Re: ST21 "SKINNYDIP" Noosa Australia
Make sure you do NOT install it perfectly straight. You need at least a little angle so the bearings move and keep from freezing in place.
- glossieblack
Aquadrive specify a change of angle of at least one degree to facilitate self lubrication of the CV joints. To achieve this, I'll need to raise the engine about 3/4" above where it would have been for a dead straight shaft line. The aluminium angle engine beds are already in place for a dead straight setup, so I'll place 3/4" thick hardwood spacers between them and the engine mounts. As Cape Man would say, 'it's just a thing', and a very small one at that.Fuzz wrote:Make sure you do NOT install it perfectly straight. You need at least a little angle so the bearings move and keep from freezing in place.
- glossieblack
Thanks for following the build Topwater.topwater wrote:Love this boat , build on
Today I collected the 16 lithium battery cells which will form the 48V 100 Ah battery bank for the electric motor subsystem of the diesel-electric parallel hybrid drive system. Grouped together the 16 cells are 16" deep, 21" wide and 8 1/2" high. Tomorrow I'll start building the starboard and port side battery bank container boxes, each containing 8 cells.
- topwater
I don't think i want to know what those batteries cost
Novi 23 finally launched !
- glossieblack
And I don't think I want to tell.topwater wrote:I don't think i want to know what those batteries cost
This has been a great build to follow. Certainly it is one of the most technically interesting builds and ambitiously different as well. You've done a lot in a year. Congratulations and best wishes in the New Year for continued boat building success!
Totally unique hull design, inboard shaft and rudder, diesel power, and electric alternate power Yep everything Browndog said and then some. Like a lot of other folks I check this thread every day. Sometimes before I go to bed and then again with my morning coffee
Yeah, that says it for me.Fuzz wrote:Totally unique hull design, inboard shaft and rudder, diesel power, and electric alternate power Yep everything Browndog said and then some. Like a lot of other folks I check this thread every day. Sometimes before I go to bed and then again with my morning coffee
Every time I turn around you throw a new one at us. Those batteries should provide you plenty of secondary power. Can't wait to see you finish this boat it is such a beautiful contrast in old and new.
