A layer of 6" cloth on the bottom is sufficient. I run a 15 hp 4 storke that's 126# on mine and that's what the designer recommended. Here's how I did my transom knees. Be sure to glass all the intersecting joints. I didn't glass the inner 1x2 at the ends where it meets the sides and the inner frame and had some cosmetic cracking in the fairing. Was an easy fix, but unnecessary if done right the first time.
GV11. And so it begins...
Re: GV11. And so it begins...
I like the look of that! I have a small piece of 1" exterior from the early 1970's that I am thinking about using for the transom knees. My motor is extremely light for a 15 hp. Even though, it can still do some damaged to the transom while being trailered. The guy I bought the motor from had broken transome Knees from towing his boat on bumpy roads. It looked like someone had taken a saw and cleanly sliced right through the knee. And that was on an aluminum boat!
Use a transom brace when trailering and you won't hurt the transom.
Don't throw it away.
I couldn't have done what you've done because some of the parts, like the seats, couldn't be cut until I had the hull built to measure from. Otherwise I'm sure they wouldn't have fit.
Tony
I never throw things away! For what that wood costs I might even sweep up the saw dust!
We spend a lot of time on the nesting drawing!
If it makes you feel any better you are not the only one who feels like their work is not in the same class.
I am almost to the point of saying "work boat is good enough". Not quite there yet but getting close
Fuzz
Fuzz
I'm pretty sure my build, once started, will make you all feel better. I'm expecting gnats and sand in the paint. A fairing that makes a wadded up plastic bag seem smooth, and a tape job that looks like a toddler got into the toilet paper. I'm building a boat that I only expect to last 2 years so there isn't much point in killing myself on the details. Second build... yes. But until then... GET ME IN THE WATER!
