Coach wrote: ↑Sun May 05, 2019 8:49 am Hi Mike to be honest I never thought about that. Its a good point. The 610 epoxy tabs between the stitches will sit for like 55 hours so I should be good after that. I will be using the Marine Epoxy from BBC the rest of the way.
If I can get the rest of the gaps filled on Monday night it will sit and cure for 4 days then I have to sand and prepare for taping the seams. Its still pretty cold up here barely making it over 50 degrees so I cant move too quickly.
Not sure it was JM, although I think it was, might have been Jeff or Reid, but I recall seeing a couple of threads about different manufacturers of epoxy and they said 7 days for a full cure between using different brands, except between the MarinEpoxy and the Silvertip epoxy. Seems I recall something about them being more compatible and just 48 hours being enough.seaslug wrote: ↑Sun May 05, 2019 6:11 pm 55 hours might be long enough, but I'm not an expert so you should check with Jacques to be sure. My other concern is your picture shows Quick Fair, a System 3 product, not the same as the Marine Epoxy, so the same situation with waiting for a full cure. I did the same thing on my first build, and the down time waiting for a full cure drove me crazy.
Before doing anything thought, drop an email to Reid, Jeff and/or JM. Any of them should be able to answer as they have discussed this issue many times in the past.
