Wouter
Posted: Fri Apr 03, 2015 11:21 am
by Wouter
And flipped it! Now to put the guts together on the inside!
Rigged up a "block and tackle" system with some old Harken blocks I had from my sailing days.
Slowly Lifted it evenly.
High Enough to get the Jig out.
Pulled the Jig Out.
Replaced the Bulkheads with the cradle.
Just chillin in the air!
Got two hands from the street, took 30 secs to flip! Cost = 2 x ice cold cold drinks!!
Sitting Pretty on the Cradle
She's a wide one!
Stringers/bulkheads fitting good! Will need to strap it together but it fits well.
Now I need a new order of Epoxy!!!
Posted: Fri Apr 03, 2015 1:52 pm
by willg
Congratulations on the flip! The bulkheads are fitting nicely.
Posted: Fri Apr 10, 2015 8:46 pm
by MarkOrge
Way to go, those fish are incredible too!
Posted: Fri Apr 10, 2015 9:28 pm
by peter-curacao
Wouter wrote:
I got the console Tribal Bass Boats SA
Are they making adult toys also? if so they might have misplaced your console mold LOL
sorry couldn't help myself
Posted: Mon Apr 20, 2015 1:06 pm
by tobolamr
Nicely done on the flip!
Posted: Mon Apr 20, 2015 1:47 pm
by blueflood
Nice hull Wouter
and your glass work as well ! The flip is one huge relief.
Marc
Posted: Mon Apr 20, 2015 2:45 pm
by Wouter
Thanks gents!!
Peter, that is why boats are female
Posted: Sun May 17, 2015 2:35 pm
by Wouter
Posted: Sun May 17, 2015 4:13 pm
by cottontop
Really fine glass work. Like your shop. John
Posted: Sun May 17, 2015 4:23 pm
by Wouter
Thanx John.
The workshop is nice and spacious
plenty of room for everything. Just gets a bit hot in there! But have a camping freezer hooked up to keep the drinks cold and close by!
Posted: Mon May 18, 2015 9:48 am
by MarkOrge
Wouter - what he said - nice clean work. If I may, i would like to pass on what others have demonstrated on this forum and what I learned the hard way - neat, clean work pays off huge. I am not a patient man and when I have rushed and not taken the extra time to slow down and produce neat tidy work, it has cost me in material, re-work effort, etc. Nothing worse then grinding and sanding sh*&^t when you dont have to....
Cheers, Happy Birthday Queen Victoria!
Posted: Mon May 18, 2015 9:56 am
What they said, very clean and good work. A little extra time spent working clean saves hours of grinding and sanding later.
Posted: Tue May 19, 2015 2:20 pm
by Wouter
Thanx Mark and CL,
Yeah, agreed! It's worth spending the extra time to prepare properly. I had all the fg pieces pre cut and to the correct size. Laid them down on a table in order of use. Also pre measured the resin/hardener in cups ala CL style. (that's been a great tip I picked up from his forum) Also stocked up on enough rollers so I wouldn't run out!
Although it was a long day, it was a very pleasurable one too! Just love seeing a plan come together!
Away on a work trip for the next two weeks, then on to the stringers.
Posted: Tue May 19, 2015 4:16 pm
by peter-curacao
Very nice glass work
Posted: Sat May 23, 2015 7:02 am
by Evan_Gatehouse
Hey, we will be sailing up the coast of Namibia from S. Africa sometime around Jan/Feb of 2016. Probably will stop at Luderitz and Walvis Bay. Any suggestions for touring around those area from a semi-local?
Posted: Sat May 23, 2015 8:27 am
by Wouter
Hi Evan,
That sounds like a very nice trip.
Lüderitz in itself is a very pretty little town filled with architectural history. Kolmanskop is worth a visit, it's an old deserted mining town, turned ghost town, ingulfed in sand dunes which makes for good photography options. There's also some wild horses further inland, I'm sure there are tour aperators that offer trips!
Walvisbay/Swakopmund offers a lot for tourists, Dune 7 is pretty cool, one of the tallest sand dunes! There's a few outfits offering quad bike trips through the dunes that's pretty nice to do! Spitzkoppe is also worth a visit!
I have a few contacts in Swakopmund, so let me know I'll gladly help set you up.
Regards
Posted: Sat May 23, 2015 9:57 am
by terrulian
Evan,
What are you doing down there? What's your itinerary?
Posted: Fri Jul 10, 2015 6:23 am
by Wouter
Been a slow couple of weeks with a lot of head scratching, tinkering and experimenting to come up with a workable plan, but I've got it sussed out now!
The original plan was to fit the stringers next. However I ran into some problems, the cradle I made does not support the bottom of the boat all the way to the chine, so it had caused a slight droop where the chine meets the bulkhead, around 1-2cm. I did a few experiments and firstly jacked up the chine at bulkhead c (both sides), this worked but lifted the whole boat and didn't quite give the results i wanted. I then lifted the whole boat with a strap, but that was just a bad idea. I then placed some weights in the middle of the boat and jacked up the chines at c again, much better! But still not perfect. Then placed the weights on top of the stringers, to push the stringers down while I jack the sides, now I was in business. The sides however also gave some issues as they were slightly outwards, simply using a strap pulled them together but created a slight bulge along the side of the bulkhead, not good enough, so I strapped some timber up and pulled it together both at the bottom and the top, sorted that out nicely.
This whole process just showed me how damn strong this 'outer skin' is! But it also placed doubt in my mind if I was going to get a correct alignment if I tacked the stringers in, undo all the straps etc, do the stringers and then fit everything back together. I was not comfortable with this and lacked the confidence to do it this way. So I took everything apart, leveled up the jig ( using a laser level), then the boat. Strapped it all together, jiggled it around until I was 100% happy and now I'll glass each box starting from the transom working forward. I just feel a lot more confident in getting a straight boat doing it this way.
Here's a few pics.
A friend's son sitting inside giving a good idea of the size
Lightly sanded where the stringers and bulkheads needs to go.
The gap I had to close on the sides and Chine
The strap idea that just didn't work, contorted the boat way to much.
The best way, weights on the stringers and a jack on the sides.
Timber used for getting the sides lined up correctly.
The whole contraption, lined up and square!
Finally got the perfect fit I wanted!
Made myself a tool for the filleting, out of some tong depression sticks, works very well!
Bilge Area done:
Port side outer box, between e and D
Glassed in.
Got 7 boxes done, a couple more to go.
Posted: Fri Jul 10, 2015 9:01 am
by pee wee
Looking good! There's plenty of space on that boat. One tip that Jacques has mentioned to help with getting the sides in place with a fair curve is to install a temporary rub-rail, just some strips of wood clamped or screwed in place to even things out. It looks like you got it done your way, though. Nice progress.
Posted: Wed Nov 04, 2015 4:16 am
by Wouter
Hi all,
Been slow going, but finished with glassing the stringers and bulkheads. Once I've sanded it down and made it look nice I'll post a pic.
I did get the jackplate and spent some time on it giving it a custom paint job. Looks pretty good, I just hope I can keep it scratch free, for a while at least
The Fuel tank has been ordered, and is getting made here in Namibia by a local boat builder. Looking forward to receiving it back!
Keep on building ...!!
Posted: Fri Dec 04, 2015 8:09 am
by Wouter
Here is some update pics.
Engin well pieces glued into place and livewell floor being dry fitted.
Posted: Fri Dec 04, 2015 9:08 am
by tcason
That looks really GOOD.
cool lines on that boat
Posted: Fri Dec 04, 2015 11:59 pm
by willg
Looking real nice, Wouter! That's a big step getting those stringer boxes glassed.
Posted: Tue Apr 19, 2016 6:01 am
by Wouter
Got some more work done.
Done with the inner structures.
Thru hull holes filled with epoxy and flipped over again to finish and paint the bottom.
1st coat of PU primer on.
Wet sanded her with 360 water paper, she's pretty smooth now.
I do have a few pinholes that I just can't seem to get filled. Ive tried epoxy fillers but they just don't go into the holes, the air inside the holes just seem to push the filler out when I smeer it over. Any ideas..?
Regards,
Posted: Tue Apr 26, 2016 3:31 pm
by LGF
Wouter
Started following your build tonight and it looks GR8, I am soon to start mine, just need to put my wife in an medical induced Coma or divorce her before I start
Anyhow, her son is in the process of repsraying his entire Bakkie (Truck like a Toyota Tundra for the US of A peeps here
) and he recently asked the same Q concerning the pinholes. Whatever you do, do not apply a final coat as the paint will trap air in the pinholes, which will expand with heat and you'll end up with a surface that's reminiscent of some shield hood disease, measles I think it was called!
Kay, so the way to prevent this, is prior to painting the primer, you need to take resin mixed with hardner and nothing else. Then applying a thin coat all over, scrape off all the excess resin with a squidge not worrying about possible ridges and so forth, if excessive, take a brush and brush the resin (thin it out) with long strokes, leave that to cure for around 30minutes and apply a scented coat, repeating the removal of excess. Leave this to cure properly and then use 100 to 150 grip sandpaper to sand it down to have the surface as level as you'd like it to be.
Remember the primer is to thick and will never fill the pinholes, this same thickness also comes into play after sanding the entire area.
There's another way but that would entail sitting with a good pair of reading glasses and filling each pinhole with said mixture, hoping you don't miss one.
Anyhow, as you've already painted the primer, and I am not to sure that the resin coating would do any good wit regards to assisting the sealant of glass in cases where sanding took down a bit much before the primer, I am pretty sure it will still work to fill the pinholes and some scratches caused by say 80 grip paper.
Hope this helps, it sure was an easy and proper fix to the paint job we had, although we had made use of a thinned out version a super fine etch filler. However I saw this on a site where they are fixing and building and painting airfoils on aircraft, so it should work on a boat!
Posted: Tue Apr 26, 2016 4:03 pm
by Wouter
Hi LGF
Thanx for the input.
I've since taken a different route and used a 2mm drill bit, twirled it between my fingers to open up the pinholes and filled it with a epoxy based filler. It was a painstaking process and took ages. But it gave the desired results. I've now also sprayed another layer of primer. It's a filler based primer, pretty thick stuff. So not the final primer coat.
Have sanded the sides and transom and so far I have zero pinholes left. Luckily the effort seems to have paid off! Sanding the rest of the hull in the evenings and will see where I stand by the weekend. Will give an update when I get there.
Regards
Posted: Tue Apr 26, 2016 4:30 pm
by LGF
No Probs Wouter, had I only seen your build earlier I could have posted sooner and saved you the pain in the Bass with the 2mm drill, cause he also went through that process, but there were just way too many so he opted for another in the thinned out filler.
Just to say it again cause it needs to be said again, your Build Looks Fantastic. You opting for a dual console (bass-boat) style or single console or center console?
Posted: Tue Apr 26, 2016 4:55 pm
by Wouter
Thanx for the compliments!
Yeah it was a pretty labour intensive solution, but now that it's done I'm happy I did it! Peace of mind goes a long way in the building process
I'm planning a bass type layout with a single console off centre,with two seats. My fishing partner will just have to endure the breeze
The idea is also to leave enough space between the cockpit and the gunnel so that you can walk around the boat on the deck.
Posted: Tue Apr 26, 2016 7:32 pm
by LGF
Ok that sounds like a cool layout. Have you ever considered a collapsible screen that can act as additional deck area in the area where your fishing partner is sitting. Not sure if I make sense, but basically the deck can be placed and secured in an angled position when on the move and when it gets to fishing then the angled screen (deck)just goes to the horizontal position.
You could end up with a 18 X 6 foot square deck, and only the driver side and console not being able to be walked on and fished from,
Posted: Sun May 08, 2016 1:59 am
by antoniekruger
Hi Wouter,
Great progress. You are very close to the real fun part. Filling in the guts is 90% of the job....IMHO.
Good idea enlarging the pinholes and puttying them up. I sanded mine back a little and re-sprayed with a thinner primer. The high build primers do not get into those pin holes.
Cheers,
Posted: Tue May 17, 2016 11:24 am
by LGF
Wouter
what motor size wise do you intend sticking on the back?
i was looking at the jackplate you bought and was wondering how wide the unit is on the transom side of the plate? i got most of the specs of the plate, but since they don't sell automated plates i will need to modify mine, hence the question of how wide it is. thinking of installing a small yet torque sufficient low rev reversable motor between the two sections, transom and motor parts of the plate?
when you posting pics again, progress bud progress?
Posted: Tue May 17, 2016 11:38 am
by Wouter
Hi LGF
I'm planning either a 115 or 140 suzuki four stroke. It all depends on my finances when the time comes
I'll measure my jackplate for you and post the measurements. (sometime this week)
Been sanding a lot, so not much photo worthy.
Got my fuel tenk today! Will take some pics and put it up.
Posted: Wed May 18, 2016 2:05 pm
by LGF
Cool thanks for the effort.
I'll go past the post office tomorrow to see if my plans arrived yet. Been busy with electronics and plumbing in the meantime. Got the bilge and aerator pumps, some solenoid valves, switches, LED's for hatches and nav lights and switch panels with luminous (glow in the dark power mixed with resin) lettering, also sort of sorted out the way in which I need to fill, then circulated, pump out some water, perhaps refill during the day and empty after the days' fishing, mostly automated at this stage, but still some that processes that requires manual override, soon to be automated completely. Perhaps before installation
Next is the pedestal seats and cowlings.
Posted: Wed May 18, 2016 2:07 pm
by LGF
Posted: Thu May 19, 2016 8:28 am
by Wouter
Here's a pic of the pinholes I drilled/twirled out and filled with epoxy filler. Took ages but it was so worth it! I've sprayed another high build primer coat and sanded it down, It's all smooth with not a single pinhole!!
And the custom Fuel tenk, 150 liters, it will fit in between bulkhead C and D under the sole, in the center of the boat.
Posted: Thu May 19, 2016 8:35 am
by Wouter
Good Plan LGF
I'll tel you what, the sanding can take the stuffing out of you some days!
Posted: Fri May 20, 2016 6:50 am
by LGF
Wouter wrote:Good Plan LGF
That's why I had to stop and buy the following: pneumatic finishing sander (round with Velcro pads and self cleaning) and a linear straight pneumatic block type (long block) sander and a hand planer that can plane to a max depth of 2mm.
I don't like sanding much, but will never ever stop before it's not 100%, so i figured I best get some tools to make it easier and hopefully a bit quicker when I get to the major sanding time.
Was thinking of starting with the hatch lids too, but decided to rather wait as I might make them too large or too small and this will only become apparent when I get the plans and then might have lost a lot of time and effort. I will rather just use the time to produce more bass lures.
There is also work that will dictate how and when I get to build, as I travel abroad at least twice a month if everything is in place at work, however there are times that I get to be in the country for long periods, and that's when my leave gets depleted for my projects
Man I cannot wait to get started, already started with trailer planning too! PS the trailer people here is called Roadque if I'm not mistaken, but also have a former neighbor that is in the trailer building business, so Wouter if you get to that stage, lemme know if you'd like to have his number and see what he'll be able to do for you?
Where my plans @????????
Posted: Fri May 20, 2016 7:06 am
by LGF
I forgot to mention, I am planning to multiple hull flips. Well in my head at least thus far, as I am thinking of sanding the glass work from the deck and subsequent gunnels onto the shear prior fairing and applying the final coat, this goes for the inside of the hull too. Perhaps it won't be necessary, will just require proper planning, but that, although I keeps me awake at night, will sort itself out when the time comes.
Also planning to get everything in place and prepped before I start assembling/building, i.e. build the trailer base and use that as a sting back and cradle, thinking of only installing temporary braces for the bulkheads and the cradle supports when I m actually going to build the hull. The reason for this is, should I run out of time, that I can transport the hull to storage as the place where I have to build, is right in front of our front door and the wife won't be too amused if there is an unsightly unfinished hull lying on a strong back or cradle for that matter. Divorce is not something I am planning
Posted: Fri May 20, 2016 7:17 am
by LGF
Sorry I didn't give you the advice of fixing those pinholes before you had to drill them individually but the surface beneath those holes looks stunning. Great sanding work there!
That fuel tank also looks very good. If you don't mind me asking, why is it extruded at one end and how will that affect the placement wrt the sole and the deck?
Posted: Sat May 21, 2016 4:40 am
by Wouter
Thanx,
Concerning the fuel tank.
I fish two big river comps each year and they both require that you travel pretty far on a daily basis. Three weeks ago we did the Crockango event (on a friends boat), held on the Okavango river and did close to 250 km per day (4 day event), that requires a lot of fuel. And very few commercial boats have big enough fuel tanks so we always end up carrying jerry cans etc on the boat. But they just get in the way and refueling takes time etc. So with my boat a pre-requisite was a large fuel tank. I don't want loose cans on the boat and I don't want to refuel during the day.
So with a large fuel tank, you are adding a lot of weight, so placement becomes important. It had to be on the bottom of the boat to get it as low as possible. With the bulkheads and stringers I couldn't get a large enough space for the tank further back, unless I made two separate tanks, but two tanks creates multiple other issues which I don't want to deal with.
So I decided that the tank will sit in the center of the boat between C and D and on the bottom, I have 20mm of foam on the bottom of the tank. The "tower" part of the tank was added to get the required volume I wanted/needed. The flat part of the tank will then fit under the sole but the tower part will be between the seats. Where others have made coolboxes, I'll have the the tower part of the fuel tank. The Plan is also to have a hatch there so that I have access to all the parts of the tank, that way if there is any issues, I'll have access without having to rip the boat apart.
Posted: Sat May 21, 2016 3:27 pm
by TomW1
Wouter good plan. I also fish some long range comps but Cracker Larry's OD18 has a 40 gallon tank and I will no longer will have to depend on friends taking me out and will have plenty of fuel to make the long runs.
Posted: Mon Jun 13, 2016 4:55 am
by Wouter
Got the bottom painted. I did end up getting a bit of an 'orange peel' that I'm not to happy about. Will need to sand it down and see where were stand then. Maybe a light sand and a polish will sort it out!
Taped up n line.
Masked off the sides.
After two coats.
Done.
Posted: Mon Jun 13, 2016 5:28 am
by LGF
Looking good Wouter, looking very good, how did you end the black coat at the bow, straight lines?
by glossieblack
Very nice bottom treatment Wouter.
Posted: Mon Jun 13, 2016 5:37 am
by Wouter
Yes, its a straight line at the bow. Will take a pic and post it.
Posted: Mon Jun 13, 2016 6:42 am
by LGF
Cool will be nice eye candy!
Really looking good Wouter!
Posted: Tue Jun 14, 2016 4:14 am
by Wouter
As promised, here is a pic of the bow. You can see the 'orange peel' in the reflection.
I've started sanding it down with 600 water paper and its getting smooth. Going to get some 360 water paper today and try that out, should go a bit faster and easier. This stuff is hard as nails.
Had a visit from my friend who has an auto body shop with a spray booth and much better spraying equipment, he's offered to redo the spray job over a weekend for me.
BTW, the sides and transom are going to be white. No fancy paint scheme.
Posted: Tue Jun 14, 2016 4:55 am
by LGF
Posted: Tue Jun 14, 2016 6:44 am
by woylie
Watch it when your boating in the Orca mating season.Could get nasty!
Posted: Tue Jun 14, 2016 7:09 am
by Wouter
Good one Woylie!
Posted: Tue Jun 14, 2016 10:49 am
by LGF
Posted: Tue Jun 14, 2016 10:35 pm
by willg
That graphite looks great, Wouter. I would probably put the sandpaper down at that point but I've got to say I'm looking forward to see what a sprayed on coat looks like.
Posted: Wed Jun 15, 2016 5:47 am
by Wouter
Hi Will,
Just to avoid confusion, Ive decided not to go the Graphite route. I just couldn't get any graphite powder, if I did: the supplier was unwilling to ship to Namibia. There's no graphite on the bottom.
Instead, I've gone the paint route and spray painted a Polyurethane enamel. It was my 1st time using this product so I probably should have done a test section 1st
! It would have saved a lot of sanding. But in the end I'm not to worried, once this layer is sanded and a second layer is applied (professionally
), I'll have a super strong bottom coat, that looks nice too!
Posted: Thu Jul 07, 2016 4:34 am
by Wouter
Got the boat out of the workshop and into the hands of a professional.
The bottom is done and looks a ton better!! Nice and shining with a perfectly smooth finish.
Got a coat on on the sides, a little sand and then two more coats.
I also got a weekends fishing in and caught my PB Nembwe! Very chuffed!
Painting should be finished by the weekend, I'll post a pic when it gets back!
Posted: Thu Jul 07, 2016 8:05 am
by Jeff
That bottom looks great!! True mirror finish!! Jeff
Posted: Thu Jul 07, 2016 10:54 am
by LGF
The paint job looks absolutely stunning Wouter, same goes for that Nem, what's the weight?
Also, saw Bassmunn's last couple of posts. He went the paint route and regretted it, saying that it wasn't as durable and scratch resistant as a graphite coat would be. knowing you can't get hold of graphite, have you come accross a marine epoxy paint that could be sprayed? I would like to have the boat with a finish like that, but would also opt for something a little more up to scratch (pun intended) with my extreme kinda fishing
PS, don't forget the pics when she's back? Need a fix!
Posted: Thu Jul 07, 2016 11:24 am
by Wouter
Nembwe was 2.77kg
Yips, Bassmunn used automotive 2k if I remember correctly from his post.
I opted for a Polyurethane from Libra Paints. After many hours spent researching the options, I decided on their product. It does get used in the marine environment and they supply large fishing vessels with this product. So it has been tried and tested. After having used it, I would recommend it any day of the week. I also sanded down the first coat of black on the bottom and believe me this stuff is tough!! So I'm not worried about the scratches.
Check this out!!
I'm thinking about adding a red pinstripe between the black and white. This is just a vinyl sticker for now to give an indication of what it will look like.
Posted: Thu Jul 07, 2016 6:05 pm
by jorgepease
Shiny!!! I like the pinstripe!
Posted: Thu Jul 07, 2016 8:38 pm
by Dustinwg
That is top notch there! Did your painter spray graphite, or is that paint? Either way, WOW!
Posted: Fri Jul 08, 2016 1:41 am
by LGF
Oh my ................
I'm Gobsmacked
IT LOOKS (speechless)!
That is exactly what the pictures in my mind looks like, different Colours and designs on the shears if I remember your proposed designs correctly, but the finish, the shine, the sexy gloss, oh I am going to have such a hard time concentrating for at least a week.
Will defs remember Libra for the paint, do they have a good colour range?
PS. Thanx a mill for messing around with my abilities to do anything but fantasize
Posted: Fri Jul 08, 2016 5:54 am
by Eric1
That my Friend, Is one Beautiful finish!! Well Done Indeed!!!!
Posted: Fri Jul 08, 2016 6:07 am
by glossieblack
Posted: Fri Jul 08, 2016 6:52 am
by DAVE LUDICK
Boat looking brilliant, I like the "Nembwe", I think it is still the best freshwater fish to catch in Southern Africa, only the 3 spot comes close. Enjoyed fishing "Island View Lodge" area as well as the Barotse floodplains. My GV15 will spend most of it's life in that area.
Enjoy the build and I hope you have many happy hours on water doing what you like best.
Dave
Posted: Fri Jul 08, 2016 8:07 am
by topwater
Beautiful paint job
Posted: Fri Jul 08, 2016 10:21 am
by cape man
That is fantastic! The bar is once again raised!
Posted: Tue Jul 26, 2016 6:29 am
by Wouter
Posted: Tue Jul 26, 2016 7:52 am
by Jeff
Wouter, Really nice work on your bottom!! Shines like a mirror!! Also, nice fit for the fuel tank!! Jeff
Posted: Tue Jul 26, 2016 9:29 am
by cvincent
Wouter, your fairing and paint job is a work of art. Are you installing your fuel tank between frames C and D? I have been thinking of different options for the fuel tank installation with my build.
Posted: Tue Jul 26, 2016 9:59 am
by Wouter
Thanx.
Yes, the fuel tank sits between bulkheads c and d under the sole. I had to do that to accommodate the amount of fuel I will need to carry, without using two separate tanks.
Where are you going to place your tank..?
Posted: Tue Jul 26, 2016 11:11 am
by cvincent
I am thinking under the sole either between B and C or C and D like yours is placed. I want a 30 gallon tank because I sometimes fish areas that are 60 -80 mile round trip. Are you planing to route the fuel fill and vent to the back deck?
Posted: Tue Jul 26, 2016 11:28 am
by Wouter
What type of layout are you planning.? I would think that having 30 gallons between b and c would put a lot of weight in the front of the boat.?
The fuel filler cap and vents will sit behind the passenger seat. (or that's the plan). So from the tank they will go straight left towards the port side and then up to the filler cap.
Posted: Tue Jul 26, 2016 12:26 pm
by cvincent
The layout will be a center console with front and back deck as per the plans. Yes, good point 30 gallons is a lot weight forward in the hull. Once my hull is turned over I can get a better idea of how to install the tank. I will have to go with a custom made tank.
Posted: Thu Jul 28, 2016 4:23 am
by LGF
Wouter
Its starting to become a bass-rig now, is looking very very nice and please from hereon onwards please include a pic of the bottom paint job on every update, I too can't get enough of how good that looks, please?
Posted: Thu Jul 28, 2016 10:23 am
by Fred in Wisc
That paint job is stunning. it's the exact opposite of how my paint jobs turn out. Bravo!
Posted: Thu Jul 28, 2016 1:02 pm
by LGF
Fred in Wisc wrote:That paint job is stunning. it's the exact opposite of how my paint jobs turn out. Bravo!
Come now, it can't be that bad, I mean if we give Wouter a 10 then surely yours can't be -10
Posted: Thu Jul 28, 2016 2:06 pm
by Fred in Wisc
OK, maybe not the exact opposite. Both end up with color on the boat, but his surface finish is like a dead calm lake with nothing floating on it, and mine's more like a breezy day with a mayfly hatch going on. Still floats. Fish don't care. But with a boat as pretty as Wouter's I'd be a LOT more careful docking and launching.
Posted: Thu Jul 28, 2016 3:07 pm
by LGF
Kay, you win, with a description like that how can you not? One things for sure and that's that Wouter nailed that paint job, sure is heading to become a great looking girl, Lady! Again congrats on that paint job Wouter!
Re: Wouter's PH18 Namibia
Posted: Sat Sep 03, 2016 5:04 am
by flyfishingmonk
I am getting caught up on a few threads, and this boat of yours sure looks nice.
Casey
Posted: Mon Sep 05, 2016 4:30 am
by Wouter
Thanx Casey
Currently busy doing the foam and all sorts of bits and pieces. Not much photo worthy, but will make a plan to take some pics and post an update.
Regard
Posted: Thu Sep 08, 2016 7:20 am
by Wouter
As Promised, here's some pics and a update.
Test fitted the water trap for the fuel. I have heard rumors that these traps can cause the motor to struggle to suck the fuel from the fuel tank and that one should use a booster pump between fuel tank and water trap to make it easier for the motor...? Any comments..?
I got the foam and with the first pour did a pretty good job, almost perfect, some good calculations
However soon realized it wasn't always going to be this easy
Lots off little poors to fill it all up without wasting to much foam. Used a hacksaw blade to cut it down and then finally sanded it flat with a orbital sander, not too difficult just some nasty stuff to sand.
Bow floor section fitted and glassed into place.
Between bulkheads A and B, foamed and prepped to glue the sole down. Its done now and also glassed into place.
Posted: Thu Sep 08, 2016 8:32 am
by Jeff
Wouter, great job!! Looks really nice!! Jeff
Posted: Thu Sep 08, 2016 9:01 am
by topwater
Wouter as far as the fuel filter set up most of the boats on this site use a external fuel filter and
have had no problems that i am a where of. My self included.
Posted: Thu Sep 08, 2016 9:34 am
by Wouter
I'll be running an inline fuel filter as well.
But with my fuel tank being aluminum I was advised to add a separate water trap by the manufacturer of the tank. According to them the tank will have condensation inside it and create water that will lie at the bottom of the tank. The outflow of the tank sits at it's lowest point which means if any water does get in there it will definitely get into the fuel line. Therefore I have added this water trap in the fuel line system, to prevent any chance of water getting to the motor. But, now someone told me that the fuel pump on the outboard is not strong enough to suck the fuel through this water trap and maintain steady fuel flow to the motor, causing the motor to strain and under perform. This has me
my head.
The suggestion was to add a small fuel pump between the tank and the water trap that is switched on when the motor starts.
I have no experience with these water traps, so have no idea what to expect.
Will probably be best to speak to the manufacturer directly and find out from them.
Posted: Thu Sep 08, 2016 9:41 am
Do I understand your fuel is coming off the tank bottom? And you are running a gas engine? If so that is something that is not approved here in the USA. You can do it with diesel but gas is a no-no.
I have a filter like that on my Merc 50hp and it has no problem with it just for info.
Posted: Thu Sep 08, 2016 9:51 am
by Wouter
Here is a better picture of the water separator.
Posted: Thu Sep 08, 2016 10:09 am
by Wouter
Thanx Fuzz,
If a 50hp can pull it through then the 150hp should have no problems
Yeah, we don't have near as strict safety regulations as on your side of the pond. Will take years before we catch up to the Western standards. (to be honest I've tried to find regulations for Boat safety in Namibia, for registration purposes, but there just simply are none from government. They keep telling me they will just come by to inspect and then they will issue a boat license, without any set regulations whatsoever! Pretty scary!)
However I would still like to do my boat on the safe side
What would be the reason for not allowing gas to be fed from the bottom of the tank...? Is it for spillage and leak reasons..hence fire hazard?
Maybe I can modify my plan to be more safe!
Regards
Posted: Thu Sep 08, 2016 10:55 am
I have not read the regs but I am sure it has to do with a highly flammable liquid being able to leak into the boat. Diesel tanks are built with fittings on the bottom very often.
I got to thinking about it and I have the same filter as you on my 9.9 Suzuki kicker also with no problem. I think you are good with your 150. Make sure it is rated to flow what the motor needs at wide open.
Posted: Thu Sep 08, 2016 2:51 pm
by flyfishingmonk
Wow these pics are great, and what good progress.
I am thinking of making three lockers in the back as well.
Casey
Posted: Sun Sep 25, 2016 6:48 pm
by Wouter
Got a bit done.
Foamed the boxes between b and c, ready to take the sole
Glued the sole down and prepped for glassing. I dropped the sole in the middle to make a slightly larger compartment
Glassed in. Using peel ply to make the glass smoother and the fairing later on easier
The rear port side, contains the drain tube that the bilge pumps plumbing will go through.
All Foamed up and a hole made for a inspection hatch in the foam.
Test fitting the sole for the aft port section. Added hatch cover,for our yearly renewal of the Certificate of Floatation (RSA standards) the foam needs to be inspected. So I thought I would plan for this so they would not have to drill through my sole at some point in the future
Posted: Mon Sep 26, 2016 3:54 pm
by cvincent
You work looks professional. Your foam is nice and level with the top of our compartments.
Posted: Mon Sep 26, 2016 4:47 pm
by Jeff
Wouter, very professional!! Nice clean look!! Jeff
Posted: Tue Sep 27, 2016 6:55 pm
by flyfishingmonk
Great stuff here. Looks amazing.
Casey
Posted: Tue Sep 27, 2016 11:02 pm
by Wouter
Thanks gents!
Always nice when your work is appreciated!
Posted: Sun Oct 02, 2016 11:28 am
by LGF
Wouter your work looks GR8 and glad to see you're building again, been a bit quiet on the boat-building, must have done fishing I suspect, if so you owe us pictures
Posted: Sun Oct 02, 2016 11:39 am
by Wouter
Yeah, been busy with some family matters lately.
Sadly my father passed away middle August. And with me being in a different country it's put a lot of strain on my schedule etc.
Posted: Sun Oct 02, 2016 12:20 pm
That is a tough one. Wishing the best for you and your family.
Posted: Sun Oct 02, 2016 1:04 pm
by antoniekruger
Jammer om te hoor - sterkte daar.
Posted: Sun Oct 02, 2016 7:42 pm
by Eric1
Sorry to hear about your Dad. Prayers you and the family.
Posted: Wed Oct 12, 2016 4:08 pm
by Wouter
Thanx all!
My dad has sure been an inspiration in my life! Got me into boats at a very young age. Revamped and built a few with him! Definately going to miss his input and support!
I got a bit done in the evenings. Finished the sole front and aft. Now for the cockpit area.
I need to figure out how I'm going to fix the feul tank to the boat before I can fit the sole there. So a bit of thinking to do before I continue. My thoughts are that the high density foam on the bottom of the tank will compress over time...? And that might cause the tank to be slightly loose under the sole with no way to get to it. So trying to come up with an idea that will allow me to tighten it up again should it get a bit loose later on..? Or am I just beeing paranoid..?
Posted: Thu Oct 13, 2016 7:19 am
by topwater
Do not use foam under a fuel tank , you will eventually end up with crevice corrosion and a leaking tank.
Posted: Thu Oct 13, 2016 11:58 am
by cvincent
Wouter,
Just a thought, you could first lay down several neoprene strips bedded in 5200, then bed the tank on the strips with 5200. I know this does not involve any mechanical fasteners, but it may be strong enough to support the tank. I have seen others apply coal tar epoxy to the tank and then foam. I know foam is not recommended due to the risk of eventual corrosion.
Posted: Thu Oct 13, 2016 12:24 pm
by Wouter
Thanx guys
Just to clarify, the high density foam that is currently under the tank(Glued on with contact adhesive) is not the expandable type used to fill the compartments.
It's like those blue camping mattresses,only this foam is water proof and doesn't absorb water at all. I'll post a pic.
I do not want to put any expandable foam anywhere near the tank.
Vincent, you have put me onto a good idea. Instead of fastening the tank from top(which my head got stuck on) , fasten it from the bottom!
Posted: Thu Oct 13, 2016 12:37 pm
by Wouter
See the 10mm foam on the bottom of the tank in this picture
What about using silicone on the bottom of the foam (neoprene) to 'glue' it to the bottom..? Anyone done that before?
Posted: Thu Oct 13, 2016 4:28 pm
by topwater
I used 5200 on the bottom of my strips , then stuck that to the sole in the tank compartment.
Go to my build gallery and check out the way i did it. Pictures pretty much say it all.
Posted: Thu Oct 13, 2016 4:30 pm
by Wouter
Thanx. Will do!
I just can't get 5200 here, so need to find a substitute.
Posted: Thu Oct 13, 2016 4:40 pm
by TomW1
Yes Neoprene strips and 3M 5200 or equivalent top and bottom is the way to go. The strips are sold in the Bateau store for reference since you probably won't want to order from here although UPS shipping may make it feasible.
http://boatbuildercentral.com/proddetai ... 9443_1%2F4
Posted: Thu Oct 13, 2016 4:55 pm
by Wouter
Thanx Tom.
Yeah with what's going on this side on the political front and the severe nose dive of our Rand vs the U$D it's not feasible to import and transport much these days.
I had a look at your pics Topwater. Thanx for the direction and I now have a much better idea of what I need to do!
Once again this forum comes to its right!
Thanks peeps!
Posted: Thu Oct 13, 2016 5:24 pm
by cvincent
If you can find a polyurethane based adhesive or polysulfide adhesive, they both have better strength than silicone. A polyurethane based sealant/adhesive should have the best adhesive strength. Too bad you cannot get the 5200.
Posted: Thu Oct 13, 2016 5:26 pm
by Wouter
Thanx Vincent,
I'll look into that!
Posted: Thu Oct 13, 2016 5:30 pm
by peter-curacao
Wouter wrote:Thanx. Will do!
Wouter did you look in the right shops? when I started my CS we only had 1 marine shop on the island thank god we have three now, but aside from that, it was about six years ago that I looked for a long board couldn't find one, that one shop didn't have it so I made one, then one day I had to buy a new copier for the office so I went to xerox to buy one, ones leaving the store I saw a corner in the store with all 3M products after all they sell office products also,to my surprise the had a couple of shelves with industrial products also, like epoxy pour sleeves (electrical), long boards, long board paper but also 3M 5300.
Not saying it will be the same in Namibia but maybe it's worth a couple of phone calls?
Posted: Thu Oct 13, 2016 5:49 pm
by Wouter
Good point, I have found the weirdest things at the weirdest locations/shops here.
But I'm close to the Angolan border in a very small town (population 200k), 800km from the capital. With very little to no shops. So most of all metarials I have used so far have been sourced and couriered to me(at a price of course) We have also have only one hardware store
South Africa has a lot of the products, but sometimes the companies just refuse to export to me, so makes it difficult.
Mostly I take product info from this forum and try to source it. But it takes a long time unfortunately! And a lot of time dealing with suppliers etc.
But I'll get it done with the right stuff! Just got to be patient!
Posted: Tue Oct 25, 2016 1:17 pm
by Wouter
Ordered, paid and on its way
Posted: Tue Oct 25, 2016 1:25 pm
by pee wee
. . . err, that ought to get the job done!
Posted: Tue Oct 25, 2016 1:26 pm
by flyfishingmonk
Nice!
Posted: Tue Oct 25, 2016 2:06 pm
by Dustinwg
Man that thing is going to fly!
Had a buddy put a 115 on a PH18 and it would run 55+. . . hope you have good blocking for the oh sh!t handles!!
Posted: Tue Oct 25, 2016 2:32 pm
by cape man
Zoom zoom!
Posted: Tue Oct 25, 2016 9:52 pm
by cvincent
Very nice, I look forward to hear about the performance numbers. The Suzuki is a good choice, had one on my last boat and it was bulletproof.
Posted: Thu Nov 10, 2016 3:40 pm
by Wouter
Got myself a dremmel, it's an awesome little tool! Should have bought one ages ago
Made holes to fit a 110mm pvc pipe with it that I will be running the steering and other motor cables through. Came out nice!
Posted: Thu Nov 10, 2016 3:49 pm
by flyfishingmonk
Wouter wrote:Got myself a dremmel, it's an awesome little tool! Should have bought one ages ago
Very cool! Another tool I need to get. =)
Posted: Thu Nov 10, 2016 3:59 pm
by Wouter
Get one! You won't be disappointed!
With all its extras and add on's it really is a versatile tool. It's probably not designed for the scale of our boats, but if you work slowly and don't put to much pressure on the motor you can do a lot with it.
I particularly like the fact that I can now get into places that standard size tools just won't allow you to.
Posted: Thu Nov 10, 2016 9:44 pm
by Newt
It also has an attachment for sharping lawn mower blades.
Newt
Posted: Sun Nov 13, 2016 7:59 am
by Wouter
Cut out a hatch today. The plan seems to work
A whole bunch more to do!
Posted: Sun Nov 13, 2016 1:24 pm
by gonandkarl
Hi Wouter,
Did You cut out the hatch also with the Dremel ?
Greetings from Karl
Posted: Sun Nov 13, 2016 1:45 pm
by Wouter
Hi Karl.
Yes, used the dremmel. Takes a bit of time but I'm happy with the results.
Posted: Tue Nov 22, 2016 7:15 am
by Wouter
With the cockpit floor in place and the corresponding lid in place. I like this method of cutting out the hatches, it might take time, but I end up with a perfectly matching lid at the same time. So I figure it is worth the time spent.
I have looked into a proper router machine as I don't have one(I think it will go faster then with the dremmel). Interestingly enough all four hardware stores here carry a router although neither of them have a single router bit!! Amazing! I cant understand how they stock a piece of machinery but have no support for it at all. So again I will need to source one with the right bits etc.
I'm also starting to train my apprentice for one day!
Posted: Sun Dec 11, 2016 1:54 pm
by Wouter
Been playing around with counter sinking the hinges for the hatches. Made a quick tool for the dremmel to adjust the depth and to be able to follow a jig.
Posted: Sun Dec 11, 2016 2:00 pm
by Wouter
Also been working on the hatch edge that the lid will be sitting on. Plan is to use a 9mm nitrile rubber oring on the inside of the lid that will hopefully press tightly against the lid to give a good seal.
I'll post some pics of the complete assembly soon.
Posted: Sun Dec 11, 2016 6:48 pm
by gonandkarl
Hi Wouter,
I did my 2 sole hatch lids like you I just did not use round rubber but a 1 cm wide rubberband which is actually meant to be put between a door and its frame to seal any small gap. Thanks for your ideas with the dremel.
Greetings from Karl
Posted: Sun Jan 08, 2017 8:58 am
by Wouter
My motor arrived!
Posted: Sun Jan 08, 2017 9:05 am
by Wouter
Before I can fit the cockpit floor, I had to paint the feul tank bay as well as the under floor livewell. So while I was busy I thought I would do the motor bay as well seeing that it was complete.
All prepped and taped up.
A quickly sneak peak at the motor bay.
Going to give it one more coat, will post pics when done.
Posted: Sun Jan 08, 2017 11:18 am
by Wouter
Now I can fit the feul tank. And then the cockpit floor.
While I was at it I did the bow too.
Posted: Sun Jan 08, 2017 12:28 pm
by gonandkarl
Hi Wouter,
You are really making good progress with your perfect boat. When I lived in SA my son was as old as your apprentice on the picture. I then dreamt only of building boats. Now that I am a boat builder the son is already 35 and I was glad he helped me shovelling snow from the side walk today. So far for boat building in Austria in January.
I look at all your pictures in detail and I have one question. In the bow there are 3 holes of which 2 are for the bow ring but what is the hole at the bottom for ?
Greetings from Karl
Posted: Sun Jan 08, 2017 12:36 pm
by Wouter
Hi Karl.
Thanx for the compliments.
The third hole is just a draining hole for if water gets into the bow section. It (water) goes into the bottom of the boat and should run to the bilge area were i'll be able to pump it out via the bilge pump in the stern.
Posted: Mon Jan 09, 2017 2:18 pm
by Wouter
Feul tank glued into place.
Came up with a cheap and easy solution for the under floor livewell bilge pump, needs to stay in place but also be easy to remove if it needs to be replaced.
Posted: Mon Jan 09, 2017 2:23 pm
by Jeff
Wouter, very nice work and great thinking on the bilge pump!! Makes replacement a snap!! Also, your foam work looks really well done and professional!! Jeff
Posted: Mon Jan 09, 2017 2:48 pm
by Wouter
Thanx Jeff,
That bilge pump will be an arms length away from the hatch once the cockpit floor is fitted, so needed a solution that will make service or replacement easy.
Thanx for the compliment on the foam job. Spent some time to get it right. I did a few pours in each box just to make sure I don't waste to much foam. Something that I realised while working with it, is to wait a few hours before pouring another batch,just to let it cool down. That stuff gets pretty hot! When I was to hasty and poured a batch on the already expanded foam, the next pour didn't expand as much. I'm thinking it's got something to do with heat exchange. (maybe the experts could help out)
But if I let the expanded foam cool off properly (I waited 3 hours between pours) I could better work out the volume for the next pour mixture. Maybe this helps someone else who still needs to do the foaming.
Posted: Mon Jan 09, 2017 2:57 pm
by Jeff
Wouter, yes, really good explanation for everyone else on the pours of foam!! Good information!! Jeff
Posted: Sun Jan 15, 2017 11:34 am
by cvincent
Looking good Wouter
Posted: Tue Jan 17, 2017 7:47 pm
by MarkOrge
Coming together nicely !
Posted: Wed Jan 18, 2017 3:30 am
by LGF
Wouter, you're doing an amazing job and cannot wait to see what next you'll come up with to make stuff work better and getting your rig as practical and functional as can be. You're an inspiration!
Posted: Sat Jan 21, 2017 5:25 am
by Wouter
Started with the trailer, planning a double axle.
[image]
http://gallery.bateau2.com/albums/userp ... WA0008.jpg[/image]
Posted: Sat Jan 21, 2017 5:40 am
by LGF
Hmmmm looking good.
That's my starting point. I reckoned building the trailer first is the best option for my limited space issue and the realistic long time it takes to build the boat. So, I plan to use the trailer as the "strongback" and upon 1st flip, to then place the resting supports onto the hull, flip the trailer, suspend and level and then measure, cut and weld the support beams to the trailer. Paint those small pieces and flip everything back, right way up.
If I need to move the trailer during any part of the build, I can easily do so and not infuriate the Ms Boss all that much in one go, rather a little each time, till she gets used to it!
Went with the single axle @ 1600kgs unbreaked, on 14' rims n tyres, blade springs of 900kgs and 78x38x5 U channel for the frame and cross-braces.
Also got some artificial "wood" some sort of plastic decking that will form the base under the boatfelt as the support beams, two on each side of the keel around 2,5 to 3m in length.
Posted: Sat Jan 21, 2017 5:47 am
by Wouter
Unfortunately here, they have changed the regulations, if you use two axles, both need to be braked. So had to go for that. I'm using 100*50*5 u channel. Going to be a super strong trailer! (and heavy) But we have to travel some bad gravel roads to get to some locations and I don't want to struggle with a trailer. Figured I'll over engineer it and be save.
Posted: Sat Jan 21, 2017 4:39 pm
by TomW1
Wouter may I make a suggestion. Go with a single axle and 15 or 16" wheels. Use a torsion bar axle system, it is much more efficient than a spring system and provides a smoother ride.
Posted: Sun Jan 22, 2017 12:48 am
by Wouter
Hi Tom.
Problem is that we often launch directly into the river without a concrete slipway, just a shallow sand bar. So I want to keep the boat as low as possible on the trailer to facilitate easier launching. And for this reason I am using 13' wheels, but felt that a single axle with 13' would be stretching it. (hence the double axle)
I would love to have 15' or 16' but it will just not be practical for our launching facilities.
I have another hauling trailer with torsion bar axles, it works really well. But I couldn't get torsion bar axles with a 13' wheel hub, so that idea went out the door unfortunately.
Posted: Sun Jan 22, 2017 5:25 am
by Wouter
Glued the cockpit floor. Used a few screws to make sure it sits correct. Will take them out and fill with epoxy.
[image]
http://gallery.bateau2.com/albums/userp ... 120941.jpg[/image]
Posted: Sun Jan 22, 2017 5:46 am
by glossieblack
Wouter, with the new setup, you don't use the image button when posting a pic, you use the Microsoft image icon button.
Very nice work!
Posted: Sun Jan 22, 2017 6:01 am
by Wouter
Thanx.
I couldn't figure it, thought it might be something to do with my phone.
Now I know
Posted: Sun Jan 22, 2017 6:26 am
by Wouter
Let's try this picture thing again
Made a grid out of meranti that fits above the fuel cell. In other PH18 threads I've read that the floor tends to flex a little in that area, especially if you don't build a center console as the PH18 is actually designed for!
So to counter that I fitted the grid. In the picture it is not yet glued and I did place a few small pieces of rubber between the grid and the tank.
Photo thing now sorted
Posted: Wed Jan 25, 2017 5:49 pm
by LGF
Looking Good Wouter, really Good!
Posted: Thu Jan 26, 2017 2:21 am
by Wouter
Test fitting the axles
Posted: Thu Jan 26, 2017 1:14 pm
by cape man
That looks like a very stout trailer!
Posted: Fri Jan 27, 2017 2:59 pm
by LGF
Sorry for being so inquisitive but I cannot help noticing things even if it's subtle, was wondering about the beige coloured outline on the floor beneath the main frame of the trailer??????
Posted: Fri Jan 27, 2017 3:12 pm
by Wouter
Lol, well spotted. It's the spot where I sprayed the bottom. Left a nice outline of the boat. Besides measurements it just gave a crude idea of the size
Posted: Fri Jan 27, 2017 3:34 pm
by Wouter
Did a quick test on all the systems, everything works well. Next step is to put the boat on and manufacture all the supports etc. Getting closer to having a trailer
Posted: Fri Jan 27, 2017 3:39 pm
by Jeff
Nice Wouter!! Jeff
Posted: Sat Jan 28, 2017 1:13 am
by LGF
yeah sorry I had to ask, just one of my things, anyhow, the trailer looks solid Bud! Could you perhaps take a closer pic of the section just behind the coupler, I am curious to see your towing bar/trailer frame connection (how they are attach to each other)
Posted: Sat Jan 28, 2017 3:37 am
by Wouter
Posted: Sat Jan 28, 2017 7:28 am
by Jeff
Great trailer!! Jeff
Posted: Sun Jan 29, 2017 12:59 am
I have never seen that style of coupler before. It is neat to see what is used for the same tasks in different parts of the world.
Posted: Mon Jan 30, 2017 2:43 am
by LGF
VERY VERY Nice, don't think you'd ever need to worry about the trailer ever destroying your labour of Love that'll be resting on top of it !
Posted: Sat Feb 04, 2017 7:31 am
by Wouter
Posted: Sat Feb 04, 2017 8:56 am
by Jeff
Wouter, really looking nice!! Nice trailer as well!! Jeff
Posted: Sat Feb 04, 2017 9:01 am
by Wouter
Thanx Jeff,
Still a ways to go! But ala CL, taking bite size chunks out of the elephant at the moment!
Posted: Mon Feb 06, 2017 10:57 am
by flyfishingmonk
Wouter, this boat is looking great! - Casey
Posted: Mon Feb 06, 2017 3:51 pm
by Wouter
Thanx Casey!
Posted: Sun Feb 12, 2017 11:18 am
by Wouter
Posted: Sun Feb 12, 2017 11:20 am
by Wouter
The smaller rectangular cutt out is for the Trolling Mode switch.
Posted: Sun Feb 12, 2017 8:19 pm
by BB Sig
That looks great! Nice idea on the recess.
Are your gunwales tying into mount?
Posted: Sun Feb 12, 2017 9:38 pm
by Wouter
Hi Barry,
That's correct, the deck and gunwale will form part of the completed structure.
Regards
Posted: Mon Feb 13, 2017 1:39 pm
by Wouter
Here's my quick artist impression of the plan.
Blue is the deck and the green is a cross section of the gunwale that will run from stern to bow.
Posted: Sat Feb 18, 2017 3:07 pm
by Wouter
Some progress on the trailer. Bunks and winch fitted. Still designing some custom mudgaurds, but will fit cheap off the shelve ones in the mean time just to get it registered. Also still needs a lick of paint.
Posted: Sat Feb 18, 2017 3:19 pm
Nice looking trailer! you are a man of many talents
Posted: Sat Feb 18, 2017 6:20 pm
by Jeff
Agree with Fuzz!! Great job on your trailer!!! Jeff
Posted: Sun Feb 19, 2017 12:12 am
by Wouter
Thanx guys!
Posted: Sun Feb 19, 2017 12:22 pm
by Wouter
Rod locker taking shape.
Posted: Sun Feb 19, 2017 12:56 pm
That is some clean looking work
Posted: Mon Feb 20, 2017 3:12 am
by LGF
Nice going there Wouter, looks very cool.
Posted: Mon Feb 20, 2017 5:31 pm
by flyfishingmonk
This is looking great!
Posted: Mon Feb 20, 2017 8:12 pm
by Jeff
Really looking good Wouter!! Jeff
Posted: Sun Mar 05, 2017 11:18 am
by Wouter
Posted: Sun Mar 05, 2017 11:25 am
by Jeff
Nice Wouter!!! Jeff
Posted: Thu Mar 16, 2017 6:12 am
by Wouter
Trailer is done.
Posted: Thu Mar 16, 2017 6:29 am
by Eric1
VERY NICE!
Posted: Thu Mar 16, 2017 10:31 am
by willg
That trailer looks good and stout, Wouter!
Posted: Thu Mar 16, 2017 12:06 pm
by flyfishingmonk
Looks awesome!
Posted: Mon Mar 20, 2017 4:26 pm
by Wouter
Been at it this weekend.
Painted the floor under which the forward rod compartment will be. Awaiting some carpet that will go over that before I can fix those boxes in place.
Boxes painted on the inside.
Fitted the divider in the tackle storage hatches. Still nice and big hatches these!
Been playing around with the cockpit layout. Made a slit under the seat, driver side still to be done. This will just give some more storage options. And easy access for bolting the seats down.
Step in die middle over fuel tank will double up as a seat for a third person. Underneath a storage space with a shelf for cellphones and car keys and all those small things that just never have a space on a boat. Also adding a cellphone charger in there.
Just a pic from the stern.
And one from the bow.
Posted: Mon Mar 20, 2017 4:56 pm
by Jeff
Wouter, very well done!! This is going to be a great boat!! Jeff
Posted: Mon Mar 20, 2017 8:15 pm
by Eric1
You are doing a great job Wouter!
Posted: Tue Mar 21, 2017 1:51 am
This looks like a really well thought out build. I like it a lot.
Posted: Tue Mar 21, 2017 10:11 pm
by cvincent
Very nice work Wouter. You may have to buy more fishing poles to fill those rod boxes.
Posted: Wed Mar 22, 2017 6:21 am
by cape man
That's sweet.
Posted: Mon Apr 10, 2017 8:53 am
by Wouter
Thanx all
Vincent, for sure!! Will need to visit the tackle shop, not only for rods but all tackle. Those storage boxes are massive!
Posted: Mon Apr 17, 2017 12:11 pm
by Wouter
Done most of the fillet and fiberglass tape on all the joints this weekend. Started with fairing the boxes in the front, but will take a while before beeing photo worthy.
Made a box next to the passenger which will house the landing net(folding type). Did it at an angle to make it easier to put it in and take it out. The landing net always seems to be in the way on a boat, so hopefully that issue will be resolved
Posted: Tue Apr 18, 2017 9:54 am
by pee wee
Wouter wrote: ↑Mon Apr 17, 2017 12:11 pm
That's a great idea, and one that I've never seen addressed. Don't be surprised if you see that idea being thought of spontaneously by others!
Posted: Tue Apr 18, 2017 10:18 am
by cape man
Nice! Don't know how many times I wished I had planned for my landing net.
Posted: Tue May 30, 2017 5:53 pm
by Wouter
There's just something very satisfying with freshly sanded wood.
Slowly making progress. Holes in the cockpit bulkhead will house some waterproof speakers. Got to have some tunes on the water
Test fitting the seats and getting the angle right for a comfortable ride.
Hoping to put some colour on the front boxes come this weekend.
Posted: Tue May 30, 2017 6:38 pm
by glossieblack
Lovely work Wouter.
Posted: Tue May 30, 2017 6:45 pm
by cape man
I agree. Looking really awesome and so we'll thought out.
Posted: Wed May 31, 2017 2:27 am
by TomW1
Looking good, like the seats.
Posted: Wed May 31, 2017 7:49 am
by Jeff
Great build Wouter!!! Jeff
Posted: Wed May 31, 2017 4:02 pm
by Eric1
+1 Your Boat looks Freakin Sweet!!
Posted: Wed May 31, 2017 4:25 pm
by Wouter
Thanx gents!!
Posted: Thu Jun 01, 2017 9:41 am
by cvincent
I agree with everyone else your boat looks great and is very well planned.
Posted: Fri Jun 02, 2017 10:48 am
by Wouter
I've received a personal email regarding a fitting I made on the transom. Someone spotted it on a pic and enquired about it. Thought it good to share it here with you all.
So it is an automatic uptake for the livewell. I really didn't want to put the standard fitting through the bottom of the hull and came up with the idea to make it off the transom. Here a series of pics.
I used a 10mm stainless steel pipe, inner diameter of 6mm. Bent it using a pipe bender.
I made a sharp bend and cut it straight.
Made a hole through the transom for the pipe to go through.
Fiberglassed it to the transom.
With about 12mm sticking out below the boat. So the idea is that when I'm driving forward the water pressure should push up the pipe and into the livewell, creating an auto uptake.
Faired it nicely and after painting, it made for a nice seamless fitting that looks part of the transom.
On the inside it will get connected to the livewell with a fitting that can control the amount of flow (fitting is in the 1st pic.
I haven't seen this done before, so it still remains untested
Posted: Fri Jun 02, 2017 8:23 pm
by woylie
Hi Wouter,
I've seen a lot of Indonesian fishermen with similar setups on their cooling water intakes.Siphoning shouldn't be an issue in your baitwell.A flexible system could also be made using a bit of sailtrack and a thumbscrew to withdraw the intake when not in use.
Cheers!
Woylie
Posted: Sun Jun 04, 2017 7:28 am
by Wouter
Got the forward boxes sprayed over weekend. Happy with how it came out.
Posted: Sun Jun 04, 2017 9:01 am
by BarraMan
That is a very nice build - continue!
Posted: Sun Jun 04, 2017 9:53 am
by Jeff
Nice work Wouter!!! Jeff
Posted: Sun Jun 04, 2017 5:37 pm
by willg
Wouter, really nice! You definitely deserve to be happy with that paint job.
Posted: Mon Jun 05, 2017 5:07 am
by Eric1
She just gets better and better!
Posted: Mon Jun 05, 2017 9:01 am
by Fair WX Pilot
Fantastic job, love the attention to detail.
Posted: Thu Jun 08, 2017 9:51 pm
by flyfishingmonk
Wow those rod lockers look amazing!
Casey
Posted: Sun Jun 11, 2017 1:06 pm
by Wouter
Got the rear deck cut and test fitted with cut-outs for the hatches. Did it using the dremmel so I'll be able to use the cut-outs as the hatches.
Posted: Sun Jun 11, 2017 1:21 pm
by flyfishingmonk
Nice! Looking good.
Casey
Posted: Sun Jun 11, 2017 3:56 pm
by Jeff
Wouter, really nice progress!!! Jeff
Posted: Mon Jun 12, 2017 9:39 am
by willg
Looks great!
Posted: Mon Jun 12, 2017 3:26 pm
by cape_fisherman
Probably has been discussed already, but why the asymmetric layout on the rear deck?
Posted: Mon Jun 12, 2017 4:29 pm
by Wouter
The steering cable and other motor wiring runs along the starboard side above the sole. I've made provision for this with a 110mm pvc pipe. Thats what takes up the space on the starboard side, hence the smaller hatches on that side.
I'll post pics.
Posted: Mon Jun 12, 2017 4:43 pm
by Wouter
I've only fitted this tube over the weekend. It's also the reason why the rear most starboard box hasn't been painted as I still had to fit the tube and finish it off before painting.
Posted: Mon Jun 12, 2017 7:02 pm
by glossieblack
Lovely clean work.
Posted: Mon Jun 12, 2017 9:31 pm
by Eric1
I agree, Very clean and well thought out.
Posted: Tue Jun 20, 2017 3:39 pm
by Wouter
Testing the fit of the reed switches I plan on putting in on the lip of the hatch construction. Encapsulated with epoxy. The 10mm magnet will go in the hatch lid. These will switch on the hatch lights when the lid is lifted.
Posted: Tue Jun 20, 2017 3:44 pm
by Jeff
Really nice touch Wouter!!! Jeff
Posted: Tue Jun 20, 2017 3:54 pm
by cape man
Too slick!
Posted: Tue Jun 20, 2017 5:25 pm
by Eric1
That's just Dang Sexy!!
Posted: Tue Jun 20, 2017 8:03 pm
by cape man
Yeah you don't get that on a store-bought POS!
Posted: Tue Jun 20, 2017 8:43 pm
by Aripeka Angler
Great idea with the hatch switches Wouter! Very nice looking work!
Posted: Tue Jun 20, 2017 10:58 pm
by Dutch1
Nice touch with the reed switch on the hatch covers! I just went through your entire build thread and have to say you do some clean work. Great job!
Posted: Wed Jun 21, 2017 2:59 am
by Wouter
Thanx all!! Your comments are much appreciated!!
Posted: Wed Jun 21, 2017 6:27 am
by blueflood
Hi Wouter....nice detailing
Looking back at your build, you sure put an awful lot of thought in the functional design
And the execution is top notch !
Marc
Posted: Wed Jun 21, 2017 11:57 am
by TomW1
Top notch build Wouter! You sure have put a lot of thought into every step of the way.
Posted: Thu Jun 22, 2017 11:15 pm
by willg
Sweet! And yes, a very nice touch.
Posted: Fri Jun 23, 2017 4:19 am
by glossieblack
blueflood wrote: ↑Wed Jun 21, 2017 6:27 am
Marc
One detail precise master builder saluting another.
Posted: Fri Jun 23, 2017 4:22 am
by Wouter
Thanx everyone, your kind words are much appreciated!
Looking forward to the weekend so I can get on with it!!
Posted: Fri Jun 23, 2017 5:57 am
by cape man
We too are looking forward to it. Build on.
Posted: Sat Jun 24, 2017 4:48 am
by Wouter
Got the 6mm spacer frames done. Made the inside corners round, just think it looks better
A close up of the corner.
The 9mm frames getting put together. Used some scrap wood and taped wax paper on it. Used panel pins to keep it in place, square and flat. I made corner pieces out of a 110mm pvc pipe and filled with epoxy.
Posted: Sat Jun 24, 2017 5:21 am
by glossieblack
Wouter, you're treating us to an unfolding master class of beautiful detailing and execution. Thank you.
Posted: Sat Jun 24, 2017 8:35 am
by cape man
Nice trick with the inside corners. Going to log that one in the memory bank.
Posted: Sat Jun 24, 2017 9:42 am
by Jeff
Wouter, really nice work!! Like Cape Man said, nice tip on the inside corners!!! Jeff
Posted: Sat Jun 24, 2017 9:46 am
by Eric1
Pretty cool
Posted: Sat Jun 24, 2017 4:42 pm
by TomW1
Wouter what an excellent idea with your cutout of the corners. Your making the rest of us look like pikers. Will definitely put this away in the brain cells. You are all set up to use that radius for the corners of the bait tank.
Well done!
Posted: Sun Jun 25, 2017 1:28 pm
by Wouter
I've tried and failed several times to make the ends of my rod tubes in pvc pipe. (as seen done by others on this forum)
But I finally got it figured out and done correctly today.
I started of by using various random items that was lying around, expl. A shower head (as used by other forum builders) but I could just never get the pvc to bend back on itself. I could get it flared but it would split and gave me a shabby finish.
After talking about it with a friend he suggested I send his brother a sketch of the mold/tool I would require (he runs his own machine shop), so I did, and he made me a polished steel mold/tool. (as in the picture, for free, even better)
It stil took me several tries to get it right!!! For those who want to do the same, here's some tips!
1. Make sure the edge is square and has no chips from the cutting, even the smallest chip will cause the pvc to split open when you are applying heat and pressure.
2. Heat the fitting and NOT the PVC pipe. (I used a heat gun). When I heated the pvc it tended to bend irrigularly, I think it's because some areas just get softer then others.
3. Put some Vaseline on the inside of the pipe, this helps a lot!
4. When pushing the pipe over the fitting, keep turning it. Make sure it is straight and square.
5. When you get it to the final position, keep it there until the pvc hardens. (when I lifted it up to early the plastic just unfolded)
6. I used water in a spray bottle to cool the pvc, this worked well.
I hope that helps!
Posted: Sun Jun 25, 2017 3:45 pm
by cape man
Too slick.
Posted: Sun Jun 25, 2017 4:00 pm
by willg
Wouter wrote: ↑Sun Jun 25, 2017 1:28 pm
Yep, I'd say you've got it figured out alright. That bank of rod holders will look nice.
Posted: Sun Jun 25, 2017 5:27 pm
by TomW1
Your amazing in how you come up with the solution to a problem.
Posted: Mon Jun 26, 2017 2:08 pm
by flyfishingmonk
Wow! Super nice. Very impressed!
Casey
Posted: Mon Jun 26, 2017 4:11 pm
by cape man
I was a Peace Corps volunteer in Tunisia in the mid 80's. Worked at a marine hatchery. LOTS of pvc plumbing, but VERY few fittings. Made elbows, caps, and couplings using an open fire and patience, but nothing ever, ever, ever came out pretty like that! Still find myself trying to make stuff out of a piece of pipe at home and work, and will definitely try the "heat the metal, not the pipe" trick.
Posted: Mon Jun 26, 2017 5:18 pm
by flyfishingmonk
This is a work of art. It should be in a shadow box on the mantel. - Casey
Posted: Wed Jul 05, 2017 4:43 pm
by Wouter
Got the grooves routered into the hatch lid construction where the rubber seal will go. Also got all the the rod tubes finished. Hopefully by the weekend I'll have some more pics to show.
Posted: Wed Jul 05, 2017 7:26 pm
by Jeff
Really nice Wouter!! Jeff
Posted: Fri Jul 07, 2017 12:03 pm
by Wouter
Got my trailer back, all registered etc!!
Casting the reed switches in epoxy.
Sneak peak at the rod tubes from the front.
Posted: Fri Jul 07, 2017 3:45 pm
by Wouter
Port side rod tubes fitted.
I like it
Posted: Fri Jul 07, 2017 3:52 pm
by Eric1
Me Too!
Posted: Tue Jul 11, 2017 6:16 am
by Wouter
Port and starboard 'bazookas' in place. Originally the plan was just to warm the 40mm pvc up, bend them and run them all the way to the front. But I was just not able to get the pvc to bend nicely, it kept buckling on me. So I eventually gave up and found an alternative more flexible tube. Cut the white pvc fittings shorter and then glued them into place. The black tube slides snuggly over the 40mm and I flared the edge (at the end of the white pvc) using a dremmel to make sure there aren't any edges.
Posted: Tue Jul 11, 2017 7:48 am
by Jeff
Wouter, very nice!! Your build is pure quality!! Jeff
Posted: Tue Jul 11, 2017 5:27 pm
by Wouter
Tubes now done. After changing the tube diameter (not using the 40mm pvc al the way through) I had to make the port side holes a little bigger. Drilled the starboard side the correct size, but now it's not as symetrical as I would like. But it will be under the deck so I won't see it
Posted: Tue Jul 11, 2017 9:07 pm
by cape man
No you won't
Posted: Fri Jul 14, 2017 12:29 pm
by LGF
Been a while since my last visit and Wouter you sure kept up your quality Bud. Impressive work you done!
Just one thing, glad to see you went the "reed switch" route on your hatch lights and not the mechanical route that I followed, however, knowing from previous experiences, these kinds of electronics doesn't last as long as one would hope they'll do, thus failing at some point you'll need to replace them. Although placing them in the recess and filling that with rein will hide them once painted and will look super, perhaps you should give it a thought to rather install them on the underside of the hatch lip/end and install larger rare-earth (neodymium) magnets in the lids? They are wat stronger that ordinary magnets and will surely be able to operate the reed switches. That way if a switch does continue on to the afterlife you can easily roplace it without having to cut remove, re-resin, sand and re-paint.
Just a thought.
Posted: Sat Jul 15, 2017 12:53 pm
by Wouter
You have a valid point LGF. It's already done, cast in 'epoxy'!
These switches supposedly have a life time of 50 000 cycles, so we will see how long they last. I do have other silindrical ones which I can fit should the need arise. (without to much fuss, just drill a hole)
Lid edges glued in.
Posted: Sat Jul 15, 2017 3:13 pm
by cape man
Just plain awesome!
Posted: Sat Jul 15, 2017 3:38 pm
by Jeff
Agree!!! Jeff
Posted: Sun Jul 16, 2017 7:33 am
by Wouter
Busy making the supports for the hatch lids.
Posted: Sun Jul 16, 2017 8:26 am
by gonandkarl
I really like your exact and beautiful work on your boat. Every picture you post shows me how detailed and perfect one can work. Keep up the beautiful work and show us always all the details in pictures from which I at least am learning a lot.
Posted: Sun Jul 16, 2017 11:29 am
by Browndog
Beautiful work!
Posted: Sun Jul 23, 2017 11:34 am
by Wouter
Rear hatch lids bottom supports done and epoxied.
Posted: Sun Jul 23, 2017 9:20 pm
by MarkOrge
Beautiful work, nice !
Posted: Mon Jul 24, 2017 6:26 am
by cape man
Those will stiffen it up! Pretty too.
Posted: Mon Jul 24, 2017 7:37 am
by Wouter
For sure! Amazing what a few strategic pieces of wood can do for the stiffness!!
Still got to put on one more coat of epoxy, then some fairing compound, some sanding and then it'll get sprayed.
Should look nice and clean when done!
Posted: Mon Aug 07, 2017 3:22 pm
by Wouter
Posted: Mon Aug 07, 2017 4:33 pm
by pee wee
Your attention to detail is impressing. Nobody is going to believe that's a home made boat!
Posted: Mon Aug 07, 2017 5:48 pm
by Jeff
Wouter, Really nice work!! Jeff
Posted: Mon Aug 07, 2017 7:03 pm
by blueflood
Hi Wouter, looking darn sharp. Like the guys say... beautiful craftsmanship
Marc
Posted: Tue Aug 08, 2017 10:50 am
by flyfishingmonk
Looking great!
Posted: Sat Sep 02, 2017 4:51 pm
by Wouter
Got a three bank Minn Kota DC alternator charger for my batteries, should put in a few amps while driving during the day.
Seems like it is new technology, anybody using it..?
Certainly no one around here has seen or heard of it!
Posted: Sat Sep 02, 2017 6:39 pm
by BarraMan
I have a similar setup - not Minn Kota but the same principle. When up and running on the big motor, it's alternator charges:
1) the start battery
2) the house battery
3) the trolling motor batteries (three of=36v)
In that order.
Very clever - works well.
Posted: Sat Sep 02, 2017 7:06 pm
by glossieblack
Is this a smart regulator rather than alternator?
Posted: Sat Sep 02, 2017 9:22 pm
by Browndog
I've got a Stealth 1 Battery Charger on my flats skiff and it works with the motor's alternator or as an AC shore power battery charger. Works great. Will be installing an onboard battery charger on my brother's boat too. Mighty handy to have.
Posted: Sat Sep 02, 2017 9:55 pm
by cape man
I'm confused. How is that any better than my outboard charging batteries when running? If I have my switch set at "all", both batteries are getting charged by the engine while running. Can charge them at home the same way with a normal charger.
Posted: Sun Sep 03, 2017 3:04 am
by Wouter
BarraMan. That's exactly my plan. Have a dedicated and separate cranking battery, then a house battery for the electronics and two series connected deep cycles (24v) for the the trolling motor.
Glossieblack it's a DC charger that uses the outboards alternator as input and then has three 10amp banks to charge individual batteries with smart charge algorithms.
Capeman. The issue is the 24v or 36v batteries for the trolling motor. You can't connect them straight to the alternator, you'll get feedback to your other systems and blow them out. If you only have two 12v batteries then the alternator should be sufficient.
Posted: Sun Sep 03, 2017 4:24 am
by BarraMan
If you spend a lot of time on a trolling motor with electronics etc running then you should ideally protect your crank battery - else you may find you don't have enough electrons left to get a start. A couple of voltage sensitive relays will ensure that the crank battery is the first to get a top up from the big motor, followed by the house battery, and then the trolling motor battery. Pretty straight forward if your trolling motor is 12 V but is more complicated if it's 24v or 36 v.
I'm now running a lead acid crank battery, two 120 ah AGM batteries in parallel running the electronics and 3 x 120 ah AGM batteries connected in series for the trolling motor. A 12 V to 36 V DC charger takes care of the latter.
Posted: Sun Sep 03, 2017 5:06 am
by glossieblack
If I'm not mistaken, Wouter's unit is technically a regulator, in that it receives charge generated by the motor and distributes it. And it is a smart regulator, because it can distribute charge in a way that can be programed - e.g. it first charges a 12V stater battery, then a 24V house battery bank, the then a 48V trolling motor bank. Smart regulators also optimise charge rate and the state of a battery bank, and tail of the charge rate as the battery is approaching full charge. This increases battery life.
I've been running a dedicated smart regulator on my cruising yacht for over a decade, without having to replace a single battery in two battery banks, and we've cruised at least 3-4 months each year. The dealer who sold me the batteries is surprised at their longevity. I put it down to the smart regulator.
Posted: Sun Sep 03, 2017 6:34 am
by cape man
Thanks. That makes sense.
Posted: Sun Sep 03, 2017 8:49 am
by Wouter
Jips, that makes sense.
Busy mounting it today
Posted: Thu Sep 14, 2017 5:55 am
by Wouter
Posted: Thu Sep 14, 2017 6:38 am
by glossieblack
Wouter wrote: ↑Sun Sep 03, 2017 8:49 am
Wouter, what does jips mean?
Your PH18 looks stunning, and looks the part on her trailer.
Posted: Thu Sep 14, 2017 6:59 am
by Wouter
Thanks!
Jips = Yes
It is a slang term used in my home language of Afrikaans.
Posted: Thu Sep 14, 2017 8:30 am
by cape man
That is one aggressive looking boat and trailer! Beautiful job!
Posted: Sun Sep 17, 2017 10:02 am
by Wouter
Posted: Sun Sep 17, 2017 10:05 am
by Wouter
Posted the same Pic twice
here's the one I wanted to post.
Posted: Sun Sep 17, 2017 10:45 am
by Wouter
Posted: Sun Sep 17, 2017 2:04 pm
by Eric1
Those look fantastic!
Posted: Sun Sep 17, 2017 4:07 pm
by Jeff
As always Wouter, look great!! Nice work!! Jeff
Posted: Sun Sep 17, 2017 5:54 pm
by cape man
Beautiful work as expected. Go man, go.
Posted: Fri Oct 06, 2017 3:43 pm
by Wouter
Test fitting the rough cut deck pieces!
Got a few hatches to build!!
I need some advice!
I probably need to join the deck pieces together before cutting the hatches out. But I'm not sure how to do it, as I need a flush surface on the inside and the outside. Any ideas..?
Posted: Fri Oct 06, 2017 4:29 pm
by joe2700
Wouter wrote: ↑Fri Oct 06, 2017 3:43 pm
You could scarf them together with epoxy if you need a flush surface. You could also do a butt joint with fiberglass tape like most of the joints on these boats, but it won't be flush if you don't remove the thickness of the fiberglass tape from both sides before joining them. I think flush is easier to achieve with a scarf personally.
Posted: Fri Oct 06, 2017 5:03 pm
by pee wee
Why can't you cut out the hatches before joining the panels? Seems like it would work . . .
Posted: Fri Oct 06, 2017 5:15 pm
by Wouter
Thanx Joe, you have put me on the right track.
Peewee. I could. But as I'm using the cut outs for the lids I'm not sure I'll get it all to line up perfectly.
Posted: Fri Oct 06, 2017 6:25 pm
by glossieblack
A few temporary tabs between hatch positions, then sand them off when you're done?
Posted: Wed Nov 08, 2017 1:58 am
by Wouter
Ive been tinckering a bit with a few things.
Did a test spray job with flakes on the fiberglass console I bought way back (don't think I'm going to use it). Used the same red base coat but with different primers, made for a big difference in the overall colour of the red. Then sprayed silver holographic flakes on the top and and gold flakes on the sides. Im still not sure which I will use , but it was a fun exercise. The holographic flakes look awesome in the sun!!
Ive made a prototype of a more sqaure/boxy looking console from hardboard. I do like the fact that there is lots more space compared to a fancy rounded console. I have plenty of switches and gadgets that will need to be fitted, so space is an issue. I'm also thinking that I can make a hatch on the front side of the console for easy acces to my electrical and wiring setup. That will be a bonus.
I'm still planning a slightly raised box around the fishfinder (that'll hold those loose lures etc) and a small perspex screen in front of the ff
Posted: Wed Nov 08, 2017 10:24 am
by tcason
Verify the distance between the seat and steering wheel - it looks to far apart (unless long armed) - but maybe the angle of picture.
love the paint!
Posted: Wed Nov 08, 2017 11:23 am
by Wouter
Thanx.
I'm fitting hydrolic steering so the steering wheel and fittings extends quite a bit towards the seat.
When seated I can stil easily reach the fish finder.
I'm also 6'8 so need some leg room
Posted: Wed Nov 22, 2017 7:59 am
by Wouter
After some deliberation and a couple of hours thought, I've decided to ditch the sqaure console and now planning a more rounded one. Going to take more time , but I'm sure it will be worth it!
More inline with the one Bassmunn used on his PH16
Posted: Wed Nov 22, 2017 5:14 pm
by peter-curacao
Wouter wrote: ↑Wed Nov 22, 2017 7:59 am
Don't know if you value my opinion but IMHO you made the right choice
Looks way better
Posted: Thu Nov 23, 2017 1:06 am
by flyfishingmonk
Agreed. Round will look great!
Casey
Posted: Thu Nov 23, 2017 1:54 am
by Wouter
As a Master builder Peter, your input is always greatly appreciated!
Agreed Casey!
CL always says when in doubt step back, but in this case I sat in the seat and drank a few beers!
So the new plan is to drop the seat height, I felt I was sitting to high and that in turn requires the console to be higher so I can get underneath. However it makes the console look out of place and just didn't fit in. So I grinded out the cleats for the seat and dropped the forward support, this will drop the seat by 15cm and already feels a lot better!
With the seat lower I need some more leg room to get my knees further down, so I have cut the forward cockpit bulkhead out to create extra space for my legs. It makes a huge difference in the way that I'm able to sit and is tons more comfortable. Only problem is I've run my under floor trunking to short for this move, so will have to cut the floor open and extend the trunking forward otherwise it will just get in the way. Lots of extra work, but so far I'm glad I've taken the plunge!
I'm super happy I made a cheap prototype console, put me on the right track, thankfully
Posted: Thu Nov 23, 2017 9:50 am
by pee wee
I like what you are doing and the decision to make the changes at this stage, even though it means more work and time. I agree that the more rounded console looks much better, too.
Posted: Fri Nov 24, 2017 1:56 am
by Wouter
So far so good, the demolition isn't too bad. It's definately not pretty and cutting open your floor is a bit gut wrenching. But I think I can do it without hindering the structural soundness of the boat/bulkhead. I should be able to just drill three holes in the bulkhead and place the extention tubes through. Also going to make a lip for the insert piece to fit on. Getting the foam out is a slow process, small pieces at a time but not difficult.
The seats are much better now, beeing lowered, doesn't feel like I'm sitting on top of the boat any more
but rather inside!
Still happy with my decision to go this route
Posted: Fri Nov 24, 2017 2:00 am
No point in building a custom boat if you do not build it to suit you
Your boat is really looking good. I am enjoying watching your build.
Posted: Sat Nov 25, 2017 3:56 pm
by Wouter
Got the tubes extended. Glued in some support pieces for the insert to sit on, will post a Pic of that tomorrow.
Posted: Sat Nov 25, 2017 11:38 pm
by flyfishingmonk
Looking good!
Casey
Posted: Sat Dec 02, 2017 1:03 pm
by Wouter
Re-foamed the cut out, ready to glue in the insert.
Posted: Sat Dec 02, 2017 4:59 pm
by peter-curacao
Wouter wrote: ↑Sat Dec 02, 2017 1:03 pm
Very, VERY nicely done!
Posted: Sun Dec 03, 2017 10:00 am
by Dougster
What Peter said. How did you get that foam so smooth? Doesn't look sanded.
Posted: Sun Dec 03, 2017 11:48 am
by Wouter
Insert glued into place, a bit of sanding and a layer of fiberglass, some fairing and once painted no one will be the wiser.
Dougster, I did sand the foam with a mouse sander. Makes a mess but gave a good result.
Posted: Sun Dec 03, 2017 5:49 pm
by Fair WX Pilot
Lovely insert repair, it doesn’t get any neater than that. Considering the amount of changes your making, you’re getting them done very quickly. Looks great.
Posted: Sun Dec 03, 2017 8:50 pm
by cape man
What cut out?
Posted: Sun Dec 10, 2017 4:16 pm
by Wouter
Made some progress on the console prototype v2.0
Needed a beer to size things up and get a feel for it
Posted: Sun Dec 10, 2017 4:34 pm
by peter-curacao
Yes sir imo you are on the right way with the console
Posted: Sun Dec 10, 2017 5:27 pm
by Jeff
I like the console Wouter!! Right size!! Jeff
Posted: Wed Dec 27, 2017 1:37 pm
by Wouter
The console is slowly taking shape.
Took some time to get everything to fit correctly!
Got it glued into place, now the challenge of fitting the multiple pieces to create the curves.
Lots of little other things done, seat benches almost done,soon to be glassed in place.
Posted: Wed Dec 27, 2017 4:37 pm
by poleposition
[quote
[/quote]
Not jumping on the Windhoeks?
Posted: Wed Dec 27, 2017 4:58 pm
by TomW1
That looks great
Posted: Wed Dec 27, 2017 10:20 pm
poleposition wrote: ↑Wed Dec 27, 2017 4:37 pm
[quote
[/quote]
Dang you make that boat like it is only about 12 feet long
Posted: Thu Dec 28, 2017 6:33 am
by Wouter
Posted: Thu Dec 28, 2017 7:41 am
by Browndog
Looking good.
Now that I’m wiring things up and installing things in the console of the boat I’m building do I appreciate good design and access to the underside and interior for those tasks.
Your boat build has always been an inspiration to me of how to do it right, especially since you are in an area where you can’t get parts so easily or as inexpensively as some of us. Your ingenuity, and that of the other builders on the forum, is really fun to watch and try to emulate.
Keep it up!
Posted: Thu Dec 28, 2017 8:03 am
by Jeff
As always, very nice work Wouter!! Jeff
Posted: Mon Jan 01, 2018 4:52 am
by Wouter
Starting to look like something!
Happy new year everyone!
Posted: Mon Jan 01, 2018 9:01 am
by Jeff
Nice Wouter!!! Jeff
Posted: Mon Jan 01, 2018 12:40 pm
by TomW1
Very nice, slat work like that is difficult and time consuming.
Posted: Fri Jan 05, 2018 10:17 am
by Wouter
Slats on both sides done with a round of fairing worked in. Came out good!
Still have some finishing work to do!
Posted: Fri Jan 05, 2018 10:19 am
by Wouter
Also got started on the forward deck hatches.
Posted: Fri Jan 05, 2018 10:35 am
by glossieblack
Posted: Fri Jan 05, 2018 11:22 am
by pee wee
I really like the way it is turning out, too. I see a sharp corner at the bottom front, doubt you're going to leave it that way. It'll be interesting to see what you come up with, amazing build so far.
Posted: Fri Jan 05, 2018 11:51 am
by Wouter
Thanks Hank.
Yes, you are correct, I'll be putting in a support, something like this.
I kept the bottom straight and flat to make it easier to build the console. Easier to have a stable platform to work with and then cut away what you don't need, at least that was my thinking
Posted: Fri Jan 05, 2018 12:37 pm
by Jaysen
very good thinking in my opinion.
Posted: Fri Jan 05, 2018 1:20 pm
by Jeff
As always, very well done Wouter!!!! Jeff
Posted: Fri Jan 05, 2018 7:40 pm
by cvincent
I love the custom console. Nice work Wouter!
Posted: Fri Feb 16, 2018 7:16 am
by Wouter
Slowly making progress on the console. Been working on the switch panels, making them out of 2mm aliminuim sheet. Needle filing them to fit the switches tightly. Also gotten myself a airbrush kit, so playing around with that a bit lately, likely to painted the switch panels in a carbon pattern, but we'll still see
I've added two digital Volt meters to the console that will be attached to the trolling motor and house batteries. Should help too keep an eye on them.
Posted: Fri Feb 16, 2018 8:06 am
by Jeff
Nice console Wouter!!! Jeff
Posted: Fri Feb 16, 2018 11:13 am
by terrulian
What's a "carbon pattern?"
Posted: Fri Feb 16, 2018 12:55 pm
by Wouter
Something in line with these, still playing around with it
Posted: Thu Feb 22, 2018 2:10 am
by Wouter
Pushed the boat out and cleaned it for a change.
almost done with the forward hatches,still a bit of sanding and epoxy coating to go before I paint them. Thinking I'm going to keep the rod lockers inside clear epoxy (not paint them) will see when I get there. Still need to do the cut out for the trolling motor. The mold for the insert is in the making.
Here's a few pics!
The console also seems to be proportionally correct, or at least it feels like it to me
Posted: Thu Feb 22, 2018 3:57 am
That is one fine looking boat right there
I bet you are getting pumped for the launch.
Posted: Thu Feb 22, 2018 5:23 am
by OrangeQuest
It is a good looking boat!
Posted: Thu Feb 22, 2018 7:57 am
by Jeff
Well done Wouter!!! Jeff
Posted: Thu Mar 08, 2018 5:09 pm
by MarkOrge
She is looking great !
Posted: Fri Mar 09, 2018 1:35 am
by Redfish81
Wow, you do some great work.
if you are willing to fly economy class i think I could hide the costs of flying you over to help me when I start my build. I will just tell the girlfriend I needed more sandpaper than I thought.
Posted: Fri Mar 09, 2018 5:46 pm
by TomW1
Wow a really nice looking PH18. Between you and Flyfishingmonk future builders are going to have some high standards to reach for.
Posted: Wed Mar 14, 2018 3:27 am
by Wouter
Thank you all for the kind words! It keeps me motivated!
Steering wheel mounting is now done! Using a hydrolic steering system.
Also busy making a fuse box board that will fit under the console, will post some pics of that soon.
Posted: Fri Mar 16, 2018 2:23 pm
by peter-curacao
Ubercool
Posted: Mon Apr 02, 2018 4:55 pm
by BassMunn
Wouter wrote: ↑Wed Mar 14, 2018 3:27 am
Haven't been on here for a while
Nice looking boat you have built so far.
A suggestion - check the height of your steering wheel when you are sitting on the full height seat, mine was too low and I had to put a wedge under it to lift it away from my knees, your console looks higher than mine so might not be a problem.
Good luck!
Posted: Mon Apr 02, 2018 5:54 pm
by Wouter
BassMunn,
I feel privalaged for you to comment on my feed!! Before I started building my boat I followed your feed religiously!
Got all your picks saved in a file and have been using them as reference throughout my build! Thank you!!
I agree with you, I did spend a lot of time in the seat and was glad I did a 'mock up' of the sqaure console I thought would work. But I'm very happy with the current console (actually think it's awesome, glad I spent the extra time to build it, worth every minute), having moved the bulkhead forward at my feet the positioning of everything seems much better! I also feel more comfortable in the seat!
What was the height of the sole to your seat.?
Do you still have your own PH16..?
Posted: Tue Apr 03, 2018 4:59 pm
by Wouter
The fuse box panel is done under the console, it will swing down so I have easy access.
Finished spray painting the hatches.
Here's the bottom of the rod lockers, going to leave the centre pieces as is, so that you can see the wood.
Also finished the rear but end of the rod lockers, made the bud rest out of perspex.
Re: Wouter's PH18 Namibia
Posted: Tue Apr 03, 2018 7:11 pm
by Jeff
Really nice work Wouter!! Jeff
Posted: Tue Apr 03, 2018 8:19 pm
by MarkOrge
Beautiful work, I love the console !
... makes me want to start another boat ....
Posted: Thu Apr 05, 2018 11:21 am
by Eric1
Fantastic Build!
Posted: Thu Apr 05, 2018 11:44 am
by terrulian
Great work. I really like the idea on the hatches. It adds quite a bit of elegance to open what appears to be a utilitarian hatch and find some beautiful varnished wood.
Posted: Thu Apr 05, 2018 12:51 pm
by OrangeQuest
terrulian wrote: ↑Thu Apr 05, 2018 11:44 am
Yes it does! Great idea !!
Posted: Fri Apr 06, 2018 5:05 am
by Wouter
Wiring board is done. Using two (10x) fuse boxes and a negative buss bar. Also added a main on-off switch.
Also been busy on the live well, made some deviders, should work well for our multi specie competitions.
Posted: Fri Apr 06, 2018 5:19 am
by glossieblack
Very nice work.
Posted: Fri Apr 06, 2018 7:31 am
by Browndog
Looking good!
Posted: Thu Apr 26, 2018 3:11 pm
by Wouter
Finished the plumbing and most of the wiring for the pumps and Led lights in each hatch.
Glued the rear deck in place and connected the led hatch lights, think we'll have enough light in each box
Posted: Thu Apr 26, 2018 3:13 pm
by cape man
Awesome!
Posted: Thu Apr 26, 2018 3:15 pm
by Wouter
Got the inside of the rod locker hatch lids polished. Looks really good. Need to take some pics in the sun!
Posted: Fri Apr 27, 2018 2:49 pm
Wouter those are some fine looking lids. You really do need to take some pictures in the sun to show them off.
Posted: Sat Apr 28, 2018 2:49 am
by gonandkarl
You are making a beautiful work boat I am excited whenever I see your new pictures of it. One question is the lighting in the hatches for looking good or is there some other reason for it ? Forgive me the question but I have not a clue about fishing.
Posted: Sat Apr 28, 2018 2:59 am
by Wouter
Hi, they are functional as well. We often rig and get ready in the dark, which is always a hasttle with head lamps/torches etc. So now we'll be able to see clearly in the hatches.
Posted: Sat Apr 28, 2018 6:07 am
by OrangeQuest
Fuzz wrote: ↑Fri Apr 27, 2018 2:49 pm
Great build and agree on more hatch pictures!
Posted: Sat Apr 28, 2018 9:36 am
by Jeff
Posted: Sat Apr 28, 2018 10:08 am
by Wouter
Posted: Sun Apr 29, 2018 8:28 am
by Fair WX Pilot
Looks amazing, a truly custom finish.
Posted: Thu May 10, 2018 12:28 pm
by Wouter
Finished the mold for the trolling motor foot pedal recess box.
All sanded smooth, polished and release agent applied.
Gel coat and fiberglass applied. Hoping it releases without drama!
Posted: Thu May 10, 2018 1:41 pm
by Jeff
Wouter, always very nice work!! Jeff
Posted: Mon May 14, 2018 4:33 pm
by Wouter
Foot pedal recess in its place.
Posted: Tue May 15, 2018 6:34 am
by cape man
Slick! Love the layout.
Posted: Tue May 15, 2018 8:44 am
by cvincent
Your build is progressing very well. I love the custom touches to the hatches.
Posted: Tue May 15, 2018 9:00 am
by Capt UB
twin 300?
Posted: Tue May 15, 2018 11:41 pm
by TomW1
Boat is looking better and better can't wait till your ready to launch. If you want I would be happy to try to calculate a prop for her when your ready and you have made so many adjustments from a standard PH. Keep on building, we are all waiting for you launch.
Posted: Wed May 16, 2018 1:21 am
by flyfishingmonk
This boat is looking amazing!
Posted: Fri May 18, 2018 4:43 pm
by Wouter
Thanx Tom for the offer on the prop.
I had a choice when I ordered the machine and chose a 24p three blade stainless. I'll start with that and see what happens.
What info do you need to calculate the prop..? Maybe I could give you some info already..?
Posted: Fri May 18, 2018 4:48 pm
by Wouter
Carpeted the floors of the rod lockers, fitted the paddle and rear nav light fittings for safe keeping in the lockers.
Prepared for glueing the forward deck on tomorrow.
Posted: Fri May 18, 2018 10:35 pm
by willg
Wouter, those lockers are really nice!
Posted: Sat May 19, 2018 5:35 am
by OrangeQuest
Always exciting to see pictures of your craftsmanship! Looks well thought out.
Posted: Sat May 19, 2018 6:10 pm
by TomW1
Wouter wrote: ↑Fri May 18, 2018 4:43 pm
Wouter the important number is the weight of the boat as she leaves the dock. Hull, gear, passengers, gas tank, gas @ 6.8lbs per gal, coolers with ice, live wells and water @ 10lbs per gallon, motor weight and other gear which I usually access at 200lbs. This is such things as safety gear electrical wiring and other safety and hardware. I will also need the brand and HP of the motor, I can usually get all of the info on motors from manufacturers specs. What propeller did you buy, brand, diameter, and you said 3 blade.
I think that will do it if I need more I will ask.
Regards
Posted: Sat Jun 02, 2018 11:27 am
by Wouter
Thanx Tom. I'm working on getting all the weights etc for you to do the prop calculations. I'm going to have to give you my best estimates on some though.
Got started on the gunnels!
Posted: Sat Jun 02, 2018 3:06 pm
by TomW1
Estimates are fine we just want to be as close as possible. Look forward to getting your numbers have been playing around with some estimates using different weights and the Yamaha 115:D They look very good.
Posted: Sat Jun 30, 2018 11:48 am
by Wouter
Posted: Sat Jun 30, 2018 12:21 pm
by Wouter
Will,
I've done some calculations on the weight and I think the hull on its own will be around 460kgs = 990lbs
Does this seem to be in the ball park...?
Fuel tank is 145 lt = 320lbs
I'll be fishing 2 up at 100kg per person, 200kg = 440lbs
I'm also fitting a jackplate, manual 6inch offset.
Let's say an additional 150kg for fishing gear etc. = 330lbs
All up 2080lbs. Does that seem like a likely number...?
Posted: Sat Jun 30, 2018 12:58 pm
by TomW1
Wouter that sure does.
I will take with those numbers and work with them. I'll add another 150lbs for cables, wiring, and other miscellaneous hardware that you probably didn't think of.
Posted: Sat Jun 30, 2018 1:05 pm
by Wouter
Thanks Tom!
Much appreciated!!!
Posted: Sat Jun 30, 2018 2:03 pm
by TomW1
Wouter like I said above I had already been playing with some numbers so I just plugged your numbers in and came up with some recommendations. Do you have a preference for a brand of propeller I can be a little more specific. Solas is sold around the world and are pretty economical. Yamaha are pretty expensive. Anyway here is what I came up with final weight 2600 with motor, 3 blade propeller 13 x 16, 4 blade propeller 13 x 14. The 4 blade would be my recommendation as you could raise it higher with your jack plate. It also helps in tracking and in rough weather handling and with the right one it can help with mid range speed and fuel economy and stern lift. Oops forgot to mention top speed should be around 40mph.
Posted: Sat Jun 30, 2018 2:29 pm
by Wouter
As it is my first personal boat, I haven't got any experience with props and the different brands etc. Will need to update myself on the differences.
This is the prop that I got with the motor.
What do you think about this prop..?
Posted: Sat Jun 30, 2018 2:34 pm
by Dougster
Dang, that work with the gunnels is clever and great looking. Hats off to you.
Posted: Sat Jun 30, 2018 2:45 pm
by Wouter
Thanx Dougster!
Posted: Sat Jun 30, 2018 2:54 pm
by TomW1
Wow that is a lot of prop. Way to much for your small boat and motor. I just propped a 200hp 20ft boat with a 14 x 21 propeller. You will never see rpms much over 2000 with it and I may be generous. Do not put it on your motor it could damage it by causing to low of rpms.. I agree with Dougster that is great work on the gunnels.
Posted: Sat Jun 30, 2018 3:35 pm
by Wouter
Just to make sure, we are talking about the Suzuki DF 150 four-stroke,its the new digital one (2017 model)
Posted: Sat Jun 30, 2018 4:21 pm
by cvincent
I thought you have a DF150 correct? The gunnels look great.
Posted: Sat Jun 30, 2018 7:14 pm
by TomW1
Whoops I just went back and went through Wouters build searching for motor info and there he was standing in front of a beautiful brand new Suzuki motor in its crate. So Wouter forget what I have said before just confirm that it is a 150HP. I will redo the calcs tonight so you will have them in the morning. My fault I forgot to confirm your motor brand and size.
Posted: Sat Jun 30, 2018 7:24 pm
by Capt UB
TomW1 wrote: ↑Sat Jun 30, 2018 7:14 pm
I have him with a Yamaha 115, let me know if I am wrong Wouter and I will recalculate.
Jumping in here... Sorry Wouter.
Tom, do you know/have the math for distance from the transom to the prop, to set cav. plate height above bottom of boat? I'm not finding it, I know it's used.
Thanks, Bob.
Posted: Sat Jun 30, 2018 7:29 pm
by TomW1
Bob let's take this to your site and ask me there.
Posted: Sat Jun 30, 2018 8:01 pm
by TomW1
Ok Wouter here goes for a Suzuki 150.
For a 3 blade prop like you have I show a 16.25 x 21 Is what I show. So throw that blade on and see what the maximum rpms you get and let me know. We will know from that how much to adjust for. For a 4 blade I show a 15.75 x 19 to be good. Again all the reasons for a four blade apply. I don't remember if I mentioned that you can raise it higher with your jack plate.
Again sorry for the confusion.
Posted: Sun Jul 01, 2018 1:58 am
by Wouter
Morning Tom.
Yes, I can confirm I have the Suzuki DF 150
I'm super happy with your calculations, thank you!! I'm a firm believer in maths and working things out. Not a fan of the 'local knowledge' who spits out - I think you should use.... - and if you ask them for their reasoning they just waffle about.
I'm gonna start with the prop I have and then we can see how it performs and then take it from there and make adjustments. I do think that it is still a bit much prop for the setup (as your calculations have shown) but since I have it it'll give us a starting point.
Posted: Sun Jul 01, 2018 4:04 am
by antoniekruger
Hi Wouter,
I've browsed your build since my last visit - seems yonks ago. That is great work, bud. Wow. You seem quite close at the rate you're going. Great inspiration and well thought out. When I see the detail you build in I cringe at the thought of getting glass in, finished and painted and you make it seem simple. Well done.
Posted: Sun Jul 01, 2018 1:31 pm
by TomW1
Wouter, I forgot to mention in my last post that your speed will be in the mid 40's now and your weight goes up to 4740 now. If you have not thought of moving some weight forward I would do so.
Regards
Posted: Sun Jul 01, 2018 5:58 pm
by cape man
Love the gunwales. So how are you sealing the underside of the balsa?
Posted: Sun Jul 01, 2018 11:20 pm
by Wouter
With a coat of epoxy before glueing it place (all done wet on wet). Surprisingly it gives the balsa a lot of strength. It turns out to be a very sandable structure. Still going to add 2 layers of fg.
Posted: Mon Jul 02, 2018 9:03 am
by pee wee
That is slick looking! Thanks for sharing the ideas you've come up with, they're inspiring.
Posted: Mon Jul 02, 2018 11:41 am
by Eric1
Sexy Beast! All that to go harpooning hippos!!!
Posted: Mon Jul 02, 2018 12:36 pm
by Wouter
Lol, I would rather give the hippos a miss
Posted: Sun Jul 15, 2018 1:43 pm
by Wouter
Been at it this weekend. Got the rear gunnel portions glassed and faired. Came out great!
Always keep hydrated
Got started with the forward sections, 1st glued down the supports.
Then glued the side panels in place. I've routered a groove on the inside, fitted strip led lights and filled it with clear casting resin.
A close up of the structure. Glued a backing piece on behind the led lights, fileted and fg the bottom corner.
A close up of the led lights. I've taped up the clear epoxy, once painted I'll pull off the tape and it'll get a few clear coats. Should work
Definitely going to give a lot of light!
Posted: Sun Jul 15, 2018 2:07 pm
by Jeff
Posted: Mon Jul 16, 2018 4:10 am
by antoniekruger
Hi, flip that looks good - great idea. What glass are you using on the gunnel. Is that 200g/m2 woven?
Posted: Mon Jul 16, 2018 5:10 am
by Wouter
That's correct, I used 200g woven and then s-fair 600 for the fairing.
Posted: Mon Jul 16, 2018 5:11 am
by cape man
Oh Hell yes! She's going to be a space ship!
Posted: Mon Jul 16, 2018 6:03 am
by Wouter
Lol! Sure is, plenty lights on board
Posted: Mon Jul 16, 2018 9:15 am
by pee wee
Love the creativity, that's looking great!
Posted: Tue Jul 17, 2018 8:28 pm
by BarraMan
TomW1 wrote: ↑Sun Jul 01, 2018 1:31 pm
Regards
4740 lbs (2154 kg)?? Is that figure correct Tom? My boat is waaaaaay bigger and only weighs 1900 kg full of fuel, ice and fishing gear!
Posted: Tue Jul 17, 2018 10:05 pm
by TomW1
Barraman your boat weight 4180lbs don't know how much water gas and all you carry or what your normal passenger load is. But Wouter gave me his numbers for his boat and load of everything on it so I went with what he gave me. He is adding a lot of features to the base PH18
Posted: Wed Jul 18, 2018 5:50 am
by Wouter
I have a local contact with a weigh bridge. I've weighed the trailer on its own, so once the boat is done I'll weigh it again and get an accurate weight. (I really want to know what she weighs
For the time being I was a tad over conservative with the weights.
Wired and tested the led lights in the gunnel.
Slowly making my way forward with the gunnels. Takes a bit of time to get each piece to fit. Still has a few bumps and gaps but sanding and filling will sort it out.
Boat is a bit messy, seems like I need to clean up a bit
Posted: Wed Jul 18, 2018 6:11 am
by cape man
That deck will be a dance floor!
Posted: Wed Jul 18, 2018 7:52 am
by pee wee
Nobody on earth will have a boat just like yours! Love the lighting technique.
Posted: Wed Jul 18, 2018 7:34 pm
by Eric1
Yep, That is one sharp boat!
Posted: Wed Jul 18, 2018 9:55 pm
by BarraMan
TomW1 wrote: ↑Tue Jul 17, 2018 10:05 pm
Tom, the 4180 lb weight of my boat is with 345L (91 US gal) of fuel (546 lbs), 6 x 120 amp hr batteries (heavy!), 50 lbs of ice, a 112 lb trust 72" Minn Kota Ulterra trolling motor (don't have the weight), and a 500 lb 250 hp Yamaha 4-stroke Vmax SHO outboard. We usually fish with 4 x bloke on board.
4740 lbs just seems rather heavy for an 18' bass style boat to me. There has to be something wrong with that figure. I see the hull as Jacques designed it should come in around 800 lb, so where is the additional 3940 lbs coming from?
Posted: Thu Jul 19, 2018 2:22 am
by TomW1
I think Wouter gave the answer in his post above when he said that he went heavy in the weights he gave me. I am now going to worry about it until he finishes his boat and weighs it.
Posted: Thu Jul 19, 2018 3:30 am
by Wouter
Hi BarraMan/Tom
Here's my spreadsheet with some estimates on weights. What do you think about it..? Anything I left out ..?
PH 18 Estimated Weights
Description: Notes: Weight
Kg Lbs
Hull Bare with fuel Tank (empty) 460.00 1,014.13
Motor Suzuki DF150 232.00 511.47
Fuel 145 Lt Tank 145.00 319.67
2 Persons 2 x 100kg 200.00 440.92
Jackplate 6 inch offset 16.00 35.27
Fishing gear All Tackle 150.00 330.69
Trolling motor (Estimate) 30.00 66.14
Coolbox Drinks + Ice 25.00 55.12
Electronics Charger + Fishfinders 20.00 44.09
Batteries X 4 100.00 220.46
Total 1,378.00 3,037.97
The Livewell takes 140lt but as it will be emty on take-off we'll keep it at zero and it will offset the fuel later in die day.
Posted: Thu Jul 19, 2018 3:31 am
by Wouter
Oeps, the table came out wonky on the post.
Posted: Thu Jul 19, 2018 3:51 am
by Wouter
Posted: Thu Jul 19, 2018 5:07 am
by BarraMan
OK, that’s looking better.
I make 145L of fuel as 145 x 0.72 x 2.2 = 230 lb
I assume you got your o/b weight from the specs. My 250 hp Yamaha is only 20 kg heavier than your 150 Suzi.
150 kg of fishing gear? Seems like a lot to cart around!
Posted: Thu Jul 19, 2018 5:34 am
by Wouter
Thanks for the correction on the fuel
(I just assumed it would be 1:1)
Yes, got the o/b weight online. It is a 100lbs heavier then the DF140 but then the 140 is a 2lt displacement motor and the 150 is a 2.8lt
The one I have is also the Drive-by-wire version and it seems they are slightly heavier compared to the mechanical o/b.
Fishing gear, I think I added an extra 0 to that number
Although the fishing gear weighs a lot I doubt it will be 150kg. Not sure what I did there.
But lets say that makes up for and anchor, chain and rope that I haven't added to the list yet.
Posted: Thu Jul 19, 2018 5:44 am
by BarraMan
All good ! We’ve pruned more than 1700 lb off the figure Tom used. Your Phantom should get up and go now !
Posted: Thu Jul 19, 2018 9:32 am
by Grit19
Wouter, I am new to the forum and have been asking questions about bass boats. Wegcagle alerted me to your build (and BassMunn’s) and all I can say is wow!
You are making an incredibly great looking boat!
I’m not quite to the boat building phase yet, but I am definitely “subscribed” to your build thread! It inspires and intimidates at the same time. Very very cool.
Gib
Posted: Thu Jul 19, 2018 9:52 am
by Wouter
Hi Gib,
This forum is the ultimate place for prospective boat builders there's tons of info from experienced builders. Enjoy it!
Posted: Thu Jul 19, 2018 1:54 pm
by Eric1
Dang Nice stuff!!!
Posted: Thu Jul 19, 2018 3:18 pm
by TomW1
That looks like a much better number than we had before Wouter. Let's leave the tackle number at 350lbs for now to cover all tackle, wiring, cables, hardware, safety gear, ice, drinks, anchor, chain, rope and other miscellaneous items on the boat.
I'll rerun the numbers and come up with new prop numbers. Barraman is right we should pick up a bit of speed.
Posted: Thu Jul 19, 2018 3:31 pm
by Wouter
Thanks Tom.
I appreciate your efforts! Increased speed sounds good to me
Regards
Posted: Tue Jul 24, 2018 11:16 am
by MarkOrge
Nice work ! Raising the bar on Phantom aesthetics !!
Posted: Tue Aug 14, 2018 3:33 pm
by Wouter
Made some progress, fairing the gunnel is taking some time, but I've got the back broken!
Bow section, incorporating the bow Nav light
After balsa planking
As it stands now, most of the fairing done.
Posted: Tue Aug 14, 2018 3:44 pm
by Jeff
As always Wouter, very nice work!! Jeff
Posted: Tue Aug 14, 2018 4:37 pm
by OrangeQuest
Wow! That is some really good work!
Posted: Sat Aug 18, 2018 8:42 pm
by flyfishingmonk
Looking good!
Posted: Sat Aug 18, 2018 8:48 pm
by cape man
Oh Hell yeah! Awesome.
Posted: Sun Aug 19, 2018 6:18 pm
by cvincent
Like everyone else said awesome work Wouter.
Posted: Mon Aug 20, 2018 7:58 am
by Eric1
Carry on Wouter. The boat is looking good!
Posted: Tue Aug 21, 2018 2:59 am
by Wouter
I've been busy figuring out the bow of the boat, trolling motor mount in particular. I've made a marine ply laminate piece for the trolling motor to mount to. Figured I would want a solid piece for it to sit on. However now that it's done I have some doubts, it's pretty heavy! I'm not sure of I should be putting so much weight right on the front of the boat.
Tom, you did mention that maybe I should move some weight forward, what do you think of having a heavy block of wood on the bow..? Any ideas..?
Posted: Tue Aug 21, 2018 7:22 am
by reefie
Really nice work Wouter.
Why not consider mounting the trolling motor on the deck and notch out the coaming to accommodate... it will be semi-recessed, have a lower COG, and not add unnecessary weight withe the big wooden block. You may end up finding it gives a more strealined, cleaner look too.
Reefie
Posted: Tue Aug 21, 2018 8:01 am
by topwater
Why dose it have to be solid
Make it an inch thick in all dimensions and glue it down .
Or make it out of foam with an aluminum backing plate for the motor to bolt to.
Posted: Tue Aug 21, 2018 2:23 pm
by TomW1
I would say go with it. A piece of wood that size can't weigh more than about 10lbs, probably less.
Posted: Tue Aug 28, 2018 5:21 pm
by MarkOrge
Beautiful work. I am not sure if it has been mentioned but bolts always when possible instead of screws.
I love that gunnel and console !
Posted: Tue Sep 18, 2018 4:00 am
by Wouter
Decided to keep the solid wood piece for the trolling motor mount, its now glued into place and not going anywhere
Been working on completing the bow section (deck level) with the forward fish finder mount, the motor tilt foot button, going to use Anderson plugs for the trolling motor power connection, and also fitting a cup holder.
Not the best pic, i'll take some better ones soon.
Posted: Tue Sep 18, 2018 8:17 am
by Jeff
Posted: Tue Sep 18, 2018 9:09 am
by cape man
I like the solid wood. Trolling motors have more torque than you think.
The boat is going to be one of a kind for sure.
Posted: Sun Sep 23, 2018 4:47 pm
by flyfishingmonk
Yes that will be fantastic for the trolling motor. Looks very strong.
Casey
Posted: Mon Sep 24, 2018 6:53 am
by Wouter
Posted: Mon Sep 24, 2018 1:36 pm
by Grit19
That looks cool! I like it...
Posted: Mon Sep 24, 2018 2:34 pm
That looks so nice it is going to be a crying shame to cover it up
Posted: Mon Sep 24, 2018 3:30 pm
by Wouter
Absolutely! Going to be tough to slap some fairing compound on there!
Posted: Thu Oct 04, 2018 6:12 am
by Wouter
Been at it.
Finished the bow section with tubes for wiring and cup holder.
Got a lot of the gunnel fairing done, but as usual it's a bit of a pain. But almost done.
Covered the bow with Carbon, looks pretty good, took some effort to keep the weaves correct, but it came out nice. Going to do a few epoxy clear coats and see how it turns out, hoping it looks good so I can keep it. otherwise just going to fair over it and paint it .
Posted: Thu Oct 04, 2018 6:18 am
by Eric1
I would name that boat, "Jewel of the Namib".
Posted: Thu Oct 04, 2018 7:23 am
by Jeff
Beautiful work Wouter!! Jeff
Posted: Wed Dec 12, 2018 2:43 am
by Wouter
Got some spray work done over the past weekend. Been slow going due to business trips etc. but looking forward to spending some time on her over the holidays!
Face of the console done.
Area under the console done, now I can mount the console!
Bow section
Carbon came out good, will keep it like it is with a clear coat.
Posted: Wed Dec 12, 2018 5:00 am
by cape man
Wow!
Posted: Wed Dec 12, 2018 5:33 am
by OrangeQuest
Still looking very good!
Posted: Wed Dec 12, 2018 8:06 am
by Jeff
Posted: Wed Dec 12, 2018 8:07 am
by Bogieman
Very nice!
Posted: Wed Dec 12, 2018 9:40 am
by flyfishingmonk
Looks great!!
Posted: Wed Dec 12, 2018 10:47 am
by wegcagle
Looks Fantastic! I love how custom each boat becomes over time here.
Will
Posted: Tue Dec 18, 2018 5:13 pm
by BassMunn
Hey Wouter your build is coming along nicely, that's gonna be a sweet looking Phantom
Posted: Wed Dec 26, 2018 3:09 pm
by Wouter
Thanks for all the compliments gents, much appreciated. Hope you all had a Merry Christmas!
Spent a few hours on her over the last few days.
Got the cockpit area finished and sprayed.
Next was the electrical/fuse box panel under the console. It drops down for easy access to all the wiring etc. Added some alliminium strips as 'wire hangers' should help to keep everything tidy under there.
With a master switch.
By moving the bulkhead forward to create more leg room, I actually made a very cool custom space for the fire extinguisher, fits like a glove and should be easily accessible.
Glued the Console into position. (It is now glassed in as well)
Experimenting with a home made vacuum bag setup and tried it out on some carbon.
I used a heavy duty garbage bag, but it worked well and pulled a good enough vacuum.
5 Layer sheet come out pretty good!
Good enough that I decided to make my switch panels for the console out of the sheet. Still need to drill the fitting holes and finish them off with a clear coat.
After all the hours spent I'm now looking forward to a 10 day fishing Holiday!!!
Posted: Wed Dec 26, 2018 3:14 pm
by Wouter
Almost forgot, wet sanded the gunnels as I had too many pinholes, they are now filled and ready for the next primer coat.
Damn wet sanding takes A LOT of time!!
Posted: Sun Dec 30, 2018 2:03 pm
by BassMunn
Flip Wouter that is looking nice. Still need to try that vacuum bag thing out, carbon looks awesome
Posted: Mon Jan 14, 2019 2:27 pm
by flyfishingmonk
Things are looking really good!
Casey
Posted: Mon Jan 14, 2019 2:53 pm
by OrangeQuest
That vacuum thing is just crazy good! If you got the time could you explain the invention.
Posted: Tue Jan 15, 2019 5:39 am
by fallguy1000
What is the application for the carbon panels? Are they just decorative?
That looks like the right amount of carbon for my build.
Posted: Tue Jan 15, 2019 6:31 am
by cape man
Too cool.
Posted: Tue Jan 15, 2019 8:06 am
by Bogieman
You're doing a fine job on this boat.
Posted: Tue Jan 15, 2019 8:24 am
by Wouter
Final primer coat applied to gunnel and console, did the wet sanding last night, looks good! No more Pinholes!! Planning on doing the top coat this upcoming weekend if the weather plays ball.
On the vacuum bagging -Orangequest- I managed to score a vacuum pump from a friend of mine in the medical industry, It's actually from a heart & lung machine, but works perfectly for my application. I added the "air con refill canister" in between the pump and the suction fitting to act as a "fluid container" just in case some of the epoxy gets sucked up, then it will end up in die container and not in the pump.
As for the layup, I used some peel ply I still have left over and then for the breathing material I used cloth that is actually intended for sealing a roof, but it works just as well and is much cheaper then the 'official stuff". I sealed the bag using silicone, again cheaper then the double sided tape offered by the suppliers and it worked well! I'm still experimenting with it, so still early days and learning as I go along.
Fallguy1000 - I've cut out pieces of the carbon sheet I made, they will house the switches and different electronic bits and pieces on the console.(see pic in my previous post) It is purely for aesthetics, I had aluminum pieces before but the carbon just looks so much better!
Posted: Tue Jan 15, 2019 10:53 am
by OrangeQuest
Thank you for taking the time to explain your set up. It does seem to work nicely.
Posted: Tue Jan 15, 2019 1:09 pm
by Eric1
Shame on me for not paying attention! Your boat is looking Super Nice!!!
Posted: Sun Jan 20, 2019 10:39 am
by Wouter
Got her top coat on!! Pics just don't do it justice, but here they are!
Three layers of base coat, Candy Apple Red, One clear coat mixed with 0.06 Silver holographic flakes, 6 clear coats on top.
Base coat going on.
After all coats and masking tape removed.
Gave the rear corners a bit of a finishing touch, my gf says it looks like drops and should remind me of all the sweat I've put into the boat!
The corner pattern does seem to just round the paint job off nicely!
Extended the paint to the edge of the console, giving the face of the console a better 'framed' look.
Cant see the true reflections of the flakes in the pics, but I think we got the amount of flakes just right.
Went to fetch her this afternoon and she is now back home. Just had to see what the cup holder will look like in the bow, the carbon also came out top notch!!
She sure glitters like a star in the sun!!
Posted: Sun Jan 20, 2019 10:46 am
by Jaysen
Wow! That's one sharp looking boat.
Posted: Sun Jan 20, 2019 10:58 am
by pee wee
Wow!!!
Posted: Sun Jan 20, 2019 11:10 am
by peterrivers
Wow, that's beautiful!
Posted: Sun Jan 20, 2019 11:42 am
by Bogieman
Holy cow! Beautiful job
Posted: Sun Jan 20, 2019 12:08 pm
by Fair WX Pilot
Fantastic, truly custom. Love the corners.
Posted: Sun Jan 20, 2019 12:35 pm
by Capt UB
She is one of a kind!
She is beautifull great job on the build.
Posted: Sun Jan 20, 2019 1:59 pm
by piperdown
Absolutely gorgeous!
Posted: Sun Jan 20, 2019 2:34 pm
by icelikkilinc
Now that’s a killer paint job
Love the corner and framing detail of console
Posted: Mon Jan 21, 2019 9:01 am
by gonandkarl
Hi Wouter,
You painted the boat just beautiful. It looks more than perfect. I cannot imagine that you will have fish blood on this boat soon. But seeing that it is so glossy it will wash off easily after a fishing trip. When will you splash it ? Please post again lots of pictures of it.
Greetings from Karl
Posted: Mon Jan 21, 2019 9:03 am
by Jeff
Wouter, beautiful work!!!!! Jeff
Posted: Mon Jan 21, 2019 11:08 am
by cape man
Yep...
Posted: Mon Jan 21, 2019 11:56 am
by OrangeQuest
I was really liking her when she was just bare but man! That is just crazy nice looking paint job! Very nice!
Posted: Mon Jan 21, 2019 11:49 pm
by flyfishingmonk
That is a nice boat. Very nice indeed.
Casey
Posted: Mon Jan 21, 2019 11:52 pm
by TomW1
It is looking good Wouter.
Posted: Sun Jan 27, 2019 1:59 pm
by BassMunn
Woohoo Wouter that looks good!!!!
Love the corner finishes and the carbon looks good against that red, very nice job
Posted: Sun Jan 27, 2019 3:02 pm
by Wouter
Thanks everyone!
Spent the weekend wet sanding the clear coat with 1500 grid, got 80% done. Borrowing a polisher this week and plan on getting the sanding and polishing done in the next few evenings. The clear coat had the slightest orange peel to it so had to flat it. Should now look even better
Posted: Sun Jan 27, 2019 4:28 pm
by flyfishingmonk
Sounds awesome, can wait to see it!
Casey
Posted: Mon Jan 28, 2019 3:37 pm
by wegcagle
Holy moly!! You’ve got to be a pro painter? That finish is nothing short of perfection!! Absolutely beautiful
Posted: Tue Jan 29, 2019 4:33 am
by BarraMan
Wow! Just wow! Got nothing else!
Posted: Tue Jan 29, 2019 5:29 pm
by MarkOrge
That is one beautiful Phantom !
Curious - what are you planning for your engine?
Posted: Tue Jan 29, 2019 8:32 pm
by Wouter
Got a 150 Suzuki four stroke.
Posted: Thu Jan 31, 2019 12:14 am
cape man wrote: ↑Mon Jan 21, 2019 11:08 am
Yep...
I think this just about covers it
Posted: Thu Jan 31, 2019 6:49 am
by Jeff
Agree!! Jeff
Posted: Tue Mar 26, 2019 3:57 am
by Wouter
Made some progress over the last few weeks.
Finished wet sanding the gunnel and polished it, went around three times, looks pretty good! Had some issues while sanding, it turned out that some of the flakes actually came loose and would end up under the sanding paper and before you know it, would cause a scratch. I probably should have given it another clear coat after wet sanding, but I ended up sanding out the scratches and polished over it. Still looks pretty good!
Fitted the bow mounted NAV light.
And tested the Wiring, WORKS
Rub rail is fitted, both sides, finishes the sides off nicely. Struggled to get end pieces for this rub rail, so I made some wood pieces that I have now made a silicone casting of and plan on making some resin casting to go on the ends of the rub rail to give a clean finish.
Finished the switch plates and test fitted all the console goodies, everything seems to be fitting well and I think the layout will work well. The left side upper plate gets 5 switches for the pumps, the middle one gets the switches for all the instruments, and the right one - switches for all the lights.
Bottom left will house a 12v socket and a 12v lighter plug. The right bottom will house 2 digital volt meters so I can check the voltage of the house and trolling motor batteries.
Also started with the carpeting, after I painted the rear deck. Carpeting is a slow going process and takes some time to get right
Posted: Tue Mar 26, 2019 5:56 am
by gonandkarl
Hi Wouter,
Your boat looks fantastic and I wonder how you get everything on it so perfect. If my boat would be so perfect I hardly would dare to put it in the water.
When will be your splashing time and where will you mainly fish with your boat ?
Build on and always let us see your progress.
Greetings from Karl
Posted: Tue Mar 26, 2019 6:21 am
by Wouter
Hi Karl,
Thanks for the compliments!
I'm hoping to be ready for the Splash by August, have a big event I would like to attend with my own boat
Predominantly I'll be fishing the Kavango, Kwando and Zambezi rivers.
Posted: Tue Mar 26, 2019 6:44 am
by OrangeQuest
It is an amazingly beautiful boat.
Posted: Tue Mar 26, 2019 6:46 am
by antoniekruger
Ja, boet - that looks really good. Bagging composites is a great way to get a good finish. Is that a refuge black bag? Great work.
Posted: Tue Mar 26, 2019 7:01 am
by Wouter
Correct Antonie, standard black refuge bag
It does the job! At least for flat parts that don't have sharp edges that could poke a hole in it.
Posted: Wed Mar 27, 2019 12:36 pm
by MarkOrge
Stunningly beautiful ! Wow. Cant wait to see her with the motor attached...
Posted: Wed Apr 10, 2019 3:17 am
by Wouter
Finished the trim pieces for the rub-rail.
Used balsa to make the original plugs, then made a mold out of silicone and corn starch mixture - worked very well! Poured in colored epoxy en Bob's your uncle, nice clean sturdy weather proof end pieces.
Bow section rub-rail end piece
Stern rub-rail end piece
Painted the bow deck section. Taped off a piece in the middle just so that I could reach everywhere with the spray gun, will do that middle section this weekend.
Also took the plunge and got the Trolling motor, Motorguide 82lb, 24v with transducer for the bow mounted fishfinder.
Test fitting it here. Looks pretty good and leaves plenty of deck space
Posted: Wed Apr 10, 2019 3:58 am
by glossieblack
Nicely crafted end pieces.
Posted: Wed Apr 10, 2019 5:06 am
by cape man
Bob is certainly your Uncle! That is just too much! You would be scary with a 3D printer. Love the craft you employ throughout the whole boat, but those end pieces blow me away. Such a small detail and yet so important to the big picture. She is amazing!
Nice trolling motor too...
Posted: Wed Apr 10, 2019 7:52 am
by Jeff
Beautiful work!!!!! Jeff
Posted: Mon Apr 22, 2019 9:14 pm
by Dutch1
cape man wrote: ↑Wed Apr 10, 2019 5:06 am
Couldn't agree more! Love seeing what you come up with for this build!
Posted: Tue Apr 23, 2019 1:54 am
by Wouter
Got the carpeting done over the weekend, what a job!! Super happy with the results though!
Posted: Tue Apr 23, 2019 7:58 am
by BB Sig
What a beauty!
Posted: Tue Apr 23, 2019 8:14 am
by Jeff
Beautiful work Wouter!!!! Jeff
Posted: Tue Apr 23, 2019 10:23 am
by Jaysen
It certainly creates the counterpoint to those of us who think "workboat works on my boat".
Gorgeous finish.
Posted: Tue Apr 23, 2019 10:29 am
by cape man
Posted: Mon Apr 29, 2019 5:25 am
by Wouter
Did the cockpit floor with an anti-slip over the weekend. Used a local truck-bed liner product that worked easily and I'm very happy with the results. Still need to fit the hardware on the hatch lid for the floor live well and cockpit drainage fitting.
I need some advice: what are you all using on the inside of the motor well to secure the motor bolts in terms of washers etc. Are large washers sufficient..? Size, thickness, material..? or should I use a type of plate that covers a larger area..? I would appreciate some input.
Regards
Posted: Mon Apr 29, 2019 8:16 am
by pee wee
Wouter wrote: ↑Mon Apr 29, 2019 5:25 am
Regards
This question was just addressed on another thread for a PH16, the advice from Aripeka Angler was: "When you get to the rigging stage, I would recommend using the metal bolt backing plates on the forward side of your transom.
This will prevent the motor bolts from sinking into the wood on the transom."
Posted: Mon Apr 29, 2019 10:50 am
X2 use plates and spread that force out over a larger area.
Posted: Mon Apr 29, 2019 11:06 am
by Capt UB
I've done 1/4", 3/8" thick, SS and aluminum backing plates inside. Outside I used 3/8" hard UV stable plastic, this save the transom from being dug into by the motor mount or jack plate.
- inside transom.jpg (22.33 KiB) Viewed 2032 times
- outside transom.jpg (39 KiB) Viewed 2032 times
Posted: Sat May 04, 2019 12:52 am
by flyfishingmonk
Wouter wrote: ↑Wed Apr 10, 2019 3:17 am
Brilliant.
Posted: Wed May 22, 2019 5:44 am
by Wouter
Some developments over the last few days.
Got SS backing plates made and fitted the Jackplate. Thanx for all the response in this regard!
Took her out to get the motor mounted. She does shine out in the sun
Big day to get the motor on!
However, ran into a problem with space, motor can't tilt far enough and the wiring harness hits the gunnel. This is purely my mistake! I incorrectly placed the swivel point of the motor further back on my CAD drawings (on which I based the decision not to build a motor well) So I'll need to take the motor off again and modify the transom area and gunnel.
Spent some time with the motor still on marking out what I would need to do.
Made this cut out to be able to measure more accurately. Now I know what I need to do to make it work and also make space for the hydrolic steering brackets.
It's a little hart breaking to have to cut the boat again, but then that's the purpose of building a custom one off a kind boat! So I'm actually looking forward to cutting it, fixing the problem and making it look pretty again!
Building on over the next few days!
Posted: Wed May 22, 2019 5:54 am
by cape man
Okay...
First, wow! What an absolutely beautiful boat! You did an amazing job!
Second, ain't nothin but a thang. Will be interesting to see your fix.
Finally, wow!
Posted: Wed May 22, 2019 6:59 am
by Browndog
Had to do the same thing with my brother’s boat. Ended up removing the jackplate altogether and repairing and repainting the transom. Can’t hardly tell now, but it was a setback that I hadn’t planned on. Hard to plan for everything.
Your boat looks great and It will be behind you soon enough.
Posted: Wed May 22, 2019 7:18 am
by OrangeQuest
Wow is not enough! You did a great job on your build! Will be exciting to see your mod on the transom.
Posted: Wed May 22, 2019 8:57 am
by ctbeutel
It has been amazing to watch the start to the almost finished boat. Very well done.
Posted: Wed May 22, 2019 9:45 am
by BB Sig
Amazing and well thought out build!
Posted: Wed May 22, 2019 10:14 am
by Fair WX Pilot
Absolutely amazing job. I have loved following your build and watching this take shape. Amazing.
Posted: Wed May 22, 2019 11:33 am
by cvincent
Your boat is stunning Wouter! I am certain you will find a solution for the transom.
Posted: Wed May 22, 2019 12:57 pm
by Jeff
Beautiful build Wouter!!! Jeff
Posted: Wed May 22, 2019 1:55 pm
Man that is NICE! I bet it will fly with that much power.
Posted: Thu May 23, 2019 8:18 pm
by TomW1
Wouter I have some safety questions for you on your boat seeing that 150 HP motor sitting on the transom. First I did some calculations and that motor will push that boat above 50mph well above Jacques design speed of lower 40's. So have you increased the bottom plywood thickness or fiverglass thickness. It takes several layers of fiberglass to strengthen the bottom enough. The transom may or may not need a layer of plywood on it. I don't want to be an alarmist but I have taken design courses and Jacques and I have talked about this subject about putting to much HP on his boat. If you have talked to Jacques and done what he told you then ignore me. If not I would hate to see you launch this boat take it up to top speed and have it come apart on you.
Posted: Fri May 24, 2019 7:44 am
by Wouter
Thanks for all the kind words everyone!! It's much appreciated!!
I've taken a step back this week and cleaned the workshop, glancing at the boat every now and then. Think I have my plan to fix the transom/motor clearing issues sorted out in my head. I'll take the motor off over the weekend and get on it!
Tom, I hear your concerns and would be lying if I said it doesn't bother me in the back om my mind as well. I have added extra layers of FG on both the outside and inside of the bottom, but did not change the plywood thickness. The transom has been vastly bulked up with it's construction and the FG schedule used to build it. I'm very confident in the construction of the boat, but I promise you I'll be very cautious when launching and testing the boat, It's in my nature to be conservative, so I won't be blasting along at full throttle from day one.
Posted: Fri May 24, 2019 2:03 pm
by TomW1
Wouter in my concern for the safety of the boat, I forgot to tell you what a great job you have done and what a beautiful boat you have.
Posted: Fri May 24, 2019 2:07 pm
by Wouter
Thanx Tom! Much appreciated.
I'll keep you all updated on the performance once she's launched. Hopefully soon!
Posted: Wed Jun 19, 2019 7:10 am
by Wouter
Done with the transom modification.
Cut out the piece I needed too.
Insert pieces made with 6mm marine ply. Inner surfaces done with 3 layers of epoxy.
Filleted the corners and layed some carbon over it, should be plenty strong.
After fairing I painted PU white.
And re-fitted the jackplate.
Hoping to mount the motor again this weekend, I'll let you all know how it works out
Posted: Wed Jun 19, 2019 7:15 am
by Jeff
Well done!! Jeff
Posted: Wed Jun 19, 2019 9:14 am
by ctbeutel
That looks really good. I think I like the looks of the modified transom even better!
Posted: Thu Jun 20, 2019 10:44 am
by swglenn
I had to do the same thing on my Phantom back deck to clear the hydraulic steering cables. For others thinking about building a Phantom the plans are correct. This is needed only if you don't build your boat to the plans and leave out the motor well cutout.
Posted: Thu Jun 20, 2019 11:09 am
by OrangeQuest
As expected, GREAT WORK!!
Posted: Thu Jun 20, 2019 4:40 pm
by flyfishingmonk
That looks great!
Casey
Posted: Mon Jun 24, 2019 10:50 am
by cvincent
Your modification looks better than the original transom. Very well done!
Posted: Mon Jul 08, 2019 1:15 pm
by MarkOrge
Beautiful work. What prop did you go with on the Suzuki ?
Posted: Mon Jul 08, 2019 1:18 pm
by Wouter
I've got a 24 pitch three blade ss prop.
Will start with it and see how it goes.
Posted: Mon Jul 08, 2019 1:41 pm
by flyfishingmonk
That modification looks awesome. Did you experience anything that you thought was a negative going with the 150hp? I am considering the 150 for mine.
Casey
Posted: Mon Jul 08, 2019 2:22 pm
by Wouter
Hi Casey,
So far I'm happy with my motor choice, it really looks good on the boat. The size seems to be perfect, I wouldn't go bigger though. The weight is definately a negative, but I'll only be able to give better feedback once I've launched and see how she balances.
Off hand, I think the PH is only rated for a 90HP..? So knowing I was going to fit the 150, I beefed up the transom structure a lot.
If you are thinking of upgrading your motor, maybe just make sure your transom can handle it.
I'm planning on launching early next month, will be able to give better feedback then.
Posted: Wed Jul 10, 2019 4:22 am
by Wouter
Received my console switches, again.
1st batch that I got turned out to be momentary switches and not latching so had to return them and wait for the correct ones. I think they compliment the console very well. Still need to figure out a neat way of labeling them.
Got them wired up.
Very glad I added those aluminum bars to act as wire hangers, they work well and help keep everything tidy. Now it's up to me to keep track of what is what
Should be able to finish wiring of the console tonight. Then I can move on to the hydrollic steering and steering wheel.
I've laid the wiring harness of the motor on the deck to test fit everything, so far so good. I'll install it all soon, potentially before or over the weekend.
Posted: Wed Jul 10, 2019 5:04 am
by Aripeka Angler
Beautiful work sir.
Your console is truly a work of art.
Posted: Wed Jul 10, 2019 8:36 am
by Jeff
AA said it all!! Beautiful work!! Jeff
Posted: Thu Jul 11, 2019 7:57 am
by Wouter
Some more console wiring pics, done with it now
All switches wired, but still a bit of a mess inside.
Cleaned up and cable tied in place
The drop down fuse box holder.
Posted: Thu Jul 11, 2019 9:01 am
by cape man
Note to everyone that I will NEVER post a picture of the wiring inside my console, based primarily on pictures like the ones you just posted. Nice work!
Posted: Thu Jul 11, 2019 9:36 am
by ctbeutel
That drop down fuse holder is a great idea. Every time I look at your build I am amazed at how thought out every detail is. Very nice work.
Posted: Thu Jul 11, 2019 12:03 pm
by Jeff
Beautiful work Wouter!!! Jeff
Posted: Thu Jul 11, 2019 12:07 pm
by Dougster
Cape Man need'nt worry. If he ever slips up and posts that pic I'll bail him out with a pic of mine. How do you do that Wouter?!
Posted: Thu Aug 08, 2019 5:02 am
by Wouter
Did my 1st road trip over the past weekend down to our west coast (900km away). Visited the Suzuki dealership where I got the motor from, they had to OK the motor mounting and programme the motor and check the wiring harness. It's all GOOD now, started and tested it
She roars!!
Here's a few pics from the trip! Btw that double axle trailer is an absolute pleasure to tow!!
Splash date is now set for the 22nd August!!
Posted: Thu Aug 08, 2019 6:39 am
by OrangeQuest
Boat looks awesome!!
Posted: Thu Aug 08, 2019 7:19 am
by Bogieman
Very nice!
Posted: Thu Aug 08, 2019 7:53 am
by BB Sig
Beautiful boat and background!
It reminds me of my time in Yuma, AZ. That's in the desert!
Posted: Thu Aug 08, 2019 11:37 am
by Jeff
Wouter, beautiful boat!!! Really well done!! Jeff
Posted: Fri Aug 09, 2019 7:10 pm
by TomW1
Wouter beautiful boat. When do we see pictures of her in the water?
Posted: Wed Sep 04, 2019 10:46 am
by Wouter
And she is 'SPLASHED'!!! And 'FLOATS'!!!
What a week it was! Had a minor mishap after launching, connected the hydrolic steering backwards
Not so much fun to steer a boat in that manner, but luckily it was an easy fix. Then did the first 2hrs idling time as required, after which I put her on plane for the 1 st time. Had the motor way to low and she porpoused a bit. Took her out and readjusted the motor height and she went way better. But still only got 4400 revs with my own prop 16 24P 3 blade. Took her out again and lifted the motor up even more and borrowed a 15 1/4 24P 4 blade prop and she went much better.
Holeshot is perfect, she gets on top very easy! With the increased height and smaller prop she got up to 72km/h with 5100 revs. Very stable ride and we decided to fish her like that for the competition. (seeing that no one had other props for me to try)
We caught some very nice fish and ended up 5th overall for the competition, which I'm super stoked about!! (my 1st top 10 placing for this event!!)
I still think the motor needs to come up some more and I feel I need to experiment with a few different props now until I find a good balance I still need to get another 800-900 rpms). I'll have to redesign the motor bracket for me to be able to lift the motor up further and I would like to get a little bit more angle on the motor. I'll draw up some options and see if I can get it manufactured here or otherwise try and source it from somewhere.
Electronics on the boat work fantastic!! I'm super happy with onboard DC-DC charger, we didn't have to charge or take batteries out for 10 days straight, that's awesome!!
The livewell auto uptake works like a bomb, takes around 4 minutes for it to fill up and drains at the same speed as it fills, so that works great!
Needles to say I'm SUPER HAPPY!!!
Posted: Wed Sep 04, 2019 10:48 am
by Wouter
Is there a way to share a video clip on the forum..? I got a small clip of us passing on plane!
Posted: Wed Sep 04, 2019 12:19 pm
by Jeff
Congratulations Wouter!!! She is a beauty!! Jeff
Posted: Wed Sep 04, 2019 12:28 pm
by Jaysen
Wouter wrote: ↑Wed Sep 04, 2019 10:48 am
Best option is post to youtube then use the youtube widget here.
Posted: Wed Sep 04, 2019 2:00 pm
by Wouter
Posted: Wed Sep 04, 2019 2:01 pm
by Jaysen
Posted: Wed Sep 04, 2019 2:29 pm
by Wouter
Thanx Jason!!
Posted: Wed Sep 04, 2019 11:50 pm
Congratulations on both the boat and the fishing. Nice way to start off using the boat
The boat looks simply stunning.
Posted: Thu Sep 05, 2019 12:01 am
by BB Sig
Stunning boat! Congrats on the splash!
Posted: Thu Sep 05, 2019 2:45 am
by OrangeQuest
Thing looks great on the water!
Posted: Thu Sep 05, 2019 3:09 am
by gonandkarl
Congratulations to splashing your boat. It is beautiful and the video clip is perfect. All the hard work you did on this boat is visible. You got a really fantastic boat.
Posted: Thu Sep 05, 2019 6:18 am
by cape man
Awesome! Just awesome!
Posted: Thu Sep 05, 2019 6:44 am
by glossieblack
Perfecto.
Posted: Thu Sep 05, 2019 7:17 am
by topwater
Thats a serious nice ride right there
Posted: Thu Sep 05, 2019 8:27 am
by pee wee
Fantastic! Very nice, and she rides well in the water.
I enjoyed following this build, and learned a few things!
Posted: Thu Sep 05, 2019 3:56 pm
by cvincent
Congratulations on the splash! I enjoyed following your build.
Posted: Fri Sep 06, 2019 3:05 am
by Wouter
A quick drone shot after a day's fishing as we were idling past the no-wake zone.
https://youtu.be/eJcp5_fmLuc
Posted: Fri Sep 06, 2019 3:27 am
by Wouter
A few of the fish we caught!
Tiger Fish
Nembwe
Pink Happy (bagged us a weeks hunting trip as the prize for the largest fish in the - smal bream category)
Catfish by my gf, the smallest one caught but the only one she could manage for a pic
Posted: Fri Sep 06, 2019 6:12 am
by cape man
Again...awesome!
Posted: Fri Sep 06, 2019 7:40 am
by Jeff
Great fishing!!!! Jeff
Posted: Fri Sep 06, 2019 8:04 am
by Coach
Excellent!
Posted: Tue Sep 10, 2019 8:22 pm
by Bogieman
Posted: Tue Sep 10, 2019 11:25 pm
by TomW1
Nice fishing Wouter. I also noticed getting caught up on what you had been up to that you were having prop problems. I did a rough calculation for you based on your PH18 leaving the dock weighing 2300 lbs. all in, 2 men, fuel, gear and all wiring and electrical and mechanical gear, plus that nice Suzuki. For a 3 blade I show a 16 x 24 and for a for a 4 blade a 15.75 x 21. If you want a better number calculate all the weights in your boat and let me know. The 4 blade will let you raise the motor the most.
Regards, Tom
Posted: Wed Sep 11, 2019 10:37 pm
by willg
Wouter, congratulations! You have worked very hard and she is beautiful!
Posted: Thu Sep 12, 2019 3:20 am
by Wouter
Thank you ALL for the great comments and support, it is much appreciated!
I'm sure you all can appreciate how happy I am after spending so much time on the build and then have her perform pretty good without any major issues
Now it is just tweaking here and there to get her to run even better!
I've removed the mudgaurds on the trailer and will build some fiberglass replacements. Those metal ones were just to flimsy and made putting the boat back on the trailer a bit of a job. Still contemplating if I should build a plug and make a mold or if I should just use the off cut 9mm marine ply I still have and build them from that and cover them in FG.
I've drawn up a new jackplate bracket that will allow me some more height on the motor, also has an additional 8 degrees of tilt, which will help with trimming the boat once on plane. It seems like the Suzuki runners here all have an extra 'wedge' on their motor mounts for that purpose! Anyone else noticed that elsewhere..?
Sent the plans out to a few local machine shops hoping that I could get it done locally.
Posted: Thu Sep 12, 2019 8:14 am
by fallguy1000
Nice work on the boat.
Make the trailer from wrapped plywood for custom pieces. Stiffer than frp when wrapped and faster than moulds.
I gotta admit I am confused as hell by that drawing on a couple points.
First of all, I only see a 90 degree angle. Is that thing just a bump stop? A wedge needs to be solid.
Then 8 degrees? Why would you want 8 degrees?
Posted: Thu Sep 12, 2019 8:41 am
by Wouter
Maybe this pic will be better to understand the 'bracket'.
I have a jackplate that is mounted to the transom, but want to make a piece that fits within the existing jackplate that I can just bolt on. The motor will then get bolted unto that piece.
Posted: Sun Sep 22, 2019 11:38 pm
by flyfishingmonk
Those fish are nice!
Casey
Posted: Thu Jan 16, 2020 2:00 am
by Wouter
Hi Everyone.
Spent the December holidays on the Zambezi river, had a blast and a good rest.
Done a bunch of test runs with different props and motor heights, but I'm still porpoising when going dead straight, even at lower revs cruising.
I started off by lifting the motor up from the previous position and using the same prop (4 blade 24 pitch), that gave me around 300 more revs but the boat was way to unstable, so dropped it down again. With a 3 blade 21 pitch I hit the rev limiter without trimming out at all. The 3 blade 23 pitch gave the best results and I can run around 5700-5800 revs with it.
However I'm still at a very high negative angle just to keep the nose down and trying to prevent porpoising. See below pic. (thats as much as I can trim out)
So currently I need to use the motor in a very inefficient way to keep the boat in somewhat of a driveable attitude.
It's clear to me that I will not be able to resolve this issue with motor height and props alone. I'm thinking I need to make some changes so that I can get the motor angled in a way more efficient manner.
Options:
1. Weight distribution, I can move the batteries forward. I have 4 batteries, 3 deepcycles and 1 crancking battery, combined with the onboard charger weighs 100kg. That's a lot of weight that I can move around. Any thoughts..?
2. Trim Tabs, I'm thinking that trim tabs would help push the nose down so that I can trim the motor out..? Anybody got some experience with fitting trim tabs on the PH 18? What size, brand and lb would be the best.?
Regards
Posted: Thu Jan 16, 2020 3:12 am
Not sure how much help this will be but I had similar problems with my Sintes 21. Either I made a mistake when building the hull 30 years age or it has some rocker built into it. Plus the way way I built it the hull is a little stern heavy. Anything over 25 and she would porpoise bad enough to toss you out. Even putting 250# in the bow did not cure it even with the motor trimmed all the way in. Raising the motor helped as did moving weight forward but the cure was trim tabs. Now I can run 40 with no ill handling. You probably have checked but make sure you do not have some rocker that crept in.
Posted: Thu Jan 16, 2020 9:06 am
by Browndog
I agree with Fuzz that the Trim tabs are the way to go.
You will likely improve handling, hole shot, top speed and Fuel efficiency.
I have used both Electric (Lenco) and Hydraulic (Bennett) trim tabs. They are equivalent in performance. The electrics are easier for the DIY installer and do not require space inside the boat for a hydraulic fluid reservoir and pump.
The size to use would be a 9” X 9” or a 12” (span) X 9” (chord).
Span (width) has more effect than the cord (depth).
After using trim tabs on my last 3 boats I can’t imagine not having them, they are that useful.
Posted: Fri Jan 17, 2020 12:38 pm
by cvincent
I have the Lenco Electric 9x12 trim tabs and they work great. The only porpoising I have experienced is at WOT with the motor lifted high with the jackplate and trimmed up excessively.
Posted: Fri Jan 17, 2020 1:54 pm
by Dustinwg
I also have the 9x12 Lenco Trim Tabs and have not had any problem with them. It is nice to have them as they make a significant difference when getting on plane and when heading straight into a significant chop, to push the bow down and be able to cut through waves rather than pound on top of them on the flatter part of the hull.
My experience is similar to cvincent in that I do not get really any porpoising except at WOT.
With that said, I do have weight forward as I put my 24 gallon fuel tank forward under the front casting deck, and not sure if the fact that I have a jet affects that at all.
I would try moving the batteries up first to redistribute weight to see if that it improves the ride at all.
Posted: Sat Jan 18, 2020 2:29 am
by Wouter
Thank you guys for all the feedback! Much appreciated.
I'm pretty much sold on the trim tabs idea.
I've found a seller of the Nauticus trim tabs who's willing to courier to me, but not one for the Bennet's.
Any thoughts on the Nauticus self levelling trim tabs..?
Posted: Thu Jul 16, 2020 4:57 am
by Wouter
Hi everyone.
Thanx so much for the trim tab info on my last post. Some feedback: I fitted the hydrolic self leveling tabs from Nauticus and it makes a world of difference!! Hole shot has improved dramatically but I'm more impressed with the added stability and the fact that I can now drive straight without any porpoising. I'm also now able to trim the motor out to horizontal and that makes a huge difference on rpm and speed. I used a 4 blade 23p prop which gave me 6000 rpm's and a speed of 50mph and gives a very comfortable ride. Trimming the motor out further increases the speed but then she becomes a bit unstable, so I'm super happy to be able to cruise at 50mph!
Posted: Thu Jul 16, 2020 7:24 am
by cape man
So good to hear you are happy with the results. Your boat is still one of my favorite builds I've seen here. How about some more action pictures including some fishing reports? 50 mph is impressive!
Posted: Thu Jul 16, 2020 8:34 am
by OrangeQuest
That is really good news!! And agree with Cape Man, was a thrill to follow your build but would love to see and hear more about it on the water!!
Posted: Tue Jul 21, 2020 4:10 pm
by Rollbar1
How does she handle the chop-1'-2'?
Very nice.
Posted: Tue Jul 21, 2020 5:21 pm
Your build is just amazing! And 50mph cruise is FAST! Little faster than I would be comfortable
When you get a chance some in the water pictures would be great
Posted: Fri Feb 26, 2021 3:02 am
by Wouter
Hi guys,
Apologies for being away for so long, what a roller coaster it's been over the last 12 months or so.
But I owe you some updates
I've done the trailer fenders in marine ply and covered them with FG, paint matched the boat so it looks cool and it just happens to be super functional as well
With all the lock-downs etc. we managed only one tournament last year. But it turned out to be a successful one!!
Finished 5th overall (again) but this time we took the best individual angler as well as the main prize for the most valuable single fish. Bagged ourselves a Goliath Tiger Fishing trip to Tanzania as the prize!! So looking forward to doing that sometime soon. (travel bans dependent
Here are some of the fish we caught:
Nembwe, caught on a crank bait that I airbrushed myself (dabbling in the airbrushing baits thing lately
Another Nembwe
My Three Spot
Riaan's three spot that won the main prize!
Just had to make a mount for lasting memories
On the boat front: I've been tinkering with the motor setup and the trim tabs and I'm at the point where I can leave it as it is, everything is now as good as it's gonna get and I'm super happy with the performance. Took a while, but now the testing and trying things are done, so I can just go launch and go fish
I am going to change the steering wheel configuration, it's sitting a bit flat and would like to angle the steering wheel a bit more upwards just to make it more comfortable for me. Still got to get a game plan together for doing this, but it'll happen soon.
Best Regards to you all!!
Posted: Fri Feb 26, 2021 6:28 am
by cape man
Congrats on the fenders and fishing! Both look great!
Posted: Fri Feb 26, 2021 7:42 am
by Jeff
Congrats Wouter, your boat and trailer look great!! And, nice win!!! Jeff
Posted: Fri Feb 26, 2021 4:02 pm
by TomW1
Everything looks great Wouter. Congrats on the win!
Posted: Fri Feb 26, 2021 6:34 pm
by MrPaul
Nice!!!. Please post pics of the Tiger fish when you go on the trip you won.
Posted: Fri Feb 26, 2021 7:00 pm
by VT_Jeff
This build thread should be on the required reading list for all new builders, it's just amazing!
Congrats Wouter!
Posted: Sat Feb 27, 2021 3:35 am
by Wouter
Thanx everyone!
Paul, unfortunately we hooked into a few nice Tiger fish but were unable to land them. They can be tricky to land at times
Almost forgot: after a few fishing days I realized I needed a tool holder, so made one out of carbon and mounted it on the console. Having used it now, it's in the perfect position on the boat and makes it so much easier when having multiple anglers, whether fishing from the front or the back it's easily accessible.
I made a flat sheet of carbon and cut it to shape. Then made some plugs from hardwood to the shape of the pliers and scissors. Covered them with packing tape and vacuum bagged some carbon over them. (included a magnet in between the carbon layers, helps to lock down the tools) I then glued the 'holder pieces' onto the flat carbon and gave it a good layer of clear self leveling casting epoxy. The lip grip is held in place with a simple kitchen cabinet broom holder, works pretty well. Simple but very effective
Re: Wouter's PH18 Namibia
Posted: Sat Feb 27, 2021 5:15 am
by cape man
Too slick!!
Posted: Sun Feb 28, 2021 12:08 am
That tool holder is a small thing but it is amazing none the less. You have a truly custom boat!
Posted: Wed Jun 16, 2021 5:52 am
by glossieblack
Happy birthday Wouter!
Posted: Wed Jun 16, 2021 6:37 am
by Wouter
Thank you!
Posted: Wed Jun 16, 2021 7:12 am
by Jeff
Happy Birthday Wouter!! I hope you have a great day!!! Jeff
Posted: Wed Jun 16, 2021 1:22 pm
First Happy birthday
And second we need regular updates on your adventures with that beautiful boat.
Posted: Wed Jun 16, 2021 5:35 pm
by TomW1
Happy birthday guy and may you have many more. Keep up to date on what your doing with your great boat.
