Mostly just me working on it, did get some help with painting recently and other big tasks earlier in the build.
I finished up the painting by getting the first coat of bilge paint in the storage areas, under the side decks, and on the back of the inwhales.
Imgur Album
After all the painting it was nice to take a few boats out to a nearby island and camp with some friends.
Imgur Album
Alright back to the boat. I still don't know where my waterline will be, I'll test that in the water before final paint. To do that I will need a drain plug installed, so I bottom painted where the drain plug will go to be ready to install it.
Imgur Album
After that took the exciting step of having a motor put on! Dropped the boat off for the weekend, I may have driven past once or twice to make sure she was safe.
Imgur Album
Worked on the console in the mean time, building in the partition that will keep the fuel fill and vent separated from the rest of the space with a removable cover. The pipe is to pass through the wires to the switch panel since they are fixed length.
Imgur Album
I cut a slot in the back of the console shelf and added a wall to it. the wiring will run in this slot and the wall will stop things rolling off the shelf, I hope.
Imgur Album
Glued in inwhales in permanently.
Imgur Album
Then came back with my brand new 60hp suzuki. Looks great on there to me.
Imgur Album
The anti cavitation plate is about 1/2" below the bottom with the motor mounted in the lowest hole so I think a good starting point, and I have room to adjust higher if I want to.
Imgur Album
Had to build a motor stand out of my old strongback to take the motor back off. It works but is a little unstable while you are moving it, have to be real careful. It's very stable when down.
Imgur Album
In addition to the g10 backing plate on the inside of the transom for the motor I wanted to put g10 rod around the mounting bolts. I needed to enlarge the holes while staying on center which is hard with a hole saw. I ended up putting a smaller rod around the pilot bit on the hole saw. A little strange but worked well.
Imgur Album
While the motor was on I had checked clearance for the swim platform, that it would allow the motor to fully turn and tilt. So I now screwed the swim platform to the transom and tested it. Worked well, I'll glue it on after it's primed. I was planning on adding a handle on the transom for it but I think just grabbing the top of the transom will be fine.
Imgur Album
On an evening boat ride we found a boat in the color I'm going for. For a while I thought I wanted claret red, but I saw it at a boat show and it's too purple. I think I actually want vivid red? It sounds scary like it's fire engine or something but it seems to be the right color. Anyway, this boat is the color I want to paint my hull whatever color this boat is. Any guesses on if vivid red is the right awlgrip color? Always hard to tell in pictures.
Imgur Album
I glued in some plywood to give the appearance that the inwhale wraps onto the transom.
Imgur Album
Cut the ancor hatch hole out of the bow deck and glued the deck to the frame. I had constructed a curved hatch for this opening previously.
Imgur Album
