Jeffs FS14 LS
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
bamaguy0 wrote: Fri May 28, 2021 7:24 pm Woah! Wasn't even planning to attempt that myself. Might change my mind after I call around for quotes.
Few years back I was trying to fix up a '77 280Z and was going to reupholster the seats myself, but I at least had something to go by. That project was abandoned at a major loss when I moved from Alabama to Florida.
Too bad about the Z. There is one here in town that's pretty nice, modernized a bit. If I was gonna do a car, it would be a late 70's Toyota 4x4. May yet!
bamaguy0
Re: Jeffs FS14 LS
Post by bamaguy0 »
VT_Jeff wrote: Sat May 29, 2021 3:16 pm
It was a learning experience. I learned rust repair was not for me!
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
Getting vaxxed wont save you from the need to mask in my workshop!
bamaguy0
Re: Jeffs FS14 LS
Post by bamaguy0 »
Now that's clean. How'd you cut the radii in the tape?
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
bamaguy0 wrote: Mon May 31, 2021 9:09 pm Now that's clean. How'd you cut the radii in the tape?
Thanks. It's not as clean as it looks in the photos but the non-skid will be the same color as the deck so small imperfections shouldn't matter.
I used a variety of objects for radius templates, marked the radius on the tape with a pencil, and then used an exacto knife to cut along the line. Had my best results when I didnt try to get the cut to flow: short cuts with my palm on the deck, turning slightly after each jab. Short like a few mm per jab. This kept me on the line. It took about 7 hours start to finish for the whole mask, but none of it was difficult so the time flew. I need a lot more grit for this method, only got one lb. and could not do a whole coat with it. In this method, you put on a coat, load it with grit, let it dry, then sweep off the excess and repeat. Takes a lot of grit to load it properly, at least for me.
bamaguy0
Re: Jeffs FS14 LS
Post by bamaguy0 »
Oh OK, so you're cutting with the tape in place? I was nervous about that because I wouldn't want to cut into the paint. Will you do a final coat with straight paint?
That's interesting on the application process. I think I saw that somewhere...what's the reason to do it that way over just mixing the grit into the paint?
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
bamaguy0 wrote: Mon May 31, 2021 9:33 pm Oh OK, so you're cutting with the tape in place? I was nervous about that because I wouldn't want to cut into the paint. Will you do a final coat with straight paint?
I'm definitely cutting into the paint but those cuts are immediately getting refilled with paint when I coat it so I'm not too worried. Theres a layer of glass and epoxy so I'm not getting near the wood.
I read good things about this method over adding the grit to the paint and I liked the idea. I did it the other way with my driftboat and it didnt turn out well at all, but it may have been user error. I wanted this deck really gritty for the dog and this seemed like the best bet, time will tell and I'll keep you posted, literally.
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
For the hinge radii, I can see where you could precut the tape and then put it on the deck. But for all the corners, I cant see it, it would be a real chore imo.
bamaguy0
Re: Jeffs FS14 LS
Post by bamaguy0 »
VT_Jeff wrote: Mon May 31, 2021 9:49 pm
No I totally agree. That's what I was dreading!
VT_Jeff
Re: Jeffs FS14 LS
Post by VT_Jeff »
bamaguy0 wrote: Mon May 31, 2021 9:54 pm
Btw, this is the Z I mentioned. I tend to prefer more original looking stuff but I really dig this for whatever reason. Actually not sure if it's a 260 or 280.
Users browsing this forum: Google Feedfetcher and 5 guests
