Yes, but also, my table saw is 20 minutes away at the shop, and didn’t feel the dado was worth the drive. These cleats will support the sole in the forward compartment, so having it a little higher than the main sole will allow for the limber holes a little higher.Dan_Smullen wrote: ↑Mon Feb 15, 2021 9:20 pmThat's not boatbuilding. That's marine construction surgery!
Were you looking to add height by skipping the dado?
How do you feel about the strength of the cleat glued to the top of the stringer sans dado?
[/quote]
I think your fillets do the same job: increase the glue area between the sole bottom and the stringer, and resist bending of the stinger by forming an I beam. The closer they mimick cleats, the less you'll sweat when you hit that wake head on at speed!
