Jeffs FS14 LS
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
cracked_ribs wrote: Thu Dec 17, 2020 12:27 am That's a good trick with the deck of cards...I'll have to remember that one. I could have done a better stem template that way, I bet.
Thanks. I used the same technique to make the entire deck template for my driftboat and it worked perfectly, though I hadn't thought up the deck of cards yet: I was cutting up posterboard into small, playing-card-sized pieces.
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
gstanfield wrote: Wed Dec 16, 2020 6:03 pm Looking good!
Thank you!
I wet-out some of the 4oz this AM on my stern sole and it was not a good experience, I felt like a first-timer! The biggest issue was the fraying of the
edges. :help: I think I learned that I need to cut the pieces much more oversized and stay well clear of the edges while wetting out, then trim off the edges when it's green.
The other issues I had were with the new epoxy(MarinExpoy Fast: I have been using Silvertip Slow up till now) and the white pigment suspension I was adding. Added together, it made the epoxy feel pasty and the whole process feel a bit foreign to me and cause a little frustration and poor final results.
Good news is that I was doing this work in what will be an unseen area, under the stern deck, so it's a good place to make a mess, which I did, properly and completely. And now I know what the new epoxy feels like/works like and I'll be ready when I do the next piece.
Do you pre-glass your panels before installing?
gstanfield
Re: Jeffs FS14 LS
Post by gstanfield »
VT_Jeff wrote: Thu Dec 17, 2020 10:58 am
Thank you!
The frames I pre-glass mostly, but some panels I glass after install. With the very light glass it can be a challenge as they are definitely different than working with the heavier biaxial glass or even heavier woven. The process that works for me is like this:
~ Cut cloth to size, allowing about an inch extra on all sides.
~ Roll one coat of epoxy on panel, allow to sit until it's not runny, but still pretty sticky. The time will vary depending on temp, epoxy, hardener, etc.
~ Gently lay 4oz cloth on epoxy, repositioning as needed. This is where having it sticky helps, it's like laying down decals where the sticky holds them in place, but you can still reposition as long as you don't press down hard.
~ Once positioned where you want it roll a light coat of epoxy on top. Avoid the temptation to put it on too thick.
~ Use plastic spreader and "squeegee" the cloth, pushing it into the first layer of epoxy and getting it nice and even without air bubbles.
As to the pigments, I've never used pigments in epoxy so I have nothing to offer in that regard.
Current build: FL14 (+10%)
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
gstanfield wrote: Thu Dec 17, 2020 11:39 am ~ Cut cloth to size, allowing about an inch extra on all sides.
I'll go with this process next, much appreciated! I have a few more blind sections before I need to do my cockpit floor, so a few more chances to mess-up and learn.
gstanfield wrote: Thu Dec 17, 2020 11:39 am As to the pigments, I've never used pigments in epoxy so I have nothing to offer in that regard.
I'm going to do a batch without the pigment just so I'll know what the MarinEpoxy feels like on it's own, and then adjust from there. It should not be difficult.
Jaysen
Re: Jeffs FS14 LS
Post by Jaysen »
one thing on the squeegee... keep the edge smooth and clean or your glass gets pulled or moved. And then you have a real mess. One that temps you to get gasoline and matches. But maybe that is just me.
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
Jaysen wrote: Thu Dec 17, 2020 12:00 pm one thing on the squeegee... keep the edge smooth and clean or your glass gets pulled or moved. And then you have a real mess. One that temps you to get gasoline and matches. But maybe that is just me.
I feel your rage!
Appreciate the tip, that may have been part of the issue.
gstanfield
Re: Jeffs FS14 LS
Good point that I forgot to mention. After 30 years of doing body work I just took it for granted that it was understood to use a good spreader!
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
gstanfield wrote: Thu Dec 17, 2020 1:39 pm Good point that I forgot to mention. After 30 years of doing body work I just took it for granted that it was understood to use a good spreader!
30 years of body work? That is an insanely unfair advantage! These boats are 99% body work!
Buddy of mine who grew up in VT went to some technical college in Laramie Wy (I think it was Laramie) to study the automotive trade, specialty in body work. Probably around 1987. Runs a ski-tuning shop now.
gstanfield
Re: Jeffs FS14 LS
VT_Jeff wrote: Thu Dec 17, 2020 2:08 pm
That would be WyoTech, the original before it was sold and went downhill. I also went there in the mid 90's, but grew up restoring cars with my dad in his shop. I've done body work as a primary job here and there, but have always done restoration work as a side even when not working in the industry full time.
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
Got the Mrs. to assist on the sole wet-out this morning.
