TomW1 wrote: ↑Fri Aug 10, 2018 8:54 pm Hey Bob it sounds like you have a plan. Remember the LS18 is a technical skiff designed for one thing. So build it as designed and then make some changes in the cockpit to accommodate you and your wife on your sight seeing trips. That cockpit is large and gives you a lot of room to make it yours.
Tom and OQ,
Going to build to plans.
I'm going to use Peel ply on the top panel hull sides, 18'x12". I'm saving now for the Peel Ply.
The bottom will be getting the hard bottom mix. BUT NOT WITH GRAPHITE, but with Hexagonal Boron Nitride, hBn powder, white graphite. Saving up for that Too!
The whole bottom panels with be covered with three coats of hBn/epoxy mix, no need to crazy on fairing these panels.
Going to paint the hull jade green, hunter green, hinckley green, one of these dark greens.
Bob.
