Thanks, Parkrat, It does seem a good idea to use it on attaching the hull pieces.
Ill post my progress when I actually start the build which hopefully should start a week or so after New Year.
Happy Holidays guys !
C-17 Our first Build !
Re: C-17 Our first Build !
You can use the Silvertip gel-magic for the outside hull seams as long as the temp is okay and it doesn't sag. Another member willg suggested to run blue tape along the seams underneath. I did that and tacked mine together last night using the EZ fillet. Worked real well and glad I ran the blue tape first. Didn't get anything on my garage floor. The EZ fillet is really easy to work with and doesn't sag at all.
Thats what they say about the Gel magic in their technical information. Ive never worked with either before. Ive only done lamination previously.
I guess i have a few weeks to decide. Temperature is no problem (only problem is paying the heat bill !!!!!!!). I guess either would be acceptable.
Yes, either works. I keep my garage around 70 degrees when working and I think the gel magic would have run through the seams.
Good point. Mines about 65 Degrees. How much of a gap do you leave in the keel and chine seams?
What I've gathered and did with mine is use a common nail as spacing between the seams so you can see light from the other side.
It also depends on how well you cut and draw the panels. Mine is a little wonky in places so i have some larger gaps. Once you get to that point you will probably be able to decide.
Im not doing that cutting I'm having Bateau do the cnc cutting to save me time...I usually have no time to even die (good thing) but it does put a strain on projects so anywhere I get a break i take it !
Have you thought about wood wedges (their like 3 bucks a dozen) to space the seams? Im thinking they might be very stable for you to work and adjust.
The easiest thing to get and manage is tile spacers. Available at Lowes in the tile section in sizes from 1/8 to 3/8 inch sizes. They have four legs one in the joint, two resting on the panels. Wood wedges might or might not work I can see them falling through the gaps if you don't put a nail in each one to keep them from doing so.
Thats actually a good idea. I dont suppose the gap has to be extensive so its worth using since they also take up less space.
nice.
nice.
http://gallery.bateau2.com/displayimage.php?pid=63466
Just wanted to document the very beginning and learn how to upload an image!
Thank you Jamie ! Got it...I think !
