Jeffs FS14 LS
Re: Jeffs FS14 LS
Epoxy coat 1 of 2 on the underside of the sole and coat 2 on underside of tank platform.
Re: Jeffs FS14 LS
Those tank feet look good to me. They’re not loose, it’s expansion room for the epoxy
The boat looks great.
Alan.
Re: Jeffs FS14 LS
That's right! Gaps are good gaps are good!Fair WX Pilot wrote: ↑Tue Nov 17, 2020 11:34 am They’re not loose, it’s expansion room for the epoxy
Re: Jeffs FS14 LS
Tank platform glued in, will run some biax tape on it also.
Re: Jeffs FS14 LS
Got a second, sloppy coat on the sole bottom and got parts cut for the pole platform shoes. Not convinced I'll actually pull the trigger on the platform but the shoes will go in regardless just in case.
Re: Jeffs FS14 LS
First half of platform shoes glued up.
Re: Jeffs FS14 LS
Put the load right on me!
Re: Jeffs FS14 LS
Got the other sides attached to the platform shoes. I'll trim them neat and glass them to the inside faces of the stringers at the transom. The platform legs will slide in/slide out, and the platform load will be on the stringers and not the transom. At least in theory.
Re: Jeffs FS14 LS
Aft sole cleats taking shape. Scraping the bottom of the clamp barrrel.
