Piece of glassed extra core I had in my reject pile.Dan_Smullen wrote: ↑Tue May 04, 2021 5:01 pmWhat did you use to create the solid edge? Is that molded epoxy/cabosil mix or an off the shelf product?fallguy1000 wrote: ↑Tue May 04, 2021 12:15 pm The downside of honeycomb is any raw edges need to be dealt with.
A second project. I will make a cabosil filler and attempt to pre-radius this thing before taping over it with woven tape.
Woods Skoota 32DM
Re: Woods Skoota 32DM
So, busy day.
I got the hatch hinge fills done.
Fixed a hydraulic hose on a mower.
And these..
Cabosil, 6 oz glass and peelply on the beam locker honeycomb bottom Pic out of order, this was pulling some cabosil to make it round before glassing. Setting bog in the hinge cutouts with cold temp epoxy. 6 oz glass on the locker end panel insides Aft beam locker coosa 20# density lid got 6 oz glass Wasted quite a bit of bog. I hate to, but it happens now n then if I try to get a lot done. This was not the cold weather stuff.
And these..
A sanding we will go...
Well, today I had some sanding and got the panels back under vac.
I had some i terruptions as well.
This is the back side and no need for any wrap and the glass is 6 oz, so not much gained pulling out resins.
Anchor locker fab work.
Welding guy brought the top.
I was wondering what you are doing with a camper in your build tent then I realized it is the cabin. That is a big boat.
Fallguy you are a magician with the foam and glass. My hat is off to you sir. Beautiful work.
Ply shots. 1.5" core cabin backbone.
Ply vertical. Beefy, heavy, but spanning and supporting a lot of weight. Needs one more tabbing/reinforcement month of May!
