TomW1 wrote: ↑Wed Mar 17, 2021 2:18 pm
Unless they are going to be side by side I don't think I would worry about it.
They will actually be in series: the inside of my cockpit rim will have trim running all the way around it. For the corners, which are radius 3", I'm making the bent lam inside radius parts from doug fir veneers I ordered, 8-9 layers stacked up and then bent as you can see above. The straight runs will use solid vert-grain doug fir stock that i already have. So the solid stock will be running directly into the veneers on each side of each corner, joined by a simple 45 degree scarf.
So the difference in grain will make it quite obvious that it is not a continuous piece running the straights and the curves, which isn't the end of the world, but this is all purely aesthetic to begin with, so getting it aesthetically right is definitely worth some consideration, time will tell exactly how much.
As I mentioned, I could "cheat" and veneer the faces of the straight runs, though something about this doesn't sit quite right, unsure exactly what.
