MikeyGnz
Post by MikeyGnz »
glossieblack wrote: Tue Aug 03, 2021 5:04 am Muir recommended wrapping both the motor and gearbox in Denso petrolatum tape (Egyptian mummy style), while leaving the inlet and outlet openings of the air cooling fan's shroud unobstructed.
I use Denso a lot for work. There is a lot of misunderstanding about it, it is not just petrolatum tape but is a three part system. First there is a putty that is used to fill any voids, then the petrolatum infused hessian/sackcloth followed by an overwrap. From the photos of the motor the putty probably isn't needed to wrap the outside of the cylinder but I would recommend using the overwrap as well as the petrolatum tape. The overwrap is like a 100mm wide electrical tape that stops the petrolatum being washed out of the hessian over time.
Using it on buried infrastructure we find that in some cases Denso only gives 5 years protection. Given how aggressive the marine environment can be I would add replacing the Denso every few years to the maintenance job list.
Fuzz
Post by Fuzz »
So just wondering how long did the last motor last?
glossieblack
Post by glossieblack »
Thanks Jeff and Jaysen, and thanks MikeyGnz for your insights on Denso tape. :D
Fuzz wrote: Tue Aug 03, 2021 7:03 pm So just wondering how long did the last motor last?
Twenty years till the fag end, 100% reliable for first 15.
Fourth coat of varnish on helming seat and associated trim is on. :D
OrangeQuest
Post by OrangeQuest »
glossieblack wrote: Wed Aug 04, 2021 4:32 am
Seems what you did to protect it worked pretty good the first 15 years.
jonnymac
Post by jonnymac »
I wonder if just painting some cosmoline on it. Any metal parts that are shipped across the ocean are generally coated with it and we use it for long term storage of bare metal parts at the shipyard. cosmoline only comes off with acetone, so I would think it would work well.
Jaysen
Post by Jaysen »
OrangeQuest wrote: Wed Aug 04, 2021 7:33 am
GB, this may sound insensitive, but it’s not meant to be. If it lasts 15yr, is this a real problem for you? How much longer will GS be under your stewardship?
Fuzz
Post by Fuzz »
The kid said what I was thinking :P When I was deciding to foam in or not the Sintes fuel tank my buddy said well we know it will last around 20 years with foam. Will it really matter to you in 20 years. I chose not to foam but his point is still valid. I know you want the best for Great Sandy but this might be a case where the pain is not worth the gain.
MikeyGnz
Post by MikeyGnz »
Jaysen wrote: Wed Aug 04, 2021 9:24 am GB, this may sound insensitive, but it’s not meant to be. If it lasts 15yr, is this a real problem for you? How much longer will GS be under your stewardship?
Fuzz wrote: Wed Aug 04, 2021 1:43 pm The kid said what I was thinking :P When I was deciding to foam in or not the Sintes fuel tank my buddy said well we know it will last around 20 years with foam. Will it really matter to you in 20 years. I chose not to foam but his point is still valid. I know you want the best for Great Sandy but this might be a case where the pain is not worth the gain.
Valid points by Jaysen and Fuzz but need to look at how they have lasted for other people as well, pretty much every product has a few outliers that last significantly longer or shorter than average. Also has the manufacturing quality decreased in the last 15 years? I'm sure we all have stories where manufacturing quality has gone down over time as costs are cut.
Personally I would do what I can to protect it but then I like tinkering and the peace of mind from knowing it will work when required. Also should you be thinking of selling in time it is something that can be pointed to as an example of maintenance. Ultimately it will be your choice.
Fuzz
Post by Fuzz »
Valid points by MikeyGnz also. There is never a thing wrong with making something as good as you can. I would just want to know the pain was worth the gain. Nothing worse than causing new problems while trying to improve things.
glossieblack
Thanks OQ, jonnymac, Jaysen, Fuzz x2, and MikeyGnz for contributing to what to me is a fascinating discussion on boat ownership and maintenance.
What I find intriguing is that the discussion is taking place on a builders forum which I read as being heavily biased towards a 'build it right for the long haul, for yourself and future owners' value set rather than a 'build it to serve your ownership span only, and beyond that, it's the next person's problem' value set.
For me, as I build Skinnydip, I'm trying to build as a foundation steward, hopefully for generations of stewards to come.
And for me, as the deeply appreciative current steward of Great Sandy, I'm committed to handing her over to her next owner in at least as good a condition as I received her from her builder, then multi-year blue water cruising skipper, whose legacy I revere.
This is my personal choice, I'm not trying to foist it on to anybody else. :D
